  3. Off Topic
  4. Pflege des Betriebssystems
  5. Raspi Update - Hilfe (Close)
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
4 Beiträge 2 Kommentatoren 688 Aufrufe 2 Beobachtet
  • YodaY Offline
    YodaY Offline
    Yoda
    schrieb am zuletzt editiert von Yoda
    ich wollte eben mal ein update von meinem Raspi machen.
    Nun bekomme ich das hier angezeigt und weiß damit nichts anzufangen - was soll ich eingeben?
    login as: pi
    pi@192.168.178.118's password:
    Linux raspberrypi-5 6.12.25+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30) aarch64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Mon Jun 30 11:12:36 2025 from 192.168.178.166
    Wi-Fi is currently blocked by rfkill.
    Use raspi-config to set the country before use.
    pi@raspberrypi-5:~ $ iob stop
    pi@raspberrypi-5:~ $ sudo apt update
    Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
    Get:3 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
    Get:4 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
    Get:5 http://archive.raspberrypi.com/debian bookworm InRelease [55.0 kB]
    Get:6 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [253 kB]
    Get:7 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [268 kB]
    Get:8 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [12.2 kB]
    Get:9 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [11.9 kB]
    Get:10 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [551 kB]
    Get:11 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [554 kB]
    Fetched 1,821 kB in 1s (2,369 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    51 packages can be upgraded. Run 'apt list --upgradable' to see them.
    pi@raspberrypi-5:~ $ sudo apt full-upgrade
    Calculating upgrade... Done
    The following package was automatically installed and is no longer required:
      rpicam-apps-lite
    Use 'sudo apt autoremove' to remove it.
    The following NEW packages will be installed:
      libdtovl0 libgpiolib0 librpicam-app1 linux-headers-6.12.34+rpt-common-rpi
      linux-headers-6.12.34+rpt-rpi-2712 linux-headers-6.12.34+rpt-rpi-v8
      linux-image-6.12.34+rpt-rpi-2712 linux-image-6.12.34+rpt-rpi-v8
      linux-kbuild-6.12.34+rpt rpicam-apps-core
    The following packages will be upgraded:
      ca-certificates gir1.2-gdkpixbuf-2.0 icu-devtools initramfs-tools
      initramfs-tools-core libblockdev-crypto2 libblockdev-fs2 libblockdev-loop2
      libblockdev-part-err2 libblockdev-part2 libblockdev-swap2 libblockdev-utils2
      libblockdev2 libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dbg
      libc6-dev libcamera-ipa libcamera0.5 libgdk-pixbuf-2.0-0
      libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common
      libgnutls30 libicu-dev libicu72 libudisks2-0 libxml2 linux-headers-rpi-2712
      linux-headers-rpi-v8 linux-image-rpi-2712 linux-image-rpi-v8 linux-libc-dev
      locales nodejs pastebinit raspi-config raspi-firmware raspi-utils
      raspi-utils-core raspi-utils-dt raspi-utils-eeprom raspi-utils-otp raspinfo
      rpi-eeprom rpicam-apps-lite sudo udisks2
    51 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
    Need to get 176 MB of archives.
    After this operation, 110 MB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 http://deb.debian.org/debian-security bookworm-security/main arm64 sudo arm64 1.9.13p3-1+deb12u2 [1,827 kB]
    Get:2 http://archive.raspberrypi.com/debian bookworm/main arm64 libc6-dbg arm64 2.36-9+rpt2+deb12u12 [8,131 kB]
    Get:3 https://deb.nodesource.com/node_20.x nodistro/main arm64 nodejs arm64 20.19.4-1nodesource1 [31.1 MB]
    Get:4 http://deb.debian.org/debian-security bookworm-security/main arm64 libgnutls30 arm64 3.7.9-2+deb12u5 [1,314 kB]
    Get:5 http://deb.debian.org/debian bookworm-updates/main arm64 ca-certificates all 20230311+deb12u1 [155 kB]
    Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 libgdk-pixbuf2.0-common all 2.42.10+dfsg-1+deb12u2 [306 kB]
    Get:7 http://deb.debian.org/debian-security bookworm-security/main arm64 libgdk-pixbuf-2.0-dev arm64 2.42.10+dfsg-1+deb12u2 [51.7 kB]
    Get:8 http://deb.debian.org/debian-security bookworm-security/main arm64 libgdk-pixbuf-2.0-0 arm64 2.42.10+dfsg-1+deb12u2 [130 kB]
    Get:9 http://deb.debian.org/debian-security bookworm-security/main arm64 libgdk-pixbuf2.0-bin arm64 2.42.10+dfsg-1+deb12u2 [18.0 kB]
    Get:10 http://deb.debian.org/debian-security bookworm-security/main arm64 gir1.2-gdkpixbuf-2.0 arm64 2.42.10+dfsg-1+deb12u2 [13.4 kB]
    Get:11 http://deb.debian.org/debian-security bookworm-security/main arm64 libicu-dev arm64 72.1-3+deb12u1 [10.2 MB]
    Get:12 http://deb.debian.org/debian-security bookworm-security/main arm64 icu-devtools arm64 72.1-3+deb12u1 [192 kB]
    Get:13 http://deb.debian.org/debian-security bookworm-security/main arm64 libicu72 arm64 72.1-3+deb12u1 [9,202 kB]
    Get:14 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-utils2 arm64 2.28-2+deb12u1 [14.3 kB]
    Get:15 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-crypto2 arm64 2.28-2+deb12u1 [17.3 kB]
    Get:16 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-part-err2 arm64 2.28-2+deb12u1 [5,696 B]
    Get:17 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-fs2 arm64 2.28-2+deb12u1 [21.7 kB]
    Get:18 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-loop2 arm64 2.28-2+deb12u1 [8,392 B]
    Get:19 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-part2 arm64 2.28-2+deb12u1 [16.8 kB]
    Get:20 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-swap2 arm64 2.28-2+deb12u1 [10.2 kB]
    Get:21 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev2 arm64 2.28-2+deb12u1 [38.8 kB]
    Get:22 http://deb.debian.org/debian-security bookworm-security/main arm64 libudisks2-0 arm64 2.9.4-4+deb12u1 [137 kB]
    Get:23 http://deb.debian.org/debian-security bookworm-security/main arm64 libxml2 arm64 2.9.14+dfsg-1.3~deb12u2 [619 kB]
    Get:24 http://deb.debian.org/debian-security bookworm-security/main arm64 udisks2 arm64 2.9.4-4+deb12u1 [385 kB]
    Get:25 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-devtools arm64 2.36-9+rpt2+deb12u12 [61.4 kB]
    Get:26 http://archive.raspberrypi.com/debian bookworm/main arm64 libc6-dev arm64 2.36-9+rpt2+deb12u12 [2,102 kB]
    Get:27 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-dev-bin arm64 2.36-9+rpt2+deb12u12 [49.9 kB]
    Get:28 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-libc-dev all 1:6.12.34-1+rpt1~bookworm [2,314 kB]
    Get:29 http://archive.raspberrypi.com/debian bookworm/main arm64 libc6 arm64 2.36-9+rpt2+deb12u12 [5,001 kB]
    Get:30 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-bin arm64 2.36-9+rpt2+deb12u12 [753 kB]
    Get:31 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-firmware all 1:1.20250430-4~bookworm [12.8 MB]
    Get:32 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-l10n all 2.36-9+rpt2+deb12u12 [1,541 kB]
    Get:33 http://archive.raspberrypi.com/debian bookworm/main arm64 locales all 2.36-9+rpt2+deb12u12 [5,086 kB]
    Get:34 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools all 0.142+rpt4+deb12u3 [17.4 kB]
    Get:35 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools-core all 0.142+rpt4+deb12u3 [53.6 kB]
    Get:36 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera0.5 arm64 0.5.1+rpt20250722-1 [692 kB]
    Get:37 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera-ipa arm64 0.5.1+rpt20250722-1 [877 kB]
    Get:38 http://archive.raspberrypi.com/debian bookworm/main arm64 libdtovl0 arm64 20250514-1~bookworm [28.0 kB]
    Get:39 http://archive.raspberrypi.com/debian bookworm/main arm64 libgpiolib0 arm64 20250514-1~bookworm [37.0 kB]
    Get:40 http://archive.raspberrypi.com/debian bookworm/main arm64 librpicam-app1 arm64 1.8.1-1~bookworm [270 kB]
    Get:41 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.34+rpt-common-rpi all 1:6.12.34-1+rpt1~bookworm [8,753 kB]
    Get:42 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.12.34+rpt-rpi-2712 arm64 1:6.12.34-1+rpt1~bookworm [32.6 MB]
    Get:43 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-kbuild-6.12.34+rpt arm64 1:6.12.34-1+rpt1~bookworm [1,193 kB]
    Get:44 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.34+rpt-rpi-2712 arm64 1:6.12.34-1+rpt1~bookworm [1,346 kB]
    Get:45 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.12.34+rpt-rpi-v8 arm64 1:6.12.34-1+rpt1~bookworm [32.6 MB]
    Get:46 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.34+rpt-rpi-v8 arm64 1:6.12.34-1+rpt1~bookworm [1,346 kB]
    Get:47 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-2712 arm64 1:6.12.34-1+rpt1~bookworm [1,168 B]
    Get:48 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-v8 arm64 1:6.12.34-1+rpt1~bookworm [1,164 B]
    Get:49 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-2712 arm64 1:6.12.34-1+rpt1~bookworm [1,436 B]
    Get:50 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-v8 arm64 1:6.12.34-1+rpt1~bookworm [1,436 B]
    Get:51 http://archive.raspberrypi.com/debian bookworm/main arm64 pastebinit all 1.6.2-1+rpt2 [53.2 kB]
    Get:52 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-core arm64 20250514-1~bookworm [39.3 kB]
    Get:53 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom all 28.3-1 [1,544 kB]
    Get:54 http://archive.raspberrypi.com/debian bookworm/main arm64 raspinfo all 20250514-1~bookworm [8,106 B]
    Get:55 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-otp all 20250514-1~bookworm [8,422 B]
    Get:56 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-eeprom arm64 20250514-1~bookworm [25.4 kB]
    Get:57 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-dt arm64 20250514-1~bookworm [50.9 kB]
    Get:58 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils all 20250514-1~bookworm [6,008 B]
    Get:59 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-config all 20250707 [37.8 kB]
    Get:60 http://archive.raspberrypi.com/debian bookworm/main arm64 rpicam-apps-lite all 1.8.1-1~bookworm [3,758 B]
    Get:61 http://archive.raspberrypi.com/debian bookworm/main arm64 rpicam-apps-core arm64 1.8.1-1~bookworm [257 kB]
    Fetched 176 MB in 18s (9,532 kB/s)
    Reading changelogs... Done
    Extracting templates from packages: 100%
    Preconfiguring packages ...
    (Reading database ... 69032 files and directories currently installed.)
    Preparing to unpack .../0-libc6-dbg_2.36-9+rpt2+deb12u12_arm64.deb ...
    Unpacking libc6-dbg:arm64 (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
    Preparing to unpack .../1-libc-devtools_2.36-9+rpt2+deb12u12_arm64.deb ...
    Unpacking libc-devtools (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
    Preparing to unpack .../2-libc6-dev_2.36-9+rpt2+deb12u12_arm64.deb ...
    Unpacking libc6-dev:arm64 (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
    Preparing to unpack .../3-libc-dev-bin_2.36-9+rpt2+deb12u12_arm64.deb ...
    Unpacking libc-dev-bin (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
    Preparing to unpack .../4-linux-libc-dev_1%3a6.12.34-1+rpt1~bookworm_all.deb ...
    Unpacking linux-libc-dev (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
    Preparing to unpack .../5-libc6_2.36-9+rpt2+deb12u12_arm64.deb ...
    Unpacking libc6:arm64 (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
    Setting up libc6:arm64 (2.36-9+rpt2+deb12u12) ...
    (Reading database ... 69031 files and directories currently installed.)
    Preparing to unpack .../libc-bin_2.36-9+rpt2+deb12u12_arm64.deb ...
    Unpacking libc-bin (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
    Setting up libc-bin (2.36-9+rpt2+deb12u12) ...
    Preparing to unpack .../raspi-firmware_1%3a1.20250430-4~bookworm_all.deb ...
    Unpacking raspi-firmware (1:1.20250430-4~bookworm) over (1:1.20250430-1) ...
    Preparing to unpack .../sudo_1.9.13p3-1+deb12u2_arm64.deb ...
    Unpacking sudo (1.9.13p3-1+deb12u2) over (1.9.13p3-1+deb12u1) ...
    Preparing to unpack .../libgnutls30_3.7.9-2+deb12u5_arm64.deb ...
    Unpacking libgnutls30:arm64 (3.7.9-2+deb12u5) over (3.7.9-2+deb12u4) ...
    Setting up libgnutls30:arm64 (3.7.9-2+deb12u5) ...
    Preparing to unpack .../00-ca-certificates_20230311+deb12u1_all.deb ...
    Unpacking ca-certificates (20230311+deb12u1) over (20230311) ...
    Preparing to unpack .../01-libc-l10n_2.36-9+rpt2+deb12u12_all.deb ...
    Unpacking libc-l10n (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
    Preparing to unpack .../02-locales_2.36-9+rpt2+deb12u12_all.deb ...
    Unpacking locales (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
    Preparing to unpack .../03-libgdk-pixbuf2.0-common_2.42.10+dfsg-1+deb12u2_all.deb ...
    Unpacking libgdk-pixbuf2.0-common (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
    Preparing to unpack .../04-libgdk-pixbuf-2.0-dev_2.42.10+dfsg-1+deb12u2_arm64.deb ...
    Unpacking libgdk-pixbuf-2.0-dev:arm64 (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
    Preparing to unpack .../05-libgdk-pixbuf-2.0-0_2.42.10+dfsg-1+deb12u2_arm64.deb ...
    Unpacking libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
    Preparing to unpack .../06-libgdk-pixbuf2.0-bin_2.42.10+dfsg-1+deb12u2_arm64.deb ...
    Unpacking libgdk-pixbuf2.0-bin (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
    Preparing to unpack .../07-gir1.2-gdkpixbuf-2.0_2.42.10+dfsg-1+deb12u2_arm64.deb ...
    Unpacking gir1.2-gdkpixbuf-2.0:arm64 (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
    Preparing to unpack .../08-libicu-dev_72.1-3+deb12u1_arm64.deb ...
    Unpacking libicu-dev:arm64 (72.1-3+deb12u1) over (72.1-3) ...
    Preparing to unpack .../09-icu-devtools_72.1-3+deb12u1_arm64.deb ...
    Unpacking icu-devtools (72.1-3+deb12u1) over (72.1-3) ...
    Preparing to unpack .../10-libicu72_72.1-3+deb12u1_arm64.deb ...
    Unpacking libicu72:arm64 (72.1-3+deb12u1) over (72.1-3) ...
    Preparing to unpack .../11-initramfs-tools_0.142+rpt4+deb12u3_all.deb ...
    Unpacking initramfs-tools (0.142+rpt4+deb12u3) over (0.142+rpt3+deb12u3) ...
    Preparing to unpack .../12-initramfs-tools-core_0.142+rpt4+deb12u3_all.deb ...
    Unpacking initramfs-tools-core (0.142+rpt4+deb12u3) over (0.142+rpt3+deb12u3) ...
    Preparing to unpack .../13-libblockdev-utils2_2.28-2+deb12u1_arm64.deb ...
    Unpacking libblockdev-utils2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
    Preparing to unpack .../14-libblockdev-crypto2_2.28-2+deb12u1_arm64.deb ...
    Unpacking libblockdev-crypto2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
    Preparing to unpack .../15-libblockdev-part-err2_2.28-2+deb12u1_arm64.deb ...
    Unpacking libblockdev-part-err2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
    Preparing to unpack .../16-libblockdev-fs2_2.28-2+deb12u1_arm64.deb ...
    Unpacking libblockdev-fs2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
    Preparing to unpack .../17-libblockdev-loop2_2.28-2+deb12u1_arm64.deb ...
    Unpacking libblockdev-loop2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
    Preparing to unpack .../18-libblockdev-part2_2.28-2+deb12u1_arm64.deb ...
    Unpacking libblockdev-part2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
    Preparing to unpack .../19-libblockdev-swap2_2.28-2+deb12u1_arm64.deb ...
    Unpacking libblockdev-swap2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
    Preparing to unpack .../20-libblockdev2_2.28-2+deb12u1_arm64.deb ...
    Unpacking libblockdev2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
    Preparing to unpack .../21-libcamera0.5_0.5.1+rpt20250722-1_arm64.deb ...
    Unpacking libcamera0.5:arm64 (0.5.1+rpt20250722-1) over (0.5.0+rpt20250429-1) ...
    Preparing to unpack .../22-libcamera-ipa_0.5.1+rpt20250722-1_arm64.deb ...
    Unpacking libcamera-ipa:arm64 (0.5.1+rpt20250722-1) over (0.5.0+rpt20250429-1) ...
    Selecting previously unselected package libdtovl0:arm64.
    Preparing to unpack .../23-libdtovl0_20250514-1~bookworm_arm64.deb ...
    Unpacking libdtovl0:arm64 (20250514-1~bookworm) ...
    Selecting previously unselected package libgpiolib0:arm64.
    Preparing to unpack .../24-libgpiolib0_20250514-1~bookworm_arm64.deb ...
    Unpacking libgpiolib0:arm64 (20250514-1~bookworm) ...
    Selecting previously unselected package librpicam-app1:arm64.
    Preparing to unpack .../25-librpicam-app1_1.8.1-1~bookworm_arm64.deb ...
    Unpacking librpicam-app1:arm64 (1.8.1-1~bookworm) ...
    Preparing to unpack .../26-libudisks2-0_2.9.4-4+deb12u1_arm64.deb ...
    Unpacking libudisks2-0:arm64 (2.9.4-4+deb12u1) over (2.9.4-4) ...
    Preparing to unpack .../27-libxml2_2.9.14+dfsg-1.3~deb12u2_arm64.deb ...
    Unpacking libxml2:arm64 (2.9.14+dfsg-1.3~deb12u2) over (2.9.14+dfsg-1.3~deb12u1) ...
    Selecting previously unselected package linux-headers-6.12.34+rpt-common-rpi.
    Preparing to unpack .../28-linux-headers-6.12.34+rpt-common-rpi_1%3a6.12.34-1+rpt1~bookworm_all.deb ...
    Unpacking linux-headers-6.12.34+rpt-common-rpi (1:6.12.34-1+rpt1~bookworm) ...
    Selecting previously unselected package linux-image-6.12.34+rpt-rpi-2712.
    Preparing to unpack .../29-linux-image-6.12.34+rpt-rpi-2712_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
    Unpacking linux-image-6.12.34+rpt-rpi-2712 (1:6.12.34-1+rpt1~bookworm) ...
    Selecting previously unselected package linux-kbuild-6.12.34+rpt.
    Preparing to unpack .../30-linux-kbuild-6.12.34+rpt_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
    Unpacking linux-kbuild-6.12.34+rpt (1:6.12.34-1+rpt1~bookworm) ...
    Selecting previously unselected package linux-headers-6.12.34+rpt-rpi-2712.
    Preparing to unpack .../31-linux-headers-6.12.34+rpt-rpi-2712_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
    Unpacking linux-headers-6.12.34+rpt-rpi-2712 (1:6.12.34-1+rpt1~bookworm) ...
    Selecting previously unselected package linux-image-6.12.34+rpt-rpi-v8.
    Preparing to unpack .../32-linux-image-6.12.34+rpt-rpi-v8_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
    Unpacking linux-image-6.12.34+rpt-rpi-v8 (1:6.12.34-1+rpt1~bookworm) ...
    Selecting previously unselected package linux-headers-6.12.34+rpt-rpi-v8.
    Preparing to unpack .../33-linux-headers-6.12.34+rpt-rpi-v8_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
    Unpacking linux-headers-6.12.34+rpt-rpi-v8 (1:6.12.34-1+rpt1~bookworm) ...
    Preparing to unpack .../34-linux-headers-rpi-2712_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
    Unpacking linux-headers-rpi-2712 (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
    Preparing to unpack .../35-linux-headers-rpi-v8_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
    Unpacking linux-headers-rpi-v8 (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
    Preparing to unpack .../36-linux-image-rpi-2712_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
    Unpacking linux-image-rpi-2712 (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
    Preparing to unpack .../37-linux-image-rpi-v8_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
    Unpacking linux-image-rpi-v8 (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
    Preparing to unpack .../38-nodejs_20.19.4-1nodesource1_arm64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (20.19.4-1nodesource1) over (20.19.2-1nodesource1) ...
    Preparing to unpack .../39-pastebinit_1.6.2-1+rpt2_all.deb ...
    Unpacking pastebinit (1.6.2-1+rpt2) over (1.6.2-1+rpt1) ...
    Preparing to unpack .../40-raspi-utils-core_20250514-1~bookworm_arm64.deb ...
    Unpacking raspi-utils-core (20250514-1~bookworm) over (20250314-1) ...
    Preparing to unpack .../41-rpi-eeprom_28.3-1_all.deb ...
    Unpacking rpi-eeprom (28.3-1) over (28.2-1) ...
    Preparing to unpack .../42-raspinfo_20250514-1~bookworm_all.deb ...
    Unpacking raspinfo (20250514-1~bookworm) over (20250314-1) ...
    Preparing to unpack .../43-raspi-utils-otp_20250514-1~bookworm_all.deb ...
    Unpacking raspi-utils-otp (20250514-1~bookworm) over (20250314-1) ...
    Preparing to unpack .../44-raspi-utils-eeprom_20250514-1~bookworm_arm64.deb ...
    Unpacking raspi-utils-eeprom (20250514-1~bookworm) over (20250314-1) ...
    Preparing to unpack .../45-raspi-utils-dt_20250514-1~bookworm_arm64.deb ...
    Unpacking raspi-utils-dt (20250514-1~bookworm) over (20250314-1) ...
    Preparing to unpack .../46-raspi-utils_20250514-1~bookworm_all.deb ...
    Unpacking raspi-utils (20250514-1~bookworm) over (20250314-1) ...
    Preparing to unpack .../47-raspi-config_20250707_all.deb ...
    Unpacking raspi-config (20250707) over (20250605) ...
    Preparing to unpack .../48-rpicam-apps-lite_1.8.1-1~bookworm_all.deb ...
    Unpacking rpicam-apps-lite (1.8.1-1~bookworm) over (1.7.0-1) ...
    Selecting previously unselected package rpicam-apps-core.
    Preparing to unpack .../49-rpicam-apps-core_1.8.1-1~bookworm_arm64.deb ...
    Unpacking rpicam-apps-core (1.8.1-1~bookworm) ...
    Preparing to unpack .../50-udisks2_2.9.4-4+deb12u1_arm64.deb ...
    Unpacking udisks2 (2.9.4-4+deb12u1) over (2.9.4-4) ...
    Setting up libc-l10n (2.36-9+rpt2+deb12u12) ...
    Setting up raspi-utils-eeprom (20250514-1~bookworm) ...
    Setting up libicu72:arm64 (72.1-3+deb12u1) ...
    Setting up raspi-utils-otp (20250514-1~bookworm) ...
    Setting up libdtovl0:arm64 (20250514-1~bookworm) ...
    Setting up raspi-utils-dt (20250514-1~bookworm) ...
    Setting up libgdk-pixbuf2.0-common (2.42.10+dfsg-1+deb12u2) ...
    Setting up linux-libc-dev (1:6.12.34-1+rpt1~bookworm) ...
    Setting up pastebinit (1.6.2-1+rpt2) ...
    Setting up locales (2.36-9+rpt2+deb12u12) ...
    Generating locales (this might take a while)...
      en_GB.UTF-8... done
    Generation complete.
    Setting up linux-headers-6.12.34+rpt-common-rpi (1:6.12.34-1+rpt1~bookworm) ...
    Setting up libc6-dbg:arm64 (2.36-9+rpt2+deb12u12) ...
    Setting up ca-certificates (20230311+deb12u1) ...
    Updating certificates in /etc/ssl/certs...
    rehash: warning: skipping ca-certificates.crt,it does not contain exactly one certificate or CRL
    2 added, 0 removed; done.
    Setting up libblockdev-utils2:arm64 (2.28-2+deb12u1) ...
    Setting up raspi-firmware (1:1.20250430-4~bookworm) ...
    Installing new version of config file /etc/initramfs/post-update.d/z50-raspi-firmware ...
    Installing new version of config file /etc/kernel/postinst.d/z50-raspi-firmware ...
    '/boot/vmlinuz-6.12.34+rpt-rpi-2712' -> '/boot/firmware/kernel_2712.img'
    '/boot/vmlinuz-6.12.34+rpt-rpi-v8' -> '/boot/firmware/kernel8.img'
    Setting up libgpiolib0:arm64 (20250514-1~bookworm) ...
    Setting up icu-devtools (72.1-3+deb12u1) ...
    Setting up sudo (1.9.13p3-1+deb12u2) ...
    Setting up linux-kbuild-6.12.34+rpt (1:6.12.34-1+rpt1~bookworm) ...
    Setting up libblockdev-part-err2:arm64 (2.28-2+deb12u1) ...
    Setting up libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+deb12u2) ...
    Setting up initramfs-tools-core (0.142+rpt4+deb12u3) ...
    Configuration file '/etc/initramfs-tools/initramfs.conf'
     ==> Modified (by you or by a script) since installation.
     ==> Package distributor has shipped an updated version.
       What would you like to do about it ?  Your options are:
        Y or I  : install the package maintainer's version
        N or O  : keep your currently-installed version
          D     : show the differences between the versions
          Z     : start a shell to examine the situation
     The default action is to keep your current version.
    *** initramfs.conf (Y/I/N/O/D/Z) [default=N] ?
    Progress: [ 68%] [#######################################...................]
    Gruß Yoda
    Stand 05.2025
    Raspberry5,linux,arm64,CPUs:4,Geschwindigkeit:2400 MHz,Modell:Cortex-A76,RAM:15.8 GB,Node.js:v20.19.2
    • YodaY Yoda
      login as: pi
        rpicam-apps-lite
        en_GB.UTF-8... done
      wendy2702W Offline
      wendy2702W Offline
      wendy2702
      @yoda die möglichen Optionen stehen doch da.
      Wenn du dir unsicher bist lass es bei „default“ oder schau dir die Unterschiede an.
      YodaY 2 Antworten Letzte Antwort
      • wendy2702W wendy2702
        YodaY Offline
        YodaY Offline
        Yoda
        @wendy2702 ich bin mir unsicher ;-)
        keine Ahnung welche Auswirkung das hat, habe die Abfrage hier das erste mal....
        oki dann mache ich mal "N" - in 5 Minuten wen keiner was dagegen sagt 😊
        Gruß Yoda
        Stand 05.2025
          YodaY Offline
          YodaY Offline
          Yoda
          @wendy2702 Danke dir, ich hätte vermutlich "Y" gemacht, scheint nun wieder alles an zu laufen, sieht soweit ok aus.
          Gruß Yoda
          Stand 05.2025
