  4. Weboberfläche nicht mehr erreichbar
17 Beiträge 4 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • ChendaC Offline
    ChendaC Offline
    Chenda
    Hi zusammen,
    leider kann ich die Weboberfläche nicht mehr erreichen.
    Ich habe mich auf dem Raspi per ssh eingeloggt und folgende Schritte gemacht:
    sudo apt update
    sudo apt upgrade
    sudo apt autoremove
    sudo apt autoclean
    iobroker update
    iobroker upgrade
    iob diag
    iob stop
    iob fix
    iob start
    iob diag
    sudo reboot
    Hat aber nicht geholfen. Auch mehrfaches fix hat nicht die Lösung gebracht.
    chenda@iobroker:~ $ iob diag
    *** iob diag is starting up, please wait ***
    iob diag needs to be updated. Please execute 'iobroker fix' first.
    ^C
    chenda@iobroker:~ $ iob start
    chenda@iobroker:~ $ iob fix
    library: loaded
    Library version=2024-10-22
    ioBroker or some processes are still running:
    507 iobroker.js-con
    711 io.admin.0
    720 io.javascript.0
    731 io.backitup.0
    744 io.deyeidc.0
    763 io.smartmeter.0
    770 io.nissan.0
    799 io.alexa2.0
    810 io.deyeidc.1
    825 io.deyeidc.2
    844 io.discovery.0
    855 io.go-e.0
    862 io.web.0
    868 io.vis-2.0
    884 io.trashschedul
    912 io.hs100.0
    Please stop them first and try again!
    chenda@iobroker:~ $ iob stop
    library: loaded
        Welcome to the ioBroker installation fixer!
        Script version: 205-02-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
        Checking ioBroker user and directory permissions (2/5)
    Created /etc/sudoers.d/iobroker
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
    [Invalid UTF-8]
    Authenticating as: ,,, (michael)
    Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
    Enabling autostart...
    Autostart enabled!
    chenda@iobroker:~ $ ```
      @chenda sagte in Weboberfläche nicht mehr erreichbar:
      iob diag
      wo ist der output davon?
      ChendaC 1 Antwort Letzte Antwort
        iob diag
        ChendaC Offline
        ChendaC Offline
        Chenda
        Anfang zweiter Codeblock
        • ChendaC Chenda
          Hi zusammen,
          sudo apt update
          sudo apt upgrade
          sudo apt autoremove
          sudo apt autoclean
          iobroker update
          iobroker upgrade
          iob diag
          iob stop
          iob fix
          iob start
          iob diag
          sudo reboot
          ^C
          library: loaded
          507 iobroker.js-con
          711 io.admin.0
          720 io.javascript.0
          731 io.backitup.0
          744 io.deyeidc.0
          763 io.smartmeter.0
          770 io.nissan.0
          799 io.alexa2.0
          810 io.deyeidc.1
          825 io.deyeidc.2
          844 io.discovery.0
          855 io.go-e.0
          862 io.web.0
          868 io.vis-2.0
          884 io.trashschedul
          912 io.hs100.0
          library: loaded
          Done.
          [Invalid UTF-8]
          Autostart enabled!
          Alleine die beiden Zeilen sagen mir schon, das das ganze unsauber von 'bullseye' auf 'bookworm' gehoben wurde.
          Das funktioniert so nicht. Installier da 'bookworm' komplett von Grund auf NEU.
          • ChendaC Chenda
            da ist kein iob diag
            schon gar nicht die Langfassung
              ChendaC Offline
              ChendaC Offline
              Chenda
              @homoran sagte in Weboberfläche nicht mehr erreichbar:
              Ja weil es nicht läuft:
              auch nicht nach iobroker fix - wie ich schon geschrieben habe.
              • ChendaC Chenda
                @chenda dann dürfte dein System ziemlich verbigen sein.
                Möglicherweise hilft die iob diag Spezialversion für Raspi von @Thomas-Braun
                hab den Link gerade nicht parat.
                • ChendaC Chenda
                  Die aktuelle Version sollte trotz der Meldung durchlaufen. Abwarten.
                    ChendaC Offline
                    ChendaC Offline
                    Chenda
                    @thomas-braun sagte in Weboberfläche nicht mehr erreichbar:
                    Abwarten.
                    Nach einigem Warten lief die Diagnose doch durch. Ich sehe da aber nur einen kritischen Fehler, jedoch keinen Ansatzpunkt für das Problem, dass die Weboberfläche nicht erreichbar ist.
                    Copy text starting here:
                    ```bash
                                            v.2025-02-23
                     Static hostname: iobroker
                           Icon name: computer
                    Operating System: Raspbian GNU/Linux 12 (bookworm)
                              Kernel: Linux 6.1.21-v7+
                        Architecture: arm
                    Installation:           native
                    Kernel:                 armv7l
                    Userland:               32 bit
                    Timezone:               Europe/Berlin (CET, +0100)
                    User-ID:                1000
                    Display-Server:         false
                    Boot Target:            multi-user.target
                    Pending OS-Updates:     67
                    Pending iob updates:    0
                    Nodejs-Installation:
                    /usr/bin/nodejs         v20.19.0
                    /usr/bin/node           v20.19.0
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    /usr/bin/corepack       0.31.0
                    Recommended versions are nodejs 20.19.0 and npm 10.8.2
                    nodeJS installation is correct
                    MEMORY:
                    Mem:            966M        654M         91M        417K        277M        312M
                    Swap:           104M        104M          0B
                    Total:          1.1G        759M         91M
                    Active iob-Instances:   16
                    Upgrade policy: none
                    ioBroker Core:          js-controller           7.0.6
                                            admin                   7.4.10
                    Objects type: jsonl
                    States  type: jsonl
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    Objects:                2694
                    States:                 2194
                    Size of iob-Database:
                    13M     /opt/iobroker/iobroker-data/objects.jsonl
                    2.9M    /opt/iobroker/iobroker-data/states.jsonl
                    1560 CRITICAL ERRORS DETECTED!
                    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                    Operating System is the current Debian stable version codenamed 'bookworm'!
                    chenda@iobroker:~ $  sudo dmesg --level=emerg,alert,crit -T
                    [Mon Mar 17 21:15:04 2025] hwmon hwmon1: Undervoltage detected!
                    Dieser Fehler wird laut Zeitstempel etwa alle 10s geschrieben.
                    Das Problem mit der Spannung wundert mich in dem Fall zwar, ich das original Raspi Netzteil habe, aber dürfte meiner Ansicht nach nicht dazu führen, dass die Weboberfläche nicht erreichbar ist.
                    Ich mach jetzt nochmal ein Upgrade
                    chenda@iobroker:~ $ sudo apt update
                    Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
                    Building dependency tree... Done
                    81 packages can be upgraded. Run 'apt list --upgradable' to see them.
                    chenda@iobroker:~ $ sudo apt upgrade
                    Calculating upgrade... Done
                    The following packages were automatically installed and are no longer required:
                      libboost-program-options1.74.0 libcamera-apps-lite libcamera0 libdrm-nouveau2 libexif12
                      libfmt7 libgstreamer-plugins-base1.0-0 libgstreamer1.0-0 liborc-0.4-0 libtiff5 libunwind8
                      libwebp6
                    Use 'sudo apt autoremove' to remove them.
                    The following NEW packages will be installed:
                      dconf-cli firmware-intel-graphics firmware-intel-misc firmware-marvell-prestera
                      firmware-mediatek firmware-nvidia-graphics libdconf1 liblgpio1 libossp-uuid16 libvulkan1
                      mesa-libgallium mesa-vulkan-drivers python3-lgpio python3-pycryptodome python3-spidev uuid
                    The following packages have been kept back:
                      libcamera-apps-lite libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0
                      raspi-utils raspinfo
                    The following packages will be upgraded:
                      alsa-utils bluez bluez-firmware console-setup console-setup-linux dphys-swapfile dpkg
                      dpkg-dev firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree
                      firmware-realtek initramfs-tools initramfs-tools-core keyboard-configuration kms++-utils
                      libasound2 libasound2-data libatopology2 libbluetooth3 libc-bin libc-dev-bin libc-devtools
                      libc-l10n libc6 libc6-dbg libc6-dev libcairo-gobject2 libcairo-script-interpreter2 libcairo2
                      libcairo2-dev libdpkg-perl libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-omap1
                      libdrm-radeon1 libdrm2 libegl-mesa0 libgbm1 libgl1-mesa-dri libglapi-mesa libglx-mesa0
                      libgstreamer-plugins-base1.0-0 libkms++0 libnm0 libpam-chksshpwd libpam-modules
                      libpam-modules-bin libpam-runtime libpam0g libpam0g-dev libpixman-1-0 libpixman-1-dev
                      libssl3 libwayland-client0 libwayland-egl1 libwayland-server0 linux-libc-dev locales
                      network-manager openssl pi-bluetooth python3-gpiozero raspberrypi-net-mods
                      raspberrypi-sys-mods raspi-config raspi-gpio rpi-eeprom rpi-update userconf-pi zlib1g
                      zlib1g-dev
                    74 upgraded, 16 newly installed, 0 to remove and 7 not upgraded.
                    Need to get 267 MB of archives.
                    After this operation, 217 MB of additional disk space will be used.
                    Do you want to continue? [Y/n] y
                    HomoranH Thomas BraunT ? 3 Antworten Letzte Antwort
                    • ChendaC Chenda
                      Abwarten.
                      ```bash
                                              v.2025-02-23
                             Icon name: computer
                          Architecture: arm
                      Kernel:                 armv7l
                      Userland:               32 bit
                      User-ID:                1000
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      MEMORY:
                      Swap:           104M        104M          0B
                                              admin                   7.4.10
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                2694
                      States:                 2194
                        libwebp6
                        zlib1g-dev
                      nein 1560 kritische Fehler
                      weil das nur die Ultrakurzfassung ist, steht außerdem nur wenig drin.
                      In der Langfassung steht erheblich mehr
                      • ChendaC Chenda
                        Abwarten.
                        ```bash
                                                v.2025-02-23
                               Icon name: computer
                            Architecture: arm
                        Kernel:                 armv7l
                        Userland:               32 bit
                        User-ID:                1000
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        MEMORY:
                        Swap:           104M        104M          0B
                                                admin                   7.4.10
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                2694
                        States:                 2194
                          libwebp6
                          zlib1g-dev
                        @chenda
                        1GB RAM ist zu wenig, insbesondere wenn da auch noch offenbar eine graphische Oberfläche mitgeschleppt wird.
                        Ich würde da mal auf potentere Hardware gehen.
                        Näheres kann man der Langfassung entnehmen.
                        Und die Spannungsversorgung ist zu schwach.
                          ChendaC Offline
                          ChendaC Offline
                          Chenda
                          Wie schon geschrieben ist es der eine undervoltage Fehler, der ca. alle 10s geschrieben wird. Daher halt 1560 mal.
                          Ich verstehe nicht, was das mit dem Fehlerbild zu tun hat? Bisher lief es doch auch. Ist durch ein Update die Anforderung an die Hardware gestiegen?
                          • ChendaC Chenda
                            @chenda
                            Dann ist da auch alle 10 Sekunden zu wenig Spannung...
                            Jetzt aber halt nicht mehr. Ist die Eigenschaft von Fehlern, das die oft 'plötzlich' auftauchen.
                              @chenda
                              ChendaC Offline
                              ChendaC Offline
                              Chenda
                              Das ist klar -- aber das hat doch dann nix mit dem RAM etc. zu tun.
                              Evtl. könnte es mit dem undervoltage zu tun haben.
                              Nach dem Upgrade nochmal eine Diagnose gemacht:
                              ```bash
                                                      v.2025-02-23
                                     Icon name: computer
                                  Architecture: arm
                              Kernel:                 armv7l
                              Userland:               32 bit
                              User-ID:                1000
                              Pending OS-Updates:     0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              MEMORY:
                              Mem:            966M        687M        119M        1.0M        220M        279M
                              Swap:           104M        104M          0B
                              Total:          1.1G        792M        119M
                                                      admin                   7.4.10
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                2694
                              States:                 2194
                              3.2M    /opt/iobroker/iobroker-data/states.jsonl
                              1553 CRITICAL ERRORS DETECTED!
                              Da steht doch drin, dass iobroker läuft und web Interface auch.
                              Netzteil kann ich mal austauschen, sobald ich ein neues habe.
                              Aber soll das nicht erreichbare Web Interface echt mit dem Netzteil zusammenhängen?
                              • ChendaC Chenda
                                ```bash
                                                        v.2025-02-23
                                       Icon name: computer
                                    Architecture: arm
                                Kernel:                 armv7l
                                Userland:               32 bit
                                User-ID:                1000
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                MEMORY:
                                Swap:           104M        104M          0B
                                                        admin                   7.4.10
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                2694
                                States:                 2194
                                @chenda
                                Die Langfassung ist gefragt.
                                • ChendaC Chenda
                                  Abwarten.
                                  ```bash
                                                          v.2025-02-23
                                         Icon name: computer
                                      Architecture: arm
                                  Kernel:                 armv7l
                                  Userland:               32 bit
                                  User-ID:                1000
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  MEMORY:
                                  Swap:           104M        104M          0B
                                                          admin                   7.4.10
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                2694
                                  States:                 2194
                                    libwebp6
                                    zlib1g-dev
                                  doch, dein Raspi hat mehrere Probleme, das schlimmste ist das kaputte Netzteil, wirf das weg und mach endlich n neues mit der richtigen Leistung (mind.3,5A) dran. Vorher braucht man hier nicht weiter zu suchen, wenn dauernd die Spannung zusammenbricht, kann der keinen Task richtig starten. Ausserdem geht das auch auf die SD-Karte, die wird wahrscheinlich auch n Hau weg haben.
                                  Mal ganz abgesehen davon, dass 1GB Raspi mindestens 10 Jahre alt ist und heutzutage ausgedient hat..
                                  Dann das upgrade mit 32bit auf Bookworm, was sowieso verbogen sein muss.
                                  Kurz gesagt:
                                  Kauf ne neue potente Hardware, die auf das, was du da machen moechtest, zugeschnitten ist, und installier Debian Bookworm in der 64bit Version darauf neu.
                                  Dann die eine Zeile fuer iobroker zum installieren, Backup zurueck spielen, und fertig ist die Sache.
                                  • ChendaC Chenda
                                    ```bash
                                                            v.2025-02-23
                                           Icon name: computer
                                        Architecture: arm
                                    Kernel:                 armv7l
                                    Userland:               32 bit
                                    User-ID:                1000
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    MEMORY:
                                    Swap:           104M        104M          0B
                                                            admin                   7.4.10
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                2694
                                    States:                 2194
                                    wieder nur die Summary!
                                    das wirklich wichtige steht in der Langfassung.
                                    Die bisher genannten kommen on top und können Auslöser für den wahren Grund sein, der hier nicht zu sehen ist.
