  4. ULANZI TC001 mit Awtrix light "friert" ein
    6.3k
34 Beiträge 9 Kommentatoren 3.3k Aufrufe 7 Beobachtet
  • W Offline
    W Offline
    warp735
    @raspiuser
    Interessant... Das Icon 32930 ist auch bei mir dass, das zu 99% beim einfrieren angezeigt wird
    • RaspiUserR RaspiUser
      Ich nutze eine ULANZI TC001 (Firmware 0.98) und den Awtrix Light Adapter (1.4.1) und probiere gerade ein paar Apps aus ... (ich kann leider nicht sagen, nach welchem Versuch der Fehler zum ersten Mal kam ...)
      Hier die letzten (fehlerhaften ?) Adapter Einstellungen:
        "awtrixIp": "192.168.178.38",
        "userName": "",
        "userPassword": "",
        "downloadScreenContent": false,
        "downloadScreenContentInterval": 10,
        "foreignSettingsInstance": "",
        "foreignSettingsInstanceActivateApps": false,
        "customApps": [
            "name": "wozitemp",
            "icon": "14592",
            "duration": 0,
            "repeat": 0,
            "text": "%s",
            "objId": "sainlogic.0.weather.current.indoortemp",
            "decimals": 1,
            "dynamicRound": false,
            "_textHeader": null,
            "rainbow": null,
            "textColor": "#f8ec04",
            "noScroll": null,
            "scrollSpeed": 0,
            "_backgroundHeader": null,
            "useBackgroundEffect": false,
            "backgroundColor": "#000000",
            "backgroundEffect": "LookingEyes",
            "_thresholdHeader": null,
            "thresholdLtActive": true,
            "thresholdLtValue": 20,
            "thresholdLtIcon": "",
            "thresholdLtTextColor": "#00ffff",
            "thresholdLtBackgroundColor": "",
            "thresholdGtActive": true,
            "thresholdGtValue": 23,
            "thresholdGtIcon": "",
            "thresholdGtTextColor": "#ff0000",
            "thresholdGtBackgroundColor": "",
            "_expertOptionsHeader": null,
            "position": 0
            "name": "photobatterie",
            "icon": "61396",
            "duration": 0,
            "repeat": 0,
            "text": "%s %u",
            "objId": "alpha-ess.0.Realtime.Battery_SOC",
            "decimals": 0,
            "rainbow": null,
            "textColor": "#FFFFFF",
            "noScroll": null,
            "scrollSpeed": 0,
            "backgroundEffect": "BrickBreaker",
            "thresholdLtActive": null,
            "thresholdLtValue": 0,
            "thresholdLtTextColor": "",
            "thresholdGtActive": null,
            "thresholdGtValue": 100,
            "thresholdGtTextColor": "",
            "position": 0
            "name": "photostring",
            "icon": "9098",
            "duration": 0,
            "repeat": 0,
            "text": "%s %u",
            "objId": "alpha-ess.0.Realtime.PV_power_string_1",
            "decimals": 0,
            "dynamicRound": true,
            "rainbow": null,
            "noScroll": null,
            "scrollSpeed": 0,
            "position": 0
            "name": "corsa",
            "icon": "56683",
            "duration": 0,
            "repeat": 0,
            "text": "%s %u",
            "objId": "go-e.0.loaded_energy_kwh",
            "decimals": 1,
            "rainbow": null,
            "noScroll": null,
            "scrollSpeed": 0,
            "position": 0
            "name": "powerload",
            "icon": "32930",
            "duration": 0,
            "repeat": 0,
            "text": "%s %u",
            "objId": "alpha-ess.0.Realtime.Load_total",
            "decimals": 0,
            "rainbow": null,
            "textColor": "#0000ff",
            "noScroll": null,
            "scrollSpeed": 0,
            "thresholdLtValue": 350,
            "thresholdLtTextColor": "#27fb00",
            "thresholdGtValue": 1000,
            "position": 0
        "ignoreNewValueForAppInTimeRange": 4,
        "historyApps": [],
        "historyAppsBackgroundColor": "#000000",
        "historyAppsRefreshInterval": 300,
        "autoDeleteForeignApps": false,
        "removeAppsOnStop": true,
        "httpTimeout": 3,
        "numberFormat": "system",
        "customPositions": false,
        "expertApps": []
      Die Fehlerbeschreibung:
      Die Anzeige "friert" unregelmäßig beim Wechsel (?) zwischen der "wozitemp" und der "powerload" Anzeige ein. Der Adapter ist dann "gelb", die Anzeige ist über WLAN nicht mehr ansprechbar und läßt sich nur durch aus- und wieder einschalten in Gang setzen. Der Adapter selbst braucht keinen Neustart und wird dann von sich aus wieder "grün".
      Einige Apps werden durch Blockly sichtbar geschaltet.
      Der Adpter steht auf "debug" und das LOG-File iobroker.2025-02-11.log ist riesig ... Ich kann dort nicht erkennen bzw. weiss nicht wie ich suchen soll, wann der Fehler auftritt ... er ist aber in diesem Zeitraum aufgetreten.
      Kann jemand helfen ?
      eflo
      @raspiuser
      Ich möchte mich hier gern anhängen, wegen dem gleichen Problem. Bei mir laufen 3 Uhren alles ULANZI TC001 mit FW 0.98 und Awtrix Light Adapter in Version 1.4.1. mit 3 Instanzen. Die
      Uhren habe ich zu unterschiedlichen Zeiten mit einem Abstand von ca. 1/2 Jahr erworben, so das ich mal von unterschiedlichen Chargen ausgehe. Die APP-Einstellen werden von der 1. Instanz übernommen, in der sind 45 benutzerdefinierte APPS angelegt. Alle Uhren frieren nach unterschiedlichen Laufzeiten ab, mal früher mal später und sind nur über Neustart wieder über WLan zu erreichen. Die Häufigkeit der Abstürze hat mit Zuname der benutzerdefinierten APPs zugenommen. Die in den Uhren hinterlegten Icons sind zum größten Teil animiert. Ich habe den Verdacht, dass die Icons mit den Abstützen in Verbindung stehen.
      Da ich aus dem Adapter nicht alle Icon-ID's (45) löschen wollte,
      habe ich die File-Ordner auf den Uhren mal ungenannt.
      Die Uhren laufen jetzt seit ein paar Tagen ohne Absturz, leider aber auch ohne Icons. Da ich an den Adaptereinstellungen nichts geändert habe, sollten die übertragenen Daten von den Adaptern zu den Uhren immer noch die gleichen sein.
      Nun möchte ich natürlich die Uhren weiterhin mit Icons laufen lassen.
      Gibt es hier neue Erkenntnisse?
      • RaspiUserR Online
        RaspiUserR Online
        RaspiUser
        @eflo
        Nein, zumindest ich kenne nix neues ... siehe #13
        @raspiuser sagte in ULANZI TC001 mit Awtrix light "friert" ein:
        ... da bin ich als "einfacher Anwender" raus bzw. kein Entwickler ... ich kann nur laienhafte Beobachtungen mitteilen.
        Wenn mir jemand genau sagt / schreibe was ich konkret tun kann helfe ich gerne ...
          @eflo
          drapo
          Das wird euch zwar nicht helfen hatte die selben Probleme mit dem einfrieren. Ich bin dann auf die Lametric gewechselt. Diese läuft bei mir seit Monaten ohne etwas neuzustarten und somit genau nach meinem Geschmack.
          Der Awtrix Adapter ist aus meiner Sicht besser programmiert wie der Lametric. Das soll auch keine Kritik sein einfach meine persönliche Meinung.
          • D drapo
            haus-automatisierungH Offline
            @drapo Ja den LaMetric Adapter habe ich vor vielen Jahren programmiert. Guckmal wie der ioBroker damals noch aussah :)
            Aber wenn Du Lust hast den auf TypeScript umzuschreiben: Gern einen PR.
            📚 Meine Dokumentation
            • K Offline
              klee
              Ich würde habe das gleich Problem, vielleicht ein paar Daten von mir.
              Firmeware 0.98
              Adapter v3.0.0
              WLAN Unifi mit verschiedenen APs 2,4 Ghz Netz mit 20Mhz Bandbreite
              Bei 8 Apps dauert es ca 1,5 Tage bis es einfriert.
              Es bleibt meist bei dem Icon 34921 hängen (animiert)
              Hat es schonmal jemand mit 40 Mhz Bandbreite beim WLAN Kanal versucht? --> Link
              Ich habe mal versuchsweise meinem unfi Netz mitgeteilt, das der Client (Awtrix Hardware) nicht den AP wechseln darf sondern an einen AP hard gekoppelt ist.
              • K Offline
                klee
                schrieb am zuletzt editiert von klee
                Diesmal hat es 4 Tage gedauert bis es wieder eingefrohren ist, trotz dem AP binding. Hatte mich kurz gefreut, das es jetzt ein wenig länger hält...
                • W Offline
                  W Offline
                  warp735
                  Bei mir hält es "manchmal" auch länger. Aber meist ist nach 1-2 Tagen Neustart angesagt. Wandern bald in Müll die Dinger. So belasten sie nur das Nervenkostüm.
                  • JLegJ Offline
                    JLegJ Offline
                    JLeg
                    bei mir läuft das Teil monatelang ohne Probleme - allerdings schalte ich um 22:30 das Display aus, und schicke es in den Deepsleep (device.sleep) mit der Anzahl Sekunden bis zum Sonnenaufgang. Spart auch noch Strom... :)
                    Thomas BraunT K 3 Antworten Letzte Antwort
                    • JLegJ JLeg
                      @JLeg sagte:
                      Bei mir auch. Und auch ich schicke das Display nachts und bei Abwesenheit in den Schlaf. Und ich habe auch keine 45 Apps angelegt...
                      • W Offline
                        W Offline
                        warp735
                        Habt ihr nur eine Ulanzi?
                        • JLegJ JLeg
                          klee
                          @JLeg sagte:
                          Werde ich auch mal testen :)
                          @warp735 sagte:
                          Ja
                          • JLegJ JLeg
                            klee
                            @JLeg sagte:
                            Ich habe den Datentyp von device.sleep von number (sec) zu einem boolean geändert.
                            Wenn ich abends device.sleep = true sende geht er schlafen.
                            Wenn ich morgens device.sleep = false sende, wacht er auf und geht in den AP Mode und zeigt leider keine Werte mehr von ioBroker an.
                            Laut KI liegt das wohl dann daran, das er sich nicht schnell genug im WLAN einwählen kann.
                            Ich nehme mal das Accespoint Binding in Unifi wieder raus. mal sehen ob er sich dann schnell genug wieder verbinden kann.
                            • K klee
                              @JLeg sagte:
                              @klee sagte:
                              Und warum? Bitte nichts an Datenpunkten ändern, welche man nicht selbst angelegt hat. Die verwaltet logischerweise der Adapter. sleep erwartet jedenfalls einen numerischen Wert:
                              https://blueforcer.github.io/awtrix3/#/api?id=power-control
