  4. Backup Fehler nach Neuaufsetzung
    6.5k
13 Beiträge 2 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • K Offline
    kg36304
    ich habe mein System neu aufgesetzt, also Iobroker Master und zwei Slave´s jeweils auf Raspberry´s.
    Danch das Backup wieder eingespielt.
    Seit dem macht Backitup zicken mit InfluxDB (auf einer separaten Pi Büchse).
    Folgende Meldung kommt und ich kann nicht finde, wo der Fehler liegt.
    Danke.
    0:18:01.869
    INFO
    gui
    Backup gestartet ...
    10:18:23.655
    DEBUG
    iobroker
    host.raspberrypi 25677 objects saved
    10:18:27.230
    DEBUG
    iobroker
    host.raspberrypi 22307 states saved
    host.raspberrypi Validating backup ...
    10:18:27.272
    DEBUG
    iobroker
    host.raspberrypi "config.json" is valid
    10:18:27.279
    DEBUG
    iobroker
    host.raspberrypi "objects.jsonl" exists
    host.raspberrypi "states.jsonl" exists
    10:18:28.565
    DEBUG
    iobroker
    host.raspberrypi JSONL lines are valid
    10:18:29.673
    DEBUG
    iobroker
    host.raspberrypi The backup is valid!
    10:18:46.155
    DEBUG
    iobroker
    Backup created: /opt/iobroker/backups/iobroker_2025_09_06-10_18_02_backupiobroker.tar.gz
    10:18:46.163
    DEBUG
    iobroker
    This backup can only be restored with js-controller version 7.0 or higher
    10:18:47.215
    DEBUG
    iobroker
    done
    10:18:47.387
    DEBUG
    influxDB
    InfluxDB-Backup started ...
    10:18:47.396
    DEBUG
    influxDB
    Start InfluxDB Backup ...
    10:18:47.446
    DEBUG
    influxDB
    InfluxDB Backup tmp directory created
    10:18:47.450
    DEBUG
    influxDB
    Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker"
    10:18:47.457
    DEBUG
    influxDB
    InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker" successfully deleted
    [DEBUG] [influxDB] -
    10:18:47.506
    ERROR
    influxDB
    Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker"
    /bin/sh: 1: influxd: not found
    10:18:47.514
    DEBUG
    influxDB
    done
    10:18:48.652
    DEBUG
    grafana
    Start Grafana Backup ...
    10:18:48.657
    DEBUG
    grafana
    Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    10:18:48.672
    DEBUG
    grafana
    Created dashboard directory
    10:18:48.751
    DEBUG
    grafana
    Created folder directory
    10:18:48.757
    DEBUG
    grafana
    Created dashboards_manually_restore directory
    10:18:48.760
    DEBUG
    grafana
    Created datasource directory
    10:18:48.765
    DEBUG
    grafana
    start Grafana request ...
    10:18:48.791
    DEBUG
    grafana
    Grafana is available ... Status: 200
    10:18:49.627
    DEBUG
    grafana
    found Dashboard: mein-dashboard
    10:18:49.745
    DEBUG
    grafana
    Saved dashboard-folder mapping
    10:18:50.031
    DEBUG
    grafana
    start Grafana backup compress ...
    10:18:55.060
    DEBUG
    grafana
    Backup created: /opt/iobroker/backups/grafana_2025_09_06-10_18_49_backupiobroker.tar.gz
    10:18:55.075
    DEBUG
    grafana
    Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    10:18:55.130
    DEBUG
    grafana
    Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    10:18:55.137
    DEBUG
    grafana
    done
    10:18:58.079
    DEBUG
    googledrive
    Google Drive: Copy iobroker_2025_09_06-10_18_02_backupiobroker.tar.gz...
    10:19:08.548
    ERROR
    googledrive
    Google Drive: File "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker.tar.gz" not found
    10:19:09.483
    DEBUG
    googledrive
    Google Drive: Copy grafana_2025_09_06-10_18_49_backupiobroker.tar.gz...
    10:19:11.043
    DEBUG
    googledrive
    done
    10:19:11.181
    ERROR
    clean
    Backup files not deleted from /opt/iobroker/backups because some errors.
    10:19:11.224
    DEBUG
    clean
    done
    10:19:11.468
    DEBUG
    historyHTML
    new history html values created
    10:19:11.765
    DEBUG
    historyHTML
    done
    10:19:11.987
    DEBUG
    historyJSON
    new history json values created
    10:19:12.037
    DEBUG
    historyJSON
    done
    10:19:13.293
    DEBUG
    telegram
    done
    10:19:14.519
    DEBUG
    notification
    Admin notification will be sent
    10:19:14.561
    DEBUG
    notification
    done
    10:19:14.663
    INFO
    gui
    Das Backup wurde erfolgreich erstellt!
    • K kg36304
      Danke.
      0:18:01.869
      INFO
      gui
      10:18:23.655
      DEBUG
      iobroker
      10:18:27.230
      DEBUG
      iobroker
      10:18:27.272
      DEBUG
      iobroker
      10:18:27.279
      DEBUG
      iobroker
      10:18:28.565
      DEBUG
      iobroker
      10:18:29.673
      DEBUG
      iobroker
      10:18:46.155
      DEBUG
      iobroker
      10:18:46.163
      DEBUG
      iobroker
      10:18:47.215
      DEBUG
      iobroker
      done
      10:18:47.387
      DEBUG
      influxDB
      10:18:47.396
      DEBUG
      influxDB
      10:18:47.446
      DEBUG
      influxDB
      10:18:47.450
      DEBUG
      influxDB
      10:18:47.457
      DEBUG
      influxDB
      10:18:47.506
      ERROR
      influxDB
      10:18:47.514
      DEBUG
      influxDB
      done
      10:18:48.652
      DEBUG
      grafana
      10:18:48.657
      DEBUG
      grafana
      10:18:48.672
      DEBUG
      grafana
      10:18:48.751
      DEBUG
      grafana
      10:18:48.757
      DEBUG
      grafana
      10:18:48.760
      DEBUG
      grafana
      10:18:48.765
      DEBUG
      grafana
      10:18:48.791
      DEBUG
      grafana
      10:18:49.627
      DEBUG
      grafana
      10:18:49.745
      DEBUG
      grafana
      10:18:50.031
      DEBUG
      grafana
      10:18:55.060
      DEBUG
      grafana
      10:18:55.075
      DEBUG
      grafana
      10:18:55.130
      DEBUG
      grafana
      10:18:55.137
      DEBUG
      grafana
      done
      10:18:58.079
      DEBUG
      googledrive
      10:19:08.548
      ERROR
      googledrive
      10:19:09.483
      DEBUG
      googledrive
      10:19:11.043
      DEBUG
      googledrive
      done
      10:19:11.181
      ERROR
      clean
      10:19:11.224
      DEBUG
      clean
      done
      10:19:11.468
      DEBUG
      historyHTML
      10:19:11.765
      DEBUG
      historyHTML
      done
      10:19:11.987
      DEBUG
      historyJSON
      10:19:12.037
      DEBUG
      historyJSON
      done
      10:19:13.293
      DEBUG
      telegram
      done
      10:19:14.519
      DEBUG
      notification
      10:19:14.561
      DEBUG
      notification
      done
      10:19:14.663
      INFO
      gui
      @kg36304 sagte in Backup Fehler nach Neuaufsetzung:
      Da fehlt influx auf mindestens einer der Kisten. Es muss der passende influx-client installiert sein.
      • K Offline
        kg36304
        Das heißt auf dem Master auf dem ich das Backup starte müsste quasi der client drauf?
        Hast Du den Befehl gerade greifbar?
        Vielen Dank
        Kai
        • K kg36304
          Vielen Dank
          Kai
          Nein, das Paket hängt davon ab, welche Version von influxdb da installiert ist.
          Bei mir wäre es wohl influxdb2-client oder sowas:
          echad@chet:~ $ apt policy influxdb
          influxdb              influxdb2-cli         influxdb3-core        influxdb-client
          influxdb2             influxdb2-client      influxdb3-enterprise  influxdb-python
          echad@chet:~ $
          Edit:
          echad@chet:~ $ dpkg -S /usr/bin/influxd
          influxdb: /usr/bin/influxd
          Kommt also aus dem Paket 'influxdb'. Ist das bei dir installiert? Check das mit
          sudo apt update
          apt policy influxdb
          K 1 Antwort Letzte Antwort
            echad@chet:~ $
            Edit:
            sudo apt update
            apt policy influxdb
            kg36304
            @thomas-braun said in Backup Fehler nach Neuaufsetzung:
            apt policy influxdb
            Also auf meinem Iobroker Master (Influxdb ist auf einem separaten Pi)
            kommt das:
            kai@raspberrypi:~ $ apt policy influxdb
            influxdb:
              Installed: (none)
              Candidate: 1.6.7~rc0-1+b13
              Version table:
                 1.6.7~rc0-1+b13 500
            und
            kai@raspberrypi:~ $ dpkg -S /usr/bin/influxd
            dpkg-query: no path found matching pattern /usr/bin/influxd
            Auf dem Influxdp pi kommt das:
            pi@raspberrypi:~ $ apt policy influxdb
            influxdb:
              Installed: 1.8.4-1
              Candidate: 1.8.4-1
              Version table:
             *** 1.8.4-1 500
                    500 https://repos.influxdata.com/debian buster/stable armhf Packages
                    100 /var/lib/dpkg/status
                 1.6.4-1+deb10u1 500
                    500 https://archive.raspbian.org/raspbian buster/main armhf Packages
            pi@raspberrypi:~ $
            Wie gesagt ich starte das Backup auf dem Iobroker Master und die die InfluxDB ist zusammen mit Grafana auf einem separaten Raspberry.
            • K kg36304
              apt policy influxdb
              kommt das:
              influxdb:
                Installed: (none)
                Version table:
                   1.6.7~rc0-1+b13 500
              und
              influxdb:
                Installed: 1.8.4-1
                Candidate: 1.8.4-1
                Version table:
               *** 1.8.4-1 500
                   1.6.4-1+deb10u1 500
              pi@raspberrypi:~ $
              @kg36304
              Da ist aber mit Sicherheit auch noch mehr krumm/falsch/veraltet.
              Buster ist läääääääääääängst abgekündigt.
              Stell die Kisten erstmal auf eine stabile Basis.
              Und zweimal der gleiche hostname in einem Netz ist auch Krampf.
              • K Offline
                kg36304
                die iobroker sind alle auf Bookworm umgestellt, daher kommen meine Probleme.
                Der Pi wo Grafana und influxdb drauf laufen ist noch alt.
                Hostname habe ich geändert, das war erstmal das einfachste.
                InfluxDB und Grafana liefern auf jeden Fall Daten und Grafana wird auch gebackupt. Das ist schon mal was.
                Leider geht das Backup von Influxdb nicht.
                Muss mich jetzt wohl erst mal schlau machen wie ich das System auf Bookworm umhebe und alle daten wieder drauf bekomme.
                Danke.
                • K kg36304
                  Danke.
                  Gar nicht. Installier das neu. Das läuft ja auch als 32Bit-System. Will man nicht.
                    kg36304
                    Also Neustes Betriebssystem drauf und InfluxDB und Grafana neu drauf installieren?
                    Und die gespeicherten Daten vom Backup wieder drauf?
                    Sehe ich das richtig?
                    Nochmal danke.
                    • K kg36304
                      Nochmal danke.
                      Mit wie vielen Systemen auf welchem Stand jonglierst du denn da eigentlich herum?
                      Für mal auf allen Kisten ein
                      iob diag
                      aus (sofern verfügbar).
                        iob diag
                        kg36304
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                         Static hostname: raspberrypi
                               Icon name: computer
                                  Kernel: Linux 6.12.34+rpt-rpi-v8
                            Architecture: arm64
                        OS is similar to:
                        Model		: Raspberry Pi 4 Model B Rev 1.1
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         12:59:46 up 2 days, 23:10,  2 users,  load average: 1.53, 1.38, 1.38
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        Operating System is the current Debian stable version codenamed 'bookworm'!
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** TIME AND TIMEZONES ***
                                       Local time: Sat 2025-09-06 12:59:47 CEST
                                   Universal time: Sat 2025-09-06 10:59:47 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        kai
                        HOME=/home/kai
                        GROUPS=kai adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server: 	false
                        Unit display-manager.service could not be found.
                        Display-Manager:
                        Desktop:
                        Session: 		tty
                        *** MEMORY ***
                        Mem:            4.0G        3.2G        264M        2.3M        583M        747M
                        Swap:           1.1G        1.0G         32M
                        Total:          5.1G        4.3G        296M
                        Active iob-Instances: 	55
                                 3795 M total memory
                                 3083 M used memory
                                 2082 M active memory
                                 1257 M inactive memory
                                  251 M free memory
                                   39 M buffer memory
                                  516 M swap cache
                                 1023 M total swap
                                  993 M used swap
                                   30 M free swap
                        top - 12:59:47 up 2 days, 23:10,  2 users,  load average: 1.53, 1.38, 1.38
                        Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  9.1 us,  9.1 sy,  0.0 ni, 72.7 id,  9.1 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3795.9 total,    251.7 free,   3083.1 used,    556.8 buff/cache
                        MiB Swap:   1024.0 total,     30.9 free,    993.1 used.    712.8 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        No critical errors detected
                        *** FILESYSTEM ***
                        udev           devtmpfs  1.6G     0  1.6G   0% /dev
                        tmpfs          tmpfs     380M  5.9M  374M   2% /run
                        /dev/sda2      ext4      117G  6.1G  106G   6% /
                        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                        /dev/sda1      vfat      510M   58M  453M  12% /boot/firmware
                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                        [Wed Sep  3 13:49:20 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:50:A2:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=1d815a5d-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Wed Sep  3 13:49:22 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                        [Wed Sep  3 13:49:23 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
                        Show mounted filesystems:
                        TARGET           SOURCE    FSTYPE OPTIONS
                        /                /dev/sda2 ext4   rw,noatime
                        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        1.4G	/var/
                        210M	/var/cache
                        204M	/var/cache/apt
                        168M	/var/lib
                        135M	/var/lib/apt/lists
                        Archived and active journals take up 4.7M in the file system.
                        /opt/iobroker/backups:
                        218M	/opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        739M	/opt/iobroker/iobroker-data/
                        593M	/opt/iobroker/iobroker-data/files
                        112M	/opt/iobroker/iobroker-data/backup-objects
                        74M	/opt/iobroker/iobroker-data/files/vis.0
                        74M	/opt/iobroker/iobroker-data/files/vis-2.0
                        38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                        27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                        26M	/opt/iobroker/iobroker-data/objects.jsonl
                        24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                        USB-Devices by-id:
                        No Devices found 'by-id'
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs 	v22.19.0
                        /usr/bin/node 		v22.19.0
                        /usr/bin/npm 		10.9.3
                        /usr/bin/npx 		10.9.3
                        /usr/bin/corepack 	0.34.0
                        nodejs:
                          Installed: 22.19.0-1nodesource1
                          Candidate: 22.19.0-1nodesource1
                          Version table:
                         *** 22.19.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                             22.18.0-1nodesource1 1001
                             22.17.1-1nodesource1 1001
                             22.17.0-1nodesource1 1001
                             22.16.0-1nodesource1 1001
                             22.15.1-1nodesource1 1001
                             22.15.0-1nodesource1 1001
                             22.14.0-1nodesource1 1001
                             22.13.1-1nodesource1 1001
                             22.13.0-1nodesource1 1001
                             22.12.0-1nodesource1 1001
                             22.11.0-1nodesource1 1001
                             22.10.0-1nodesource1 1001
                             22.9.0-1nodesource1 1001
                             22.8.0-1nodesource1 1001
                             22.7.0-1nodesource1 1001
                             22.6.0-1nodesource1 1001
                             22.5.1-1nodesource1 1001
                             22.5.0-1nodesource1 1001
                             22.4.1-1nodesource1 1001
                             22.4.0-1nodesource1 1001
                             22.3.0-1nodesource1 1001
                             22.2.0-1nodesource1 1001
                             22.1.0-1nodesource1 1001
                             22.0.0-1nodesource1 1001
                             18.20.4+dfsg-1~deb12u1 500
                             18.19.0+dfsg-6~deb12u2 500
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        Slave               Slave (version: 7.0.7, hostname: Slave         , alive, uptime: 265791)
                        iobrokergarten      iobrokergarten (version: 7.0.7, hostname: iobrokergarten, alive, uptime: 332732)
                        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 72640)
                        Core adapters versions
                        js-controller: 	7.0.7
                        admin: 		7.6.17
                        javascript: 	8.9.2
                        nodejs modules from github: 	2
                        | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
                        +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#640df7360a877f37764a31d628e4d6de3ed1f6e3)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                          system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                        + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                        + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                          system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                        + system.adapter.ds18b20.0                : ds18b20               : Slave                                    -  enabled
                        + system.adapter.ds18b20.1                : ds18b20               : iobrokergarten                           -  enabled
                          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                        + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                        + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                        + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
                        + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
                        + system.adapter.hm-rega.1                : hm-rega               : raspberrypi                              -  enabled
                        + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                        + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                        + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                        + system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
                        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                          system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                        + system.adapter.mqtt.0                   : mqtt                  : Slave                                    -  enabled, port: 1886, bind: 0.0.0.0
                        + system.adapter.octoprint.0              : octoprint             : Slave                                    -  enabled
                        + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
                        + system.adapter.openligadb.1             : openligadb            : raspberrypi                              -  enabled
                        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                        + system.adapter.rpi2.1                   : rpi2                  : Slave                                    -  enabled
                        + system.adapter.rpi2.2                   : rpi2                  : iobrokergarten                           -  enabled
                        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
                        + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                        + system.adapter.sonoff.0                 : sonoff                : Slave                                    -  enabled, port: 1884, bind: 0.0.0.0
                        + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                        + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
                        + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                        + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                        + system.adapter.worx.0                   : worx                  : Slave                                    -  enabled
                        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Adapters
                        Used repository: stable
                        Adapter    "admin"        : 7.6.17   , installed 7.6.17
                        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                        Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                        Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                        Adapter    "deconz"       : 1.6.4    , installed 1.6.4
                        Adapter    "denon"        : 1.15.12  , installed 1.15.12
                        Adapter    "devices"      : 1.1.5    , installed 1.1.5
                        Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
                        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                        Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                        Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                        Adapter    "govee-local"  : 0.2.8    , installed 0.2.8
                        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                        Adapter    "ical"         : 1.16.2   , installed 1.16.2
                        Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
                        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                        Adapter    "iot"          : 3.3.0    , installed 3.3.0
                        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                        Controller "js-controller": 7.0.7    , installed 7.0.7
                        Adapter    "kodi"         : 3.1.0    , installed 3.1.0
                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                        Adapter    "meross"       : 1.17.0   , installed 1.17.0
                        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                        Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                        Adapter    "openligadb"   : 1.9.0    , installed 1.9.0
                        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                        Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                        Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                        Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
                        Adapter    "tado"         : 0.7.10   , installed 0.7.10
                        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                        Adapter    "tuya"         : 3.16.0   , installed 3.17.0
                        Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
                        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                        Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                        Adapter    "web"          : 7.0.8    , installed 7.0.8
                        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                        Adapter    "ws"           : 2.6.2    , installed 3.0.19
                        Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                        Objects and States
                        Objects: 	25864
                        States: 	22325
                        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       5126439    254861/iobroker.js-
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       5125608    254861/iobroker.js-
                        tcp        0      0 0.0.0.0:37009           0.0.0.0:*               LISTEN      1001       5128832    255829/io.yahka.0
                        tcp        0      0 192.168.62.93:8701      0.0.0.0:*               LISTEN      1001       5127136    255452/io.hm-rpc.4
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          769        619/sshd: /usr/sbin
                        tcp        0      0 192.168.62.93:2010      0.0.0.0:*               LISTEN      1001       5129564    255441/io.hm-rpc.3
                        tcp        0      0 192.168.62.93:12001     0.0.0.0:*               LISTEN      1001       5127692    255400/io.hm-rpc.2
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       5130924    255685/io.shelly.1
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          771        619/sshd: /usr/sbin
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5123984    254984/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6609596    329621/io.web.0
                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       5130725    256040/io.socketio.
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       5131273    256008/io.simple-ap
                        tcp6       0      0 :::8089                 :::*                    LISTEN      1001       5130022    256101/io.terminal.
                        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       5128896    255703/io.sonos.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       5129240    255214/io.deconz.0
                        udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       5127522    255360/io.govee-loc
                        udp        0      0 0.0.0.0:49092           0.0.0.0:*                           104        5483       460/avahi-daemon: r
                        udp        0      0 0.0.0.0:45197           0.0.0.0:*                           1001       5126777    255181/io.broadlink
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5130160    255788/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5130161    255788/io.tuya.0
                        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       5126770    255181/io.broadlink
                        udp        0      0 0.0.0.0:58518           0.0.0.0:*                           1001       7156864    255181/io.broadlink
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5131303    256180/io.wled.0
                        udp        0      0 192.168.62.93:5353      0.0.0.0:*                           1001       5130579    255732/io.tr-064.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5481       460/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       5128982    255610/io.shelly.0
                        udp6       0      0 :::1900                 :::*                                1001       5129243    255214/io.deconz.0
                        udp6       0      0 :::1900                 :::*                                1001       5129242    255214/io.deconz.0
                        udp6       0      0 :::1900                 :::*                                1001       5129241    255214/io.deconz.0
                        udp6       0      0 fe80::ec38:3d4e:49e:546 :::*                                0          5618       549/NetworkManager
                        udp6       0      0 :::5353                 :::*                                104        5482       460/avahi-daemon: r
                        udp6       0      0 :::44360                :::*                                104        5484       460/avahi-daemon: r
                        2025-09-06 13:01:31.598  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6 with null  {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}}
                        2025-09-06 13:01:31.601  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.hour_value with 17:00
                        2025-09-06 13:01:31.610  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.temp_value with 18 °C
                        2025-09-06 13:01:31.619  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_desc2 with Bewölkt mit stürmischen Regenschauern
                        2025-09-06 13:01:31.636  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_value2 with 12
                        2025-09-06 13:01:31.655  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_desc with Bewölkt mit mäßigem Regen
                        2025-09-06 13:01:31.673  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_value with 9
                        2025-09-06 13:01:31.686  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/9.png
                        2025-09-06 13:01:31.696  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_symbolB with 26
                        2025-09-06 13:01:31.705  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_symbol with 2
                        2025-09-06 13:01:31.714  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_dir with NE
                        2025-09-06 13:01:31.725  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_value with 4 km/h
                        2025-09-06 13:01:31.737  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/26.png
                        2025-09-06 13:01:31.746  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.windgusts_value with 14 km/h
                        2025-09-06 13:01:31.754  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.rain_value with 3.3 mm
                        2025-09-06 13:01:31.763  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.humidity_value with 87
                        2025-09-06 13:01:31.771  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.pressure_value with 1014 mb
                        2025-09-06 13:01:31.780  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.clouds_value with 66%
                        2025-09-06 13:01:31.787  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.snowline_value with 3400 m
                        2025-09-06 13:01:31.796  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.windchill_value with 18 °C
                        2025-09-06 13:01:31.804  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.uv_index_value with 1
                        2025-09-06 13:01:31.813  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7 with null  {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}}
                        2025-09-06 13:01:31.817  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7.hour_value with 20:00
                        2025-09-06 13:01:31.825  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7.temp_value with 16 °C
                        2025-09-06 13:01:31.835  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7.symbol_desc2 with Bewölkt
                        iob diag has finished.
                        kai@raspberrypi:~ $
                        • K Offline
                          kg36304
                          also ich habe aktuell umgestellt. Mein Master läuft jetzt auf Proxmox und das deutlich schneller als auf dem Raspberry.
                          Leider habe ich immernoch das Problem, dass die Backups alle gezogen werden ausser von Influxdb (ist noch die 1er Version. Laufen tut alles nur halt nicht das Backup und bevor ich umziehe bzw. neu aufsetze möchte ich die Daten halt speichern.
                          Muss ich auf dem Master auch influxdb installieren obwohl es schon auf dem anderen Raspberry läuft?
                          Auf dem Master kommt das
                          kai@iobrokerMaster:~$ apt policy influxdb
                          influxdb:
                            Installed: (none)
                            Version table:
                               1.6.7~rc0-1+b13 500
                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                          und auf dem Infludb Pi das
                          pi@InfluxGrafana:~ $ apt policy influxdb
                          influxdb:
                            Installed: 1.8.4-1
                            Candidate: 1.8.4-1
                            Version table:
                           *** 1.8.4-1 500
                               1.6.4-1+deb10u1 500
                          Ich weiß das der Buster überfällig ist aber ohne Backup kann ich nicht neu aufsetzen. Würde dann gerne auf Proxmox eine separate Umgebung für Influxdb und Grafana erstellen. In dem Zusammenhang die Frage, ob ich gleich auf die Influxdb2 gehe, geht das?
                          Vielen Dank
                          liebe Grüße
                          Kai
                          • K kg36304
                            influxdb:
                              Installed: (none)
                              Version table:
                                 1.6.7~rc0-1+b13 500
                            influxdb:
                              Installed: 1.8.4-1
                              Candidate: 1.8.4-1
                              Version table:
                             *** 1.8.4-1 500
                                 1.6.4-1+deb10u1 500
                            Vielen Dank
                            liebe Grüße
                            Kai
                            @kg36304
                            Typischer Fall von: 'So lange updates/upgrades herauszögern weil es zu 'kompliziert' ist um dann festzustellen, dass es dadurch erst recht kompliziert wurde...'
                            Der Buster ist jetzt schon wie lange EndOfLife?
                            Du musst für Backups auf beiden Kisten influxdb installiert haben. Auf dem client reichen die entsprechenden client-Pakete aus. Das ganze nach Möglichkeit in gleicher Version, mindestens aber gleiche Major-Version.
