  4. Sonof startet nach Aktualisierung auf 3.2.1 nicht mehr
    6.5k
8 Beiträge 5 Kommentatoren 495 Aufrufe 2 Beobachtet
  • E Offline
    exmerci
    ich habe den Sonoff Adapter aktualisiert und jetzt startet er nicht mehr. Im Log steht folgendes. Leider kann ich damit nichts anfangen.
    Jemand eine Idee zum Anstoss? Bin jetzt erstmal zurück auf die vorherige Version. Die funktioniert.
    sonoff.0
    2025-09-13 12:23:47.350	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    sonoff.0
    2025-09-13 12:23:47.348	info	terminating
    sonoff.0
    2025-09-13 12:23:46.819	error	The id "info.clients." is invalid. Ids are not allowed to end in "."
    sonoff.0
    2025-09-13 12:23:46.818	error	Error: The id "info.clients." is invalid. Ids are not allowed to end in "." at Validator.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:214:23) at AdapterClass.getObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:3814:25) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2336:26 at new Promise (<anonymous>) at AdapterClass.getObjectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2332:16) at updateClients (/opt/iobroker/node_modules/iobroker.sonoff/lib/server.js:824:49)
    sonoff.0
    2025-09-13 12:23:46.488	error	unhandled promise rejection: The id "info.clients." is invalid. Ids are not allowed to end in "."
    sonoff.0
    2025-09-13 12:23:46.487	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    sonoff.0
    2025-09-13 12:23:46.404	warn	New object creation error: The id "sonoff.0." is invalid. Ids are not allowed to end in "."
    haselchenH 2 Antworten Letzte Antwort
    • E exmerci
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      haselchenH Offline
      haselchenH Offline
      haselchen
      @exmerci
      Du hast da ein Gerät mit einem Punkt benannt bzw. nicht benannt.
      Umbenennen.
      • haselchenH haselchen
        @exmerci
        Umbenennen.
        @haselchen sagte in Sonof startet nach Aktualisierung auf 3.2.1 nicht mehr:
        Du hast da ein Gerät mit einem Punkt benannt,
        wohl eher nicht
        @exmerci sagte in Sonof startet nach Aktualisierung auf 3.2.1 nicht mehr:
        aber warum das angemeckert wird ist hieraus nicht ersichtlich
          @exmerci
          Umbenennen.
          bzw. nicht benannt.
          das schon eher
          • E exmerci
            sonoff.0
            sonoff.0
            sonoff.0
            sonoff.0
            sonoff.0
            sonoff.0
            sonoff.0
            haselchenH Offline
            haselchenH Offline
            haselchen
            @exmerci
            sonoff.0.info.clients.
            So müsste der Objektbaum aussehen. Und danach kommen die Geräte(bezeichnungen)
            sonoff.0.info.clients.Carportsteckdose_hinten_links
            Ausserdem der Hinweis im Changelog
            3.2.1 (2024-10-07)
                (bluefox) Sanitize the IDs of the clients
            • skvarelS Online
              skvarelS Online
              skvarel
              schrieb am zuletzt editiert von skvarel
              Es liegt vermutlich nicht am Adapter. Ich nutze die v3.2.1 seit fast einem Jahr und habe keine Fehlermeldungen.
              Edit: Zum Testen habe ich gerade alle Objekte gelöscht und den Adapter neu gestartet. Alle Datenpunkte werden sauber angelegt.
              #TeamInventwo
              Unsere Adapter:
              • T Nicht stören
                T Nicht stören
                ticaki
                Die Fehlermeldung kommt vom js-controller. Ich vermute mal, das ein Gerät mit einem Leerzeichen benannt ist und keine Buchstaben enthält. Oder gar keinen Namen hat einfach nur eine leere Zeichenkette
                Spenden
                E 1 Antwort Letzte Antwort
                • T ticaki
                  exmerci
                  Danke erstmal für die vielen Antworten. Ich werde mir das morgen alles mal ansehen. Heute komme ich leider nicht mehr dazu.
