  4. Wieder mal der Fully ...
    6.8k
47 Beiträge 8 Kommentatoren 6.1k Aufrufe 6 Beobachtet
  • Dr.PieD Dr.Pie
    @meister-mopper
    Das Tab mit IP 16 ist das alte Tab.
    Das neue hat IP 44 und Android 14
    Dr.PieD Offline
    Dr.PieD Offline
    Dr.Pie
    schrieb am zuletzt editiert von Dr.Pie
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: nuc
           Icon name: computer-desktop
             Chassis: desktop 🖥️
              Kernel: Linux 6.1.0-32-amd64
        Architecture: x86-64
     Hardware Vendor: Intel Corporation
      Hardware Model: NUC7i3BNK
    Firmware Version: BNKBL357.86A.0083.2020.0714.1344
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     21:16:00 up 7 days, 11:07,  2 users,  load average: 0.53, 0.57, 0.57
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2025-05-02 21:16:00 CEST
               Universal time: Fri 2025-05-02 19:16:00 UTC
                     RTC time: Fri 2025-05-02 19:16:00
                  NTP service: n/a
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    jens
    HOME=/home/jens
    GROUPS=jens cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             16G        4.0G         11G        1.0M        1.9G         12G
    Swap:           1.0G          0B        1.0G
    Total:           17G        4.0G         12G
    Active iob-Instances:   31
            15876 M total memory
             3811 M used memory
              545 M active memory
             4304 M inactive memory
            10613 M free memory
               21 M buffer memory
             1771 M swap cache
              975 M total swap
                0 M used swap
              975 M free swap
    top - 21:16:00 up 7 days, 11:07,  2 users,  load average: 0.53, 0.57, 0.57
    Tasks: 144 total,   2 running, 142 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 75.0 us, 25.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15876.2 total,  10613.5 free,   3811.6 used,   1792.2 buff/cache
    MiB Swap:    976.0 total,    976.0 free,      0.0 used.  12064.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  792K  1.6G   1% /run
    /dev/nvme0n1p1 ext4      116G   13G   98G  12% /
    tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Fri Apr 25 10:08:56 2025] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Apr 25 10:08:57 2025] EXT4-fs (nvme0n1p1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE         FSTYPE OPTIONS
    /      /dev/nvme0n1p1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.7G    /var/
    2.2G    /var/log/journal/71f4ccb046934bb889999d75429a60cc
    2.2G    /var/log
    379M    /var/cache
    Archived and active journals take up 71.7M in the file system.
    /opt/iobroker/backups:
    2.5G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.3G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    32M     /opt/iobroker/iobroker-data/objects.jsonl
    28M     /opt/iobroker/iobroker-data/states.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.1
    /usr/bin/node           v20.19.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.1-1nodesource1
      Candidate: 20.19.1-1nodesource1
      Version table:
     *** 20.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    nuc                 nuc (version: 7.0.6, hostname: nuc           , alive, uptime: 644824)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     5
    +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/Joylancer/ioBroker.bambulab.git#e45a2b4644fa2af1f0532352ac7da71ee3257c84)
    +-- iobroker.parcel@0.2.10 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#7504e1cbfc79a62e49ebc2e0502cb958d01008be)
    +-- iobroker.smartthings@0.1.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#0921ba9cef4d6b62375f339126457f3429d0448f)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : nuc                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : nuc                                      -  enabled
    + system.adapter.bambulab.0               : bambulab              : nuc                                      -  enabled, port: 8883
      system.adapter.bambulab.1               : bambulab              : nuc                                      - disabled, port: 8883
      system.adapter.daswetter.0              : daswetter             : nuc                                      -  enabled
      system.adapter.daswetter.1              : daswetter             : nuc                                      -  enabled
    + system.adapter.denon.0                  : denon                 : nuc                                      -  enabled
    + system.adapter.discovery.0              : discovery             : nuc                                      -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : nuc                                      -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : nuc                                      -  enabled
    + system.adapter.harmony.0                : harmony               : nuc                                      -  enabled
    + system.adapter.heos.0                   : heos                  : nuc                                      -  enabled
    + system.adapter.history.0                : history               : nuc                                      -  enabled
      system.adapter.homeconnect.0            : homeconnect           : nuc                                      - disabled
      system.adapter.ical.0                   : ical                  : nuc                                      -  enabled
      system.adapter.ical.1                   : ical                  : nuc                                      -  enabled
      system.adapter.ical.2                   : ical                  : nuc                                      -  enabled
      system.adapter.ical.3                   : ical                  : nuc                                      -  enabled
    + system.adapter.javascript.0             : javascript            : nuc                                      -  enabled
    + system.adapter.parcel.0                 : parcel                : nuc                                      -  enabled
    + system.adapter.parcel.1                 : parcel                : nuc                                      -  enabled
    + system.adapter.parcel.2                 : parcel                : nuc                                      -  enabled
      system.adapter.parcel.3                 : parcel                : nuc                                      - disabled
      system.adapter.parcel.4                 : parcel                : nuc                                      - disabled
    + system.adapter.shelly.0                 : shelly                : nuc                                      -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : nuc                                      -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.smartthings.0            : smartthings           : nuc                                      - disabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : nuc                                      -  enabled
    + system.adapter.sql.0                    : sql                   : nuc                                      -  enabled
    + system.adapter.synology.0               : synology              : nuc                                      -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : nuc                                      -  enabled, port: 5002
    + system.adapter.synology.2               : synology              : nuc                                      -  enabled, port: 5003
    + system.adapter.tankerkoenig.0           : tankerkoenig          : nuc                                      -  enabled
    + system.adapter.tankerkoenig.1           : tankerkoenig          : nuc                                      -  enabled
    + system.adapter.telegram.0               : telegram              : nuc                                      -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : nuc                                      -  enabled
    + system.adapter.tr-064.2                 : tr-064                : nuc                                      -  enabled
    + system.adapter.upnp.0                   : upnp                  : nuc                                      -  enabled
      system.adapter.vis-2.0                  : vis-2                 : nuc                                      - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : nuc                                      -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : nuc                                      -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : nuc                                      -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : nuc                                      -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : nuc                                      -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : nuc                                      -  enabled
      system.adapter.vis.0                    : vis                   : nuc                                      -  enabled
    + system.adapter.web.0                    : web                   : nuc                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : nuc                                      -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "fb-checkpresence": 1.3.1 , installed 1.3.1
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "heos"         : 2.2.1    , installed 2.2.1
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "shelly"       : 9.2.0    , installed 9.2.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        37111
    States:         30455
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19769      530/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19764      530/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14099      556/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1368       1/init
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21706      865/io.shelly.1
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      104        19691      529/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14101      556/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1370       1/init
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8553803    33339/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21325      585/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      104        16220      529/influxd
    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       26610      1126/io.upnp.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       21569      741/io.harmony.0
    udp        0      0 0.0.0.0:56846           0.0.0.0:*                           1001       23941      1126/io.upnp.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13951      410/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1369       1/init
    udp        0      0 192.168.178.28:123      0.0.0.0:*                           0          8517977    33058/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          8517975    33058/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          8517971    33058/ntpd
    udp        0      0 0.0.0.0:33737           0.0.0.0:*                           1001       20373      1069/io.heos.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24668      1126/io.upnp.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21570      741/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22943      1175/io.wled.0
    udp        0      0 192.168.178.28:5353     0.0.0.0:*                           1001       20120      955/io.tr-064.0
    udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       17512576   1039/io.discovery.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       22571      820/io.shelly.0
    udp6       0      0 :::111                  :::*                                0          1371       1/init
    udp6       0      0 fe80::96c6:91ff:fea:123 :::*                                0          8517983    33058/ntpd
    udp6       0      0 2a02:8109:1800:4200:123 :::*                                0          8517981    33058/ntpd
    udp6       0      0 ::1:123                 :::*                                0          8517979    33058/ntpd
    udp6       0      0 :::123                  :::*                                0          8517968    33058/ntpd
    2025-05-02 21:14:19.970  - warn: fullybrowser.0 (69498) [REST] 192.168.178.16: Sending command get axiosGetDevicesInfo  failed: No response
    2025-05-02 21:14:21.973  - warn: fullybrowser.0 (69498) [REST] 192.168.178.44: Sending command get axiosGetDevicesInfo  failed: No response
    2025-05-02 21:14:25.562  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
    2025-05-02 21:14:59.100  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
    2025-05-02 21:15:02.018  - info: host.nuc instance system.adapter.daswetter.1 in version "3.2.3" started with pid 82109
    2025-05-02 21:15:03.213  - info: daswetter.1 (82109) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.1, js-controller: 7.0.6
    2025-05-02 21:15:07.477  - info: daswetter.1 (82109) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-05-02 21:15:07.993  - info: daswetter.1 (82109) cleaned everything up...
    2025-05-02 21:15:08.017  - info: host.nuc instance system.adapter.daswetter.1 having pid 82109 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-05-02 21:15:19.972  - warn: fullybrowser.0 (69498) [REST] 192.168.178.16: Sending command get axiosGetDevicesInfo  failed: No response
    2025-05-02 21:15:21.976  - warn: fullybrowser.0 (69498) [REST] 192.168.178.44: Sending command get axiosGetDevicesInfo  failed: No response
    2025-05-02 21:15:32.473  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
    2025-05-02 21:15:38.352  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 3(firetvwz/10:BF:67:01:BF:29) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2025-05-02 21:15:39.966  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 30(firetv-sz/B4:B7:42:F6:BE:B4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2025-05-02 21:15:41.400  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 58(Schrank/A4:CF:12:BF:35:65) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2025-05-02 21:15:42.837  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 79(TVBoard/A4:CF:12:BF:2F:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2025-05-02 21:15:43.059  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 82(Vitrine/A4:CF:12:BF:30:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2025-05-02 21:15:55.033  - info: host.nuc instance system.adapter.daswetter.0 in version "3.2.3" started with pid 82233
    2025-05-02 21:15:56.761  - info: daswetter.0 (82233) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.1, js-controller: 7.0.6
    2025-05-02 21:16:03.694  - info: daswetter.0 (82233) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-05-02 21:16:04.204  - info: daswetter.0 (82233) cleaned everything up...
    2025-05-02 21:16:04.223  - info: host.nuc instance system.adapter.daswetter.0 having pid 82233 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-05-02 21:16:05.887  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
    2025-05-02 21:16:19.972  - warn: fullybrowser.0 (69498) [REST] 192.168.178.16: Sending command get axiosGetDevicesInfo  failed: No response
    2025-05-02 21:16:21.975  - warn: fullybrowser.0 (69498) [REST] 192.168.178.44: Sending command get axiosGetDevicesInfo  failed: No response
    Dr.PieD 1 Antwort Letzte Antwort
    • Dr.PieD Dr.Pie
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
               Chassis: desktop 🖥️
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: n/a
                RTC in local TZ: no
      jens
      HOME=/home/jens
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
      Total:           17G        4.0G         12G
               3811 M used memory
                545 M active memory
              10613 M free memory
                 21 M buffer memory
               1771 M swap cache
                975 M total swap
                  0 M used swap
                975 M free swap
      *** FILESYSTEM ***
      /var:
      2.7G    /var/
      2.2G    /var/log
      379M    /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.3
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        37111
      States:         30455
      Pending Updates: 0
      Dr.PieD Offline
      Dr.PieD Offline
      Dr.Pie
      Und das noch hinterher
      ```bash
                              v.2025-02-23
               Chassis: desktop 🖥️
      Installation:           native
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs 20.19.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:             16G        3.9G         11G        1.1M        1.9G         12G
      Swap:           1.0G          0B        1.0G
      Total:           17G        3.9G         12G
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.6.3
      Objects type: jsonl
      States  type: jsonl
      Objects:                37111
      States:                 30455
      Size of iob-Database:
      33M     /opt/iobroker/iobroker-data/objects.jsonl
      29M     /opt/iobroker/iobroker-data/states.jsonl
      Aber was meinst du mit "adm group bist" ?
      Würde das weiterhelfen ?
      Wie kommt man da hin ?
      • Dr.PieD Dr.Pie
        ```bash
                                v.2025-02-23
                 Chassis: desktop 🖥️
        Kernel:                 x86_64
        Userland:               64 bit
        User-ID:                1000
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        MEMORY:
        Swap:           1.0G          0B        1.0G
        Total:           17G        3.9G         12G
                                admin                   7.6.3
        Objects type: jsonl
        States  type: jsonl
        Objects:                37111
        States:                 30455
        Meister MopperM Offline
        Meister Mopper
        @dr-pie sagte in Wieder mal der Fully ...:
        Nein, helfen würde es nicht. Wenn du in der Gruppe adm bist, kannst du alle Log-Dateien einsehen.
        Proxmox und HA ...
        • Dr.PieD Dr.Pie
          Moin
          nun habe ich ein neues Tab mit Android 14 ... aber auch das funktioniert nicht ... der lädt und lädt und lädt .... es ist zum ******
          Das Übertragen der Lizenz hat problemlos funktioniert.
          Moin
          funktionieren denn andere views von iobroker oder der iobroker admin einwandfrei auf den Tablets?
          Wifi verbindung auch wirklich ok?
          Oder ist dein Server zu sehr ausgelastet, um das zu providen?
          viel hilft viel.. nur mal so.. :)
          Edit:
          Ich hab auch zwei Tab A, die laden auch keine Vis2 bei mir, liegt wohl am alten Android 8, ich nutze daher zu 80% auf den Tablets MinuVIS, das braucht kaum ressourcen und funktioniert auch mit aelteren Devices gut.
          Wobei bei mir die Tablets nur Anzeigemedien sind, bedienen tut da keiner was mit, das geht automatisch, wofuer hab ich ein Smarthome wenn ich irgendwo rumklicken muss.. ? :)
            Moin
            Edit:
            Dr.PieD Offline
            Dr.PieD Offline
            Dr.Pie
            @neuschwansteini sagte in Wieder mal der Fully ...:
            Moin
            Da ja permanent der Ladebalken dreht, kann natürlich keine einzige View angezeigt werden.
            Die WLan Verbindung ist exzellent da ich ja alles andere machen kann. Von Mails über Bankgeschäfte. Alle anderen Apps und Anwendungen funktionieren.
            Da ja auch andere Browser dieses Verhalten haben wenn ich auf den iob zugreifen will, nehme ich mal an das es nicht wirklich am Tab als solches liegt, denn das neue Tab ist schon ziemlich aktuell .... was die Software betrifft.
            • Dr.PieD Dr.Pie
              Moin
              @dr-pie du hast ja zu beiden Tabs keine Verbindung!
              2025-05-02 19:51:05.958  - warn: fullybrowser.0 (66868) [REST] 192.168.178.16: Sending command get axiosGetDevicesInfo  failed: No response
              2025-05-02 19:51:06.082  - warn: fullybrowser.0 (66868) [REST] 192.168.178.44: Sending command get axiosGetDevicesInfo  failed: No response
              liegt also am Netzwerk, fitewall, pihole oder....ä
                Dr.PieD Offline
                Dr.PieD Offline
                Dr.Pie
                @homoran sagte in Wieder mal der Fully ...:
                Wo muss ich denn da nachschauen ?
                Vom PC oder Laptop komme ich problemlos mit dem Firefox oder Chrome auf die Vis.
                Da werden alle Views, Edit's und die Tabs in Millisekunden geladen.
                Dr. BakteriusD 1 Antwort Letzte Antwort
                • Dr.PieD Dr.Pie
                  Dr. BakteriusD Online
                  Dr. Bakterius
                  @dr-pie Welche IP hat denn der ioBroker?
                    Dr.PieD Offline
                    Dr.PieD Offline
                    Dr.Pie
                    @dr-bakterius sagte in Wieder mal der Fully ...:
                    Der nuc auf dem ich den iob installiert habe ist: 192.168.178.28
                    • Dr.PieD Dr.Pie
                      Dr. Bakterius
                      @dr-pie Und mit einem normalen Browser am Tablet kannst du die VIS aufrufen?
                        Dr.PieD Offline
                        Dr.PieD Offline
                        Dr.Pie
                        Mit dem Fully geht es auch nach 10 Minuten nicht.
                        Der Firefox dauert auch teilweise 15 Minuten bis er die Vis geladen hat. Dann dauert aber jeder View-Wechsel ebenfalls mehrere Minuten.
                        Und der Samsung Browser funktioniert auch nicht.
                        Nutze ich die Browser aber um damit ins Internet zu kommen, werden die Seiten im Millisekunden geladen.
                        Bankgeschäfte, EMails, Webseiten ... alles seeeehr flink.
                        Auch auf meine 3 Server (Synology) alles schnell ... so wie ich mir das vorstelle.
                        Am PC und am Laptop werden alle Seiten der Vis razfaz geladen.
                        Mit der Vis arbeite ich üblicherweise mit dem Chrome.
                        • Dr.PieD Dr.Pie
                          @dr-pie und was schließt du daraus?
                          dass die Verbindung der Tablets zum ioBroker Server klemmt?
                            Dr.PieD Offline
                            Dr.PieD Offline
                            Dr.Pie
                            Diese Erkenntnis habe ich schon seit Monaten ... nur eben eine Lösung nicht.
                            • Dr.PieD Dr.Pie
                              Du bist der einzige der deine Topologie kennt
                                Dr.PieD Offline
                                Dr.PieD Offline
                                Dr.Pie
                                Ich musste erst mal nach dem Wort googlen ...
                                "Lehre von der Lage und Anordnung geometrischer Gebilde im Raum"
                                Wieder etwas schlauer geworden... Danke
                                Dr.PieD HomoranH 2 Antworten Letzte Antwort
                                • Dr.PieD Dr.Pie
                                  Dr.PieD Offline
                                  Dr.PieD Offline
                                  Dr.Pie
                                  Nochwas .... falls von Bedeutung:
                                  Starte ich den Fully an den Tabs, kann ich im iob sehen das der dazugehörige Datenpunkt "true" anzeigt und das WLan Zeichen grün ist
                                  • Dr.PieD Dr.Pie
                                    in diesem Fall (Netzwerktopologie) geht es um den Aubau deines Netzwerks.
                                    Was hängt wo an welchem Gerät usw.
                                      Dr.PieD Offline
                                      Dr.PieD Offline
                                      Dr.Pie
                                      Benötigst du du diese Infos ?
                                      • Dr.PieD Dr.Pie
                                        sicher nicht!
                                        ich werde mich da nicht einarbeiten!
                                        und der Fully ist sonst nicht gestartet?
                                        wendy2702W Dr.PieD 2 Antworten Letzte Antwort
                                          sicher nicht!
                                          wendy2702W Online
                                          wendy2702W Online
                                          wendy2702
                                          @homoran könnte es dieses Webview Problem sein das du glaube ich auch kennst?
