  4. Fehlermeldung nach Neuinstallation und Rückladen von Backup
    2.9k
    3.0k
8 Beiträge 3 Kommentatoren 700 Aufrufe 2 Beobachtet
  • N Offline
    N Offline
    Nr5lebt
    hallo zusammen,
    nach neuinstallation von iobroker auf omv 7 und rückladen eines backups hatte iobroker nur noch eine Fehlermeldung für mich übrig:
    Error in GUI!
    Please open the browser console (F12), copy error text from there and create the issue on github
    Without this information it is not possible to analyse the error.
    It should looks like
    error
    If in the second line you will see at :3000/static/js/main.chunk.js:36903 and not the normal file name,
    please try to reproduce an error with opened browser console. In this case the special "map" files will be loaded and the developers can see the real name of functions and files.
    Loading chunk 6552 failed. (error: http://192.168.178.50:8081/static/js/6552.8a972966.chunk.js)
    t.f.j@http://192.168.178.50:8081/static/js/main.148da242.js:1:14165
    t.e/<@http://192.168.178.50:8081/static/js/main.148da242.js:1:1152
    t.e@http://192.168.178.50:8081/static/js/main.148da242.js:1:1130
    32098/Ba<@http://192.168.178.50:8081/static/js/7669.72a3d01c.chunk.js:1:1651072
    P@http://192.168.178.50:8081/static/js/4905.33747b16.chunk.js:2:3345
    xi@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:120729
    bs@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:109363
    vs@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:109291
    gs@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:109152
    is@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:106270
    Hl@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:46915
    62280/rs/<@http://192.168.178.50:8081/static/js/5096.802dcc19.chunk.js:2:103865
    Kann mir einer helfen?
    • N Nr5lebt
      hallo zusammen,
      Error in GUI!
      error
      CodierknechtC Online
      Codierknecht
      @nr5lebt sagte in Fehlermeldung nach Neuinstallation und Rückladen von Backup:
      Steht doch da
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      N 2 Antworten Letzte Antwort
      • CodierknechtC Codierknecht
        Steht doch da
        N Offline
        N Offline
        Nr5lebt
        @codierknecht
        [2024-09-15T17:44:24.445Z] No READY flag received in 3 seconds. Re-init 3957.af86c9f9.chunk.js:2:243182
        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.50:8081/?sid=1726422261443&name=admin aufbauen. socket.io.js:140:21
        [2024-09-15T17:44:24.446Z] Start reconnect 5 3957.af86c9f9.chunk.js:2:243182
        Die Verbindung zu ws://192.168.178.50:8081/?sid=1726422261443&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
        [2024-09-15T17:44:24.449Z] Reconnect is already running 5 3957.af86c9f9.chunk.js:2:243182
        [2024-09-15T17:44:24.450Z] ws connection error: CLOSE_ABNORMAL 3957.af86c9f9.chunk.js:2:243182
        [2024-09-15T17:44:24.450Z] Reconnect is already running 5 3957.af86c9f9.chunk.js:2:243182
        [2024-09-15T17:44:29.447Z] Try to connect 3957.af86c9f9.chunk.js:2:243182
        [2024-09-15T17:44:32.451Z] No READY flag received in 3 seconds. Re-init 3957.af86c9f9.chunk.js:2:243182
        Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.50:8081/?sid=1726422269448&name=admin aufbauen. socket.io.js:140:21
        [2024-09-15T17:44:32.451Z] Start reconnect 5 3957.af86c9f9.chunk.js:2:243182
        Die Verbindung zu ws://192.168.178.50:8081/?sid=1726422269448&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
        [2024-09-15T17:44:32.453Z] Reconnect is already running 5 3957.af86c9f9.chunk.js:2:243182
        [2024-09-15T17:44:32.453Z] ws connection error: CLOSE_ABNORMAL 3957.af86c9f9.chunk.js:2:243182
        [2024-09-15T17:44:32.454Z] Reconnect is already running 5
        das hier?
          Steht doch da
          N Offline
          N Offline
          Nr5lebt
          @codierknecht das hier?
          N Ro75R 2 Antworten Letzte Antwort
          • N Nr5lebt
            N Offline
            N Offline
            Nr5lebt
            @Homoran hallo, kannst du mir noch hoffnung geben?
            • N Nr5lebt
              Ro75R Online
              Ro75R Online
              Ro75
              @nr5lebt du hast doch das selbe Thema in einem anderen Thread beschrieben. Warum nochmal? Hatte dir dort schon was dazu geschrieben.
              Ro75
              N 1 Antwort Letzte Antwort
              • Ro75R Ro75
                Ro75
                N Offline
                N Offline
                Nr5lebt
                @ro75 das war doch was ganz anderes (omv, rechteprobleme bei installation von iobroker)
                mein iobroker lief ja eben, hab backup zurückgespielt und jetzt das
                Ro75R 1 Antwort Letzte Antwort
                • N Nr5lebt
                  Ro75R Online
                  Ro75R Online
                  Ro75
                  @nr5lebt und an dieser Stelle nochmal. Auf Dauer wird das nicht sauber und zuverlässig funktionieren!
                  Ro75.
