  4. [gelöst] Zigbeestick nach Neuinstallation nicht ansprechbar
    6.5k
8 Beiträge 4 Kommentatoren 580 Aufrufe 4 Beobachtet
  • I Offline
    I Offline
    Ianig Iro
    schrieb am zuletzt editiert von Ianig Iro
    Ich habe seit geraumer Zeit probleme mit dem Zigbee Stick. Mein neustes:
    Komplette Neuinstallation iob und backup eingepflegt. Der Stick wird nicht mehr im Adapter erkannt.
    ls -l /dev/serial/by-id/
    total 0
    lrwxrwxrwx 1 root root 13 Sep 20 14:14 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f211ce48ec1bef11a50ba3d94909ffd0-if00-port0 -> ../../ttyUSB0
    iob diag zeigt mir den Stick an:
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f211ce48ec1bef11a50ba3d94909ffd0-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    Die logs beim start/wählen des Sticks in den Einstellungen sagen:
    2025-09-22 11:55:13.171 - info: zigbee.0 (463319) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7
    2025-09-22 11:55:13.222 - info: zigbee.0 (463319) Adapter ready - starting subsystems. Adapter is running in info mode.
    2025-09-22 11:55:13.225 - info: zigbee.0 (463319) init localConfig
    2025-09-22 11:55:13.241 - info: zigbee.0 (463319) --- creating device debug ---
    2025-09-22 11:55:13.242 - warn: zigbee.0 (463319) Zigbee autostart option not set - omitting start of zigbee substystem!
    2025-09-22 11:55:52.300 - info: admin.0 (457008) ==> Connected system.user.admin from ::ffff:192.168.178.35
    2025-09-22 11:55:52.712 - info: zigbee.0 (463319) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"f211ce48ec1bef11a50ba3d94909ffd0","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f211ce48ec1bef11a50ba3d94909ffd0-if00-port0","vendorId":"10c4","productId":"ea60"}]
    2025-09-22 11:55:58.949 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2025-09-22 11:55:58.956 - info: zigbee.0 (463319) Got terminate signal TERMINATE_YOURSELF
    2025-09-22 11:55:58.996 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2025-09-22 11:55:59.049 - info: admin.0 (457008) <== Disconnect system.user.admin from ::ffff:192.168.178.35
    2025-09-22 11:55:58.959 - info: zigbee.0 (463319) Halting zigbee adapter. Restart delay is at least 30 seconds.
    2025-09-22 11:55:58.963 - info: zigbee.0 (463319) cleaning everything up...
    2025-09-22 11:55:58.971 - info: zigbee.0 (463319) Saved local configuration data
    2025-09-22 11:55:59.103 - warn: zigbee.0 (463319) Failed to stop zigbee during startup
    2025-09-22 11:55:59.103 - info: zigbee.0 (463319) cleanup successful
    2025-09-22 11:55:59.104 - info: zigbee.0 (463319) terminating
    2025-09-22 11:55:59.105 - info: zigbee.0 (463319) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-09-22 11:55:59.687 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    könnte mein stick auch hinüber sein?
    • I Ianig Iro
      total 0
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      @ianig-iro sagte in Zigbeestick nach Neuinstallation nicht ansprechbar:
      Du musst die 'Startoption' im Adapter setzen.
      I 1 Antwort Letzte Antwort
        I Offline
        I Offline
        Ianig Iro
        @thomas-braun wo finde ich die? in den adaptereinstellungen habe ich nichts gesehen.
        • I Ianig Iro
          @ianig-iro
          Hab gerade keinen graphischen Zugriff auf den Admin, kann es nicht nachschauen.
          Auf der rechten Seite findet sich da was, wenn ich mich recht entsinne.
            @ianig-iro
            I Offline
            I Offline
            Ianig Iro
            @thomas-braun danke, ich habe es wirklich 10 mal übersehen.
            jetzt:
            2025-09-22 12:14:59.738 - info: zigbee.0 (466687) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7
            2025-09-22 12:14:59.789 - info: zigbee.0 (466687) Adapter ready - starting subsystems. Adapter is running in info mode.
            2025-09-22 12:14:59.791 - info: zigbee.0 (466687) init localConfig
            2025-09-22 12:14:59.806 - info: zigbee.0 (466687) --- creating device debug ---
            2025-09-22 12:14:59.807 - info: zigbee.0 (466687) Autostart Zigbee subsystem
            2025-09-22 12:14:59.808 - info: zigbee.0 (466687) Starting Adapter npm ...
            2025-09-22 12:14:59.823 - info: zigbee.0 (466687) Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
            2025-09-22 12:14:59.825 - info: zigbee.0 (466687) configured transmit power : normal
            2025-09-22 12:14:59.827 - info: zigbee.0 (466687) Starting Zigbee-Herdsman
            2025-09-22 12:15:19.653 - info: zigbee.0 (466687) Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20210708 (2-1.2.7.1)
            2025-09-22 12:15:19.665 - info: zigbee.0 (466687) Unable to disable LED, unsupported function.
            2025-09-22 12:15:19.666 - info: zigbee.0 (466687) No devices are currently joined.
            2025-09-22 12:15:19.670 - info: zigbee.0 (466687) Zigbee started
            2025-09-22 12:15:19.671 - info: zigbee.0 (466687) Config value 0x585c41c0b20ee24b : Network value 0x00124b002f89898f
            2025-09-22 12:15:19.675 - error: zigbee.0 (466687) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
            2025-09-22 12:15:19.747 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
            2025-09-22 12:15:19.757 - info: zigbee.0 (466687) Got terminate signal TERMINATE_YOURSELF
            2025-09-22 12:15:19.759 - info: zigbee.0 (466687) Halting zigbee adapter. Restart delay is at least 30 seconds.
            2025-09-22 12:15:19.759 - info: zigbee.0 (466687) cleaning everything up...
            2025-09-22 12:15:19.761 - info: zigbee.0 (466687) Saved local configuration data
            2025-09-22 12:15:19.798 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
            2025-09-22 12:15:19.832 - error: zigbee.0 (466687) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
            2025-09-22 12:15:20.001 - info: zigbee.0 (466687) Closing Zigbee network, 0 seconds remaining
            2025-09-22 12:15:23.762 - info: zigbee.0 (466687) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-09-22 12:15:24.387 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            • I Ianig Iro
              jetzt:
              arteckA Offline
              arteckA Offline
              arteck
              @ianig-iro Doku lesen soll da helfen ...
              • arteckA arteck
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @arteck sagte in Zigbeestick nach Neuinstallation nicht ansprechbar:
                Wie kommst du denn auf das dünne Brett ? Da müsste ja jemand Doku geschrieben haben. 😏
                Scherz beiseite - Du hast ein Problem mit deiner Netzwerk Konfiguration. Steht da auch. Lesen bildet ungemein:
                @Ianig-Iro
                Du hast jetzt 2 Optionen:
                Option A) wenn du sowieso alles neu anlernen musst: die ExtPanID aus dem Netzwerk in die Konfiguration übernehmen
                Option B) wenn du das bestehende übernehmen willst: Alle Router im Netz vom Strom nehmen, eine ggf. vorhandene nvbackup.json löschen, den Adapter starten.
                A.
                • AsgothianA Asgothian
                  @Ianig-Iro
                  A.
                  I Offline
                  I Offline
                  Ianig Iro
                  @asgothian danke option a hat es gelöst. den error habe ich gesehen, aber ich habe nicht verstanden, was genau das problem ist. ich wusste noch nichtmal, dass es mehrere IDs gibt.
