  4. npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie
    6.5k
35 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • meuteM Offline
    meuteM Offline
    meute
    ich habe nach der Top-Anleitung das Debian-Upgrade von 12 bookworm zu 13 trixie gemacht.
    Es hat soweit geklappt.
    Aber ich erhalte bei iob diag einen npm error.
    Wie kann ich den Fehler beheben?
    $ iob diag
    [sudo] Passwort für mf:
    *** iob diag is starting up, please wait ***
    npm error code ELSPROBLEMS
    npm error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
    npm error missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
    npm error missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
    npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
    npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
    npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
    npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
    npm error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    * Some output is masked. For full results please use 'iob diag --unmask' *
    Press any key to continue
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker84
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.11-3-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:42:36 up 3 min,  1 user,  load average: 0.80, 1.12, 1.01
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-10-12 11:42:36 CEST
               Universal time: Sun 2025-10-12 09:42:36 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    mf
    HOME=/home/mf
    GROUPS=mf adm sudo users iobroker lxc_shares
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/mf
    GROUPS=iobroker tty dialout audio video plugdev lxc_shares
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.3G        1.3G        2.6G        3.9M        470M        3.0G
    Swap:           536M          0B        536M
    Total:          4.8G        1.3G        3.1G
    Active iob-Instances:   15
             4096 M total memory
             1203 M used memory
             1449 M active memory
              127 M inactive memory
             2446 M free memory
                0 M buffer memory
              449 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 11:42:37 up 3 min,  1 user,  load average: 0.80, 1.12, 1.01
    Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  4.0 us,  4.0 sy,  0.0 ni, 88.0 id,  4.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,   2445.0 free,   1205.2 used,    449.4 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2890.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                                  Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0            ext4       12G  7.7G  3.5G  70% /
    //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs      467G   51G  416G  11% /mnt/nas8
    none                                        tmpfs     492K  4.0K  488K   1% /dev
    udev                                        devtmpfs  9.7G     0  9.7G   0% /dev/tty
    tmpfs                                       tmpfs     9.7G     0  9.7G   0% /dev/shm
    tmpfs                                       tmpfs     3.9G  3.3M  3.9G   1% /run
    tmpfs                                       tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                                       tmpfs     9.7G  460K  9.7G   1% /tmp
    tmpfs                                       tmpfs     2.0G  8.0K  2.0G   1% /run/user/1000
    Show mounted filesystems:
    TARGET      SOURCE                                      FSTYPE OPTIONS
    /           /dev/mapper/pve-vm--100--disk--0            ext4   rw,relatime,stripe=16
    `-/mnt/nas8 //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs   rw,relatime,vers=3.0,cache=strict,upcall_target=app,username=fritznas,uid=100000,forceuid,gid=110000,forcegid,addr=192.168.23.8,file_mode=0770,dir_mode=0770,soft,nounix,mapposix,reparse=nfs,nativesocket,symlink=native,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    /var:
    2.7G    /var/
    1.3G    /var/log/journal
    1.3G    /var/log
    1.2G    /var/cache/apt
    1.2G    /var/cache
    Archived and active journals take up 1G in the file system.
    /opt/iobroker/backups:
    69M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    369M    /opt/iobroker/iobroker-data/
    300M    /opt/iobroker/iobroker-data/files
    67M     /opt/iobroker/iobroker-data/files/echarts.admin
    61M     /opt/iobroker/iobroker-data/files/echarts
    53M     /opt/iobroker/iobroker-data/backup-objects
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
    18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.20.0
    /usr/bin/node           v22.20.0
    /usr/bin/npm            11.6.2
    /usr/bin/npx            11.6.2
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.20.0-1nodesource1
      Candidate: 22.20.0-1nodesource1
      Version table:
     *** 22.20.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker84          iobroker84 (version: 7.0.7, hostname: iobroker84    , alive, uptime: 183)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker84                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iobroker84                               - disabled
    + system.adapter.backitup.0               : backitup              : iobroker84                               -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker84                               -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker84                               -  enabled
      system.adapter.ical.0                   : ical                  : iobroker84                               -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker84                               -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : iobroker84                               -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker84                               -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker84                               -  enabled
      system.adapter.ping.0                   : ping                  : iobroker84                               - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker84                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker84                               -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker84                               -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker84                               -  enabled
    + system.adapter.web.0                    : web                   : iobroker84                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker84                               -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "ical"         : 1.17.0   , installed 1.17.0
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "shelly"       : 10.2.0   , installed 10.2.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        1346
    States:         1056
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://security.debian.org trixie-security InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30392745   277/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30392287   277/iobroker.js-con
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          30392581   264/smbd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30390652   1/init
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          30392580   264/smbd
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       30393200   450/io.sonoff.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       30392832   313/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30396478   525/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        30392118   192/influxd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          30392579   264/smbd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          30390654   1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          30391102   1/init
    tcp6       0      0 :::445                  :::*                    LISTEN      0          30392578   264/smbd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30390653   1/init
    udp        0      0 192.168.23.255:137      0.0.0.0:*                           0          30392381   222/nmbd
    udp        0      0 192.168.23.84:137       0.0.0.0:*                           0          30392380   222/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          30392368   222/nmbd
    udp        0      0 192.168.23.255:138      0.0.0.0:*                           0          30392383   222/nmbd
    udp        0      0 192.168.23.84:138       0.0.0.0:*                           0          30392382   222/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          30392369   222/nmbd
    udp        0      0 192.168.23.84:5353      0.0.0.0:*                           1001       30396440   495/io.tr-064.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       30393134   430/io.shelly.0
    udp6       0      0 :::111                  :::*                                0          30390655   1/init
    2025-10-12 11:40:23.767  - info: host.iobroker84 instance system.adapter.web.0 in version "7.0.8" started with pid 525
    2025-10-12 11:40:25.537  - info: web.0 (525) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.20.0, js-controller: 7.0.7
    2025-10-12 11:40:25.795  - info: web.0 (525) socket.io server listening on port 8082
    2025-10-12 11:40:25.799  - info: web.0 (525) http server listening on port 8082
    2025-10-12 11:40:27.762  - info: host.iobroker84 instance system.adapter.iqontrol.0 in version "3.0.0" started with pid 540
    2025-10-12 11:40:29.125  - info: iqontrol.0 (540) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v22.20.0, js-controller: 7.0.7
    2025-10-12 11:40:29.169  - info: iqontrol.0 (540) systemLanguage = de
    2025-10-12 11:40:29.170  - info: iqontrol.0 (540) Creating Passphrase...
    2025-10-12 11:40:29.217  - info: iqontrol.0 (540) Creating Popup States...
    2025-10-12 11:40:29.290  - info: iqontrol.0 (540) Creating Widget States...
    2025-10-12 11:40:29.291  - info: iqontrol.0 (540) Lists deactivated.
    2025-10-12 11:40:29.292  - info: iqontrol.0 (540) Deleting unused Objects...
    2025-10-12 11:40:29.292  - info: iqontrol.0 (540) Subscribing to states...
    2025-10-12 11:40:29.294  - info: iqontrol.0 (540) iQontrol ready.
    2025-10-12 11:40:31.715  - info: host.iobroker84 instance system.adapter.trashschedule.0 in version "3.3.0" started with pid 555
    2025-10-12 11:40:33.165  - info: trashschedule.0 (555) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v22.20.0, js-controller: 7.0.7
    2025-10-12 11:40:33.243  - info: trashschedule.0 (555) [onReady] starting with source "ical" -> ical
    2025-10-12 11:40:33.249  - info: trashschedule.0 (555) [ical] configured ical preview is 45 days (until 26.11.2025) - increase this value to find more events in the future
    2025-10-12 11:40:35.666  - info: host.iobroker84 instance system.adapter.echarts.0 in version "1.9.2" started with pid 570
    2025-10-12 11:40:36.881  - info: echarts.0 (570) starting. Version 1.9.2 in /opt/iobroker/node_modules/iobroker.echarts, node: v22.20.0, js-controller: 7.0.7
    2025-10-12 11:40:52.818  - info: sonoff.0 (450) Client [Steckdose01] connected with secret 1760262052812_6539
    2025-10-12 11:40:52.978  - info: sonoff.0 (450) Client [Steckdose02] connected with secret 1760262052977_7832
    2025-10-12 11:40:53.209  - info: sonoff.0 (450) Client [Stromzaehler] connected with secret 1760262053207_304
    2025-10-12 11:41:20.278  - info: admin.0 (313) ==> Connected system.user.admin from ::ffff:192.168.23.27
    2025-10-12 11:41:35.334  - info: admin.0 (313) <== Disconnect system.user.admin from ::ffff:192.168.23.27 admin
    iob diag has finished.
    EDIT:
    Hier der Inhalt vom npm-Log /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
    $ cat /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@11.6.2
    2 info using node@v22.20.0
    3 silly config load:file:/usr/lib/node_modules/npm/npmrc
    4 silly config load:file:/opt/iobroker/.npmrc
    5 silly config load:file:/home/mf/.npmrc
    6 silly config load:file:/usr/etc/npmrc
    7 verbose title npm ls
    8 verbose argv "ls" "--all"
    9 verbose logfile logs-max:10 dir:/home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-
    10 verbose logfile /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
    11 silly logfile start cleaning logs, removing 1 files
    12 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
    13 silly logfile done cleaning log files
    14 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.js-controller
    15 verbose stack Error: invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
    15 verbose stack missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
    15 verbose stack missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
    15 verbose stack missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
    15 verbose stack missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
    15 verbose stack missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
    15 verbose stack missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
    15 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:206:9)
    15 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:208:9)
    15 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:67:5)
    16 error code ELSPROBLEMS
    17 error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
    17 error missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
    17 error missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
    17 error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
    17 error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
    17 error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
    17 error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
    18 verbose cwd /opt/iobroker
    19 verbose os Linux 6.14.11-3-pve
    20 verbose node v22.20.0
    21 verbose npm  v11.6.2
    22 verbose exit 1
    23 verbose code 1
    24 error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
    fraenk for friends Code: MATF103
    • meuteM meute
      $ iob diag
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      mf
      HOME=/home/mf
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/mf
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           536M          0B        536M
               4096 M total memory
               1203 M used memory
               2446 M free memory
                  0 M buffer memory
                449 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      2.7G    /var/
      1.3G    /var/log
      1.2G    /var/cache/apt
      1.2G    /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            11.6.2
      /usr/bin/npx            11.6.2
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        1346
      States:         1056
      Pending Updates: 0
      EDIT:
      22 verbose exit 1
      23 verbose code 1
      @meute sagte in npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie:
      @csstools/css-calc
      Aus welcher Ecke kommt das denn?
      cd /opt/iobroker && npm ls @csstools/css-calc
      mal anschauen.
      OliverIOO meuteM 2 Antworten Letzte Antwort
        @csstools/css-calc
        mal anschauen.
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @thomas-braun sagte in npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie:
        csstools/css-calc
        der github suche nach vom webui adapter
        https://github.com/search?q=iobroker+csstools%2Fcss-calc&type=code
        Meine Adapter und Widgets
        Links im Profil
          @csstools/css-calc
          mal anschauen.
          meuteM Offline
          meuteM Offline
          meute
          mal anschauen.
          Hier das Ergebnis:
          $ cd /opt/iobroker && npm ls @csstools/css-calc
          iobroker.inst@3.0.0 /opt/iobroker
          └─┬ iobroker.echarts@1.9.2
            └─┬ jsdom@25.0.1
              └─┬ cssstyle@4.6.0
                └─┬ @asamuzakjp/css-color@3.2.0
                  ├── @csstools/css-calc@2.1.4
                  └─┬ @csstools/css-color-parser@3.1.0
                    └── @csstools/css-calc@2.1.4 deduped
          • meuteM meute
            mal anschauen.
            Hier das Ergebnis:
              └─┬ jsdom@25.0.1
                └─┬ cssstyle@4.6.0
            @meute
            Dann installier den echarts nochmal drüber oder versuch es mal mit der Beta 2.0.10.
            meuteM 1 Antwort Letzte Antwort
              @meute
              meuteM Offline
              meuteM Offline
              meute
              schrieb am zuletzt editiert von meute
              @meute
              Ich habe iobroker install und iobroker upgrade ausgeführt.
              Reicht das? Oder wie muss man drüber installieren?
              $ iobroker install echarts
              adapter "echarts" already installed. Use "upgrade" to upgrade to a newer version.
              $ iobroker upgrade echarts
              Adapter "echarts"        is up to date.
              EDIT:
              Der npm error bei iob diag ist noch vorhanden.
              • meuteM meute
                @meute
                EDIT:
                @meute
                iob upgrade iobroker.echarts@1.9.2 --debug
                  @meute
                  meuteM Offline
                  meuteM Offline
                  meute
                  @meute
                  Ich habe den Adapter echarts nun drüber installiert:
                  $ iob upgrade iobroker.echarts@1.9.2 --debug
                  Would you like to reinstall version 1.9.2 of echarts now? [(y)es, (n)o]: y
                  Update echarts from @1.9.2 to @1.9.2
                  Uninstall npm packet "iobroker.echarts" for a clean re-installation
                  removed 37 packages in 6s
                  104 packages are looking for funding
                    run `npm fund` for details
                  NPM version: 11.6.2
                  Installing iobroker.echarts@1.9.2... (System call)
                  npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                  npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                  npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                  npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                  npm warn deprecated gauge@3.0.2: This package is no longer supported.
                  added 71 packages in 10s
                  108 packages are looking for funding
                  upload [17] echarts /opt/iobroker/node_modules/iobroker.echarts/www/asset-manifest.json asset-manifest.json application/json
                  upload [16] echarts /opt/iobroker/node_modules/iobroker.echarts/www/favicon.ico favicon.ico image/vnd.microsoft.icon
                  upload [15] echarts /opt/iobroker/node_modules/iobroker.echarts/www/index.html index.html text/html
                  upload [14] echarts /opt/iobroker/node_modules/iobroker.echarts/www/manifest.json manifest.json application/json
                  upload [13] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/asset-manifest.json preview/asset-manifest.json application/json
                  upload [12] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/favicon.ico preview/favicon.ico image/vnd.microsoft.icon
                  upload [11] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/index.html preview/index.html text/html
                  upload [10] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/manifest.json preview/manifest.json application/json
                  upload [9] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/css/main.e631bfb5.css preview/static/css/main.e631bfb5.css text/css
                  upload [8] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/css/main.e631bfb5.css.map preview/static/css/main.e631bfb5.css.map application/json
                  upload [7] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/js/main.5fe9c7da.js preview/static/js/main.5fe9c7da.js application/javascript
                  upload [6] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/js/main.5fe9c7da.js.LICENSE.txt preview/static/js/main.5fe9c7da.js.LICENSE.txt text/plain
                  upload [5] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/js/main.5fe9c7da.js.map preview/static/js/main.5fe9c7da.js.map application/json
                  upload [4] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.e631bfb5.css static/css/main.e631bfb5.css text/css
                  upload [3] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.e631bfb5.css.map static/css/main.e631bfb5.css.map application/json
                  upload [2] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.41cee985.js static/js/main.41cee985.js application/javascript
                  upload [1] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.41cee985.js.LICENSE.txt static/js/main.41cee985.js.LICENSE.txt text/plain
                  upload [0] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.41cee985.js.map static/js/main.41cee985.js.map application/json
                  Updating objects from io-package.json for adapter "echarts" with version "1.9.2"
                  upload [16] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/asset-manifest.json chart/asset-manifest.json application/json
                  upload [15] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/favicon.ico chart/favicon.ico image/vnd.microsoft.icon
                  upload [14] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/index.html chart/index.html text/html
                  upload [13] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/manifest.json chart/manifest.json application/json
                  upload [12] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/css/main.e631bfb5.css chart/static/css/main.e631bfb5.css text/css
                  upload [11] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/css/main.e631bfb5.css.map chart/static/css/main.e631bfb5.css.map application/json
                  upload [10] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.41cee985.js chart/static/js/main.41cee985.js application/javascript
                  upload [9] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.41cee985.js.LICENSE.txt chart/static/js/main.41cee985.js.LICENSE.txt text/plain
                  upload [8] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.41cee985.js.map chart/static/js/main.41cee985.js.map application/json
                  upload [7] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/echarts.png echarts.png image/png
                  upload [6] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/main.f21b47ed.css static/css/main.f21b47ed.css text/css
                  upload [5] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/main.f21b47ed.css.map static/css/main.f21b47ed.css.map application/json
                  upload [4] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.70a15e1f.js static/js/main.70a15e1f.js application/javascript
                  upload [3] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.70a15e1f.js.LICENSE.txt static/js/main.70a15e1f.js.LICENSE.txt text/plain
                  upload [2] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.70a15e1f.js.map static/js/main.70a15e1f.js.map application/json
                  upload [1] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/tab.html tab.html text/html
                  upload [0] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                  Leider ist der npm error bei iob diag nun größer geworden.
                  $ iob diag
                  npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                  npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                  npm error extraneous: aproba@2.1.0 /opt/iobroker/node_modules/aproba
                  npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                  npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                  npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                  npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                  npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                  npm error extraneous: detect-libc@2.1.2 /opt/iobroker/node_modules/detect-libc
                  npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                  npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                  npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                  npm error extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-response
                  npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                  npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                  npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                  npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                  npm error extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                  npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                  npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                  npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                  npm error extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/agent-base
                  npm error extraneous: debug@4.4.3 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/debug
                  npm error extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/https-proxy-agent
                  npm error extraneous: ms@2.1.3 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/ms
                  npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/node-fetch
                  npm error extraneous: tr46@0.0.3 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/tr46
                  npm error extraneous: webidl-conversions@3.0.1 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/webidl-conversions
                  npm error extraneous: whatwg-url@5.0.0 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/whatwg-url
                  npm error extraneous: semver@6.3.1 /opt/iobroker/node_modules/make-dir/node_modules/semver
                  npm error extraneous: brace-expansion@1.1.12 /opt/iobroker/node_modules/rimraf/node_modules/brace-expansion
                  npm error extraneous: glob@7.2.3 /opt/iobroker/node_modules/rimraf/node_modules/glob
                  npm error extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/rimraf/node_modules/minimatch
                  npm error extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/simple-get/node_modules/decompress-response
                  npm error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-13T09_23_31_389Z-debug-0.log
                  • meuteM meute
                    @meute
                    NPM version: 11.6.2
                    $ iob diag
                    @meute
                    Dann zieh mal die Beta 2.0.10 rein.
                    Ich vermute, die Dependencies wurden da mittlerweile angepasst.
                      @meute
                      meuteM Offline
                      meuteM Offline
                      meute
                      @meute
                      Installiert man die Beta auch so?
                      iob upgrade iobroker.echarts@2.0.10 --debug
                      Thomas BraunT meuteM 2 Antworten Letzte Antwort
                      • meuteM meute
                        @meute
                        @meute
                        Ja, sollte funktionieren.
                        • meuteM meute
                          @meute
                          meuteM Offline
                          meuteM Offline
                          meute
                          @meute
                          Die Installation hat funktioniert.
                          Aber der Adapter produziert eine Menge Fehler und startet nicht.
                          Log anbei.
                          logs - iobroker84.html
                          EDIT:
                          Ich installiere lieber wieder 1.9.2.
                          EDIT2:
                          Ich bin jetzt außer Haus kann mich erst später wieder melden, falls Du antwortest.
                          • meuteM meute
                            @meute
                            Log anbei.
                            EDIT:
                            EDIT2:
                            @meute
                            Das ist kein Log, das ist Quark.
                            Das log kann man sich per
                            iob logs
                            anschauen.
                              @meute
                              iob logs
                              anschauen.
                              meuteM Offline
                              meuteM Offline
                              meute
                              iob logs
                              anschauen.
                              Dann hier das richtige Log mit iob logs.
                              2025-10-13 12:08:50.391  - info: host.iobroker84 stopInstance system.adapter.echarts.0 (force=false, process=true)
                              2025-10-13 12:08:50.399  - info: echarts.0 (1850) Got terminate signal TERMINATE_YOURSELF
                              2025-10-13 12:08:50.441  - info: host.iobroker84 stopInstance system.adapter.echarts.0 send kill signal
                              2025-10-13 12:08:50.918  - info: echarts.0 (1850) terminating
                              2025-10-13 12:08:50.919  - info: echarts.0 (1850) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2025-10-13 12:08:51.441  - info: host.iobroker84 stopInstance timeout system.adapter.echarts.0 killing pid 1850
                              2025-10-13 12:08:51.478  - info: host.iobroker84 instance system.adapter.echarts.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2025-10-13 12:08:54.802  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 3802
                              2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                              2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]:   throw err;
                              2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]:   ^
                              2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                              2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: Require stack:
                              2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                              2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                              2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                              2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                              2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                              2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                              2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                              2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                              2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                              2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                              2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                              2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                              2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                              2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:   ]
                              2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]: }
                              2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                              2025-10-13 12:08:55.729  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2025-10-13 12:08:55.729  - info: host.iobroker84 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
                              2025-10-13 12:08:55.730  - info: host.iobroker84 system.adapter.echarts.0 will be rebuilt
                              2025-10-13 12:08:55.730  - warn: host.iobroker84 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                              2025-10-13 12:08:55.731  - info: host.iobroker84 iobroker rebuild
                              2025-10-13 12:08:56.624  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules ...
                              2025-10-13 12:09:14.147  - info: admin.0 (1598) ==> Connected system.user.admin from ::ffff:192.168.23.27
                              2025-10-13 12:09:20.769  - info: host.iobroker84 iobroker npm-rebuild: rebuilt dependencies successfully
                              2025-10-13 12:09:20.796  - info: host.iobroker84 iobroker npm-rebuild:
                              2025-10-13 12:09:20.797  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules done
                              2025-10-13 12:09:21.809  - info: host.iobroker84 iobroker npm-rebuild: exit 0
                              2025-10-13 12:09:22.198  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4060
                              2025-10-13 12:09:23.079  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:   throw err;
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:   ^
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]: Require stack:
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                              2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:   ]
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]: }
                              2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                              2025-10-13 12:09:23.081  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2025-10-13 12:09:23.081  - info: host.iobroker84 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
                              2025-10-13 12:09:23.082  - info: host.iobroker84 system.adapter.echarts.0 will be rebuilt
                              2025-10-13 12:09:23.082  - warn: host.iobroker84 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                              2025-10-13 12:09:23.082  - info: host.iobroker84 iobroker rebuild
                              2025-10-13 12:09:23.972  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules ...
                              2025-10-13 12:09:40.440  - info: host.iobroker84 iobroker npm-rebuild: rebuilt dependencies successfully
                              2025-10-13 12:09:40.469  - info: host.iobroker84 iobroker npm-rebuild:
                              2025-10-13 12:09:40.469  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules done
                              2025-10-13 12:09:41.482  - info: host.iobroker84 iobroker npm-rebuild: exit 0
                              2025-10-13 12:09:41.861  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4306
                              2025-10-13 12:09:42.771  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:   throw err;
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:   ^
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]: Require stack:
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                              2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                              2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                              2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                              2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                              2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                              2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:   ]
                              2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]: }
                              2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                              2025-10-13 12:09:42.773  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2025-10-13 12:09:42.773  - info: host.iobroker84 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
                              2025-10-13 12:09:42.773  - info: host.iobroker84 system.adapter.echarts.0 will be rebuilt
                              2025-10-13 12:09:42.773  - warn: host.iobroker84 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                              2025-10-13 12:09:42.774  - info: host.iobroker84 iobroker rebuild
                              2025-10-13 12:09:43.649  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules ...
                              2025-10-13 12:09:59.744  - info: host.iobroker84 iobroker npm-rebuild: rebuilt dependencies successfully
                              2025-10-13 12:09:59.773  - info: host.iobroker84 iobroker npm-rebuild:
                              2025-10-13 12:09:59.774  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules done
                              2025-10-13 12:10:00.790  - info: host.iobroker84 iobroker npm-rebuild: exit 0
                              2025-10-13 12:10:01.155  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4536
                              2025-10-13 12:10:02.102  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:   throw err;
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:   ^
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]: Require stack:
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                              2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:   ]
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]: }
                              2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                              2025-10-13 12:10:02.104  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2025-10-13 12:10:02.105  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                              2025-10-13 12:10:06.604  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4543
                              2025-10-13 12:10:07.492  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                              2025-10-13 12:10:07.492  - error: host.iobroker84 Caught by controller[0]:   throw err;
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:   ^
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]: Require stack:
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                              2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                              2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                              2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                              2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                              2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:   ]
                              2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]: }
                              2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                              2025-10-13 12:10:07.494  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2025-10-13 12:10:07.494  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                              2025-10-13 12:10:17.295  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4550
                              2025-10-13 12:10:18.192  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                              2025-10-13 12:10:18.192  - error: host.iobroker84 Caught by controller[0]:   throw err;
                              2025-10-13 12:10:18.192  - error: host.iobroker84 Caught by controller[0]:   ^
                              2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                              2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]: Require stack:
                              2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                              2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                              2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                              2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                              2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                              2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                              2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                              2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                              2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                              2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                              2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                              2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                              2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                              2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:   ]
                              2025-10-13 12:10:18.195  - error: host.iobroker84 Caught by controller[0]: }
                              2025-10-13 12:10:18.195  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                              2025-10-13 12:10:18.195  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2025-10-13 12:10:18.195  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                              2025-10-13 12:10:18.526  - info: host.iobroker84 "system.adapter.echarts.0" disabled
                              2025-10-13 12:10:20.582  - info: host.iobroker84 "system.adapter.echarts.0" enabled
                              2025-10-13 12:10:21.027  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4557
                              2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                              2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]:   throw err;
                              2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]:   ^
                              2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                              2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]: Require stack:
                              2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                              2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                              2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                              2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                              2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                              2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                              2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                              2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                              2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                              2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                              2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                              2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                              2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                              2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:   ]
                              2025-10-13 12:10:21.955  - error: host.iobroker84 Caught by controller[0]: }
                              2025-10-13 12:10:21.955  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                              2025-10-13 12:10:21.955  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2025-10-13 12:10:21.955  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                              2025-10-13 12:11:04.014  - info: host.iobroker84 "system.adapter.echarts.0" disabled
                              2025-10-13 12:14:28.139  - info: host.iobroker84 "system.adapter.echarts.0" enabled
                              2025-10-13 12:14:28.607  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4570
                              2025-10-13 12:14:29.498  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                              2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:   throw err;
                              2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:   ^
                              2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                              2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]: Require stack:
                              2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                              2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                              2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                              2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                              2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                              2025-10-13 12:14:29.501  - error: host.iobroker84 Caught by controller[0]:   ]
                              2025-10-13 12:14:29.501  - error: host.iobroker84 Caught by controller[0]: }
                              2025-10-13 12:14:29.501  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                              2025-10-13 12:14:29.501  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2025-10-13 12:14:29.501  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                              • meuteM meute
                                iob logs
                                anschauen.
                                Da kann ein Modul (vermutlich canvas) nicht richtig gebaut werden.
                                cd /opt/iobroker && npm ls canvas
                                mal anschauen.
                                Und dann vielleicht im Verzeichnis des Adapters
                                npm install --omit=dev
                                ausführen.
                                  mal anschauen.
                                  ausführen.
                                  meuteM Offline
                                  meuteM Offline
                                  meute
                                  mal anschauen.
                                  Ergebnis:
                                  $ cd /opt/iobroker && npm ls canvas
                                  └── (empty)
                                  ausführen.
                                  Meinst Du diesen Ordner?
                                  $ ls -lh /opt/iobroker/iobroker-data/files/echarts
                                  insgesamt 152K
                                  -rw-rw-r--+ 1 iobroker iobroker  11K 13. Okt 12:15 asset-manifest.json
                                  drwxrwxr-x+ 2 iobroker iobroker 4,0K 13. Okt 12:15 assets
                                  -rw-rw-r--+ 1 iobroker iobroker 4,0K 13. Okt 12:15 _data.json
                                  -rw-rw-r--+ 1 iobroker iobroker 115K 13. Okt 12:15 favicon.ico
                                  -rw-rw-r--+ 1 iobroker iobroker  690 13. Okt 12:15 index.html
                                  -rw-rw-r--+ 1 iobroker iobroker  313 13. Okt 12:15 manifest.json
                                  drwxrwxr-x+ 4 iobroker iobroker 4,0K 13. Okt 12:15 preview
                                  drwxrwxr-x+ 4 iobroker iobroker 4,0K  3. Okt 15:03 static
                                  Hier soll ich npm install --omit=dev ausführen.
                                  Kann ich mir damit was kaputt machen?
                                  EDIT:
                                  Aber eigentlich müsste der npm error doch bei jedem vorhanden sein, der den Adapter echarts installiert hat.
                                  Oder verstehe ich hier was falsch?
                                  • meuteM meute
                                    mal anschauen.
                                    Ergebnis:
                                    └── (empty)
                                    ausführen.
                                    insgesamt 152K
                                    EDIT:
                                    @meute
                                    Das richtige Verzeichnis ist
                                    Nein, wenn der Adapter bzw. das Modul gebaut werden kann dann hat man auch keinen Fehler.
                                    Bei mir ist der Adapter z. B. sauber installiert worden.
                                    • meuteM meute
                                      mal anschauen.
                                      Ergebnis:
                                      └── (empty)
                                      ausführen.
                                      insgesamt 152K
                                      EDIT:
                                      @meute
                                      Da sollte so ähnlich eigentlich aussehen:
                                      echad@chet:/opt/iobroker $ node -v
                                      v24.10.0
                                      echad@chet:/opt/iobroker $ npm ls canvas
                                      ├─┬ iobroker.echarts@2.0.10
                                      │ ├── canvas@3.2.0
                                      │ └─┬ jsdom@26.1.0
                                      │   └── canvas@3.2.0 deduped
                                      ├─┬ iobroker.mihome-vacuum@5.3.0
                                      └─┬ iobroker.parcel@0.2.10
                                        └─┬ jsdom@25.0.1
                                          └── canvas@3.2.0 deduped invalid: "^2.11.2" from node_modules/iobroker.parcel/node_modules/jsdom
                                      npm error invalid: canvas@3.2.0 /opt/iobroker/node_modules/canvas
                                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-13T16_27_05_147Z-debug-0.log
                                      Der Error bei parcel ist was anderes. Aber hier baut canvas sogar mit nodejs@24. Würde aber mit nodejs@22 auch nicht anders aussehen.
                                        @meute
                                        meuteM Offline
                                        meuteM Offline
                                        meute
                                        Ich habe npm install --omit=dev ausgeführt.
                                        $ cd /opt/iobroker/node_modules/iobroker.echarts/
                                        /opt/iobroker/node_modules/iobroker.echarts $ npm install --omit=dev
                                        npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                                        added 128 packages, and audited 129 packages in 2m
                                        18 packages are looking for funding
                                        found 0 vulnerabilities
                                        Ergebnis cd /opt/iobroker && npm ls canvas:
                                          ├── canvas@2.11.2
                                          └─┬ jsdom@25.0.1
                                            └── canvas@2.11.2 deduped
                                        Der npm error bei iob diag ist noch größer geworden.
                                        $ iob diag
                                        *** iob diag is starting up, please wait ***
                                        npm error code ELSPROBLEMS
                                        npm error extraneous: @asamuzakjp/css-color@3.2.0 /opt/iobroker/node_modules/@asamuzakjp/css-color
                                        npm error extraneous: @csstools/color-helpers@5.1.0 /opt/iobroker/node_modules/@csstools/color-helpers
                                        npm error extraneous: @csstools/css-calc@2.1.4 /opt/iobroker/node_modules/@csstools/css-calc
                                        npm error extraneous: @csstools/css-color-parser@3.1.0 /opt/iobroker/node_modules/@csstools/css-color-parser
                                        npm error extraneous: cssstyle@4.6.0 /opt/iobroker/node_modules/cssstyle
                                        npm error extraneous: data-urls@5.0.0 /opt/iobroker/node_modules/data-urls
                                        npm error extraneous: decimal.js@10.6.0 /opt/iobroker/node_modules/decimal.js
                                        npm error extraneous: echarts@5.6.0 /opt/iobroker/node_modules/echarts
                                        npm error extraneous: html-encoding-sniffer@4.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                        npm error extraneous: http-proxy-agent@7.0.2 /opt/iobroker/node_modules/http-proxy-agent
                                        npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                        npm error extraneous: jsdom@25.0.1 /opt/iobroker/node_modules/jsdom
                                        npm error extraneous: nwsapi@2.2.22 /opt/iobroker/node_modules/nwsapi
                                        npm error extraneous: parse5@7.3.0 /opt/iobroker/node_modules/parse5
                                        npm error extraneous: rrweb-cssom@0.7.1 /opt/iobroker/node_modules/rrweb-cssom
                                        npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                                        npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                        npm error extraneous: tldts-core@6.1.86 /opt/iobroker/node_modules/tldts-core
                                        npm error extraneous: tldts@6.1.86 /opt/iobroker/node_modules/tldts
                                        npm error extraneous: tr46@5.1.1 /opt/iobroker/node_modules/tr46
                                        npm error extraneous: w3c-xmlserializer@5.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                        npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                        npm error extraneous: whatwg-encoding@3.1.1 /opt/iobroker/node_modules/whatwg-encoding
                                        npm error extraneous: whatwg-mimetype@4.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                        npm error invalid: whatwg-url@14.2.0 /opt/iobroker/node_modules/whatwg-url
                                        npm error extraneous: whatwg-url@14.2.0 /opt/iobroker/node_modules/whatwg-url
                                        npm error extraneous: xml-name-validator@5.0.0 /opt/iobroker/node_modules/xml-name-validator
                                        npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                                        npm error extraneous: zrender@5.6.1 /opt/iobroker/node_modules/zrender
                                        npm error missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
                                        npm error missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
                                        npm error extraneous: lru-cache@10.4.3 /opt/iobroker/node_modules/@asamuzakjp/css-color/node_modules/lru-cache
                                        npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
                                        npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
                                        npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
                                        npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
                                        npm error extraneous: rrweb-cssom@0.8.0 /opt/iobroker/node_modules/cssstyle/node_modules/rrweb-cssom
                                        npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/echarts/node_modules/tslib
                                        npm error extraneous: debug@4.4.3 /opt/iobroker/node_modules/http-proxy-agent/node_modules/debug
                                        npm error extraneous: ms@2.1.3 /opt/iobroker/node_modules/http-proxy-agent/node_modules/ms
                                        npm error extraneous: tough-cookie@5.1.2 /opt/iobroker/node_modules/jsdom/node_modules/tough-cookie
                                        npm error extraneous: iconv-lite@0.6.3 /opt/iobroker/node_modules/whatwg-encoding/node_modules/iconv-lite
                                        npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/zrender/node_modules/tslib
                                        npm error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                                        npm error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-13T16_46_12_186Z-debug-0.log
                                        *** ioBroker Diagnosis ***
                                        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                        • meuteM meute
                                            ├── canvas@2.11.2
                                            └─┬ jsdom@25.0.1
                                          $ iob diag
                                          @meute
                                          Die Einträge mir extraneous sollten mit einem
                                          npm prune
                                          verschwinden.
