  4. Fehler bei mehreren Adaptern nach öffnen der Instanz
    6.0k
6 Beiträge 3 Kommentatoren 466 Aufrufe 3 Beobachtet
  • J Offline
    Jan201
    Moin,
    Nach dem öffnen der Instanzen: I-Cal, trashschedule, vis-2, bekomme ich folgende Meldung:
    2025-10-31 11:09:39.390 - warn: admin.0 (5166) vis-2 has an invalid jsonConfig: [{"instancePath":"/items/loading/items/loading-bg.png/accept","schemaPath":"#/patternProperties/%5E.%2B/allOf/10/then/properties/accept/type","keyword":"type","params":{"type":"object"},"message":"must be object"},{"instancePath":"/items/loading","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
    Iob Diag sagt:
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: IoBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.8-2-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:17:11 up 2 days, 17:43,  1 user,  load average: 0.50, 0.27, 0.19
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2025-10-31 11:17:11 CET
               Universal time: Fri 2025-10-31 10:17:11 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout sudo audio video plugdev users
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/iobroker
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            4.3G        2.6G        621M        3.1M        1.1G        1.7G
    Swap:           536M        7.3M        529M
    Total:          4.8G        2.6G        1.2G
    Active iob-Instances:   20
             4096 M total memory
             2504 M used memory
             2563 M active memory
              674 M inactive memory
              592 M free memory
                0 M buffer memory
             1002 M swap cache
              512 M total swap
                6 M used swap
              505 M free swap
    top - 11:17:12 up 2 days, 17:43,  1 user,  load average: 0.50, 0.27, 0.19
    Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.0 us,  4.2 sy,  0.0 ni, 40.6 id, 54.2 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,    590.5 free,   2505.4 used,   1003.0 buff/cache
    MiB Swap:    512.0 total,    505.0 free,      7.0 used.   1590.6 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    [sudo] password for iobroker:
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       12G  4.8G  6.4G  43% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  120K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     3.9G  3.0M  3.8G   1% /tmp
    tmpfs                            tmpfs     779M  4.0K  779M   1% /run/user/1000
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    454M    /var/
    275M    /var/cache
    272M    /var/cache/apt
    181M    /var/cache/apt/archives
    161M    /var/lib
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    273M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    756M    /opt/iobroker/iobroker-data/
    635M    /opt/iobroker/iobroker-data/files
    233M    /opt/iobroker/iobroker-data/files/vis
    225M    /opt/iobroker/iobroker-data/files/vis/widgets
    122M    /opt/iobroker/iobroker-data/files/vis-2
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    14M     /opt/iobroker/iobroker-data/states.jsonl
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IoBroker            IoBroker (version: 7.0.7, hostname: IoBroker      , alive, uptime: 235498)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : IoBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
      system.adapter.bring.0                  : bring                 : IoBroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : IoBroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : IoBroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : IoBroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : IoBroker                                 - disabled
      system.adapter.eventlist.0              : eventlist             : IoBroker                                 - disabled
      system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
      system.adapter.fullcalendar.0           : fullcalendar          : IoBroker                                 - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker                                 -  enabled
    + system.adapter.history.0                : history               : IoBroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : IoBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : IoBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoBroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
      system.adapter.mqtt-client.0            : mqtt-client           : IoBroker                                 - disabled, port: 1884
    + system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.reolink.0                : reolink               : IoBroker                                 - disabled
      system.adapter.ring.0                   : ring                  : IoBroker                                 - disabled
    + system.adapter.shelly.0                 : shelly                : IoBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : IoBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 - disabled
      system.adapter.spotify-premium.0        : spotify-premium       : IoBroker                                 - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
    + system.adapter.time-switch.0            : time-switch           : IoBroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : IoBroker                                 - disabled
    + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : IoBroker                                 -  enabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: IoBroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IoBroker                                 - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IoBroker                                 -  enabled
      system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : IoBroker                                 - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: IoBroker                                 - disabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: IoBroker                                 - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IoBroker                                 - disabled
      system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: IoBroker                                 - disabled
    + system.adapter.vis-2.0                  : vis-2                 : IoBroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IoBroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : IoBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : IoBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : IoBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : IoBroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : IoBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : IoBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : IoBroker                                 - disabled
    + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : IoBroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "bring"        : 1.9.1    , installed 1.9.1
    Adapter    "daswetter"    : 3.2.6    , installed 3.2.6
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "eventlist"    : 2.1.0    , installed 2.1.0
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "ring"         : 6.4.0    , installed 6.4.0
    Adapter    "shelly"       : 10.4.0   , installed 10.4.0
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "spotify-premium": 1.5.3  , installed 1.5.3
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
    Adapter    "trashschedule": 4.0.1    , installed 4.0.1
    Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
    Adapter    "vis-2"        : 2.13.6   , installed 2.13.6
    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
    Adapter    "vis-2-widgets-icontwo": 1.18.0, installed 1.18.0
    Adapter    "vis-2-widgets-inventwo": 0.3.9, installed 0.3.9
    Adapter    "vis-2-widgets-jaeger-design": 1.4.9, installed 1.4.9
    Adapter    "vis-2-widgets-material": 1.6.0, installed 1.6.0
    Adapter    "vis-2-widgets-weather-and-heating": 1.1.5, installed 1.1.5
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.9    , installed 7.0.9
    Adapter    "ws"           : 3.0.19   , installed 3.0.19
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Objects and States
    Objects:        12073
    States:         10629
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://security.debian.org trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1124018    271/master
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1160265    1731/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1161269    1731/iobroker.js-co
    tcp        0      0 192.168.178.62:42001    0.0.0.0:*               LISTEN      1000       1217795    5272/io.hm-rpc.0
    tcp        0      0 192.168.178.62:42010    0.0.0.0:*               LISTEN      1000       1217825    5283/io.hm-rpc.1
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1122562    1/init
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       1218145    5403/io.shelly.1
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       1421800    7955/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1218115    5410/io.sonoff.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1214003    5166/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1216458    5554/io.web.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1124019    271/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1123582    1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1122564    1/init
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       1218023    5362/io.mihome-vacu
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1216299    5396/io.shelly.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1122563    1/init
    udp6       0      0 :::111                  :::*                                0          1122565    1/init
    2025-10-31 11:15:14.648  - info: admin.0 (5166) ==> Connected system.user.admin from ::ffff:192.168.178.70
    2025-10-31 11:15:16.062  - info: host.IoBroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 67400
    2025-10-31 11:15:17.351  - info: admin.0 (5166) <== Disconnect system.user.admin from ::ffff:192.168.178.70
    2025-10-31 11:15:18.784  - info: host.IoBroker "system.adapter.yahka.0" disabled
    2025-10-31 11:15:18.784  - info: host.IoBroker stopInstance system.adapter.yahka.0 (force=false, process=true)
    2025-10-31 11:15:18.799  - info: yahka.0 (5625) Got terminate signal TERMINATE_YOURSELF
    2025-10-31 11:15:18.815  - info: yahka.0 (5625) cleaning up ...
    2025-10-31 11:15:18.816  - info: yahka.0 (5625) cleaned up ...
    2025-10-31 11:15:18.817  - info: yahka.0 (5625) terminating
    2025-10-31 11:15:18.818  - info: yahka.0 (5625) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-10-31 11:15:18.921  - info: host.IoBroker stopInstance system.adapter.yahka.0 send kill signal
    2025-10-31 11:15:19.191  - info: tvspielfilm.0 (67400) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v22.21.0, js-controller: 7.0.7
    2025-10-31 11:15:19.322  - info: yahka.0 (5625) terminating
    2025-10-31 11:15:19.431  - info: host.IoBroker instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-10-31 11:15:21.269  - info: tvspielfilm.0 (67400) objects written
    2025-10-31 11:15:25.048  - info: daswetter.0 (67383) still wrong data structure from server received! repaired...
    2025-10-31 11:15:27.065  - info: host.IoBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 67415
    2025-10-31 11:15:29.973  - info: dwd.0 (67415) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.21.0, js-controller: 7.0.7
    2025-10-31 11:15:30.714  - info: dwd.0 (67415) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-10-31 11:15:30.922  - info: daswetter.0 (67383) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-10-31 11:15:31.250  - info: host.IoBroker instance system.adapter.dwd.0 having pid 67415 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-10-31 11:15:31.435  - info: daswetter.0 (67383) cleaned everything up...
    2025-10-31 11:15:31.456  - info: host.IoBroker instance system.adapter.daswetter.0 having pid 67383 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-10-31 11:15:31.776  - info: tvspielfilm.0 (67400) Terminated (NO_ERROR): Without reason
    2025-10-31 11:15:32.307  - info: host.IoBroker instance system.adapter.tvspielfilm.0 having pid 67400 terminated with code 0 (NO_ERROR)
    iob diag has finished.
    iobroker@IoBroker:~$ ========== Start marking the full check here ===========
    Script v.2025-08-09
    *** BASE SYSTEM ***
      Virtualization: lxc
    OS is similar to:
    Docker          : false
    Kernel          : x86_64
    Userland        : 64 bit
    CPU threads: 2
                     RTC time: n/a
              RTC in local TZ: no
    iobroker
    HOME=/home/iobroker
    iobroker
    HOME=/home/iobroker
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
             4096 M total memory
             2504 M used memory
              592 M free memory
                0 M buffer memory
             1002 M swap cache
              512 M total swap
                6 M used swap
              505 M free swap
    iob diag has finished.l here for C&P =============tance system.adapter.tvspielfilm.0 having pid 67400 terminated with code 0 (NO_ERROR)QUESTED_TERMINATION)enter: 7.0.7
    [/s]
    |Hardwaresystem:| NUC|
    |Arbeitsspeicher:| 8GB |
    |Festplattenart:| 250gb SSD |
    |Betriebssystem:| Proxmox , Ubuntu 21.10 |
    |Node-Version:| vv20.15.1 |
    |Nodejs-Version:| vv20.15.1 |
    |NPM-Version:| 10.7.0 |
    Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
    • J Jan201
      Moin,
      Iob Diag sagt:
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               4096 M total memory
               2504 M used memory
                592 M free memory
                  0 M buffer memory
               1002 M swap cache
                512 M total swap
                  6 M used swap
                505 M free swap
      *** FILESYSTEM ***
      /var:
      454M    /var/
      275M    /var/cache
      272M    /var/cache/apt
      161M    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.19
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:        12073
      States:         10629
      Pending Updates: 0
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               4096 M total memory
               2504 M used memory
                592 M free memory
                  0 M buffer memory
               1002 M swap cache
                512 M total swap
                  6 M used swap
                505 M free swap
      [/s]
      @jan201 sagte in Fehler bei mehreren Adaptern nach öffnen der Instanz:
      Tu das.
      Schalt das um.
      Die eigentliche Meldung ist soweit aber harmlos.
      J 1 Antwort Letzte Antwort
      • J Jan201
        Moin,
        Iob Diag sagt:
        Script v.2025-08-09
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 2
                         RTC time: n/a
                  RTC in local TZ: no
        iobroker
        HOME=/home/iobroker
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 4096 M total memory
                 2504 M used memory
                  592 M free memory
                    0 M buffer memory
                 1002 M swap cache
                  512 M total swap
                    6 M used swap
                  505 M free swap
        *** FILESYSTEM ***
        /var:
        454M    /var/
        275M    /var/cache
        272M    /var/cache/apt
        161M    /var/lib
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.19
        javascript:     9.0.11
        Adapter State
        + instance is alive
        Objects and States
        Objects:        12073
        States:         10629
        Pending Updates: 0
        Script v.2025-08-09
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 2
                         RTC time: n/a
                  RTC in local TZ: no
        iobroker
        HOME=/home/iobroker
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 4096 M total memory
                 2504 M used memory
                  592 M free memory
                    0 M buffer memory
                 1002 M swap cache
                  512 M total swap
                    6 M used swap
                  505 M free swap
        [/s]
        mcm1957M Offline
        mcm1957M Offline
        mcm1957
        @jan201 said in Fehler bei mehreren Adaptern nach öffnen der Instanz:
        Moin,
        Iob Diag sagt:
        Script v.2025-08-09
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 2
                         RTC time: n/a
                  RTC in local TZ: no
        iobroker
        HOME=/home/iobroker
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 4096 M total memory
                 2504 M used memory
                  592 M free memory
                    0 M buffer memory
                 1002 M swap cache
                  512 M total swap
                    6 M used swap
                  505 M free swap
        *** FILESYSTEM ***
        /var:
        454M    /var/
        275M    /var/cache
        272M    /var/cache/apt
        161M    /var/lib
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.19
        javascript:     9.0.11
        Adapter State
        + instance is alive
        Objects and States
        Objects:        12073
        States:         10629
        Pending Updates: 0
        Script v.2025-08-09
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 2
                         RTC time: n/a
                  RTC in local TZ: no
        iobroker
        HOME=/home/iobroker
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 4096 M total memory
                 2504 M used memory
                  592 M free memory
                    0 M buffer memory
                 1002 M swap cache
                  512 M total swap
                    6 M used swap
                  505 M free swap
        [/s]
        Mach mit den jeweiligen Meldungen ein Issue beim betroffenen Adapter auf - sofern noch kein Issue dazu existiert. Obige Meldung betrifft vis-2
        Welche Meldungen du voin ical und trashschedule bekommts ist daraus nicht zu sehen. Ebensowenig welche Versionen der betroffenen Adapter zu verwendest.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
          Tu das.
          Schalt das um.
          Jan201
          nach ausführen von iob fix hat sich nichts weiter mit der Medung geändert:
          2025-11-04 08:51:15.588 - info: web.0 (114941) starting. Version 7.0.9 in /opt/iobroker/node_modules/iobroker.web, node: v22.21.0, js-controller: 7.0.7
          2025-11-04 08:51:16.805 - info: web.0 (114941) socket.io server listening on port 8082
          2025-11-04 08:51:16.835 - info: web.0 (114941) http server listening on port 8082
          2025-11-04 08:51:18.860 - info: web.0 (114941) ==> Connected system.user.admin from ::ffff:192.168.178.199
          2025-11-04 08:51:25.154 - info: vis.0 (114624) Uploaded. 0
          2025-11-04 08:51:25.670 - info: vis.0 (114624) Terminated (NO_ERROR): Without reason
          2025-11-04 08:51:26.496 - info: host.IoBroker instance system.adapter.vis.0 terminated while should be started once
          2025-11-04 08:51:27.631 - info: tankerkoenig.0 (114862) Start first request
          2025-11-04 08:51:32.460 - warn: admin.0 (114469) ical has an invalid jsonConfig: [{"instancePath":"/items/_calendars/items/calendars/items/5","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_calendars/items/calendars","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"/items/_calendars","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
          2025-11-04 08:51:38.573 - error: daswetter.0 (114832) force terminate
          2025-11-04 08:51:38.575 - warn: daswetter.0 (114832) Terminated (UNKNOWN_ERROR): Without reason
          2025-11-04 08:51:39.100 - error: daswetter.0 (114832) exception in await insertIntoList [Error: DB closed]
          2025-11-04 08:51:39.101 - error: daswetter.0 (114832) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_13.symbol_value2": Connection is closed.
          2025-11-04 08:51:39.104 - error: daswetter.0 (114832) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_13.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_13.symbol_value2": Connection is closed.]
          2025-11-04 08:51:39.110 - error: daswetter.0 (114832) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_13.symbol_desc": Connection is closed.
          2025-11-04 08:51:39.217 - error: host.IoBroker instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
          2025-11-04 08:51:42.434 - info: shelly.1 (114783) [MQTT] Device with client id "shelly2pmg3-8cbfea94ad7c" connected from 192.168.178.85!
          2025-11-04 08:51:49.523 - info: web.0 (114941) <== Disconnect system.user.admin from ::ffff:192.168.178.199
          2025-11-04 08:51:52.852 - info: web.0 (114941) ==> Connected system.user.admin from ::ffff:192.168.178.199
          2025-11-04 08:53:23.924 - warn: admin.0 (114469) vis-2 has an invalid jsonConfig: [{"instancePath":"/items/loading/items/loading-bg.png/accept","schemaPath":"#/patternProperties/%5E.%2B/allOf/10/then/properties/accept/type","keyword":"type","params":{"type":"object"},"message":"must be object"},{"instancePath":"/items/loading","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
          2025-11-04 08:53:43.213 - warn: admin.0 (114469) trashschedule has an invalid jsonConfig: [{"instancePath":"/items/_advanced/items/trashtypes/items/4","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_advanced/items/trashtypes","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"/items/_advanced","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
          2025-11-04 08:54:45.391 - warn: admin.0 (114469) ical has an invalid jsonConfig: [{"instancePath":"/items/_calendars/items/calendars/items/5","schemaPath":"#/items/allOf/6/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_calendars/items/calendars","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"/items/_calendars","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
          • J Jan201
            @jan201
            • mcm1957M mcm1957
              Moin,
              Iob Diag sagt:
              Script v.2025-08-09
              *** BASE SYSTEM ***
                Virtualization: lxc
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 2
                               RTC time: n/a
                        RTC in local TZ: no
              iobroker
              HOME=/home/iobroker
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
                       4096 M total memory
                       2504 M used memory
                        592 M free memory
                          0 M buffer memory
                       1002 M swap cache
                        512 M total swap
                          6 M used swap
                        505 M free swap
              *** FILESYSTEM ***
              /var:
              454M    /var/
              275M    /var/cache
              272M    /var/cache/apt
              161M    /var/lib
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
                   20.19.2+dfsg-1 500
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.19
              javascript:     9.0.11
              Adapter State
              + instance is alive
              Objects and States
              Objects:        12073
              States:         10629
              Pending Updates: 0
              Script v.2025-08-09
              *** BASE SYSTEM ***
                Virtualization: lxc
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 2
                               RTC time: n/a
                        RTC in local TZ: no
              iobroker
              HOME=/home/iobroker
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
                       4096 M total memory
                       2504 M used memory
                        592 M free memory
                          0 M buffer memory
                       1002 M swap cache
                        512 M total swap
                          6 M used swap
                        505 M free swap
              [/s]
              mcm1957M Offline
              mcm1957M Offline
              mcm1957
              @mcm1957 said in Fehler bei mehreren Adaptern nach öffnen der Instanz:
              Hast du bitte für die 'has an invalid jsonConfig' Meldungen ein Issue in den einzelnen Adapter Repos gemacht? Ohne Issue ist keine Analyse und keine Behebung zu erwarten.
