  3. Off Topic
  4. Grafana
  5. (gelöst) Grafana: X-Achse ändern von Zeit auf Werte
    6.7k
Geplant Angeheftet Gesperrt Verschoben Grafana
8 Beiträge 3 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • CephalopodC Offline
    CephalopodC Offline
    Cephalopod
    schrieb am zuletzt editiert von Cephalopod
    Ich kämpfe schon seit Stunden mit einer Visualisierung des Strompreises.
    Der Strompreisverlauf über den Tag ist in 24 einzelnen (Stunden-) Variablen gespeichert.
    Diese möchte ich als Balken darstellen, also 24 einzelne Balken nebeneinander.
    Meine Datenquelle sieht so aus:
    from(bucket: "iobroker")
      |> range(start: v.timeRangeStart, stop: v.timeRangeStop)
      |> filter(fn: (r) => r["_measurement"] == "awattar.0.prices.0.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.1.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.2.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.3.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.4.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.5.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.10.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.11.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.12.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.13.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.14.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.15.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.16.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.17.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.18.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.19.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.20.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.21.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.22.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.23.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.24.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.6.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.7.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.8.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.9.totalPriceKwh")
      |> filter(fn: (r) => r["_field"] == "value")
      |> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
      |> yield(name: "last")
    Das habe ich bisher hinbekommen:
    Ich möchte die X-Achse nicht mehr als Zeitachse haben, sondern als Werteachse von 0 bis 24.
    Wie geht das?
    CephalopodC 1 Antwort Letzte Antwort
    • CephalopodC Cephalopod
        |> yield(name: "last")
      Wie geht das?
      CephalopodC Offline
      CephalopodC Offline
      Cephalopod
      Habe es hinbekommen:
      Angezeigt wird der aktuelle Tag bis morgen früh 8 Uhr.
      Unten noch ein Balken mit dem aktuellen Verbrauch:
      P T 2 Antworten Letzte Antwort
        peterfido
        @cephalopod
        Magst Du Deine Lösung noch zeigen? Evtl. kann es jemand gebrauchen.
        Peterfido
        • P peterfido
          @cephalopod
          CephalopodC Offline
          CephalopodC Offline
          Cephalopod
          @peterfido
          Stimmt.
          Der "Trick" war, bei der Auswahl der Visualisierung "BAR GAUGE" anstatt "Bar chart" zu verwenden.
          Bei letzterem wird anscheinend immer eine Zeitleiste als X-Achse verwendet.
            tritor
            @Cephalopod
            Wie hast du die Uhrzeiten auf die x-Achse gebracht?
            Bei mir wird der DP Name angezeigt.
            Gernot
            Host: i9 server Proxmox , Debian 13.4 for ioBroker
            ioBroker: 7.9.2, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.2.1
            Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
            Grafana 13.0.1 / InfluxDB 2.8.0
            • T tritor
              @Cephalopod
              CephalopodC Offline
              CephalopodC Offline
              Cephalopod
              @tritor
              Das ist einfach.
              Per Override die Beschriftung für jede einzelne Datenreihe ändern.
              Fleißarbeit 😊
                @tritor
                Das ist einfach.
                Fleißarbeit 😊
                tritor
                schrieb am zuletzt editiert von tritor
                @cephalopod
                hätte ich schon gemacht bleibt aber durcheinander
                oder darf ich nur numerisch verwenden?
                Gernot
                • T tritor
                  @cephalopod
                  CephalopodC Offline
                  CephalopodC Offline
                  Cephalopod
                  @tritor sagte in (gelöst) Grafana: X-Achse ändern von Zeit auf Werte:
                  @cephalopod
                  Du musst die Datenreihen umbenennen, dass die Einstelligen Uhrzeiten mit einer 0 beginnen.
                  Mit influxdb kannst du z.B. die Datenpunkte unter einem anderen Namen speichern.
