  4. [gelöst] ZigBee-Adapter Terminated nach Updates
    1.0k
    6.1k
4 Beiträge 2 Kommentatoren 529 Aufrufe 2 Beobachtet
  • I Offline
    I Offline
    iobroker2001
    schrieb am zuletzt editiert von iobroker2001
    mein Zigbee-Adapter ist heute nacht beendet worden. Nach einem Neustart lief er auch wieder, bis ich ihn jetzt - ein paar Stunden nach Neustart - noch einmal neugestartet habe.
    Jetzt bleibt er im roten Zustand.
    2025-06-04 09:43:27.552 - info: host.iobroker "system.adapter.zigbee.0" enabled
    2025-06-04 09:43:28.003 - info: host.iobroker instance system.adapter.zigbee.0 in version "2.0.5" started with pid 2210
    2025-06-04 09:43:29.086 - info: zigbee.0 (2210) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
    2025-06-04 09:43:29.095 - info: zigbee.0 (2210) init localConfig
    2025-06-04 09:43:29.098 - info: zigbee.0 (2210) --> transmitPower : low
    2025-06-04 09:43:29.102 - info: zigbee.0 (2210) delete old Backup files. keep only last 10
    2025-06-04 09:43:29.104 - info: zigbee.0 (2210) --- creating device debug ---
    2025-06-04 09:43:29.104 - info: zigbee.0 (2210) Starting Adapter npm ...
    2025-06-04 09:43:29.125 - info: zigbee.0 (2210) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.1)
    2025-06-04 09:43:29.125 - info: zigbee.0 (2210) Starting Zigbee-Herdsman
    2025-06-04 09:43:54.168 - info: zigbee.0 (2210) Unable to obtain herdsman settings
    2025-06-04 09:43:54.183 - error: zigbee.0 (2210) Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    2025-06-04 09:43:54.184 - error: zigbee.0 (2210) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-06-04 09:43:54.185 - error: zigbee.0 (2210) unhandled promise rejection: undefined
    2025-06-04 09:43:54.185 - error: zigbee.0 (2210) undefined
    2025-06-04 09:43:54.187 - info: zigbee.0 (2210) cleaned everything up...
    2025-06-04 09:43:54.187 - info: zigbee.0 (2210) local config saved
    2025-06-04 09:43:54.188 - info: zigbee.0 (2210) Saved local configuration data
    2025-06-04 09:43:54.189 - info: zigbee.0 (2210) terminating
    2025-06-04 09:43:54.190 - warn: zigbee.0 (2210) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-06-04 09:43:54.328 - error: zigbee.0 (2210) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
    at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:259:35)
    at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33)
    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
    2025-06-04 09:43:54.340 - info: zigbee.0 (2210) terminating
    2025-06-04 09:43:54.341 - warn: zigbee.0 (2210) Device 0x00158d0001dfc320 "RTCGQ11LM" not found.
    2025-06-04 09:43:54.341 - warn: zigbee.0 (2210) Device 0x00178801094a2b87 "9290019758" not found.
    2025-06-04 09:43:54.342 - warn: zigbee.0 (2210) Device 0xf0d1b800001c7724 "4058075208384" not found.
    2025-06-04 09:43:54.342 - warn: zigbee.0 (2210) Device 0xf0d1b800001c7164 "4058075208384" not found.
    2025-06-04 09:43:54.342 - warn: zigbee.0 (2210) Device 0x00178801094a0a2d "9290019758" not found.
    2025-06-04 09:43:54.342 - warn: zigbee.0 (2210) Device 0x00158d0008d8a2d7 "RTCGQ11LM" not found.
    2025-06-04 09:43:54.342 - warn: zigbee.0 (2210) Device 0xf4b3b1fffe94fddb "SNZB-02D" not found.
    2025-06-04 09:43:54.343 - warn: zigbee.0 (2210) Device 0x001788010d27a3e8 "929002398602" not found.
    2025-06-04 09:43:54.343 - warn: zigbee.0 (2210) Device 0x54ef441000782ea4 "ZNJLBL01LM" not found.
    2025-06-04 09:43:54.343 - warn: zigbee.0 (2210) Device 0x54ef44100078265d "ZNJLBL01LM" not found.
    2025-06-04 09:43:54.343 - warn: zigbee.0 (2210) Device 0x54ef4410006b9837 "ZNJLBL01LM" not found.
    2025-06-04 09:43:54.343 - warn: zigbee.0 (2210) Device 0x54ef4410007830cd "ZNJLBL01LM" not found.
    2025-06-04 09:43:54.344 - warn: zigbee.0 (2210) Device 0x54ef44100078437a "ZNJLBL01LM" not found.
    2025-06-04 09:43:54.344 - warn: zigbee.0 (2210) Device 0x00158d0006d3ec06 "RTCGQ11LM" not found.
    2025-06-04 09:43:54.344 - warn: zigbee.0 (2210) Device 0x00158d0008f31e05 "WXKG11LM" not found.
    2025-06-04 09:43:54.344 - warn: zigbee.0 (2210) Device 0x00158d00080854c5 "RTCGQ11LM" not found.
    2025-06-04 09:43:54.344 - warn: zigbee.0 (2210) Device 0x00158d0009d34e04 "DJT11LM" not found.
    2025-06-04 09:43:54.379 - info: zigbee.0 (2210) debug devices set to []
    2025-06-04 09:43:54.690 - info: zigbee.0 (2210) terminating
    2025-06-04 09:43:54.733 - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-06-04 09:43:54.733 - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled
    2025-06-04 09:43:54.733 - warn: host.iobroker Do not restart adapter system.adapter.zigbee.0 because restart loop detected
    2025-06-04 09:43:54.790 - info: notification-manager.0 (1839) Send notification "system.restartLoop" to "telegram.0"
    2025-06-04 09:43:54.793 - info: telegram.0 (1663) New notification received from system.adapter.notification-manager.0
    2025-06-04 09:43:54.940 - info: notification-manager.0 (1839) Instance telegram.0 successfully handled the notification for "system.restartLoop"
    Gestern hatte ich einige Adapter geupdatet (Backitup, und 2 weitere, weiß nicht mehr welche) und auch
    Node.js: auf v20.19.2 geliftet, sowie das Raspbian geupdatet.
    Als Zigbee-Hardware ist ein SLZB-06 eingesetzt, dieser ist über seine Oberfläche erreichbar und sieht ok aus.
    Hat jemand eine zündende Idee?
    Vielen Dank!
    ```bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.12.25+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     09:49:31 up 9 min,  2 users,  load average: 0.50, 0.40, 0.29
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-06-04 09:49:31 CEST
               Universal time: Wed 2025-06-04 07:49:31 UTC
                     RTC time: Wed 2025-06-04 07:49:31
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Mem:            8.5G        3.2G        4.0G        6.0M        1.3G        5.2G
    Swap:           209M          0B        209M
    Total:          8.7G        3.2G        4.2G
    Active iob-Instances: 	34
             8063 M total memory
             3094 M used memory
             3225 M active memory
              591 M inactive memory
             3819 M free memory
              105 M buffer memory
             1137 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 09:49:31 up 9 min,  2 users,  load average: 0.50, 0.40, 0.29
    Tasks: 231 total,   1 running, 230 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.7 total,   3819.8 free,   3095.0 used,   1242.5 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4968.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     807M  5.7M  801M   1% /run
    /dev/mmcblk0p2 ext4       29G   13G   15G  47% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   64K  5.0M   2% /run/lock
    /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
    [Wed Jun  4 09:40:12 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:34:62:E1 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=87a1b5ec-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Jun  4 09:40:15 2025] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
    [Wed Jun  4 09:40:16 2025] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.1G	/var/
    2.4G	/var/log
    2.3G	/var/log/journal/41e4a03f5b7d490a97523b509aa0a614
    358M	/var/lib
    Archived and active journals take up 2.2G in the file system.
    /opt/iobroker/backups:
    12M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    778M	/opt/iobroker/iobroker-data/
    624M	/opt/iobroker/iobroker-data/files
    203M	/opt/iobroker/iobroker-data/files/vis-2
    112M	/opt/iobroker/iobroker-data/backup-objects
    89M	/opt/iobroker/iobroker-data/files/vis-2/static
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    34M	/opt/iobroker/iobroker-data/objects.jsonl
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI04PGZY-if00-port0
    /dev/serial/by-id/usb-busware.de_CUL868-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.19.2
    /usr/bin/node 		v20.19.2
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.31.0
    nodejs:
      Installed: 20.19.2-1nodesource1
      Candidate: 20.19.2-1nodesource1
      Version table:
     *** 20.19.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 534)
    Core adapters versions
    admin: 		7.6.17
    javascript: 	8.9.2
    nodejs modules from github: 	1
    +-- iobroker.connector-local-control@0.0.4 (git+ssh://git@github.com/ConnectorGit/ioBroker.connector-local-control.git#af6ca3a95371ad333ec5e967fa33ce251bb87ad3)
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.connector-local-control.0: connector-local-control: iobroker                                 -  enabled
    + system.adapter.cul.0                    : cul                   : iobroker                                 -  enabled, port: 23
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.jeelink.0                : jeelink               : iobroker                                 -  enabled
      system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
    + system.adapter.reolink.1                : reolink               : iobroker                                 -  enabled
    + system.adapter.reolink.2                : reolink               : iobroker                                 -  enabled
    + system.adapter.reolink.3                : reolink               : iobroker                                 -  enabled
    + system.adapter.reolink.4                : reolink               : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.75:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "backitup"     : 3.2.2    , installed 3.2.2
    Adapter    "cul"          : 2.2.0    , installed 2.2.0
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "followthesun" : 0.5.2    , installed 0.5.2
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "lovelace"     : 4.1.15   , installed 4.1.15
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "notification-manager": 1.2.1, installed 1.2.1
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "reolink"      : 1.2.2    , installed 1.2.2
    Adapter    "shelly"       : 9.5.1    , installed 9.5.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "worx"         : 3.2.0    , installed 3.2.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects: 	14415
    States: 	11366
    Hit:2 https://repos.influxdata.com/debian stable InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:7 https://apt.grafana.com stable InRelease
    Hit:8 https://apt.debmatic.de/debmatic stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:31999           0.0.0.0:*               LISTEN      0          7761       1552/ReGaHss.normal
    tcp        0      0 127.0.0.1:30080         0.0.0.0:*               LISTEN      0          7019       1235/lighttpd
    tcp        0      0 0.0.0.0:32001           0.0.0.0:*               LISTEN      0          8307       1295/rfd
    tcp        0      0 0.0.0.0:8183            0.0.0.0:*               LISTEN      0          9484       1552/ReGaHss.normal
    tcp        0      0 0.0.0.0:8181            0.0.0.0:*               LISTEN      0          1966       1027/lighttpd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9387       1346/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7079       1346/iobroker.js-co
    tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      0          1972       1027/lighttpd
    tcp        0      0 0.0.0.0:1999            0.0.0.0:*               LISTEN      0          1968       1027/lighttpd
    tcp        0      0 127.0.0.1:12001         0.0.0.0:*               LISTEN      1001       10660      1791/io.hm-rpc.0
    tcp        0      0 127.0.0.1:12010         0.0.0.0:*               LISTEN      1001       10695      1808/io.hm-rpc.1
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      0          1970       1027/lighttpd
    tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      0          1974       1027/lighttpd
    tcp        0      0 0.0.0.0:2000            0.0.0.0:*               LISTEN      0          1976       1027/lighttpd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       8792       1824/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       8838       1876/io.shelly.0
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          1965       1027/lighttpd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6570       894/sshd: /usr/sbin
    tcp6       0      0 :::32010                :::*                    LISTEN      0          7149       1336/java
    tcp6       0      0 :::8181                 :::*                    LISTEN      0          1967       1027/lighttpd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10976      2109/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7672       1441/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       11477      2124/io.ws.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        9335       1019/influxd
    tcp6       0      0 :::39292                :::*                    LISTEN      0          8405       1336/java
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        8378       1345/grafana
    tcp6       0      0 :::9293                 :::*                    LISTEN      0          8388       1336/java
    tcp6       0      0 :::9292                 :::*                    LISTEN      0          1973       1027/lighttpd
    tcp6       0      0 :::18075                :::*                    LISTEN      1001       8703       1744/io.fullybrowse
    tcp6       0      0 :::1999                 :::*                    LISTEN      0          1969       1027/lighttpd
    tcp6       0      0 :::2010                 :::*                    LISTEN      0          1971       1027/lighttpd
    tcp6       0      0 :::2001                 :::*                    LISTEN      0          1975       1027/lighttpd
    tcp6       0      0 :::2000                 :::*                    LISTEN      0          1977       1027/lighttpd
    tcp6       0      0 :::80                   :::*                    LISTEN      0          1964       1027/lighttpd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6572       894/sshd: /usr/sbin
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          5113       1195/ssdpd
    udp        0      0 127.0.0.1:1998          0.0.0.0:*                           0          9485       1552/ReGaHss.normal
    udp        0      0 0.0.0.0:43439           0.0.0.0:*                           0          7004       1191/eq3configd
    udp        0      0 0.0.0.0:32101           0.0.0.0:*                           1001       9831       1956/io.connector-l
    udp        0      0 127.0.0.1:8182          0.0.0.0:*                           0          8287       1233/hss_led
    udp        0      0 0.0.0.0:53851           0.0.0.0:*                           104        5858       722/avahi-daemon: r
    udp        0      0 0.0.0.0:45776           0.0.0.0:*                           0          8308       1295/rfd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5856       722/avahi-daemon: r
    udp6       0      0 :::47915                :::*                                0          7073       1336/java
    udp6       0      0 :::60964                :::*                                104        5859       722/avahi-daemon: r
    udp6       0      0 fe80::c317:5c0b:740:546 :::*                                0          6665       851/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        5857       722/avahi-daemon: r
    2025-06-04 09:46:39.932  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 echarts-show
    2025-06-04 09:46:39.933  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 echarts-show
    2025-06-04 09:46:39.936  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 echarts-show
    2025-06-04 09:46:39.944  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 echarts-show
    2025-06-04 09:46:39.951  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 vis-2
    2025-06-04 09:46:42.618  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:46:59.610  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:46:59.613  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 echarts-show
    2025-06-04 09:47:01.619  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:47:01.640  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:47:01.662  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:47:01.682  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:47:02.781  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 echarts-show
    2025-06-04 09:47:02.787  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 echarts-show
    2025-06-04 09:47:02.793  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 echarts-show
    2025-06-04 09:47:02.798  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 echarts-show
    2025-06-04 09:47:02.807  - info: web.0 (2109) <== Disconnect system.user.admin from ::ffff:192.168.178.58 vis-2
    2025-06-04 09:47:04.407  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:47:09.322  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:47:09.342  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:47:09.371  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    2025-06-04 09:47:09.413  - info: web.0 (2109) ==> Connected system.user.admin from ::ffff:192.168.178.58
    • I Offline
      I Offline
      iobroker2001
      Der Zigbee-Adapter:
      • I iobroker2001
        Vielen Dank!
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 8063 M total memory
                 3094 M used memory
                 3819 M free memory
                  105 M buffer memory
                 1137 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        3.1G	/var/
        2.4G	/var/log
        358M	/var/lib
        USB-Devices by-id:
        HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin: 		7.6.17
        javascript: 	8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	14415
        States: 	11366
        Pending Updates: 0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @iobroker2001 sagte in ZigBee-Adapter Terminated nach Updates:
        Der Adapter hat ein Problem damit die Firmware auf dem Koordinator zu erreichen. Da gibt es (in deinem Fall) 3 Möglichkeiten:
        • Der Koordinator ist 'abgestürzt'. Gegenmassnahme: Adapter anhalten, Koordinator stromlos machen, 30s warten, Koordinator mit Strom versorgen, Warten bis der gebootet hat (10-20 s)Adapter starten, läuft.
        • Der Koordinator ist defekt. Gegenmassnahme: Koordinator austauschen
        • Zigbee-Firmware auf dem Koordinator ist defekt. Gegenmassnahme : Zigbee-Firmware auf dem Koordinator neu flashen, dann den Adapter neu starten.
        A.
        I 1 Antwort Letzte Antwort
        • AsgothianA Asgothian
          A.
          I Offline
          I Offline
          iobroker2001
          @asgothian Du bist ein As!
          Adapter war ja schon gestoppt ;-)
          Dann Zigbee-Gateway stromlos und neu gestartet -> funktioniert wieder!
          Dankeschön!!
