  4. JAVA - Script Parse Error
    5.1k
5 Beiträge 4 Kommentatoren 571 Aufrufe 1 Beobachtet
    Seeandfeel
    schrieb am zuletzt editiert von Seeandfeel
    Ich habe einen Parse Error im Script (was aber ziemlich sicher schon funktioniert hatte), komme aber irgendwie nicht drauf :( .
    Kann mir ggf. jemand weiterhelfen?
    Fehler (bei jedem CRON Aufruf):
    javascript.0 2024-08-03 13:18:00.009	error	at process.processTimers (node:internal/timers:512:7)
    javascript.0 2024-08-03 13:18:00.009	error	at listOnTimeout (node:internal/timers:569:17)
    javascript.0 2024-08-03 13:18:00.009	error	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
    javascript.0 2024-08-03 13:18:00.009	error	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
    javascript.0 2024-08-03 13:18:00.009	error	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
    javascript.0 2024-08-03 13:18:00.008	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1769:34)
    javascript.0 2024-08-03 13:18:00.008	error	at Object.<anonymous> (script.js.Parse.Parse_Sauna_Neu:23:5)
    javascript.0 2024-08-03 13:18:00.008	error	Error in callback: ReferenceError: Request is not defined
    Script:
    const url = 'http://192.168.5.113/api';
    const idTemp1 = 'javascript.0.Sauna.Sauna';
    const idTemp2 = 'javascript.0.Sauna.Sauna_Raum';
    createState(idTemp1, 0, {
        desc: 'Temperatur in °C',
        type: 'string',
        role: 'value',
        unit: '°C'
    createState(idTemp2, 1, {
        type: 'string',
        role: 'value',
        unit: '°C'
    schedule('*/60 * * * * *', function() { //every minute
        Request(url, function(error, response, result) {
            let obj = JSON.parse(result);
            setState(idTemp1,  parseFloat(obj.sensors['0'].value), true);
            setState(idTemp2,  parseFloat(obj.sensors['1'].value), true);
    JSON von http://192.168.5.113/api :
      "systemname": "Sauna",
      "secure_counter": 236923,
      "firmware": "2.3.05-b",
      "sensors": [
          "name": "Sauna Temperature",
          "value": 22.3125,
          "mean-1": {
            "value": 21.80416679,
            "count": 60,
            "period": 3600
          "mean-24": {
            "value": 19.52482605,
            "count": 1440,
            "period": 86400
          "unit": "Celsius",
          "time": "Sat Aug  3 13:19:48 2024"
          "name": "Gebäude Temperatur",
          "value": 20.375,
          "unit": "Celsius",
    T paul53P 2 Antworten Letzte Antwort
    • S Seeandfeel
      Script:
          type: 'string',
          role: 'value',
          unit: '°C'
          type: 'string',
          role: 'value',
          unit: '°C'
        "sensors": [
            "value": 22.3125,
            "mean-1": {
              "count": 60,
              "period": 3600
            "mean-24": {
              "count": 1440,
              "period": 86400
            "unit": "Celsius",
            "value": 20.375,
            "unit": "Celsius",
      TT-Tom
      @seeandfeel
      Es handelt sich bei dir um das Request Problem. Request ist abgemeldet und sollte durch httpGet bzw httpPost ersetzt werden.
      Es gibt dazu schon viele Threads hier zu diesem Thema. Zum Beispiel hier Link Text
      Edit Link angepasst
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      • S Seeandfeel
        Script:
            type: 'string',
            role: 'value',
            unit: '°C'
            type: 'string',
            role: 'value',
            unit: '°C'
          "sensors": [
              "value": 22.3125,
              "mean-1": {
                "count": 60,
                "period": 3600
              "mean-24": {
                "count": 1440,
                "period": 86400
              "unit": "Celsius",
              "value": 20.375,
              "unit": "Celsius",
        @seeandfeel sagte: schon funktioniert hatte
        Das kann mit groß geschriebenem Request() noch nie funktioniert haben.
        Ändere Zeilen 22 und 23 in:
            httpGet(url, function(error, response) {
                let obj = JSON.parse(response.data);
          Seeandfeel
          Perfekt, Vielen Dank euch beiden, hätte ich wohl genauer suchen müssen das "request" deprecated ist.
          @paul53 :
          Du hast recht, das Request hatte noch nie funktioniert. Ich hatte das vor kurzem erst groß geschrieben weil ich die (vorherige) Fehlermeldung dahingehenden interpretiert hatte. Leider vergessen, Sorry :( !
          • S Seeandfeel
            @paul53 :
            haus-automatisierungH Offline
            @seeandfeel sagte in JAVA - Script Parse Error:
            Normalerweise solltest Du vor dem Upgrade eine große Warnung bekommen haben, dass das der Fall ist. Und diese muss man manuell bestätigen.
            https://github.com/ioBroker/ioBroker.javascript/blob/d5772eaf30e865c4089b83c1198a86e2aac73774/io-package.json#L343-L383
            Es ist erforderlich, alle Skripte zu aktualisieren, die das "Request"-Paket verwenden! Dieses Paket wird in zukünftigen Versionen entfernt. Bitte nutze die neuen "Bockly"-Blöcke für "httpGet" oder nutze eine andere Bibliothek (wie axios) im JavaScript-Code.
