  4. Node-Red
  5. Meldung aus Node Red
    6.4k
5 Beiträge 3 Kommentatoren 539 Aufrufe 2 Beobachtet
  • L Offline
    LITO 0
    Hallo, wahrscheinlich ist das nur ein dummer Anfänger Fehler aber ich weiss nicht wie diese Meldungen weg bekommen.
    Die Werte und alles andere funktioniert, aber ich würde das gerne weg bekommen.
    Hier einige Meldungen es sind sehr viele:
    node-red.0
    2024-08-05 10:21:43.766	info	State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:43.073	info	State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:37.705	info	State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:34.836	info	State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:26.787	info	State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:24.998	info	State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:23.864	info	State value to set for "node-red.0.Huawei.Battery.Battery_Max_Discharge_Power_TEST" has to be type "number" but received type "object"
    node-red.0
    2024-08-05 10:21:16.690	info	State value to set for "node-red.0.Huawei.Inverter.Peak_Active_Power_of_current_Day" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:16.081	info	State value to set for "node-red.0.Huawei.Inverter.Modell ID" has to be type "string" but received type "object"
    node-red.0
    2024-08-05 10:21:15.919	info	State value to set for "node-red.0.Huawei.Inverter.Modell" has to be type "string" but received type "object"
    node-red.0
    2024-08-05 10:21:14.332	info	State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:13.603	info	State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:04.865	info	State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:21:03.455	info	State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:20:55.412	info	State value to set for "node-red.0.Huawei.Battery.Battery_Max_Discharge_Power_TEST" has to be type "number" but received type "object"
    node-red.0
    2024-08-05 10:20:55.118	info	State value to set for "node-red.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:20:53.115	info	State value to set for "node-red.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:20:47.053	info	State value to set for "node-red.0.Huawei.Inverter.Peak_Active_Power_of_current_Day" has to be stringified but received type "number"
    node-red.0
    2024-08-05 10:20:46.438	info	State value to set for "node-red.0.Huawei.Inverter.Modell ID" has to be type "string" but received type "object"
    node-red.0
    2024-08-05 10:20:45.890	info	State value to set for "node-red.0.Huawei.Inverter.Modell" has to be type "string" but received type "object"
    • L LITO 0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      @lito-0 dann ist der Datenpunkt vom Typ String und der Wert vom Typ Zahl.
      Du musst eins von beiden Anpassen
      • mickymM Offline
        mickymM Offline
        mickym
        Du solltest in den NodeRed adapter gar nichts schreiben. Das sollte man besser in 0_userdata.0 schreiben.
        Generell musst Du bei Objekten eine JSON Node voranstellen. Also da stimmt was mit Deinem Flow nicht.
        L 1 Antwort Letzte Antwort
        • mickymM mickym
          LITO 0
          @mickym Hallo danke für die Info, leider bin ich noch nicht in der Lage um das zu verstehen 😞 ich glaube das ich noch eine menge Hausaufgaben zu machen habe.
          @Homoran Hallo ich habe sowohl im Datenpunkt wie auch in Node red die Daten je nach Wunsch auf String oder Objekt gestellt, die Meldung bleibt aber
          • L LITO 0
            mickymM Offline
            mickymM Offline
            mickym
            @lito-0 Na Du hast doch iobroker-Out Nodes wo Du in diese Datenpunkte schreibst. Die musst Du doch nur erst mal suchen, am Besten über das Suchfeld im Info Tab
            Und dann musst du dort halt deinen Flow ändern.
