  4. Node-Red
  5. HUE Bewegungsmelder Roborock integr.
    6.4k
34 Beiträge 2 Kommentatoren 4.6k Aufrufe 2 Beobachtet
  • P peterfido
    @aphofis mit myTimeout könnte das so aussehen.
    Mehr mag ich auf dem Mäusekino nicht probieren, zumal Samsung oder Google die Stiftbedienung seit einigen Updates vermurkst haben.
            "id": "a42b83181f07f8d0",
            "type": "tab",
            "label": "Flow 8",
            "disabled": false,
            "info": "",
            "env": []
            "id": "1c8c0acba7c2bff2",
            "type": "inject",
            "z": "a42b83181f07f8d0",
            "name": "Test Bewegung",
            "props": [
                    "p": "payload.motion",
                    "v": "true",
                    "vt": "bool"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "Bewegungsmelder",
            "x": 120,
            "y": 60,
            "wires": [
                    "8bf1e5067a6f0ad2",
                    "b0410acfcad1b37e"
            "id": "d1f2c8393ea7f683",
            "type": "debug",
            "name": "debug 3",
            "active": false,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "true",
            "targetType": "full",
            "statusVal": "",
            "statusType": "auto",
            "x": 1640,
            "y": 180,
            "wires": []
            "id": "8bf1e5067a6f0ad2",
            "type": "delay",
            "name": "",
            "pauseType": "delay",
            "timeout": "1",
            "timeoutUnits": "seconds",
            "rate": "1",
            "nbRateUnits": "1",
            "rateUnits": "second",
            "randomFirst": "1",
            "randomLast": "5",
            "randomUnits": "seconds",
            "drop": false,
            "allowrate": false,
            "outputs": 1,
            "x": 120,
            "y": 120,
            "wires": [
                    "a9f9b30b4f8999d0"
            "id": "a9f9b30b4f8999d0",
            "type": "change",
            "name": "motion:false",
            "rules": [
                    "t": "set",
                    "pt": "msg",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 170,
            "y": 160,
            "wires": [
                    "b0410acfcad1b37e"
            "id": "7a509a8587332f14",
            "type": "switch",
            "name": "Schalter",
            "property": "stopp",
            "propertyType": "flow",
            "rules": [
                    "t": "true"
                    "t": "false"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 820,
            "y": 80,
            "wires": [
                    "4d146d05efbc5d35"
            "id": "6adb99e531920623",
            "type": "change",
            "name": "Motion",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.motion",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 500,
            "y": 60,
            "wires": [
                    "9f0c88dad82d8633"
            "id": "9f83e7917ef2d8e2",
            "type": "comment",
            "name": "<< Bewegungsmelder |||||||||||||| Simulator  Beginn>>",
            "info": "",
            "x": 220,
            "y": 20,
            "wires": []
            "id": "0762e0ad3da83f0d",
            "type": "inject",
            "name": "Test 1000",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "Schalter_1000",
            "payload": "1000",
            "payloadType": "num",
            "x": 120,
            "y": 280,
            "wires": [
                    "d1051390faa881a3"
            "id": "bd795708de32c118",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "on",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 570,
            "y": 200,
            "wires": [
                    "a6a847c390a23b20"
            "id": "d1051390faa881a3",
            "type": "switch",
            "name": "1000?",
            "property": "payload",
            "propertyType": "msg",
            "rules": [
                    "t": "eq",
                    "v": "1000",
                    "vt": "num"
                    "t": "eq",
                    "v": "",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 290,
            "y": 300,
            "wires": [
                    "91fb51e7bf3d65f7"
            "id": "4d146d05efbc5d35",
            "type": "switch",
            "name": "Robi",
            "property": "BWM",
            "rules": [
                    "t": "true"
                    "t": "false"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 950,
            "y": 80,
            "wires": [
                    "9cf97a8724bea369"
            "id": "32b9213c2fe970b0",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "stopp",
                    "pt": "flow",
                    "to": "true",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 820,
            "y": 300,
            "wires": [
            "id": "0439088d7ec73749",
            "type": "change",
            "name": "löscheflow.stopp",
            "rules": [
                    "t": "set",
                    "p": "stopp",
                    "pt": "flow",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1330,
            "y": 340,
            "wires": [
            "id": "550905a564f09176",
            "type": "function",
            "name": "Variablen Ini + Ausgabe",
            "func": "node.status({ text: msg.payload });\n\nreturn msg;",
            "outputs": 1,
            "timeout": 0,
            "noerr": 0,
            "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\n",
            "finalize": "",
            "libs": [],
            "x": 1490,
            "y": 260,
            "wires": [
                    "d1f2c8393ea7f683",
                    "e2721e4056e942e3"
            "id": "d7bd1efc606cfcad",
            "type": "ioBroker in",
            "name": "ioB Robi",
            "attrname": "payload",
            "topic": "*",
            "payloadType": "value",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "fireOnStart": "false",
            "outFormat": "MQTT",
            "x": 120,
            "y": 560,
            "wires": [
                    "b2f36db79c165583"
            "id": "b0410acfcad1b37e",
            "type": "function",
            "name": "Ausgang BWM",
            "func": "\nreturn msg;",
            "outputs": 1,
            "timeout": 0,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 320,
            "y": 60,
            "wires": [
                    "6adb99e531920623"
            "id": "e2721e4056e942e3",
            "type": "ioBroker out",
            "name": "ioBroker Lampe",
            "topic": "0_userdata.0.tests.Lampekueche",
            "ack": "false",
            "autoCreate": "true",
            "stateName": "Lampe_Kueche",
            "role": "light",
            "payloadType": "boolean",
            "readonly": "false",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 1720,
            "y": 300,
            "wires": []
            "id": "7cfd7f7fba2e2d7a",
            "name": "ioB Schalter",
            "topic": "*",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "x": 110,
            "y": 320,
            "wires": [
                    "d1051390faa881a3"
            "id": "91ef09f531fcc27b",
            "type": "inject",
            "name": "Test Robi = 5",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "5",
            "x": 130,
            "y": 440,
            "wires": [
                    "b2f36db79c165583"
            "id": "6db2cc2617ad5707",
            "type": "inject",
            "name": "Test Robi <> 5",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "6",
            "x": 130,
            "y": 500,
            "wires": [
                    "b2f36db79c165583"
            "id": "b2f36db79c165583",
            "type": "switch",
            "name": "5?",
            "rules": [
                    "t": "eq",
                    "v": "5",
                    "vt": "num"
                    "t": "neq",
                    "v": "5",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 310,
            "y": 500,
            "wires": [
                    "407e2e376c0ee370"
                    "5061312f43733426"
            "id": "407e2e376c0ee370",
            "type": "change",
            "name": "setze Flow.BWM",
            "rules": [
                    "t": "set",
                    "p": "BWM",
                    "pt": "flow",
                    "to": "true",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 680,
            "y": 480,
            "wires": [
                    "0650a4ab7aec40a1"
            "id": "5061312f43733426",
            "type": "change",
            "name": "lösche Flow.BWM",
            "rules": [
                    "t": "set",
                    "p": "BWM",
                    "pt": "flow",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 690,
            "y": 520,
            "wires": [
                    "0650a4ab7aec40a1"
            "id": "879b9060efcd163b",
            "type": "comment",
            "name": "evtl. gesperrt durch??",
            "info": "",
            "x": 880,
            "y": 40,
            "wires": []
            "id": "9f0c88dad82d8633",
            "type": "switch",
            "name": "nur true",
            "rules": [
                    "t": "true"
                    "t": "false"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 640,
            "y": 80,
            "wires": [
                    "7a509a8587332f14"
            "id": "0650a4ab7aec40a1",
            "type": "debug",
            "name": "debug 4",
            "active": false,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "true",
            "statusVal": "",
            "x": 900,
            "y": 500,
            "wires": []
            "id": "f144b6f8b998c7f5",
            "type": "comment",
            "name": "<< Bewegungsmelder |||||||||||||| Simulator Ende >>",
            "info": "",
            "x": 220,
            "y": 220,
            "wires": []
            "id": "a6a847c390a23b20",
            "type": "mytimeout",
            "name": "45 sec",
            "outtopic": "",
            "outsafe": "on",
            "outwarning": "Warning",
            "outunsafe": "off",
            "warning": "5",
            "timer": "45",
            "debug": false,
            "ndebug": false,
            "ignoreCase": false,
            "repeat": false,
            "again": false,
            "x": 730,
            "y": 180,
            "wires": [
                    "25e12cdd5eeefe18"
            "id": "442af76f7b9f1d0a",
            "name": "3 sec",
            "outtopic": "",
            "outsafe": "on",
            "outunsafe": "off",
            "warning": "1",
            "timer": "3",
            "debug": false,
            "ndebug": false,
            "repeat": false,
            "again": false,
            "x": 1290,
            "y": 120,
            "wires": [
                    "01e10f79b058e94d"
            "id": "25e12cdd5eeefe18",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "change",
                    "p": "payload",
                    "pt": "msg",
                    "from": "on",
                    "fromt": "str",
                    "to": "true",
                    "tot": "bool"
                    "t": "change",
                    "p": "payload",
                    "pt": "msg",
                    "from": "off",
                    "fromt": "str",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 890,
            "y": 180,
            "wires": [
                    "d5e9baf2e985c341"
            "id": "d5e9baf2e985c341",
            "type": "switch",
            "name": "",
            "rules": [
                    "t": "true"
                    "t": "false"
                    "t": "eq",
                    "v": "",
                    "vt": "str"
            "checkall": "true",
            "repair": false,
            "outputs": 3,
            "x": 1150,
            "y": 260,
            "wires": [
                    "550905a564f09176"
                    "550905a564f09176",
                    "0439088d7ec73749"
            "id": "d7c7e0bfb963466c",
            "type": "switch",
            "name": "",
            "rules": [
                    "t": "true"
                    "t": "false"
                    "t": "eq",
                    "v": "",
                    "vt": "str"
            "checkall": "true",
            "repair": false,
            "outputs": 3,
            "x": 1550,
            "y": 40,
            "wires": [
                    "550905a564f09176"
                    "550905a564f09176"
            "id": "01e10f79b058e94d",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "change",
                    "p": "payload",
                    "pt": "msg",
                    "from": "on",
                    "fromt": "str",
                    "to": "true",
                    "tot": "bool"
                    "t": "change",
                    "p": "payload",
                    "pt": "msg",
                    "from": "off",
                    "fromt": "str",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1370,
            "y": 40,
            "wires": [
                    "d7c7e0bfb963466c"
            "id": "9cf97a8724bea369",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "on",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1130,
            "y": 80,
            "wires": [
                    "442af76f7b9f1d0a"
            "id": "91fb51e7bf3d65f7",
            "type": "ioBroker get",
            "name": "Lampe ist?",
            "errOnInvalidState": "nothing",
            "x": 430,
            "y": 300,
            "wires": [
                    "e1bc32d82926ab1a"
            "id": "e1bc32d82926ab1a",
            "type": "switch",
            "name": "",
            "rules": [
                    "t": "false"
                    "t": "true"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 570,
            "y": 360,
            "wires": [
                    "32b9213c2fe970b0",
                    "bd795708de32c118"
                    "407e2e376c0ee370",
                    "0439088d7ec73749",
                    "f8efa184517f5926",
                    "5ff36fd59f9b86a7"
            "id": "f8efa184517f5926",
            "type": "change",
            "name": "Alles auf Anfang",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 880,
            "y": 420,
            "wires": [
                    "550905a564f09176"
            "id": "5ff36fd59f9b86a7",
            "type": "change",
            "name": "stop",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "stop",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 650,
            "y": 260,
            "wires": [
                    "a6a847c390a23b20",
                    "442af76f7b9f1d0a"
    Daher bitte selbst probieren und tüfteln, falls was nicht so läuft, wie gewollt.
    AphofisA Offline
    AphofisA Offline
    Aphofis
    @peterfido
    Ich werde tüfteln
    • P peterfido
              "type": "tab",
              "label": "Flow 8",
              "disabled": false,
              "info": "",
              "env": []
              "type": "inject",
              "props": [
                      "v": "true",
                      "vt": "bool"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "x": 120,
              "y": 60,
              "wires": [
                      "8bf1e5067a6f0ad2",
                      "b0410acfcad1b37e"
              "type": "debug",
              "name": "debug 3",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "statusVal": "",
              "x": 1640,
              "y": 180,
              "wires": []
              "type": "delay",
              "name": "",
              "timeout": "1",
              "rate": "1",
              "nbRateUnits": "1",
              "randomFirst": "1",
              "randomLast": "5",
              "drop": false,
              "allowrate": false,
              "outputs": 1,
              "x": 120,
              "y": 120,
              "wires": [
                      "a9f9b30b4f8999d0"
              "type": "change",
              "rules": [
                      "t": "set",
                      "pt": "msg",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 170,
              "y": 160,
              "wires": [
                      "b0410acfcad1b37e"
              "type": "switch",
              "name": "Schalter",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 820,
              "y": 80,
              "wires": [
                      "4d146d05efbc5d35"
              "type": "change",
              "name": "Motion",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 500,
              "y": 60,
              "wires": [
                      "9f0c88dad82d8633"
              "type": "comment",
              "info": "",
              "x": 220,
              "y": 20,
              "wires": []
              "type": "inject",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "payload": "1000",
              "x": 120,
              "y": 280,
              "wires": [
                      "d1051390faa881a3"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "on",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 570,
              "y": 200,
              "wires": [
                      "a6a847c390a23b20"
              "type": "switch",
              "name": "1000?",
              "rules": [
                      "t": "eq",
                      "v": "1000",
                      "vt": "num"
                      "t": "eq",
                      "v": "",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 290,
              "y": 300,
              "wires": [
                      "91fb51e7bf3d65f7"
              "type": "switch",
              "name": "Robi",
              "property": "BWM",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 950,
              "y": 80,
              "wires": [
                      "9cf97a8724bea369"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "stopp",
                      "pt": "flow",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 820,
              "y": 300,
              "wires": [
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "stopp",
                      "pt": "flow",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1330,
              "y": 340,
              "wires": [
              "type": "function",
              "outputs": 1,
              "timeout": 0,
              "noerr": 0,
              "finalize": "",
              "libs": [],
              "x": 1490,
              "y": 260,
              "wires": [
                      "d1f2c8393ea7f683",
                      "e2721e4056e942e3"
              "name": "ioB Robi",
              "topic": "*",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 120,
              "y": 560,
              "wires": [
                      "b2f36db79c165583"
              "type": "function",
              "outputs": 1,
              "timeout": 0,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 320,
              "y": 60,
              "wires": [
                      "6adb99e531920623"
              "ack": "false",
              "role": "light",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1720,
              "y": 300,
              "wires": []
              "topic": "*",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 110,
              "y": 320,
              "wires": [
                      "d1051390faa881a3"
              "type": "inject",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "5",
              "x": 130,
              "y": 440,
              "wires": [
                      "b2f36db79c165583"
              "type": "inject",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "6",
              "x": 130,
              "y": 500,
              "wires": [
                      "b2f36db79c165583"
              "type": "switch",
              "name": "5?",
              "rules": [
                      "t": "eq",
                      "v": "5",
                      "vt": "num"
                      "t": "neq",
                      "v": "5",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 310,
              "y": 500,
              "wires": [
                      "407e2e376c0ee370"
                      "5061312f43733426"
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "BWM",
                      "pt": "flow",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 680,
              "y": 480,
              "wires": [
                      "0650a4ab7aec40a1"
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "BWM",
                      "pt": "flow",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 690,
              "y": 520,
              "wires": [
                      "0650a4ab7aec40a1"
              "type": "comment",
              "info": "",
              "x": 880,
              "y": 40,
              "wires": []
              "type": "switch",
              "name": "nur true",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 640,
              "y": 80,
              "wires": [
                      "7a509a8587332f14"
              "type": "debug",
              "name": "debug 4",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "statusVal": "",
              "x": 900,
              "y": 500,
              "wires": []
              "type": "comment",
              "info": "",
              "x": 220,
              "y": 220,
              "wires": []
              "name": "45 sec",
              "outtopic": "",
              "outsafe": "on",
              "outunsafe": "off",
              "warning": "5",
              "timer": "45",
              "debug": false,
              "ndebug": false,
              "repeat": false,
              "again": false,
              "x": 730,
              "y": 180,
              "wires": [
                      "25e12cdd5eeefe18"
              "name": "3 sec",
              "outtopic": "",
              "outsafe": "on",
              "outunsafe": "off",
              "warning": "1",
              "timer": "3",
              "debug": false,
              "ndebug": false,
              "repeat": false,
              "again": false,
              "x": 1290,
              "y": 120,
              "wires": [
                      "01e10f79b058e94d"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "on",
                      "fromt": "str",
                      "to": "true",
                      "tot": "bool"
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "off",
                      "fromt": "str",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 890,
              "y": 180,
              "wires": [
                      "d5e9baf2e985c341"
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "true"
                      "t": "false"
                      "t": "eq",
                      "v": "",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 3,
              "x": 1150,
              "y": 260,
              "wires": [
                      "550905a564f09176"
                      "550905a564f09176",
                      "0439088d7ec73749"
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "true"
                      "t": "false"
                      "t": "eq",
                      "v": "",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 3,
              "x": 1550,
              "y": 40,
              "wires": [
                      "550905a564f09176"
                      "550905a564f09176"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "on",
                      "fromt": "str",
                      "to": "true",
                      "tot": "bool"
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "off",
                      "fromt": "str",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1370,
              "y": 40,
              "wires": [
                      "d7c7e0bfb963466c"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "on",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1130,
              "y": 80,
              "wires": [
                      "442af76f7b9f1d0a"
              "x": 430,
              "y": 300,
              "wires": [
                      "e1bc32d82926ab1a"
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "false"
                      "t": "true"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 570,
              "y": 360,
              "wires": [
                      "32b9213c2fe970b0",
                      "bd795708de32c118"
                      "407e2e376c0ee370",
                      "0439088d7ec73749",
                      "f8efa184517f5926",
                      "5ff36fd59f9b86a7"
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 880,
              "y": 420,
              "wires": [
                      "550905a564f09176"
              "type": "change",
              "name": "stop",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "stop",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 650,
              "y": 260,
              "wires": [
                      "a6a847c390a23b20",
                      "442af76f7b9f1d0a"
      AphofisA Offline
      AphofisA Offline
      Aphofis
      @peterfido
      Scheint alles zu funktionieren. Nur Wiederbewegung hatte ich noch nicht getestet ob das Licht dann an bleibt oder erstmal aus geht und dann wieder eingeschaltet wird.
      Aber an sich tolle Steuerung. Wie und wo kann man sowas bloß lernen und dann auch noch auf einem Mäusekino. Ich sage mal Vielen vielen Dank.
      AphofisA 1 Antwort Letzte Antwort
      • AphofisA Aphofis
        @peterfido
        AphofisA Offline
        AphofisA Offline
        Aphofis
        schrieb am zuletzt editiert von Aphofis
        So siehts jetzt aus und scheint zu laufen.
        Wie gesagt bis auf die wiederbewegung klappt nicht.
        Ganz ehrlich gesagt, ich wüsste nicht mal wo ich da ansetzen soll um die schaltung träge zu machen damit nicht beim BWM auf jedes false zwischen den true reagiert wird sondern wenn keine Ahnung wenn wirklich 10 sek zB. false ist das dann erst ein false gesendet wird
        Hab jetzt die Steuerung in Küche und Bad integriert und bin so auch erstmal zufrieden. nur die Wiederbewegung ist halt etwas doof das dass nicht klappt. Ist aber in Öffentlichen Toiletten und Restaurants auch so das bei einer Sitzung das Licht einmal aus geht und erst wenn man sich bewegt das Licht wieder an geht. Ganz schlecht ist es nur wenn nicht jedes Klo einen BWM hat und man mit Handy Taschenlampe die Sitzung beenden muss. Da ist es so zumindest schon mal ein Anfang.
                "id": "b802892eed83e90f",
                "type": "tab",
                "label": "Flow 8",
                "disabled": false,
                "info": "",
                "env": []
                "id": "f00e20abd94ff43d",
                "type": "junction",
                "z": "b802892eed83e90f",
                "x": 960,
                "y": 320,
                "wires": [
                        "141a052859674836",
                        "574a9f7ddc4f663b"
                "id": "423ea0f1dc0e4d31",
                "type": "junction",
                "x": 1440,
                "y": 300,
                "wires": [
                        "ff32f89078260f0e",
                        "67e2e01a1266d1c3",
                        "e98816534075b0f5",
                        "21f36ea2695afe19",
                        "a695276a00fe8f61"
                "id": "a2104cdffd7ca75f",
                "type": "inject",
                "props": [
                        "v": "true",
                        "vt": "bool"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "x": 120,
                "y": 60,
                "wires": [
                        "a919a4c30d900c39",
                        "0150c15cf7b51170"
                "id": "ed06e85de97289c8",
                "type": "debug",
                "name": "debug 3",
                "active": false,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "complete": "true",
                "statusVal": "",
                "x": 1620,
                "y": 140,
                "wires": []
                "id": "a919a4c30d900c39",
                "type": "delay",
                "name": "",
                "timeout": "1",
                "rate": "1",
                "nbRateUnits": "1",
                "randomFirst": "1",
                "randomLast": "5",
                "drop": false,
                "allowrate": false,
                "outputs": 1,
                "x": 380,
                "y": 140,
                "wires": [
                        "bee64eb116d76ed1"
                "id": "bee64eb116d76ed1",
                "type": "change",
                "rules": [
                        "t": "set",
                        "pt": "msg",
                        "to": "false",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 390,
                "y": 100,
                "wires": [
                        "0150c15cf7b51170"
                "id": "ab41883686b27cc0",
                "type": "switch",
                "name": "Schalter",
                "rules": [
                        "t": "true"
                        "t": "false"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 860,
                "y": 80,
                "wires": [
                        "01fea99b98c641a3"
                "id": "0395e4bbb7c67e21",
                "type": "change",
                "name": "Motion",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 590,
                "y": 80,
                "wires": [
                        "d24a5429e472b18a"
                "id": "59792b228df9eb30",
                "type": "comment",
                "info": "",
                "x": 220,
                "y": 20,
                "wires": []
                "id": "93f0d4c85ab42e59",
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "on",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 590,
                "y": 160,
                "wires": [
                        "ed2607cafe826532"
                "id": "e22b60db6265e908",
                "type": "switch",
                "name": "1000?",
                "rules": [
                        "t": "eq",
                        "v": "1000",
                        "vt": "num"
                        "t": "eq",
                        "v": "",
                        "vt": "num"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 210,
                "y": 320,
                "wires": [
                        "6ae2e0e61f81faeb"
                "id": "01fea99b98c641a3",
                "type": "switch",
                "name": "Robi",
                "property": "BWM",
                "rules": [
                        "t": "true"
                        "t": "false"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 990,
                "y": 80,
                "wires": [
                        "ba0aea0ff71ebc3d"
                "id": "7eea52e80cbe51f0",
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "stopp",
                        "pt": "flow",
                        "to": "true",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 680,
                "y": 220,
                "wires": [
                "id": "574a9f7ddc4f663b",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "stopp",
                        "pt": "flow",
                        "to": "false",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 1280,
                "y": 300,
                "wires": [
                "id": "331a07cfba2d7df1",
                "type": "function",
                "outputs": 1,
                "timeout": 0,
                "noerr": 0,
                "finalize": "",
                "libs": [],
                "x": 1410,
                "y": 180,
                "wires": [
                        "ed06e85de97289c8",
                        "423ea0f1dc0e4d31"
                "id": "b9692c9131fb2ef5",
                "name": "Robi",
                "topic": "mihome-vacuum.0.info.state",
                "onlyack": "",
                "func": "all",
                "gap": "",
                "x": 50,
                "y": 380,
                "wires": [
                        "6b214a0a59b5e04a"
                "id": "0150c15cf7b51170",
                "type": "function",
                "outputs": 1,
                "timeout": 0,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 440,
                "y": 60,
                "wires": [
                        "0395e4bbb7c67e21"
                "id": "b6b4c157c31e3701",
                "name": "KüSchalter",
                "topic": "hue.0.Hue_GordonX.Küche_Schalter.buttonevent",
                "onlyack": "",
                "func": "all",
                "gap": "",
                "x": 60,
                "y": 320,
                "wires": [
                        "e22b60db6265e908"
                "id": "6b214a0a59b5e04a",
                "type": "switch",
                "name": "8?",
                "rules": [
                        "t": "eq",
                        "v": "8",
                        "vt": "num"
                        "t": "neq",
                        "v": "8",
                        "vt": "num"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 650,
                "y": 380,
                "wires": [
                        "7b9c0fa6e795af2d"
                        "ccadbb1ee1de29e6"
                "id": "7b9c0fa6e795af2d",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "BWM",
                        "pt": "flow",
                        "to": "true",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 810,
                "y": 360,
                "wires": [
                        "b117dac109d51b34"
                "id": "ccadbb1ee1de29e6",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "BWM",
                        "pt": "flow",
                        "to": "false",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 810,
                "y": 400,
                "wires": [
                        "b117dac109d51b34"
                "id": "558db419c5c37cca",
                "type": "comment",
                "info": "",
                "x": 860,
                "y": 40,
                "wires": []
                "id": "d24a5429e472b18a",
                "type": "switch",
                "name": "nur true",
                "rules": [
                        "t": "true"
                        "t": "false"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 720,
                "y": 80,
                "wires": [
                        "ab41883686b27cc0"
                "id": "b117dac109d51b34",
                "type": "debug",
                "name": "debug 4",
                "active": false,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "complete": "true",
                "statusVal": "",
                "x": 1100,
                "y": 380,
                "wires": []
                "id": "d64f728f4f574f51",
                "type": "comment",
                "info": "",
                "x": 190,
                "y": 280,
                "wires": []
                "id": "91febc7692f9b822",
                "type": "change",
                "name": "",
                "rules": [
                        "t": "change",
                        "p": "payload",
                        "pt": "msg",
                        "from": "on",
                        "fromt": "str",
                        "to": "true",
                        "tot": "bool"
                        "t": "change",
                        "p": "payload",
                        "pt": "msg",
                        "from": "off",
                        "fromt": "str",
                        "to": "false",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 930,
                "y": 140,
                "wires": [
                        "d303b6e1817d8b77"
                "id": "d303b6e1817d8b77",
                "type": "switch",
                "name": "",
                "rules": [
                        "t": "true"
                        "t": "false"
                        "t": "eq",
                        "v": "",
                        "vt": "str"
                "checkall": "true",
                "repair": false,
                "outputs": 3,
                "x": 1090,
                "y": 120,
                "wires": [
                        "331a07cfba2d7df1"
                        "331a07cfba2d7df1",
                        "574a9f7ddc4f663b"
                "id": "b4e55cb04c30244e",
                "type": "switch",
                "name": "",
                "rules": [
                        "t": "true"
                        "t": "false"
                        "t": "eq",
                        "v": "",
                        "vt": "str"
                "checkall": "true",
                "repair": false,
                "outputs": 3,
                "x": 1630,
                "y": 60,
                "wires": [
                        "331a07cfba2d7df1"
                        "331a07cfba2d7df1"
                "id": "90c9685b4a5344dc",
                "type": "change",
                "name": "",
                "rules": [
                        "t": "change",
                        "p": "payload",
                        "pt": "msg",
                        "from": "on",
                        "fromt": "str",
                        "to": "true",
                        "tot": "bool"
                        "t": "change",
                        "p": "payload",
                        "pt": "msg",
                        "from": "off",
                        "fromt": "str",
                        "to": "false",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 1470,
                "y": 60,
                "wires": [
                        "b4e55cb04c30244e"
                "id": "ba0aea0ff71ebc3d",
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "on",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 1150,
                "y": 60,
                "wires": [
                        "fa5f2b5bcd258a98"
                "id": "6ae2e0e61f81faeb",
                "name": "Virtuelle Lampe",
                "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_1",
                "x": 460,
                "y": 320,
                "wires": [
                        "cf3016a536d38a8d"
                "id": "cf3016a536d38a8d",
                "type": "switch",
                "name": "",
                "rules": [
                        "t": "false"
                        "t": "true"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 650,
                "y": 320,
                "wires": [
                        "7eea52e80cbe51f0",
                        "93f0d4c85ab42e59"
                        "7b9c0fa6e795af2d",
                        "87ec46662c49de4e",
                        "f00e20abd94ff43d"
                "id": "141a052859674836",
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "false",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 1280,
                "y": 340,
                "wires": [
                        "331a07cfba2d7df1"
                "id": "87ec46662c49de4e",
                "type": "change",
                "name": "stop",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "stop",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 930,
                "y": 280,
                "wires": [
                        "ed2607cafe826532",
                        "fa5f2b5bcd258a98"
                "id": "ed2607cafe826532",
                "name": "45min.",
                "outtopic": "",
                "outsafe": "on",
                "outunsafe": "off",
                "warning": "10",
                "timer": "2700",
                "debug": false,
                "ndebug": false,
                "repeat": false,
                "again": false,
                "x": 770,
                "y": 160,
                "wires": [
                        "91febc7692f9b822"
                "id": "fa5f2b5bcd258a98",
                "name": "3Min.",
                "outtopic": "",
                "outsafe": "on",
                "outunsafe": "off",
                "warning": "10",
                "timer": "180",
                "debug": false,
                "ndebug": false,
                "repeat": false,
                "again": false,
                "x": 1310,
                "y": 100,
                "wires": [
                        "90c9685b4a5344dc"
                "id": "802770af38c8534e",
                "type": "hue-bridge-node",
                "name": "Hue",
                "bridge": "cbd54dbabf6f65be",
                "autoupdates": true,
                "skipglobalevents": false,
                "initevents": false,
                "x": 90,
                "y": 220,
                "wires": [
                        "2e0c2a67486c0ac7"
                "id": "2e0c2a67486c0ac7",
                "type": "hue-motion",
                "name": "Küche Motion Sensor",
                "sensorid": "7529c8d8-9f5c-451d-ba56-70cacda84564",
                "skipevents": false,
                "initevents": true,
                "x": 140,
                "y": 140,
                "wires": [
                        "a919a4c30d900c39",
                        "0150c15cf7b51170"
                "id": "21f36ea2695afe19",
                "name": "U-rechts",
                "topic": "tuya.0.bfb09eea5dad3699abyrbu.20",
                "ack": "false",
                "autoCreate": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 1600,
                "y": 360,
                "wires": []
                "id": "084e7114b7ed1c61",
                "name": "Küche Decke",
                "topic": "tuya.0.bfe4af976feb74d845vugp.1",
                "ack": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 1730,
                "y": 240,
                "wires": []
                "id": "ff32f89078260f0e",
                "name": "Virtuel Switch 1",
                "ack": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 1620,
                "y": 300,
                "wires": []
                "id": "442c2ef743d9599f",
                "type": "debug",
                "name": "Küche",
                "active": true,
                "tosidebar": true,
                "console": true,
                "tostatus": false,
                "complete": "payload",
                "targetType": "msg",
                "statusVal": "",
                "x": 1620,
                "y": 520,
                "wires": []
                "id": "67e2e01a1266d1c3",
                "type": "delay",
                "name": "100ms",
                "timeout": "100",
                "timeoutUnits": "milliseconds",
                "rate": "1",
                "nbRateUnits": "1",
                "randomFirst": "1",
                "randomLast": "5",
                "drop": false,
                "allowrate": false,
                "outputs": 1,
                "x": 1590,
                "y": 240,
                "wires": [
                        "084e7114b7ed1c61"
                "id": "e98816534075b0f5",
                "type": "change",
                "name": "Küche",
                "rules": [
                        "t": "change",
                        "p": "payload",
                        "pt": "msg",
                        "from": "1000",
                        "fromt": "str",
                        "to": "Küche",
                        "tot": "str"
                        "t": "change",
                        "p": "payload",
                        "pt": "msg",
                        "from": "true",
                        "fromt": "bool",
                        "to": "Küche eingeschaltet",
                        "tot": "str"
                        "t": "change",
                        "p": "payload",
                        "pt": "msg",
                        "from": "false",
                        "fromt": "bool",
                        "to": "Küche ausgeschaltet",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 1490,
                "y": 520,
                "wires": [
                        "442c2ef743d9599f"
                "id": "a695276a00fe8f61",
                "name": "U-links",
                "topic": "hue.0.Hue_GordonX.Küche_Unterschr_Links.on",
                "ack": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 1590,
                "y": 440,
                "wires": []
                "id": "cbd54dbabf6f65be",
                "type": "hue-bridge",
                "name": "Hue GordonX",
                "bridge": "192.168.0.8",
                "key": "SlfyXwpcaEvRN0d1DU2JrrOlwrm9Debhhm9A4E-d",
                "worker": "10",
                "disableupdates": false
          peterfido
          @aphofis Wenn Du die Laufzeit des Bewegungsmelders mit berücksichtigen möchtest, dann muss diese zyklisch abgefragt werden, und kommt dann zu der Laufzeit von drei Minuten dazu.
                 "type": "tab",
                 "label": "Flow 8",
                 "disabled": false,
                 "info": "",
                 "env": []
                 "type": "junction",
                 "x": 1120,
                 "y": 660,
                 "wires": [
                         "141a052859674836",
                         "574a9f7ddc4f663b",
                         "b6322a40cf4557b3"
                 "type": "junction",
                 "x": 1960,
                 "y": 460,
                 "wires": [
                         "ff32f89078260f0e",
                         "67e2e01a1266d1c3",
                         "e98816534075b0f5",
                         "21f36ea2695afe19",
                         "a695276a00fe8f61"
                 "id": "ae8ceff406113f11",
                 "type": "junction",
                 "x": 1140,
                 "y": 260,
                 "wires": [
                         "ba0aea0ff71ebc3d"
                 "id": "256e4df028333ee3",
                 "type": "junction",
                 "x": 580,
                 "y": 60,
                 "wires": [
                         "6ae2e0e61f81faeb"
                 "id": "9c7c62ee37b6b12c",
                 "type": "junction",
                 "x": 540,
                 "y": 120,
                 "wires": [
                         "d24a5429e472b18a"
                 "id": "d96f128a59bdfbb4",
                 "type": "junction",
                 "x": 900,
                 "y": 440,
                 "wires": [
                         "84bd4ea1d044fea4",
                         "ed2607cafe826532"
                 "id": "84bd4ea1d044fea4",
                 "type": "junction",
                 "x": 980,
                 "y": 360,
                 "wires": [
                         "be66da991b562e24"
                 "id": "be66da991b562e24",
                 "type": "junction",
                 "x": 1280,
                 "y": 360,
                 "wires": [
                         "fa5f2b5bcd258a98"
                 "type": "inject",
                 "props": [
                         "v": "true",
                         "vt": "bool"
                         "p": "topic",
                         "vt": "str"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "x": 140,
                 "y": 380,
                 "wires": [
                         "a919a4c30d900c39",
                         "0150c15cf7b51170"
                 "type": "debug",
                 "name": "debug 3",
                 "active": false,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "complete": "true",
                 "statusVal": "",
                 "x": 2000,
                 "y": 360,
                 "wires": []
                 "type": "delay",
                 "name": "",
                 "timeout": "10",
                 "rate": "1",
                 "nbRateUnits": "1",
                 "randomFirst": "1",
                 "randomLast": "5",
                 "drop": false,
                 "allowrate": false,
                 "outputs": 1,
                 "x": 150,
                 "y": 460,
                 "wires": [
                         "bee64eb116d76ed1"
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "pt": "msg",
                         "to": "false",
                         "tot": "bool"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 350,
                 "y": 460,
                 "wires": [
                         "0150c15cf7b51170"
                 "type": "switch",
                 "name": "Schalter",
                 "rules": [
                         "t": "true"
                         "t": "false"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 2,
                 "x": 920,
                 "y": 260,
                 "wires": [
                         "01fea99b98c641a3"
                 "type": "change",
                 "name": "Motion",
                 "rules": [
                         "t": "set",
                         "p": "bewegung",
                         "pt": "flow",
                         "tot": "msg"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 670,
                 "y": 320,
                 "wires": [
                 "type": "comment",
                 "name": "<< Bewegungsmelder |||||||||||||| Simulator da kein Hue  Beginn>>",
                 "info": "",
                 "x": 270,
                 "y": 300,
                 "wires": []
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "on",
                         "tot": "str"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 710,
                 "y": 400,
                 "wires": [
                         "ed2607cafe826532"
                 "type": "switch",
                 "name": "1000?",
                 "rules": [
                         "t": "eq",
                         "v": "1000",
                         "vt": "num"
                         "t": "eq",
                         "v": "",
                         "vt": "num"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 2,
                 "x": 250,
                 "y": 660,
                 "wires": [
                         "35f7a8f381fdb099"
                 "type": "switch",
                 "name": "Robi",
                 "property": "BWM",
                 "rules": [
                         "t": "true"
                         "t": "false"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 2,
                 "x": 1050,
                 "y": 260,
                 "wires": [
                         "ae8ceff406113f11"
                 "type": "change",
                 "name": "setze stopp",
                 "rules": [
                         "t": "set",
                         "p": "stopp",
                         "pt": "flow",
                         "to": "true",
                         "tot": "bool"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 890,
                 "y": 600,
                 "wires": [
                 "type": "change",
                 "name": "lösche stopp",
                 "rules": [
                         "t": "set",
                         "p": "stopp",
                         "pt": "flow",
                         "to": "false",
                         "tot": "bool"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 1370,
                 "y": 600,
                 "wires": [
                 "type": "function",
                 "func": "node.status({ text: msg.payload });\n\n// Für Tests Beginn\nflow.set(\"lampe_ist\", msg.payload); // Zeile für Normalbetrieb auskommentieren\n// Für Tests Ende\n\nreturn msg;",
                 "outputs": 1,
                 "timeout": 0,
                 "noerr": 0,
                 "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\nflow.set(\"bewegung\", false);\nflow.set(\"lampe_ist\", false);\n",
                 "finalize": "",
                 "libs": [],
                 "x": 1770,
                 "y": 380,
                 "wires": [
                         "ed06e85de97289c8",
                         "423ea0f1dc0e4d31"
                 "name": "Robi",
                 "onlyack": "",
                 "func": "all",
                 "gap": "",
                 "x": 90,
                 "y": 780,
                 "wires": [
                         "6b214a0a59b5e04a"
                 "type": "function",
                 "outputs": 1,
                 "timeout": 0,
                 "noerr": 0,
                 "initialize": "",
                 "finalize": "",
                 "libs": [],
                 "x": 360,
                 "y": 360,
                 "wires": [
                         "0395e4bbb7c67e21"
                 "onlyack": "",
                 "func": "all",
                 "gap": "",
                 "x": 100,
                 "y": 680,
                 "wires": [
                         "e22b60db6265e908"
                 "type": "switch",
                 "name": "8?",
                 "rules": [
                         "t": "eq",
                         "v": "8",
                         "vt": "num"
                         "t": "neq",
                         "v": "8",
                         "vt": "num"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 2,
                 "x": 630,
                 "y": 780,
                 "wires": [
                         "7b9c0fa6e795af2d"
                         "ccadbb1ee1de29e6"
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "BWM",
                         "pt": "flow",
                         "to": "true",
                         "tot": "bool"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 850,
                 "y": 760,
                 "wires": [
                         "b117dac109d51b34"
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "BWM",
                         "pt": "flow",
                         "to": "false",
                         "tot": "bool"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 850,
                 "y": 800,
                 "wires": [
                         "b117dac109d51b34"
                 "type": "comment",
                 "name": "evtl. gesperrt durch?? Beginn",
                 "info": "",
                 "x": 980,
                 "y": 220,
                 "wires": []
                 "type": "switch",
                 "name": "nur true",
                 "rules": [
                         "t": "true"
                         "t": "false"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 2,
                 "x": 740,
                 "y": 240,
                 "wires": [
                         "ab41883686b27cc0"
                 "type": "debug",
                 "name": "debug 4",
                 "active": false,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "complete": "true",
                 "statusVal": "",
                 "x": 1040,
                 "y": 760,
                 "wires": []
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "change",
                         "p": "payload",
                         "pt": "msg",
                         "from": "on",
                         "fromt": "str",
                         "to": "true",
                         "tot": "bool"
                         "t": "change",
                         "p": "payload",
                         "pt": "msg",
                         "from": "off",
                         "fromt": "str",
                         "to": "false",
                         "tot": "bool"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 1290,
                 "y": 400,
                 "wires": [
                         "d303b6e1817d8b77"
                 "type": "switch",
                 "name": "",
                 "rules": [
                         "t": "true"
                         "t": "false"
                         "t": "eq",
                         "v": "",
                         "vt": "str"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 3,
                 "x": 1470,
                 "y": 400,
                 "wires": [
                         "331a07cfba2d7df1"
                         "331a07cfba2d7df1",
                         "574a9f7ddc4f663b"
                 "type": "switch",
                 "name": "",
                 "rules": [
                         "t": "true"
                         "t": "false"
                         "t": "eq",
                         "v": "",
                         "vt": "str"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 3,
                 "x": 1770,
                 "y": 260,
                 "wires": [
                         "331a07cfba2d7df1"
                         "331a07cfba2d7df1"
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "change",
                         "p": "payload",
                         "pt": "msg",
                         "from": "on",
                         "fromt": "str",
                         "to": "true",
                         "tot": "bool"
                         "t": "change",
                         "p": "payload",
                         "pt": "msg",
                         "from": "off",
                         "fromt": "str",
                         "to": "false",
                         "tot": "bool"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 1610,
                 "y": 260,
                 "wires": [
                         "b4e55cb04c30244e"
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "on",
                         "tot": "str"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 1250,
                 "y": 260,
                 "wires": [
                         "fa5f2b5bcd258a98"
                 "x": 760,
                 "y": 100,
                 "wires": [
                         "dc4b3ed2e3d1a857"
                 "type": "switch",
                 "name": "true false",
                 "rules": [
                         "t": "false"
                         "t": "true"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 2,
                 "x": 680,
                 "y": 660,
                 "wires": [
                         "7eea52e80cbe51f0",
                         "93f0d4c85ab42e59"
                         "7b9c0fa6e795af2d",
                         "87ec46662c49de4e",
                         "f00e20abd94ff43d"
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "false",
                         "tot": "bool"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 1380,
                 "y": 640,
                 "wires": [
                         "331a07cfba2d7df1"
                 "type": "change",
                 "name": "stop",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "stop",
                         "tot": "str"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 1010,
                 "y": 640,
                 "wires": [
                         "d96f128a59bdfbb4"
                 "name": "45sek",
                 "outtopic": "",
                 "outsafe": "on",
                 "outunsafe": "off",
                 "warning": "10",
                 "timer": "45",
                 "debug": false,
                 "ndebug": false,
                 "repeat": false,
                 "again": false,
                 "x": 1090,
                 "y": 400,
                 "wires": [
                         "91febc7692f9b822"
                 "name": "10Sek",
                 "outtopic": "",
                 "outsafe": "on",
                 "outunsafe": "off",
                 "warning": "10",
                 "timer": "10",
                 "debug": false,
                 "ndebug": false,
                 "repeat": false,
                 "again": false,
                 "x": 1430,
                 "y": 260,
                 "wires": [
                         "90c9685b4a5344dc"
                 "name": "U-rechts",
                 "ack": "false",
                 "stateName": "",
                 "role": "",
                 "payloadType": "",
                 "readonly": "",
                 "stateUnit": "",
                 "stateMin": "",
                 "stateMax": "",
                 "x": 2140,
                 "y": 600,
                 "wires": []
                 "ack": "false",
                 "stateName": "",
                 "role": "",
                 "payloadType": "",
                 "readonly": "",
                 "stateUnit": "",
                 "stateMin": "",
                 "stateMax": "",
                 "x": 2210,
                 "y": 460,
                 "wires": []
                 "ack": "false",
                 "stateName": "",
                 "role": "",
                 "payloadType": "",
                 "readonly": "",
                 "stateUnit": "",
                 "stateMin": "",
                 "stateMax": "",
                 "x": 2160,
                 "y": 540,
                 "wires": []
                 "type": "debug",
                 "name": "Küche",
                 "active": true,
                 "tosidebar": true,
                 "console": true,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 2160,
                 "y": 760,
                 "wires": []
                 "type": "delay",
                 "name": "100ms",
                 "timeout": "100",
                 "rate": "1",
                 "nbRateUnits": "1",
                 "randomFirst": "1",
                 "randomLast": "5",
                 "drop": false,
                 "allowrate": false,
                 "outputs": 1,
                 "x": 2070,
                 "y": 460,
                 "wires": [
                         "084e7114b7ed1c61"
                 "type": "change",
                 "name": "Küche",
                 "rules": [
                         "t": "change",
                         "p": "payload",
                         "pt": "msg",
                         "from": "1000",
                         "fromt": "str",
                         "to": "Küche",
                         "tot": "str"
                         "t": "change",
                         "p": "payload",
                         "pt": "msg",
                         "from": "true",
                         "fromt": "bool",
                         "tot": "str"
                         "t": "change",
                         "p": "payload",
                         "pt": "msg",
                         "from": "false",
                         "fromt": "bool",
                         "tot": "str"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 2030,
                 "y": 760,
                 "wires": [
                         "442c2ef743d9599f"
                 "name": "U-links",
                 "ack": "false",
                 "stateName": "",
                 "role": "",
                 "payloadType": "",
                 "readonly": "",
                 "stateUnit": "",
                 "stateMin": "",
                 "stateMax": "",
                 "x": 2130,
                 "y": 680,
                 "wires": []
                 "name": "Hue",
                 "x": 130,
                 "y": 160,
                 "wires": [
                         "2e0c2a67486c0ac7"
                 "initevents": true,
                 "x": 360,
                 "y": 160,
                 "wires": [
                         "0395e4bbb7c67e21"
                 "id": "83e1205cab7afd75",
                 "type": "inject",
                 "name": "Takt",
                 "props": [
                         "p": "payload"
                         "p": "topic",
                         "vt": "str"
                 "repeat": "1",
                 "crontab": "",
                 "once": true,
                 "onceDelay": 0.1,
                 "topic": "Takt",
                 "payload": "true",
                 "payloadType": "bool",
                 "x": 130,
                 "y": 60,
                 "wires": [
                         "26a06677287b879b",
                         "256e4df028333ee3"
                 "id": "26a06677287b879b",
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "bewegung",
                         "tot": "flow"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 350,
                 "y": 120,
                 "wires": [
                         "9c7c62ee37b6b12c"
                 "id": "c8bd53de95a27a58",
                 "type": "inject",
                 "name": "Test Schalter",
                 "props": [
                         "p": "payload"
                         "p": "topic",
                         "vt": "str"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "1000",
                 "x": 130,
                 "y": 600,
                 "wires": [
                         "e22b60db6265e908"
                 "id": "b6322a40cf4557b3",
                 "type": "change",
                 "name": "lösche bewegung",
                 "rules": [
                         "t": "set",
                         "p": "bewegung",
                         "pt": "flow",
                         "to": "false",
                         "tot": "bool"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 1390,
                 "y": 680,
                 "wires": [
                 "id": "35f7a8f381fdb099",
                 "type": "change",
                 "name": "lichtan?",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "lampe_ist",
                         "tot": "flow"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 460,
                 "y": 660,
                 "wires": [
                         "cf3016a536d38a8d"
                 "id": "dc4b3ed2e3d1a857",
                 "type": "change",
                 "name": "Motion",
                 "rules": [
                         "t": "set",
                         "p": "lampe_ist",
                         "pt": "flow",
                         "to": "payload",
                         "tot": "msg"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 910,
                 "y": 100,
                 "wires": [
                 "id": "704f9134130a0c13",
                 "type": "comment",
                 "name": "Nötig für Simulation, da kein Tuya Ende",
                 "info": "",
                 "x": 830,
                 "y": 160,
                 "wires": []
                 "id": "105d29d40a2b08f3",
                 "type": "comment",
                 "name": "Nötig für Simulation, da kein Tuya Beginn",
                 "info": "",
                 "x": 840,
                 "y": 40,
                 "wires": []
                 "id": "2e246cc32c852ec4",
                 "type": "comment",
                 "name": "Nötig für Simulation, da kein Tuya",
                 "info": "",
                 "x": 470,
                 "y": 620,
                 "wires": []
                 "id": "5d18e186acebf108",
                 "type": "comment",
                 "info": "",
                 "x": 470,
                 "y": 720,
                 "wires": []
                 "id": "4208dd4576daa563",
                 "type": "comment",
                 "name": "<< Bewegungsmelder |||||||||||||| Simulator da kein Hue  Ende>>",
                 "info": "",
                 "x": 260,
                 "y": 520,
                 "wires": []
                 "id": "f6fea6b16f9005b0",
                 "type": "comment",
                 "name": "evtl. gesperrt durch?? Ende",
                 "info": "",
                 "x": 980,
                 "y": 320,
                 "wires": []
                 "worker": "10",
          Peterfido
          • P peterfido
                   "type": "tab",
                   "label": "Flow 8",
                   "disabled": false,
                   "info": "",
                   "env": []
                   "type": "junction",
                   "x": 1120,
                   "y": 660,
                   "wires": [
                           "141a052859674836",
                           "574a9f7ddc4f663b",
                           "b6322a40cf4557b3"
                   "type": "junction",
                   "x": 1960,
                   "y": 460,
                   "wires": [
                           "ff32f89078260f0e",
                           "67e2e01a1266d1c3",
                           "e98816534075b0f5",
                           "21f36ea2695afe19",
                           "a695276a00fe8f61"
                   "type": "junction",
                   "x": 1140,
                   "y": 260,
                   "wires": [
                           "ba0aea0ff71ebc3d"
                   "type": "junction",
                   "x": 580,
                   "y": 60,
                   "wires": [
                           "6ae2e0e61f81faeb"
                   "type": "junction",
                   "x": 540,
                   "y": 120,
                   "wires": [
                           "d24a5429e472b18a"
                   "type": "junction",
                   "x": 900,
                   "y": 440,
                   "wires": [
                           "84bd4ea1d044fea4",
                           "ed2607cafe826532"
                   "type": "junction",
                   "x": 980,
                   "y": 360,
                   "wires": [
                           "be66da991b562e24"
                   "type": "junction",
                   "x": 1280,
                   "y": 360,
                   "wires": [
                           "fa5f2b5bcd258a98"
                   "type": "inject",
                   "props": [
                           "v": "true",
                           "vt": "bool"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "x": 140,
                   "y": 380,
                   "wires": [
                           "a919a4c30d900c39",
                           "0150c15cf7b51170"
                   "type": "debug",
                   "name": "debug 3",
                   "active": false,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "true",
                   "statusVal": "",
                   "x": 2000,
                   "y": 360,
                   "wires": []
                   "type": "delay",
                   "name": "",
                   "timeout": "10",
                   "rate": "1",
                   "nbRateUnits": "1",
                   "randomFirst": "1",
                   "randomLast": "5",
                   "drop": false,
                   "allowrate": false,
                   "outputs": 1,
                   "x": 150,
                   "y": 460,
                   "wires": [
                           "bee64eb116d76ed1"
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "pt": "msg",
                           "to": "false",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 350,
                   "y": 460,
                   "wires": [
                           "0150c15cf7b51170"
                   "type": "switch",
                   "name": "Schalter",
                   "rules": [
                           "t": "true"
                           "t": "false"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 920,
                   "y": 260,
                   "wires": [
                           "01fea99b98c641a3"
                   "type": "change",
                   "name": "Motion",
                   "rules": [
                           "t": "set",
                           "p": "bewegung",
                           "pt": "flow",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 670,
                   "y": 320,
                   "wires": [
                   "type": "comment",
                   "info": "",
                   "x": 270,
                   "y": 300,
                   "wires": []
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "on",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 710,
                   "y": 400,
                   "wires": [
                           "ed2607cafe826532"
                   "type": "switch",
                   "name": "1000?",
                   "rules": [
                           "t": "eq",
                           "v": "1000",
                           "vt": "num"
                           "t": "eq",
                           "v": "",
                           "vt": "num"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 250,
                   "y": 660,
                   "wires": [
                           "35f7a8f381fdb099"
                   "type": "switch",
                   "name": "Robi",
                   "property": "BWM",
                   "rules": [
                           "t": "true"
                           "t": "false"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 1050,
                   "y": 260,
                   "wires": [
                           "ae8ceff406113f11"
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "stopp",
                           "pt": "flow",
                           "to": "true",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 890,
                   "y": 600,
                   "wires": [
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "stopp",
                           "pt": "flow",
                           "to": "false",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1370,
                   "y": 600,
                   "wires": [
                   "type": "function",
                   "outputs": 1,
                   "timeout": 0,
                   "noerr": 0,
                   "finalize": "",
                   "libs": [],
                   "x": 1770,
                   "y": 380,
                   "wires": [
                           "ed06e85de97289c8",
                           "423ea0f1dc0e4d31"
                   "name": "Robi",
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "x": 90,
                   "y": 780,
                   "wires": [
                           "6b214a0a59b5e04a"
                   "type": "function",
                   "outputs": 1,
                   "timeout": 0,
                   "noerr": 0,
                   "initialize": "",
                   "finalize": "",
                   "libs": [],
                   "x": 360,
                   "y": 360,
                   "wires": [
                           "0395e4bbb7c67e21"
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "x": 100,
                   "y": 680,
                   "wires": [
                           "e22b60db6265e908"
                   "type": "switch",
                   "name": "8?",
                   "rules": [
                           "t": "eq",
                           "v": "8",
                           "vt": "num"
                           "t": "neq",
                           "v": "8",
                           "vt": "num"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 630,
                   "y": 780,
                   "wires": [
                           "7b9c0fa6e795af2d"
                           "ccadbb1ee1de29e6"
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "BWM",
                           "pt": "flow",
                           "to": "true",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 850,
                   "y": 760,
                   "wires": [
                           "b117dac109d51b34"
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "BWM",
                           "pt": "flow",
                           "to": "false",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 850,
                   "y": 800,
                   "wires": [
                           "b117dac109d51b34"
                   "type": "comment",
                   "info": "",
                   "x": 980,
                   "y": 220,
                   "wires": []
                   "type": "switch",
                   "name": "nur true",
                   "rules": [
                           "t": "true"
                           "t": "false"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 740,
                   "y": 240,
                   "wires": [
                           "ab41883686b27cc0"
                   "type": "debug",
                   "name": "debug 4",
                   "active": false,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "true",
                   "statusVal": "",
                   "x": 1040,
                   "y": 760,
                   "wires": []
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "change",
                           "p": "payload",
                           "pt": "msg",
                           "from": "on",
                           "fromt": "str",
                           "to": "true",
                           "tot": "bool"
                           "t": "change",
                           "p": "payload",
                           "pt": "msg",
                           "from": "off",
                           "fromt": "str",
                           "to": "false",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1290,
                   "y": 400,
                   "wires": [
                           "d303b6e1817d8b77"
                   "type": "switch",
                   "name": "",
                   "rules": [
                           "t": "true"
                           "t": "false"
                           "t": "eq",
                           "v": "",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 3,
                   "x": 1470,
                   "y": 400,
                   "wires": [
                           "331a07cfba2d7df1"
                           "331a07cfba2d7df1",
                           "574a9f7ddc4f663b"
                   "type": "switch",
                   "name": "",
                   "rules": [
                           "t": "true"
                           "t": "false"
                           "t": "eq",
                           "v": "",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 3,
                   "x": 1770,
                   "y": 260,
                   "wires": [
                           "331a07cfba2d7df1"
                           "331a07cfba2d7df1"
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "change",
                           "p": "payload",
                           "pt": "msg",
                           "from": "on",
                           "fromt": "str",
                           "to": "true",
                           "tot": "bool"
                           "t": "change",
                           "p": "payload",
                           "pt": "msg",
                           "from": "off",
                           "fromt": "str",
                           "to": "false",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1610,
                   "y": 260,
                   "wires": [
                           "b4e55cb04c30244e"
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "on",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1250,
                   "y": 260,
                   "wires": [
                           "fa5f2b5bcd258a98"
                   "x": 760,
                   "y": 100,
                   "wires": [
                           "dc4b3ed2e3d1a857"
                   "type": "switch",
                   "rules": [
                           "t": "false"
                           "t": "true"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 680,
                   "y": 660,
                   "wires": [
                           "7eea52e80cbe51f0",
                           "93f0d4c85ab42e59"
                           "7b9c0fa6e795af2d",
                           "87ec46662c49de4e",
                           "f00e20abd94ff43d"
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "false",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1380,
                   "y": 640,
                   "wires": [
                           "331a07cfba2d7df1"
                   "type": "change",
                   "name": "stop",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "stop",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1010,
                   "y": 640,
                   "wires": [
                           "d96f128a59bdfbb4"
                   "name": "45sek",
                   "outtopic": "",
                   "outsafe": "on",
                   "outunsafe": "off",
                   "warning": "10",
                   "timer": "45",
                   "debug": false,
                   "ndebug": false,
                   "repeat": false,
                   "again": false,
                   "x": 1090,
                   "y": 400,
                   "wires": [
                           "91febc7692f9b822"
                   "name": "10Sek",
                   "outtopic": "",
                   "outsafe": "on",
                   "outunsafe": "off",
                   "warning": "10",
                   "timer": "10",
                   "debug": false,
                   "ndebug": false,
                   "repeat": false,
                   "again": false,
                   "x": 1430,
                   "y": 260,
                   "wires": [
                           "90c9685b4a5344dc"
                   "name": "U-rechts",
                   "ack": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2140,
                   "y": 600,
                   "wires": []
                   "ack": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2210,
                   "y": 460,
                   "wires": []
                   "ack": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2160,
                   "y": 540,
                   "wires": []
                   "type": "debug",
                   "name": "Küche",
                   "active": true,
                   "tosidebar": true,
                   "console": true,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 2160,
                   "y": 760,
                   "wires": []
                   "type": "delay",
                   "name": "100ms",
                   "timeout": "100",
                   "rate": "1",
                   "nbRateUnits": "1",
                   "randomFirst": "1",
                   "randomLast": "5",
                   "drop": false,
                   "allowrate": false,
                   "outputs": 1,
                   "x": 2070,
                   "y": 460,
                   "wires": [
                           "084e7114b7ed1c61"
                   "type": "change",
                   "name": "Küche",
                   "rules": [
                           "t": "change",
                           "p": "payload",
                           "pt": "msg",
                           "from": "1000",
                           "fromt": "str",
                           "to": "Küche",
                           "tot": "str"
                           "t": "change",
                           "p": "payload",
                           "pt": "msg",
                           "from": "true",
                           "fromt": "bool",
                           "tot": "str"
                           "t": "change",
                           "p": "payload",
                           "pt": "msg",
                           "from": "false",
                           "fromt": "bool",
                           "tot": "str"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 2030,
                   "y": 760,
                   "wires": [
                           "442c2ef743d9599f"
                   "name": "U-links",
                   "ack": "false",
                   "stateName": "",
                   "role": "",
                   "payloadType": "",
                   "readonly": "",
                   "stateUnit": "",
                   "stateMin": "",
                   "stateMax": "",
                   "x": 2130,
                   "y": 680,
                   "wires": []
                   "name": "Hue",
                   "x": 130,
                   "y": 160,
                   "wires": [
                           "2e0c2a67486c0ac7"
                   "initevents": true,
                   "x": 360,
                   "y": 160,
                   "wires": [
                           "0395e4bbb7c67e21"
                   "type": "inject",
                   "name": "Takt",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "1",
                   "crontab": "",
                   "once": true,
                   "onceDelay": 0.1,
                   "topic": "Takt",
                   "payload": "true",
                   "x": 130,
                   "y": 60,
                   "wires": [
                           "26a06677287b879b",
                           "256e4df028333ee3"
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "bewegung",
                           "tot": "flow"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 350,
                   "y": 120,
                   "wires": [
                           "9c7c62ee37b6b12c"
                   "type": "inject",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "1000",
                   "x": 130,
                   "y": 600,
                   "wires": [
                           "e22b60db6265e908"
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "bewegung",
                           "pt": "flow",
                           "to": "false",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1390,
                   "y": 680,
                   "wires": [
                   "type": "change",
                   "name": "lichtan?",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "lampe_ist",
                           "tot": "flow"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 460,
                   "y": 660,
                   "wires": [
                           "cf3016a536d38a8d"
                   "type": "change",
                   "name": "Motion",
                   "rules": [
                           "t": "set",
                           "p": "lampe_ist",
                           "pt": "flow",
                           "to": "payload",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 910,
                   "y": 100,
                   "wires": [
                   "type": "comment",
                   "info": "",
                   "x": 830,
                   "y": 160,
                   "wires": []
                   "type": "comment",
                   "info": "",
                   "x": 840,
                   "y": 40,
                   "wires": []
                   "type": "comment",
                   "info": "",
                   "x": 470,
                   "y": 620,
                   "wires": []
                   "type": "comment",
                   "info": "",
                   "x": 470,
                   "y": 720,
                   "wires": []
                   "type": "comment",
                   "info": "",
                   "x": 260,
                   "y": 520,
                   "wires": []
                   "type": "comment",
                   "info": "",
                   "x": 980,
                   "y": 320,
                   "wires": []
                   "worker": "10",
            AphofisA Offline
            AphofisA Offline
            Aphofis
            @peterfido
            Mit der neuen Schaltung kann man per HUE schalter einmal zweimal klick nicht das licht ein und ausschalten es geht nur einschalten einschalten.
            Das war in der vorherigen Schaltung korrekt da war jeder klick auf den schalter ein aus ein aus schalten.
            P 1 Antwort Letzte Antwort
            • AphofisA Aphofis
              @peterfido
              peterfido
              @aphofis Guck Dir mal die Function genauer an. Da ist ein Bemerkungstext drin, dass eine Zeile auskommentiert werden soll, wenn es produktiv genutzt wird. Evtl. war es das dann schon. Ich habe die Hardware nicht da, und habe daher die Lampe mit der Function simuliert.
              Es ist nicht einfach, da was zu "testen", was man nicht hat.
              Peterfido
              • AphofisA Offline
                AphofisA Offline
                Aphofis
                @peterfido
                Du meinst in der Variable !?
                flow.set("lampe_ist", msg.payload);
                Hatte ich auskommentiert, geht dann aber trotzdem nicht.
                • AphofisA Aphofis
                  @peterfido
                  peterfido
                  @aphofis Da kommt dann die Fehlersuche. Also ein Node, z.B. den vom Bewegungsmelder deaktivieren, und schauen, ob es dann in der Simulation läuft. Man kann auch das Topic setzen und am Ende auswerten, wer die Lampe eingeschaltet hat.
                  Die Abfrage der Lampe_ist kann auch von oben wieder weg und nach unten als Ersatz für den von mir mit "kein Tuya" 'eingerahmten' Block.
                  Peterfido
                  • P peterfido
                    AphofisA Offline
                    AphofisA Offline
                    Aphofis
                    @peterfido
                    Also es funktioniert soweit, doch wenn der Roboter status 5 hat und man in den BWM läuft geht trotzdem das Licht an und wenn man es dann per Schalter ausschalten will, muss man das 3-4 mal machen bis das licht aus bleibt. Wie man jetzt herausfindet wer nun das licht schaltet weiß ich nicht.
                            "id": "a4c8574588c0de3c",
                            "type": "change",
                            "z": "f40fbc4eb5ac4f7a",
                            "rules": [
                                    "t": "set",
                                    "pt": "msg",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 450,
                            "y": 540,
                            "wires": [
                                    "169c9cd74337485f"
                            "id": "f6bc1b429099ca57",
                            "type": "switch",
                            "name": "Schalter",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 800,
                            "y": 500,
                            "wires": [
                                    "ee120a8678492945"
                            "id": "f2bfa3e6a90d48ed",
                            "type": "change",
                            "name": "Motion",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 610,
                            "y": 500,
                            "wires": [
                                    "a7c05960eac63d95"
                            "id": "8803280db34eb22b",
                            "type": "comment",
                            "name": "Bewegungsmelder Simulator  Beginn",
                            "info": "",
                            "x": 160,
                            "y": 420,
                            "wires": []
                            "id": "5925b1db569c695b",
                            "type": "change",
                            "name": "payload",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "on",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 620,
                            "y": 540,
                            "wires": [
                                    "5f9435538ec534ed"
                            "id": "95fda7a91b84c03f",
                            "type": "switch",
                            "name": "1000?",
                            "rules": [
                                    "t": "eq",
                                    "v": "1000",
                                    "vt": "num"
                                    "t": "eq",
                                    "v": "",
                                    "vt": "num"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 250,
                            "y": 600,
                            "wires": [
                                    "ee5a65e2896d189b"
                            "id": "ee120a8678492945",
                            "type": "switch",
                            "name": "Robi",
                            "property": "BWM",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 810,
                            "y": 460,
                            "wires": [
                                    "8f4fcec5a545127f"
                            "id": "3648551e97ec2cab",
                            "type": "change",
                            "name": "flow/stop",
                            "rules": [
                                    "t": "set",
                                    "p": "stopp",
                                    "pt": "flow",
                                    "to": "true",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 620,
                            "y": 580,
                            "wires": [
                            "id": "a8b609cc983f0b37",
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "stopp",
                                    "pt": "flow",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1220,
                            "y": 520,
                            "wires": [
                            "id": "0e43213215238d27",
                            "type": "function",
                            "name": "Variab.Ini + Ausg.",
                            "outputs": 1,
                            "timeout": 0,
                            "noerr": 0,
                            "finalize": "",
                            "libs": [],
                            "x": 1430,
                            "y": 460,
                            "wires": [
                                    "f1be18a24ca143f6"
                            "id": "6500453922363ac9",
                            "name": "Robi",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 370,
                            "y": 700,
                            "wires": [
                                    "81fd4c871d668d04"
                            "id": "169c9cd74337485f",
                            "type": "function",
                            "name": "Ausg.BWM",
                            "outputs": 1,
                            "timeout": 0,
                            "noerr": 0,
                            "initialize": "",
                            "finalize": "",
                            "libs": [],
                            "x": 450,
                            "y": 500,
                            "wires": [
                                    "f2bfa3e6a90d48ed"
                            "id": "c6d6a47028727285",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 80,
                            "y": 600,
                            "wires": [
                                    "95fda7a91b84c03f"
                            "id": "81fd4c871d668d04",
                            "type": "switch",
                            "name": "8?",
                            "rules": [
                                    "t": "eq",
                                    "v": "8",
                                    "vt": "num"
                                    "t": "neq",
                                    "v": "8",
                                    "vt": "num"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 490,
                            "y": 680,
                            "wires": [
                                    "638dc14da90f5eb4"
                                    "542b940ecfefa127"
                            "id": "638dc14da90f5eb4",
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "BWM",
                                    "pt": "flow",
                                    "to": "true",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 650,
                            "y": 660,
                            "wires": [
                                    "3803f5607daeb485"
                            "id": "542b940ecfefa127",
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "BWM",
                                    "pt": "flow",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 650,
                            "y": 700,
                            "wires": [
                                    "3803f5607daeb485"
                            "id": "2bb3725204a30905",
                            "type": "comment",
                            "info": "",
                            "x": 800,
                            "y": 380,
                            "wires": []
                            "id": "a7c05960eac63d95",
                            "type": "switch",
                            "name": "nur true",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 640,
                            "y": 460,
                            "wires": [
                                    "f6bc1b429099ca57"
                            "id": "3803f5607daeb485",
                            "type": "debug",
                            "name": "debug 9",
                            "active": false,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "complete": "true",
                            "statusVal": "",
                            "x": 820,
                            "y": 680,
                            "wires": []
                            "id": "86ed2879e6ab1742",
                            "type": "comment",
                            "name": "Bewegungsmelder Simulator Ende",
                            "info": "",
                            "x": 160,
                            "y": 560,
                            "wires": []
                            "id": "4deb5666bac8cf44",
                            "type": "change",
                            "name": "on/off",
                            "rules": [
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "on",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "bool"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "off",
                                    "fromt": "str",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 890,
                            "y": 560,
                            "wires": [
                                    "d2eeea8c88021d24"
                            "id": "d2eeea8c88021d24",
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                                    "t": "eq",
                                    "v": "",
                                    "vt": "str"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 3,
                            "x": 1010,
                            "y": 560,
                            "wires": [
                                    "1584a54e77837dbd"
                                    "a8b609cc983f0b37",
                                    "1584a54e77837dbd"
                            "id": "774f8f940a2c4c96",
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                                    "t": "eq",
                                    "v": "",
                                    "vt": "str"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 3,
                            "x": 1190,
                            "y": 460,
                            "wires": [
                                    "0e43213215238d27"
                                    "0e43213215238d27"
                            "id": "bcc31acbfde45d97",
                            "type": "change",
                            "name": "on/off",
                            "rules": [
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "on",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "bool"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "off",
                                    "fromt": "str",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 990,
                            "y": 460,
                            "wires": [
                                    "774f8f940a2c4c96"
                            "id": "8f4fcec5a545127f",
                            "type": "change",
                            "name": "on",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "on",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 810,
                            "y": 420,
                            "wires": [
                                    "e8865a546b6ee97f"
                            "id": "ee5a65e2896d189b",
                            "x": 340,
                            "y": 640,
                            "wires": [
                                    "661eb84a02820976"
                            "id": "661eb84a02820976",
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "false"
                                    "t": "true"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 430,
                            "y": 580,
                            "wires": [
                                    "a8a0cb4a1682f9f2",
                                    "3bd2c8cd8fbc4e0d"
                                    "638dc14da90f5eb4",
                                    "d5b7b0bf08213264",
                                    "8791ca72f579691c"
                            "id": "3c6f79231d0fc04b",
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1220,
                            "y": 560,
                            "wires": [
                                    "0e43213215238d27"
                            "id": "d5b7b0bf08213264",
                            "type": "change",
                            "name": "stop",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "stop",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 610,
                            "y": 620,
                            "wires": [
                                    "5f9435538ec534ed",
                                    "9b6cc9d834347e2b"
                            "id": "5f9435538ec534ed",
                            "name": "10min.",
                            "outtopic": "",
                            "outsafe": "on",
                            "outunsafe": "off",
                            "warning": "10",
                            "timer": "600",
                            "debug": false,
                            "ndebug": false,
                            "repeat": false,
                            "again": false,
                            "x": 770,
                            "y": 560,
                            "wires": [
                                    "4deb5666bac8cf44"
                            "id": "e8865a546b6ee97f",
                            "name": "3Min.",
                            "outtopic": "",
                            "outsafe": "on",
                            "outunsafe": "off",
                            "warning": "10",
                            "timer": "180",
                            "debug": false,
                            "ndebug": false,
                            "repeat": false,
                            "again": false,
                            "x": 990,
                            "y": 500,
                            "wires": [
                                    "bcc31acbfde45d97"
                            "id": "166ff2a331d49e9e",
                            "name": "Hue",
                            "x": 130,
                            "y": 500,
                            "wires": [
                                    "d500eca26ab86278"
                            "id": "d500eca26ab86278",
                            "name": "KüMo",
                            "initevents": true,
                            "x": 270,
                            "y": 500,
                            "wires": [
                                    "169c9cd74337485f",
                                    "a4c8574588c0de3c"
                            "id": "631201f88292c2d6",
                            "name": "U-rechts",
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1320,
                            "y": 740,
                            "wires": []
                            "id": "400b88291d913b81",
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1330,
                            "y": 620,
                            "wires": []
                            "id": "ce64922d78c18bb2",
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1340,
                            "y": 680,
                            "wires": []
                            "id": "b16aaa4000874ffd",
                            "type": "debug",
                            "name": "Küche",
                            "active": true,
                            "tosidebar": true,
                            "console": true,
                            "tostatus": false,
                            "statusVal": "",
                            "statusType": "auto",
                            "x": 1440,
                            "y": 860,
                            "wires": []
                            "id": "f5195df37114b7de",
                            "type": "change",
                            "name": "Küche",
                            "rules": [
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "1000",
                                    "fromt": "str",
                                    "to": "Küche",
                                    "tot": "str"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "true",
                                    "fromt": "bool",
                                    "tot": "str"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "false",
                                    "fromt": "bool",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1310,
                            "y": 860,
                            "wires": [
                                    "b16aaa4000874ffd"
                            "id": "08276b1f6580fc56",
                            "name": "U-links",
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1430,
                            "y": 800,
                            "wires": []
                            "id": "587e1a24a2250226",
                            "type": "inject",
                            "name": "",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "1000",
                            "payloadType": "str",
                            "x": 90,
                            "y": 720,
                            "wires": [
                                    "95fda7a91b84c03f"
                            "id": "f3e6cb95fd339887",
                            "name": "VIS-Küche",
                            "topic": "0_userdata.0.GordonX-Home.0.Küche.VIS-Küche",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 80,
                            "y": 660,
                            "wires": [
                                    "95fda7a91b84c03f"
                            "id": "3c0717cd3d6e108e",
                            "type": "delay",
                            "name": "100ms",
                            "pauseType": "delay",
                            "timeout": "100",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "rateUnits": "second",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "randomUnits": "seconds",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 1310,
                            "y": 800,
                            "wires": [
                                    "08276b1f6580fc56"
                            "id": "805251b70f5d5a93",
                            "type": "inject",
                            "name": "Test Bewegung",
                            "props": [
                                    "p": "payload.motion",
                                    "v": "true",
                                    "vt": "bool"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "Bewegungsmelder",
                            "x": 240,
                            "y": 460,
                            "wires": [
                                    "169c9cd74337485f",
                                    "e1f5f49327a29a8a"
                            "id": "e1f5f49327a29a8a",
                            "type": "change",
                            "name": "motion:false",
                            "rules": [
                                    "t": "set",
                                    "pt": "msg",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 450,
                            "y": 460,
                            "wires": [
                                    "169c9cd74337485f"
                            "id": "90f844739a331c64",
                            "type": "junction",
                            "x": 1060,
                            "y": 600,
                            "wires": [
                                    "3c6f79231d0fc04b",
                                    "a8b609cc983f0b37"
                            "id": "f1be18a24ca143f6",
                            "type": "junction",
                            "x": 1160,
                            "y": 680,
                            "wires": [
                                    "ce64922d78c18bb2",
                                    "f5195df37114b7de",
                                    "631201f88292c2d6",
                                    "400b88291d913b81",
                                    "3c0717cd3d6e108e"
                            "id": "1584a54e77837dbd",
                            "type": "junction",
                            "x": 1100,
                            "y": 480,
                            "wires": [
                                    "612158a90f7d1a23"
                            "id": "e9a12ac84d11dd0e",
                            "type": "junction",
                            "x": 980,
                            "y": 640,
                            "wires": [
                                    "90f844739a331c64"
                            "id": "a8a0cb4a1682f9f2",
                            "type": "junction",
                            "x": 540,
                            "y": 560,
                            "wires": [
                                    "5925b1db569c695b"
                            "id": "3bd2c8cd8fbc4e0d",
                            "type": "junction",
                            "x": 540,
                            "y": 580,
                            "wires": [
                                    "3648551e97ec2cab"
                            "id": "9b6cc9d834347e2b",
                            "type": "junction",
                            "x": 880,
                            "y": 620,
                            "wires": [
                                    "e8865a546b6ee97f"
                            "id": "612158a90f7d1a23",
                            "type": "junction",
                            "x": 1260,
                            "y": 480,
                            "wires": [
                                    "0e43213215238d27"
                            "id": "8791ca72f579691c",
                            "type": "junction",
                            "x": 560,
                            "y": 640,
                            "wires": [
                                    "e9a12ac84d11dd0e"
                            "worker": "10",
                    • AphofisA Aphofis
                      @peterfido
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "pt": "msg",
                                      "to": "false",
                                      "tot": "bool"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 450,
                              "y": 540,
                              "wires": [
                                      "169c9cd74337485f"
                              "type": "switch",
                              "name": "Schalter",
                              "property": "stopp",
                              "propertyType": "flow",
                              "rules": [
                                      "t": "true"
                                      "t": "false"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 2,
                              "x": 800,
                              "y": 500,
                              "wires": [
                                      "ee120a8678492945"
                              "type": "change",
                              "name": "Motion",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "to": "payload.motion",
                                      "tot": "msg"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 610,
                              "y": 500,
                              "wires": [
                                      "a7c05960eac63d95"
                              "type": "comment",
                              "info": "",
                              "x": 160,
                              "y": 420,
                              "wires": []
                              "type": "change",
                              "name": "payload",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "to": "on",
                                      "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 620,
                              "y": 540,
                              "wires": [
                                      "5f9435538ec534ed"
                              "type": "switch",
                              "name": "1000?",
                              "property": "payload",
                              "propertyType": "msg",
                              "rules": [
                                      "t": "eq",
                                      "v": "1000",
                                      "vt": "num"
                                      "t": "eq",
                                      "v": "",
                                      "vt": "num"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 2,
                              "x": 250,
                              "y": 600,
                              "wires": [
                                      "ee5a65e2896d189b"
                              "type": "switch",
                              "name": "Robi",
                              "property": "BWM",
                              "rules": [
                                      "t": "true"
                                      "t": "false"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 2,
                              "x": 810,
                              "y": 460,
                              "wires": [
                                      "8f4fcec5a545127f"
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "p": "stopp",
                                      "pt": "flow",
                                      "to": "true",
                                      "tot": "bool"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 620,
                              "y": 580,
                              "wires": [
                              "type": "change",
                              "name": "löscheflow.stopp",
                              "rules": [
                                      "t": "set",
                                      "p": "stopp",
                                      "pt": "flow",
                                      "to": "false",
                                      "tot": "bool"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 1220,
                              "y": 520,
                              "wires": [
                              "type": "function",
                              "func": "node.status({ text: msg.payload });\n\nreturn msg;",
                              "outputs": 1,
                              "timeout": 0,
                              "noerr": 0,
                              "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\n",
                              "finalize": "",
                              "libs": [],
                              "x": 1430,
                              "y": 460,
                              "wires": [
                                      "f1be18a24ca143f6"
                              "type": "ioBroker in",
                              "name": "Robi",
                              "attrname": "payload",
                              "payloadType": "value",
                              "onlyack": "",
                              "func": "all",
                              "gap": "",
                              "fireOnStart": "false",
                              "outFormat": "MQTT",
                              "x": 370,
                              "y": 700,
                              "wires": [
                                      "81fd4c871d668d04"
                              "type": "function",
                              "name": "Ausg.BWM",
                              "func": "\nreturn msg;",
                              "outputs": 1,
                              "timeout": 0,
                              "noerr": 0,
                              "initialize": "",
                              "finalize": "",
                              "libs": [],
                              "x": 450,
                              "y": 500,
                              "wires": [
                                      "f2bfa3e6a90d48ed"
                              "onlyack": "",
                              "func": "all",
                              "gap": "",
                              "x": 80,
                              "y": 600,
                              "wires": [
                                      "95fda7a91b84c03f"
                              "type": "switch",
                              "name": "8?",
                              "rules": [
                                      "t": "eq",
                                      "v": "8",
                                      "vt": "num"
                                      "t": "neq",
                                      "v": "8",
                                      "vt": "num"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 2,
                              "x": 490,
                              "y": 680,
                              "wires": [
                                      "638dc14da90f5eb4"
                                      "542b940ecfefa127"
                              "type": "change",
                              "name": "setze Flow.BWM",
                              "rules": [
                                      "t": "set",
                                      "p": "BWM",
                                      "pt": "flow",
                                      "to": "true",
                                      "tot": "bool"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 650,
                              "y": 660,
                              "wires": [
                                      "3803f5607daeb485"
                              "type": "change",
                              "name": "lösche Flow.BWM",
                              "rules": [
                                      "t": "set",
                                      "p": "BWM",
                                      "pt": "flow",
                                      "to": "false",
                                      "tot": "bool"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 650,
                              "y": 700,
                              "wires": [
                                      "3803f5607daeb485"
                              "type": "comment",
                              "name": "evtl. gesperrt durch??",
                              "info": "",
                              "x": 800,
                              "y": 380,
                              "wires": []
                              "type": "switch",
                              "name": "nur true",
                              "rules": [
                                      "t": "true"
                                      "t": "false"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 2,
                              "x": 640,
                              "y": 460,
                              "wires": [
                                      "f6bc1b429099ca57"
                              "type": "debug",
                              "name": "debug 9",
                              "active": false,
                              "tosidebar": true,
                              "console": false,
                              "tostatus": false,
                              "complete": "true",
                              "targetType": "full",
                              "statusVal": "",
                              "x": 820,
                              "y": 680,
                              "wires": []
                              "type": "comment",
                              "info": "",
                              "x": 160,
                              "y": 560,
                              "wires": []
                              "type": "change",
                              "name": "on/off",
                              "rules": [
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "on",
                                      "fromt": "str",
                                      "to": "true",
                                      "tot": "bool"
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "off",
                                      "fromt": "str",
                                      "to": "false",
                                      "tot": "bool"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 890,
                              "y": 560,
                              "wires": [
                                      "d2eeea8c88021d24"
                              "type": "switch",
                              "name": "",
                              "rules": [
                                      "t": "true"
                                      "t": "false"
                                      "t": "eq",
                                      "v": "",
                                      "vt": "str"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 3,
                              "x": 1010,
                              "y": 560,
                              "wires": [
                                      "1584a54e77837dbd"
                                      "a8b609cc983f0b37",
                                      "1584a54e77837dbd"
                              "type": "switch",
                              "name": "",
                              "rules": [
                                      "t": "true"
                                      "t": "false"
                                      "t": "eq",
                                      "v": "",
                                      "vt": "str"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 3,
                              "x": 1190,
                              "y": 460,
                              "wires": [
                                      "0e43213215238d27"
                                      "0e43213215238d27"
                              "type": "change",
                              "name": "on/off",
                              "rules": [
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "on",
                                      "fromt": "str",
                                      "to": "true",
                                      "tot": "bool"
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "off",
                                      "fromt": "str",
                                      "to": "false",
                                      "tot": "bool"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 990,
                              "y": 460,
                              "wires": [
                                      "774f8f940a2c4c96"
                              "type": "change",
                              "name": "on",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "to": "on",
                                      "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 810,
                              "y": 420,
                              "wires": [
                                      "e8865a546b6ee97f"
                              "type": "ioBroker get",
                              "errOnInvalidState": "nothing",
                              "x": 340,
                              "y": 640,
                              "wires": [
                                      "661eb84a02820976"
                              "type": "switch",
                              "name": "",
                              "rules": [
                                      "t": "false"
                                      "t": "true"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 2,
                              "x": 430,
                              "y": 580,
                              "wires": [
                                      "a8a0cb4a1682f9f2",
                                      "3bd2c8cd8fbc4e0d"
                                      "638dc14da90f5eb4",
                                      "d5b7b0bf08213264",
                                      "8791ca72f579691c"
                              "type": "change",
                              "name": "Alles auf Anfang",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "to": "false",
                                      "tot": "bool"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 1220,
                              "y": 560,
                              "wires": [
                                      "0e43213215238d27"
                              "type": "change",
                              "name": "stop",
                              "rules": [
                                      "t": "set",
                                      "p": "payload",
                                      "pt": "msg",
                                      "to": "stop",
                                      "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 610,
                              "y": 620,
                              "wires": [
                                      "5f9435538ec534ed",
                                      "9b6cc9d834347e2b"
                              "type": "mytimeout",
                              "name": "10min.",
                              "outtopic": "",
                              "outsafe": "on",
                              "outwarning": "Warning",
                              "outunsafe": "off",
                              "warning": "10",
                              "timer": "600",
                              "debug": false,
                              "ndebug": false,
                              "ignoreCase": false,
                              "repeat": false,
                              "again": false,
                              "x": 770,
                              "y": 560,
                              "wires": [
                                      "4deb5666bac8cf44"
                              "name": "3Min.",
                              "outtopic": "",
                              "outsafe": "on",
                              "outunsafe": "off",
                              "warning": "10",
                              "timer": "180",
                              "debug": false,
                              "ndebug": false,
                              "repeat": false,
                              "again": false,
                              "x": 990,
                              "y": 500,
                              "wires": [
                                      "bcc31acbfde45d97"
                              "name": "Hue",
                              "x": 130,
                              "y": 500,
                              "wires": [
                                      "d500eca26ab86278"
                              "name": "KüMo",
                              "initevents": true,
                              "x": 270,
                              "y": 500,
                              "wires": [
                                      "169c9cd74337485f",
                                      "a4c8574588c0de3c"
                              "type": "ioBroker out",
                              "name": "U-rechts",
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 1320,
                              "y": 740,
                              "wires": []
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 1330,
                              "y": 620,
                              "wires": []
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 1340,
                              "y": 680,
                              "wires": []
                              "type": "debug",
                              "name": "Küche",
                              "active": true,
                              "tosidebar": true,
                              "console": true,
                              "tostatus": false,
                              "statusVal": "",
                              "x": 1440,
                              "y": 860,
                              "wires": []
                              "type": "change",
                              "name": "Küche",
                              "rules": [
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "1000",
                                      "fromt": "str",
                                      "to": "Küche",
                                      "tot": "str"
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "true",
                                      "fromt": "bool",
                                      "tot": "str"
                                      "t": "change",
                                      "p": "payload",
                                      "pt": "msg",
                                      "from": "false",
                                      "fromt": "bool",
                                      "tot": "str"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 1310,
                              "y": 860,
                              "wires": [
                                      "b16aaa4000874ffd"
                              "name": "U-links",
                              "ack": "false",
                              "stateName": "",
                              "role": "",
                              "payloadType": "",
                              "readonly": "",
                              "stateUnit": "",
                              "stateMin": "",
                              "stateMax": "",
                              "x": 1430,
                              "y": 800,
                              "wires": []
                              "type": "inject",
                              "name": "",
                              "props": [
                                      "p": "payload"
                                      "p": "topic",
                                      "vt": "str"
                              "repeat": "",
                              "crontab": "",
                              "once": false,
                              "onceDelay": 0.1,
                              "topic": "",
                              "payload": "1000",
                              "x": 90,
                              "y": 720,
                              "wires": [
                                      "95fda7a91b84c03f"
                              "onlyack": "",
                              "func": "all",
                              "gap": "",
                              "x": 80,
                              "y": 660,
                              "wires": [
                                      "95fda7a91b84c03f"
                              "type": "delay",
                              "name": "100ms",
                              "timeout": "100",
                              "rate": "1",
                              "nbRateUnits": "1",
                              "randomFirst": "1",
                              "randomLast": "5",
                              "drop": false,
                              "allowrate": false,
                              "outputs": 1,
                              "x": 1310,
                              "y": 800,
                              "wires": [
                                      "08276b1f6580fc56"
                              "type": "inject",
                              "props": [
                                      "v": "true",
                                      "vt": "bool"
                                      "p": "topic",
                                      "vt": "str"
                              "repeat": "",
                              "crontab": "",
                              "once": false,
                              "onceDelay": 0.1,
                              "x": 240,
                              "y": 460,
                              "wires": [
                                      "169c9cd74337485f",
                                      "e1f5f49327a29a8a"
                              "type": "change",
                              "rules": [
                                      "t": "set",
                                      "pt": "msg",
                                      "to": "false",
                                      "tot": "bool"
                              "action": "",
                              "property": "",
                              "from": "",
                              "to": "",
                              "reg": false,
                              "x": 450,
                              "y": 460,
                              "wires": [
                                      "169c9cd74337485f"
                              "type": "junction",
                              "x": 1060,
                              "y": 600,
                              "wires": [
                                      "3c6f79231d0fc04b",
                                      "a8b609cc983f0b37"
                              "type": "junction",
                              "x": 1160,
                              "y": 680,
                              "wires": [
                                      "ce64922d78c18bb2",
                                      "f5195df37114b7de",
                                      "631201f88292c2d6",
                                      "400b88291d913b81",
                                      "3c0717cd3d6e108e"
                              "type": "junction",
                              "x": 1100,
                              "y": 480,
                              "wires": [
                                      "612158a90f7d1a23"
                              "type": "junction",
                              "x": 980,
                              "y": 640,
                              "wires": [
                                      "90f844739a331c64"
                              "type": "junction",
                              "x": 540,
                              "y": 560,
                              "wires": [
                                      "5925b1db569c695b"
                              "type": "junction",
                              "x": 540,
                              "y": 580,
                              "wires": [
                                      "3648551e97ec2cab"
                              "type": "junction",
                              "x": 880,
                              "y": 620,
                              "wires": [
                                      "e8865a546b6ee97f"
                              "type": "junction",
                              "x": 1260,
                              "y": 480,
                              "wires": [
                                      "0e43213215238d27"
                              "type": "junction",
                              "x": 560,
                              "y": 640,
                              "wires": [
                                      "e9a12ac84d11dd0e"
                              "worker": "10",
                      peterfido
                      @aphofis Das ist eine neue Variante. Meine "Simulation" des HUE Bewegungsmelders hast Du noch nicht verinnerlicht. Die ist rein für Tests, oder, wenn man wie ich keinen HUE BWM hat. Das ist nur für die Simulation zum Testen, und dann auch erst nach einer Zeit x vorgesehen. Jetzt wird zeitgleich payload.motion auf false gesetzt, auch wenn der HUE BWM meldet.
                      Ich habe es jetzt nicht importiert / ausprobiert.
                      Eine Idee:
                      Der HUE Bewegungsmelder geht seine eigenen Wege. Wenn das Licht nicht aus, bzw. gleich wieder an geht, könnte einer erkannten, oder noch anstehenden Bewegung geschuldet sein. Da könnte man eine Sperrvarable setzen, bzw. nur Änderungen durchlassen. Zumindest lief die von mir zuletzt gepostete Variante in meiner Testumgebung. Möglich, dass Dein BWM / Taster / Schalter da was unerwartetes losschickt.
                      Hier mein aufgeräumter Flow.
                             "type": "tab",
                             "label": "Flow 8",
                             "disabled": false,
                             "info": "",
                             "env": []
                             "type": "junction",
                             "x": 1120,
                             "y": 660,
                             "wires": [
                                     "141a052859674836",
                                     "574a9f7ddc4f663b",
                                     "b6322a40cf4557b3"
                             "type": "junction",
                             "x": 1960,
                             "y": 460,
                             "wires": [
                                     "ff32f89078260f0e",
                                     "67e2e01a1266d1c3",
                                     "e98816534075b0f5",
                                     "21f36ea2695afe19",
                                     "a695276a00fe8f61"
                             "type": "junction",
                             "x": 1140,
                             "y": 260,
                             "wires": [
                                     "ba0aea0ff71ebc3d"
                             "type": "junction",
                             "x": 520,
                             "y": 60,
                             "wires": [
                                     "d24a5429e472b18a"
                             "type": "junction",
                             "x": 900,
                             "y": 440,
                             "wires": [
                                     "84bd4ea1d044fea4",
                                     "ed2607cafe826532"
                             "type": "junction",
                             "x": 980,
                             "y": 360,
                             "wires": [
                                     "be66da991b562e24"
                             "type": "junction",
                             "x": 1280,
                             "y": 360,
                             "wires": [
                                     "fa5f2b5bcd258a98"
                             "id": "8355cf791b8a8b1b",
                             "type": "junction",
                             "x": 580,
                             "y": 560,
                             "wires": [
                                     "e22b60db6265e908"
                             "id": "1ee1fe89c1628b34",
                             "type": "junction",
                             "x": 580,
                             "y": 560,
                             "wires": [
                                     "e22b60db6265e908"
                             "id": "f3921b2658b5916c",
                             "type": "junction",
                             "x": 240,
                             "y": 560,
                             "wires": [
                                     "1ee1fe89c1628b34"
                             "type": "inject",
                             "props": [
                                     "v": "true",
                                     "vt": "bool"
                                     "p": "topic",
                                     "vt": "str"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "x": 140,
                             "y": 380,
                             "wires": [
                                     "a919a4c30d900c39",
                                     "0150c15cf7b51170"
                             "type": "debug",
                             "name": "debug 3",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "complete": "true",
                             "statusVal": "",
                             "x": 2000,
                             "y": 360,
                             "wires": []
                             "type": "delay",
                             "name": "",
                             "timeout": "30",
                             "timeoutUnits": "seconds",
                             "rate": "1",
                             "nbRateUnits": "1",
                             "randomFirst": "1",
                             "randomLast": "5",
                             "drop": false,
                             "allowrate": false,
                             "outputs": 1,
                             "x": 150,
                             "y": 460,
                             "wires": [
                                     "bee64eb116d76ed1"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "pt": "msg",
                                     "to": "false",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 350,
                             "y": 460,
                             "wires": [
                                     "0150c15cf7b51170"
                             "type": "switch",
                             "name": "Schalter",
                             "rules": [
                                     "t": "true"
                                     "t": "false"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 920,
                             "y": 260,
                             "wires": [
                                     "01fea99b98c641a3"
                             "type": "change",
                             "name": "Motion",
                             "rules": [
                                     "t": "set",
                                     "p": "bewegung",
                                     "pt": "flow",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 670,
                             "y": 320,
                             "wires": [
                             "type": "comment",
                             "name": "Beginn << Für Simulation Für Simulation Für Simulation Für Simulation >>",
                             "info": "",
                             "x": 280,
                             "y": 300,
                             "wires": []
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "on",
                                     "tot": "str"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 710,
                             "y": 400,
                             "wires": [
                                     "ed2607cafe826532"
                             "type": "switch",
                             "name": "1000?",
                             "rules": [
                                     "t": "eq",
                                     "v": "1000",
                                     "vt": "num"
                                     "t": "eq",
                                     "v": "",
                                     "vt": "num"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 310,
                             "y": 660,
                             "wires": [
                                     "6ae2e0e61f81faeb"
                             "type": "switch",
                             "name": "Robi",
                             "property": "BWM",
                             "rules": [
                                     "t": "true"
                                     "t": "false"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 1050,
                             "y": 260,
                             "wires": [
                                     "ae8ceff406113f11"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "stopp",
                                     "pt": "flow",
                                     "to": "true",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 890,
                             "y": 600,
                             "wires": [
                             "type": "change",
                             "z": "b802892eed83e90f",
                             "rules": [
                                     "t": "set",
                                     "p": "stopp",
                                     "pt": "flow",
                                     "to": "false",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1370,
                             "y": 600,
                             "wires": [
                             "type": "function",
                             "name": "Variablen Ini + Ausgabe",
                             "outputs": 1,
                             "timeout": 0,
                             "noerr": 0,
                             "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\nflow.set(\"bewegung\", false);\n",
                             "finalize": "",
                             "libs": [],
                             "x": 1770,
                             "y": 380,
                             "wires": [
                                     "ed06e85de97289c8",
                                     "423ea0f1dc0e4d31"
                             "name": "Robi",
                             "onlyack": "",
                             "func": "all",
                             "gap": "",
                             "x": 90,
                             "y": 780,
                             "wires": [
                                     "6b214a0a59b5e04a"
                             "type": "function",
                             "name": "Ausgang BWM",
                             "outputs": 1,
                             "timeout": 0,
                             "noerr": 0,
                             "initialize": "",
                             "finalize": "",
                             "libs": [],
                             "x": 360,
                             "y": 360,
                             "wires": [
                                     "0395e4bbb7c67e21"
                             "onlyack": "",
                             "func": "all",
                             "gap": "",
                             "x": 100,
                             "y": 680,
                             "wires": [
                                     "e22b60db6265e908"
                             "type": "switch",
                             "name": "8?",
                             "rules": [
                                     "t": "eq",
                                     "v": "8",
                                     "vt": "num"
                                     "t": "neq",
                                     "v": "8",
                                     "vt": "num"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 630,
                             "y": 780,
                             "wires": [
                                     "7b9c0fa6e795af2d"
                                     "ccadbb1ee1de29e6"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "BWM",
                                     "pt": "flow",
                                     "to": "true",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 850,
                             "y": 760,
                             "wires": [
                                     "b117dac109d51b34"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "BWM",
                                     "pt": "flow",
                                     "to": "false",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 850,
                             "y": 800,
                             "wires": [
                                     "b117dac109d51b34"
                             "type": "comment",
                             "info": "",
                             "x": 980,
                             "y": 220,
                             "wires": []
                             "type": "switch",
                             "name": "nur true",
                             "rules": [
                                     "t": "true"
                                     "t": "false"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 740,
                             "y": 240,
                             "wires": [
                                     "ab41883686b27cc0"
                             "type": "debug",
                             "name": "debug 4",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "complete": "true",
                             "statusVal": "",
                             "x": 1040,
                             "y": 760,
                             "wires": []
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "change",
                                     "p": "payload",
                                     "pt": "msg",
                                     "from": "on",
                                     "fromt": "str",
                                     "to": "true",
                                     "tot": "bool"
                                     "t": "change",
                                     "p": "payload",
                                     "pt": "msg",
                                     "from": "off",
                                     "fromt": "str",
                                     "to": "false",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1290,
                             "y": 400,
                             "wires": [
                                     "d303b6e1817d8b77"
                             "type": "switch",
                             "name": "",
                             "rules": [
                                     "t": "true"
                                     "t": "false"
                                     "t": "eq",
                                     "v": "",
                                     "vt": "str"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 3,
                             "x": 1470,
                             "y": 400,
                             "wires": [
                                     "331a07cfba2d7df1"
                                     "331a07cfba2d7df1",
                                     "574a9f7ddc4f663b"
                             "type": "switch",
                             "name": "",
                             "rules": [
                                     "t": "true"
                                     "t": "false"
                                     "t": "eq",
                                     "v": "",
                                     "vt": "str"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 3,
                             "x": 1770,
                             "y": 260,
                             "wires": [
                                     "331a07cfba2d7df1"
                                     "331a07cfba2d7df1"
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "change",
                                     "p": "payload",
                                     "pt": "msg",
                                     "from": "on",
                                     "fromt": "str",
                                     "to": "true",
                                     "tot": "bool"
                                     "t": "change",
                                     "p": "payload",
                                     "pt": "msg",
                                     "from": "off",
                                     "fromt": "str",
                                     "to": "false",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1610,
                             "y": 260,
                             "wires": [
                                     "b4e55cb04c30244e"
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "on",
                                     "tot": "str"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1250,
                             "y": 260,
                             "wires": [
                                     "fa5f2b5bcd258a98"
                             "x": 500,
                             "y": 660,
                             "wires": [
                                     "cf3016a536d38a8d"
                             "type": "switch",
                             "rules": [
                                     "t": "false"
                                     "t": "true"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 680,
                             "y": 660,
                             "wires": [
                                     "7eea52e80cbe51f0",
                                     "93f0d4c85ab42e59"
                                     "7b9c0fa6e795af2d",
                                     "87ec46662c49de4e",
                                     "f00e20abd94ff43d"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "false",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1380,
                             "y": 640,
                             "wires": [
                                     "331a07cfba2d7df1"
                             "type": "change",
                             "name": "stop",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "stop",
                                     "tot": "str"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1010,
                             "y": 640,
                             "wires": [
                                     "d96f128a59bdfbb4"
                             "name": "45sek",
                             "outtopic": "",
                             "outsafe": "on",
                             "outunsafe": "off",
                             "warning": "10",
                             "timer": "60",
                             "debug": false,
                             "ndebug": false,
                             "repeat": false,
                             "again": false,
                             "x": 1090,
                             "y": 400,
                             "wires": [
                                     "91febc7692f9b822"
                             "name": "10Sek",
                             "outtopic": "",
                             "outsafe": "on",
                             "outunsafe": "off",
                             "warning": "10",
                             "timer": "30",
                             "debug": false,
                             "ndebug": false,
                             "repeat": false,
                             "again": false,
                             "x": 1430,
                             "y": 260,
                             "wires": [
                                     "90c9685b4a5344dc"
                             "name": "U-rechts",
                             "ack": "false",
                             "stateName": "",
                             "role": "",
                             "payloadType": "",
                             "readonly": "",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 2140,
                             "y": 600,
                             "wires": []
                             "ack": "false",
                             "stateName": "",
                             "role": "",
                             "payloadType": "",
                             "readonly": "",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 2210,
                             "y": 460,
                             "wires": []
                             "ack": "false",
                             "autoCreate": "true",
                             "stateName": "Simlulierte Lampe",
                             "role": "value",
                             "payloadType": "boolean",
                             "readonly": "",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 2160,
                             "y": 540,
                             "wires": []
                             "type": "debug",
                             "name": "Küche",
                             "active": false,
                             "tosidebar": true,
                             "console": true,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 2160,
                             "y": 760,
                             "wires": []
                             "type": "delay",
                             "name": "100ms",
                             "timeout": "100",
                             "rate": "1",
                             "nbRateUnits": "1",
                             "randomFirst": "1",
                             "randomLast": "5",
                             "drop": false,
                             "allowrate": false,
                             "outputs": 1,
                             "x": 2070,
                             "y": 460,
                             "wires": [
                                     "084e7114b7ed1c61"
                             "type": "change",
                             "name": "Küche",
                             "rules": [
                                     "t": "change",
                                     "p": "payload",
                                     "pt": "msg",
                                     "from": "1000",
                                     "fromt": "str",
                                     "to": "Küche",
                                     "tot": "str"
                                     "t": "change",
                                     "p": "payload",
                                     "pt": "msg",
                                     "from": "true",
                                     "fromt": "bool",
                                     "tot": "str"
                                     "t": "change",
                                     "p": "payload",
                                     "pt": "msg",
                                     "from": "false",
                                     "fromt": "bool",
                                     "tot": "str"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 2030,
                             "y": 760,
                             "wires": [
                                     "442c2ef743d9599f"
                             "name": "U-links",
                             "ack": "false",
                             "stateName": "",
                             "role": "",
                             "payloadType": "",
                             "readonly": "",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 2130,
                             "y": 680,
                             "wires": []
                             "name": "Hue",
                             "x": 130,
                             "y": 160,
                             "wires": [
                                     "2e0c2a67486c0ac7"
                             "initevents": true,
                             "x": 360,
                             "y": 160,
                             "wires": [
                                     "0395e4bbb7c67e21"
                             "type": "inject",
                             "name": "Takt",
                             "props": [
                                     "p": "payload"
                                     "p": "topic",
                                     "vt": "str"
                             "repeat": "1",
                             "crontab": "",
                             "once": true,
                             "onceDelay": 0.1,
                             "topic": "Takt",
                             "payload": "true",
                             "x": 130,
                             "y": 60,
                             "wires": [
                                     "26a06677287b879b"
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "bewegung",
                                     "tot": "flow"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 370,
                             "y": 60,
                             "wires": [
                                     "9c7c62ee37b6b12c"
                             "type": "inject",
                             "props": [
                                     "p": "payload"
                                     "p": "topic",
                                     "vt": "str"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "1000",
                             "payloadType": "num",
                             "x": 130,
                             "y": 520,
                             "wires": [
                                     "64bf8df5efc25d40",
                                     "f3921b2658b5916c"
                             "type": "change",
                             "rules": [
                                     "t": "set",
                                     "p": "bewegung",
                                     "pt": "flow",
                                     "to": "false",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1390,
                             "y": 680,
                             "wires": [
                             "type": "comment",
                             "name": "Ende << Für Simulation Für Simulation Für Simulation Für Simulation >>",
                             "info": "",
                             "x": 270,
                             "y": 580,
                             "wires": []
                             "type": "comment",
                             "info": "",
                             "x": 980,
                             "y": 320,
                             "wires": []
                             "id": "64bf8df5efc25d40",
                             "type": "delay",
                             "name": "200 ms",
                             "timeout": "200",
                             "rate": "1",
                             "nbRateUnits": "1",
                             "randomFirst": "1",
                             "randomLast": "5",
                             "drop": false,
                             "allowrate": false,
                             "outputs": 1,
                             "x": 300,
                             "y": 520,
                             "wires": [
                                     "d628f1137cfb08c1"
                             "id": "d628f1137cfb08c1",
                             "type": "change",
                             "name": "1002",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "1002",
                                     "tot": "num"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 430,
                             "y": 520,
                             "wires": [
                                     "8355cf791b8a8b1b"
                             "id": "9a70fab410cfbdae",
                             "type": "inject",
                             "name": "Test Robi 8",
                             "props": [
                                     "p": "payload"
                                     "p": "topic",
                                     "vt": "str"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "8",
                             "x": 120,
                             "y": 840,
                             "wires": [
                                     "6b214a0a59b5e04a"
                             "id": "10a3703ea5e9c5fd",
                             "type": "inject",
                             "name": "Test Robi 5",
                             "props": [
                                     "p": "payload"
                                     "p": "topic",
                                     "vt": "str"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "5",
                             "x": 120,
                             "y": 900,
                             "wires": [
                                     "6b214a0a59b5e04a"
                             "worker": "10",
                             "autoupdates": true,
                      Peterfido
                      AphofisA 1 Antwort Letzte Antwort
                      • P peterfido
                        Eine Idee:
                               "id": "b802892eed83e90f",
                               "type": "tab",
                               "label": "Flow 8",
                               "disabled": false,
                               "info": "",
                               "env": []
                               "id": "f00e20abd94ff43d",
                               "type": "junction",
                               "x": 1120,
                               "y": 660,
                               "wires": [
                                       "141a052859674836",
                                       "574a9f7ddc4f663b",
                                       "b6322a40cf4557b3"
                               "id": "423ea0f1dc0e4d31",
                               "type": "junction",
                               "x": 1960,
                               "y": 460,
                               "wires": [
                                       "ff32f89078260f0e",
                                       "67e2e01a1266d1c3",
                                       "e98816534075b0f5",
                                       "21f36ea2695afe19",
                                       "a695276a00fe8f61"
                               "type": "junction",
                               "x": 1140,
                               "y": 260,
                               "wires": [
                                       "ba0aea0ff71ebc3d"
                               "type": "junction",
                               "x": 520,
                               "y": 60,
                               "wires": [
                                       "d24a5429e472b18a"
                               "type": "junction",
                               "x": 900,
                               "y": 440,
                               "wires": [
                                       "84bd4ea1d044fea4",
                                       "ed2607cafe826532"
                               "type": "junction",
                               "x": 980,
                               "y": 360,
                               "wires": [
                                       "be66da991b562e24"
                               "type": "junction",
                               "x": 1280,
                               "y": 360,
                               "wires": [
                                       "fa5f2b5bcd258a98"
                               "type": "junction",
                               "x": 580,
                               "y": 560,
                               "wires": [
                                       "e22b60db6265e908"
                               "type": "junction",
                               "x": 580,
                               "y": 560,
                               "wires": [
                                       "e22b60db6265e908"
                               "type": "junction",
                               "x": 240,
                               "y": 560,
                               "wires": [
                                       "1ee1fe89c1628b34"
                               "id": "a2104cdffd7ca75f",
                               "type": "inject",
                               "props": [
                                       "v": "true",
                                       "vt": "bool"
                                       "p": "topic",
                                       "vt": "str"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "x": 140,
                               "y": 380,
                               "wires": [
                                       "a919a4c30d900c39",
                                       "0150c15cf7b51170"
                               "id": "ed06e85de97289c8",
                               "type": "debug",
                               "name": "debug 3",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "true",
                               "statusVal": "",
                               "x": 2000,
                               "y": 360,
                               "wires": []
                               "id": "a919a4c30d900c39",
                               "type": "delay",
                               "name": "",
                               "timeout": "30",
                               "rate": "1",
                               "nbRateUnits": "1",
                               "randomFirst": "1",
                               "randomLast": "5",
                               "drop": false,
                               "allowrate": false,
                               "outputs": 1,
                               "x": 150,
                               "y": 460,
                               "wires": [
                                       "bee64eb116d76ed1"
                               "id": "bee64eb116d76ed1",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "pt": "msg",
                                       "to": "false",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 350,
                               "y": 460,
                               "wires": [
                                       "0150c15cf7b51170"
                               "id": "ab41883686b27cc0",
                               "type": "switch",
                               "name": "Schalter",
                               "rules": [
                                       "t": "true"
                                       "t": "false"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 920,
                               "y": 260,
                               "wires": [
                                       "01fea99b98c641a3"
                               "id": "0395e4bbb7c67e21",
                               "type": "change",
                               "name": "Motion",
                               "rules": [
                                       "t": "set",
                                       "p": "bewegung",
                                       "pt": "flow",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 670,
                               "y": 320,
                               "wires": [
                               "id": "59792b228df9eb30",
                               "type": "comment",
                               "info": "",
                               "x": 280,
                               "y": 300,
                               "wires": []
                               "id": "93f0d4c85ab42e59",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "on",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 710,
                               "y": 400,
                               "wires": [
                                       "ed2607cafe826532"
                               "id": "e22b60db6265e908",
                               "type": "switch",
                               "name": "1000?",
                               "rules": [
                                       "t": "eq",
                                       "v": "1000",
                                       "vt": "num"
                                       "t": "eq",
                                       "v": "",
                                       "vt": "num"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 310,
                               "y": 660,
                               "wires": [
                                       "6ae2e0e61f81faeb"
                               "id": "01fea99b98c641a3",
                               "type": "switch",
                               "name": "Robi",
                               "property": "BWM",
                               "rules": [
                                       "t": "true"
                                       "t": "false"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 1050,
                               "y": 260,
                               "wires": [
                                       "ae8ceff406113f11"
                               "id": "7eea52e80cbe51f0",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "stopp",
                                       "pt": "flow",
                                       "to": "true",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 890,
                               "y": 600,
                               "wires": [
                               "id": "574a9f7ddc4f663b",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "stopp",
                                       "pt": "flow",
                                       "to": "false",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1370,
                               "y": 600,
                               "wires": [
                               "id": "331a07cfba2d7df1",
                               "type": "function",
                               "outputs": 1,
                               "timeout": 0,
                               "noerr": 0,
                               "finalize": "",
                               "libs": [],
                               "x": 1770,
                               "y": 380,
                               "wires": [
                                       "ed06e85de97289c8",
                                       "423ea0f1dc0e4d31"
                               "id": "b9692c9131fb2ef5",
                               "name": "Robi",
                               "topic": "mihome-vacuum.0.info.state",
                               "onlyack": "",
                               "func": "all",
                               "gap": "",
                               "x": 90,
                               "y": 780,
                               "wires": [
                                       "6b214a0a59b5e04a"
                               "id": "0150c15cf7b51170",
                               "type": "function",
                               "outputs": 1,
                               "timeout": 0,
                               "noerr": 0,
                               "initialize": "",
                               "finalize": "",
                               "libs": [],
                               "x": 360,
                               "y": 360,
                               "wires": [
                                       "0395e4bbb7c67e21"
                               "id": "b6b4c157c31e3701",
                               "name": "KüSchalter",
                               "topic": "hue.0.Hue_GordonX.Küche_Schalter.buttonevent",
                               "onlyack": "",
                               "func": "all",
                               "gap": "",
                               "x": 100,
                               "y": 680,
                               "wires": [
                                       "e22b60db6265e908"
                               "id": "6b214a0a59b5e04a",
                               "type": "switch",
                               "name": "8?",
                               "rules": [
                                       "t": "eq",
                                       "v": "8",
                                       "vt": "num"
                                       "t": "neq",
                                       "v": "8",
                                       "vt": "num"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 630,
                               "y": 780,
                               "wires": [
                                       "7b9c0fa6e795af2d"
                                       "ccadbb1ee1de29e6"
                               "id": "7b9c0fa6e795af2d",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "BWM",
                                       "pt": "flow",
                                       "to": "true",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 850,
                               "y": 760,
                               "wires": [
                                       "b117dac109d51b34"
                               "id": "ccadbb1ee1de29e6",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "BWM",
                                       "pt": "flow",
                                       "to": "false",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 850,
                               "y": 800,
                               "wires": [
                                       "b117dac109d51b34"
                               "id": "558db419c5c37cca",
                               "type": "comment",
                               "info": "",
                               "x": 980,
                               "y": 220,
                               "wires": []
                               "id": "d24a5429e472b18a",
                               "type": "switch",
                               "name": "nur true",
                               "rules": [
                                       "t": "true"
                                       "t": "false"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 740,
                               "y": 240,
                               "wires": [
                                       "ab41883686b27cc0"
                               "id": "b117dac109d51b34",
                               "type": "debug",
                               "name": "debug 4",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "true",
                               "statusVal": "",
                               "x": 1040,
                               "y": 760,
                               "wires": []
                               "id": "91febc7692f9b822",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "change",
                                       "p": "payload",
                                       "pt": "msg",
                                       "from": "on",
                                       "fromt": "str",
                                       "to": "true",
                                       "tot": "bool"
                                       "t": "change",
                                       "p": "payload",
                                       "pt": "msg",
                                       "from": "off",
                                       "fromt": "str",
                                       "to": "false",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1290,
                               "y": 400,
                               "wires": [
                                       "d303b6e1817d8b77"
                               "id": "d303b6e1817d8b77",
                               "type": "switch",
                               "name": "",
                               "rules": [
                                       "t": "true"
                                       "t": "false"
                                       "t": "eq",
                                       "v": "",
                                       "vt": "str"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 3,
                               "x": 1470,
                               "y": 400,
                               "wires": [
                                       "331a07cfba2d7df1"
                                       "331a07cfba2d7df1",
                                       "574a9f7ddc4f663b"
                               "id": "b4e55cb04c30244e",
                               "type": "switch",
                               "name": "",
                               "rules": [
                                       "t": "true"
                                       "t": "false"
                                       "t": "eq",
                                       "v": "",
                                       "vt": "str"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 3,
                               "x": 1770,
                               "y": 260,
                               "wires": [
                                       "331a07cfba2d7df1"
                                       "331a07cfba2d7df1"
                               "id": "90c9685b4a5344dc",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "change",
                                       "p": "payload",
                                       "pt": "msg",
                                       "from": "on",
                                       "fromt": "str",
                                       "to": "true",
                                       "tot": "bool"
                                       "t": "change",
                                       "p": "payload",
                                       "pt": "msg",
                                       "from": "off",
                                       "fromt": "str",
                                       "to": "false",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1610,
                               "y": 260,
                               "wires": [
                                       "b4e55cb04c30244e"
                               "id": "ba0aea0ff71ebc3d",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "on",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1250,
                               "y": 260,
                               "wires": [
                                       "fa5f2b5bcd258a98"
                               "id": "6ae2e0e61f81faeb",
                               "name": "Virtuelle Lampe",
                               "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_1",
                               "x": 500,
                               "y": 660,
                               "wires": [
                                       "cf3016a536d38a8d"
                               "id": "cf3016a536d38a8d",
                               "type": "switch",
                               "rules": [
                                       "t": "false"
                                       "t": "true"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 680,
                               "y": 660,
                               "wires": [
                                       "7eea52e80cbe51f0",
                                       "93f0d4c85ab42e59"
                                       "7b9c0fa6e795af2d",
                                       "87ec46662c49de4e",
                                       "f00e20abd94ff43d"
                               "id": "141a052859674836",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "false",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1380,
                               "y": 640,
                               "wires": [
                                       "331a07cfba2d7df1"
                               "id": "87ec46662c49de4e",
                               "type": "change",
                               "name": "stop",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "stop",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1010,
                               "y": 640,
                               "wires": [
                                       "d96f128a59bdfbb4"
                               "id": "ed2607cafe826532",
                               "name": "45sek",
                               "outtopic": "",
                               "outsafe": "on",
                               "outunsafe": "off",
                               "warning": "10",
                               "timer": "60",
                               "debug": false,
                               "ndebug": false,
                               "repeat": false,
                               "again": false,
                               "x": 1090,
                               "y": 400,
                               "wires": [
                                       "91febc7692f9b822"
                               "id": "fa5f2b5bcd258a98",
                               "name": "10Sek",
                               "outtopic": "",
                               "outsafe": "on",
                               "outunsafe": "off",
                               "warning": "10",
                               "timer": "30",
                               "debug": false,
                               "ndebug": false,
                               "repeat": false,
                               "again": false,
                               "x": 1430,
                               "y": 260,
                               "wires": [
                                       "90c9685b4a5344dc"
                               "id": "21f36ea2695afe19",
                               "name": "U-rechts",
                               "topic": "tuya.0.bfb09eea5dad3699abyrbu.20",
                               "ack": "false",
                               "autoCreate": "false",
                               "stateName": "",
                               "role": "",
                               "payloadType": "",
                               "readonly": "",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 2140,
                               "y": 600,
                               "wires": []
                               "id": "084e7114b7ed1c61",
                               "name": "Küche Decke",
                               "topic": "tuya.0.bfe4af976feb74d845vugp.1",
                               "ack": "false",
                               "stateName": "",
                               "role": "",
                               "payloadType": "",
                               "readonly": "",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 2210,
                               "y": 460,
                               "wires": []
                               "id": "ff32f89078260f0e",
                               "name": "Virtuel Switch 1",
                               "ack": "false",
                               "role": "value",
                               "readonly": "",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 2160,
                               "y": 540,
                               "wires": []
                               "id": "442c2ef743d9599f",
                               "type": "debug",
                               "name": "Küche",
                               "active": false,
                               "tosidebar": true,
                               "console": true,
                               "tostatus": false,
                               "complete": "payload",
                               "targetType": "msg",
                               "statusVal": "",
                               "x": 2160,
                               "y": 760,
                               "wires": []
                               "id": "67e2e01a1266d1c3",
                               "type": "delay",
                               "name": "100ms",
                               "timeout": "100",
                               "timeoutUnits": "milliseconds",
                               "rate": "1",
                               "nbRateUnits": "1",
                               "randomFirst": "1",
                               "randomLast": "5",
                               "drop": false,
                               "allowrate": false,
                               "outputs": 1,
                               "x": 2070,
                               "y": 460,
                               "wires": [
                                       "084e7114b7ed1c61"
                               "id": "e98816534075b0f5",
                               "type": "change",
                               "name": "Küche",
                               "rules": [
                                       "t": "change",
                                       "p": "payload",
                                       "pt": "msg",
                                       "from": "1000",
                                       "fromt": "str",
                                       "to": "Küche",
                                       "tot": "str"
                                       "t": "change",
                                       "p": "payload",
                                       "pt": "msg",
                                       "from": "true",
                                       "fromt": "bool",
                                       "to": "Küche eingeschaltet",
                                       "tot": "str"
                                       "t": "change",
                                       "p": "payload",
                                       "pt": "msg",
                                       "from": "false",
                                       "fromt": "bool",
                                       "to": "Küche ausgeschaltet",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 2030,
                               "y": 760,
                               "wires": [
                                       "442c2ef743d9599f"
                               "id": "a695276a00fe8f61",
                               "name": "U-links",
                               "topic": "hue.0.Hue_GordonX.Küche_Unterschr_Links.on",
                               "ack": "false",
                               "stateName": "",
                               "role": "",
                               "payloadType": "",
                               "readonly": "",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 2130,
                               "y": 680,
                               "wires": []
                               "id": "802770af38c8534e",
                               "type": "hue-bridge-node",
                               "name": "Hue",
                               "bridge": "cbd54dbabf6f65be",
                               "skipglobalevents": false,
                               "initevents": false,
                               "x": 130,
                               "y": 160,
                               "wires": [
                                       "2e0c2a67486c0ac7"
                               "id": "2e0c2a67486c0ac7",
                               "type": "hue-motion",
                               "name": "Küche Motion Sensor",
                               "sensorid": "7529c8d8-9f5c-451d-ba56-70cacda84564",
                               "skipevents": false,
                               "initevents": true,
                               "x": 360,
                               "y": 160,
                               "wires": [
                                       "0395e4bbb7c67e21"
                               "type": "inject",
                               "name": "Takt",
                               "props": [
                                       "p": "payload"
                                       "p": "topic",
                                       "vt": "str"
                               "repeat": "1",
                               "crontab": "",
                               "once": true,
                               "onceDelay": 0.1,
                               "topic": "Takt",
                               "payload": "true",
                               "x": 130,
                               "y": 60,
                               "wires": [
                                       "26a06677287b879b"
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "bewegung",
                                       "tot": "flow"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 370,
                               "y": 60,
                               "wires": [
                                       "9c7c62ee37b6b12c"
                               "type": "inject",
                               "props": [
                                       "p": "payload"
                                       "p": "topic",
                                       "vt": "str"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "1000",
                               "x": 130,
                               "y": 520,
                               "wires": [
                                       "64bf8df5efc25d40",
                                       "f3921b2658b5916c"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "bewegung",
                                       "pt": "flow",
                                       "to": "false",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1390,
                               "y": 680,
                               "wires": [
                               "type": "comment",
                               "info": "",
                               "x": 270,
                               "y": 580,
                               "wires": []
                               "type": "comment",
                               "info": "",
                               "x": 980,
                               "y": 320,
                               "wires": []
                               "type": "delay",
                               "name": "200 ms",
                               "timeout": "200",
                               "rate": "1",
                               "nbRateUnits": "1",
                               "randomFirst": "1",
                               "randomLast": "5",
                               "drop": false,
                               "allowrate": false,
                               "outputs": 1,
                               "x": 300,
                               "y": 520,
                               "wires": [
                                       "d628f1137cfb08c1"
                               "type": "change",
                               "name": "1002",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "1002",
                                       "tot": "num"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 430,
                               "y": 520,
                               "wires": [
                                       "8355cf791b8a8b1b"
                               "type": "inject",
                               "props": [
                                       "p": "payload"
                                       "p": "topic",
                                       "vt": "str"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "8",
                               "x": 120,
                               "y": 840,
                               "wires": [
                                       "6b214a0a59b5e04a"
                               "type": "inject",
                               "props": [
                                       "p": "payload"
                                       "p": "topic",
                                       "vt": "str"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "5",
                               "x": 120,
                               "y": 900,
                               "wires": [
                                       "6b214a0a59b5e04a"
                               "id": "cbd54dbabf6f65be",
                               "type": "hue-bridge",
                               "name": "Hue GordonX",
                               "bridge": "192.168.0.8",
                               "key": "SlfyXwpcaEvRN0d1DU2JrrOlwrm9Debhhm9A4E-d",
                               "worker": "10",
                               "disableupdates": false
                        AphofisA Offline
                        AphofisA Offline
                        Aphofis
                        schrieb am zuletzt editiert von Aphofis
                        @peterfido
                        Also soweit funktionierts nur irgend etwas schaltet mitten drin nach klick schalter die lampen ab
                        hab schon paar debug nodes angehängt finde aber nicht wer das macht.
                        Wenn man nach der selbst abschaltung dann in den BWM läuft geht das licht wieder an.
                        Wenn man also schalter schaltet geht das licht nach paar sekunden alleine aus und es kommt keine debug ausgabe. geht man in den BWM gehts licht wieder an und bleibt auch für eingestellte zeit an und bei wiederbewegung blitzt das licht einmal kurz und ist dann aber wieder an.
                        BWM / Roboter Sauger funktioniert soweit.
                                "id": "cd388a27e1177b2a",
                                "type": "tab",
                                "label": "Flow 8",
                                "disabled": false,
                                "info": "",
                                "env": []
                                "id": "c858be985d04ff23",
                                "type": "junction",
                                "z": "cd388a27e1177b2a",
                                "x": 680,
                                "y": 560,
                                "wires": [
                                        "e52cacfb28f4eef0",
                                        "d4243e5842d002b7",
                                        "f4dd19c85bec8f67"
                                "id": "49ed5c100ffadbfb",
                                "type": "junction",
                                "x": 1060,
                                "y": 600,
                                "wires": [
                                        "3da3568f5cb1d905",
                                        "d9b21aa55e80ae44",
                                        "c9f5b344739be161",
                                        "a0d644333024864d"
                                "id": "6b29472d446bd70a",
                                "type": "junction",
                                "x": 680,
                                "y": 320,
                                "wires": [
                                        "1f6129972520dbc9",
                                        "2cf7c09b18238747"
                                "id": "97a52cd45dee491f",
                                "type": "junction",
                                "x": 1060,
                                "y": 460,
                                "wires": [
                                        "49ed5c100ffadbfb"
                                "id": "17a82c94f393c061",
                                "type": "junction",
                                "x": 160,
                                "y": 520,
                                "wires": [
                                        "34daca3383213026"
                                "id": "f2c58fd53288296d",
                                "type": "debug",
                                "name": "debug 3",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "statusVal": "",
                                "x": 1400,
                                "y": 420,
                                "wires": []
                                "id": "25ad2bdbb9a6a3f2",
                                "type": "change",
                                "rules": [
                                        "t": "set",
                                        "pt": "msg",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 310,
                                "y": 420,
                                "wires": [
                                        "c5344e2d70758330"
                                "id": "6fa8c560705cd84b",
                                "type": "switch",
                                "name": "Schalter",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 560,
                                "y": 280,
                                "wires": [
                                        "e5b4dd5e0fdf55b3"
                                "id": "7cade0980ce23b6f",
                                "type": "change",
                                "name": "Motion",
                                "rules": [
                                        "t": "set",
                                        "p": "bewegung",
                                        "pt": "flow",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 470,
                                "y": 320,
                                "wires": [
                                "id": "1d02d4d287c62d8d",
                                "type": "change",
                                "name": "set payload",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "on",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 610,
                                "y": 360,
                                "wires": [
                                        "1f6129972520dbc9"
                                "id": "edd034e0ac4e9dbd",
                                "type": "switch",
                                "name": "1000?",
                                "rules": [
                                        "t": "eq",
                                        "v": "1000",
                                        "vt": "num"
                                        "t": "eq",
                                        "v": "",
                                        "vt": "num"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 230,
                                "y": 460,
                                "wires": [
                                        "b3cf3d5c5932a0f1"
                                "id": "e5b4dd5e0fdf55b3",
                                "type": "switch",
                                "name": "Robi",
                                "property": "BWM",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 690,
                                "y": 280,
                                "wires": [
                                        "eb53173feca16754"
                                "id": "6ad2e1e41e7eba3d",
                                "type": "change",
                                "name": "setze stopp",
                                "rules": [
                                        "t": "set",
                                        "p": "stopp",
                                        "pt": "flow",
                                        "to": "true",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 630,
                                "y": 460,
                                "wires": [
                                "id": "d4243e5842d002b7",
                                "type": "change",
                                "name": "lösche stopp",
                                "rules": [
                                        "t": "set",
                                        "p": "stopp",
                                        "pt": "flow",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 830,
                                "y": 560,
                                "wires": [
                                "id": "0649103700725132",
                                "type": "function",
                                "outputs": 1,
                                "timeout": 0,
                                "noerr": 0,
                                "finalize": "",
                                "libs": [],
                                "x": 1170,
                                "y": 420,
                                "wires": [
                                        "f2c58fd53288296d",
                                        "97a52cd45dee491f"
                                "id": "5b195fc1f7acb5c0",
                                "name": "Robi",
                                "onlyack": "",
                                "func": "all",
                                "gap": "",
                                "x": 110,
                                "y": 600,
                                "wires": [
                                        "7f79db16bb82a357"
                                "id": "c5344e2d70758330",
                                "type": "function",
                                "outputs": 1,
                                "timeout": 0,
                                "noerr": 0,
                                "initialize": "",
                                "finalize": "",
                                "libs": [],
                                "x": 300,
                                "y": 380,
                                "wires": [
                                        "7cade0980ce23b6f"
                                "id": "d4e6916ec6660771",
                                "onlyack": "",
                                "func": "all",
                                "gap": "",
                                "x": 80,
                                "y": 460,
                                "wires": [
                                        "edd034e0ac4e9dbd"
                                "id": "7f79db16bb82a357",
                                "type": "switch",
                                "name": "8?",
                                "rules": [
                                        "t": "eq",
                                        "v": "8",
                                        "vt": "num"
                                        "t": "neq",
                                        "v": "8",
                                        "vt": "num"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 230,
                                "y": 600,
                                "wires": [
                                        "34daca3383213026"
                                        "9725d7651f53e931"
                                "id": "34daca3383213026",
                                "type": "change",
                                "rules": [
                                        "t": "set",
                                        "p": "BWM",
                                        "pt": "flow",
                                        "to": "true",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 410,
                                "y": 580,
                                "wires": [
                                        "3d95821769504d11"
                                "id": "9725d7651f53e931",
                                "type": "change",
                                "rules": [
                                        "t": "set",
                                        "p": "BWM",
                                        "pt": "flow",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 410,
                                "y": 620,
                                "wires": [
                                        "3d95821769504d11"
                                "id": "6a9e975c8a2cb22e",
                                "type": "switch",
                                "name": "nur true",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 420,
                                "y": 280,
                                "wires": [
                                        "6fa8c560705cd84b"
                                "id": "3d95821769504d11",
                                "type": "debug",
                                "name": "debug 4",
                                "active": false,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "statusVal": "",
                                "x": 580,
                                "y": 600,
                                "wires": []
                                "id": "19d59c4b02bc1d4e",
                                "type": "change",
                                "name": "true/on/false/off",
                                "rules": [
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "on",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "off",
                                        "fromt": "str",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 820,
                                "y": 440,
                                "wires": [
                                        "2b6788c8f61bc75d"
                                "id": "2b6788c8f61bc75d",
                                "type": "switch",
                                "name": "",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                        "t": "eq",
                                        "v": "",
                                        "vt": "str"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 3,
                                "x": 830,
                                "y": 500,
                                "wires": [
                                        "0649103700725132",
                                        "22f763e23b4b426d"
                                        "0649103700725132",
                                        "d4243e5842d002b7",
                                        "078d3cdea12da58a"
                                "id": "81379b4c78eb5084",
                                "type": "switch",
                                "name": "",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                        "t": "eq",
                                        "v": "",
                                        "vt": "str"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 3,
                                "x": 970,
                                "y": 380,
                                "wires": [
                                        "0649103700725132",
                                        "cada2da2ed2bfaf6"
                                        "0649103700725132",
                                        "c38db948a076700c"
                                "id": "6d74347a2369c9b1",
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "on",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "off",
                                        "fromt": "str",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 970,
                                "y": 320,
                                "wires": [
                                        "81379b4c78eb5084"
                                "id": "eb53173feca16754",
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "on",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 850,
                                "y": 280,
                                "wires": [
                                        "2cf7c09b18238747"
                                "id": "b3cf3d5c5932a0f1",
                                "name": "Virt Lampe",
                                "x": 330,
                                "y": 520,
                                "wires": [
                                        "fe9075ec01f6e19a"
                                "id": "fe9075ec01f6e19a",
                                "type": "switch",
                                "name": "true false",
                                "rules": [
                                        "t": "false"
                                        "t": "true"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 440,
                                "y": 460,
                                "wires": [
                                        "6ad2e1e41e7eba3d",
                                        "1d02d4d287c62d8d"
                                        "6fda00babbc6c3cf",
                                        "c858be985d04ff23",
                                        "17a82c94f393c061"
                                "id": "e52cacfb28f4eef0",
                                "type": "change",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 840,
                                "y": 600,
                                "wires": [
                                        "0649103700725132",
                                        "0e6b80937690ec94"
                                "id": "6fda00babbc6c3cf",
                                "type": "change",
                                "name": "stop",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "stop",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 610,
                                "y": 320,
                                "wires": [
                                        "6b29472d446bd70a"
                                "id": "1f6129972520dbc9",
                                "name": "45min",
                                "outtopic": "",
                                "outsafe": "on",
                                "outunsafe": "off",
                                "warning": "10",
                                "timer": "2700",
                                "debug": false,
                                "ndebug": false,
                                "repeat": false,
                                "again": false,
                                "x": 810,
                                "y": 380,
                                "wires": [
                                        "19d59c4b02bc1d4e"
                                "id": "2cf7c09b18238747",
                                "name": "3min",
                                "outtopic": "",
                                "outsafe": "on",
                                "outunsafe": "off",
                                "warning": "10",
                                "timer": "90",
                                "debug": false,
                                "ndebug": false,
                                "repeat": false,
                                "again": false,
                                "x": 810,
                                "y": 320,
                                "wires": [
                                        "6d74347a2369c9b1"
                                "id": "c9f5b344739be161",
                                "name": "U-rechts",
                                "ack": "false",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 1200,
                                "y": 600,
                                "wires": []
                                "id": "eb0a77e50a594126",
                                "ack": "false",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 1330,
                                "y": 480,
                                "wires": []
                                "id": "3da3568f5cb1d905",
                                "ack": "false",
                                "role": "value",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 1220,
                                "y": 540,
                                "wires": []
                                "id": "d9b21aa55e80ae44",
                                "type": "delay",
                                "name": "100ms",
                                "timeout": "100",
                                "rate": "1",
                                "nbRateUnits": "1",
                                "randomFirst": "1",
                                "randomLast": "5",
                                "drop": false,
                                "allowrate": false,
                                "outputs": 1,
                                "x": 1190,
                                "y": 480,
                                "wires": [
                                        "eb0a77e50a594126"
                                "id": "a0d644333024864d",
                                "name": "U-links",
                                "ack": "false",
                                "stateName": "",
                                "role": "",
                                "payloadType": "",
                                "readonly": "",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 1190,
                                "y": 660,
                                "wires": []
                                "id": "749bbf25ef1c6f5d",
                                "name": "Hue",
                                "x": 90,
                                "y": 320,
                                "wires": [
                                        "7e046925a0149339"
                                "id": "7e046925a0149339",
                                "initevents": true,
                                "x": 280,
                                "y": 320,
                                "wires": [
                                        "7cade0980ce23b6f"
                                "id": "6744591312f4367c",
                                "type": "inject",
                                "name": "Takt",
                                "props": [
                                        "p": "payload"
                                        "p": "topic",
                                        "vt": "str"
                                "repeat": "1",
                                "crontab": "",
                                "once": true,
                                "onceDelay": 0.1,
                                "topic": "Takt",
                                "payload": "true",
                                "payloadType": "bool",
                                "x": 90,
                                "y": 280,
                                "wires": [
                                        "19d0869e86da09b3"
                                "id": "19d0869e86da09b3",
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "bewegung",
                                        "tot": "flow"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 250,
                                "y": 280,
                                "wires": [
                                        "6a9e975c8a2cb22e"
                                "id": "f4dd19c85bec8f67",
                                "type": "change",
                                "name": "lösche bewegung",
                                "rules": [
                                        "t": "set",
                                        "p": "bewegung",
                                        "pt": "flow",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 850,
                                "y": 640,
                                "wires": [
                                "id": "14cbab0539105d58",
                                "type": "change",
                                "name": "1002",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "1000",
                                        "tot": "num"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 110,
                                "y": 380,
                                "wires": [
                                        "edd034e0ac4e9dbd"
                                "id": "cada2da2ed2bfaf6",
                                "type": "debug",
                                "name": "debug 8",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "false",
                                "statusVal": "",
                                "x": 1300,
                                "y": 280,
                                "wires": []
                                "id": "c38db948a076700c",
                                "type": "debug",
                                "name": "debug 17",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "statusVal": "",
                                "x": 1300,
                                "y": 320,
                                "wires": []
                                "id": "0e6b80937690ec94",
                                "type": "debug",
                                "name": "debug 18",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "statusVal": "",
                                "x": 1200,
                                "y": 800,
                                "wires": []
                                "id": "078d3cdea12da58a",
                                "type": "debug",
                                "name": "debug 19",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "statusVal": "",
                                "x": 1200,
                                "y": 760,
                                "wires": []
                                "id": "22f763e23b4b426d",
                                "type": "debug",
                                "name": "debug 20",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "statusVal": "",
                                "x": 1200,
                                "y": 720,
                                "wires": []
                                "worker": "10",
                        • AphofisA Aphofis
                          @peterfido
                                  "type": "tab",
                                  "label": "Flow 8",
                                  "disabled": false,
                                  "info": "",
                                  "env": []
                                  "type": "junction",
                                  "x": 680,
                                  "y": 560,
                                  "wires": [
                                          "e52cacfb28f4eef0",
                                          "d4243e5842d002b7",
                                          "f4dd19c85bec8f67"
                                  "type": "junction",
                                  "x": 1060,
                                  "y": 600,
                                  "wires": [
                                          "3da3568f5cb1d905",
                                          "d9b21aa55e80ae44",
                                          "c9f5b344739be161",
                                          "a0d644333024864d"
                                  "type": "junction",
                                  "x": 680,
                                  "y": 320,
                                  "wires": [
                                          "1f6129972520dbc9",
                                          "2cf7c09b18238747"
                                  "type": "junction",
                                  "x": 1060,
                                  "y": 460,
                                  "wires": [
                                          "49ed5c100ffadbfb"
                                  "type": "junction",
                                  "x": 160,
                                  "y": 520,
                                  "wires": [
                                          "34daca3383213026"
                                  "type": "debug",
                                  "name": "debug 3",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 1400,
                                  "y": 420,
                                  "wires": []
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "pt": "msg",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 310,
                                  "y": 420,
                                  "wires": [
                                          "c5344e2d70758330"
                                  "type": "switch",
                                  "name": "Schalter",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 560,
                                  "y": 280,
                                  "wires": [
                                          "e5b4dd5e0fdf55b3"
                                  "type": "change",
                                  "name": "Motion",
                                  "rules": [
                                          "t": "set",
                                          "p": "bewegung",
                                          "pt": "flow",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 470,
                                  "y": 320,
                                  "wires": [
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "on",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 610,
                                  "y": 360,
                                  "wires": [
                                          "1f6129972520dbc9"
                                  "type": "switch",
                                  "name": "1000?",
                                  "rules": [
                                          "t": "eq",
                                          "v": "1000",
                                          "vt": "num"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "num"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 230,
                                  "y": 460,
                                  "wires": [
                                          "b3cf3d5c5932a0f1"
                                  "type": "switch",
                                  "name": "Robi",
                                  "property": "BWM",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 690,
                                  "y": 280,
                                  "wires": [
                                          "eb53173feca16754"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "stopp",
                                          "pt": "flow",
                                          "to": "true",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 630,
                                  "y": 460,
                                  "wires": [
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "stopp",
                                          "pt": "flow",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 830,
                                  "y": 560,
                                  "wires": [
                                  "type": "function",
                                  "outputs": 1,
                                  "timeout": 0,
                                  "noerr": 0,
                                  "finalize": "",
                                  "libs": [],
                                  "x": 1170,
                                  "y": 420,
                                  "wires": [
                                          "f2c58fd53288296d",
                                          "97a52cd45dee491f"
                                  "name": "Robi",
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "x": 110,
                                  "y": 600,
                                  "wires": [
                                          "7f79db16bb82a357"
                                  "type": "function",
                                  "outputs": 1,
                                  "timeout": 0,
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 300,
                                  "y": 380,
                                  "wires": [
                                          "7cade0980ce23b6f"
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "x": 80,
                                  "y": 460,
                                  "wires": [
                                          "edd034e0ac4e9dbd"
                                  "type": "switch",
                                  "name": "8?",
                                  "rules": [
                                          "t": "eq",
                                          "v": "8",
                                          "vt": "num"
                                          "t": "neq",
                                          "v": "8",
                                          "vt": "num"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 230,
                                  "y": 600,
                                  "wires": [
                                          "34daca3383213026"
                                          "9725d7651f53e931"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "BWM",
                                          "pt": "flow",
                                          "to": "true",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 410,
                                  "y": 580,
                                  "wires": [
                                          "3d95821769504d11"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "BWM",
                                          "pt": "flow",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 410,
                                  "y": 620,
                                  "wires": [
                                          "3d95821769504d11"
                                  "type": "switch",
                                  "name": "nur true",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 420,
                                  "y": 280,
                                  "wires": [
                                          "6fa8c560705cd84b"
                                  "type": "debug",
                                  "name": "debug 4",
                                  "active": false,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 580,
                                  "y": 600,
                                  "wires": []
                                  "type": "change",
                                  "rules": [
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "on",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "off",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 820,
                                  "y": 440,
                                  "wires": [
                                          "2b6788c8f61bc75d"
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "str"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 3,
                                  "x": 830,
                                  "y": 500,
                                  "wires": [
                                          "0649103700725132",
                                          "22f763e23b4b426d"
                                          "0649103700725132",
                                          "d4243e5842d002b7",
                                          "078d3cdea12da58a"
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "str"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 3,
                                  "x": 970,
                                  "y": 380,
                                  "wires": [
                                          "0649103700725132",
                                          "cada2da2ed2bfaf6"
                                          "0649103700725132",
                                          "c38db948a076700c"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "on",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "off",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 970,
                                  "y": 320,
                                  "wires": [
                                          "81379b4c78eb5084"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "on",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 850,
                                  "y": 280,
                                  "wires": [
                                          "2cf7c09b18238747"
                                  "x": 330,
                                  "y": 520,
                                  "wires": [
                                          "fe9075ec01f6e19a"
                                  "type": "switch",
                                  "rules": [
                                          "t": "false"
                                          "t": "true"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 440,
                                  "y": 460,
                                  "wires": [
                                          "6ad2e1e41e7eba3d",
                                          "1d02d4d287c62d8d"
                                          "6fda00babbc6c3cf",
                                          "c858be985d04ff23",
                                          "17a82c94f393c061"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 840,
                                  "y": 600,
                                  "wires": [
                                          "0649103700725132",
                                          "0e6b80937690ec94"
                                  "type": "change",
                                  "name": "stop",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "stop",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 610,
                                  "y": 320,
                                  "wires": [
                                          "6b29472d446bd70a"
                                  "name": "45min",
                                  "outtopic": "",
                                  "outsafe": "on",
                                  "outunsafe": "off",
                                  "warning": "10",
                                  "timer": "2700",
                                  "debug": false,
                                  "ndebug": false,
                                  "repeat": false,
                                  "again": false,
                                  "x": 810,
                                  "y": 380,
                                  "wires": [
                                          "19d59c4b02bc1d4e"
                                  "name": "3min",
                                  "outtopic": "",
                                  "outsafe": "on",
                                  "outunsafe": "off",
                                  "warning": "10",
                                  "timer": "90",
                                  "debug": false,
                                  "ndebug": false,
                                  "repeat": false,
                                  "again": false,
                                  "x": 810,
                                  "y": 320,
                                  "wires": [
                                          "6d74347a2369c9b1"
                                  "name": "U-rechts",
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1200,
                                  "y": 600,
                                  "wires": []
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1330,
                                  "y": 480,
                                  "wires": []
                                  "ack": "false",
                                  "role": "value",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1220,
                                  "y": 540,
                                  "wires": []
                                  "type": "delay",
                                  "name": "100ms",
                                  "timeout": "100",
                                  "rate": "1",
                                  "nbRateUnits": "1",
                                  "randomFirst": "1",
                                  "randomLast": "5",
                                  "drop": false,
                                  "allowrate": false,
                                  "outputs": 1,
                                  "x": 1190,
                                  "y": 480,
                                  "wires": [
                                          "eb0a77e50a594126"
                                  "name": "U-links",
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1190,
                                  "y": 660,
                                  "wires": []
                                  "name": "Hue",
                                  "x": 90,
                                  "y": 320,
                                  "wires": [
                                          "7e046925a0149339"
                                  "initevents": true,
                                  "x": 280,
                                  "y": 320,
                                  "wires": [
                                          "7cade0980ce23b6f"
                                  "type": "inject",
                                  "name": "Takt",
                                  "props": [
                                          "p": "payload"
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "1",
                                  "crontab": "",
                                  "once": true,
                                  "onceDelay": 0.1,
                                  "topic": "Takt",
                                  "payload": "true",
                                  "x": 90,
                                  "y": 280,
                                  "wires": [
                                          "19d0869e86da09b3"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "bewegung",
                                          "tot": "flow"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 250,
                                  "y": 280,
                                  "wires": [
                                          "6a9e975c8a2cb22e"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "bewegung",
                                          "pt": "flow",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 850,
                                  "y": 640,
                                  "wires": [
                                  "type": "change",
                                  "name": "1002",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "1000",
                                          "tot": "num"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 110,
                                  "y": 380,
                                  "wires": [
                                          "edd034e0ac4e9dbd"
                                  "type": "debug",
                                  "name": "debug 8",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 1300,
                                  "y": 280,
                                  "wires": []
                                  "type": "debug",
                                  "name": "debug 17",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 1300,
                                  "y": 320,
                                  "wires": []
                                  "type": "debug",
                                  "name": "debug 18",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 1200,
                                  "y": 800,
                                  "wires": []
                                  "type": "debug",
                                  "name": "debug 19",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 1200,
                                  "y": 760,
                                  "wires": []
                                  "type": "debug",
                                  "name": "debug 20",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 1200,
                                  "y": 720,
                                  "wires": []
                                  "worker": "10",
                          peterfido
                          @aphofis
                          Das hier sollte anzeigen, wer da wo den Schaltbefehl gibt:
                                 "type": "tab",
                                 "label": "Flow 8",
                                 "disabled": false,
                                 "info": "",
                                 "env": []
                                 "type": "junction",
                                 "x": 1120,
                                 "y": 660,
                                 "wires": [
                                         "141a052859674836",
                                         "574a9f7ddc4f663b",
                                         "b6322a40cf4557b3"
                                 "type": "junction",
                                 "x": 1960,
                                 "y": 460,
                                 "wires": [
                                         "ff32f89078260f0e",
                                         "67e2e01a1266d1c3",
                                         "e98816534075b0f5",
                                         "21f36ea2695afe19",
                                         "a695276a00fe8f61"
                                 "id": "ae8ceff406113f11",
                                 "type": "junction",
                                 "x": 1140,
                                 "y": 260,
                                 "wires": [
                                         "ba0aea0ff71ebc3d"
                                 "id": "9c7c62ee37b6b12c",
                                 "type": "junction",
                                 "x": 520,
                                 "y": 60,
                                 "wires": [
                                         "d24a5429e472b18a"
                                 "id": "d96f128a59bdfbb4",
                                 "type": "junction",
                                 "x": 900,
                                 "y": 440,
                                 "wires": [
                                         "84bd4ea1d044fea4",
                                         "ed2607cafe826532"
                                 "id": "84bd4ea1d044fea4",
                                 "type": "junction",
                                 "x": 980,
                                 "y": 360,
                                 "wires": [
                                         "be66da991b562e24"
                                 "id": "be66da991b562e24",
                                 "type": "junction",
                                 "x": 1280,
                                 "y": 360,
                                 "wires": [
                                         "fa5f2b5bcd258a98"
                                 "type": "junction",
                                 "x": 580,
                                 "y": 560,
                                 "wires": [
                                         "e22b60db6265e908"
                                 "type": "junction",
                                 "x": 580,
                                 "y": 560,
                                 "wires": [
                                         "e22b60db6265e908"
                                 "type": "junction",
                                 "x": 240,
                                 "y": 560,
                                 "wires": [
                                         "1ee1fe89c1628b34"
                                 "type": "inject",
                                 "props": [
                                         "v": "true",
                                         "vt": "bool"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "x": 140,
                                 "y": 380,
                                 "wires": [
                                         "a919a4c30d900c39",
                                         "0150c15cf7b51170"
                                 "type": "debug",
                                 "name": "debug 3",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "complete": "true",
                                 "statusVal": "",
                                 "statusType": "auto",
                                 "x": 2000,
                                 "y": 360,
                                 "wires": []
                                 "type": "delay",
                                 "name": "",
                                 "timeout": "30",
                                 "rate": "1",
                                 "nbRateUnits": "1",
                                 "randomFirst": "1",
                                 "randomLast": "5",
                                 "drop": false,
                                 "allowrate": false,
                                 "outputs": 1,
                                 "x": 150,
                                 "y": 460,
                                 "wires": [
                                         "bee64eb116d76ed1"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "pt": "msg",
                                         "to": "false",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 350,
                                 "y": 460,
                                 "wires": [
                                         "0150c15cf7b51170"
                                 "type": "switch",
                                 "name": "Schalter",
                                 "rules": [
                                         "t": "true"
                                         "t": "false"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 920,
                                 "y": 260,
                                 "wires": [
                                         "01fea99b98c641a3"
                                 "type": "change",
                                 "name": "Motion",
                                 "rules": [
                                         "t": "set",
                                         "p": "bewegung",
                                         "pt": "flow",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 670,
                                 "y": 320,
                                 "wires": [
                                 "type": "comment",
                                 "info": "",
                                 "x": 280,
                                 "y": 300,
                                 "wires": []
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "on",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 710,
                                 "y": 400,
                                 "wires": [
                                         "ed2607cafe826532"
                                 "type": "switch",
                                 "name": "1000?",
                                 "rules": [
                                         "t": "eq",
                                         "v": "1000",
                                         "vt": "num"
                                         "t": "eq",
                                         "v": "",
                                         "vt": "num"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 270,
                                 "y": 660,
                                 "wires": [
                                         "6ae2e0e61f81faeb"
                                 "type": "switch",
                                 "name": "Robi",
                                 "property": "robi",
                                 "rules": [
                                         "t": "true"
                                         "t": "false"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 1050,
                                 "y": 260,
                                 "wires": [
                                         "ae8ceff406113f11"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "stopp",
                                         "pt": "flow",
                                         "to": "true",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 950,
                                 "y": 600,
                                 "wires": [
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "stopp",
                                         "pt": "flow",
                                         "to": "false",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1370,
                                 "y": 600,
                                 "wires": [
                                 "type": "function",
                                 "func": "if(msg.payload){\n    msg.topic = msg.topic + \": Licht ein\";\n}else{\n    msg.topic = msg.topic + \": Licht aus\";\n}\n\nmsg.topic += \", robi:\" + flow.get(\"robi\");\nnode.status({ text: msg.topic });\n\nreturn msg;",
                                 "outputs": 1,
                                 "timeout": 0,
                                 "noerr": 0,
                                 "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"robi\", true);\nflow.set(\"bewegung\", false);\n",
                                 "finalize": "",
                                 "libs": [],
                                 "x": 1770,
                                 "y": 380,
                                 "wires": [
                                         "ed06e85de97289c8",
                                         "423ea0f1dc0e4d31"
                                 "name": "Robi",
                                 "onlyack": "",
                                 "func": "rbe-preinitvalue",
                                 "gap": "",
                                 "fireOnStart": "true",
                                 "x": 90,
                                 "y": 780,
                                 "wires": [
                                         "6b214a0a59b5e04a"
                                 "type": "function",
                                 "outputs": 1,
                                 "timeout": 0,
                                 "noerr": 0,
                                 "initialize": "",
                                 "finalize": "",
                                 "libs": [],
                                 "x": 360,
                                 "y": 360,
                                 "wires": [
                                         "0395e4bbb7c67e21"
                                 "onlyack": "",
                                 "func": "all",
                                 "gap": "",
                                 "x": 100,
                                 "y": 680,
                                 "wires": [
                                         "e22b60db6265e908"
                                 "type": "switch",
                                 "name": "8?",
                                 "rules": [
                                         "t": "eq",
                                         "v": "8",
                                         "vt": "num"
                                         "t": "neq",
                                         "v": "8",
                                         "vt": "num"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 630,
                                 "y": 780,
                                 "wires": [
                                         "7b9c0fa6e795af2d"
                                         "ccadbb1ee1de29e6"
                                 "type": "change",
                                 "name": "setze Flow.robi",
                                 "rules": [
                                         "t": "set",
                                         "p": "robi",
                                         "pt": "flow",
                                         "to": "true",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 840,
                                 "y": 760,
                                 "wires": [
                                         "b117dac109d51b34"
                                 "type": "change",
                                 "name": "lösche Flow.robi",
                                 "rules": [
                                         "t": "set",
                                         "p": "robi",
                                         "pt": "flow",
                                         "to": "false",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 840,
                                 "y": 800,
                                 "wires": [
                                         "b117dac109d51b34"
                                 "type": "comment",
                                 "name": "evtl. gesperrt durch?? Beginn",
                                 "info": "",
                                 "x": 980,
                                 "y": 220,
                                 "wires": []
                                 "type": "switch",
                                 "name": "nur true",
                                 "property": "payload",
                                 "propertyType": "msg",
                                 "rules": [
                                         "t": "true"
                                         "t": "false"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 720,
                                 "y": 240,
                                 "wires": [
                                         "ab41883686b27cc0"
                                 "type": "debug",
                                 "name": "debug 4",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "complete": "true",
                                 "statusVal": "",
                                 "x": 1040,
                                 "y": 760,
                                 "wires": []
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "change",
                                         "p": "payload",
                                         "pt": "msg",
                                         "from": "on",
                                         "fromt": "str",
                                         "to": "true",
                                         "tot": "bool"
                                         "t": "change",
                                         "p": "payload",
                                         "pt": "msg",
                                         "from": "off",
                                         "fromt": "str",
                                         "to": "false",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1290,
                                 "y": 400,
                                 "wires": [
                                         "d303b6e1817d8b77"
                                 "type": "switch",
                                 "name": "",
                                 "rules": [
                                         "t": "true"
                                         "t": "false"
                                         "t": "eq",
                                         "v": "",
                                         "vt": "str"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 3,
                                 "x": 1470,
                                 "y": 400,
                                 "wires": [
                                         "331a07cfba2d7df1"
                                         "331a07cfba2d7df1",
                                         "574a9f7ddc4f663b"
                                 "type": "switch",
                                 "name": "",
                                 "rules": [
                                         "t": "true"
                                         "t": "false"
                                         "t": "eq",
                                         "v": "",
                                         "vt": "str"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 3,
                                 "x": 1770,
                                 "y": 260,
                                 "wires": [
                                         "331a07cfba2d7df1"
                                         "331a07cfba2d7df1"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "change",
                                         "p": "payload",
                                         "pt": "msg",
                                         "from": "on",
                                         "fromt": "str",
                                         "to": "true",
                                         "tot": "bool"
                                         "t": "change",
                                         "p": "payload",
                                         "pt": "msg",
                                         "from": "off",
                                         "fromt": "str",
                                         "to": "false",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1610,
                                 "y": 260,
                                 "wires": [
                                         "b4e55cb04c30244e"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "on",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1250,
                                 "y": 260,
                                 "wires": [
                                         "fa5f2b5bcd258a98"
                                 "attrname": "payload",
                                 "payloadType": "value",
                                 "x": 440,
                                 "y": 660,
                                 "wires": [
                                         "f8d92d8cb9d60184"
                                 "type": "switch",
                                 "rules": [
                                         "t": "false"
                                         "t": "true"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 760,
                                 "y": 660,
                                 "wires": [
                                         "7eea52e80cbe51f0",
                                         "93f0d4c85ab42e59"
                                         "7b9c0fa6e795af2d",
                                         "87ec46662c49de4e",
                                         "f00e20abd94ff43d"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "false",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1380,
                                 "y": 640,
                                 "wires": [
                                         "331a07cfba2d7df1"
                                 "type": "change",
                                 "name": "stop",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "stop",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1070,
                                 "y": 640,
                                 "wires": [
                                         "d96f128a59bdfbb4"
                                 "name": "45sek",
                                 "outtopic": "Schalter 1000",
                                 "outsafe": "on",
                                 "outunsafe": "off",
                                 "warning": "10",
                                 "timer": "60",
                                 "debug": false,
                                 "ndebug": false,
                                 "repeat": false,
                                 "again": false,
                                 "x": 1090,
                                 "y": 400,
                                 "wires": [
                                         "91febc7692f9b822"
                                 "name": "10Sek",
                                 "outtopic": "BWM",
                                 "outsafe": "on",
                                 "outunsafe": "off",
                                 "warning": "10",
                                 "timer": "30",
                                 "debug": false,
                                 "ndebug": false,
                                 "repeat": false,
                                 "again": false,
                                 "x": 1430,
                                 "y": 260,
                                 "wires": [
                                         "90c9685b4a5344dc"
                                 "name": "U-rechts",
                                 "ack": "false",
                                 "stateName": "",
                                 "role": "",
                                 "payloadType": "",
                                 "readonly": "",
                                 "stateUnit": "",
                                 "stateMin": "",
                                 "stateMax": "",
                                 "x": 2140,
                                 "y": 600,
                                 "wires": []
                                 "ack": "false",
                                 "stateName": "",
                                 "role": "",
                                 "payloadType": "",
                                 "readonly": "",
                                 "stateUnit": "",
                                 "stateMin": "",
                                 "stateMax": "",
                                 "x": 2210,
                                 "y": 460,
                                 "wires": []
                                 "ack": "false",
                                 "role": "value",
                                 "readonly": "",
                                 "stateUnit": "",
                                 "stateMin": "",
                                 "stateMax": "",
                                 "x": 2160,
                                 "y": 540,
                                 "wires": []
                                 "type": "debug",
                                 "name": "Küche",
                                 "active": false,
                                 "tosidebar": true,
                                 "console": true,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 2160,
                                 "y": 760,
                                 "wires": []
                                 "type": "delay",
                                 "name": "100ms",
                                 "pauseType": "delay",
                                 "timeout": "100",
                                 "rate": "1",
                                 "nbRateUnits": "1",
                                 "rateUnits": "second",
                                 "randomFirst": "1",
                                 "randomLast": "5",
                                 "randomUnits": "seconds",
                                 "drop": false,
                                 "allowrate": false,
                                 "outputs": 1,
                                 "x": 2070,
                                 "y": 460,
                                 "wires": [
                                         "084e7114b7ed1c61"
                                 "type": "change",
                                 "name": "Küche",
                                 "rules": [
                                         "t": "change",
                                         "p": "payload",
                                         "pt": "msg",
                                         "from": "1000",
                                         "fromt": "str",
                                         "to": "Küche",
                                         "tot": "str"
                                         "t": "change",
                                         "p": "payload",
                                         "pt": "msg",
                                         "from": "true",
                                         "fromt": "bool",
                                         "tot": "str"
                                         "t": "change",
                                         "p": "payload",
                                         "pt": "msg",
                                         "from": "false",
                                         "fromt": "bool",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 2030,
                                 "y": 760,
                                 "wires": [
                                         "442c2ef743d9599f"
                                 "name": "U-links",
                                 "ack": "false",
                                 "stateName": "",
                                 "role": "",
                                 "payloadType": "",
                                 "readonly": "",
                                 "stateUnit": "",
                                 "stateMin": "",
                                 "stateMax": "",
                                 "x": 2130,
                                 "y": 680,
                                 "wires": []
                                 "name": "Hue",
                                 "x": 130,
                                 "y": 160,
                                 "wires": [
                                         "2e0c2a67486c0ac7"
                                 "initevents": true,
                                 "x": 360,
                                 "y": 160,
                                 "wires": [
                                         "0395e4bbb7c67e21"
                                 "id": "83e1205cab7afd75",
                                 "type": "inject",
                                 "name": "Takt",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "1",
                                 "crontab": "",
                                 "once": true,
                                 "onceDelay": 0.1,
                                 "topic": "Takt",
                                 "payload": "true",
                                 "x": 130,
                                 "y": 60,
                                 "wires": [
                                         "26a06677287b879b"
                                 "id": "26a06677287b879b",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "bewegung",
                                         "tot": "flow"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 370,
                                 "y": 60,
                                 "wires": [
                                         "9c7c62ee37b6b12c"
                                 "id": "c8bd53de95a27a58",
                                 "type": "inject",
                                 "name": "Test Schalter",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "1000",
                                 "x": 130,
                                 "y": 520,
                                 "wires": [
                                         "64bf8df5efc25d40",
                                         "f3921b2658b5916c"
                                 "id": "b6322a40cf4557b3",
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "bewegung",
                                         "pt": "flow",
                                         "to": "false",
                                         "tot": "bool"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 1390,
                                 "y": 680,
                                 "wires": [
                                 "id": "4208dd4576daa563",
                                 "type": "comment",
                                 "info": "",
                                 "x": 270,
                                 "y": 580,
                                 "wires": []
                                 "id": "f6fea6b16f9005b0",
                                 "type": "comment",
                                 "name": "evtl. gesperrt durch?? Ende",
                                 "info": "",
                                 "x": 980,
                                 "y": 320,
                                 "wires": []
                                 "type": "delay",
                                 "name": "200 ms",
                                 "timeout": "200",
                                 "rate": "1",
                                 "nbRateUnits": "1",
                                 "randomFirst": "1",
                                 "randomLast": "5",
                                 "drop": false,
                                 "allowrate": false,
                                 "outputs": 1,
                                 "x": 300,
                                 "y": 520,
                                 "wires": [
                                         "d628f1137cfb08c1"
                                 "type": "change",
                                 "name": "1002",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "1002",
                                         "tot": "num"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 430,
                                 "y": 520,
                                 "wires": [
                                         "8355cf791b8a8b1b"
                                 "type": "inject",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "8",
                                 "x": 120,
                                 "y": 840,
                                 "wires": [
                                         "6b214a0a59b5e04a"
                                 "type": "inject",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "5",
                                 "x": 120,
                                 "y": 900,
                                 "wires": [
                                         "6b214a0a59b5e04a"
                                 "id": "f8d92d8cb9d60184",
                                 "type": "change",
                                 "name": "topic",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "Schalter 1000",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 610,
                                 "y": 660,
                                 "wires": [
                                         "cf3016a536d38a8d"
                                 "worker": "10",
                          Im Prinzip kann alles so bleiben. Evtl. Hue nebst Motion Sensor einrichten. Der BWM Simulator tut nix, wenn man nicht die Inject-Node davon klickt. Das gleiche beim Test Schalter. Lass die drin, dann ist die Chance größer, dass ich Deine Exporte importiere und teste.
                          Peterfido
                          • AphofisA Offline
                            AphofisA Offline
                            Aphofis
                            @peterfido
                            bin beim Testen, mal sehen was dabei raus kommt.
                            • AphofisA Offline
                              AphofisA Offline
                              Aphofis
                              Also das immer wieder das Licht eingeschaltet wird wenn man in den BWM läuft und dann per Schalter ausschalten will und dieses 2-3 mal machen musste bis das Licht aus bleibt, lag am HUE Node. Die Globale Aktualisierungsmitteilungen auf diesem Node ignorieren, musste angehakt sein. Jetzt läuft die Steuerung tadellos.
