  4. Regex liefert falschen Wert
    5.1k
14 Beiträge 5 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • C Offline
    ck_coke
    ich habe ein paar (Anfänger)-Schwierigkeiten mit einer Regex und könnte etwas Hilfe gebrauchen.
    Folgendes ist das Ergebnis:
    javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: Found match, group 0: "total_power":-43.36,
    javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: Found match, group 1: -43.36
    javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: Found match, group 2: .36
    javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: {"isok":true,"data":{"online":true,"device_status":{"has_update":false,"fs_free":155118,"unixtime":1725530007,"emeter_n":{"current":0,"ixsum":0.9,"mismatch":false,"is_valid":false},"wifi_sta":{"connected":true,"ssid":"....","ip":"192.168.178.52","rssi":-72},"total_power":-43.36,"ct_calst":0,"relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"is_valid":true,"source":"cloud"}],"v_data":1,"uptime":885115,"fs_size":233681,"_updated":"2024-09-05 20:16:00","cloud":{"enabled":true,"connected":true},"fs_mounted":true,"ram_free":32500,"actions_stats":{"skipped":0},"emeters":[{"power":-9.73,"pf":-0.1,"current":0.44,"voltage":233.55,"is_valid":true,"total":0,"total_returned":7844.1},{"power":-33.63,"pf":-0.62,"current":0.23,"voltage":235.21,"is_valid":true,"total":2419,"total_returned":28747.5},{"power":0,"pf":0,"current":0.44,"voltage":234.18,"is_valid":true,"total":10489.3,"total_returned":0.1}],"mac":"483FDAC3902E","mqtt":{"connected":false},"cfg_changed_cnt":0,"serial":62007,"getinfo":{"fw_info":{"device":"shellyem3-483FDAC3902E","fw":"20230913-114244/v1.14.0-gcb84623"}},"time":"22:16","update":{"status":"idle","has_update":false,"new_version":"20230913-114244/v1.14.0-gcb84623","old_version":"20230913-114244/v1.14.0-gcb84623","beta_version":"20231107-165007/v1.14.1-rc1-g0617c15"},"ram_total":49920}}} - % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 1500 100 1383 100 117 15896 1344 --:--:-- --:--:-- --:--:-- 17441
    javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: Leistung: 3
    So habe ich mir das Ganze zusammengebastelt:
    schedule("*/1 * * * *", function () {
        exec('curl -X POST https://shelly-89-eu.shelly.cloud/device/status -d "id=483fdac3902e&auth_key=MjBjN2JjdWlkB12AE36D401E9C6EC6573933F664EA9B25923B90241D5720122CC428B8........."',
    		function (error, stdout, stderr) {
                const regex = /"total_power":(-?\d+(\.\d+)?),/gm;
                const str = stdout;
                let m;
                while ((m = regex.exec(str)) !== null) {
                    // This is necessary to avoid infinite loops with zero-width matches
                    if (m.index === regex.lastIndex) {
                        regex.lastIndex++;
                    // The result can be accessed through the `m`-variable.
                    m.forEach((match, groupIndex) => {
                        console.log(`Found match, group ${groupIndex}: ${match}`);
                            if (groupIndex=1) {
                P = match[1] // im match stehen die aktuelle parser ergebnisse ich brauch aber nur das der gruppe 1
                log(stdout + " - " + stderr);
                console.log('Leistung: ' + P);
    Die regex scheint wie man sieht zu funktionieren nur wird nicht das richtige verwendet.
    Ich hätte gerne group 1 als "Ergebnis". Wie bekomme ich das hin?
    HomoranH M haus-automatisierungH 3 Antworten Letzte Antwort
    • C ck_coke
                  const str = stdout;
                  let m;
                          regex.lastIndex++;
                              if (groupIndex=1) {
      @ck_coke sagte in Regex liefert falschen Wert:
      ist das nicht [0]?
      kenne nich mit regex in js nicht aus
      • C ck_coke
                    const str = stdout;
                    let m;
                            regex.lastIndex++;
                                if (groupIndex=1) {
        M Online
        M Online
        MCU
        @ck_coke
        const regex = /"total_power":(-?\d+(\.\d+)?)/gm;     /* , entfernt */
        let m;
        m = regex.exec(str)  /* m ist ja "total_power":-43.36 */
        P = m.split(':')[1]
        C 1 Antwort Letzte Antwort
        • M MCU
          @ck_coke
          let m;
          P = m.split(':')[1]
          ck_coke
          schrieb am zuletzt editiert von ck_coke
          @mcu
          Error in callback: TypeError: m.split is not a function
          M F 2 Antworten Letzte Antwort
          • C ck_coke
            @mcu
            M Online
            M Online
            MCU
            @ck_coke Dann muss man vorher noch aus m einen String machen.
            m = String(m)
            P= m.split ......
            • C ck_coke
              @mcu
              F Online
              F Online
              fastfoot
              @ck_coke
              let m;
              if ((m = regex.exec(str)) != null)
                  log('Leistung: ' + m[1])
              iobroker läuft unter Docker auf Windows (WSL2)
              • C ck_coke
                            const str = stdout;
                            let m;
                                    regex.lastIndex++;
                                        if (groupIndex=1) {
                haus-automatisierungH Offline
                Warum überhaupt JSON-Strings mit einem regex auseinander nehmen?!
                  schrieb am zuletzt editiert von haus-automatisierung
                  Hier mal ein Beispiel-Script. Ohne exec, curl und regex :)
                  const server = 'https://shelly-67-eu.shelly.cloud';
                  const authKey = 'MTk3YjZhdWlkE6CD....';
                  const deviceId = 'b0b21c18d700';
                  httpPost(`${server}/device/status`,
                          auth_key: authKey,
                      (error, response) => {
                          if (!error) {
                              try {
                                  const obj = JSON.parse(response.data);
                                  // Daten extrahieren
                              } catch (e) {
                                  console.error(e);
                          } else {
                              console.error(error);
                  Du suchst ja scheinbar: obj.data.device_status.total_power.
                            auth_key: authKey,
                            if (!error) {
                                try {
                                } catch (e) {
                                    console.error(e);
                            } else {
                    ck_coke
                    @haus-automatisierung
                    Vielen Dank! So ist es natürlich noch besser gelöst.
                    • C ck_coke
                      ck_coke
                      Jetzt habe ich das Problem, dass es bei einem Gerät funktioniert und bei einem anderen
                      {"ack":true}
                      als Wert gesetzt wird.
                      So sieht das Skript aus:
                      schedule("*/10 * * * * *", function () {
                      const server = 'https://shelly-89-eu.shelly.cloud';
                      const authKey = 'XjBjN2JjdWlkB12AE36D401E9C6EC6573933F664EA9B25923B90241D5720122CC428B82EF7477624E84B517133E2';
                      const deviceId = 'a0a3b3e7d67c';
                              auth_key: authKey,
                              if (!error) {
                                  try {
                                      console.log(obj.data);
                                                 setState('0_userdata.0.Leistung-Entladen', obj.data.device_status.voltage, true);
                                  } catch (e) {
                                      console.error(e);
                              } else {
                      Folgendes bekomme ich im Log angezeigt:
                      javascript.0
                      	2024-09-09 20:34:40.074	info	script.js.common.Balkonkraftwerk.Skript_1: setForeignState(id=0_userdata.0.Leistung-Entladen, state={"val":{"ack":true},"ack":true,"ts":1725906880074,"q":0,"from":"system.adapter.javascript.0","lc":1725906880074,"c":"script.js.common.Balkonkraftwerk.Skript_1"})
                      javascript.0
                      	2024-09-09 20:34:40.074	info	script.js.common.Balkonkraftwerk.Skript_1: { online: true, device_status: { sys: { available_updates: [Object], mac: 'A0A3B3E7D67C', restart_required: false, time: '11:48', unixtime: 1725788939, uptime: 3, ram_size: 246876, ram_free: 134944, fs_size: 458752, fs_free: 122880, cfg_rev: 19, kvs_rev: 0, schedule_rev: 10, webhook_rev: 0, reset_reason: 1 }, ts: 1725906873.77, plugs_ui: {}, id: 'a0a3b3e7d67c', code: 'SNPL-00112EU', ws: { connected: false }, wifi: { sta_ip: '192.168.33.67', status: 'got ip', ssid: 'ShellyPlusPlugS-E465B8B3A57C', rssi: -29, ap_client_count: 0 }, mqtt: { connected: false }, serial: 3566, ffs: { ts: 0 }, 'switch:0': { id: 0, current: 0.021, source: 'SHC', output: true, apower: 0, voltage: 232.9, aenergy: [Object], temperature: [Object] }, cloud: { connected: true }, _updated: '2024-09-09 18:34:34', ble: {} } }
                      javascript.0
                      	2024-09-09 20:34:40.074	info	script.js.common.Balkonkraftwerk.Skript_1: httpPost(url=https://shelly-89-eu.shelly.cloud/device/status, responseTime=66ms)
                      javascript.0
                      	2024-09-09 20:34:40.007	info	script.js.common.Balkonkraftwerk.Skript_1: httpPost(config={"method":"post","url":"https://shelly-89-eu.shelly.cloud/device/status","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0"},"data":{"id":"a0a3b3e7d67c","auth_key":"XjBjN2JjdWlkB12AE36D401E9C6EC6573933F664EA9B25923B90241D5720122CC428B82EF7477624E84B517133E2"}}, data=[object Object])
                      ```z
                      • C ck_coke
                        {"ack":true}
                                auth_key: authKey,
                                if (!error) {
                                    try {
                                    } catch (e) {
                                        console.error(e);
                                } else {
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        ```z
                        @ck_coke In deinem Scripts sind Klammerfehler. Das kann so gar nicht klappen. Da fehlt etwas.
                        voltage, true);
                        • C Offline
                          ck_coke
                          Das ist wohl beim hier ins Forum kopieren passiert.
                          Die Zeile sieht so aus:
                          • C Offline
                            ck_coke
                            Kann es daran liegen das der Datenpunkt hinter switch:0, also eine Ebene tiefer liegt?
                            Zumindest habe ich das nach Internetrechersche in anderen Foren so gesehen.
                            • C ck_coke
                              Ich hab das Thema JSON vs. Objekt in zig kostenlosen Inhalten super ausführlich erklärt.
                              Du musst schon den kompletten Pfad angeben. Im Falle von switch:0 muss das dann aber in eckige Klammern und kann nicht mit der einfachen Punkt-Notation erreicht werden.
                              obj.data.device_status['switch:0'].voltage
