  4. Update von node 20 auf 22: Verbindung mbus geht nicht mehr
    6.0k
5 Beiträge 3 Kommentatoren 369 Aufrufe 2 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    habe eben Update von 20 auf 22 durchgeführt.
    Alles neu gestartet.
    Die Verbindung zu mbus (auf slave) wird nicht mehr grün.
    Im log kommt:
    host.Pi-Strom-Wasser
    2026-01-01 17:21:59.402	error	instance system.adapter.mbus.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2026-01-01 17:21:59.402	error	Caught by controller[0]: Node.js v22.21.0
    2026-01-01 17:21:59.402	error	Caught by controller[0]: }
    2026-01-01 17:21:59.402	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    2026-01-01 17:21:59.401	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14) {
    2026-01-01 17:21:59.401	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-mbus/index.js:7:40)
    2026-01-01 17:21:59.401	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    2026-01-01 17:21:59.401	error	Caught by controller[0]: at require (node:internal/modules/helpers:147:16)
    2026-01-01 17:21:59.401	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
    2026-01-01 17:21:59.401	error	Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    2026-01-01 17:21:59.401	error	Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
    2026-01-01 17:21:59.401	error	Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
    2026-01-01 17:21:59.400	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
    2026-01-01 17:21:59.400	error	Caught by controller[0]: at Object..node (node:internal/modules/cjs/loader:1865:18)
    2026-01-01 17:21:59.400	error	Caught by controller[0]: Error: Module did not self-register: '/opt/iobroker/node_modules/node-mbus/build/Release/mbus.node'.
    2026-01-01 17:21:59.400	error	Caught by controller[0]: ^
    2026-01-01 17:21:59.400	error	Caught by controller[0]: throw e;
    2026-01-01 17:21:59.399	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    2026-01-01 17:21:58.203	info	instance system.adapter.mbus.0 in version "2.7.0" started with pid 993
    2026-01-01 17:21:56.133	info	"system.adapter.mbus.0" enabled
    Kann jemand damit was anfangen ?
    Soll ich wieder auf 20 downgraden ?
    Da lief alles
    Danke.
    • bahnuhrB bahnuhr
      Im log kommt:
      Da lief alles
      MCU
      @bahnuhr
      https://github.com/Apollon77/ioBroker.mbus/issues/399
      bahnuhrB Thomas BraunT 2 Antworten Letzte Antwort
      • M MCU
        @bahnuhr
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @MCU
        Danke für die Info.
        Werde ich bei Gelegenheit mal probieren.
        Danke.
        • M MCU
          @bahnuhr
          @MCU
          Hatte ich im Parallelthread auch schon empfohlen:
          https://forum.iobroker.net/topic/83424/update-von-node-20-auf-22-verbindung-cloud-geht-nicht-mehr/7
          • bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            so, bin wieder auf 22
            Und in der Tat; Adapter deinstalliert und dann wieder neu.
            Das hat geholfen.
            mfg
            Danke.
