  4. Virtuelle Sensor Smartthings
    5.1k
3 Beiträge 2 Kommentatoren 315 Aufrufe 3 Beobachtet
  • Vadim KumpanV Offline
    Vadim Kumpan
    schrieb am zuletzt editiert von Vadim Kumpan
    Hallo zusammen. Ich habe in Samsung Smartthings einen virtuellen Sensor erstellt, dessen Zustand ich mithilfe eines Google-Skripts steuern kann. Können Sie mir helfen, wie man dieses Skript in iobroker ausführt?
    function close() {
      var url = 'https://api.smartthings.com/virtualdevices/XXXXXXX-c1f5-4029-8740-1c59dd5f1b35/events'
      var params = {
        method: "POST",
        'contentType': 'application/json',
        "followRedirects": false,
        "headers": {
          "Content-Type": "application/json;charset=utf-8",
          "Accept": "application/json",
          "Authorization": "Bearer XXXXXXX-3eaa-4212-b946-XXXXXXX"
        'payload': JSON.stringify(
            "deviceEvents": [
                "component": "main",
                "capability": "contactSensor",
                "attribute": "contact",
                "value": "closed"
      var UrlFetch = UrlFetchApp.fetch(url, params)
      var ResponseCode = UrlFetch.getResponseCode()
      Logger.log('ResponseCode ' + ResponseCode)
    function open() {
      var params = {
        method: "POST",
        "headers": {
            "deviceEvents": [
                "value": "open"
    • Vadim KumpanV Vadim Kumpan
      function close() {
        var params = {
          method: "POST",
          "headers": {
              "deviceEvents": [
                  "value": "closed"
      function open() {
        var params = {
          method: "POST",
          "headers": {
              "deviceEvents": [
                  "value": "open"
      mickymM Offline
      mickymM Offline
      mickym
      @vadim-kumpan Mit NodeRed wäre das einfach.
             "id": "2aca98399fd6b167",
             "type": "http request",
             "z": "517cd16e4d7e6ae4",
             "name": "",
             "method": "POST",
             "ret": "txt",
             "paytoqs": "ignore",
             "url": "https://api.smartthings.com/virtualdevices/XXXXXXX-c1f5-4029-8740-1c59dd5f1b35/events",
             "tls": "",
             "persist": false,
             "proxy": "",
             "insecureHTTPParser": false,
             "authType": "",
             "senderr": false,
             "headers": [
                     "keyType": "Accept",
                     "keyValue": "",
                     "valueType": "other",
                     "valueValue": "application/json"
                     "keyType": "Authorization",
                     "keyValue": "",
                     "valueValue": "Bearer XXXXXXX-3eaa-4212-b946-XXXXXXX"
                     "keyType": "Content-Type",
                     "keyValue": "",
             "x": 670,
             "y": 4980,
             "wires": [
                     "99533863d12f47af"
             "id": "4dc1e4ee628421ae",
             "type": "inject",
             "name": "open",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "{\"deviceEvents\":[{\"component\":\"main\",\"capability\":\"contactSensor\",\"attribute\":\"contact\",\"value\":\"open\"}]}",
             "payloadType": "json",
             "x": 490,
             "y": 4960,
             "wires": [
                     "2aca98399fd6b167"
             "id": "e8440e45dee52d60",
             "type": "inject",
             "name": "close",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "{\"deviceEvents\":[{\"component\":\"main\",\"capability\":\"contactSensor\",\"attribute\":\"contact\",\"value\":\"closed\"}]}",
             "x": 490,
             "y": 5000,
             "wires": [
                     "2aca98399fd6b167"
             "id": "99533863d12f47af",
             "type": "debug",
             "name": "Response",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 840,
             "y": 4980,
             "wires": []
      Aber ansonsten musst Du halt mit Javascript und dieser Axios Bibliothek programmieren. Da können Dir aber die JS Jungs sicher helfen.
      Vadim KumpanV 1 Antwort Letzte Antwort
      • mickymM mickym
               "name": "",
               "method": "POST",
               "ret": "txt",
               "tls": "",
               "persist": false,
               "proxy": "",
               "authType": "",
               "senderr": false,
               "headers": [
                       "keyValue": "",
                       "keyValue": "",
                       "keyValue": "",
               "x": 670,
               "y": 4980,
               "wires": [
                       "99533863d12f47af"
               "type": "inject",
               "name": "open",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "x": 490,
               "y": 4960,
               "wires": [
                       "2aca98399fd6b167"
               "type": "inject",
               "name": "close",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "x": 490,
               "y": 5000,
               "wires": [
                       "2aca98399fd6b167"
               "type": "debug",
               "name": "Response",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 840,
               "y": 4980,
               "wires": []
        Vadim Kumpan
        @mickym Danke!!!
