  4. Backit Up Fehler bei Grafana Backup
    6.5k
3 Beiträge 2 Kommentatoren 268 Aufrufe 2 Beobachtet
    toki1973
    Ich verwende Grafana V8 und bekomme nach dem Update einen Zugriffsfehler. Ich habe nichts geändert. Wurde am Adapter etwas geändert?
    Backitup:
    Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
    grafana: {"message":"Request failed with status code 403","name":"AxiosError","stack":"AxiosError: Request failed with status code 403\n    at settle (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:2053:12)\n    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:3170:11)\n    at IncomingMessage.emit (node:events:536:35)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n    at Axios.request (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:4280:41)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n    at async /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:42:44","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer eyJrIjoiSWxxxxx0lxxxxLCJuIjoiR3JhZmFuYUtleSIsImlkIjoxxx==","User-Agent":"axios/1.10.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.0.xx:3000/api/datasources","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}},"allowAbsoluteUrls":true},"code":"**ERR_BAD_REQUEST","status":403**}
    NUC, PROXMOX, Grafana, Influx, Unify
    • T toki1973
      Backitup:
      simatecS Offline
      simatecS Offline
      simatec
      @toki1973 sagte in Backit Up Fehler bei Grafana Backup:
      Grafana V8
      Bei dieser alten Version kann es durchaus sein, dass diese nicht mehr kompatibel ist. Grafana ist aktuell bei v12.1
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        Grafana V8
        toki1973
        Ohje sehe gerade das Influx und Grafana noch auf Buster VM läuft. Dann wohl am besten alles neu und mal schauen wie ich meine Grafana und Influxdaten migriere 😲
