  4. js Controler auf 7.07 geht nicht Fehlermeldung iOb
    1.0k
    6.1k
52 Beiträge 6 Kommentatoren 4.9k Aufrufe 5 Beobachtet
    @marcel-drzal
    dpkg ist aber das Paketmanagement auf OS-Ebene. Da ist also eine Etage tiefer schon was schief.
    sudo apt update
    sagt?
    marcel-drzalM Offline
    marcel-drzal
    schrieb am zuletzt editiert von marcel-drzal
    direcktes uptadt aus iobroker:
    marcel@10.10.50.16's password:
    Linux iobroker 6.14.8-2-pve #1 SMP PREEMPT_DYNAMIC PMX 6.14.8-2 (2025-07-22T10:0                                                       4Z) x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Tue Aug 26 18:40:15 2025 from 10.10.10.166
    marcel@iobroker:~$ sudo apt update
    [sudo] password for marcel:
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Get:2 http://security.debian.org/debian-security trixie-security InRelease [43.4                                                        kB]
    Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.1 kB]
    Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
    Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
    Get:6 http://security.debian.org/debian-security trixie-security/main amd64 Pack                                                       ages [33.1 kB]
    Get:7 http://security.debian.org/debian-security trixie-security/main Translatio                                                       n-en [22.0 kB]
    Err:4 https://repos.influxdata.com/debian buster InRelease
      The following signatures couldn't be verified because the public key is not av                                                       ailable: NO_PUBKEY D8FF8E1F7DF8B07E
    Get:8 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [7803 B]
    Err:9 https://dl.yarnpkg.co m/debian InRelease
      Could not connect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connec                                                       tion refused) Could not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect                                                        (111: Connection refused)
    Fetched 178 kB in 1s (325 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    471 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: An error occurred during the signature verification. The repository is not up                                                       dated and the previous index files will be used. GPG error: https://repos.influx                                                       data.com/debian buster InRelease: The following signatures couldn't be verified                                                        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  T                                                       he following signatures couldn't be verified because the public key is not avail                                                       able: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not con                                                       nect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connection refused) C                                                       ould not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect (111: Connecti                                                       on refused)
    W: Some index files failed to download. They have been ignored, or old ones used                                                        instead.
    PlatformBetriebssystem:linux
    Architektur:x64
    CPUs:2
    Geschwindigkeit:4043 MHz
    Modell:unknown
    RAM:6 GB
    System-Betriebszeit:2 T. 00:15:05
    Node.js:v22.18.0
    Zeit:1756964837826
    Zeitversatz:-120
    NPM:10.9.3
    Adapter-Anzahl:574
    Datenträgergröße:29.4 GB
    Freier Festplattenspeicher:18.5 GB
    Aktive Instanzen:21
    Pfad:/opt/iobroker/
    Betriebszeit:2 T. 00:15:01
    aktiv:true
    _nodeCurrent:22.18.0
    _nodeNewest:22.19.0
    _nodeNewestNext:22.19.0
    _npmCurrent:10.9.3
    _npmNewest:10.9.3
    _npmNewestNext:10.9.3
    • marcel-drzalM marcel-drzal
      Architektur:x64
      CPUs:2
      Modell:unknown
      RAM:6 GB
      Node.js:v22.18.0
      Zeit:1756964837826
      Zeitversatz:-120
      NPM:10.9.3
      Adapter-Anzahl:574
      Aktive Instanzen:21
      Pfad:/opt/iobroker/
      aktiv:true
      _nodeNewest:22.19.0
      _npmCurrent:10.9.3
      _npmNewest:10.9.3
      @marcel-drzal
      Hau die 471 Updates rein, verdammt.
      Die influxdb-Quelle ist veraltet. Leg die neu an.
      Geht so:
      https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
      Und dann schau, aus welcher Datei dieses yarn-Dingsi kommt.
      cd /etc/apt/
      grep -r yarn .
      Die Zeile mit dem Eintrag zu yarn würde ich löschen.
      marcel-drzalM 1 Antwort Letzte Antwort
        @marcel-drzal
        Geht so:
        cd /etc/apt/
        grep -r yarn .
        marcel-drzal
        habe ich bekomme hier die Meldung:
        Fetched 38.5 MB in 3s (11.3 MB/s)
        Reading changelogs... Done
        Extracting templates from packages: 100%
        Preconfiguring packages ...
        (Reading database ... 43860 files and directories currently installed.)
        Preparing to unpack .../base-files_13.8_amd64.deb ...
        * The base-files package cannot be installed because
        * /bin is a directory, but should be a symbolic link.
        * Please install the usrmerge package to convert this system to merged-/usr.
        * For more information please read https://wiki.debian.org/UsrMerge.
        dpkg: error processing archive /var/cache/apt/archives/base-files_13.8_amd64.deb (--unpack):
         new base-files package pre-installation script subprocess returned error exit status 1
        Errors were encountered while processing:
        E: Sub-process /usr/bin/dpkg returned an error code (1)
        marcel@iobroker:~$
          marcel@iobroker:~$
          @marcel-drzal
          Hast du das ganze Ding über Jahre von Release zu Release geschliffen?
          Oder von Buster direkt auf Trixie gesprungen?
          Da scheint mir einiges schiefgelaufen zu sein.
          Installier es von Grund auf neu.
            @marcel-drzal
            marcel-drzal
            @thomas-braun nein denke habe es immer auf den neusten Stand gehalten.
            Neu? Gibt es einen anderen Weg. Wie kann ich da am besten vor gehen?
              @marcel-drzal sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
              Von wo aus? Also doch über Generationen rübergetragen?
              Ich würde es neuinstallieren. Da fehlt mindestens der usrmerge auf der Kiste und wer weiß was sonst noch alles.
              Edit:
              Und dein Herumgehampel als root trägt auch nicht dazu bei da ein stabiles, sauberes System zu haben.
                Edit:
                marcel-drzal
                ok, ich mach alles neu.
                kannst du mir dabei helfen?
                würde erst mal ein neues sauberes System auf setzen in Proxmox.
                also es erst mal parallel laufen lassen und nach und nach alles rüber ziehen.
                oder geht das nich ?
                ich denke wenn ich ein Backup ziehe in iobroker habe ich die gelichen Probleme dann wieder oder?
                da_WoodyD Thomas BraunT 2 Antworten Letzte Antwort
                  da_WoodyD Offline
                  da_WoodyD Offline
                  da_Woody
                  @marcel-drzal bin jetzt auch kein profi, aber sauber aufsetzen (beschreibungen gibts genug), backup mit dem backitup adapter machen, dann sollten keine schweinereien mehr sein nach rückspielen.
                  gruß vom Woody
                    Nein, das darunterliegende System ist krumm und schief, der ioBroker dürfte da nicht direkt von betroffen sein.
                    Zur Installation auf Proxmox:
                    https://www.iobroker.net/#de/documentation/install/proxmox.md
                      da_WoodyD Offline
                      da_WoodyD Offline
                      da_Woody
                      @thomas-braun da wäre erstmal die frage, wie aktuell proxmox ist... ;)
                      gruß vom Woody
                      • da_WoodyD da_Woody
                        @da_woody
                        Da würde ich halt auch die aktuelle Version empfehlen...
                          @da_woody
                          marcel-drzal
                          @thomas-braun Danke erst mal.
                          ich werde einen neuen iObroker auf einen LXC Container erstellen.
                          Kann ich die beiden iObroker dann parallel laufen lassen oder muss ich den alten ab stellen?
                            @marcel-drzal
                            Das hängt von den Adaptern ab, ob da Doubles möglich sind. Tendenziell würde ich es aber vermeiden Dinge doppelt laufen zu haben
                            • marcel-drzalM Offline
                              marcel-drzal
                              Iobroker läuft
                              auf den neuen System
                              das alte habe ich erst mal runter gefahren.
                              am Ende der Instllation kam die info das ich iob fix eingeben soll nach dem es läuft.
                              hier erhalte ich aber eine Fehlermeldung:
                              marcel@PiObroker:/opt/iobroker$ iob stop
                              marcel@PiObroker:/opt/iobroker$ iob fix
                              bash: /home/iobroker/.fix.sh: Permission denied
                              habe aber den Befehl ausgeführt:
                              adduser marcel
                              Anschließend muss der User noch der sudo Gruppe zugeordnet werden.
                              usermod -aG sudo marcel
                              marcel@PiObroker:/opt/iobroker$ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v22.19.0
                              v22.19.0
                              10.9.3
                              marcel
                              /opt/iobroker
                              Hit:2 http://security.debian.org trixie-security InRelease
                              Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                              Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                              All packages are up to date.
                              Warning: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                              nodejs:
                                Installed: 22.19.0-1nodesource1
                                Candidate: 22.19.0-1nodesource1
                                Version table:
                               *** 22.19.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   22.18.0-1nodesource1 1001
                                   22.17.1-1nodesource1 1001
                                   22.17.0-1nodesource1 1001
                                   22.16.0-1nodesource1 1001
                                   22.15.1-1nodesource1 1001
                                   22.15.0-1nodesource1 1001
                                   22.14.0-1nodesource1 1001
                                   22.13.1-1nodesource1 1001
                                   22.13.0-1nodesource1 1001
                                   22.12.0-1nodesource1 1001
                                   22.11.0-1nodesource1 1001
                                   22.10.0-1nodesource1 1001
                                   22.9.0-1nodesource1 1001
                                   22.8.0-1nodesource1 1001
                                   22.7.0-1nodesource1 1001
                                   22.6.0-1nodesource1 1001
                                   22.5.1-1nodesource1 1001
                                   22.5.0-1nodesource1 1001
                                   22.4.1-1nodesource1 1001
                                   22.4.0-1nodesource1 1001
                                   22.3.0-1nodesource1 1001
                                   22.2.0-1nodesource1 1001
                                   22.1.0-1nodesource1 1001
                                   22.0.0-1nodesource1 1001
                                   20.19.2+dfsg-1 500
                                      500 http://deb.debian.org/debian trixie/main amd64 Packages
                              lines 16-57/57 (END)
                                Iobroker läuft
                                adduser marcel
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v22.19.0
                                v22.19.0
                                10.9.3
                                marcel
                                /opt/iobroker
                                nodejs:
                                  Version table:
                                     20.19.2+dfsg-1 500
                                Die kommt immer, das muss nach der Erst Installation gemacht werden.
                                ls -l /home
                                sagt?
                                Edith: Einen User legt man als erstes an, dann kann der nämlich von iobroker-Installer direkt richtig konfiguriert werden.
                                  ls -l /home
                                  sagt?
                                  marcel-drzal
                                  habe erst einen User marcel angelegt wie in der Doku gesagt wurde komisch
                                  marcel@PiObroker:~$ ls -l /home
                                  total 8
                                  drwxr-x--- 2 iobroker iobroker 4096 Sep 11 17:50 iobroker
                                  drwx------ 5 marcel   marcel   4096 Sep 11 18:06 marcel
                                  marcel@PiObroker:~$
                                  CPU: 0,67 %
                                  RAM: 6 %
                                  Betriebszeit: 0h
                                  Verfügbar: 7.0.7
                                  Installiert: 7.0.7
                                  Ereignisse: ⇥5 / ↦13
                                  Plattform: linux
                                  Betriebssystem: linux
                                  Architektur: x64
                                  CPUs: 2
                                  Geschwindigkeit: 400 MHz
                                  Modell: Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
                                  RAM: 6 GB
                                  System-Betriebszeit: 00:04:45
                                  Node.js: v22.19.0
                                  Zeit: 11.9.2025, 18:19:25
                                  Zeitversatz: -120
                                  NPM: 10.9.3
                                  Adapter-Anzahl: 576
                                  Datenträgergröße: 7.8 GB
                                  Freier Festplattenspeicher: 5.5 GB
                                  Aktive Instanzen: 3
                                  Pfad: /opt/iobroker/
                                  Betriebszeit: 00:04:36
                                  aktiv: true
                                  _nodeCurrent: 22.19.0
                                  _nodeNewest: 22.19.0
                                  _nodeNewestNext: 22.19.0
                                  _npmCurrent: 10.9.3
                                  _npmNewest: 10.9.3
                                  _npmNewestNext: 10.9.3
                                    total 8
                                    marcel@PiObroker:~$
                                    CPU: 0,67 %
                                    RAM: 6 %
                                    Betriebszeit: 0h
                                    Verfügbar: 7.0.7
                                    Installiert: 7.0.7
                                    Plattform: linux
                                    Architektur: x64
                                    CPUs: 2
                                    RAM: 6 GB
                                    Node.js: v22.19.0
                                    Zeitversatz: -120
                                    NPM: 10.9.3
                                    Adapter-Anzahl: 576
                                    Aktive Instanzen: 3
                                    aktiv: true
                                    _npmCurrent: 10.9.3
                                    _npmNewest: 10.9.3
                                    @marcel-drzal
                                    Als user marcel:
                                    id
                                      @marcel-drzal
                                      Als user marcel:
                                      id
                                      marcel-drzal
                                      was meinst du mit id
                                      wir bekomme ich das gerade gezogen?
                                        @marcel-drzal
                                        Das ist ein Kommando in deinem Terminal.
                                          @marcel-drzal
                                          marcel-drzal
                                          sorry
                                          marcel@PiObroker:~$ id
                                          uid=1000(marcel) gid=1000(marcel) groups=1000(marcel),27(sudo),100(users),1001(iobroker)
                                          marcel@PiObroker:~$
