  4. IOT Cannot read properties of undefined
    2.9k
    3.0k
4 Beiträge 2 Kommentatoren 482 Aufrufe 2 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    Hallo
    Mir ist heute bei einer von 2 IOT-Instanzen der untere Fehler aufgefallen.
    Diese Instanz wird auch nicht mehr grün.
    Ich werde aus dem Log nicht schlau.
    IOT 3.5.1
    Admin 7.6.18
    Node 20.19.1
    NPM 10.8.2
    Controller: 7.0.6
    iot.1 2025-06-02 18:09:07.801	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    iot.1 2025-06-02 18:09:07.801	debug	Plugin sentry destroyed
    iot.1 2025-06-02 18:09:07.801	info	terminating
    iot.1 2025-06-02 18:09:07.781	error	Cannot read properties of undefined (reading 'iot.1')
    iot.1 2025-06-02 18:09:07.781	error	TypeError: Cannot read properties of undefined (reading 'iot.1') at getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:40:47) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2571:41) at processImmediate (node:internal/timers:485:21)
    iot.1 2025-06-02 18:09:07.781	error	uncaught exception: Cannot read properties of undefined (reading 'iot.1')
    iot.1 2025-06-02 18:09:07.169	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    iot.1 2025-06-02 18:09:07.037	info	starting. Version 3.5.1 in /opt/iobroker/node_modules/iobroker.iot, node: v20.19.1, js-controller: 7.0.6
    iot.1 2025-06-02 18:09:06.714	debug	Plugin sentry Initialize Plugin (enabled=true)
    iot.1 2025-06-02 18:08:35.067	info	Connection changed: connect "laura_xxxxxxxxx"
    iot.1 2025-06-02 18:08:34.832	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    iot.1 2025-06-02 18:08:34.832	debug	Plugin sentry destroyed
    iot.1 2025-06-02 18:08:34.831	info	terminating
    iot.1 2025-06-02 18:08:34.819	error	Cannot read properties of undefined (reading 'iot.1')
    iot.1 2025-06-02 18:08:34.819	error	TypeError: Cannot read properties of undefined (reading 'iot.1') at getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:40:47) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2571:41) at processImmediate (node:internal/timers:485:21)
    iot.1 2025-06-02 18:08:34.818	error	uncaught exception: Cannot read properties of undefined (reading 'iot.1')
    iot.1 2025-06-02 18:08:34.160	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    iot.1 2025-06-02 18:08:34.055	info	starting. Version 3.5.1 in /opt/iobroker/node_modules/iobroker.iot, node: v20.19.1, js-controller: 7.0.6
    iot.1 2025-06-02 18:08:33.747	debug	Plugin sentry Initialize Plugin (enabled=true)
    iot.1 2025-06-02 18:08:01.817	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    iot.1 2025-06-02 18:08:01.817	debug	Plugin sentry destroyed
    iot.1 2025-06-02 18:08:01.817	info	terminating
    iot.1 2025-06-02 18:08:01.807	error	Cannot read properties of undefined (reading 'iot.1')
    iot.1 2025-06-02 18:08:01.807	error	TypeError: Cannot read properties of undefined (reading 'iot.1') at getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:40:47) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2571:41) at processImmediate (node:internal/timers:485:21)
    iot.1 2025-06-02 18:08:01.806	error	uncaught exception: Cannot read properties of undefined (reading 'iot.1')
    iot.1 2025-06-02 18:08:01.237	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    iot.1 2025-06-02 18:08:01.068	info	starting. Version 3.5.1 in /opt/iobroker/node_modules/iobroker.iot, node: v20.19.1, js-controller: 7.0.6
    iot.1 2025-06-02 18:08:00.705	debug	Plugin sentry Initialize Plugin (enabled=true)
    ° Fixer ---> iob fix
    L 1 Antwort Letzte Antwort
    • NegaleinN Negalein
      Hallo
      IOT 3.5.1
      Admin 7.6.18
      Node 20.19.1
      NPM 10.8.2
      Controller: 7.0.6
      L Online
      L Online
      Lucky_ESA
      @negalein Schau mal hier
      • L Lucky_ESA
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @lucky_esa
        Danke, hatte ich nicht gefunden.
        Ich benötige den Hacken aktiv wegen 2 Konten.
        Sonst schaltet mir die Kleine zuviel.
          @lucky_esa
          L Online
          L Online
          Lucky_ESA
          @negalein sagte in IOT Cannot read properties of undefined:
          @lucky_esa
          Ein Issue wurde auch schon erstellt.
