  4. Kaputt nach Update
Kaputt nach Update
15 Beiträge 4 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • 6 Offline
    6 Offline
    64kbyte
    Ich habe gemäss Anweisung
    iobroker stop
    iobroker update
    iobroker fix
    ipbroker uprade self
    meine iobroker Installation beim Upgrade kaputt gemacht. Es startet praktisch nichts mehr, keine Adapter, keine Weboberfläche. Die Fehlermeldungen sind immer die gleichen, aber für mich wenig aufschlussreich:
    2025-01-03 10:26:11.417  - info: host.UBU14 iobroker.js-controller version 7.0.6 js-controller starting
    2025-01-03 10:26:11.419  - info: host.UBU14 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-01-03 10:26:11.420  - info: host.UBU14 hostname: UBU14, node: v18.17.1
    2025-01-03 10:26:11.421  - info: host.UBU14 ip addresses: 10.0.2.3 fe80::8400:ff:fe48:7a5
    2025-01-03 10:26:12.020  - info: host.UBU14 connected to Objects and States
    2025-01-03 10:26:12.034  - info: host.UBU14 added notifications configuration of host
    2025-01-03 10:26:12.332  - info: host.UBU14 34 instances found
    2025-01-03 10:26:12.348  - info: host.UBU14 starting 31 instances
    2025-01-03 10:26:12.521  - info: host.UBU14 instance system.adapter.admin.0 in version "6.13.16" started with pid 4476
    2025-01-03 10:26:14.012  - error: admin.0 (4476) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-01-03 10:26:14.023  - error: admin.0 (4476) unhandled promise rejection: callback is not a function
    2025-01-03 10:26:14.025  - error: admin.0 (4476) TypeError: callback is not a function
        at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
    2025-01-03 10:26:14.025  - error: admin.0 (4476) callback is not a function
    2025-01-03 10:26:14.387  - info: admin.0 (4476) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 7.0.6
    2025-01-03 10:26:14.559  - info: admin.0 (4476) terminating
    2025-01-03 10:26:14.560  - warn: admin.0 (4476) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-01-03 10:26:15.123  - error: host.UBU14 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-01-03 10:26:15.124  - error: host.UBU14 Caught by controller[1]: TypeError: callback is not a function
    2025-01-03 10:26:15.124  - error: host.UBU14 Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
    2025-01-03 10:26:15.125  - error: host.UBU14 instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-01-03 10:26:15.125  - info: host.UBU14 Restart adapter system.adapter.admin.0 because enabled
    2025-01-03 10:26:16.502  - info: host.UBU14 instance system.adapter.sql.0 in version "2.2.0" started with pid 4494
    System ist
    Ubuntu 22.04.5 LTS (GNU/Linux 5.15.0-130-generic aarch64)
    Wo soll ich als erstes hinlangen?
    Vielen Dank.
    • 6 64kbyte
      iobroker stop
      iobroker update
      iobroker fix
      System ist
      Vielen Dank.
      @64kbyte sagte in Kaputt nach Update:
      die Langfassung von iob diag posten
      6 1 Antwort Letzte Antwort
        6 Offline
        6 Offline
        64kbyte
        Script v.2024-10-19
        *** BASE SYSTEM ***
         Static hostname: UBU14
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Ubuntu 22.04.5 LTS
                  Kernel: Linux 5.15.0-130-generic
            Architecture: arm64
         Hardware Vendor: Hetzner
          Hardware Model: vServer
        OS is similar to: debian
        Docker          : false
        Virtualization  : kvm
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         10:51:53 up 37 min,  3 users,  load average: 0.66, 0.34, 0.29
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2025-01-03 10:51:53 CET
                   Universal time: Fri 2025-01-03 09:51:53 UTC
                         RTC time: Fri 2025-01-03 09:51:54
                        Time zone: Europe/Zurich (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        iobroker
        OPENHAB_HOME=/usr/share/openhab
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        iobroker
        HOME=/home/iobroker
        A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
        A root login is not required in most Linux Distributions.
        Run 'iobroker fix' or use the system tools to create a user.
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            3.8G        1.1G        824M         22M        1.8G        2.5G
        Swap:           1.0G          0B        1.0G
        Total:          4.8G        1.1G        1.8G
        Active iob-Instances:   2
                 3813 M total memory
                 1149 M used memory
                  708 M active memory
                 1894 M inactive memory
                  824 M free memory
                  205 M buffer memory
                 1634 M swap cache
                 1023 M total swap
                    0 M used swap
                 1023 M free swap
        top - 10:51:54 up 37 min,  3 users,  load average: 0.66, 0.34, 0.29
        Tasks: 193 total,   2 running, 191 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 50.0 us, 12.5 sy,  0.0 ni, 37.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3813.8 total,    818.5 free,   1155.2 used,   1840.1 buff/cache
        MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   2450.6 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        tmpfs          tmpfs  382M  1.1M  381M   1% /run
        /dev/sda1      ext4    38G   14G   23G  39% /
        tmpfs          tmpfs  1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
        /dev/sda15     vfat   253M  6.3M  246M   3% /boot/efi
        tmpfs          tmpfs  382M     0  382M   0% /run/user/0
        [Fri Jan  3 10:14:45 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Fri Jan  3 10:14:46 2025] EXT4-fs (sda1): re-mounted. Opts: (null). Quota mode: none.
        Show mounted filesystems:
        TARGET      SOURCE     FSTYPE OPTIONS
        /           /dev/sda1  ext4   rw,relatime
        `-/boot/efi /dev/sda15 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        /var:
        2.6G    /var/
        1.4G    /var/log
        1.2G    /var/log/journal/d00883623d1e40b08f3f029f850712c9
        1023M   /var/lib
        Archived and active journals take up 400.1M in the file system.
        /opt/iobroker/backups:
        116M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        157M    /opt/iobroker/iobroker-data/
        117M    /opt/iobroker/iobroker-data/files
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        8.2M    /opt/iobroker/iobroker-data/objects.jsonl
        6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
        6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.9~dfsg-1ubuntu3.6 500
                500 http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe arm64 Packages
                500 http://ports.ubuntu.com/ubuntu-ports jammy-security/universe arm64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: redis
        States  type: redis
        Hosts:
        UBU14               UBU14 (version: 7.0.6, hostname: UBU14         , alive, uptime: 91)
        Core adapters versions
        admin:          6.13.16
        javascript:     7.8.0
        nodejs modules from github:     9
        +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#b60ff276702bbee5ca4cb4ef90ca743055281b20)
        +-- iobroker.garmin@0.0.4 (git+ssh://git@github.com/TA2k/ioBroker.garmin.git#eb23cf2960bb35e7b2917d859f153c21bf60e5d3)
        +-- iobroker.luxtronik2@0.4.2 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#68def1b194fb8cc418dc0543c3a0b48e5206cb45)
        +-- iobroker.miele@0.1.6 (git+ssh://git@github.com/soef/ioBroker.miele.git#5e90c7af1e5d8f83beaff7767e065e166e8cc544)
        +-- iobroker.mielecloudservice@6.5.4 (git+ssh://git@github.com/Grizzelbee/ioBroker.mielecloudservice.git#756d7a4dcae64ea50459e8af38e24bd8f0dd14da)
        +-- iobroker.swiss-weather-api@2.1.0 (git+ssh://git@github.com/baerengraben/ioBroker.swiss-weather-api.git#82276c9d7fb6dda69499c3d6e193a682eaabf7d0)
        +-- iobroker.vis-inventwo@3.3.3 (git+ssh://git@github.com/inventwo/ioBroker.vis-inventwo.git#c0ac2de2a01b3e616f1d230b8def838c70a680d4)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
        +-- iobroker.vw-connect@0.5.4 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#85f79d2a7282c7dacb8899fe2d0822971e549018)
        Adapter State
          system.adapter.admin.0                  : admin                 : UBU14                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : UBU14                                    -  enabled
          system.adapter.discovery.0              : discovery             : UBU14                                    -  enabled
          system.adapter.energiefluss.0           : energiefluss          : UBU14                                    -  enabled
          system.adapter.hm-rega.0                : hm-rega               : UBU14                                    -  enabled
          system.adapter.hm-rpc.0                 : hm-rpc                : UBU14                                    -  enabled, port: 0
          system.adapter.hm-rpc.1                 : hm-rpc                : UBU14                                    -  enabled, port: 0
          system.adapter.hue.0                    : hue                   : UBU14                                    - disabled, port: 443
        + system.adapter.javascript.0             : javascript            : UBU14                                    -  enabled
          system.adapter.luftdaten.0              : luftdaten             : UBU14                                    -  enabled
          system.adapter.luxtronik2.0             : luxtronik2            : UBU14                                    -  enabled, port: 8214
          system.adapter.meteoalarm.0             : meteoalarm            : UBU14                                    -  enabled
          system.adapter.mielecloudservice.0      : mielecloudservice     : UBU14                                    -  enabled
          system.adapter.modbus.0                 : modbus                : UBU14                                    -  enabled
          system.adapter.modbus.1                 : modbus                : UBU14                                    -  enabled
          system.adapter.modbus.2                 : modbus                : UBU14                                    -  enabled
          system.adapter.modbus.3                 : modbus                : UBU14                                    -  enabled
          system.adapter.modbus.4                 : modbus                : UBU14                                    -  enabled
          system.adapter.modbus.5                 : modbus                : UBU14                                    -  enabled
          system.adapter.modbus.6                 : modbus                : UBU14                                    -  enabled
          system.adapter.modbus.7                 : modbus                : UBU14                                    -  enabled
          system.adapter.modbus.8                 : modbus                : UBU14                                    -  enabled
          system.adapter.netatmo.0                : netatmo               : UBU14                                    -  enabled
          system.adapter.openhab.0                : openhab               : UBU14                                    -  enabled, port: 8080
          system.adapter.pvforecast.0             : pvforecast            : UBU14                                    -  enabled
          system.adapter.pvforecast.1             : pvforecast            : UBU14                                    - disabled
          system.adapter.robonect.0               : robonect              : UBU14                                    - disabled
          system.adapter.sql.0                    : sql                   : UBU14                                    -  enabled
          system.adapter.sql.1                    : sql                   : UBU14                                    -  enabled
          system.adapter.swiss-weather-api.0      : swiss-weather-api     : UBU14                                    -  enabled
          system.adapter.vis.0                    : vis                   : UBU14                                    -  enabled
          system.adapter.vw-connect.0             : vw-connect            : UBU14                                    -  enabled
          system.adapter.vw-connect.1             : vw-connect            : UBU14                                    -  enabled
          system.adapter.web.0                    : web                   : UBU14                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 6.13.16 [Updatable]
        Adapter    "backitup"     : 3.0.25   , installed 2.10.11 [Updatable]
        Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
        Adapter    "energiefluss" : 3.6.2    , installed 3.6.0  [Updatable]
        Adapter    "garmin"       : 0.0.3    , installed 0.0.4
        Adapter    "hm-rega"      : 5.1.0    , installed 4.0.0  [Updatable]
        Adapter    "hm-rpc"       : 2.0.2    , installed 1.16.0 [Updatable]
        Adapter    "hue"          : 3.13.1   , installed 3.10.2 [Updatable]
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
        Adapter    "javascript"   : 8.8.3    , installed 7.8.0  [Updatable]
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "luftdaten"    : 4.0.0    , installed 3.1.0  [Updatable]
        Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.2  [Updatable]
        Adapter    "miele"        : 0.1.5    , installed 0.1.6
        Adapter    "mielecloudservice": 6.5.7, installed 6.5.4  [Updatable]
        Adapter    "modbus"       : 6.3.2    , installed 6.1.0  [Updatable]
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "openhab"      : 1.2.0    , installed 1.2.0
        Adapter    "pvforecast"   : 4.1.0    , installed 2.9.1  [Updatable]
        Adapter    "robonect"     : 1.4.2    , installed 1.3.4  [Updatable]
        Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
        Adapter    "smartgarden"  : 2.0.1    , installed 2.0.0  [Updatable]
        Adapter    "socketio"     : 6.7.1    , installed 6.6.1  [Updatable]
        Adapter    "sql"          : 3.0.1    , installed 2.2.0  [Updatable]
        Adapter    "swiss-weather-api": 2.2.2, installed 2.1.0  [Updatable]
        Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
        Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
        Adapter    "ws"           : 2.6.2    , installed 2.5.11 [Updatable]
        Objects and States
        Objects:        12300
        States:         10876
        Hit:1 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
        Hit:2 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease
        Hit:3 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
        Hit:4 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:6 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
        Hit:7 https://repo.zabbix.com/zabbix/6.4/ubuntu-arm64 jammy InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:10051           0.0.0.0:*               LISTEN      114        24398      762/zabbix_server
        tcp        0      0 10.0.2.3:53             0.0.0.0:*               LISTEN      121        21326      734/named
        tcp        0      0 10.0.2.3:53             0.0.0.0:*               LISTEN      121        21325      734/named
        tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      33         22107      718/python3
        tcp        0      0 0.0.0.0:514             0.0.0.0:*               LISTEN      0          21760      712/rsyslogd
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        20797      637/systemd-resolve
        tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      121        21322      734/named
        tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      121        21321      734/named
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17927      1/init
        tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      121        21328      734/named
        tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      121        21327      734/named
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21206      728/sshd: /usr/sbin
        tcp6       0      0 :::8080                 :::*                    LISTEN      116        26899      1473/java
        tcp6       0      0 :::10050                :::*                    LISTEN      114        22052      719/zabbix_agent2
        tcp6       0      0 :::10051                :::*                    LISTEN      114        24399      762/zabbix_server
        tcp6       0      0 127.0.0.1:8101          :::*                    LISTEN      116        26419      1473/java
        tcp6       0      0 127.0.0.1:37203         :::*                    LISTEN      116        26352      1473/java
        tcp6       0      0 :::8888                 :::*                    LISTEN      33         22108      718/python3
        tcp6       0      0 :::514                  :::*                    LISTEN      0          21761      712/rsyslogd
        tcp6       0      0 :::5007                 :::*                    LISTEN      116        27214      1473/java
        tcp6       0      0 :::3000                 :::*                    LISTEN      117        22169      675/grafana
        tcp6       0      0 :::8443                 :::*                    LISTEN      116        26897      1473/java
        tcp6       0      0 :::111                  :::*                    LISTEN      0          17929      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          21217      728/sshd: /usr/sbin
        udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          21066      700/chronyd
        udp        0      0 0.0.0.0:514             0.0.0.0:*                           0          21756      712/rsyslogd
        udp        0      0 10.0.2.3:53             0.0.0.0:*                           121        21324      734/named
        udp        0      0 10.0.2.3:53             0.0.0.0:*                           121        21323      734/named
        udp        0      0 127.0.0.1:53            0.0.0.0:*                           121        21320      734/named
        udp        0      0 127.0.0.1:53            0.0.0.0:*                           121        21319      734/named
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        20796      637/systemd-resolve
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          21304      686/dhclient
        udp        0      0 10.0.2.3:68             0.0.0.0:*                           101        21533      635/systemd-network
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17928      1/init
        udp6       0      0 ::1:323                 :::*                                0          21067      700/chronyd
        udp6       0      0 :::514                  :::*                                0          21757      712/rsyslogd
        udp6       0      0 :::5353                 :::*                                116        27035      1473/java
        udp6       0      0 :::1900                 :::*                                116        27352      1473/java
        udp6       0      0 :::1902                 :::*                                116        27946      1473/java
        udp6       0      0 10.0.2.3:59483          :::*                                116        27919      1473/java
        udp6       0      0 :::111                  :::*                                0          17930      1/init
        2025-01-03 10:52:23.385  - error: host.UBU14 Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
        2025-01-03 10:52:23.385  - error: host.UBU14 Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
        2025-01-03 10:52:23.385  - error: host.UBU14 instance system.adapter.modbus.4 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2025-01-03 10:52:23.386  - info: host.UBU14 Restart adapter system.adapter.modbus.4 because enabled
        2025-01-03 10:52:23.386  - warn: host.UBU14 Do not restart adapter system.adapter.modbus.4 because restart loop detected
        2025-01-03 10:52:23.731  - info: host.UBU14 instance system.adapter.pvforecast.0 in version "2.9.1" started with pid 14090
        2025-01-03 10:52:24.385  - info: host.UBU14 instance system.adapter.vw-connect.0 in version "0.5.4" (non-npm: ta2k/ioBroker.vw-connect) started with pid 14454
        2025-01-03 10:52:24.847  - info: host.UBU14 instance system.adapter.modbus.3 in version "6.1.0" started with pid 14463
        2025-01-03 10:52:25.358  - error: pvforecast.0 (14090) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2025-01-03 10:52:25.360  - error: pvforecast.0 (14090) unhandled promise rejection: callback is not a function
        2025-01-03 10:52:25.361  - error: pvforecast.0 (14090) TypeError: callback is not a function
        2025-01-03 10:52:25.362  - error: pvforecast.0 (14090) callback is not a function
        2025-01-03 10:52:25.891  - info: pvforecast.0 (14090) terminating
        2025-01-03 10:52:25.891  - warn: pvforecast.0 (14090) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2025-01-03 10:52:25.931  - info: pvforecast.0 (14090) starting. Version 2.9.1 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v20.18.1, js-controller: 7.0.6
        2025-01-03 10:52:26.443  - error: host.UBU14 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2025-01-03 10:52:26.444  - error: host.UBU14 Caught by controller[1]: TypeError: callback is not a function
        2025-01-03 10:52:26.444  - error: host.UBU14 Caught by controller[1]:     at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
        2025-01-03 10:52:26.444  - error: host.UBU14 Caught by controller[1]:     at runNextTicks (node:internal/process/task_queues:60:5)
        2025-01-03 10:52:26.444  - error: host.UBU14 Caught by controller[1]:     at processImmediate (node:internal/timers:454:9)
        2025-01-03 10:52:26.445  - error: host.UBU14 instance system.adapter.pvforecast.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2025-01-03 10:52:26.445  - info: host.UBU14 Restart adapter system.adapter.pvforecast.0 because enabled
        • 6 64kbyte
          Script v.2024-10-19
          *** BASE SYSTEM ***
                   Chassis: vm
            Virtualization: kvm
              Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 2
                        NTP service: active
                    RTC in local TZ: no
          iobroker
          HOME=/home/iobroker
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
                   3813 M total memory
                   1149 M used memory
                    708 M active memory
                    824 M free memory
                    205 M buffer memory
                   1634 M swap cache
                   1023 M total swap
                      0 M used swap
                   1023 M free swap
          *** FILESYSTEM ***
          /var:
          2.6G    /var/
          1.4G    /var/log
          1023M   /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: redis
          States  type: redis
          Hosts:
          admin:          6.13.16
          javascript:     7.8.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        12300
          States:         10876
          Pending Updates: 0
          @64kbyte
          iob update
          iob upgrade all -y
          iob start admin
          Und ob die Idee, das auf einem vServer bei Hetzner zu betreiben die beste Idee ist wahrlich auch zu bezweifeln.
          6 2 Antworten Letzte Antwort
            @64kbyte
            iob update
            iob upgrade all -y
            iob start admin
            6 Offline
            6 Offline
            64kbyte
            @thomas-braun said in Kaputt nach Update:
            @64kbyte
            Warum nicht? Ich habe mir da ne private cloud gebaut. Zugriff erfolgt via Site2Site VPN. Ausser vielleicht "Laufzeiten" mache ich mir da keine grossen Sorgen.
            Ich mach' mal die angegebenen Befehle und melde mich wieder
              @64kbyte
              iob update
              iob upgrade all -y
              iob start admin
              6 Offline
              6 Offline
              64kbyte
              @64kbyte
              iob update
              iob upgrade all -y
              iob start admin
              Das war weitestgehend erfolgreich. Eine Fehlermeldung bleibt:
              2025-01-03 11:16:43.082  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
              Require stack:
              - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/lib/PluginHandler.js
              - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/index.js
              - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
              - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/index.js
              - /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js
              • 6 64kbyte
                @64kbyte
                iob update
                iob upgrade all -y
                iob start admin
                Require stack:
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                @64kbyte
                Hast du nun alle Adapter auf einem aktuellen Stand?
                Poste bitte nochmal ein aktualisiertes iob diag.
                UNd zeig bitte mal den output von npm ls @iobroker/plugin-sentry
                Sollte in etwa so aussehen:
                xxx@xxx:/opt/iobroker $ npm ls @iobroker/plugin-sentry
                iobroker.inst@3.0.0 /opt/iobroker
                └─┬ iobroker.js-controller@7.0.3
                  └── @iobroker/plugin-sentry@2.0.4
                EDIT: name of plugin korrigiert
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • mcm1957M mcm1957
                  @64kbyte
                  6 Offline
                  6 Offline
                  64kbyte
                  @mcm1957 said in Kaputt nach Update:
                  npm ls @iobroker/sentry-plugin
                  Glaub schon, dass die Adapter alle auf dem aktuellen Stand sind. Jedenfalls funktioniert alles bis auf die Sentry Fehlermeldung. Hier das diag:
                  Script v.2024-10-19
                  *** BASE SYSTEM ***
                           Chassis: vm
                    Virtualization: kvm
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                   21:22:22 up 10:24,  2 users,  load average: 0.24, 0.25, 0.20
                  CPU threads: 2
                                 Local time: Fri 2025-01-03 21:22:22 CET
                             Universal time: Fri 2025-01-03 20:22:22 UTC
                                   RTC time: Fri 2025-01-03 20:22:23
                                NTP service: active
                            RTC in local TZ: no
                  iobroker
                  HOME=/home/iobroker
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:            3.8G        2.3G        243M         22M        1.3G        1.3G
                  Swap:           1.0G        0.0K        1.0G
                  Total:          4.8G        2.3G        1.3G
                  Active iob-Instances:   29
                           3813 M total memory
                           2303 M used memory
                            565 M active memory
                           2682 M inactive memory
                            243 M free memory
                            122 M buffer memory
                           1143 M swap cache
                           1023 M total swap
                              0 M used swap
                           1023 M free swap
                  top - 21:22:22 up 10:24,  2 users,  load average: 0.24, 0.25, 0.20
                  Tasks: 211 total,   3 running, 208 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 33.3 us,  3.0 sy,  0.0 ni, 60.6 id,  0.0 wa,  0.0 hi,  3.0 si,  0.0 st
                  MiB Mem :   3813.8 total,    243.4 free,   2303.3 used,   1267.1 buff/cache
                  MiB Swap:   1024.0 total,   1023.2 free,      0.8 used.   1303.5 avail Mem
                  [sudo] password for iobroker:
                  *** FILESYSTEM ***
                  /dev/sda1      ext4    38G   15G   22G  41% /
                  [Fri Jan  3 10:58:15 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Fri Jan  3 10:58:16 2025] EXT4-fs (sda1): re-mounted. Opts: (null). Quota mode: none.
                  /var:
                  2.6G    /var/
                  1.4G    /var/log
                  1023M   /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: redis
                  States  type: redis
                  Hosts:
                  UBU14               UBU14 (version: 7.0.6, hostname: UBU14         , alive, uptime: 36662)
                  admin:          7.1.5
                  javascript:     8.8.3
                  nodejs modules from github:     5
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : UBU14                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : UBU14                                    -  enabled
                  + system.adapter.discovery.0              : discovery             : UBU14                                    -  enabled
                  + system.adapter.energiefluss.0           : energiefluss          : UBU14                                    -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : UBU14                                    -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : UBU14                                    -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : UBU14                                    -  enabled, port: 0
                  + system.adapter.luxtronik2.0             : luxtronik2            : UBU14                                    -  enabled, port: 8214
                  + system.adapter.mielecloudservice.0      : mielecloudservice     : UBU14                                    -  enabled
                  + system.adapter.modbus.0                 : modbus                : UBU14                                    -  enabled
                  + system.adapter.modbus.1                 : modbus                : UBU14                                    -  enabled
                  + system.adapter.modbus.2                 : modbus                : UBU14                                    -  enabled
                  + system.adapter.modbus.3                 : modbus                : UBU14                                    -  enabled
                  + system.adapter.modbus.4                 : modbus                : UBU14                                    -  enabled
                  + system.adapter.modbus.5                 : modbus                : UBU14                                    -  enabled
                  + system.adapter.modbus.6                 : modbus                : UBU14                                    -  enabled
                  + system.adapter.modbus.7                 : modbus                : UBU14                                    -  enabled
                  + system.adapter.modbus.8                 : modbus                : UBU14                                    -  enabled
                  + system.adapter.netatmo.0                : netatmo               : UBU14                                    -  enabled
                  + system.adapter.openhab.0                : openhab               : UBU14                                    -  enabled, port: 8080
                  + system.adapter.pvforecast.0             : pvforecast            : UBU14                                    -  enabled
                  + system.adapter.sql.0                    : sql                   : UBU14                                    -  enabled
                  + system.adapter.sql.1                    : sql                   : UBU14                                    -  enabled
                  + system.adapter.swiss-weather-api.0      : swiss-weather-api     : UBU14                                    -  enabled
                  + system.adapter.vw-connect.0             : vw-connect            : UBU14                                    -  enabled
                  + system.adapter.vw-connect.1             : vw-connect            : UBU14                                    -  enabled
                  + system.adapter.web.0                    : web                   : UBU14                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                  Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "hue"          : 3.13.1   , installed 3.13.1
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
                  Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
                  Adapter    "mielecloudservice": 6.5.7, installed 6.5.7
                  Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                  Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
                  Adapter    "robonect"     : 1.4.2    , installed 1.4.2
                  Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "sql"          : 3.0.1    , installed 3.0.1
                  Adapter    "swiss-weather-api": 2.2.2, installed 2.2.2
                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Objects and States
                  Objects:        14075
                  States:         12650
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21092      729/sshd: /usr/sbin
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17555      1/init
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        20742      638/systemd-resolve
                  tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      33         22168      719/python3
                  tcp        0      0 10.0.2.3:53             0.0.0.0:*               LISTEN      121        21193      734/named
                  tcp        0      0 10.0.2.3:53             0.0.0.0:*               LISTEN      121        21192      734/named
                  tcp        0      0 0.0.0.0:514             0.0.0.0:*               LISTEN      0          21011      713/rsyslogd
                  tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      121        21189      734/named
                  tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      121        21188      734/named
                  tcp        0      0 10.0.2.3:2010           0.0.0.0:*               LISTEN      1000       47554      4751/io.hm-rpc.0
                  tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      121        21203      734/named
                  tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      121        21202      734/named
                  tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       46825      4688/io.hm-rpc.1
                  tcp        0      0 0.0.0.0:10051           0.0.0.0:*               LISTEN      114        22143      769/zabbix_server
                  tcp6       0      0 :::8443                 :::*                    LISTEN      116        53308      5179/java
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          21094      729/sshd: /usr/sbin
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          17557      1/init
                  tcp6       0      0 :::8888                 :::*                    LISTEN      33         22169      719/python3
                  tcp6       0      0 :::514                  :::*                    LISTEN      0          21012      713/rsyslogd
                  tcp6       0      0 127.0.0.1:8101          :::*                    LISTEN      116        52709      5179/java
                  tcp6       0      0 :::3000                 :::*                    LISTEN      117        22256      676/grafana
                  tcp6       0      0 :::5007                 :::*                    LISTEN      116        52804      5179/java
                  tcp6       0      0 127.0.0.1:36473         :::*                    LISTEN      116        52681      5179/java
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       49767      5017/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       46429      4564/io.admin.0
                  tcp6       0      0 :::8080                 :::*                    LISTEN      116        52716      5179/java
                  tcp6       0      0 :::10051                :::*                    LISTEN      114        22144      769/zabbix_server
                  tcp6       0      0 :::10050                :::*                    LISTEN      114        22132      720/zabbix_agent2
                  udp        0      0 10.0.2.3:53             0.0.0.0:*                           121        21191      734/named
                  udp        0      0 10.0.2.3:53             0.0.0.0:*                           121        21190      734/named
                  udp        0      0 127.0.0.1:53            0.0.0.0:*                           121        21187      734/named
                  udp        0      0 127.0.0.1:53            0.0.0.0:*                           121        21186      734/named
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        20741      638/systemd-resolve
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          21973      686/dhclient
                  udp        0      0 10.0.2.3:68             0.0.0.0:*                           101        20733      636/systemd-network
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17556      1/init
                  udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          20974      709/chronyd
                  udp        0      0 0.0.0.0:514             0.0.0.0:*                           0          21007      713/rsyslogd
                  udp6       0      0 :::1900                 :::*                                116        52837      5179/java
                  udp6       0      0 :::1902                 :::*                                116        53588      5179/java
                  udp6       0      0 :::111                  :::*                                0          17558      1/init
                  udp6       0      0 ::1:323                 :::*                                0          20975      709/chronyd
                  udp6       0      0 :::514                  :::*                                0          21008      713/rsyslogd
                  udp6       0      0 10.0.2.3:54045          :::*                                116        52838      5179/java
                  udp6       0      0 :::5353                 :::*                                116        52733      5179/java
                  2025-01-03 21:22:02.565  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                  2025-01-03 21:22:03.045  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                  2025-01-03 21:22:03.190  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:03.190  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:12.605  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                  2025-01-03 21:22:14.323  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                  2025-01-03 21:22:14.465  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:14.466  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:22.647  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                  2025-01-03 21:22:25.633  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                  2025-01-03 21:22:25.771  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:25.771  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:32.688  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                  2025-01-03 21:22:37.012  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                  2025-01-03 21:22:37.182  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:37.182  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:42.729  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                  2025-01-03 21:22:48.357  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                  2025-01-03 21:22:48.504  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:48.504  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                  2025-01-03 21:22:52.771  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                  2025-01-03 21:22:59.911  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0')
                  2025-01-03 21:23:00.083  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section.
                  2025-01-03 21:23:00.083  - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section.
                  2025-01-03 21:23:02.812  - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888
                  Der luxtronik Fehler ist mir bekannt, der ist schon immer da. Stört nicht, füllt nur das Log.
                  und die nmp Abfrage:
                  iobroker@UBU14:~$ npm ls @iobroker/sentry-plugin
                  /home/iobroker
                  └── (empty)
                  • 6 64kbyte
                    Script v.2024-10-19
                    *** BASE SYSTEM ***
                             Chassis: vm
                      Virtualization: kvm
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 2
                                  NTP service: active
                              RTC in local TZ: no
                    iobroker
                    HOME=/home/iobroker
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                             3813 M total memory
                             2303 M used memory
                              565 M active memory
                              243 M free memory
                              122 M buffer memory
                             1143 M swap cache
                             1023 M total swap
                                0 M used swap
                             1023 M free swap
                    *** FILESYSTEM ***
                    /var:
                    2.6G    /var/
                    1.4G    /var/log
                    1023M   /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: redis
                    States  type: redis
                    Hosts:
                    admin:          7.1.5
                    javascript:     8.8.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        14075
                    States:         12650
                    Pending Updates: 0
                    /home/iobroker
                    └── (empty)
                    mcm1957M Offline
                    mcm1957M Offline
                    mcm1957
                    @64kbyte
                    npm ls bitte in /opt(/iobroker absetzen.
                    Sorry, hab ich nicht extra geschrieben.
                    • mcm1957M mcm1957
                      @64kbyte
                      @mcm1957 bei dir heisst es auch plugin-sentry
                      mcm1957M 6 2 Antworten Letzte Antwort
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        YEP, das ist der zweite Fehler. Bin heute wohl schon zu lange am PC...
                          6 Offline
                          6 Offline
                          64kbyte
                          @mcm1957
                          Hab beides gemacht:
                          iobroker@UBU14:~$ cd /opt/iobroker/
                          iobroker@UBU14:/opt/iobroker$ npm ls @iobroker/sentry-plugin
                          └── (empty)
                          iobroker@UBU14:/opt/iobroker$ npm ls @iobroker/plugin-sentry
                          └─┬ iobroker.js-controller@7.0.6
                          • 6 64kbyte
                            @mcm1957
                            Hab beides gemacht:
                            └── (empty)
                            mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            @64kbyte
                            OK schaut mal normal aus.
                            ioBroker funktioniert normal abgesehen von der Fehlermeldung im Log. Hab ich das richtig mitbekommen?
                            Ehrlich - ich hab keine Idee mehr was da nicht stimmen könnte. Ich glaub da kann maximal @foxriver76 noch was dazu sagen. Ev. mach ein Issue beim js-controller auf. Wenn du ein Testsystem hast, check mal mit der aktuellen Beta des js-controllers.
                            Hast du Statistic Reporting generell gesperrt / Sentry global deaktiviert? Sollte dann auch nicht den Fehler werfen aber wer weiß :-).
                            • mcm1957M mcm1957
                              @64kbyte
                              6 Offline
                              6 Offline
                              64kbyte
                              @64kbyte
                              Habe ich probiert, ist wirkungslos:
                              iobroker@UBU14:~$ iob plugin disable sentry
                              The plugin "sentry" was successfully disabled for host "UBU14".
                              iobroker@UBU14:~$ iob restart
                              und trotzdem im Log:
                              2025-01-04 08:58:58.360  - info: host.UBU14 instance system.adapter.sql.0 in version "3.0.1" started with pid 45612
                              2025-01-04 08:58:58.984  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
                              Require stack:
                              2025-01-04 08:59:02.406  - info: host.UBU14 instance system.adapter.javascript.0 in version "8.8.3" started with pid 45642
                              2025-01-04 08:59:03.326  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
                              Require stack:
                              ... und immer so weiter bei jedem einzelnen Adapter
                              • 6 64kbyte
                                @64kbyte
                                Require stack:
                                Require stack:
                                mcm1957M Offline
                                mcm1957M Offline
                                mcm1957
                                @foxriver76
                                Irgendeine Idee dazu?
