  2. English
  3. Scripting / Logic
  5. Modbus Register of Wallbox
    6.8k
2 Beiträge 2 Kommentatoren 1.1k Aufrufe 2 Beobachtet
    maxnomo
    Re: E3DC Hauskraftwerk steuern
    Hi Arno, i am not familar with iobroker, ido all my stuff in HOMEASSISTANT. I have a "E3DC 10Pro" and an "easy connect" wallbox. I have access to the MODBUS registers of the E3DC machine. Afaik the "Hauskraftwerk" does directly communicate to the wallbox, although the "Wallbox" has an extra and different IP adress. In your documentation you mention registers of the wallbox. in the range of 100....528
    I tried to get access to some of this registers, like "128" meaning - in your documentation: "total_kwh - Gesamtzaehler kWh" - according to the file : "Modbus_E3DC_Wallbox_Import_Eingangsregister.tsv" - but without success.
    So my question is if i used the registers in the right way, accessing the IP adress of the wallbox and reading the right registers:
    - name: wallbox_
      type: tcp
      host: 192.168.2.177
      port: 502
      delay: 1
      sensors:
      # Abfrage Status Wallbox
        - name: e3dc_wallbox_ex_WB
          scan_interval: 6
          unit_of_measurement: W
          address: 128
          device_class: power
    error code is: wallbox_: Error: device: 1 address: 128 -> Modbus Error: [Input/Output] No response received after 3 retries, continue with next request
    Any hints are welcome....
    • M maxnomo
      - name: wallbox_
        type: tcp
        host: 192.168.2.177
        port: 502
        delay: 1
        sensors:
            scan_interval: 6
            address: 128
            device_class: power
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @maxnomo
      Do you want to migrate to ioBroker?
      Do you have problems with the iobroker modbus adapter?
      This forum is NOT related to home assistent. So if you question relates to an home asisstent problme, please ask that some ha forum.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
