  4. OSRAM Smart+ schaltet unkontrolliert (Zigbee)
15 Beiträge 7 Kommentatoren 2.0k Aufrufe 4 Beobachtet
  • surfer09S Offline
    surfer09S Offline
    surfer09
    ich habe eine OSRAM Smart+ Steckdose, die sich häufig unkontrolliert an und aus schaltet. Warum auch immer sie das macht, es schaltet sie aktiv niemand ein / aus.
    Ich habe gestern das LOG mal auf "Debug" gestellt und das hier eingefangen als sie eingeschaltet hat.
    2025-01-17 13:41:47.874 - debug: zigbee.0 (5036) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":29,"_applicationVersion":9,"_dateCode":"20140331DEOS****","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"profileID":49246,"ID":3,"clusters":{"genBasic":{"attributes":{"modelId":"Plug 01","manufacturerName":"OSRAM","powerSource":1,"zclVersion":1,"appVersion":9,"stackVersion":2,"hwVersion":1,"dateCode":"20140331DEOS****","swBuildId":"V1.05.09"}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x7cb03eaa0a09c05c","deviceNetworkAddress":41270,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":3,"deviceIeeeAddress":"0x7cb03eaa0a09c05c"}}],"_hardwareVersion":1,"_ieeeAddr":"0x7cb03eaa0a09c05c","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1737117707874,"_manufacturerID":48042,"_manufacturerName":"OSRAM","_modelID":"Plug 01","_networkAddress":41270,"_powerSource":"Mains (single phase)","_softwareBuildID":"V1.05.09","_stackVersion":2,"_type":"Router","_zclVersion":1,"_linkquality":172,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909577},"linkquality":172,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-01-17 13:41:47.874 - debug: zigbee.0 (5036) Received Zigbee message from '0x7cb03eaa0a09c05c', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909577}' from endpoint 3 with groupID 0
    2025-01-17 13:41:47.874 - debug: zigbee.0 (5036) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":29,"_applicationVersion":9,"_dateCode":"20140331DEOS****","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"profileID":49246,"ID":3,"clusters":{"genBasic":{"attributes":{"modelId":"Plug 01","manufacturerName":"OSRAM","powerSource":1,"zclVersion":1,"appVersion":9,"stackVersion":2,"hwVersion":1,"dateCode":"20140331DEOS****","swBuildId":"V1.05.09"}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x7cb03eaa0a09c05c","deviceNetworkAddress":41270,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":3,"deviceIeeeAddress":"0x7cb03eaa0a09c05c"}}],"_hardwareVersion":1,"_ieeeAddr":"0x7cb03eaa0a09c05c","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1737117707874,"_manufacturerID":48042,"_manufacturerName":"OSRAM","_modelID":"Plug 01","_networkAddress":41270,"_powerSource":"Mains (single phase)","_softwareBuildID":"V1.05.09","_stackVersion":2,"_type":"Router","_zclVersion":1,"_linkquality":172,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]}],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"onEvent":null,"ota":{},"zigbeeModel":["Plug 01"],"model":"AB3257001NJ","description":"Smart+ plug","vendor":"OSRAM","whiteLabel":[{"vendor":"LEDVANCE","model":"AB3257001NJ"},{"vendor":"LEDVANCE","model":"AC03360"}],"options":["[Circular]"]},"name":"0x7cb03eaa0a09c05c"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":29,"_applicationVersion":9,"_dateCode":"20140331DEOS****","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"profileID":49246,"ID":3,"clusters":{"genBasic":{"attributes":{"modelId":"Plug 01","manufacturerName":"OSRAM","powerSource":1,"zclVersion":1,"appVersion":9,"stackVersion":2,"hwVersion":1,"dateCode":"20140331DEOS****","swBuildId":"V1.05.09"}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x7cb03eaa0a09c05c","deviceNetworkAddress":41270,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":3,"deviceIeeeAddress":"0x7cb03eaa0a09c05c"}}],"_hardwareVersion":1,"_ieeeAddr":"0x7cb03eaa0a09c05c","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1737117707874,"_manufacturerID":48042,"_manufacturerName":"OSRAM","_modelID":"Plug 01","_networkAddress":41270,"_powerSource":"Mains (single phase)","_softwareBuildID":"V1.05.09","_stackVersion":2,"_type":"Router","_zclVersion":1,"_linkquality":172,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909577},"linkquality":172,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    • surfer09S surfer09
      arteckA Offline
      arteckA Offline
      arteck
      @surfer09 schmeiss weg das olle Ding..
      surfer09S 1 Antwort Letzte Antwort
      • arteckA arteck
        surfer09S Offline
        surfer09S Offline
        surfer09
        @arteck Ich setze den eigentlich nur noch ein, weil sich die anderen Zigbee Geräte dort auch anmelden können, weil der Zigbee Stick nicht ganz in der Nähe ist. Gibts da eine Alternative für?
          FabioF Offline
          FabioF Offline
          Fabio
          schrieb am zuletzt editiert von Fabio
          @surfer09 du kannst zum Beispiel einen Lidl Plug nehmen, davon habe ich sehr viele im System, die laufen einwandfrei und sind auch gute Router.
          Oder von Aetoc das hier https://aeotec.com/products/aeotec-range-extender-zi/ die sind auch sehr gut.
          Iobroker:
          • Matter over Thread Hilfe
          • FabioF Fabio
            surfer09S Offline
            surfer09S Offline
            surfer09
            @fabio Super, Dankeschön für den Tipp!
            FabioF haselchenH 2 Antworten Letzte Antwort
              FabioF Offline
              FabioF Offline
              Fabio
              @surfer09 hier siehst du die Verbindungen gut, Stehlampe ist ein Lidl Plug.
              Iobroker:
                haselchenH Offline
                haselchenH Offline
                haselchen
                @surfer09
                Eigentlich musste Dir nur merken ,
                Zigbee = Batterie = kein Repeater
                Zigbee = Strom = Repeater
                Und danach suchst Du im Netz .
                Am Strom hängen meistens Birnen, Steckdosen….
                • FabioF Fabio
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @fabio sagte in OSRAM Smart+ schaltet unkontrolliert (Zigbee):
                  Blende mal in der Map die Nachbarn (siblings) aus. Nur dann kannst du sehen wie die Verbindung wirklich läuft.
                  A.
                  • AsgothianA Asgothian
                    A.
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    @asgothian hab ich gemacht das sieht denk ich nicht so gut aus oder?
                    Iobroker:
                    • haselchenH haselchen
                      @surfer09
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      @haselchen sagte in OSRAM Smart+ schaltet unkontrolliert (Zigbee):
                      @surfer09
                      Das stimmt leider nur "meistens".
                      Hab noch keine Steckdose oder Lampe gesehen die kein Router ist aber ->
                      Das ist ein FP1E hat Dauerstrom und ist kein router.
                      Ich kaufe mir gerne die Steckdosen von Nous A1Z ... mag die Firma wegen dem Tasmota Kram.
                      EDIT: oh rechtschreibfehler im Lampen namen :D
                      Spenden
                      • FabioF Fabio
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        Jein. Jetzt siehst du wenigstens mal was. Unter anderem auch das du da irgendeinen Router hast der seine Routing Table nicht sauber weiter gibt :)
                        Ansonsten kannst du jetzt wirklich die Verbindungen sehen, nicht nur ein Meer aus grünen Linien
                        A.
                          A.
                          FabioF Offline
                          FabioF Offline
                          Fabio
                          @asgothian okay, aber das jetzt rauszufinden, wer was nicht weiterleitet, ist mir zu viel Arbeit, da müsste ich quasi wieder von vorne anfangen und alles 24 Stunden schauen wo es hängt. Habe jetzt fast einen Monat mein System auf den ZigBee Adapter etc. umgestellt, jetzt reicht es erst mal.
                          Und wieder was gelernt hier. ;-)
                          Herzliche Grüße
                          Fabio
                          Iobroker:
                          L 1 Antwort Letzte Antwort
                          • FabioF Fabio
                            Herzliche Grüße
                            Fabio
                            legro
                            .. rauszufinden, wer was nicht weiterleitet, ist mir zu viel Arbeit, ..
                            Das habe ich schon lange aufgegeben.😕
                            Ich habe mich schweren Herzens entschieden, alle OSRAM Teile nach und nach in die Mülltonne einzubauen. Was ich da schon an Zeit für die Fehlersuche aufbringen musste, ließ mich so manche Ausgaben verschmerzen.
                            Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                            • L legro
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              @legro das glaube ich dir gerne. Ich achte jetzt immer bei Neukauf ob die ZigBee 3.0 können.
                              Grüße
                              Fabio
                              Iobroker:
                              • T ticaki
                                @surfer09
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @ticaki sagte in OSRAM Smart+ schaltet unkontrolliert (Zigbee):
                                das sind die Sonderfälle.. meistens sind das die PIR's.. die brauchen mehr Strom deshalb hängen die am Strom.. machen aber kein Routing..
