  4. Backup Fehler nach Neuaufsetzung
    6.5k
13 Beiträge 2 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • K kg36304
    ich habe mein System neu aufgesetzt, also Iobroker Master und zwei Slave´s jeweils auf Raspberry´s.
    Danch das Backup wieder eingespielt.
    Seit dem macht Backitup zicken mit InfluxDB (auf einer separaten Pi Büchse).
    Folgende Meldung kommt und ich kann nicht finde, wo der Fehler liegt.
    Danke.
    0:18:01.869
    INFO
    gui
    Backup gestartet ...
    10:18:23.655
    DEBUG
    iobroker
    host.raspberrypi 25677 objects saved
    10:18:27.230
    DEBUG
    iobroker
    host.raspberrypi 22307 states saved
    host.raspberrypi Validating backup ...
    10:18:27.272
    DEBUG
    iobroker
    host.raspberrypi "config.json" is valid
    10:18:27.279
    DEBUG
    iobroker
    host.raspberrypi "objects.jsonl" exists
    host.raspberrypi "states.jsonl" exists
    10:18:28.565
    DEBUG
    iobroker
    host.raspberrypi JSONL lines are valid
    10:18:29.673
    DEBUG
    iobroker
    host.raspberrypi The backup is valid!
    10:18:46.155
    DEBUG
    iobroker
    Backup created: /opt/iobroker/backups/iobroker_2025_09_06-10_18_02_backupiobroker.tar.gz
    10:18:46.163
    DEBUG
    iobroker
    This backup can only be restored with js-controller version 7.0 or higher
    10:18:47.215
    DEBUG
    iobroker
    done
    10:18:47.387
    DEBUG
    influxDB
    InfluxDB-Backup started ...
    10:18:47.396
    DEBUG
    influxDB
    Start InfluxDB Backup ...
    10:18:47.446
    DEBUG
    influxDB
    InfluxDB Backup tmp directory created
    10:18:47.450
    DEBUG
    influxDB
    Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker"
    10:18:47.457
    DEBUG
    influxDB
    InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker" successfully deleted
    [DEBUG] [influxDB] -
    10:18:47.506
    ERROR
    influxDB
    Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker"
    /bin/sh: 1: influxd: not found
    10:18:47.514
    DEBUG
    influxDB
    done
    10:18:48.652
    DEBUG
    grafana
    Start Grafana Backup ...
    10:18:48.657
    DEBUG
    grafana
    Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    10:18:48.672
    DEBUG
    grafana
    Created dashboard directory
    10:18:48.751
    DEBUG
    grafana
    Created folder directory
    10:18:48.757
    DEBUG
    grafana
    Created dashboards_manually_restore directory
    10:18:48.760
    DEBUG
    grafana
    Created datasource directory
    10:18:48.765
    DEBUG
    grafana
    start Grafana request ...
    10:18:48.791
    DEBUG
    grafana
    Grafana is available ... Status: 200
    10:18:49.627
    DEBUG
    grafana
    found Dashboard: mein-dashboard
    10:18:49.745
    DEBUG
    grafana
    Saved dashboard-folder mapping
    10:18:50.031
    DEBUG
    grafana
    start Grafana backup compress ...
    10:18:55.060
    DEBUG
    grafana
    Backup created: /opt/iobroker/backups/grafana_2025_09_06-10_18_49_backupiobroker.tar.gz
    10:18:55.075
    DEBUG
    grafana
    Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    10:18:55.130
    DEBUG
    grafana
    Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    10:18:55.137
    DEBUG
    grafana
    done
    10:18:58.079
    DEBUG
    googledrive
    Google Drive: Copy iobroker_2025_09_06-10_18_02_backupiobroker.tar.gz...
    10:19:08.548
    ERROR
    googledrive
    Google Drive: File "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker.tar.gz" not found
    10:19:09.483
    DEBUG
    googledrive
    Google Drive: Copy grafana_2025_09_06-10_18_49_backupiobroker.tar.gz...
    10:19:11.043
    DEBUG
    googledrive
    done
    10:19:11.181
    ERROR
    clean
    Backup files not deleted from /opt/iobroker/backups because some errors.
    10:19:11.224
    DEBUG
    clean
    done
    10:19:11.468
    DEBUG
    historyHTML
    new history html values created
    10:19:11.765
    DEBUG
    historyHTML
    done
    10:19:11.987
    DEBUG
    historyJSON
    new history json values created
    10:19:12.037
    DEBUG
    historyJSON
    done
    10:19:13.293
    DEBUG
    telegram
    done
    10:19:14.519
    DEBUG
    notification
    Admin notification will be sent
    10:19:14.561
    DEBUG
    notification
    done
    10:19:14.663
    INFO
    gui
    Das Backup wurde erfolgreich erstellt!
    @kg36304 sagte in Backup Fehler nach Neuaufsetzung:
    Da fehlt influx auf mindestens einer der Kisten. Es muss der passende influx-client installiert sein.
      kg36304
      Das heißt auf dem Master auf dem ich das Backup starte müsste quasi der client drauf?
      Hast Du den Befehl gerade greifbar?
      Vielen Dank
      Kai
      • K kg36304
        Vielen Dank
        Kai
        Nein, das Paket hängt davon ab, welche Version von influxdb da installiert ist.
        Bei mir wäre es wohl influxdb2-client oder sowas:
        echad@chet:~ $ apt policy influxdb
        influxdb              influxdb2-cli         influxdb3-core        influxdb-client
        influxdb2             influxdb2-client      influxdb3-enterprise  influxdb-python
        echad@chet:~ $
        Edit:
        echad@chet:~ $ dpkg -S /usr/bin/influxd
        influxdb: /usr/bin/influxd
        Kommt also aus dem Paket 'influxdb'. Ist das bei dir installiert? Check das mit
        sudo apt update
        apt policy influxdb
          echad@chet:~ $
          Edit:
          sudo apt update
          apt policy influxdb
          kg36304
          @thomas-braun said in Backup Fehler nach Neuaufsetzung:
          apt policy influxdb
          Also auf meinem Iobroker Master (Influxdb ist auf einem separaten Pi)
          kommt das:
          kai@raspberrypi:~ $ apt policy influxdb
          influxdb:
            Installed: (none)
            Candidate: 1.6.7~rc0-1+b13
            Version table:
               1.6.7~rc0-1+b13 500
                  500 http://deb.debian.org/debian bookworm/main arm64 Packages
          und
          kai@raspberrypi:~ $ dpkg -S /usr/bin/influxd
          dpkg-query: no path found matching pattern /usr/bin/influxd
          Auf dem Influxdp pi kommt das:
          pi@raspberrypi:~ $ apt policy influxdb
          influxdb:
            Installed: 1.8.4-1
            Candidate: 1.8.4-1
            Version table:
           *** 1.8.4-1 500
                  500 https://repos.influxdata.com/debian buster/stable armhf Packages
               1.6.4-1+deb10u1 500
                  500 https://archive.raspbian.org/raspbian buster/main armhf Packages
          pi@raspberrypi:~ $
          Wie gesagt ich starte das Backup auf dem Iobroker Master und die die InfluxDB ist zusammen mit Grafana auf einem separaten Raspberry.
          • K kg36304
            apt policy influxdb
            kommt das:
            influxdb:
              Installed: (none)
              Version table:
                 1.6.7~rc0-1+b13 500
            und
            influxdb:
              Installed: 1.8.4-1
              Candidate: 1.8.4-1
              Version table:
             *** 1.8.4-1 500
                 1.6.4-1+deb10u1 500
            pi@raspberrypi:~ $
            @kg36304
            Da ist aber mit Sicherheit auch noch mehr krumm/falsch/veraltet.
            Buster ist läääääääääääängst abgekündigt.
            Stell die Kisten erstmal auf eine stabile Basis.
            Und zweimal der gleiche hostname in einem Netz ist auch Krampf.
              kg36304
              die iobroker sind alle auf Bookworm umgestellt, daher kommen meine Probleme.
              Der Pi wo Grafana und influxdb drauf laufen ist noch alt.
              Hostname habe ich geändert, das war erstmal das einfachste.
              InfluxDB und Grafana liefern auf jeden Fall Daten und Grafana wird auch gebackupt. Das ist schon mal was.
              Leider geht das Backup von Influxdb nicht.
              Muss mich jetzt wohl erst mal schlau machen wie ich das System auf Bookworm umhebe und alle daten wieder drauf bekomme.
              Danke.
              • K kg36304
                Danke.
                Gar nicht. Installier das neu. Das läuft ja auch als 32Bit-System. Will man nicht.
                  kg36304
                  Also Neustes Betriebssystem drauf und InfluxDB und Grafana neu drauf installieren?
                  Und die gespeicherten Daten vom Backup wieder drauf?
                  Sehe ich das richtig?
                  Nochmal danke.
                  • K kg36304
                    Nochmal danke.
                    Mit wie vielen Systemen auf welchem Stand jonglierst du denn da eigentlich herum?
                    Für mal auf allen Kisten ein
                    iob diag
                    aus (sofern verfügbar).
                      iob diag
                      kg36304
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                       Static hostname: raspberrypi
                             Icon name: computer
                                Kernel: Linux 6.12.34+rpt-rpi-v8
                          Architecture: arm64
                      OS is similar to:
                      Model		: Raspberry Pi 4 Model B Rev 1.1
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       12:59:46 up 2 days, 23:10,  2 users,  load average: 1.53, 1.38, 1.38
                      CPU threads: 4
                      *** LIFE CYCLE STATUS ***
                      Operating System is the current Debian stable version codenamed 'bookworm'!
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** TIME AND TIMEZONES ***
                                     Local time: Sat 2025-09-06 12:59:47 CEST
                                 Universal time: Sat 2025-09-06 10:59:47 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      kai
                      HOME=/home/kai
                      GROUPS=kai adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server: 	false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session: 		tty
                      *** MEMORY ***
                      Mem:            4.0G        3.2G        264M        2.3M        583M        747M
                      Swap:           1.1G        1.0G         32M
                      Total:          5.1G        4.3G        296M
                      Active iob-Instances: 	55
                               3795 M total memory
                               3083 M used memory
                               2082 M active memory
                               1257 M inactive memory
                                251 M free memory
                                 39 M buffer memory
                                516 M swap cache
                               1023 M total swap
                                993 M used swap
                                 30 M free swap
                      top - 12:59:47 up 2 days, 23:10,  2 users,  load average: 1.53, 1.38, 1.38
                      Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  9.1 us,  9.1 sy,  0.0 ni, 72.7 id,  9.1 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3795.9 total,    251.7 free,   3083.1 used,    556.8 buff/cache
                      MiB Swap:   1024.0 total,     30.9 free,    993.1 used.    712.8 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      udev           devtmpfs  1.6G     0  1.6G   0% /dev
                      tmpfs          tmpfs     380M  5.9M  374M   2% /run
                      /dev/sda2      ext4      117G  6.1G  106G   6% /
                      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                      /dev/sda1      vfat      510M   58M  453M  12% /boot/firmware
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                      [Wed Sep  3 13:49:20 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:50:A2:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=1d815a5d-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Wed Sep  3 13:49:22 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                      [Wed Sep  3 13:49:23 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
                      Show mounted filesystems:
                      TARGET           SOURCE    FSTYPE OPTIONS
                      /                /dev/sda2 ext4   rw,noatime
                      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      1.4G	/var/
                      210M	/var/cache
                      204M	/var/cache/apt
                      168M	/var/lib
                      135M	/var/lib/apt/lists
                      Archived and active journals take up 4.7M in the file system.
                      /opt/iobroker/backups:
                      218M	/opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      739M	/opt/iobroker/iobroker-data/
                      593M	/opt/iobroker/iobroker-data/files
                      112M	/opt/iobroker/iobroker-data/backup-objects
                      74M	/opt/iobroker/iobroker-data/files/vis.0
                      74M	/opt/iobroker/iobroker-data/files/vis-2.0
                      38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                      27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                      26M	/opt/iobroker/iobroker-data/objects.jsonl
                      24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs 	v22.19.0
                      /usr/bin/node 		v22.19.0
                      /usr/bin/npm 		10.9.3
                      /usr/bin/npx 		10.9.3
                      /usr/bin/corepack 	0.34.0
                      nodejs:
                        Installed: 22.19.0-1nodesource1
                        Candidate: 22.19.0-1nodesource1
                        Version table:
                       *** 22.19.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                           22.18.0-1nodesource1 1001
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                           18.20.4+dfsg-1~deb12u1 500
                              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                           18.19.0+dfsg-6~deb12u2 500
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      Slave               Slave (version: 7.0.7, hostname: Slave         , alive, uptime: 265791)
                      iobrokergarten      iobrokergarten (version: 7.0.7, hostname: iobrokergarten, alive, uptime: 332732)
                      raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 72640)
                      Core adapters versions
                      js-controller: 	7.0.7
                      admin: 		7.6.17
                      javascript: 	8.9.2
                      nodejs modules from github: 	2
                      | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
                      +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#640df7360a877f37764a31d628e4d6de3ed1f6e3)
                      Adapter State
                      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                      + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                      + system.adapter.ds18b20.0                : ds18b20               : Slave                                    -  enabled
                      + system.adapter.ds18b20.1                : ds18b20               : iobrokergarten                           -  enabled
                        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                      + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                      + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
                      + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
                      + system.adapter.hm-rega.1                : hm-rega               : raspberrypi                              -  enabled
                      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                      + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                      + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                      + system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
                      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                      + system.adapter.mqtt.0                   : mqtt                  : Slave                                    -  enabled, port: 1886, bind: 0.0.0.0
                      + system.adapter.octoprint.0              : octoprint             : Slave                                    -  enabled
                      + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
                      + system.adapter.openligadb.1             : openligadb            : raspberrypi                              -  enabled
                      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                      + system.adapter.rpi2.1                   : rpi2                  : Slave                                    -  enabled
                      + system.adapter.rpi2.2                   : rpi2                  : iobrokergarten                           -  enabled
                      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
                      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      + system.adapter.sonoff.0                 : sonoff                : Slave                                    -  enabled, port: 1884, bind: 0.0.0.0
                      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                      + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
                      + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                      + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                      + system.adapter.worx.0                   : worx                  : Slave                                    -  enabled
                      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Used repository: stable
                      Adapter    "admin"        : 7.6.17   , installed 7.6.17
                      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                      Adapter    "deconz"       : 1.6.4    , installed 1.6.4
                      Adapter    "denon"        : 1.15.12  , installed 1.15.12
                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                      Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
                      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                      Adapter    "govee-local"  : 0.2.8    , installed 0.2.8
                      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                      Adapter    "ical"         : 1.16.2   , installed 1.16.2
                      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                      Controller "js-controller": 7.0.7    , installed 7.0.7
                      Adapter    "kodi"         : 3.1.0    , installed 3.1.0
                      Adapter    "linux-control": 1.1.5    , installed 1.1.5
                      Adapter    "meross"       : 1.17.0   , installed 1.17.0
                      Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                      Adapter    "openligadb"   : 1.9.0    , installed 1.9.0
                      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                      Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
                      Adapter    "tado"         : 0.7.10   , installed 0.7.10
                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                      Adapter    "tuya"         : 3.16.0   , installed 3.17.0
                      Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
                      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                      Adapter    "wled"         : 0.7.2    , installed 0.7.2
                      Adapter    "ws"           : 2.6.2    , installed 3.0.19
                      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                      Objects and States
                      Objects: 	25864
                      States: 	22325
                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       5126439    254861/iobroker.js-
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       5125608    254861/iobroker.js-
                      tcp        0      0 0.0.0.0:37009           0.0.0.0:*               LISTEN      1001       5128832    255829/io.yahka.0
                      tcp        0      0 192.168.62.93:8701      0.0.0.0:*               LISTEN      1001       5127136    255452/io.hm-rpc.4
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          769        619/sshd: /usr/sbin
                      tcp        0      0 192.168.62.93:2010      0.0.0.0:*               LISTEN      1001       5129564    255441/io.hm-rpc.3
                      tcp        0      0 192.168.62.93:12001     0.0.0.0:*               LISTEN      1001       5127692    255400/io.hm-rpc.2
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       5130924    255685/io.shelly.1
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          771        619/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5123984    254984/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6609596    329621/io.web.0
                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       5130725    256040/io.socketio.
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       5131273    256008/io.simple-ap
                      tcp6       0      0 :::8089                 :::*                    LISTEN      1001       5130022    256101/io.terminal.
                      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       5128896    255703/io.sonos.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       5129240    255214/io.deconz.0
                      udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       5127522    255360/io.govee-loc
                      udp        0      0 0.0.0.0:49092           0.0.0.0:*                           104        5483       460/avahi-daemon: r
                      udp        0      0 0.0.0.0:45197           0.0.0.0:*                           1001       5126777    255181/io.broadlink
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5130160    255788/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5130161    255788/io.tuya.0
                      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       5126770    255181/io.broadlink
                      udp        0      0 0.0.0.0:58518           0.0.0.0:*                           1001       7156864    255181/io.broadlink
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5131303    256180/io.wled.0
                      udp        0      0 192.168.62.93:5353      0.0.0.0:*                           1001       5130579    255732/io.tr-064.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5481       460/avahi-daemon: r
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       5128982    255610/io.shelly.0
                      udp6       0      0 :::1900                 :::*                                1001       5129243    255214/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       5129242    255214/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       5129241    255214/io.deconz.0
                      udp6       0      0 fe80::ec38:3d4e:49e:546 :::*                                0          5618       549/NetworkManager
                      udp6       0      0 :::5353                 :::*                                104        5482       460/avahi-daemon: r
                      udp6       0      0 :::44360                :::*                                104        5484       460/avahi-daemon: r
                      2025-09-06 13:01:31.598  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6 with null  {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}}
                      2025-09-06 13:01:31.601  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.hour_value with 17:00
                      2025-09-06 13:01:31.610  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.temp_value with 18 °C
                      2025-09-06 13:01:31.619  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_desc2 with Bewölkt mit stürmischen Regenschauern
                      2025-09-06 13:01:31.636  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_value2 with 12
                      2025-09-06 13:01:31.655  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_desc with Bewölkt mit mäßigem Regen
                      2025-09-06 13:01:31.673  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_value with 9
                      2025-09-06 13:01:31.686  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/9.png
                      2025-09-06 13:01:31.696  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_symbolB with 26
                      2025-09-06 13:01:31.705  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_symbol with 2
                      2025-09-06 13:01:31.714  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_dir with NE
                      2025-09-06 13:01:31.725  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_value with 4 km/h
                      2025-09-06 13:01:31.737  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/26.png
                      2025-09-06 13:01:31.746  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.windgusts_value with 14 km/h
                      2025-09-06 13:01:31.754  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.rain_value with 3.3 mm
                      2025-09-06 13:01:31.763  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.humidity_value with 87
                      2025-09-06 13:01:31.771  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.pressure_value with 1014 mb
                      2025-09-06 13:01:31.780  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.clouds_value with 66%
                      2025-09-06 13:01:31.787  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.snowline_value with 3400 m
                      2025-09-06 13:01:31.796  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.windchill_value with 18 °C
                      2025-09-06 13:01:31.804  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.uv_index_value with 1
                      2025-09-06 13:01:31.813  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7 with null  {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}}
                      2025-09-06 13:01:31.817  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7.hour_value with 20:00
                      2025-09-06 13:01:31.825  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7.temp_value with 16 °C
                      2025-09-06 13:01:31.835  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7.symbol_desc2 with Bewölkt
                      iob diag has finished.
                      kai@raspberrypi:~ $
                        kg36304
                        also ich habe aktuell umgestellt. Mein Master läuft jetzt auf Proxmox und das deutlich schneller als auf dem Raspberry.
                        Leider habe ich immernoch das Problem, dass die Backups alle gezogen werden ausser von Influxdb (ist noch die 1er Version. Laufen tut alles nur halt nicht das Backup und bevor ich umziehe bzw. neu aufsetze möchte ich die Daten halt speichern.
                        Muss ich auf dem Master auch influxdb installieren obwohl es schon auf dem anderen Raspberry läuft?
                        Auf dem Master kommt das
                        kai@iobrokerMaster:~$ apt policy influxdb
                        influxdb:
                          Installed: (none)
                          Version table:
                             1.6.7~rc0-1+b13 500
                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                        und auf dem Infludb Pi das
                        pi@InfluxGrafana:~ $ apt policy influxdb
                        influxdb:
                          Installed: 1.8.4-1
                          Candidate: 1.8.4-1
                          Version table:
                         *** 1.8.4-1 500
                             1.6.4-1+deb10u1 500
                        Ich weiß das der Buster überfällig ist aber ohne Backup kann ich nicht neu aufsetzen. Würde dann gerne auf Proxmox eine separate Umgebung für Influxdb und Grafana erstellen. In dem Zusammenhang die Frage, ob ich gleich auf die Influxdb2 gehe, geht das?
                        Vielen Dank
                        liebe Grüße
                        Kai
                        • K kg36304
                          influxdb:
                            Installed: (none)
                            Version table:
                               1.6.7~rc0-1+b13 500
                          influxdb:
                            Installed: 1.8.4-1
                            Candidate: 1.8.4-1
                            Version table:
                           *** 1.8.4-1 500
                               1.6.4-1+deb10u1 500
                          Vielen Dank
                          liebe Grüße
                          Kai
                          @kg36304
                          Typischer Fall von: 'So lange updates/upgrades herauszögern weil es zu 'kompliziert' ist um dann festzustellen, dass es dadurch erst recht kompliziert wurde...'
                          Der Buster ist jetzt schon wie lange EndOfLife?
                          Du musst für Backups auf beiden Kisten influxdb installiert haben. Auf dem client reichen die entsprechenden client-Pakete aus. Das ganze nach Möglichkeit in gleicher Version, mindestens aber gleiche Major-Version.
