  4. Node-Red
  5. [erledigt]Awtrix DP per NodeRed ändern
    6.4k
4 Beiträge 2 Kommentatoren 531 Aufrufe 2 Beobachtet
  • V Offline
    V Offline
    valbuz
    schrieb am zuletzt editiert von valbuz
    Erstmal Danke für den Adapter! Genial was da alles möglich ist.
    Soweit läuft alles, auch einige Apps sind eingerichtet.
    Gerne möchte ich nun mittels NR eine App visible schalten oder eben nicht.
    Der DP ändert sich, jedoch wird die App weiterhin angezeigt.
    Ämdere ich den DP direkt im Objektbaum funzt es.
    Mache ich einen Denkfehler? 😑 Danke
    Habe mir zu Testzwecken einen Flow gemacht:
            "id": "3de1245d7c757f4e",
            "type": "ioBroker out",
            "z": "f25267d62ffa866b",
            "name": "PV App",
            "topic": "awtrix-light.0.apps.pv.visible",
            "ack": "true",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 765,
            "y": 545,
            "wires": []
            "id": "05b54a36291c772a",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "false",
            "payloadType": "bool",
            "x": 540,
            "y": 520,
            "wires": [
                    "3de1245d7c757f4e"
            "id": "c2c4176314b2e407",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 540,
            "y": 585,
            "wires": [
                    "3de1245d7c757f4e"
    2xProxmox auf NUC
    E3DC 13kWh Speicher via RCSP an ioBroker
    • V valbuz
              "name": "PV App",
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 765,
              "y": 545,
              "wires": []
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "false",
              "x": 540,
              "y": 520,
              "wires": [
                      "3de1245d7c757f4e"
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "x": 540,
              "y": 585,
              "wires": [
                      "3de1245d7c757f4e"
      mickymM Offline
      mickymM Offline
      mickym
      @valbuz wenn du einem Adapter einen Befehl gibst, dann musst du Type „command“ nehmen und nicht „value“ in der iobroker-out Node.
      V 2 Antworten Letzte Antwort
      • mickymM mickym
        V Offline
        V Offline
        valbuz
        @mickym sagte in Awtrix DP per NodeRed ändern:
        Werde es am Abend testen!
        2xProxmox auf NUC
        • mickymM mickym
          V Offline
          V Offline
          valbuz
          Funzt 👍
          2xProxmox auf NUC
