  4. Probleme mit sudo apt update / PUBKEY
sudo apt update pubkey
26 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • P puffy00007
    @mp3junkie Hi, ich habe ein ähnliches Problem, könnt ih mir helfen?
    pi@iobroker:/var/lib $ sudo apt update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian stable InRelease [6,907 B]
    Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,661 B]
    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
    Err:5 https://repos.influxdata.com/debian stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Err:6 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    Fetched 6,907 B in 2s (3,699 B/s)
    Reading package lists... Done
    Building dependency tree... Done
    104 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    die Zugriffsrechte (ls -l /etc/apt/trusted.gpg.d/) dind alle auf 644
    @puffy00007 sagte in Probleme mit sudo apt update / PUBKEY:
    DRINGENDST updaten...
    Sowohl grafana wie auch influx müssen neu angelegt werden.
    Mach es danach:
    https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
    P 1 Antwort Letzte Antwort
      Mach es danach:
      puffy00007
      @thomas-braun Bei Grafana ging alles gut, bei Influx sieht so aus:
      pi@iobroker:/var/lib $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
      sha256sum: influxdata-archive_compat.key: No such file or directory
      influxdata-archive_compat.key: FAILED open or read
      sha256sum: WARNING: 1 listed file could not be read
      • P puffy00007
        @puffy00007
        Stell dich NICHT in /var/lib rein.
        Du musst in deinem home stehen....
        Grundsätzlich hast du da eh nix verloren.
          puffy00007
          @thomas-braun Super, alles sauber durchgelaufen und aufm neusten Stand!
          Aber es gibt ein Problem:
          Ich nutze VIS (1.5.6), darin habe ich auf der Hauptpage ein iFrame und als Quelle eine der URL aus Grafana, um die Visualisierung darzustellen.
          Der weigert sich den Inhalt zu zeigen. KATASTROPHE
          Was ist hier anders?
          -1
          • P puffy00007
            KATASTROPHE
            das hat nichts mit diesem Thread zu tun.
            Bitte neuen Thread in der richtigen Kategorie aufmachen, oder an einen der zu diesem Thema bestehenden anhängen
              KATASTROPHE
              puffy00007
              @homoran Habs gelöst, sorry und DANKE!
