  4. "homepilot20" stürzt nach js-controller 6.0.1-Update ab
    1.0k
    6.1k
9 Beiträge 4 Kommentatoren 895 Aufrufe 3 Beobachtet
  • KlausStoertebekerK Offline
    KlausStoertebeker
    Hallo ins Forum,
    ich habe gestern meinen js-controller auf die Version 6.0.1 aktualisiert und seitdem stürzt mein "homepilot20" Adapter zur Steuerung meiner Rademacher-Jallousien ständig ab.
    Im ioBroker-Protokoll gibt es dazu folgende Einträge:
    host.Nordmanns-ioBroker-Server
    	2024-06-12 17:46:11.532	error	instance system.adapter.homepilot20.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    	2024-06-12 17:46:11.531	error	Caught by controller[0]: Node.js v18.20.3
    	2024-06-12 17:46:11.531	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
    	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
    	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
    	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    	2024-06-12 17:46:11.531	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.homepilot20/main.js:2736:5)
    	2024-06-12 17:46:11.531	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.homepilot20/main.js:66:12)
    	2024-06-12 17:46:11.530	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
    	2024-06-12 17:46:11.530	error	Caught by controller[0]: ^
    	2024-06-12 17:46:11.530	error	Caught by controller[0]: adapter = new utils.Adapter(options);
    	2024-06-12 17:46:11.530	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.homepilot20/main.js:66
    Hat jemand das gleiche Problem und vielleicht auch eine Lösung?
    Vielen Dank im voraus und viele Grüße aus Dräschdn
    "Klaus"
    Systeminformationen
    • Adaptername: homepilot20
    • Link zu Adapterrepository: https://github.com/homecineplexx/ioBroker.homepilot20
    • Adapterversion: 0.0.51
    • js-controller Version: 6.0.1
    • Admin Version: 6.17.14
    • Hardwaresystem: Raspberry Pi 4B
    • Arbeitsspeicher: 8 GByte
    • Festplattenart: 256 GByte SSD
    • Betriebssystem: Linux
    • Nodejs-Version: v18.20.3
    • NPM-Version: 10.7
    • Installationsart: Manuell (Adapter nicht über Repositories verfügbar)
    • Image, Docker genutzt: Nein
    Output von iob diag
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: Nordmanns-ioBroker-Server
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     17:29:32 up 19:51,  2 users,  load average: 0.92, 0.85, 0.82
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2024-06-12 17:29:33 CEST
               Universal time: Wed 2024-06-12 15:29:33 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    mainuser
    HOME=/home/mainuser
    GROUPS=mainuser adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth gpio i2c
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            8.2G        2.1G        3.4G        1.3M        2.8G        6.1G
    Swap:           209M          0B        209M
    Total:          8.4G        2.1G        3.6G
    Active iob-Instances: 	19
             7810 M total memory
             2036 M used memory
             3400 M active memory
              985 M inactive memory
             3259 M free memory
              113 M buffer memory
             2523 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 17:29:33 up 19:51,  2 users,  load average: 0.92, 0.85, 0.82
    Tasks: 176 total,   2 running, 174 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7810.2 total,   3258.0 free,   2038.0 used,   2637.3 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5772.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                                   LOAD   ACTIVE SUB    DESCRIPTION
    * 4 netshares (powered off)              loaded failed failed <mountpoints>
    4 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                           Type      Size  Used Avail Use% Mounted on
    udev                                 devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs                                tmpfs     782M  1.2M  780M   1% /run
    /dev/sda2                            ext4      235G   11G  212G   5% /
    tmpfs                                tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                                tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1                            vfat      510M   61M  450M  12% /boot/firmware
    //5 netshares (working fine and deleted for privacy reasons
    tmpfs                                tmpfs     782M     0  782M   0% /run/user/1000
    [Tue Jun 11 21:38:25 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:99:FE:52 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=09f188be-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Tue Jun 11 21:38:30 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Jun 11 21:38:32 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET                                                  SOURCE                               FSTYPE      OPTIONS
    /                                                       /dev/sda2                            ext4        rw,noatime
    |-/sys                                                  sysfs                                sysfs       rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security                                securityfs                           securityfs  rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                                      cgroup2                              cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore                                      pstore                               pstore      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                                         bpf                                  bpf         rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                                   debugfs                              debugfs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing                                 tracefs                              tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config                                  configfs                             configfs    rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections                            fusectl                              fusectl     rw,nosuid,nodev,noexec,relatime
    |-/proc                                                 proc                                 proc        rw,relatime
    | `-/proc/sys/fs/binfmt_misc                            systemd-1                            autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=3940
    |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc                          binfmt_misc rw,nosuid,nodev,noexec,relatime
    |-/dev                                                  udev                                 devtmpfs    rw,nosuid,relatime,size=3729132k,nr_inodes=932283,mode=755
    | |-/dev/pts                                            devpts                               devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                                            tmpfs                                tmpfs       rw,nosuid,nodev
    | `-/dev/mqueue                                         mqueue                               mqueue      rw,nosuid,nodev,noexec,relatime
    |-/run                                                  tmpfs                                tmpfs       rw,nosuid,nodev,noexec,relatime,size=799772k,mode=755
    | |-/run/lock                                           tmpfs                                tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/credentials/systemd-sysctl.service             ramfs                                ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysusers.service           ramfs                                ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                                ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/rpc_pipefs                                     sunrpc                               rpc_pipefs  rw,relatime
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                                ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | `-/run/user/1000                                      tmpfs                                tmpfs       rw,nosuid,nodev,relatime,size=799768k,nr_inodes=199942,mode=700,uid=1000,gid=1000
    |-/boot/firmware                                        /dev/sda1                            vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    | 6 netshares mounted successful, deleted because of privacy issues
    /var:
    2.9G	/var/
    2.0G	/var/log/journal/608b96614dfe4477b12b074e08cee6d6
    2.0G	/var/log
    520M	/var/cache
    Archived and active journals take up 1.9G in the file system.
    /opt/iobroker/backups:
    4.0K	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G	/opt/iobroker/iobroker-data/
    946M	/opt/iobroker/iobroker-data/files
    285M	/opt/iobroker/iobroker-data/files/javascript.admin
    250M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    249M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M	/opt/iobroker/iobroker-data/objects.jsonl
    29M	/opt/iobroker/iobroker-data/states.jsonl
    29M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ecef4f21.js.map
    26M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DB_FT2PTYKW-if00-port0
    /dev/serial/by-id/usb-0658_0200-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.20.3
    /usr/bin/node 		v18.20.3
    /usr/bin/npm 		10.7.0
    /usr/bin/npx 		10.7.0
    /usr/bin/corepack 	0.28.0
    nodejs:
      Installed: 18.20.3-1nodesource1
      Candidate: 18.20.3-1nodesource1
      Version table:
     *** 18.20.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u1 500
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	6.0.1
    admin: 		6.17.14
    javascript: 	8.5.2
    nodejs modules from github: 	2
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    +-- iobroker.pioneer_sc_vsx@0.1.0 (git+ssh://git@github.com/okeck1982/ioBroker.pioneer_sc_vsx.git#b74d0f748835d2c1c4b860d43a8e6a24939039ce)
    Adapter State
    + system.adapter.adb.0                    : adb                   : Nordmanns-ioBroker-Server                -  enabled
    + system.adapter.admin.0                  : admin                 : Nordmanns-ioBroker-Server                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : Nordmanns-ioBroker-Server                - disabled
      system.adapter.backitup.0               : backitup              : Nordmanns-ioBroker-Server                - disabled
    + system.adapter.broadlink2.0             : broadlink2            : Nordmanns-ioBroker-Server                -  enabled
      system.adapter.discovery.0              : discovery             : Nordmanns-ioBroker-Server                - disabled
      system.adapter.dwd.0                    : dwd                   : Nordmanns-ioBroker-Server                -  enabled
    + system.adapter.echarts.0                : echarts               : Nordmanns-ioBroker-Server                -  enabled
    + system.adapter.ekey.0                   : ekey                  : Nordmanns-ioBroker-Server                -  enabled, port: 56000, bind: 0.0.0.0
    + system.adapter.enocean.0                : enocean               : Nordmanns-ioBroker-Server                -  enabled
    + system.adapter.ford.0                   : ford                  : Nordmanns-ioBroker-Server                -  enabled
      system.adapter.homepilot20.0            : homepilot20           : Nordmanns-ioBroker-Server                -  enabled
    + system.adapter.hue.0                    : hue                   : Nordmanns-ioBroker-Server                -  enabled, port: 443
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Nordmanns-ioBroker-Server                - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Nordmanns-ioBroker-Server                - disabled
    + system.adapter.javascript.0             : javascript            : Nordmanns-ioBroker-Server                -  enabled
      system.adapter.modbus.0                 : modbus                : Nordmanns-ioBroker-Server                - disabled
    + system.adapter.netatmo.0                : netatmo               : Nordmanns-ioBroker-Server                -  enabled
    + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : Nordmanns-ioBroker-Server                -  enabled, port: 23
      system.adapter.scenes.0                 : scenes                : Nordmanns-ioBroker-Server                - disabled
    + system.adapter.shelly.0                 : shelly                : Nordmanns-ioBroker-Server                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.signal-cmb.0             : signal-cmb            : Nordmanns-ioBroker-Server                -  enabled
    + system.adapter.simple-api.0             : simple-api            : Nordmanns-ioBroker-Server                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : Nordmanns-ioBroker-Server                -  enabled, port: 3306
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : Nordmanns-ioBroker-Server                - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : Nordmanns-ioBroker-Server                - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Nordmanns-ioBroker-Server                - disabled
    + system.adapter.vis-2.0                  : vis-2                 : Nordmanns-ioBroker-Server                -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : Nordmanns-ioBroker-Server                - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : Nordmanns-ioBroker-Server                - disabled
    + system.adapter.web.0                    : web                   : Nordmanns-ioBroker-Server                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zwave2.0                 : zwave2                : Nordmanns-ioBroker-Server                -  enabled
    + instance is alive
    ioBroker-Repositories
    latest        : http://download.iobroker.net/sources-dist-latest.json
    stable        : http://download.iobroker.net/sources-dist-stable.json
    Active repo(s): latest
    Installed ioBroker-Instances
    Used repository: latest
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "admin"        : 6.17.14  , installed 6.17.14
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.3    , installed 3.0.3
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "ekey"         : 1.2.3    , installed 1.2.3
    Adapter    "enocean"      : 0.9.3    , installed 0.9.3
    Adapter    "ford"         : 1.0.2    , installed 1.0.2
    Adapter    "hue"          : 3.11.0   , installed 3.11.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
    Adapter    "javascript"   : 8.5.2    , installed 8.5.2
    Controller "js-controller": 6.0.2    , installed 6.0.1  [Updatable]
    Adapter    "modbus"       : 6.2.3    , installed 6.2.3
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "scenes"       : 3.0.4    , installed 3.0.4
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
    Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
    Adapter    "vis-2-widgets-material": 1.3.33, installed 1.3.33
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.2.6    , installed 6.2.6
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
    Objects and States
    Objects: 	13334
    States: 	8317
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13800      734/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18633      734/iobroker.js-con
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17843      1061/io.shelly.0
    tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       18987      1309/adb
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12225      758/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14190      1132/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13843      962/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18935      1173/io.simple-api.
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12227      758/sshd: /usr/sbin
    udp        0      0 0.0.0.0:58091           0.0.0.0:*                           104        13151      603/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13149      603/avahi-daemon: r
    udp        0      0 0.0.0.0:55610           0.0.0.0:*                           1001       80679      1018/io.broadlink2.
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       13898      1018/io.broadlink2.
    udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1001       18909      1118/io.ekey.0
    udp        0      0 0.0.0.0:57738           0.0.0.0:*                           1001       18782      1018/io.broadlink2.
    udp6       0      0 :::5353                 :::*                                104        13150      603/avahi-daemon: r
    udp6       0      0 :::53284                :::*                                104        13152      603/avahi-daemon: r
    2024-06-12 17:30:35.915  - debug: zwave2.0 (1197) Node 9: metadata updated: value_001_electric_kwh_consumed
    2024-06-12 17:30:35.916  - debug: zwave2.0 (1197) Node 9: value updated: value_001_electric_kwh_consumed => 7.54
    2024-06-12 17:30:35.963  - info: pioneer_sc_vsx.0 (1146) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2024-06-12 17:30:36.006  - debug: zwave2.0 (1197) Node 23: metadata updated: power
    2024-06-12 17:30:36.007  - debug: zwave2.0 (1197) Node 23: value updated: power => 33.5
    2024-06-12 17:30:36.201  - debug: zwave2.0 (1197) Node 25: metadata updated: value_electric_kwh_consumed
    2024-06-12 17:30:36.202  - debug: zwave2.0 (1197) Node 25: value updated: value_electric_kwh_consumed => 91.9
    2024-06-12 17:30:36.376  - debug: zwave2.0 (1197) Node 4: metadata updated: value_002_electric_w_consumed
    2024-06-12 17:30:36.377  - debug: zwave2.0 (1197) Node 4: value updated: value_002_electric_w_consumed => 0
    2024-06-12 17:30:36.585  - debug: zwave2.0 (1197) Node 11: metadata updated: power
    2024-06-12 17:30:36.587  - debug: zwave2.0 (1197) Node 11: value updated: power => 0
    2024-06-12 17:30:36.912  - debug: zwave2.0 (1197) Node 23: metadata updated: power
    2024-06-12 17:30:36.915  - debug: zwave2.0 (1197) Node 23: value updated: power => 14.7
    2024-06-12 17:30:36.947  - debug: zwave2.0 (1197) Node 45: metadata updated: power
    2024-06-12 17:30:36.949  - debug: zwave2.0 (1197) Node 45: value updated: power => 0.5
    2024-06-12 17:30:36.960  - debug: zwave2.0 (1197) Node 23: metadata updated: power
    2024-06-12 17:30:36.962  - debug: zwave2.0 (1197) Node 23: value updated: power => 14.7
    2024-06-12 17:30:37.038  - debug: zwave2.0 (1197) Node 45: metadata updated: power
    2024-06-12 17:30:37.039  - debug: zwave2.0 (1197) Node 45: value updated: power => 0.5
    2024-06-12 17:30:37.912  - debug: zwave2.0 (1197) Node 23: metadata updated: power
    2024-06-12 17:30:37.913  - debug: zwave2.0 (1197) Node 23: value updated: power => 24
    2024-06-12 17:30:38.460  - debug: zwave2.0 (1197) Node 36: metadata updated: power
    2024-06-12 17:30:38.462  - debug: zwave2.0 (1197) Node 36: value updated: power => 0.5
    2024-06-12 17:30:38.997  - debug: zwave2.0 (1197) Node 25: metadata updated: power
    2024-06-12 17:30:38.998  - debug: zwave2.0 (1197) Node 25: value updated: power => 122.6
    ioBroker-Host: Raspberry Pi 5 (8GByte RAM) mit Halo8-KI-Hat, Argon ONE M.2-Gehäuse mit 256GByte PCIe-SSD
    • Ro75R Offline
      Ro75R Offline
      Ro75
      schrieb am zuletzt editiert von Ro75
      @klausstoertebeker bist du viel in BETA unterwegs? Der Controller ist "Beta". Wenn du nicht testen willst und das nicht deine Absicht ist, dann bleibe auf "stable".
      Ro75.
      KlausStoertebekerK 1 Antwort Letzte Antwort
      • Ro75R Ro75
        Ro75.
        KlausStoertebeker
        @Ro75
        Nein, ich wollte nicht testen. Aber mir wurde halt über eine Benachrichtigung unter "Hosts" mitgeteilt, dass für den js-controller eine neue Version vorliegt - von "Beta" war da nicht die Rede...
        Aber wenn Version 6.0.1 keine "stable"-Version ist, werde ic hwieder auf die letzte stabile Version downgraden (5.0.19).
        Danke für den Hinweis :-)
        Ro75R Samson71S 2 Antworten Letzte Antwort
        • KlausStoertebekerK KlausStoertebeker
          @Ro75
          Ro75R Offline
          Ro75R Offline
          Ro75
          @klausstoertebeker dann stelle mal zurück auf "stable" wenn du nicht aktiv testen willst.
          Aber ich befürchte, dass da schon jede Menge an Adapter in "Testversion / nicht stable" installiert wurde.
          Ro75.
            @Ro75
            Samson71S Offline
            Samson71S Offline
            Samson71
            @klausstoertebeker sagte in "homepilot20" stürzt nach js-controller 6.0.1-Update ab:
            Dann steht aber in den Einstellungen Dein Standard-Repo nicht auf stable sondern auf beta. Änder das ggf. ab
            Markus
            Bitte beachten:
            • Ro75R Ro75
              Ro75.
              mcm1957M Online
              mcm1957M Online
              mcm1957
              Homepilot20 ist nicht in einem Repository gelistet und nicht mit js-controller 6 kompatibel.
              Bitte wende dich an den dev des Adapters.
              Von der Installation von Adaptern dirjet von Github wird exolizut abgeraten ausser für Testzwecke in Abstimmung mit dem dev.
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              • mcm1957M mcm1957
                mcm1957M Online
                mcm1957M Online
                mcm1957
                @mcm1957
                @mcm1957 said in "homepilot20" stürzt nach js-controller 6.0.1-Update ab:
                Von der Installation von Adaptern direkt von Github wird explizit abgeraten ausser für Testzwecke in Abstimmung mit dem dev.
                @homecineplexx hat den Adapter dankenswerterweise angepasst. Bitte teste mit Version 0.0.53. Diese sollte nun auch mit js-controller funktionieren. - DANKE (Installation von Github und npm möglich, derzeit aber nicht in den Repos)
                Sollte der Adapter nun auch mit js-ontroller 6 in gewohnter guter Qualität funktionieren rege ggF beim dev an diesen in den Repositories zu veröffentlichen. Die offizielle Empfehlung außer auf Anregung des Devs und zu Testzwecken keine Adapter direkt von Github auf produktiven Systemen zu installieren gilt unverändert.
                • Samson71S Samson71
                  KlausStoertebeker
                  @samson71
                  Hallo Samson,
                  mein Repo steht auf "latest"...
                  Und weiter unten hat mcm1957 gesagt, dass der homepilot20-Adapter angepasst wurde. Dann werde ich das bei meiner geplanten Neuinstallation mal ausprobieren :-)
                    @samson71
                    Hallo Samson,
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @samson71 said in "homepilot20" stürzt nach js-controller 6.0.1-Update ab:
                    @klausstoertebeker said in "homepilot20" stürzt nach js-controller 6.0.1-Update ab:
                    LATEST === BETA = Testversionen von Adaptern
                    STABLE = Versionen die bereits einige Zeit ohne (gröbere) Probleme im Latest getestet wurden.
                    Wenn du also nicht nagelneue Versionen zum Tests installieren willst, stell dein Repo auf STABLE. Zusätzlich solltest du solange du latest / beta eingestelltz hast am oberen Rand des Admin Adapter Tabs eine Warnmeldung sehen dass du auf latest / beta bist ...
