  4. Node-Red
  5. HUE Bewegungsmelder Roborock integr.
    6.4k
34 Beiträge 2 Kommentatoren 4.6k Aufrufe 2 Beobachtet
  • P peterfido
    @aphofis Wenn Du die Laufzeit des Bewegungsmelders mit berücksichtigen möchtest, dann muss diese zyklisch abgefragt werden, und kommt dann zu der Laufzeit von drei Minuten dazu.
           "id": "b802892eed83e90f",
           "type": "tab",
           "label": "Flow 8",
           "disabled": false,
           "info": "",
           "env": []
           "id": "f00e20abd94ff43d",
           "type": "junction",
           "z": "b802892eed83e90f",
           "x": 1120,
           "y": 660,
           "wires": [
                   "141a052859674836",
                   "574a9f7ddc4f663b",
                   "b6322a40cf4557b3"
           "id": "423ea0f1dc0e4d31",
           "type": "junction",
           "x": 1960,
           "y": 460,
           "wires": [
                   "ff32f89078260f0e",
                   "67e2e01a1266d1c3",
                   "e98816534075b0f5",
                   "21f36ea2695afe19",
                   "a695276a00fe8f61"
           "id": "ae8ceff406113f11",
           "type": "junction",
           "x": 1140,
           "y": 260,
           "wires": [
                   "ba0aea0ff71ebc3d"
           "id": "256e4df028333ee3",
           "type": "junction",
           "x": 580,
           "y": 60,
           "wires": [
                   "6ae2e0e61f81faeb"
           "id": "9c7c62ee37b6b12c",
           "type": "junction",
           "x": 540,
           "y": 120,
           "wires": [
                   "d24a5429e472b18a"
           "id": "d96f128a59bdfbb4",
           "type": "junction",
           "x": 900,
           "y": 440,
           "wires": [
                   "84bd4ea1d044fea4",
                   "ed2607cafe826532"
           "id": "84bd4ea1d044fea4",
           "type": "junction",
           "x": 980,
           "y": 360,
           "wires": [
                   "be66da991b562e24"
           "id": "be66da991b562e24",
           "type": "junction",
           "x": 1280,
           "y": 360,
           "wires": [
                   "fa5f2b5bcd258a98"
           "id": "a2104cdffd7ca75f",
           "type": "inject",
           "name": "Test Bewegung",
           "props": [
                   "p": "payload.motion",
                   "v": "true",
                   "vt": "bool"
                   "p": "topic",
                   "vt": "str"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "Bewegungsmelder",
           "x": 140,
           "y": 380,
           "wires": [
                   "a919a4c30d900c39",
                   "0150c15cf7b51170"
           "id": "ed06e85de97289c8",
           "type": "debug",
           "name": "debug 3",
           "active": false,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "true",
           "targetType": "full",
           "statusVal": "",
           "statusType": "auto",
           "x": 2000,
           "y": 360,
           "wires": []
           "id": "a919a4c30d900c39",
           "type": "delay",
           "name": "",
           "pauseType": "delay",
           "timeout": "10",
           "timeoutUnits": "seconds",
           "rate": "1",
           "nbRateUnits": "1",
           "rateUnits": "second",
           "randomFirst": "1",
           "randomLast": "5",
           "randomUnits": "seconds",
           "drop": false,
           "allowrate": false,
           "outputs": 1,
           "x": 150,
           "y": 460,
           "wires": [
                   "bee64eb116d76ed1"
           "id": "bee64eb116d76ed1",
           "type": "change",
           "name": "motion:false",
           "rules": [
                   "t": "set",
                   "pt": "msg",
                   "to": "false",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 350,
           "y": 460,
           "wires": [
                   "0150c15cf7b51170"
           "id": "ab41883686b27cc0",
           "type": "switch",
           "name": "Schalter",
           "property": "stopp",
           "propertyType": "flow",
           "rules": [
                   "t": "true"
                   "t": "false"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 920,
           "y": 260,
           "wires": [
                   "01fea99b98c641a3"
           "id": "0395e4bbb7c67e21",
           "type": "change",
           "name": "Motion",
           "rules": [
                   "t": "set",
                   "p": "bewegung",
                   "pt": "flow",
                   "to": "payload.motion",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 670,
           "y": 320,
           "wires": [
           "id": "59792b228df9eb30",
           "type": "comment",
           "name": "<< Bewegungsmelder |||||||||||||| Simulator da kein Hue  Beginn>>",
           "info": "",
           "x": 270,
           "y": 300,
           "wires": []
           "id": "93f0d4c85ab42e59",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "on",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 710,
           "y": 400,
           "wires": [
                   "ed2607cafe826532"
           "id": "e22b60db6265e908",
           "type": "switch",
           "name": "1000?",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "eq",
                   "v": "1000",
                   "vt": "num"
                   "t": "eq",
                   "v": "",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 250,
           "y": 660,
           "wires": [
                   "35f7a8f381fdb099"
           "id": "01fea99b98c641a3",
           "type": "switch",
           "name": "Robi",
           "property": "BWM",
           "rules": [
                   "t": "true"
                   "t": "false"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 1050,
           "y": 260,
           "wires": [
                   "ae8ceff406113f11"
           "id": "7eea52e80cbe51f0",
           "type": "change",
           "name": "setze stopp",
           "rules": [
                   "t": "set",
                   "p": "stopp",
                   "pt": "flow",
                   "to": "true",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 890,
           "y": 600,
           "wires": [
           "id": "574a9f7ddc4f663b",
           "type": "change",
           "name": "lösche stopp",
           "rules": [
                   "t": "set",
                   "p": "stopp",
                   "pt": "flow",
                   "to": "false",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1370,
           "y": 600,
           "wires": [
           "id": "331a07cfba2d7df1",
           "type": "function",
           "name": "Variablen Ini + Ausgabe",
           "func": "node.status({ text: msg.payload });\n\n// Für Tests Beginn\nflow.set(\"lampe_ist\", msg.payload); // Zeile für Normalbetrieb auskommentieren\n// Für Tests Ende\n\nreturn msg;",
           "outputs": 1,
           "timeout": 0,
           "noerr": 0,
           "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\nflow.set(\"bewegung\", false);\nflow.set(\"lampe_ist\", false);\n",
           "finalize": "",
           "libs": [],
           "x": 1770,
           "y": 380,
           "wires": [
                   "ed06e85de97289c8",
                   "423ea0f1dc0e4d31"
           "id": "b9692c9131fb2ef5",
           "type": "ioBroker in",
           "name": "Robi",
           "attrname": "payload",
           "topic": "mihome-vacuum.0.info.state",
           "payloadType": "value",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "false",
           "outFormat": "MQTT",
           "x": 90,
           "y": 780,
           "wires": [
                   "6b214a0a59b5e04a"
           "id": "0150c15cf7b51170",
           "type": "function",
           "name": "Ausgang BWM",
           "func": "\nreturn msg;",
           "outputs": 1,
           "timeout": 0,
           "noerr": 0,
           "initialize": "",
           "finalize": "",
           "libs": [],
           "x": 360,
           "y": 360,
           "wires": [
                   "0395e4bbb7c67e21"
           "id": "b6b4c157c31e3701",
           "name": "KüSchalter",
           "topic": "hue.0.Hue_GordonX.Küche_Schalter.buttonevent",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "x": 100,
           "y": 680,
           "wires": [
                   "e22b60db6265e908"
           "id": "6b214a0a59b5e04a",
           "type": "switch",
           "name": "8?",
           "rules": [
                   "t": "eq",
                   "v": "8",
                   "vt": "num"
                   "t": "neq",
                   "v": "8",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 630,
           "y": 780,
           "wires": [
                   "7b9c0fa6e795af2d"
                   "ccadbb1ee1de29e6"
           "id": "7b9c0fa6e795af2d",
           "type": "change",
           "name": "setze Flow.BWM",
           "rules": [
                   "t": "set",
                   "p": "BWM",
                   "pt": "flow",
                   "to": "true",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 850,
           "y": 760,
           "wires": [
                   "b117dac109d51b34"
           "id": "ccadbb1ee1de29e6",
           "type": "change",
           "name": "lösche Flow.BWM",
           "rules": [
                   "t": "set",
                   "p": "BWM",
                   "pt": "flow",
                   "to": "false",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 850,
           "y": 800,
           "wires": [
                   "b117dac109d51b34"
           "id": "558db419c5c37cca",
           "type": "comment",
           "name": "evtl. gesperrt durch?? Beginn",
           "info": "",
           "x": 980,
           "y": 220,
           "wires": []
           "id": "d24a5429e472b18a",
           "type": "switch",
           "name": "nur true",
           "rules": [
                   "t": "true"
                   "t": "false"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 740,
           "y": 240,
           "wires": [
                   "ab41883686b27cc0"
           "id": "b117dac109d51b34",
           "type": "debug",
           "name": "debug 4",
           "active": false,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "true",
           "statusVal": "",
           "x": 1040,
           "y": 760,
           "wires": []
           "id": "91febc7692f9b822",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "on",
                   "fromt": "str",
                   "to": "true",
                   "tot": "bool"
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "off",
                   "fromt": "str",
                   "to": "false",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1290,
           "y": 400,
           "wires": [
                   "d303b6e1817d8b77"
           "id": "d303b6e1817d8b77",
           "type": "switch",
           "name": "",
           "rules": [
                   "t": "true"
                   "t": "false"
                   "t": "eq",
                   "v": "",
                   "vt": "str"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 1470,
           "y": 400,
           "wires": [
                   "331a07cfba2d7df1"
                   "331a07cfba2d7df1",
                   "574a9f7ddc4f663b"
           "id": "b4e55cb04c30244e",
           "type": "switch",
           "name": "",
           "rules": [
                   "t": "true"
                   "t": "false"
                   "t": "eq",
                   "v": "",
                   "vt": "str"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 1770,
           "y": 260,
           "wires": [
                   "331a07cfba2d7df1"
                   "331a07cfba2d7df1"
           "id": "90c9685b4a5344dc",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "on",
                   "fromt": "str",
                   "to": "true",
                   "tot": "bool"
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "off",
                   "fromt": "str",
                   "to": "false",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1610,
           "y": 260,
           "wires": [
                   "b4e55cb04c30244e"
           "id": "ba0aea0ff71ebc3d",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "on",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1250,
           "y": 260,
           "wires": [
                   "fa5f2b5bcd258a98"
           "id": "6ae2e0e61f81faeb",
           "type": "ioBroker get",
           "name": "Virtuelle Lampe",
           "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_1",
           "errOnInvalidState": "nothing",
           "x": 760,
           "y": 100,
           "wires": [
                   "dc4b3ed2e3d1a857"
           "id": "cf3016a536d38a8d",
           "type": "switch",
           "name": "true false",
           "rules": [
                   "t": "false"
                   "t": "true"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 680,
           "y": 660,
           "wires": [
                   "7eea52e80cbe51f0",
                   "93f0d4c85ab42e59"
                   "7b9c0fa6e795af2d",
                   "87ec46662c49de4e",
                   "f00e20abd94ff43d"
           "id": "141a052859674836",
           "type": "change",
           "name": "Alles auf Anfang",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "false",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1380,
           "y": 640,
           "wires": [
                   "331a07cfba2d7df1"
           "id": "87ec46662c49de4e",
           "type": "change",
           "name": "stop",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "stop",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1010,
           "y": 640,
           "wires": [
                   "d96f128a59bdfbb4"
           "id": "ed2607cafe826532",
           "type": "mytimeout",
           "name": "45sek",
           "outtopic": "",
           "outsafe": "on",
           "outwarning": "Warning",
           "outunsafe": "off",
           "warning": "10",
           "timer": "45",
           "debug": false,
           "ndebug": false,
           "ignoreCase": false,
           "repeat": false,
           "again": false,
           "x": 1090,
           "y": 400,
           "wires": [
                   "91febc7692f9b822"
           "id": "fa5f2b5bcd258a98",
           "name": "10Sek",
           "outtopic": "",
           "outsafe": "on",
           "outunsafe": "off",
           "warning": "10",
           "timer": "10",
           "debug": false,
           "ndebug": false,
           "repeat": false,
           "again": false,
           "x": 1430,
           "y": 260,
           "wires": [
                   "90c9685b4a5344dc"
           "id": "21f36ea2695afe19",
           "type": "ioBroker out",
           "name": "U-rechts",
           "topic": "tuya.0.bfb09eea5dad3699abyrbu.20",
           "ack": "false",
           "autoCreate": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 2140,
           "y": 600,
           "wires": []
           "id": "084e7114b7ed1c61",
           "name": "Küche Decke",
           "topic": "tuya.0.bfe4af976feb74d845vugp.1",
           "ack": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 2210,
           "y": 460,
           "wires": []
           "id": "ff32f89078260f0e",
           "name": "Virtuel Switch 1",
           "ack": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 2160,
           "y": 540,
           "wires": []
           "id": "442c2ef743d9599f",
           "type": "debug",
           "name": "Küche",
           "active": true,
           "tosidebar": true,
           "console": true,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "x": 2160,
           "y": 760,
           "wires": []
           "id": "67e2e01a1266d1c3",
           "type": "delay",
           "name": "100ms",
           "timeout": "100",
           "timeoutUnits": "milliseconds",
           "rate": "1",
           "nbRateUnits": "1",
           "randomFirst": "1",
           "randomLast": "5",
           "drop": false,
           "allowrate": false,
           "outputs": 1,
           "x": 2070,
           "y": 460,
           "wires": [
                   "084e7114b7ed1c61"
           "id": "e98816534075b0f5",
           "type": "change",
           "name": "Küche",
           "rules": [
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "1000",
                   "fromt": "str",
                   "to": "Küche",
                   "tot": "str"
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "true",
                   "fromt": "bool",
                   "to": "Küche eingeschaltet",
                   "tot": "str"
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "false",
                   "fromt": "bool",
                   "to": "Küche ausgeschaltet",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 2030,
           "y": 760,
           "wires": [
                   "442c2ef743d9599f"
           "id": "a695276a00fe8f61",
           "name": "U-links",
           "topic": "hue.0.Hue_GordonX.Küche_Unterschr_Links.on",
           "ack": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 2130,
           "y": 680,
           "wires": []
           "id": "802770af38c8534e",
           "type": "hue-bridge-node",
           "name": "Hue",
           "bridge": "cbd54dbabf6f65be",
           "autoupdates": true,
           "skipglobalevents": false,
           "initevents": false,
           "x": 130,
           "y": 160,
           "wires": [
                   "2e0c2a67486c0ac7"
           "id": "2e0c2a67486c0ac7",
           "type": "hue-motion",
           "name": "Küche Motion Sensor",
           "sensorid": "7529c8d8-9f5c-451d-ba56-70cacda84564",
           "skipevents": false,
           "initevents": true,
           "x": 360,
           "y": 160,
           "wires": [
                   "0395e4bbb7c67e21"
           "id": "83e1205cab7afd75",
           "type": "inject",
           "name": "Takt",
           "props": [
                   "p": "payload"
                   "p": "topic",
                   "vt": "str"
           "repeat": "1",
           "crontab": "",
           "once": true,
           "onceDelay": 0.1,
           "topic": "Takt",
           "payload": "true",
           "payloadType": "bool",
           "x": 130,
           "y": 60,
           "wires": [
                   "26a06677287b879b",
                   "256e4df028333ee3"
           "id": "26a06677287b879b",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "bewegung",
                   "tot": "flow"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 350,
           "y": 120,
           "wires": [
                   "9c7c62ee37b6b12c"
           "id": "c8bd53de95a27a58",
           "type": "inject",
           "name": "Test Schalter",
           "props": [
                   "p": "payload"
                   "p": "topic",
                   "vt": "str"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "1000",
           "payloadType": "num",
           "x": 130,
           "y": 600,
           "wires": [
                   "e22b60db6265e908"
           "id": "b6322a40cf4557b3",
           "type": "change",
           "name": "lösche bewegung",
           "rules": [
                   "t": "set",
                   "p": "bewegung",
                   "pt": "flow",
                   "to": "false",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1390,
           "y": 680,
           "wires": [
           "id": "35f7a8f381fdb099",
           "type": "change",
           "name": "lichtan?",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "lampe_ist",
                   "tot": "flow"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 460,
           "y": 660,
           "wires": [
                   "cf3016a536d38a8d"
           "id": "dc4b3ed2e3d1a857",
           "type": "change",
           "name": "Motion",
           "rules": [
                   "t": "set",
                   "p": "lampe_ist",
                   "pt": "flow",
                   "to": "payload",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 910,
           "y": 100,
           "wires": [
           "id": "704f9134130a0c13",
           "type": "comment",
           "name": "Nötig für Simulation, da kein Tuya Ende",
           "info": "",
           "x": 830,
           "y": 160,
           "wires": []
           "id": "105d29d40a2b08f3",
           "type": "comment",
           "name": "Nötig für Simulation, da kein Tuya Beginn",
           "info": "",
           "x": 840,
           "y": 40,
           "wires": []
           "id": "2e246cc32c852ec4",
           "type": "comment",
           "name": "Nötig für Simulation, da kein Tuya",
           "info": "",
           "x": 470,
           "y": 620,
           "wires": []
           "id": "5d18e186acebf108",
           "type": "comment",
           "info": "",
           "x": 470,
           "y": 720,
           "wires": []
           "id": "4208dd4576daa563",
           "type": "comment",
           "name": "<< Bewegungsmelder |||||||||||||| Simulator da kein Hue  Ende>>",
           "info": "",
           "x": 260,
           "y": 520,
           "wires": []
           "id": "f6fea6b16f9005b0",
           "type": "comment",
           "name": "evtl. gesperrt durch?? Ende",
           "info": "",
           "x": 980,
           "y": 320,
           "wires": []
           "id": "cbd54dbabf6f65be",
           "type": "hue-bridge",
           "name": "Hue GordonX",
           "bridge": "192.168.0.8",
           "key": "SlfyXwpcaEvRN0d1DU2JrrOlwrm9Debhhm9A4E-d",
           "worker": "10",
           "disableupdates": false
    AphofisA Offline
    AphofisA Offline
    Aphofis
    schrieb am zuletzt editiert von Aphofis
    @peterfido
    Mit der neuen Schaltung kann man per HUE schalter einmal zweimal klick nicht das licht ein und ausschalten es geht nur einschalten einschalten.
    Das war in der vorherigen Schaltung korrekt da war jeder klick auf den schalter ein aus ein aus schalten.
    P 1 Antwort Letzte Antwort
    • AphofisA Aphofis
      @peterfido
      peterfido
      @aphofis Guck Dir mal die Function genauer an. Da ist ein Bemerkungstext drin, dass eine Zeile auskommentiert werden soll, wenn es produktiv genutzt wird. Evtl. war es das dann schon. Ich habe die Hardware nicht da, und habe daher die Lampe mit der Function simuliert.
      Es ist nicht einfach, da was zu "testen", was man nicht hat.
      Peterfido
      • AphofisA Offline
        AphofisA Offline
        Aphofis
        @peterfido
        Du meinst in der Variable !?
        flow.set("lampe_ist", msg.payload);
        Hatte ich auskommentiert, geht dann aber trotzdem nicht.
        • AphofisA Aphofis
          @peterfido
          peterfido
          @aphofis Da kommt dann die Fehlersuche. Also ein Node, z.B. den vom Bewegungsmelder deaktivieren, und schauen, ob es dann in der Simulation läuft. Man kann auch das Topic setzen und am Ende auswerten, wer die Lampe eingeschaltet hat.
          Die Abfrage der Lampe_ist kann auch von oben wieder weg und nach unten als Ersatz für den von mir mit "kein Tuya" 'eingerahmten' Block.
          Peterfido
          AphofisA 1 Antwort Letzte Antwort
          • P peterfido
            AphofisA Offline
            AphofisA Offline
            Aphofis
            @peterfido
            Also es funktioniert soweit, doch wenn der Roboter status 5 hat und man in den BWM läuft geht trotzdem das Licht an und wenn man es dann per Schalter ausschalten will, muss man das 3-4 mal machen bis das licht aus bleibt. Wie man jetzt herausfindet wer nun das licht schaltet weiß ich nicht.
                    "id": "a4c8574588c0de3c",
                    "type": "change",
                    "z": "f40fbc4eb5ac4f7a",
                    "rules": [
                            "t": "set",
                            "pt": "msg",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 450,
                    "y": 540,
                    "wires": [
                            "169c9cd74337485f"
                    "id": "f6bc1b429099ca57",
                    "type": "switch",
                    "name": "Schalter",
                    "rules": [
                            "t": "true"
                            "t": "false"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 800,
                    "y": 500,
                    "wires": [
                            "ee120a8678492945"
                    "id": "f2bfa3e6a90d48ed",
                    "type": "change",
                    "name": "Motion",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 610,
                    "y": 500,
                    "wires": [
                            "a7c05960eac63d95"
                    "id": "8803280db34eb22b",
                    "type": "comment",
                    "name": "Bewegungsmelder Simulator  Beginn",
                    "info": "",
                    "x": 160,
                    "y": 420,
                    "wires": []
                    "id": "5925b1db569c695b",
                    "type": "change",
                    "name": "payload",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "on",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 620,
                    "y": 540,
                    "wires": [
                            "5f9435538ec534ed"
                    "id": "95fda7a91b84c03f",
                    "type": "switch",
                    "name": "1000?",
                    "rules": [
                            "t": "eq",
                            "v": "1000",
                            "vt": "num"
                            "t": "eq",
                            "v": "",
                            "vt": "num"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 250,
                    "y": 600,
                    "wires": [
                            "ee5a65e2896d189b"
                    "id": "ee120a8678492945",
                    "type": "switch",
                    "name": "Robi",
                    "property": "BWM",
                    "rules": [
                            "t": "true"
                            "t": "false"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 810,
                    "y": 460,
                    "wires": [
                            "8f4fcec5a545127f"
                    "id": "3648551e97ec2cab",
                    "type": "change",
                    "name": "flow/stop",
                    "rules": [
                            "t": "set",
                            "p": "stopp",
                            "pt": "flow",
                            "to": "true",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 620,
                    "y": 580,
                    "wires": [
                    "id": "a8b609cc983f0b37",
                    "type": "change",
                    "name": "löscheflow.stopp",
                    "rules": [
                            "t": "set",
                            "p": "stopp",
                            "pt": "flow",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1220,
                    "y": 520,
                    "wires": [
                    "id": "0e43213215238d27",
                    "type": "function",
                    "name": "Variab.Ini + Ausg.",
                    "func": "node.status({ text: msg.payload });\n\nreturn msg;",
                    "outputs": 1,
                    "timeout": 0,
                    "noerr": 0,
                    "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\n",
                    "finalize": "",
                    "libs": [],
                    "x": 1430,
                    "y": 460,
                    "wires": [
                            "f1be18a24ca143f6"
                    "id": "6500453922363ac9",
                    "name": "Robi",
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 370,
                    "y": 700,
                    "wires": [
                            "81fd4c871d668d04"
                    "id": "169c9cd74337485f",
                    "type": "function",
                    "name": "Ausg.BWM",
                    "outputs": 1,
                    "timeout": 0,
                    "noerr": 0,
                    "initialize": "",
                    "finalize": "",
                    "libs": [],
                    "x": 450,
                    "y": 500,
                    "wires": [
                            "f2bfa3e6a90d48ed"
                    "id": "c6d6a47028727285",
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 80,
                    "y": 600,
                    "wires": [
                            "95fda7a91b84c03f"
                    "id": "81fd4c871d668d04",
                    "type": "switch",
                    "name": "8?",
                    "rules": [
                            "t": "eq",
                            "v": "8",
                            "vt": "num"
                            "t": "neq",
                            "v": "8",
                            "vt": "num"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 490,
                    "y": 680,
                    "wires": [
                            "638dc14da90f5eb4"
                            "542b940ecfefa127"
                    "id": "638dc14da90f5eb4",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "BWM",
                            "pt": "flow",
                            "to": "true",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 650,
                    "y": 660,
                    "wires": [
                            "3803f5607daeb485"
                    "id": "542b940ecfefa127",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "BWM",
                            "pt": "flow",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 650,
                    "y": 700,
                    "wires": [
                            "3803f5607daeb485"
                    "id": "2bb3725204a30905",
                    "type": "comment",
                    "name": "evtl. gesperrt durch??",
                    "info": "",
                    "x": 800,
                    "y": 380,
                    "wires": []
                    "id": "a7c05960eac63d95",
                    "type": "switch",
                    "name": "nur true",
                    "rules": [
                            "t": "true"
                            "t": "false"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 640,
                    "y": 460,
                    "wires": [
                            "f6bc1b429099ca57"
                    "id": "3803f5607daeb485",
                    "type": "debug",
                    "name": "debug 9",
                    "active": false,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "complete": "true",
                    "statusVal": "",
                    "x": 820,
                    "y": 680,
                    "wires": []
                    "id": "86ed2879e6ab1742",
                    "type": "comment",
                    "name": "Bewegungsmelder Simulator Ende",
                    "info": "",
                    "x": 160,
                    "y": 560,
                    "wires": []
                    "id": "4deb5666bac8cf44",
                    "type": "change",
                    "name": "on/off",
                    "rules": [
                            "t": "change",
                            "p": "payload",
                            "pt": "msg",
                            "from": "on",
                            "fromt": "str",
                            "to": "true",
                            "tot": "bool"
                            "t": "change",
                            "p": "payload",
                            "pt": "msg",
                            "from": "off",
                            "fromt": "str",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 890,
                    "y": 560,
                    "wires": [
                            "d2eeea8c88021d24"
                    "id": "d2eeea8c88021d24",
                    "type": "switch",
                    "name": "",
                    "rules": [
                            "t": "true"
                            "t": "false"
                            "t": "eq",
                            "v": "",
                            "vt": "str"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 3,
                    "x": 1010,
                    "y": 560,
                    "wires": [
                            "1584a54e77837dbd"
                            "a8b609cc983f0b37",
                            "1584a54e77837dbd"
                    "id": "774f8f940a2c4c96",
                    "type": "switch",
                    "name": "",
                    "rules": [
                            "t": "true"
                            "t": "false"
                            "t": "eq",
                            "v": "",
                            "vt": "str"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 3,
                    "x": 1190,
                    "y": 460,
                    "wires": [
                            "0e43213215238d27"
                            "0e43213215238d27"
                    "id": "bcc31acbfde45d97",
                    "type": "change",
                    "name": "on/off",
                    "rules": [
                            "t": "change",
                            "p": "payload",
                            "pt": "msg",
                            "from": "on",
                            "fromt": "str",
                            "to": "true",
                            "tot": "bool"
                            "t": "change",
                            "p": "payload",
                            "pt": "msg",
                            "from": "off",
                            "fromt": "str",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 990,
                    "y": 460,
                    "wires": [
                            "774f8f940a2c4c96"
                    "id": "8f4fcec5a545127f",
                    "type": "change",
                    "name": "on",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "on",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 810,
                    "y": 420,
                    "wires": [
                            "e8865a546b6ee97f"
                    "id": "ee5a65e2896d189b",
                    "x": 340,
                    "y": 640,
                    "wires": [
                            "661eb84a02820976"
                    "id": "661eb84a02820976",
                    "type": "switch",
                    "name": "",
                    "rules": [
                            "t": "false"
                            "t": "true"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 430,
                    "y": 580,
                    "wires": [
                            "a8a0cb4a1682f9f2",
                            "3bd2c8cd8fbc4e0d"
                            "638dc14da90f5eb4",
                            "d5b7b0bf08213264",
                            "8791ca72f579691c"
                    "id": "3c6f79231d0fc04b",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1220,
                    "y": 560,
                    "wires": [
                            "0e43213215238d27"
                    "id": "d5b7b0bf08213264",
                    "type": "change",
                    "name": "stop",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "stop",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 610,
                    "y": 620,
                    "wires": [
                            "5f9435538ec534ed",
                            "9b6cc9d834347e2b"
                    "id": "5f9435538ec534ed",
                    "name": "10min.",
                    "outtopic": "",
                    "outsafe": "on",
                    "outunsafe": "off",
                    "warning": "10",
                    "timer": "600",
                    "debug": false,
                    "ndebug": false,
                    "repeat": false,
                    "again": false,
                    "x": 770,
                    "y": 560,
                    "wires": [
                            "4deb5666bac8cf44"
                    "id": "e8865a546b6ee97f",
                    "name": "3Min.",
                    "outtopic": "",
                    "outsafe": "on",
                    "outunsafe": "off",
                    "warning": "10",
                    "timer": "180",
                    "debug": false,
                    "ndebug": false,
                    "repeat": false,
                    "again": false,
                    "x": 990,
                    "y": 500,
                    "wires": [
                            "bcc31acbfde45d97"
                    "id": "166ff2a331d49e9e",
                    "name": "Hue",
                    "x": 130,
                    "y": 500,
                    "wires": [
                            "d500eca26ab86278"
                    "id": "d500eca26ab86278",
                    "name": "KüMo",
                    "initevents": true,
                    "x": 270,
                    "y": 500,
                    "wires": [
                            "169c9cd74337485f",
                            "a4c8574588c0de3c"
                    "id": "631201f88292c2d6",
                    "name": "U-rechts",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1320,
                    "y": 740,
                    "wires": []
                    "id": "400b88291d913b81",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1330,
                    "y": 620,
                    "wires": []
                    "id": "ce64922d78c18bb2",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1340,
                    "y": 680,
                    "wires": []
                    "id": "b16aaa4000874ffd",
                    "type": "debug",
                    "name": "Küche",
                    "active": true,
                    "tosidebar": true,
                    "console": true,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1440,
                    "y": 860,
                    "wires": []
                    "id": "f5195df37114b7de",
                    "type": "change",
                    "name": "Küche",
                    "rules": [
                            "t": "change",
                            "p": "payload",
                            "pt": "msg",
                            "from": "1000",
                            "fromt": "str",
                            "to": "Küche",
                            "tot": "str"
                            "t": "change",
                            "p": "payload",
                            "pt": "msg",
                            "from": "true",
                            "fromt": "bool",
                            "tot": "str"
                            "t": "change",
                            "p": "payload",
                            "pt": "msg",
                            "from": "false",
                            "fromt": "bool",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1310,
                    "y": 860,
                    "wires": [
                            "b16aaa4000874ffd"
                    "id": "08276b1f6580fc56",
                    "name": "U-links",
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1430,
                    "y": 800,
                    "wires": []
                    "id": "587e1a24a2250226",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "1000",
                    "payloadType": "str",
                    "x": 90,
                    "y": 720,
                    "wires": [
                            "95fda7a91b84c03f"
                    "id": "f3e6cb95fd339887",
                    "name": "VIS-Küche",
                    "topic": "0_userdata.0.GordonX-Home.0.Küche.VIS-Küche",
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 80,
                    "y": 660,
                    "wires": [
                            "95fda7a91b84c03f"
                    "id": "3c0717cd3d6e108e",
                    "type": "delay",
                    "name": "100ms",
                    "timeout": "100",
                    "rate": "1",
                    "nbRateUnits": "1",
                    "randomFirst": "1",
                    "randomLast": "5",
                    "drop": false,
                    "allowrate": false,
                    "outputs": 1,
                    "x": 1310,
                    "y": 800,
                    "wires": [
                            "08276b1f6580fc56"
                    "id": "805251b70f5d5a93",
                    "type": "inject",
                    "props": [
                            "v": "true",
                            "vt": "bool"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "x": 240,
                    "y": 460,
                    "wires": [
                            "169c9cd74337485f",
                            "e1f5f49327a29a8a"
                    "id": "e1f5f49327a29a8a",
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "pt": "msg",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 450,
                    "y": 460,
                    "wires": [
                            "169c9cd74337485f"
                    "id": "90f844739a331c64",
                    "type": "junction",
                    "x": 1060,
                    "y": 600,
                    "wires": [
                            "3c6f79231d0fc04b",
                            "a8b609cc983f0b37"
                    "id": "f1be18a24ca143f6",
                    "type": "junction",
                    "x": 1160,
                    "y": 680,
                    "wires": [
                            "ce64922d78c18bb2",
                            "f5195df37114b7de",
                            "631201f88292c2d6",
                            "400b88291d913b81",
                            "3c0717cd3d6e108e"
                    "id": "1584a54e77837dbd",
                    "type": "junction",
                    "x": 1100,
                    "y": 480,
                    "wires": [
                            "612158a90f7d1a23"
                    "id": "e9a12ac84d11dd0e",
                    "type": "junction",
                    "x": 980,
                    "y": 640,
                    "wires": [
                            "90f844739a331c64"
                    "id": "a8a0cb4a1682f9f2",
                    "type": "junction",
                    "x": 540,
                    "y": 560,
                    "wires": [
                            "5925b1db569c695b"
                    "id": "3bd2c8cd8fbc4e0d",
                    "type": "junction",
                    "x": 540,
                    "y": 580,
                    "wires": [
                            "3648551e97ec2cab"
                    "id": "9b6cc9d834347e2b",
                    "type": "junction",
                    "x": 880,
                    "y": 620,
                    "wires": [
                            "e8865a546b6ee97f"
                    "id": "612158a90f7d1a23",
                    "type": "junction",
                    "x": 1260,
                    "y": 480,
                    "wires": [
                            "0e43213215238d27"
                    "id": "8791ca72f579691c",
                    "type": "junction",
                    "x": 560,
                    "y": 640,
                    "wires": [
                            "e9a12ac84d11dd0e"
                    "worker": "10",
            • AphofisA Aphofis
              @peterfido
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "pt": "msg",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 450,
                      "y": 540,
                      "wires": [
                              "169c9cd74337485f"
                      "type": "switch",
                      "name": "Schalter",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 800,
                      "y": 500,
                      "wires": [
                              "ee120a8678492945"
                      "type": "change",
                      "name": "Motion",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 610,
                      "y": 500,
                      "wires": [
                              "a7c05960eac63d95"
                      "type": "comment",
                      "info": "",
                      "x": 160,
                      "y": 420,
                      "wires": []
                      "type": "change",
                      "name": "payload",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "on",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 620,
                      "y": 540,
                      "wires": [
                              "5f9435538ec534ed"
                      "type": "switch",
                      "name": "1000?",
                      "rules": [
                              "t": "eq",
                              "v": "1000",
                              "vt": "num"
                              "t": "eq",
                              "v": "",
                              "vt": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 250,
                      "y": 600,
                      "wires": [
                              "ee5a65e2896d189b"
                      "type": "switch",
                      "name": "Robi",
                      "property": "BWM",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 810,
                      "y": 460,
                      "wires": [
                              "8f4fcec5a545127f"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "stopp",
                              "pt": "flow",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 620,
                      "y": 580,
                      "wires": [
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "stopp",
                              "pt": "flow",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1220,
                      "y": 520,
                      "wires": [
                      "type": "function",
                      "outputs": 1,
                      "timeout": 0,
                      "noerr": 0,
                      "finalize": "",
                      "libs": [],
                      "x": 1430,
                      "y": 460,
                      "wires": [
                              "f1be18a24ca143f6"
                      "name": "Robi",
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 370,
                      "y": 700,
                      "wires": [
                              "81fd4c871d668d04"
                      "type": "function",
                      "name": "Ausg.BWM",
                      "outputs": 1,
                      "timeout": 0,
                      "noerr": 0,
                      "initialize": "",
                      "finalize": "",
                      "libs": [],
                      "x": 450,
                      "y": 500,
                      "wires": [
                              "f2bfa3e6a90d48ed"
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 80,
                      "y": 600,
                      "wires": [
                              "95fda7a91b84c03f"
                      "type": "switch",
                      "name": "8?",
                      "rules": [
                              "t": "eq",
                              "v": "8",
                              "vt": "num"
                              "t": "neq",
                              "v": "8",
                              "vt": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 490,
                      "y": 680,
                      "wires": [
                              "638dc14da90f5eb4"
                              "542b940ecfefa127"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "BWM",
                              "pt": "flow",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 650,
                      "y": 660,
                      "wires": [
                              "3803f5607daeb485"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "BWM",
                              "pt": "flow",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 650,
                      "y": 700,
                      "wires": [
                              "3803f5607daeb485"
                      "type": "comment",
                      "info": "",
                      "x": 800,
                      "y": 380,
                      "wires": []
                      "type": "switch",
                      "name": "nur true",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 640,
                      "y": 460,
                      "wires": [
                              "f6bc1b429099ca57"
                      "type": "debug",
                      "name": "debug 9",
                      "active": false,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "complete": "true",
                      "statusVal": "",
                      "x": 820,
                      "y": 680,
                      "wires": []
                      "type": "comment",
                      "info": "",
                      "x": 160,
                      "y": 560,
                      "wires": []
                      "type": "change",
                      "name": "on/off",
                      "rules": [
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "on",
                              "fromt": "str",
                              "to": "true",
                              "tot": "bool"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "off",
                              "fromt": "str",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 890,
                      "y": 560,
                      "wires": [
                              "d2eeea8c88021d24"
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "true"
                              "t": "false"
                              "t": "eq",
                              "v": "",
                              "vt": "str"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 3,
                      "x": 1010,
                      "y": 560,
                      "wires": [
                              "1584a54e77837dbd"
                              "a8b609cc983f0b37",
                              "1584a54e77837dbd"
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "true"
                              "t": "false"
                              "t": "eq",
                              "v": "",
                              "vt": "str"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 3,
                      "x": 1190,
                      "y": 460,
                      "wires": [
                              "0e43213215238d27"
                              "0e43213215238d27"
                      "type": "change",
                      "name": "on/off",
                      "rules": [
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "on",
                              "fromt": "str",
                              "to": "true",
                              "tot": "bool"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "off",
                              "fromt": "str",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 990,
                      "y": 460,
                      "wires": [
                              "774f8f940a2c4c96"
                      "type": "change",
                      "name": "on",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "on",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 810,
                      "y": 420,
                      "wires": [
                              "e8865a546b6ee97f"
                      "x": 340,
                      "y": 640,
                      "wires": [
                              "661eb84a02820976"
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "false"
                              "t": "true"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 430,
                      "y": 580,
                      "wires": [
                              "a8a0cb4a1682f9f2",
                              "3bd2c8cd8fbc4e0d"
                              "638dc14da90f5eb4",
                              "d5b7b0bf08213264",
                              "8791ca72f579691c"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1220,
                      "y": 560,
                      "wires": [
                              "0e43213215238d27"
                      "type": "change",
                      "name": "stop",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "stop",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 610,
                      "y": 620,
                      "wires": [
                              "5f9435538ec534ed",
                              "9b6cc9d834347e2b"
                      "name": "10min.",
                      "outtopic": "",
                      "outsafe": "on",
                      "outunsafe": "off",
                      "warning": "10",
                      "timer": "600",
                      "debug": false,
                      "ndebug": false,
                      "repeat": false,
                      "again": false,
                      "x": 770,
                      "y": 560,
                      "wires": [
                              "4deb5666bac8cf44"
                      "name": "3Min.",
                      "outtopic": "",
                      "outsafe": "on",
                      "outunsafe": "off",
                      "warning": "10",
                      "timer": "180",
                      "debug": false,
                      "ndebug": false,
                      "repeat": false,
                      "again": false,
                      "x": 990,
                      "y": 500,
                      "wires": [
                              "bcc31acbfde45d97"
                      "name": "Hue",
                      "x": 130,
                      "y": 500,
                      "wires": [
                              "d500eca26ab86278"
                      "name": "KüMo",
                      "initevents": true,
                      "x": 270,
                      "y": 500,
                      "wires": [
                              "169c9cd74337485f",
                              "a4c8574588c0de3c"
                      "name": "U-rechts",
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1320,
                      "y": 740,
                      "wires": []
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1330,
                      "y": 620,
                      "wires": []
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1340,
                      "y": 680,
                      "wires": []
                      "type": "debug",
                      "name": "Küche",
                      "active": true,
                      "tosidebar": true,
                      "console": true,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1440,
                      "y": 860,
                      "wires": []
                      "type": "change",
                      "name": "Küche",
                      "rules": [
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "1000",
                              "fromt": "str",
                              "to": "Küche",
                              "tot": "str"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "true",
                              "fromt": "bool",
                              "tot": "str"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "false",
                              "fromt": "bool",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1310,
                      "y": 860,
                      "wires": [
                              "b16aaa4000874ffd"
                      "name": "U-links",
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1430,
                      "y": 800,
                      "wires": []
                      "type": "inject",
                      "name": "",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "1000",
                      "x": 90,
                      "y": 720,
                      "wires": [
                              "95fda7a91b84c03f"
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 80,
                      "y": 660,
                      "wires": [
                              "95fda7a91b84c03f"
                      "type": "delay",
                      "name": "100ms",
                      "timeout": "100",
                      "rate": "1",
                      "nbRateUnits": "1",
                      "randomFirst": "1",
                      "randomLast": "5",
                      "drop": false,
                      "allowrate": false,
                      "outputs": 1,
                      "x": 1310,
                      "y": 800,
                      "wires": [
                              "08276b1f6580fc56"
                      "type": "inject",
                      "props": [
                              "v": "true",
                              "vt": "bool"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "x": 240,
                      "y": 460,
                      "wires": [
                              "169c9cd74337485f",
                              "e1f5f49327a29a8a"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "pt": "msg",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 450,
                      "y": 460,
                      "wires": [
                              "169c9cd74337485f"
                      "type": "junction",
                      "x": 1060,
                      "y": 600,
                      "wires": [
                              "3c6f79231d0fc04b",
                              "a8b609cc983f0b37"
                      "type": "junction",
                      "x": 1160,
                      "y": 680,
                      "wires": [
                              "ce64922d78c18bb2",
                              "f5195df37114b7de",
                              "631201f88292c2d6",
                              "400b88291d913b81",
                              "3c0717cd3d6e108e"
                      "type": "junction",
                      "x": 1100,
                      "y": 480,
                      "wires": [
                              "612158a90f7d1a23"
                      "type": "junction",
                      "x": 980,
                      "y": 640,
                      "wires": [
                              "90f844739a331c64"
                      "type": "junction",
                      "x": 540,
                      "y": 560,
                      "wires": [
                              "5925b1db569c695b"
                      "type": "junction",
                      "x": 540,
                      "y": 580,
                      "wires": [
                              "3648551e97ec2cab"
                      "type": "junction",
                      "x": 880,
                      "y": 620,
                      "wires": [
                              "e8865a546b6ee97f"
                      "type": "junction",
                      "x": 1260,
                      "y": 480,
                      "wires": [
                              "0e43213215238d27"
                      "type": "junction",
                      "x": 560,
                      "y": 640,
                      "wires": [
                              "e9a12ac84d11dd0e"
                      "worker": "10",
              peterfido
              @aphofis Das ist eine neue Variante. Meine "Simulation" des HUE Bewegungsmelders hast Du noch nicht verinnerlicht. Die ist rein für Tests, oder, wenn man wie ich keinen HUE BWM hat. Das ist nur für die Simulation zum Testen, und dann auch erst nach einer Zeit x vorgesehen. Jetzt wird zeitgleich payload.motion auf false gesetzt, auch wenn der HUE BWM meldet.
              Ich habe es jetzt nicht importiert / ausprobiert.
              Eine Idee:
              Der HUE Bewegungsmelder geht seine eigenen Wege. Wenn das Licht nicht aus, bzw. gleich wieder an geht, könnte einer erkannten, oder noch anstehenden Bewegung geschuldet sein. Da könnte man eine Sperrvarable setzen, bzw. nur Änderungen durchlassen. Zumindest lief die von mir zuletzt gepostete Variante in meiner Testumgebung. Möglich, dass Dein BWM / Taster / Schalter da was unerwartetes losschickt.
              Hier mein aufgeräumter Flow.
                     "type": "tab",
                     "label": "Flow 8",
                     "disabled": false,
                     "info": "",
                     "env": []
                     "type": "junction",
                     "x": 1120,
                     "y": 660,
                     "wires": [
                             "141a052859674836",
                             "574a9f7ddc4f663b",
                             "b6322a40cf4557b3"
                     "type": "junction",
                     "x": 1960,
                     "y": 460,
                     "wires": [
                             "ff32f89078260f0e",
                             "67e2e01a1266d1c3",
                             "e98816534075b0f5",
                             "21f36ea2695afe19",
                             "a695276a00fe8f61"
                     "type": "junction",
                     "x": 1140,
                     "y": 260,
                     "wires": [
                             "ba0aea0ff71ebc3d"
                     "type": "junction",
                     "x": 520,
                     "y": 60,
                     "wires": [
                             "d24a5429e472b18a"
                     "type": "junction",
                     "x": 900,
                     "y": 440,
                     "wires": [
                             "84bd4ea1d044fea4",
                             "ed2607cafe826532"
                     "type": "junction",
                     "x": 980,
                     "y": 360,
                     "wires": [
                             "be66da991b562e24"
                     "type": "junction",
                     "x": 1280,
                     "y": 360,
                     "wires": [
                             "fa5f2b5bcd258a98"
                     "id": "8355cf791b8a8b1b",
                     "type": "junction",
                     "x": 580,
                     "y": 560,
                     "wires": [
                             "e22b60db6265e908"
                     "id": "1ee1fe89c1628b34",
                     "type": "junction",
                     "x": 580,
                     "y": 560,
                     "wires": [
                             "e22b60db6265e908"
                     "id": "f3921b2658b5916c",
                     "type": "junction",
                     "x": 240,
                     "y": 560,
                     "wires": [
                             "1ee1fe89c1628b34"
                     "type": "inject",
                     "props": [
                             "v": "true",
                             "vt": "bool"
                             "p": "topic",
                             "vt": "str"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "x": 140,
                     "y": 380,
                     "wires": [
                             "a919a4c30d900c39",
                             "0150c15cf7b51170"
                     "type": "debug",
                     "name": "debug 3",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "complete": "true",
                     "statusVal": "",
                     "x": 2000,
                     "y": 360,
                     "wires": []
                     "type": "delay",
                     "name": "",
                     "timeout": "30",
                     "rate": "1",
                     "nbRateUnits": "1",
                     "randomFirst": "1",
                     "randomLast": "5",
                     "drop": false,
                     "allowrate": false,
                     "outputs": 1,
                     "x": 150,
                     "y": 460,
                     "wires": [
                             "bee64eb116d76ed1"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "pt": "msg",
                             "to": "false",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 350,
                     "y": 460,
                     "wires": [
                             "0150c15cf7b51170"
                     "type": "switch",
                     "name": "Schalter",
                     "rules": [
                             "t": "true"
                             "t": "false"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 920,
                     "y": 260,
                     "wires": [
                             "01fea99b98c641a3"
                     "type": "change",
                     "name": "Motion",
                     "rules": [
                             "t": "set",
                             "p": "bewegung",
                             "pt": "flow",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 670,
                     "y": 320,
                     "wires": [
                     "type": "comment",
                     "name": "Beginn << Für Simulation Für Simulation Für Simulation Für Simulation >>",
                     "info": "",
                     "x": 280,
                     "y": 300,
                     "wires": []
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "on",
                             "tot": "str"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 710,
                     "y": 400,
                     "wires": [
                             "ed2607cafe826532"
                     "type": "switch",
                     "name": "1000?",
                     "rules": [
                             "t": "eq",
                             "v": "1000",
                             "vt": "num"
                             "t": "eq",
                             "v": "",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 310,
                     "y": 660,
                     "wires": [
                             "6ae2e0e61f81faeb"
                     "type": "switch",
                     "name": "Robi",
                     "property": "BWM",
                     "rules": [
                             "t": "true"
                             "t": "false"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 1050,
                     "y": 260,
                     "wires": [
                             "ae8ceff406113f11"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "stopp",
                             "pt": "flow",
                             "to": "true",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 890,
                     "y": 600,
                     "wires": [
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "stopp",
                             "pt": "flow",
                             "to": "false",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1370,
                     "y": 600,
                     "wires": [
                     "type": "function",
                     "outputs": 1,
                     "timeout": 0,
                     "noerr": 0,
                     "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\nflow.set(\"bewegung\", false);\n",
                     "finalize": "",
                     "libs": [],
                     "x": 1770,
                     "y": 380,
                     "wires": [
                             "ed06e85de97289c8",
                             "423ea0f1dc0e4d31"
                     "name": "Robi",
                     "onlyack": "",
                     "func": "all",
                     "gap": "",
                     "x": 90,
                     "y": 780,
                     "wires": [
                             "6b214a0a59b5e04a"
                     "type": "function",
                     "outputs": 1,
                     "timeout": 0,
                     "noerr": 0,
                     "initialize": "",
                     "finalize": "",
                     "libs": [],
                     "x": 360,
                     "y": 360,
                     "wires": [
                             "0395e4bbb7c67e21"
                     "onlyack": "",
                     "func": "all",
                     "gap": "",
                     "x": 100,
                     "y": 680,
                     "wires": [
                             "e22b60db6265e908"
                     "type": "switch",
                     "name": "8?",
                     "rules": [
                             "t": "eq",
                             "v": "8",
                             "vt": "num"
                             "t": "neq",
                             "v": "8",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 630,
                     "y": 780,
                     "wires": [
                             "7b9c0fa6e795af2d"
                             "ccadbb1ee1de29e6"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "BWM",
                             "pt": "flow",
                             "to": "true",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 850,
                     "y": 760,
                     "wires": [
                             "b117dac109d51b34"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "BWM",
                             "pt": "flow",
                             "to": "false",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 850,
                     "y": 800,
                     "wires": [
                             "b117dac109d51b34"
                     "type": "comment",
                     "info": "",
                     "x": 980,
                     "y": 220,
                     "wires": []
                     "type": "switch",
                     "name": "nur true",
                     "rules": [
                             "t": "true"
                             "t": "false"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 740,
                     "y": 240,
                     "wires": [
                             "ab41883686b27cc0"
                     "type": "debug",
                     "name": "debug 4",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "complete": "true",
                     "statusVal": "",
                     "x": 1040,
                     "y": 760,
                     "wires": []
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "change",
                             "p": "payload",
                             "pt": "msg",
                             "from": "on",
                             "fromt": "str",
                             "to": "true",
                             "tot": "bool"
                             "t": "change",
                             "p": "payload",
                             "pt": "msg",
                             "from": "off",
                             "fromt": "str",
                             "to": "false",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1290,
                     "y": 400,
                     "wires": [
                             "d303b6e1817d8b77"
                     "type": "switch",
                     "name": "",
                     "rules": [
                             "t": "true"
                             "t": "false"
                             "t": "eq",
                             "v": "",
                             "vt": "str"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 3,
                     "x": 1470,
                     "y": 400,
                     "wires": [
                             "331a07cfba2d7df1"
                             "331a07cfba2d7df1",
                             "574a9f7ddc4f663b"
                     "type": "switch",
                     "name": "",
                     "rules": [
                             "t": "true"
                             "t": "false"
                             "t": "eq",
                             "v": "",
                             "vt": "str"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 3,
                     "x": 1770,
                     "y": 260,
                     "wires": [
                             "331a07cfba2d7df1"
                             "331a07cfba2d7df1"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "change",
                             "p": "payload",
                             "pt": "msg",
                             "from": "on",
                             "fromt": "str",
                             "to": "true",
                             "tot": "bool"
                             "t": "change",
                             "p": "payload",
                             "pt": "msg",
                             "from": "off",
                             "fromt": "str",
                             "to": "false",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1610,
                     "y": 260,
                     "wires": [
                             "b4e55cb04c30244e"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "on",
                             "tot": "str"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1250,
                     "y": 260,
                     "wires": [
                             "fa5f2b5bcd258a98"
                     "x": 500,
                     "y": 660,
                     "wires": [
                             "cf3016a536d38a8d"
                     "type": "switch",
                     "rules": [
                             "t": "false"
                             "t": "true"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 680,
                     "y": 660,
                     "wires": [
                             "7eea52e80cbe51f0",
                             "93f0d4c85ab42e59"
                             "7b9c0fa6e795af2d",
                             "87ec46662c49de4e",
                             "f00e20abd94ff43d"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "false",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1380,
                     "y": 640,
                     "wires": [
                             "331a07cfba2d7df1"
                     "type": "change",
                     "name": "stop",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "stop",
                             "tot": "str"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1010,
                     "y": 640,
                     "wires": [
                             "d96f128a59bdfbb4"
                     "name": "45sek",
                     "outtopic": "",
                     "outsafe": "on",
                     "outunsafe": "off",
                     "warning": "10",
                     "timer": "60",
                     "debug": false,
                     "ndebug": false,
                     "repeat": false,
                     "again": false,
                     "x": 1090,
                     "y": 400,
                     "wires": [
                             "91febc7692f9b822"
                     "name": "10Sek",
                     "outtopic": "",
                     "outsafe": "on",
                     "outunsafe": "off",
                     "warning": "10",
                     "timer": "30",
                     "debug": false,
                     "ndebug": false,
                     "repeat": false,
                     "again": false,
                     "x": 1430,
                     "y": 260,
                     "wires": [
                             "90c9685b4a5344dc"
                     "name": "U-rechts",
                     "ack": "false",
                     "stateName": "",
                     "role": "",
                     "payloadType": "",
                     "readonly": "",
                     "stateUnit": "",
                     "stateMin": "",
                     "stateMax": "",
                     "x": 2140,
                     "y": 600,
                     "wires": []
                     "ack": "false",
                     "stateName": "",
                     "role": "",
                     "payloadType": "",
                     "readonly": "",
                     "stateUnit": "",
                     "stateMin": "",
                     "stateMax": "",
                     "x": 2210,
                     "y": 460,
                     "wires": []
                     "ack": "false",
                     "autoCreate": "true",
                     "stateName": "Simlulierte Lampe",
                     "role": "value",
                     "payloadType": "boolean",
                     "readonly": "",
                     "stateUnit": "",
                     "stateMin": "",
                     "stateMax": "",
                     "x": 2160,
                     "y": 540,
                     "wires": []
                     "type": "debug",
                     "name": "Küche",
                     "active": false,
                     "tosidebar": true,
                     "console": true,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 2160,
                     "y": 760,
                     "wires": []
                     "type": "delay",
                     "name": "100ms",
                     "timeout": "100",
                     "rate": "1",
                     "nbRateUnits": "1",
                     "randomFirst": "1",
                     "randomLast": "5",
                     "drop": false,
                     "allowrate": false,
                     "outputs": 1,
                     "x": 2070,
                     "y": 460,
                     "wires": [
                             "084e7114b7ed1c61"
                     "type": "change",
                     "name": "Küche",
                     "rules": [
                             "t": "change",
                             "p": "payload",
                             "pt": "msg",
                             "from": "1000",
                             "fromt": "str",
                             "to": "Küche",
                             "tot": "str"
                             "t": "change",
                             "p": "payload",
                             "pt": "msg",
                             "from": "true",
                             "fromt": "bool",
                             "tot": "str"
                             "t": "change",
                             "p": "payload",
                             "pt": "msg",
                             "from": "false",
                             "fromt": "bool",
                             "tot": "str"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 2030,
                     "y": 760,
                     "wires": [
                             "442c2ef743d9599f"
                     "name": "U-links",
                     "ack": "false",
                     "stateName": "",
                     "role": "",
                     "payloadType": "",
                     "readonly": "",
                     "stateUnit": "",
                     "stateMin": "",
                     "stateMax": "",
                     "x": 2130,
                     "y": 680,
                     "wires": []
                     "name": "Hue",
                     "x": 130,
                     "y": 160,
                     "wires": [
                             "2e0c2a67486c0ac7"
                     "initevents": true,
                     "x": 360,
                     "y": 160,
                     "wires": [
                             "0395e4bbb7c67e21"
                     "type": "inject",
                     "name": "Takt",
                     "props": [
                             "p": "payload"
                             "p": "topic",
                             "vt": "str"
                     "repeat": "1",
                     "crontab": "",
                     "once": true,
                     "onceDelay": 0.1,
                     "topic": "Takt",
                     "payload": "true",
                     "x": 130,
                     "y": 60,
                     "wires": [
                             "26a06677287b879b"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "bewegung",
                             "tot": "flow"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 370,
                     "y": 60,
                     "wires": [
                             "9c7c62ee37b6b12c"
                     "type": "inject",
                     "props": [
                             "p": "payload"
                             "p": "topic",
                             "vt": "str"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "1000",
                     "x": 130,
                     "y": 520,
                     "wires": [
                             "64bf8df5efc25d40",
                             "f3921b2658b5916c"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "bewegung",
                             "pt": "flow",
                             "to": "false",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1390,
                     "y": 680,
                     "wires": [
                     "type": "comment",
                     "name": "Ende << Für Simulation Für Simulation Für Simulation Für Simulation >>",
                     "info": "",
                     "x": 270,
                     "y": 580,
                     "wires": []
                     "type": "comment",
                     "info": "",
                     "x": 980,
                     "y": 320,
                     "wires": []
                     "id": "64bf8df5efc25d40",
                     "type": "delay",
                     "name": "200 ms",
                     "timeout": "200",
                     "rate": "1",
                     "nbRateUnits": "1",
                     "randomFirst": "1",
                     "randomLast": "5",
                     "drop": false,
                     "allowrate": false,
                     "outputs": 1,
                     "x": 300,
                     "y": 520,
                     "wires": [
                             "d628f1137cfb08c1"
                     "id": "d628f1137cfb08c1",
                     "type": "change",
                     "name": "1002",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "1002",
                             "tot": "num"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 430,
                     "y": 520,
                     "wires": [
                             "8355cf791b8a8b1b"
                     "id": "9a70fab410cfbdae",
                     "type": "inject",
                     "name": "Test Robi 8",
                     "props": [
                             "p": "payload"
                             "p": "topic",
                             "vt": "str"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "8",
                     "x": 120,
                     "y": 840,
                     "wires": [
                             "6b214a0a59b5e04a"
                     "id": "10a3703ea5e9c5fd",
                     "type": "inject",
                     "name": "Test Robi 5",
                     "props": [
                             "p": "payload"
                             "p": "topic",
                             "vt": "str"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "5",
                     "x": 120,
                     "y": 900,
                     "wires": [
                             "6b214a0a59b5e04a"
                     "worker": "10",
              Peterfido
              • P peterfido
                Eine Idee:
                       "type": "tab",
                       "label": "Flow 8",
                       "disabled": false,
                       "info": "",
                       "env": []
                       "type": "junction",
                       "x": 1120,
                       "y": 660,
                       "wires": [
                               "141a052859674836",
                               "574a9f7ddc4f663b",
                               "b6322a40cf4557b3"
                       "type": "junction",
                       "x": 1960,
                       "y": 460,
                       "wires": [
                               "ff32f89078260f0e",
                               "67e2e01a1266d1c3",
                               "e98816534075b0f5",
                               "21f36ea2695afe19",
                               "a695276a00fe8f61"
                       "type": "junction",
                       "x": 1140,
                       "y": 260,
                       "wires": [
                               "ba0aea0ff71ebc3d"
                       "type": "junction",
                       "x": 520,
                       "y": 60,
                       "wires": [
                               "d24a5429e472b18a"
                       "type": "junction",
                       "x": 900,
                       "y": 440,
                       "wires": [
                               "84bd4ea1d044fea4",
                               "ed2607cafe826532"
                       "type": "junction",
                       "x": 980,
                       "y": 360,
                       "wires": [
                               "be66da991b562e24"
                       "type": "junction",
                       "x": 1280,
                       "y": 360,
                       "wires": [
                               "fa5f2b5bcd258a98"
                       "type": "junction",
                       "x": 580,
                       "y": 560,
                       "wires": [
                               "e22b60db6265e908"
                       "type": "junction",
                       "x": 580,
                       "y": 560,
                       "wires": [
                               "e22b60db6265e908"
                       "type": "junction",
                       "x": 240,
                       "y": 560,
                       "wires": [
                               "1ee1fe89c1628b34"
                       "type": "inject",
                       "props": [
                               "v": "true",
                               "vt": "bool"
                               "p": "topic",
                               "vt": "str"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "x": 140,
                       "y": 380,
                       "wires": [
                               "a919a4c30d900c39",
                               "0150c15cf7b51170"
                       "type": "debug",
                       "name": "debug 3",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "true",
                       "statusVal": "",
                       "x": 2000,
                       "y": 360,
                       "wires": []
                       "type": "delay",
                       "name": "",
                       "timeout": "30",
                       "rate": "1",
                       "nbRateUnits": "1",
                       "randomFirst": "1",
                       "randomLast": "5",
                       "drop": false,
                       "allowrate": false,
                       "outputs": 1,
                       "x": 150,
                       "y": 460,
                       "wires": [
                               "bee64eb116d76ed1"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "pt": "msg",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 350,
                       "y": 460,
                       "wires": [
                               "0150c15cf7b51170"
                       "type": "switch",
                       "name": "Schalter",
                       "rules": [
                               "t": "true"
                               "t": "false"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 920,
                       "y": 260,
                       "wires": [
                               "01fea99b98c641a3"
                       "type": "change",
                       "name": "Motion",
                       "rules": [
                               "t": "set",
                               "p": "bewegung",
                               "pt": "flow",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 670,
                       "y": 320,
                       "wires": [
                       "type": "comment",
                       "info": "",
                       "x": 280,
                       "y": 300,
                       "wires": []
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "on",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 710,
                       "y": 400,
                       "wires": [
                               "ed2607cafe826532"
                       "type": "switch",
                       "name": "1000?",
                       "rules": [
                               "t": "eq",
                               "v": "1000",
                               "vt": "num"
                               "t": "eq",
                               "v": "",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 310,
                       "y": 660,
                       "wires": [
                               "6ae2e0e61f81faeb"
                       "type": "switch",
                       "name": "Robi",
                       "property": "BWM",
                       "rules": [
                               "t": "true"
                               "t": "false"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 1050,
                       "y": 260,
                       "wires": [
                               "ae8ceff406113f11"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "stopp",
                               "pt": "flow",
                               "to": "true",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 890,
                       "y": 600,
                       "wires": [
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "stopp",
                               "pt": "flow",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1370,
                       "y": 600,
                       "wires": [
                       "type": "function",
                       "outputs": 1,
                       "timeout": 0,
                       "noerr": 0,
                       "finalize": "",
                       "libs": [],
                       "x": 1770,
                       "y": 380,
                       "wires": [
                               "ed06e85de97289c8",
                               "423ea0f1dc0e4d31"
                       "name": "Robi",
                       "onlyack": "",
                       "func": "all",
                       "gap": "",
                       "x": 90,
                       "y": 780,
                       "wires": [
                               "6b214a0a59b5e04a"
                       "type": "function",
                       "outputs": 1,
                       "timeout": 0,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 360,
                       "y": 360,
                       "wires": [
                               "0395e4bbb7c67e21"
                       "onlyack": "",
                       "func": "all",
                       "gap": "",
                       "x": 100,
                       "y": 680,
                       "wires": [
                               "e22b60db6265e908"
                       "type": "switch",
                       "name": "8?",
                       "rules": [
                               "t": "eq",
                               "v": "8",
                               "vt": "num"
                               "t": "neq",
                               "v": "8",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 630,
                       "y": 780,
                       "wires": [
                               "7b9c0fa6e795af2d"
                               "ccadbb1ee1de29e6"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "BWM",
                               "pt": "flow",
                               "to": "true",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 850,
                       "y": 760,
                       "wires": [
                               "b117dac109d51b34"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "BWM",
                               "pt": "flow",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 850,
                       "y": 800,
                       "wires": [
                               "b117dac109d51b34"
                       "type": "comment",
                       "info": "",
                       "x": 980,
                       "y": 220,
                       "wires": []
                       "type": "switch",
                       "name": "nur true",
                       "rules": [
                               "t": "true"
                               "t": "false"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 740,
                       "y": 240,
                       "wires": [
                               "ab41883686b27cc0"
                       "type": "debug",
                       "name": "debug 4",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "true",
                       "statusVal": "",
                       "x": 1040,
                       "y": 760,
                       "wires": []
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "on",
                               "fromt": "str",
                               "to": "true",
                               "tot": "bool"
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "off",
                               "fromt": "str",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1290,
                       "y": 400,
                       "wires": [
                               "d303b6e1817d8b77"
                       "type": "switch",
                       "name": "",
                       "rules": [
                               "t": "true"
                               "t": "false"
                               "t": "eq",
                               "v": "",
                               "vt": "str"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 3,
                       "x": 1470,
                       "y": 400,
                       "wires": [
                               "331a07cfba2d7df1"
                               "331a07cfba2d7df1",
                               "574a9f7ddc4f663b"
                       "type": "switch",
                       "name": "",
                       "rules": [
                               "t": "true"
                               "t": "false"
                               "t": "eq",
                               "v": "",
                               "vt": "str"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 3,
                       "x": 1770,
                       "y": 260,
                       "wires": [
                               "331a07cfba2d7df1"
                               "331a07cfba2d7df1"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "on",
                               "fromt": "str",
                               "to": "true",
                               "tot": "bool"
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "off",
                               "fromt": "str",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1610,
                       "y": 260,
                       "wires": [
                               "b4e55cb04c30244e"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "on",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1250,
                       "y": 260,
                       "wires": [
                               "fa5f2b5bcd258a98"
                       "x": 500,
                       "y": 660,
                       "wires": [
                               "cf3016a536d38a8d"
                       "type": "switch",
                       "rules": [
                               "t": "false"
                               "t": "true"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 680,
                       "y": 660,
                       "wires": [
                               "7eea52e80cbe51f0",
                               "93f0d4c85ab42e59"
                               "7b9c0fa6e795af2d",
                               "87ec46662c49de4e",
                               "f00e20abd94ff43d"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1380,
                       "y": 640,
                       "wires": [
                               "331a07cfba2d7df1"
                       "type": "change",
                       "name": "stop",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "stop",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1010,
                       "y": 640,
                       "wires": [
                               "d96f128a59bdfbb4"
                       "name": "45sek",
                       "outtopic": "",
                       "outsafe": "on",
                       "outunsafe": "off",
                       "warning": "10",
                       "timer": "60",
                       "debug": false,
                       "ndebug": false,
                       "repeat": false,
                       "again": false,
                       "x": 1090,
                       "y": 400,
                       "wires": [
                               "91febc7692f9b822"
                       "name": "10Sek",
                       "outtopic": "",
                       "outsafe": "on",
                       "outunsafe": "off",
                       "warning": "10",
                       "timer": "30",
                       "debug": false,
                       "ndebug": false,
                       "repeat": false,
                       "again": false,
                       "x": 1430,
                       "y": 260,
                       "wires": [
                               "90c9685b4a5344dc"
                       "name": "U-rechts",
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 2140,
                       "y": 600,
                       "wires": []
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 2210,
                       "y": 460,
                       "wires": []
                       "ack": "false",
                       "role": "value",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 2160,
                       "y": 540,
                       "wires": []
                       "type": "debug",
                       "name": "Küche",
                       "active": false,
                       "tosidebar": true,
                       "console": true,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 2160,
                       "y": 760,
                       "wires": []
                       "type": "delay",
                       "name": "100ms",
                       "timeout": "100",
                       "rate": "1",
                       "nbRateUnits": "1",
                       "randomFirst": "1",
                       "randomLast": "5",
                       "drop": false,
                       "allowrate": false,
                       "outputs": 1,
                       "x": 2070,
                       "y": 460,
                       "wires": [
                               "084e7114b7ed1c61"
                       "type": "change",
                       "name": "Küche",
                       "rules": [
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "1000",
                               "fromt": "str",
                               "to": "Küche",
                               "tot": "str"
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "true",
                               "fromt": "bool",
                               "tot": "str"
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "false",
                               "fromt": "bool",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 2030,
                       "y": 760,
                       "wires": [
                               "442c2ef743d9599f"
                       "name": "U-links",
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 2130,
                       "y": 680,
                       "wires": []
                       "name": "Hue",
                       "x": 130,
                       "y": 160,
                       "wires": [
                               "2e0c2a67486c0ac7"
                       "initevents": true,
                       "x": 360,
                       "y": 160,
                       "wires": [
                               "0395e4bbb7c67e21"
                       "type": "inject",
                       "name": "Takt",
                       "props": [
                               "p": "payload"
                               "p": "topic",
                               "vt": "str"
                       "repeat": "1",
                       "crontab": "",
                       "once": true,
                       "onceDelay": 0.1,
                       "topic": "Takt",
                       "payload": "true",
                       "x": 130,
                       "y": 60,
                       "wires": [
                               "26a06677287b879b"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "bewegung",
                               "tot": "flow"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 370,
                       "y": 60,
                       "wires": [
                               "9c7c62ee37b6b12c"
                       "type": "inject",
                       "props": [
                               "p": "payload"
                               "p": "topic",
                               "vt": "str"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "1000",
                       "x": 130,
                       "y": 520,
                       "wires": [
                               "64bf8df5efc25d40",
                               "f3921b2658b5916c"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "bewegung",
                               "pt": "flow",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1390,
                       "y": 680,
                       "wires": [
                       "type": "comment",
                       "info": "",
                       "x": 270,
                       "y": 580,
                       "wires": []
                       "type": "comment",
                       "info": "",
                       "x": 980,
                       "y": 320,
                       "wires": []
                       "type": "delay",
                       "name": "200 ms",
                       "timeout": "200",
                       "rate": "1",
                       "nbRateUnits": "1",
                       "randomFirst": "1",
                       "randomLast": "5",
                       "drop": false,
                       "allowrate": false,
                       "outputs": 1,
                       "x": 300,
                       "y": 520,
                       "wires": [
                               "d628f1137cfb08c1"
                       "type": "change",
                       "name": "1002",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "1002",
                               "tot": "num"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 430,
                       "y": 520,
                       "wires": [
                               "8355cf791b8a8b1b"
                       "type": "inject",
                       "props": [
                               "p": "payload"
                               "p": "topic",
                               "vt": "str"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "8",
                       "x": 120,
                       "y": 840,
                       "wires": [
                               "6b214a0a59b5e04a"
                       "type": "inject",
                       "props": [
                               "p": "payload"
                               "p": "topic",
                               "vt": "str"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "5",
                       "x": 120,
                       "y": 900,
                       "wires": [
                               "6b214a0a59b5e04a"
                       "worker": "10",
                AphofisA Offline
                AphofisA Offline
                Aphofis
                @peterfido
                Also soweit funktionierts nur irgend etwas schaltet mitten drin nach klick schalter die lampen ab
                hab schon paar debug nodes angehängt finde aber nicht wer das macht.
                Wenn man nach der selbst abschaltung dann in den BWM läuft geht das licht wieder an.
                Wenn man also schalter schaltet geht das licht nach paar sekunden alleine aus und es kommt keine debug ausgabe. geht man in den BWM gehts licht wieder an und bleibt auch für eingestellte zeit an und bei wiederbewegung blitzt das licht einmal kurz und ist dann aber wieder an.
                BWM / Roboter Sauger funktioniert soweit.
                        "id": "cd388a27e1177b2a",
                        "type": "tab",
                        "label": "Flow 8",
                        "disabled": false,
                        "info": "",
                        "env": []
                        "id": "c858be985d04ff23",
                        "type": "junction",
                        "z": "cd388a27e1177b2a",
                        "x": 680,
                        "y": 560,
                        "wires": [
                                "e52cacfb28f4eef0",
                                "d4243e5842d002b7",
                                "f4dd19c85bec8f67"
                        "id": "49ed5c100ffadbfb",
                        "type": "junction",
                        "x": 1060,
                        "y": 600,
                        "wires": [
                                "3da3568f5cb1d905",
                                "d9b21aa55e80ae44",
                                "c9f5b344739be161",
                                "a0d644333024864d"
                        "id": "6b29472d446bd70a",
                        "type": "junction",
                        "x": 680,
                        "y": 320,
                        "wires": [
                                "1f6129972520dbc9",
                                "2cf7c09b18238747"
                        "id": "97a52cd45dee491f",
                        "type": "junction",
                        "x": 1060,
                        "y": 460,
                        "wires": [
                                "49ed5c100ffadbfb"
                        "id": "17a82c94f393c061",
                        "type": "junction",
                        "x": 160,
                        "y": 520,
                        "wires": [
                                "34daca3383213026"
                        "id": "f2c58fd53288296d",
                        "type": "debug",
                        "name": "debug 3",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "complete": "true",
                        "targetType": "full",
                        "statusVal": "",
                        "statusType": "auto",
                        "x": 1400,
                        "y": 420,
                        "wires": []
                        "id": "25ad2bdbb9a6a3f2",
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "payload.motion",
                                "pt": "msg",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 310,
                        "y": 420,
                        "wires": [
                                "c5344e2d70758330"
                        "id": "6fa8c560705cd84b",
                        "type": "switch",
                        "name": "Schalter",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 560,
                        "y": 280,
                        "wires": [
                                "e5b4dd5e0fdf55b3"
                        "id": "7cade0980ce23b6f",
                        "type": "change",
                        "name": "Motion",
                        "rules": [
                                "t": "set",
                                "p": "bewegung",
                                "pt": "flow",
                                "tot": "msg"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 470,
                        "y": 320,
                        "wires": [
                        "id": "1d02d4d287c62d8d",
                        "type": "change",
                        "name": "set payload",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "on",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 610,
                        "y": 360,
                        "wires": [
                                "1f6129972520dbc9"
                        "id": "edd034e0ac4e9dbd",
                        "type": "switch",
                        "name": "1000?",
                        "rules": [
                                "t": "eq",
                                "v": "1000",
                                "vt": "num"
                                "t": "eq",
                                "v": "",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 230,
                        "y": 460,
                        "wires": [
                                "b3cf3d5c5932a0f1"
                        "id": "e5b4dd5e0fdf55b3",
                        "type": "switch",
                        "name": "Robi",
                        "property": "BWM",
                        "propertyType": "flow",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 690,
                        "y": 280,
                        "wires": [
                                "eb53173feca16754"
                        "id": "6ad2e1e41e7eba3d",
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "stopp",
                                "pt": "flow",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 630,
                        "y": 460,
                        "wires": [
                        "id": "d4243e5842d002b7",
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "stopp",
                                "pt": "flow",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 830,
                        "y": 560,
                        "wires": [
                        "id": "0649103700725132",
                        "type": "function",
                        "outputs": 1,
                        "timeout": 0,
                        "noerr": 0,
                        "finalize": "",
                        "libs": [],
                        "x": 1170,
                        "y": 420,
                        "wires": [
                                "f2c58fd53288296d",
                                "97a52cd45dee491f"
                        "id": "5b195fc1f7acb5c0",
                        "name": "Robi",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 110,
                        "y": 600,
                        "wires": [
                                "7f79db16bb82a357"
                        "id": "c5344e2d70758330",
                        "type": "function",
                        "outputs": 1,
                        "timeout": 0,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 300,
                        "y": 380,
                        "wires": [
                                "7cade0980ce23b6f"
                        "id": "d4e6916ec6660771",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 80,
                        "y": 460,
                        "wires": [
                                "edd034e0ac4e9dbd"
                        "id": "7f79db16bb82a357",
                        "type": "switch",
                        "name": "8?",
                        "property": "payload",
                        "propertyType": "msg",
                        "rules": [
                                "t": "eq",
                                "v": "8",
                                "vt": "num"
                                "t": "neq",
                                "v": "8",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 230,
                        "y": 600,
                        "wires": [
                                "34daca3383213026"
                                "9725d7651f53e931"
                        "id": "34daca3383213026",
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "BWM",
                                "pt": "flow",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 410,
                        "y": 580,
                        "wires": [
                                "3d95821769504d11"
                        "id": "9725d7651f53e931",
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "BWM",
                                "pt": "flow",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 410,
                        "y": 620,
                        "wires": [
                                "3d95821769504d11"
                        "id": "6a9e975c8a2cb22e",
                        "type": "switch",
                        "name": "nur true",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 420,
                        "y": 280,
                        "wires": [
                                "6fa8c560705cd84b"
                        "id": "3d95821769504d11",
                        "type": "debug",
                        "name": "debug 4",
                        "active": false,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "complete": "true",
                        "statusVal": "",
                        "x": 580,
                        "y": 600,
                        "wires": []
                        "id": "19d59c4b02bc1d4e",
                        "type": "change",
                        "name": "true/on/false/off",
                        "rules": [
                                "t": "change",
                                "p": "payload",
                                "pt": "msg",
                                "from": "on",
                                "fromt": "str",
                                "to": "true",
                                "tot": "bool"
                                "t": "change",
                                "p": "payload",
                                "pt": "msg",
                                "from": "off",
                                "fromt": "str",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 820,
                        "y": 440,
                        "wires": [
                                "2b6788c8f61bc75d"
                        "id": "2b6788c8f61bc75d",
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "true"
                                "t": "false"
                                "t": "eq",
                                "v": "",
                                "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 3,
                        "x": 830,
                        "y": 500,
                        "wires": [
                                "0649103700725132",
                                "22f763e23b4b426d"
                                "0649103700725132",
                                "d4243e5842d002b7",
                                "078d3cdea12da58a"
                        "id": "81379b4c78eb5084",
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "true"
                                "t": "false"
                                "t": "eq",
                                "v": "",
                                "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 3,
                        "x": 970,
                        "y": 380,
                        "wires": [
                                "0649103700725132",
                                "cada2da2ed2bfaf6"
                                "0649103700725132",
                                "c38db948a076700c"
                        "id": "6d74347a2369c9b1",
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "change",
                                "p": "payload",
                                "pt": "msg",
                                "from": "on",
                                "fromt": "str",
                                "to": "true",
                                "tot": "bool"
                                "t": "change",
                                "p": "payload",
                                "pt": "msg",
                                "from": "off",
                                "fromt": "str",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 970,
                        "y": 320,
                        "wires": [
                                "81379b4c78eb5084"
                        "id": "eb53173feca16754",
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "on",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 850,
                        "y": 280,
                        "wires": [
                                "2cf7c09b18238747"
                        "id": "b3cf3d5c5932a0f1",
                        "name": "Virt Lampe",
                        "attrname": "payload",
                        "payloadType": "value",
                        "x": 330,
                        "y": 520,
                        "wires": [
                                "fe9075ec01f6e19a"
                        "id": "fe9075ec01f6e19a",
                        "type": "switch",
                        "rules": [
                                "t": "false"
                                "t": "true"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 440,
                        "y": 460,
                        "wires": [
                                "6ad2e1e41e7eba3d",
                                "1d02d4d287c62d8d"
                                "6fda00babbc6c3cf",
                                "c858be985d04ff23",
                                "17a82c94f393c061"
                        "id": "e52cacfb28f4eef0",
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 840,
                        "y": 600,
                        "wires": [
                                "0649103700725132",
                                "0e6b80937690ec94"
                        "id": "6fda00babbc6c3cf",
                        "type": "change",
                        "name": "stop",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "stop",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 610,
                        "y": 320,
                        "wires": [
                                "6b29472d446bd70a"
                        "id": "1f6129972520dbc9",
                        "name": "45min",
                        "outtopic": "",
                        "outsafe": "on",
                        "outunsafe": "off",
                        "warning": "10",
                        "timer": "2700",
                        "debug": false,
                        "ndebug": false,
                        "repeat": false,
                        "again": false,
                        "x": 810,
                        "y": 380,
                        "wires": [
                                "19d59c4b02bc1d4e"
                        "id": "2cf7c09b18238747",
                        "name": "3min",
                        "outtopic": "",
                        "outsafe": "on",
                        "outunsafe": "off",
                        "warning": "10",
                        "timer": "90",
                        "debug": false,
                        "ndebug": false,
                        "repeat": false,
                        "again": false,
                        "x": 810,
                        "y": 320,
                        "wires": [
                                "6d74347a2369c9b1"
                        "id": "c9f5b344739be161",
                        "name": "U-rechts",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1200,
                        "y": 600,
                        "wires": []
                        "id": "eb0a77e50a594126",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1330,
                        "y": 480,
                        "wires": []
                        "id": "3da3568f5cb1d905",
                        "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_1",
                        "ack": "false",
                        "role": "value",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1220,
                        "y": 540,
                        "wires": []
                        "id": "d9b21aa55e80ae44",
                        "type": "delay",
                        "name": "100ms",
                        "pauseType": "delay",
                        "timeout": "100",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "rateUnits": "second",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "randomUnits": "seconds",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 1190,
                        "y": 480,
                        "wires": [
                                "eb0a77e50a594126"
                        "id": "a0d644333024864d",
                        "name": "U-links",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1190,
                        "y": 660,
                        "wires": []
                        "id": "749bbf25ef1c6f5d",
                        "name": "Hue",
                        "x": 90,
                        "y": 320,
                        "wires": [
                                "7e046925a0149339"
                        "id": "7e046925a0149339",
                        "initevents": true,
                        "x": 280,
                        "y": 320,
                        "wires": [
                                "7cade0980ce23b6f"
                        "id": "6744591312f4367c",
                        "type": "inject",
                        "name": "Takt",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "1",
                        "crontab": "",
                        "once": true,
                        "onceDelay": 0.1,
                        "topic": "Takt",
                        "payload": "true",
                        "x": 90,
                        "y": 280,
                        "wires": [
                                "19d0869e86da09b3"
                        "id": "19d0869e86da09b3",
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "bewegung",
                                "tot": "flow"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 250,
                        "y": 280,
                        "wires": [
                                "6a9e975c8a2cb22e"
                        "id": "f4dd19c85bec8f67",
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "bewegung",
                                "pt": "flow",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 850,
                        "y": 640,
                        "wires": [
                        "id": "14cbab0539105d58",
                        "type": "change",
                        "name": "1002",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "1000",
                                "tot": "num"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 110,
                        "y": 380,
                        "wires": [
                                "edd034e0ac4e9dbd"
                        "id": "cada2da2ed2bfaf6",
                        "type": "debug",
                        "name": "debug 8",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "complete": "false",
                        "statusVal": "",
                        "x": 1300,
                        "y": 280,
                        "wires": []
                        "id": "c38db948a076700c",
                        "type": "debug",
                        "name": "debug 17",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 1300,
                        "y": 320,
                        "wires": []
                        "id": "0e6b80937690ec94",
                        "type": "debug",
                        "name": "debug 18",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 1200,
                        "y": 800,
                        "wires": []
                        "id": "078d3cdea12da58a",
                        "type": "debug",
                        "name": "debug 19",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 1200,
                        "y": 760,
                        "wires": []
                        "id": "22f763e23b4b426d",
                        "type": "debug",
                        "name": "debug 20",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 1200,
                        "y": 720,
                        "wires": []
                        "worker": "10",
                • AphofisA Aphofis
                  @peterfido
                          "type": "tab",
                          "label": "Flow 8",
                          "disabled": false,
                          "info": "",
                          "env": []
                          "type": "junction",
                          "x": 680,
                          "y": 560,
                          "wires": [
                                  "e52cacfb28f4eef0",
                                  "d4243e5842d002b7",
                                  "f4dd19c85bec8f67"
                          "type": "junction",
                          "x": 1060,
                          "y": 600,
                          "wires": [
                                  "3da3568f5cb1d905",
                                  "d9b21aa55e80ae44",
                                  "c9f5b344739be161",
                                  "a0d644333024864d"
                          "type": "junction",
                          "x": 680,
                          "y": 320,
                          "wires": [
                                  "1f6129972520dbc9",
                                  "2cf7c09b18238747"
                          "type": "junction",
                          "x": 1060,
                          "y": 460,
                          "wires": [
                                  "49ed5c100ffadbfb"
                          "type": "junction",
                          "x": 160,
                          "y": 520,
                          "wires": [
                                  "34daca3383213026"
                          "type": "debug",
                          "name": "debug 3",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "complete": "true",
                          "statusVal": "",
                          "x": 1400,
                          "y": 420,
                          "wires": []
                          "type": "change",
                          "name": "motion:false",
                          "rules": [
                                  "t": "set",
                                  "pt": "msg",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 310,
                          "y": 420,
                          "wires": [
                                  "c5344e2d70758330"
                          "type": "switch",
                          "name": "Schalter",
                          "property": "stopp",
                          "rules": [
                                  "t": "true"
                                  "t": "false"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 560,
                          "y": 280,
                          "wires": [
                                  "e5b4dd5e0fdf55b3"
                          "type": "change",
                          "name": "Motion",
                          "rules": [
                                  "t": "set",
                                  "p": "bewegung",
                                  "pt": "flow",
                                  "to": "payload.motion",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 470,
                          "y": 320,
                          "wires": [
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "on",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 610,
                          "y": 360,
                          "wires": [
                                  "1f6129972520dbc9"
                          "type": "switch",
                          "name": "1000?",
                          "rules": [
                                  "t": "eq",
                                  "v": "1000",
                                  "vt": "num"
                                  "t": "eq",
                                  "v": "",
                                  "vt": "num"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 230,
                          "y": 460,
                          "wires": [
                                  "b3cf3d5c5932a0f1"
                          "type": "switch",
                          "name": "Robi",
                          "property": "BWM",
                          "rules": [
                                  "t": "true"
                                  "t": "false"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 690,
                          "y": 280,
                          "wires": [
                                  "eb53173feca16754"
                          "type": "change",
                          "name": "setze stopp",
                          "rules": [
                                  "t": "set",
                                  "p": "stopp",
                                  "pt": "flow",
                                  "to": "true",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 630,
                          "y": 460,
                          "wires": [
                          "type": "change",
                          "name": "lösche stopp",
                          "rules": [
                                  "t": "set",
                                  "p": "stopp",
                                  "pt": "flow",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 830,
                          "y": 560,
                          "wires": [
                          "type": "function",
                          "name": "Variablen Ini + Ausgabe",
                          "outputs": 1,
                          "timeout": 0,
                          "noerr": 0,
                          "finalize": "",
                          "libs": [],
                          "x": 1170,
                          "y": 420,
                          "wires": [
                                  "f2c58fd53288296d",
                                  "97a52cd45dee491f"
                          "type": "ioBroker in",
                          "name": "Robi",
                          "topic": "mihome-vacuum.0.info.state",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "fireOnStart": "false",
                          "outFormat": "MQTT",
                          "x": 110,
                          "y": 600,
                          "wires": [
                                  "7f79db16bb82a357"
                          "type": "function",
                          "name": "Ausgang BWM",
                          "func": "\nreturn msg;",
                          "outputs": 1,
                          "timeout": 0,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 300,
                          "y": 380,
                          "wires": [
                                  "7cade0980ce23b6f"
                          "name": "KüSchalter",
                          "topic": "hue.0.Hue_GordonX.Küche_Schalter.buttonevent",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 80,
                          "y": 460,
                          "wires": [
                                  "edd034e0ac4e9dbd"
                          "type": "switch",
                          "name": "8?",
                          "rules": [
                                  "t": "eq",
                                  "v": "8",
                                  "vt": "num"
                                  "t": "neq",
                                  "v": "8",
                                  "vt": "num"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 230,
                          "y": 600,
                          "wires": [
                                  "34daca3383213026"
                                  "9725d7651f53e931"
                          "type": "change",
                          "name": "setze Flow.BWM",
                          "rules": [
                                  "t": "set",
                                  "p": "BWM",
                                  "pt": "flow",
                                  "to": "true",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 410,
                          "y": 580,
                          "wires": [
                                  "3d95821769504d11"
                          "type": "change",
                          "name": "lösche Flow.BWM",
                          "rules": [
                                  "t": "set",
                                  "p": "BWM",
                                  "pt": "flow",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 410,
                          "y": 620,
                          "wires": [
                                  "3d95821769504d11"
                          "type": "switch",
                          "name": "nur true",
                          "rules": [
                                  "t": "true"
                                  "t": "false"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 420,
                          "y": 280,
                          "wires": [
                                  "6fa8c560705cd84b"
                          "type": "debug",
                          "name": "debug 4",
                          "active": false,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "complete": "true",
                          "statusVal": "",
                          "x": 580,
                          "y": 600,
                          "wires": []
                          "type": "change",
                          "rules": [
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "on",
                                  "fromt": "str",
                                  "to": "true",
                                  "tot": "bool"
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "off",
                                  "fromt": "str",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 820,
                          "y": 440,
                          "wires": [
                                  "2b6788c8f61bc75d"
                          "type": "switch",
                          "name": "",
                          "rules": [
                                  "t": "true"
                                  "t": "false"
                                  "t": "eq",
                                  "v": "",
                                  "vt": "str"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 3,
                          "x": 830,
                          "y": 500,
                          "wires": [
                                  "0649103700725132",
                                  "22f763e23b4b426d"
                                  "0649103700725132",
                                  "d4243e5842d002b7",
                                  "078d3cdea12da58a"
                          "type": "switch",
                          "name": "",
                          "rules": [
                                  "t": "true"
                                  "t": "false"
                                  "t": "eq",
                                  "v": "",
                                  "vt": "str"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 3,
                          "x": 970,
                          "y": 380,
                          "wires": [
                                  "0649103700725132",
                                  "cada2da2ed2bfaf6"
                                  "0649103700725132",
                                  "c38db948a076700c"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "on",
                                  "fromt": "str",
                                  "to": "true",
                                  "tot": "bool"
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "off",
                                  "fromt": "str",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 970,
                          "y": 320,
                          "wires": [
                                  "81379b4c78eb5084"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "on",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 850,
                          "y": 280,
                          "wires": [
                                  "2cf7c09b18238747"
                          "type": "ioBroker get",
                          "errOnInvalidState": "nothing",
                          "x": 330,
                          "y": 520,
                          "wires": [
                                  "fe9075ec01f6e19a"
                          "type": "switch",
                          "name": "true false",
                          "rules": [
                                  "t": "false"
                                  "t": "true"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 440,
                          "y": 460,
                          "wires": [
                                  "6ad2e1e41e7eba3d",
                                  "1d02d4d287c62d8d"
                                  "6fda00babbc6c3cf",
                                  "c858be985d04ff23",
                                  "17a82c94f393c061"
                          "type": "change",
                          "name": "Alles auf Anfang",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 840,
                          "y": 600,
                          "wires": [
                                  "0649103700725132",
                                  "0e6b80937690ec94"
                          "type": "change",
                          "name": "stop",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "stop",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 610,
                          "y": 320,
                          "wires": [
                                  "6b29472d446bd70a"
                          "type": "mytimeout",
                          "name": "45min",
                          "outtopic": "",
                          "outsafe": "on",
                          "outwarning": "Warning",
                          "outunsafe": "off",
                          "warning": "10",
                          "timer": "2700",
                          "debug": false,
                          "ndebug": false,
                          "ignoreCase": false,
                          "repeat": false,
                          "again": false,
                          "x": 810,
                          "y": 380,
                          "wires": [
                                  "19d59c4b02bc1d4e"
                          "name": "3min",
                          "outtopic": "",
                          "outsafe": "on",
                          "outunsafe": "off",
                          "warning": "10",
                          "timer": "90",
                          "debug": false,
                          "ndebug": false,
                          "repeat": false,
                          "again": false,
                          "x": 810,
                          "y": 320,
                          "wires": [
                                  "6d74347a2369c9b1"
                          "type": "ioBroker out",
                          "name": "U-rechts",
                          "topic": "tuya.0.bfb09eea5dad3699abyrbu.20",
                          "ack": "false",
                          "autoCreate": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1200,
                          "y": 600,
                          "wires": []
                          "name": "Küche Decke",
                          "topic": "tuya.0.bfe4af976feb74d845vugp.1",
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1330,
                          "y": 480,
                          "wires": []
                          "name": "Virtuel Switch 1",
                          "ack": "false",
                          "role": "value",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1220,
                          "y": 540,
                          "wires": []
                          "type": "delay",
                          "name": "100ms",
                          "timeout": "100",
                          "timeoutUnits": "milliseconds",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 1190,
                          "y": 480,
                          "wires": [
                                  "eb0a77e50a594126"
                          "name": "U-links",
                          "topic": "hue.0.Hue_GordonX.Küche_Unterschr_Links.on",
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1190,
                          "y": 660,
                          "wires": []
                          "type": "hue-bridge-node",
                          "name": "Hue",
                          "bridge": "cbd54dbabf6f65be",
                          "autoupdates": true,
                          "skipglobalevents": false,
                          "initevents": false,
                          "x": 90,
                          "y": 320,
                          "wires": [
                                  "7e046925a0149339"
                          "type": "hue-motion",
                          "name": "Küche Motion Sensor",
                          "sensorid": "7529c8d8-9f5c-451d-ba56-70cacda84564",
                          "skipevents": false,
                          "initevents": true,
                          "x": 280,
                          "y": 320,
                          "wires": [
                                  "7cade0980ce23b6f"
                          "type": "inject",
                          "name": "Takt",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "1",
                          "crontab": "",
                          "once": true,
                          "onceDelay": 0.1,
                          "topic": "Takt",
                          "payload": "true",
                          "payloadType": "bool",
                          "x": 90,
                          "y": 280,
                          "wires": [
                                  "19d0869e86da09b3"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "bewegung",
                                  "tot": "flow"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 250,
                          "y": 280,
                          "wires": [
                                  "6a9e975c8a2cb22e"
                          "type": "change",
                          "name": "lösche bewegung",
                          "rules": [
                                  "t": "set",
                                  "p": "bewegung",
                                  "pt": "flow",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 850,
                          "y": 640,
                          "wires": [
                          "type": "change",
                          "name": "1002",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "1000",
                                  "tot": "num"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 110,
                          "y": 380,
                          "wires": [
                                  "edd034e0ac4e9dbd"
                          "type": "debug",
                          "name": "debug 8",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1300,
                          "y": 280,
                          "wires": []
                          "type": "debug",
                          "name": "debug 17",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1300,
                          "y": 320,
                          "wires": []
                          "type": "debug",
                          "name": "debug 18",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1200,
                          "y": 800,
                          "wires": []
                          "type": "debug",
                          "name": "debug 19",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1200,
                          "y": 760,
                          "wires": []
                          "type": "debug",
                          "name": "debug 20",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1200,
                          "y": 720,
                          "wires": []
                          "id": "cbd54dbabf6f65be",
                          "type": "hue-bridge",
                          "name": "Hue GordonX",
                          "bridge": "192.168.0.8",
                          "key": "SlfyXwpcaEvRN0d1DU2JrrOlwrm9Debhhm9A4E-d",
                          "worker": "10",
                          "disableupdates": false
                  peterfido
                  @aphofis
                  Das hier sollte anzeigen, wer da wo den Schaltbefehl gibt:
                         "id": "b802892eed83e90f",
                         "type": "tab",
                         "label": "Flow 8",
                         "disabled": false,
                         "info": "",
                         "env": []
                         "id": "f00e20abd94ff43d",
                         "type": "junction",
                         "z": "b802892eed83e90f",
                         "x": 1120,
                         "y": 660,
                         "wires": [
                                 "141a052859674836",
                                 "574a9f7ddc4f663b",
                                 "b6322a40cf4557b3"
                         "id": "423ea0f1dc0e4d31",
                         "type": "junction",
                         "x": 1960,
                         "y": 460,
                         "wires": [
                                 "ff32f89078260f0e",
                                 "67e2e01a1266d1c3",
                                 "e98816534075b0f5",
                                 "21f36ea2695afe19",
                                 "a695276a00fe8f61"
                         "id": "ae8ceff406113f11",
                         "type": "junction",
                         "x": 1140,
                         "y": 260,
                         "wires": [
                                 "ba0aea0ff71ebc3d"
                         "id": "9c7c62ee37b6b12c",
                         "type": "junction",
                         "x": 520,
                         "y": 60,
                         "wires": [
                                 "d24a5429e472b18a"
                         "id": "d96f128a59bdfbb4",
                         "type": "junction",
                         "x": 900,
                         "y": 440,
                         "wires": [
                                 "84bd4ea1d044fea4",
                                 "ed2607cafe826532"
                         "id": "84bd4ea1d044fea4",
                         "type": "junction",
                         "x": 980,
                         "y": 360,
                         "wires": [
                                 "be66da991b562e24"
                         "id": "be66da991b562e24",
                         "type": "junction",
                         "x": 1280,
                         "y": 360,
                         "wires": [
                                 "fa5f2b5bcd258a98"
                         "type": "junction",
                         "x": 580,
                         "y": 560,
                         "wires": [
                                 "e22b60db6265e908"
                         "type": "junction",
                         "x": 580,
                         "y": 560,
                         "wires": [
                                 "e22b60db6265e908"
                         "type": "junction",
                         "x": 240,
                         "y": 560,
                         "wires": [
                                 "1ee1fe89c1628b34"
                         "id": "a2104cdffd7ca75f",
                         "type": "inject",
                         "name": "Test Bewegung",
                         "props": [
                                 "v": "true",
                                 "vt": "bool"
                                 "p": "topic",
                                 "vt": "str"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "Bewegungsmelder",
                         "x": 140,
                         "y": 380,
                         "wires": [
                                 "a919a4c30d900c39",
                                 "0150c15cf7b51170"
                         "id": "ed06e85de97289c8",
                         "type": "debug",
                         "name": "debug 3",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "true",
                         "statusVal": "",
                         "x": 2000,
                         "y": 360,
                         "wires": []
                         "id": "a919a4c30d900c39",
                         "type": "delay",
                         "name": "",
                         "timeout": "30",
                         "timeoutUnits": "seconds",
                         "rate": "1",
                         "nbRateUnits": "1",
                         "randomFirst": "1",
                         "randomLast": "5",
                         "drop": false,
                         "allowrate": false,
                         "outputs": 1,
                         "x": 150,
                         "y": 460,
                         "wires": [
                                 "bee64eb116d76ed1"
                         "id": "bee64eb116d76ed1",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "pt": "msg",
                                 "to": "false",
                                 "tot": "bool"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 350,
                         "y": 460,
                         "wires": [
                                 "0150c15cf7b51170"
                         "id": "ab41883686b27cc0",
                         "type": "switch",
                         "name": "Schalter",
                         "rules": [
                                 "t": "true"
                                 "t": "false"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 920,
                         "y": 260,
                         "wires": [
                                 "01fea99b98c641a3"
                         "id": "0395e4bbb7c67e21",
                         "type": "change",
                         "name": "Motion",
                         "rules": [
                                 "t": "set",
                                 "p": "bewegung",
                                 "pt": "flow",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 670,
                         "y": 320,
                         "wires": [
                         "id": "59792b228df9eb30",
                         "type": "comment",
                         "info": "",
                         "x": 280,
                         "y": 300,
                         "wires": []
                         "id": "93f0d4c85ab42e59",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "on",
                                 "tot": "str"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 710,
                         "y": 400,
                         "wires": [
                                 "ed2607cafe826532"
                         "id": "e22b60db6265e908",
                         "type": "switch",
                         "name": "1000?",
                         "rules": [
                                 "t": "eq",
                                 "v": "1000",
                                 "vt": "num"
                                 "t": "eq",
                                 "v": "",
                                 "vt": "num"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 270,
                         "y": 660,
                         "wires": [
                                 "6ae2e0e61f81faeb"
                         "id": "01fea99b98c641a3",
                         "type": "switch",
                         "name": "Robi",
                         "property": "robi",
                         "rules": [
                                 "t": "true"
                                 "t": "false"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 1050,
                         "y": 260,
                         "wires": [
                                 "ae8ceff406113f11"
                         "id": "7eea52e80cbe51f0",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "stopp",
                                 "pt": "flow",
                                 "to": "true",
                                 "tot": "bool"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 950,
                         "y": 600,
                         "wires": [
                         "id": "574a9f7ddc4f663b",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "stopp",
                                 "pt": "flow",
                                 "to": "false",
                                 "tot": "bool"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1370,
                         "y": 600,
                         "wires": [
                         "id": "331a07cfba2d7df1",
                         "type": "function",
                         "func": "if(msg.payload){\n    msg.topic = msg.topic + \": Licht ein\";\n}else{\n    msg.topic = msg.topic + \": Licht aus\";\n}\n\nmsg.topic += \", robi:\" + flow.get(\"robi\");\nnode.status({ text: msg.topic });\n\nreturn msg;",
                         "outputs": 1,
                         "timeout": 0,
                         "noerr": 0,
                         "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"robi\", true);\nflow.set(\"bewegung\", false);\n",
                         "finalize": "",
                         "libs": [],
                         "x": 1770,
                         "y": 380,
                         "wires": [
                                 "ed06e85de97289c8",
                                 "423ea0f1dc0e4d31"
                         "id": "b9692c9131fb2ef5",
                         "name": "Robi",
                         "onlyack": "",
                         "func": "rbe-preinitvalue",
                         "gap": "",
                         "fireOnStart": "true",
                         "x": 90,
                         "y": 780,
                         "wires": [
                                 "6b214a0a59b5e04a"
                         "id": "0150c15cf7b51170",
                         "type": "function",
                         "outputs": 1,
                         "timeout": 0,
                         "noerr": 0,
                         "initialize": "",
                         "finalize": "",
                         "libs": [],
                         "x": 360,
                         "y": 360,
                         "wires": [
                                 "0395e4bbb7c67e21"
                         "id": "b6b4c157c31e3701",
                         "onlyack": "",
                         "func": "all",
                         "gap": "",
                         "x": 100,
                         "y": 680,
                         "wires": [
                                 "e22b60db6265e908"
                         "id": "6b214a0a59b5e04a",
                         "type": "switch",
                         "name": "8?",
                         "rules": [
                                 "t": "eq",
                                 "v": "8",
                                 "vt": "num"
                                 "t": "neq",
                                 "v": "8",
                                 "vt": "num"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 630,
                         "y": 780,
                         "wires": [
                                 "7b9c0fa6e795af2d"
                                 "ccadbb1ee1de29e6"
                         "id": "7b9c0fa6e795af2d",
                         "type": "change",
                         "name": "setze Flow.robi",
                         "rules": [
                                 "t": "set",
                                 "p": "robi",
                                 "pt": "flow",
                                 "to": "true",
                                 "tot": "bool"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 840,
                         "y": 760,
                         "wires": [
                                 "b117dac109d51b34"
                         "id": "ccadbb1ee1de29e6",
                         "type": "change",
                         "name": "lösche Flow.robi",
                         "rules": [
                                 "t": "set",
                                 "p": "robi",
                                 "pt": "flow",
                                 "to": "false",
                                 "tot": "bool"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 840,
                         "y": 800,
                         "wires": [
                                 "b117dac109d51b34"
                         "id": "558db419c5c37cca",
                         "type": "comment",
                         "name": "evtl. gesperrt durch?? Beginn",
                         "info": "",
                         "x": 980,
                         "y": 220,
                         "wires": []
                         "id": "d24a5429e472b18a",
                         "type": "switch",
                         "name": "nur true",
                         "rules": [
                                 "t": "true"
                                 "t": "false"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 720,
                         "y": 240,
                         "wires": [
                                 "ab41883686b27cc0"
                         "id": "b117dac109d51b34",
                         "type": "debug",
                         "name": "debug 4",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "true",
                         "statusVal": "",
                         "x": 1040,
                         "y": 760,
                         "wires": []
                         "id": "91febc7692f9b822",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "change",
                                 "p": "payload",
                                 "pt": "msg",
                                 "from": "on",
                                 "fromt": "str",
                                 "to": "true",
                                 "tot": "bool"
                                 "t": "change",
                                 "p": "payload",
                                 "pt": "msg",
                                 "from": "off",
                                 "fromt": "str",
                                 "to": "false",
                                 "tot": "bool"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1290,
                         "y": 400,
                         "wires": [
                                 "d303b6e1817d8b77"
                         "id": "d303b6e1817d8b77",
                         "type": "switch",
                         "name": "",
                         "rules": [
                                 "t": "true"
                                 "t": "false"
                                 "t": "eq",
                                 "v": "",
                                 "vt": "str"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 3,
                         "x": 1470,
                         "y": 400,
                         "wires": [
                                 "331a07cfba2d7df1"
                                 "331a07cfba2d7df1",
                                 "574a9f7ddc4f663b"
                         "id": "b4e55cb04c30244e",
                         "type": "switch",
                         "name": "",
                         "rules": [
                                 "t": "true"
                                 "t": "false"
                                 "t": "eq",
                                 "v": "",
                                 "vt": "str"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 3,
                         "x": 1770,
                         "y": 260,
                         "wires": [
                                 "331a07cfba2d7df1"
                                 "331a07cfba2d7df1"
                         "id": "90c9685b4a5344dc",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "change",
                                 "p": "payload",
                                 "pt": "msg",
                                 "from": "on",
                                 "fromt": "str",
                                 "to": "true",
                                 "tot": "bool"
                                 "t": "change",
                                 "p": "payload",
                                 "pt": "msg",
                                 "from": "off",
                                 "fromt": "str",
                                 "to": "false",
                                 "tot": "bool"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1610,
                         "y": 260,
                         "wires": [
                                 "b4e55cb04c30244e"
                         "id": "ba0aea0ff71ebc3d",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "on",
                                 "tot": "str"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1250,
                         "y": 260,
                         "wires": [
                                 "fa5f2b5bcd258a98"
                         "id": "6ae2e0e61f81faeb",
                         "name": "Virtuelle Lampe",
                         "x": 440,
                         "y": 660,
                         "wires": [
                                 "f8d92d8cb9d60184"
                         "id": "cf3016a536d38a8d",
                         "type": "switch",
                         "rules": [
                                 "t": "false"
                                 "t": "true"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 760,
                         "y": 660,
                         "wires": [
                                 "7eea52e80cbe51f0",
                                 "93f0d4c85ab42e59"
                                 "7b9c0fa6e795af2d",
                                 "87ec46662c49de4e",
                                 "f00e20abd94ff43d"
                         "id": "141a052859674836",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "false",
                                 "tot": "bool"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1380,
                         "y": 640,
                         "wires": [
                                 "331a07cfba2d7df1"
                         "id": "87ec46662c49de4e",
                         "type": "change",
                         "name": "stop",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "stop",
                                 "tot": "str"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1070,
                         "y": 640,
                         "wires": [
                                 "d96f128a59bdfbb4"
                         "id": "ed2607cafe826532",
                         "name": "45sek",
                         "outtopic": "Schalter 1000",
                         "outsafe": "on",
                         "outunsafe": "off",
                         "warning": "10",
                         "timer": "60",
                         "debug": false,
                         "ndebug": false,
                         "repeat": false,
                         "again": false,
                         "x": 1090,
                         "y": 400,
                         "wires": [
                                 "91febc7692f9b822"
                         "id": "fa5f2b5bcd258a98",
                         "name": "10Sek",
                         "outtopic": "BWM",
                         "outsafe": "on",
                         "outunsafe": "off",
                         "warning": "10",
                         "timer": "30",
                         "debug": false,
                         "ndebug": false,
                         "repeat": false,
                         "again": false,
                         "x": 1430,
                         "y": 260,
                         "wires": [
                                 "90c9685b4a5344dc"
                         "id": "21f36ea2695afe19",
                         "name": "U-rechts",
                         "ack": "false",
                         "stateName": "",
                         "role": "",
                         "payloadType": "",
                         "readonly": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 2140,
                         "y": 600,
                         "wires": []
                         "id": "084e7114b7ed1c61",
                         "ack": "false",
                         "stateName": "",
                         "role": "",
                         "payloadType": "",
                         "readonly": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 2210,
                         "y": 460,
                         "wires": []
                         "id": "ff32f89078260f0e",
                         "ack": "false",
                         "role": "value",
                         "readonly": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 2160,
                         "y": 540,
                         "wires": []
                         "id": "442c2ef743d9599f",
                         "type": "debug",
                         "name": "Küche",
                         "active": false,
                         "tosidebar": true,
                         "console": true,
                         "tostatus": false,
                         "complete": "payload",
                         "targetType": "msg",
                         "statusVal": "",
                         "x": 2160,
                         "y": 760,
                         "wires": []
                         "id": "67e2e01a1266d1c3",
                         "type": "delay",
                         "name": "100ms",
                         "timeout": "100",
                         "rate": "1",
                         "nbRateUnits": "1",
                         "randomFirst": "1",
                         "randomLast": "5",
                         "drop": false,
                         "allowrate": false,
                         "outputs": 1,
                         "x": 2070,
                         "y": 460,
                         "wires": [
                                 "084e7114b7ed1c61"
                         "id": "e98816534075b0f5",
                         "type": "change",
                         "name": "Küche",
                         "rules": [
                                 "t": "change",
                                 "p": "payload",
                                 "pt": "msg",
                                 "from": "1000",
                                 "fromt": "str",
                                 "to": "Küche",
                                 "tot": "str"
                                 "t": "change",
                                 "p": "payload",
                                 "pt": "msg",
                                 "from": "true",
                                 "fromt": "bool",
                                 "to": "Küche eingeschaltet",
                                 "tot": "str"
                                 "t": "change",
                                 "p": "payload",
                                 "pt": "msg",
                                 "from": "false",
                                 "fromt": "bool",
                                 "to": "Küche ausgeschaltet",
                                 "tot": "str"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 2030,
                         "y": 760,
                         "wires": [
                                 "442c2ef743d9599f"
                         "id": "a695276a00fe8f61",
                         "name": "U-links",
                         "ack": "false",
                         "stateName": "",
                         "role": "",
                         "payloadType": "",
                         "readonly": "",
                         "stateUnit": "",
                         "stateMin": "",
                         "stateMax": "",
                         "x": 2130,
                         "y": 680,
                         "wires": []
                         "id": "802770af38c8534e",
                         "name": "Hue",
                         "x": 130,
                         "y": 160,
                         "wires": [
                                 "2e0c2a67486c0ac7"
                         "id": "2e0c2a67486c0ac7",
                         "initevents": true,
                         "x": 360,
                         "y": 160,
                         "wires": [
                                 "0395e4bbb7c67e21"
                         "id": "83e1205cab7afd75",
                         "type": "inject",
                         "name": "Takt",
                         "props": [
                                 "p": "payload"
                                 "p": "topic",
                                 "vt": "str"
                         "repeat": "1",
                         "crontab": "",
                         "once": true,
                         "onceDelay": 0.1,
                         "topic": "Takt",
                         "payload": "true",
                         "x": 130,
                         "y": 60,
                         "wires": [
                                 "26a06677287b879b"
                         "id": "26a06677287b879b",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "bewegung",
                                 "tot": "flow"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 370,
                         "y": 60,
                         "wires": [
                                 "9c7c62ee37b6b12c"
                         "id": "c8bd53de95a27a58",
                         "type": "inject",
                         "name": "Test Schalter",
                         "props": [
                                 "p": "payload"
                                 "p": "topic",
                                 "vt": "str"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "payload": "1000",
                         "payloadType": "num",
                         "x": 130,
                         "y": 520,
                         "wires": [
                                 "64bf8df5efc25d40",
                                 "f3921b2658b5916c"
                         "id": "b6322a40cf4557b3",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "bewegung",
                                 "pt": "flow",
                                 "to": "false",
                                 "tot": "bool"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1390,
                         "y": 680,
                         "wires": [
                         "id": "4208dd4576daa563",
                         "type": "comment",
                         "info": "",
                         "x": 270,
                         "y": 580,
                         "wires": []
                         "id": "f6fea6b16f9005b0",
                         "type": "comment",
                         "name": "evtl. gesperrt durch?? Ende",
                         "info": "",
                         "x": 980,
                         "y": 320,
                         "wires": []
                         "type": "delay",
                         "name": "200 ms",
                         "timeout": "200",
                         "rate": "1",
                         "nbRateUnits": "1",
                         "randomFirst": "1",
                         "randomLast": "5",
                         "drop": false,
                         "allowrate": false,
                         "outputs": 1,
                         "x": 300,
                         "y": 520,
                         "wires": [
                                 "d628f1137cfb08c1"
                         "type": "change",
                         "name": "1002",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "1002",
                                 "tot": "num"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 430,
                         "y": 520,
                         "wires": [
                                 "8355cf791b8a8b1b"
                         "type": "inject",
                         "props": [
                                 "p": "payload"
                                 "p": "topic",
                                 "vt": "str"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "payload": "8",
                         "x": 120,
                         "y": 840,
                         "wires": [
                                 "6b214a0a59b5e04a"
                         "type": "inject",
                         "props": [
                                 "p": "payload"
                                 "p": "topic",
                                 "vt": "str"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "payload": "5",
                         "x": 120,
                         "y": 900,
                         "wires": [
                                 "6b214a0a59b5e04a"
                         "id": "f8d92d8cb9d60184",
                         "type": "change",
                         "name": "topic",
                         "rules": [
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "Schalter 1000",
                                 "tot": "str"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 610,
                         "y": 660,
                         "wires": [
                                 "cf3016a536d38a8d"
                         "worker": "10",
                  Im Prinzip kann alles so bleiben. Evtl. Hue nebst Motion Sensor einrichten. Der BWM Simulator tut nix, wenn man nicht die Inject-Node davon klickt. Das gleiche beim Test Schalter. Lass die drin, dann ist die Chance größer, dass ich Deine Exporte importiere und teste.
                  Peterfido
                  • AphofisA Offline
                    AphofisA Offline
                    Aphofis
                    @peterfido
                    bin beim Testen, mal sehen was dabei raus kommt.
                    • AphofisA Offline
                      AphofisA Offline
                      Aphofis
                      Also das immer wieder das Licht eingeschaltet wird wenn man in den BWM läuft und dann per Schalter ausschalten will und dieses 2-3 mal machen musste bis das Licht aus bleibt, lag am HUE Node. Die Globale Aktualisierungsmitteilungen auf diesem Node ignorieren, musste angehakt sein. Jetzt läuft die Steuerung tadellos.
