  3. Einsteigerfragen
  4. Installation
  5. Update js-controller from @6.0.7 to @6.0.11 nicht möglich
Geplant Angeheftet Gesperrt Verschoben Installation
46 Beiträge 7 Kommentatoren 6.7k Aufrufe 5 Beobachtet
  • enzoE Offline
    enzoE Offline
    enzo
    iobroker@iobroker:~ $ iob upgrade self
    Stopped Objects DB
    Stopped States DB
    NPM version: 10.8.2
    Installing iobroker.js-controller@6.0.11... (System call)
    npm error code 6
    npm error path /opt/iobroker/node_modules/iobroker.js-controller
    npm error command failed
    npm error command sh -c node iobroker.js setup first
    npm error Uncaught Rejection: TypeError: callback is not a function
    npm error     at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/        @iobroker/plugin-base/lib/PluginBase.js:310:17
    npm error This error originated either by throwing inside of an async function w        ithout a catch block, or by rejecting a promise which was not handled with .catc        h(). The promise rejected with the reason:
    npm error TypeError: callback is not a function
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/        2024-08-27T11_43_53_132Z-debug-0.log
    host.iobroker Cannot install iobroker.js-controller@6.0.11: 6
    was kann ich machen um das zu fixen ?
    HomoranH enzoE 2 Antworten Letzte Antwort
    • enzoE enzo
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.8.2
      npm error code 6
      @enzo sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
      erstmal die notwendigsten Infos liefern.
      siehe
      zuallererst mal die Langfassung von iob diag
      • enzoE enzo
        Stopped Objects DB
        Stopped States DB
        NPM version: 10.8.2
        npm error code 6
        enzoE Offline
        enzoE Offline
        enzo
        Copy text starting here:
                                v.2024-05-22
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        Display-Server:         false
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    1
        Nodejs-Installation:
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        Recommended versions are nodejs 20.17.0 and npm 10.8.2
        MEMORY:
        Mem:            3.8G        102M        233M        0.0K        3.5G        3.6G
        Swap:            99M         18M         81M
        Total:          3.9G        120M        315M
        Active iob-Instances:   1
        Upgrade policy: none
        ioBroker Core:          js-controller           6.0.7
                                admin                   7.0.25
        ioBroker Status:        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
          system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                9818
        States:                 7069
        Size of iob-Database:
        17M     /opt/iobroker/iobroker-data/objects.jsonl
        1.6M    /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
        iobroker@iobroker:~ $ Copy text starting here:
                                v.2024-05-22
                 Icon name: computer
              Architecture: arm64
        Kernel:                 aarch64
        Userland:               64 bit
        User-ID:                1000
        ^C= Mark text until here for copying ==================nd: 0.0.0.0, run as: admi
        der iobroker leuft sehr gut.
        Nur js-controller 6.0.7 lässt sich nicht auf js-controller 6.0.11 bringen.
        HomoranH ? 2 Antworten Letzte Antwort
        • enzoE enzo
                                  v.2024-05-22
                   Icon name: computer
                Architecture: arm64
          Kernel:                 aarch64
          Userland:               64 bit
          User-ID:                1000
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Swap:            99M         18M         81M
                                  admin                   7.0.25
          Objects type: jsonl
          States  type: jsonl
          Objects:                9818
          States:                 7069
                                  v.2024-05-22
                   Icon name: computer
                Architecture: arm64
          Kernel:                 aarch64
          Userland:               64 bit
          User-ID:                1000
          @enzo 2x Summary ist immer noch nicht die Langfassung 😁
          • enzoE enzo
                                    v.2024-05-22
                     Icon name: computer
                  Architecture: arm64
            Kernel:                 aarch64
            Userland:               64 bit
            User-ID:                1000
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            MEMORY:
            Swap:            99M         18M         81M
                                    admin                   7.0.25
            Objects type: jsonl
            States  type: jsonl
            Objects:                9818
            States:                 7069
                                    v.2024-05-22
                     Icon name: computer
                  Architecture: arm64
            Kernel:                 aarch64
            Userland:               64 bit
            User-ID:                1000
            @enzo
            Viiiiele Probleme.
            Erstmal. Dein OS solltest Du updaten -> Bookworm
            Dann kommst Du noch auf die Weboberfläche vom Iobroker?
            Als Nächstes. User und Host so zu benennen wie die Software selber . Schlechte Idee. Versuch das mal zu ändern.
            MartinPM enzoE Samson71S 3 Antworten Letzte Antwort
              @enzo
              Viiiiele Probleme.
              MartinPM Online
              MartinPM Online
              MartinP
              Auf welchem Repository bist Du? auf Beta?
              Ich bin auf "Stable" - mir wird angezeigt, 6.0.9 sei aktuell....
              P.S. Bullseye und Beta repository wäre eine interessante Kombi.
              enzoE 1 Antwort Letzte Antwort
                @enzo
                Viiiiele Probleme.
                enzoE Offline
                enzoE Offline
                enzo
                @mrs-antje said in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
                Bookworm
                ja es läuft ganz gut nur Update auf js-controller 6.0.11 geht nicht.???
                • MartinPM MartinP
                  enzoE Offline
                  enzoE Offline
                  enzo
                  @martinp
                  ja auf Beta
                  HomoranH MartinPM 2 Antworten Letzte Antwort
                  • enzoE enzo
                    @martinp
                    ja auf Beta
                    @enzo bitte die Langfassung!
                    @Mrs-Antje scheint ja eine Glaskugel deluxe zu haben.
                    ich leider nicht.
                    ? 1 Antwort Letzte Antwort
                      @enzo
                      Viiiiele Probleme.
                      Samson71S Offline
                      Samson71S Offline
                      Samson71
                      @mrs-antje sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
                      Viiiiele Probleme.
                      Vermessene Aussage ohne Langfassung von iob diag
                      Grundsätzlich ist das korrekt aber hier sicher nicht die Ursache und auch nicht akut nötig. Zeitnah ja, aber nicht zwingend die erste Priorität.
                      Markus
                      Bitte beachten:
                      • enzoE enzo
                        @martinp
                        ja auf Beta
                        MartinPM Online
                        MartinPM Online
                        MartinP
                        @enzo Dann hast Du aber längere Zeit keine Updates gemacht, wenn bei Dir 6.0.7 aktuell ist, und auf stable ist schon 6.0.9 draußen ...
                        Das ist alles eigentlich eine toxische Kombination:
                        • Veralteter Linux-Unterbau
                        • Beta Repository von ioBroker
                        • seltene Updates
                          @MartinP
                          was habt ihr alles für Glaskugeln?
                          @martinp sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
                          bullseye ist nicht "veraltet", so dass es Probleme verursacht.
                          seltene Updates
                          woher weisst du das?
                          höchstens vom controller kannst du das wissen.
                          und auch hier 6.0.7 ist nicht soooo alt.
                            ich leider nicht.
                            Hallo @homoran
                            Wo ist das Glaskugellesen? 🤔
                            Steht doch alles in den vom Threadersteller bereitgestellten Infos?!
                            Hallo @Samson71
                            Da im Forum Aktualität propagiert wird , was das OS angeht , habe ich das auch getan.
                            Vermutlich hat das nichts mit dem Problem zu tun.
                            Schließe mich da nur @Thomas-Braun an 😁
                              Hallo @homoran
                              Hallo @Samson71
                              aber wo sind die
                              Viiiiele Probleme.
                              aufgelistet???
                              Thomas BraunT ? 2 Antworten Letzte Antwort
                                aber wo sind die
                                Viiiiele Probleme.
                                aufgelistet???
                                Meine Glaskugel sagt da gar nicht viel zu. Die würde die Langfassung benötigen.
                                So auf den ersten Blick sieht das aber auch eigentlich gar nicht so verkehrt aus. Da hab ich schon andere Baustellen gesehen...
                                  aber wo sind die
                                  Viiiiele Probleme.
                                  aufgelistet???
                                  Hallo @homoran
                                  Hab ich doch oben geschrieben?
                                  Wenn er wieder auf die Oberfläche kommt, kann er das Update ja per GUI machen.
                                  Und das Umbenennen von User und Host halte ich für sinnvoll.
                                  Genauso wie das OS Update.
                                    Hallo @homoran
                                    dem stimme ich ja auch zu, aber ohne harte Fakten kann ich vetmuten, dass es Fehler geben könnte, vielleicht auch ein paar, aber für viiiiele Fehler kann ich bisher keine Daten finden.
                                      Hallo @homoran
                                      Warten wir mal die Langfassung von iob diag ab …..
                                        Hallo @homoran
                                        das tue ich die ganze Zeit.
                                          MartinPM Online
                                          MartinPM Online
                                          MartinP
                                          @enzo Um die Langfassung zu kopieren, sollte man NICHT den angeforderten Tastendruck (press any key for summary) für die Zusammenfassung im Ablauf auslösen, sondern zuerst die Output-Kopie anfertigen. Für die Summary wird der Screen gelöscht, und man muss von vorne beginnen!
                                          Thomas BraunT enzoE 2 Antworten Letzte Antwort
