  4. Node JS downgrade
    6.5k
Node JS downgrade
2 Beiträge 2 Kommentatoren 360 Aufrufe 2 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    kann mir jemand sagen, warum mein Node JS auf einmal ein downgrade möchte?
    ioBroker nodejs fixer 2025-08-09
    Recommended nodejs-version is: 22.21.1
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v22.21.1
    /usr/bin/node           v22.21.1
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 22.21.1-1nodesource1                                            Candidate: 22.21.0-1nodesource1                                            Version table:
     *** 22.21.1-1nodesource1 100
            100 /var/lib/dpkg/status
         22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    Nothing to do - Your installation is using the correct paths.
    Nothing to do - Your version is the recommended one.
    *** You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
    *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
    *** DO NOT use 'nodejs-update' as part of your regular update process! ***
    david@iobroker:~$ sudo apt-get update
    Hit:1 http://security.debian.org trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
    Reading package lists... Done
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    david@iobroker:~$ sudo apt-get upgrade
    Building dependency tree... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      adwaita-icon-theme android-sdk-platform-tools-common at-spi2-common
      at-spi2-core dconf-gsettings-backend dconf-service g++-12
      gsettings-desktop-schemas gtk-update-icon-cache hicolor-icon-theme
      libassuan0 libatk-bridge2.0-0t64 libatk1.0-0t64 libatspi2.0-0t64
      libavcodec59 libavdevice59 libavfilter8 libavformat59 libavutil57
      libcloudproviders0 libcodec2-1.0 libcolord2 libcups2t64 libdav1d6
      libdconf1 libdrm-nouveau2 libdrm-radeon1 libepoxy0 libflac12
      libgirepository-1.0-1 libglapi-mesa libgtk-3-0t64 libgtk-3-bin
      libgtk-3-common libjsoncpp25 libjxl0.7 libllvm15 libmbedcrypto7 libmfx1
      libnsl-dev libplacebo208 libpostproc56 libpthread-stubs0-dev librav1e0
      librhash0 libssh-gcrypt-4 libstdc++-12-dev libsvtav1enc1 libswresample4
      libswscale6 libtheora0 libtirpc-dev libutempter0 libvpx7 libx265-199
      libxcb-dri2-0 libxinerama1 libxtst6 x11proto-core-dev
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      base-files curl distro-info-data libcups2t64 libcurl3t64-gnutls
      libcurl4t64 libnss-systemd libpam-systemd libssh-4 libssl3t64
      libsystemd-dev libsystemd-shared libsystemd0 libtalloc2 libudev-dev
      libudev1 libwbclient0 libwtmpdb0 libxml2 libxml2-dev linux-libc-dev mc
      mc-data openssl openssl-provider-legacy postfix systemd
      systemd-cryptsetup systemd-sysv systemd-timesyncd udev x11-common
    The following packages will be DOWNGRADED:
      nodejs
    32 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
    Need to get 61.0 MB of archives.
    After this operation, 5,120 B of additional disk space will be used.
    Do you want to continue? [Y/n]
    • David G.D David G.
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
           20.19.2+dfsg-1 500
        nodejs
      @David-G. said in Node JS downgrade:
      Ja. Die nodesource-Quelle ist so hoch priorisiert, das apt dann auch downgrades durchführen will. Die 22.21.1-1nodesource1 gibt es nicht mehr im Repository.
      Issue dazu:
      https://github.com/nodesource/distributions/issues/1897
