  5. PV Strom Aufteilung
    6.6k
PV Strom Aufteilung
63 Beiträge 4 Kommentatoren 9.6k Aufrufe 1 Beobachtet
    @marco-willi sagte: symbol </> oder? Zeigt mir an, dass der code zu lange ist.
    Wirklich? Mein Export in Code tags (Symbol </>):
     <variables>
       <variable id="4!.QWl^o3C^:xOUsncDM">leistungen</variable>
       <variable id="Z/yy2t[:@n/yCnE{;JD2">arr</variable>
       <variable id="/cK}~OC31xnguYr]V1Ug">attr</variable>
       <variable id="MEu~m0ap=YGi@;I{l)R*">i</variable>
       <variable id="8IG{1^[y#F?[OcT$kfU^">obj</variable>
       <variable id="q6h7`B[$+ZsH#a^bNB*f">Restanzahl</variable>
       <variable id="j(Ay`U4*K?f`uxBMT=~B">Restleistung</variable>
       <variable id="%KbqcvOJ4#JoV?4(u1!T">Restmittel</variable>
       <variable id="|~:77.d*!:FG7?xwvy=+">leistung</variable>
       <variable id="ZS.uZvVkXP{+B`D%[jGd">id</variable>
     </variables>
     <block type="variables_set" id="XHOw[jb!GnH%uw/EkkSR" x="-1637" y="-1137">
       <field name="VAR" id="4!.QWl^o3C^:xOUsncDM">leistungen</field>
       <value name="VALUE">
         <block type="lists_create_with" id="w0g@e!P0GRHlcL_JocR3">
           <mutation items="5"></mutation>
           <value name="ADD0">
             <block type="object_new" id="Pz+z.0=fN{G#s2[vn_k$" inline="true">
               <mutation xmlns="http://www.w3.org/1999/xhtml">
                 <attribute id="ATTR_0" name="id"></attribute>
                 <attribute id="ATTR_1" name="power"></attribute>
               </mutation>
               <value name="ATTR_0">
                 <shadow type="text" id="/n#q.h{2u%%6]:5x%sdL">
                   <field name="TEXT">idZähler1</field>
                 </shadow>
               </value>
               <value name="ATTR_1">
                 <shadow type="text" id="5!nWL7pP`UDJEF2Iytm+">
                   <field name="TEXT"></field>
                 </shadow>
                 <block type="math_number" id="ZIhR[uYM@@_$9Dd*Kji#">
                   <field name="NUM">0</field>
                 </block>
               </value>
             </block>
           </value>
           <value name="ADD1">
             <block type="object_new" id="mI,~-6{f0omisH]1$!aH" inline="true">
               </mutation>
                 <shadow type="text" id="iYqVUWwruFtgC1SX4E,]">
                   <field name="TEXT">idZähler2</field>
                 </shadow>
               </value>
                 </shadow>
                 <block type="math_number" id="?EX-s%XS3b=]taH?;~qS">
                 </block>
               </value>
             </block>
           </value>
           <value name="ADD2">
             <block type="object_new" id="4sx|V!a=GAi:aHYor=#c" inline="true">
               </mutation>
                 <shadow type="text" id=",C(EXVwXVsw~kn*:;Ew@">
                   <field name="TEXT">idZähler3</field>
                 </shadow>
               </value>
                 </shadow>
                 <block type="math_number" id="5.Z8gqu6t|d6Nn*B2+W3">
                 </block>
               </value>
             </block>
           </value>
           <value name="ADD3">
             <block type="object_new" id="fr=y-vg*3~;hHyMzL@Xd" inline="true">
               </mutation>
                 <shadow type="text" id="Tez`^.U4nL3Qr#PFhlNX">
                   <field name="TEXT">idZähler4</field>
                 </shadow>
               </value>
                 </shadow>
                 <block type="math_number" id="lh7sliQ,!$R:T+=kd^I=">
                 </block>
               </value>
             </block>
           </value>
           <value name="ADD4">
             <block type="object_new" id="6v=SH@?A8sCwSrzlg1Ur" inline="true">
               </mutation>
                 <shadow type="text" id="u=0=rm1ozyMf}[9iM2;,">
                   <field name="TEXT">idZähler5</field>
                 </shadow>
               </value>
                 </shadow>
                 <block type="math_number" id="YFDPREY!DyIOXg{CS37?">
                 </block>
               </value>
             </block>
           </value>
         </block>
       </value>
       <next>
         <block type="on" id="~GBxWGx#,niJ$@tGOk.C">
           <field name="OID">0_userdata.0.Blockly.PV_Eigenbedarf</field>
           <statement name="STATEMENT">
             <block type="controls_for" id="jz%?P9H/lHwD^J6bh-Lq">
               <field name="VAR" id="MEu~m0ap=YGi@;I{l)R*">i</field>
               <value name="FROM">
                 <shadow type="math_number" id="p/r%~#^;:kGAh2@vkL+c">
                   <field name="NUM">1</field>
                 </shadow>
               </value>
               <value name="TO">
                 <shadow type="math_number" id="e)%X6NXh[(3!v_6NP}S*">
                   <field name="NUM">5</field>
                 </shadow>
               </value>
               <value name="BY">
                 <shadow type="math_number" id="q;,9T5So)m`!BLV9L*8?">
                 </shadow>
               </value>
               <statement name="DO">
                 <block type="variables_set" id="k?{`ELn=nM{JEdI!fiXb">
                   <field name="VAR" id="8IG{1^[y#F?[OcT$kfU^">obj</field>
                     <block type="lists_getIndex" id="L5QxUxlJihTlVVIHW;_4">
                       <mutation statement="false" at="true"></mutation>
                       <field name="MODE">GET</field>
                       <field name="WHERE">FROM_START</field>
                         <block type="variables_get" id="LoL.9{E)}57X]?Nq/~RW">
                         </block>
                       </value>
                       <value name="AT">
                         <block type="variables_get" id="cfPi2Y^N7wKK~K}1J2od">
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="object_set_attr" id="i=ahLy029.U05]UGy]l]">
                       <field name="ATTR">power</field>
                       <value name="OBJECT">
                         <block type="variables_get" id="1-1cXoe+]f2s}ui#E]3k">
                         </block>
                       </value>
                         <shadow type="text" id="$(l%#9%IrZe(j9J:nS$9">
                           <field name="TEXT">value</field>
                         </shadow>
                         <block type="get_value_var" id="i^*U/KS(R]IXQWs0WeFm">
                           <value name="OID">
                             <shadow type="field_oid" id="pA}7xDu_zarp3IH1O8^G">
                               <field name="oid">Object ID</field>
                             </shadow>
                             <block type="get_attr" id="MakZviRK#!y5O$FSUQDj">
                               <value name="PATH">
                                 <shadow type="text" id="GYLIns737hBM(rTgwbq+">
                                   <field name="TEXT">id</field>
                                 </shadow>
                               </value>
                                 <shadow type="get_object" id="vqVwCRtdz;4;|09)cUoG">
                                 </shadow>
                                 <block type="variables_get" id="J8[FT1(B2qCK|jVC)jr/">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                         <block type="lists_setIndex" id="2FK;uc+f#R0I,%71V}Rm">
                           <mutation at="true"></mutation>
                           <field name="MODE">SET</field>
                           <value name="LIST">
                             <block type="variables_get" id="|d#dX!1f9W:a_jS+=9LT">
                             </block>
                           </value>
                           <value name="AT">
                             <block type="variables_get" id="%,{F(;olX~.mC-4buL_#">
                             </block>
                           </value>
                           <value name="TO">
                             <block type="variables_get" id="pgAS[{dD}[ukC}c{L_gb">
                             </block>
                           </value>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
               <next>
                 <block type="procedures_callcustomnoreturn" id="=;B`Gy;(6,m{q-?G$=8Q" inline="true">
                   <mutation name="sortObjectNum">
                     <arg name="arr"></arg>
                     <arg name="attr"></arg>
                   </mutation>
                   <value name="ARG0">
                     <block type="variables_get" id="3}QIG$EVa~0;!{+JyzGn">
                     </block>
                   </value>
                   <value name="ARG1">
                     <block type="text" id="tarlJ1Fw+E{_Suhu7=aL">
                       <field name="TEXT">power</field>
                     </block>
                   </value>
                   <next>
                     <block type="variables_set" id="XX~d^%fLF^+zp9f8%YZX">
                       <field name="VAR" id="q6h7`B[$+ZsH#a^bNB*f">Restanzahl</field>
                         <block type="math_number" id="dfF)Kl1Hz4U;POr.tyWR">
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="nG;I777OKpG+qk3:*X_]">
                           <field name="VAR" id="j(Ay`U4*K?f`uxBMT=~B">Restleistung</field>
                             <block type="on_source" id="!J[Br_=d_0yA?arw+vL*">
                             </block>
                           </value>
                           <next>
                             <block type="controls_for" id="Z,T{!KsbeCX[m#]m%*j6">
                               <value name="FROM">
                                 <shadow type="math_number" id="3Cy.u$.p{1P.QoX5#;16">
                                 </shadow>
                               </value>
                               <value name="TO">
                                 <shadow type="math_number" id="Sf/oUpwKuB;=4PasT;@x">
                                 </shadow>
                               </value>
                               <value name="BY">
                                 <shadow type="math_number" id="ZcjkV2mkj+s-kn~QClH9">
                                 </shadow>
                               </value>
                                 <block type="variables_set" id="z^9^*h9Ncs1`kX{}PS4#">
                                   <field name="VAR" id="%KbqcvOJ4#JoV?4(u1!T">Restmittel</field>
                                     <block type="math_round" id="!MB7J]7%bNAf=X;h^QCK">
                                       <field name="OP">ROUND</field>
                                       <value name="NUM">
                                         <shadow type="math_number" id="E_zGQC$Y64TM3ClizW[Y">
                                           <field name="NUM">3.1</field>
                                         </shadow>
                                         <block type="math_arithmetic" id="M*HjmCiocLGHz=ilHr2o">
                                           <field name="OP">DIVIDE</field>
                                           <value name="A">
                                             <shadow type="math_number" id="r{CTeOH+-fp_sqwC0EKC">
                                             </shadow>
                                             <block type="variables_get" id="/RyBmFXVq)A_70ySFg_}">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <shadow type="math_number" id="w=e.DF{)iVv`WxUkBq9s">
                                             </shadow>
                                             <block type="variables_get" id="1E`Xnfl7s3EgPCfTlwFE">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="variables_set" id="k,W.9746]lV?c~40,4Rl">
                                         <block type="lists_getIndex" id="l.wv[;!F/J9WPq4THM?^">
                                             <block type="variables_get" id="eiU/42-|vX4Q8#8_jdb5">
                                             </block>
                                           </value>
                                           <value name="AT">
                                             <block type="variables_get" id="b^_u@ZD/Psy}F5Z9GOpZ">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="variables_set" id="{!y5o:n9_:=2K+RTk2!`">
                                           <field name="VAR" id="|~:77.d*!:FG7?xwvy=+">leistung</field>
                                             <block type="get_attr" id="l_[5ihlEj=inX{5l*^o!">
                                               <value name="PATH">
                                                 <shadow type="text" id="vg#iQ)P.`6$GP(m!ER$e">
                                                 </shadow>
                                               </value>
                                                 </shadow>
                                                 <block type="variables_get" id="TPdV*Rueb@x70p_XBRTZ">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                             <block type="controls_if" id="(nDus,^!Ey661rY)dyN0">
                                               <value name="IF0">
                                                 <block type="logic_compare" id="~#GYM1T$E$jp+PhS)ZRL">
                                                   <field name="OP">GT</field>
                                                   <value name="A">
                                                     <block type="variables_get" id="ZmdhoHu)*.[iabl*-W.S">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="variables_get" id="I=Q0StB]NA/HB{7TsQkO">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <statement name="DO0">
                                                 <block type="variables_set" id="I1UtP{U8HI#?YfN%VcVz">
                                                     <block type="variables_get" id="L`trdMC{7RZxCvt@(nVy">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </statement>
                                               <next>
                                                 <block type="variables_set" id="bKDOcaltB*/iMvcHoEU$">
                                                   <field name="VAR" id="ZS.uZvVkXP{+B`D%[jGd">id</field>
                                                     <block type="text_replace" id="8_aTm%Ib#,GHT2,Fi[u{">
                                                       <value name="FROM">
                                                         <shadow type="text" id="`1FmYkQgRVTX0gSmw3L/">
                                                           <field name="TEXT">alias.0</field>
                                                         </shadow>
                                                       </value>
                                                       <value name="TO">
                                                         <shadow type="text" id="kWL:nij.yb90O.,~4d`4">
                                                           <field name="TEXT">0_userdata.0</field>
                                                         </shadow>
                                                       </value>
                                                       <value name="TEXT">
                                                         <shadow type="text" id="CFe,-9!u[l|#/TvI~B@y">
                                                         </shadow>
                                                         <block type="get_attr" id="wOaK48e6v,Is-%XL#0EE">
                                                           <value name="PATH">
                                                             <shadow type="text" id="_TN-H-upTjupq8hyx1hX">
                                                             </shadow>
                                                           </value>
                                                             </shadow>
                                                             <block type="variables_get" id="sjlB|$?V5P0!Z+`Aj0OT">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="control_ex" id="Hws.qi!hVm#%OwNI!W1w" inline="true">
                                                       <field name="TYPE">true</field>
                                                       <value name="OID">
                                                         <shadow type="field_oid" id="B,Z~E~138Rbd68r/zZa8">
                                                         </shadow>
                                                         <block type="variables_get" id="5MbG/Anwd!JphfxyM|`9">
                                                         </block>
                                                       </value>
                                                         <shadow type="logic_boolean" id="9w%jp}sct=[1gZW}^)i:">
                                                         </shadow>
                                                         <block type="variables_get" id=":E9@lFe_u{%PbMVch]]P">
                                                         </block>
                                                       </value>
                                                       <value name="DELAY_MS">
                                                         <shadow type="math_number" id="B@Xu~_M:+UP}XRyn8e-K">
                                                         </shadow>
                                                       </value>
                                                       <value name="EXPIRE">
                                                         <shadow type="math_number" id="-*7!Pt_j|1@%D2LLoC`!">
                                                         </shadow>
                                                       </value>
                                                       <next>
                                                         <block type="math_change" id="Kl;wUCg]EscMZMPkL6q_">
                                                           <value name="DELTA">
                                                             <shadow type="math_number" id="HVu2@iYtQCXE?$l_R0;u">
                                                               <field name="NUM">-1</field>
                                                             </shadow>
                                                           </value>
                                                           <next>
                                                             <block type="math_change" id="yjGl@0%,T^b|p8)$R^k#">
        <shadow type="math_number" id="C)z-_5P;}E+2nSj?7lA%">
        </shadow>
        <block type="math_single" id="N=Ygb:T9LY-]]oySV~-w">
        <field name="OP">NEG</field>
        <value name="NUM">
        <shadow type="math_number" id="vRpBXlSDwGMb3h#Ho^?b">
        <field name="NUM">9</field>
        </shadow>
        <block type="variables_get" id="LVM=mCV=RkXAd#tELl,~">
        </block>
        </value>
        </block>
                                                               </value>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
     <block type="procedures_defcustomnoreturn" id="CxdOO.WCDAjV:Z{(+ME[" x="-1413" y="-912">
       <mutation statements="false">
         <arg name="arr" varid="Z/yy2t[:@n/yCnE{;JD2"></arg>
         <arg name="attr" varid="/cK}~OC31xnguYr]V1Ug"></arg>
       </mutation>
       <field name="NAME">sortObjectNum</field>
       <field name="SCRIPT">ZnVuY3Rpb24gc29ydEF0dHIoYSwgYikgew0KICAgIHJldHVybiBwYXJzZUZsb2F0KGFbYXR0cl0pIC0gcGFyc2VGbG9hdChiW2F0dHJdKTsNCn0NCmFyci5zb3J0KHNvcnRBdHRyKTs=</field>
     </block>
    </xml>
    Marco WilliM Offline
    Marco Willi
    so, jetzt am computer. Das mit den Bildern wird aber noch schwierig. Kenn den Computer so gar nicht... bin ein neuer Mac User. Sorry
      <variables>
        <variable id="dTTm]Y;f*9fW4IR]M3nv">zaehler</variable>
        <variable id="tf?~U:?IZv!S/0cEDw*M">verbrauch</variable>
        <variable id="Am?{@M!fHmePD.l=^yFu">ZählerNummer_</variable>
        <variable id="mf$nRg:n*]=]rUqF8p]~">ZählerVerbrauch_</variable>
        <variable id="jz(WYo2RH^XV%P$8`cAz">rest ab 2te</variable>
        <variable id="$0Z58`kKviMG[zyjoa$3">rest ab 3te</variable>
        <variable id="nl~Kh$W3axP]rB5;Vu,#">Zähler_ID</variable>
        <variable id="`=*LwlEhb/8gjZU.W8pv">Liste_sortiert</variable>
        <variable id="PY}*+`j;}H}^Lm+C9N$n">1_5 Teil</variable>
        <variable id="9Xtnev|xAV30$qnZw.?W">Wert_1ste</variable>
        <variable id="s}`NhkS#bbbkKnhEvlh}">Wert_2te</variable>
        <variable id="1F^o@YN[2g~LM-V]o$b!">Wert_4te</variable>
        <variable id="LvJdi,HZcN8CJ5(TUGN?">Wert_5te</variable>
        <variable id=";UV.oZ3B2@*-Y0JW8g|U">Wert_3te</variable>
        <variable id="2RGq,EZh=7ChG@rYK.*W">Gesamtbezug</variable>
        <variable id="rqWg-2(,)x%vFfNUoj?$">Liste</variable>
      </variables>
      <block type="procedures_defcustomreturn" id="^T@L{N7^b-s1(5r#zk*v" x="1288" y="-288">
          <arg name="zaehler" varid="dTTm]Y;f*9fW4IR]M3nv"></arg>
          <arg name="verbrauch" varid="tf?~U:?IZv!S/0cEDw*M"></arg>
        </mutation>
        <field name="NAME">Zähler</field>
        <field name="SCRIPT">cmV0dXJuIHsNCiAgICBaYWVobGVyOiB6YWVobGVyLA0KICAgIFZlcmJyYXVjaDogdmVyYnJhdWNoDQp9Ow==</field>
      </block>
      <block type="procedures_defnoreturn" id="ANpB/okan5xoK~us}a_e" x="1312" y="-212">
        <field name="NAME">Zäler 1</field>
        <statement name="STACK">
          <block type="variables_set" id="|rQ%!g)n`1LOP$zwQ8_F">
            <field name="VAR" id="Am?{@M!fHmePD.l=^yFu">ZählerNummer_</field>
              <block type="get_attr" id="9XM9cI)[=kb)az%gz!z/">
                <value name="PATH">
                  <shadow type="text" id="H@E)D?=PD`2V7ibfc60g">
                    <field name="TEXT">Zaehler</field>
                  </shadow>
                </value>
                  <block type="lists_getIndex" id="fuubQ1?tZqrX7Vs*H}?1">
                      <block type="variables_get" id="JYkAZ;x.)_K^5A`6@oYx">
                        <field name="VAR" id="`=*LwlEhb/8gjZU.W8pv">Liste_sortiert</field>
                      </block>
                    </value>
                    <value name="AT">
                      <block type="math_number" id="=@xY|bQ)JaDm_7^]fX^;">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="variables_set" id="54l5%IR?.Wtby#]c4e~Y">
                <field name="VAR" id="mf$nRg:n*]=]rUqF8p]~">ZählerVerbrauch_</field>
                  <block type="get_attr" id="`zXEN1b/Ju=/^]]`Im2h">
                    <value name="PATH">
                      <shadow type="text" id="0;7*([hf%b4;Nc=KEO{x">
                        <field name="TEXT">Verbrauch</field>
                      </shadow>
                    </value>
                      <block type="lists_getIndex" id="[!(#CrDWa/XZLZWXS1$%">
                          <block type="variables_get" id="1boqahr4uBXjqn8ndCVs">
                          </block>
                        </value>
                        <value name="AT">
                          <block type="math_number" id="Ky]0|GZG3lyoqP=gvYDu">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="variables_set" id=".1hnjQxtK_1yPqXvig,z">
                    <field name="VAR" id="nl~Kh$W3axP]rB5;Vu,#">Zähler_ID</field>
                      <block type="text_join" id="YIperZRgXA!]-jNUBOA#">
                        <value name="ADD0">
                          <block type="text" id="Y}|1:U[/pZY_Zes3~p;!">
                            <field name="TEXT">0_userdata.0.SolarWEG.</field>
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="variables_get" id="G,4-%l36rWxi[jJ5)3#v">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="comment" id="5qfBqyY|]AMN:E.Y7l+{" x="513" y="13">
        <field name="COMMENT">Z01=Anteil PV Allgemein</field>
        <next>
          <block type="comment" id="u*;qU~y$M4OsdioBE*Fr">
            <field name="COMMENT">Z02=Anteil PV Willi</field>
            <next>
              <block type="comment" id="jp$uy?Z?UJw_n]axA~xK">
                <field name="COMMENT">Z03=Anteil PV Gubser</field>
                <next>
                  <block type="comment" id="6EZ_e{|T]La]X0Kj$:/J">
                    <field name="COMMENT">Z04=Anteil PV Lang</field>
                    <next>
                      <block type="comment" id="T/8N3nC*e#qL4#(8-$n(">
                        <field name="COMMENT">Z05=Anteil PV Giger</field>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
      <block type="schedule" id="SeGHl$+Bs!qV^vqOAu[(" x="163" y="38">
        <field name="SCHEDULE">* * * * *</field>
          <block type="control" id="G,g#g^ql6R_dBd7wIhFM">
            <field name="OID">0_userdata.0.SolarWEG.Zähler01</field>
              <block type="math_number" id="o_kPP5E|v)vZ25=HV`?B">
              </block>
            </value>
            <next>
              <block type="control" id="=t2,Z4%xJ+A{qJ9qZF=U">
                <field name="OID">0_userdata.0.SolarWEG.Zähler02</field>
                  <block type="math_number" id="}GJ0b~P4T7RvuOcRpqND">
                  </block>
                </value>
                <next>
                  <block type="control" id="-abg#h.o@9bWaVD3i!}(">
                    <field name="OID">0_userdata.0.SolarWEG.Zähler03</field>
                      <block type="math_number" id="SVwE8Ml*vfoZZR6Mbt8^">
                      </block>
                    </value>
                    <next>
                      <block type="control" id="UHib!d4.,AF77ZuG05Bs">
                        <field name="OID">0_userdata.0.SolarWEG.Zähler04</field>
                          <block type="math_number" id="DBe$r(%#H($lQ^peX#z(">
                          </block>
                        </value>
                        <next>
                          <block type="control" id="04GS!$r@?Y=@x2,Q)o@x">
                            <field name="OID">0_userdata.0.SolarWEG.Zähler05</field>
                              <block type="math_number" id="@{qXv13)%~]2}:)T39C-">
                              </block>
                            </value>
                            <next>
                              <block type="variables_set" id="j6hAstkHo=/enSd;1r|(">
                                <field name="VAR" id="2RGq,EZh=7ChG@rYK.*W">Gesamtbezug</field>
                                  <block type="math_arithmetic" id="=QhEpQ_%E6BhzlYGf6[]" inline="false">
                                    <field name="OP">ADD</field>
                                    <value name="A">
                                      <shadow type="math_number" id="_~gE^U8$~Dx:?.4d%^RW">
                                      </shadow>
                                      <block type="math_arithmetic" id="K+im.;E7iiXZ7yRBAgoE" inline="false">
                                        <value name="A">
                                          <shadow type="math_number" id="tkM|NasEp+@@ASFwTb8#">
                                          </shadow>
                                          <block type="get_value" id="g3|eKa!v*zF_Ee*TF:OO">
                                            <field name="OID">0_userdata.0.SolarWEG.Zähler_1</field>
                                          </block>
                                        </value>
                                        <value name="B">
                                          <shadow type="math_number" id="xr}gZw1*rvRNiZYZuZXn">
                                          </shadow>
                                          <block type="get_value" id="(d@A$PU^{-Q`-#]D(DbO">
                                            <field name="OID">0_userdata.0.SolarWEG.Zähler_2</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <shadow type="math_number" id=".~7_E)hzO,,L9S+q^N9h">
                                      </shadow>
                                      <block type="math_arithmetic" id="P/:5efp4ISL4wp@VF2[f" inline="false">
                                        <value name="A">
                                          </shadow>
                                          <block type="get_value" id="s#Y(39CZUn*`Cr3!ATJS">
                                            <field name="OID">0_userdata.0.SolarWEG.Zähler_3</field>
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                          <block type="math_arithmetic" id="Hblk6Gx+(wU|8Q-,eK]1" inline="false">
                                            <value name="A">
                                              </shadow>
                                              <block type="get_value" id="8$}X=Qpq5PKU}O`fdY.+">
                                                <field name="OID">0_userdata.0.SolarWEG.Zähler_4</field>
                                              </block>
                                            </value>
                                            <value name="B">
                                              <shadow type="math_number" id="Zjf:l.g@/PeIooKY!*`k">
                                              </shadow>
                                              <block type="get_value" id="dGD_UU/@=l`4P3muef!/">
                                                <field name="OID">0_userdata.0.SolarWEG.Zähler_5</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="variables_set" id="HRYM}}D$#KT1j5_.)/d$">
                                    <field name="VAR" id="PY}*+`j;}H}^Lm+C9N$n">1_5 Teil</field>
                                      <block type="math_arithmetic" id="m9KJs(^L3E)lc1c(HgTm">
                                        <value name="A">
                                          <shadow type="math_number" id="HHDfl/7_QMOoHQ`cGgRm">
                                          </shadow>
                                          <block type="get_value" id="@jz~_*W,%`8@P)M`HjHj">
                                            <field name="OID">0_userdata.0.SolarWEG.Solar_Erzeugung</field>
                                          </block>
                                        </value>
                                        <value name="B">
                                          <shadow type="math_number" id="o`HB))n[QSUP8;sy+x*P">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="variables_set" id="$D^5JNKp:x%p3+~Cy5%g">
                                        <field name="VAR" id="rqWg-2(,)x%vFfNUoj?$">Liste</field>
                                          <block type="lists_create_with" id="VA`wrfQhk$]Y/.kJ/iJu">
                                            <value name="ADD0">
                                              <block type="procedures_callcustomreturn" id="SqMZ[qtiCH,wckJT0%:H">
                                                <mutation name="Zähler">
                                                  <arg name="zaehler"></arg>
                                                  <arg name="verbrauch"></arg>
                                                </mutation>
                                                <value name="ARG0">
                                                  <block type="text" id="=tm:mra?l9NFq:++3%zI">
                                                    <field name="TEXT">Zähler01</field>
                                                  </block>
                                                </value>
                                                <value name="ARG1">
                                                  <block type="get_value" id="!?}$Q##qcwAr`r-Xh~)J">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              <block type="procedures_callcustomreturn" id="/D^2/:Ij|$#YeZMV-juN">
                                                </mutation>
                                                <value name="ARG0">
                                                  <block type="text" id="93z4=INPlW+iYBc279U?">
                                                    <field name="TEXT">Zähler02</field>
                                                  </block>
                                                </value>
                                                <value name="ARG1">
                                                  <block type="get_value" id="WCf{_Q1bYMED:DV2k3%.">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              <block type="procedures_callcustomreturn" id="42C`@j6,{KJ:*wLek2++">
                                                </mutation>
                                                <value name="ARG0">
                                                  <block type="text" id="1B?-Dtk=%NF0Ol@XoS^K">
                                                    <field name="TEXT">Zähler03</field>
                                                  </block>
                                                </value>
                                                <value name="ARG1">
                                                  <block type="get_value" id="=B]00ybj*}KA7;l;}}.P">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD3">
                                              <block type="procedures_callcustomreturn" id="THo/J%u/Gpb$N^(+]l_W">
                                                </mutation>
                                                <value name="ARG0">
                                                  <block type="text" id="hMd+`TL}aKQG@w^9I`uX">
                                                    <field name="TEXT">Zähler04</field>
                                                  </block>
                                                </value>
                                                <value name="ARG1">
                                                  <block type="get_value" id="^$*pv`P}uHtFaQx!3M]r">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD4">
                                              <block type="procedures_callcustomreturn" id="f6Z:.JN7Kljatcd5!$/x">
                                                </mutation>
                                                <value name="ARG0">
                                                  <block type="text" id="Ha$7Q4Vz:{D}N@%29kNU">
                                                    <field name="TEXT">Zähler05</field>
                                                  </block>
                                                </value>
                                                <value name="ARG1">
                                                  <block type="get_value" id="N}Nbl@r+^Qhz1M3vUYdY">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="variables_set" id="X7:u!seN2IG;;/sAz#fY">
                                              <block type="convert_jsonata" id="rZwcgUE0VDc(k@gP,])_">
                                                <value name="EXPRESSION">
                                                  <shadow type="text" id="Jzh0?fmT4!/[A2HL.!$b">
                                                    <field name="TEXT">$^(Verbrauch)</field>
                                                  </shadow>
                                                </value>
                                                <value name="TARGET">
                                                  <block type="variables_get" id="N1C%LACBsP%bfOVU@9w:">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="debug" id="{F^e[uY#[qgYRJNS(#s=">
                                                <field name="Severity">info</field>
                                                <value name="TEXT">
                                                  <shadow type="text" id="PzTYJ=Ris)2sri]/=o.(">
                                                  </shadow>
                                                  <block type="variables_get" id="agX[a-P=R_j@L+J;hTH#">
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="debug" id="dduw8J}KeX!ZyMysUZb0">
                                                    <value name="TEXT">
                                                      </shadow>
                                                      <block type="text_join" id="J:.hyJ;XnKt2Vzah;AU4">
                                                        <mutation items="6"></mutation>
                                                        <value name="ADD0">
                                                          <block type="text" id="2.sWz[3U8p$9Km=$wl]r">
                                                            <field name="TEXT">Es werden </field>
                                                          </block>
                                                        </value>
                                                        <value name="ADD1">
                                                          <block type="get_value" id="R1I=6SI4Y5cZEpPX^U.h">
                                                          </block>
                                                        </value>
                                                        <value name="ADD2">
                                                          <block type="text" id="`fTX;wjU]u/aKdmUC]lS">
                                                            <field name="TEXT">W erzeugt. </field>
                                                          </block>
                                                        </value>
                                                        <value name="ADD3">
                                                          <block type="text" id="$ctDhY:N}@?f|si4F+mE">
                                                            <field name="TEXT">1/5 davon sind: </field>
                                                          </block>
                                                        </value>
                                                        <value name="ADD4">
                                                          <block type="variables_get" id="!M2d7+4TO%mc[%klC,IF">
                                                          </block>
                                                        </value>
                                                        <value name="ADD5">
                                                          <block type="text" id="vwBB5T7A{s0L9@AoMk0?">
                                                            <field name="TEXT">W</field>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="debug" id="%C!T_36a0H^%0U?6J%E{">
                                                        <value name="TEXT">
                                                          <shadow type="text" id="PMeeDCoj%7;i}]Lk}Cx1">
                                                          </shadow>
                                                          <block type="variables_get" id="_xrM:]o[#RIr1,!b!/V)">
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="procedures_callnoreturn" id="t9h:5W4IV3^A~:vX^#T?">
                                                            <mutation name="1ste"></mutation>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="procedures_defnoreturn" id="7YP@fw0x2br`??Lv@w)p" x="1313" y="12">
        <field name="NAME">Zäler 2</field>
          <block type="variables_set" id="I_Hzj)n3E?{*I_hj0#8:">
              <block type="get_attr" id="ph6.G41;TZ/pXKc`sAL?">
                <value name="PATH">
                  <shadow type="text" id="6Y(xvT:XmWkCQ_fOI6$%">
                  </shadow>
                </value>
                  <block type="lists_getIndex" id="XH5JBu[ooOkWt[:m!}Vt">
                      <block type="variables_get" id="O/$u`15-DNZ6o8NwHDlK">
                      </block>
                    </value>
                    <value name="AT">
                      <block type="math_number" id="L)4bU8^~ovvn-]U6x2Mf">
                        <field name="NUM">2</field>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="variables_set" id="LVCAEV%vd[R/DMHjm_D7">
                  <block type="get_attr" id="-CVup1C4jPY]Ru][O]Qy">
                    <value name="PATH">
                      <shadow type="text" id="`V;88RIptMOFp^%6/T1E">
                      </shadow>
                    </value>
                      <block type="lists_getIndex" id="~1|S`:F*:e_|y^PFMn9h">
                          <block type="variables_get" id="X+BcO@IUV]Qx4_UR*gO.">
                          </block>
                        </value>
                        <value name="AT">
                          <block type="math_number" id="xN;:|h4B#l+)dQ,?6COp">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="variables_set" id="peA}4+bc:5oX*/Y/^ZFF">
                      <block type="text_join" id="E/#8:_9!iyt06*2h^()g">
                        <value name="ADD0">
                          <block type="text" id="Be5$M^j!xjZwVUBxhn)G">
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="variables_get" id="MEF?OE9(Ey@3^FVsEFT|">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="comment" id="OHbkd-#h-O}k/j9],#WG" x="788" y="213">
        <field name="COMMENT">Z1 Mw Allgemein</field>
        <next>
          <block type="comment" id="YZZ[$w+,!YsoAOl,:|VB">
            <field name="COMMENT">Z2 Mw Willi</field>
            <next>
              <block type="comment" id="Z0VGN#5XN1CEiLExZh~F">
                <field name="COMMENT">Z3 Mw Gubser</field>
                <next>
                  <block type="comment" id="|dr)RqPKsG+DrF|2j]U)">
                    <field name="COMMENT">Z4 Mw Lang</field>
                    <next>
                      <block type="comment" id="6tkTCaw_34mB0~Wmg.}g">
                        <field name="COMMENT">Z5 Mw Giger</field>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
      <block type="procedures_defnoreturn" id="3I(Z[b/.mHEHLwDW^:rf" x="1313" y="238">
        <field name="NAME">Zähler 3</field>
          <block type="variables_set" id="Z+c4n:C=eO%37`*Uj:#N">
              <block type="get_attr" id="O~,r_.xlNt:,rU4Xv,,k">
                <value name="PATH">
                  <shadow type="text" id="K^ac66x^]?!=4Tp;x@8O">
                  </shadow>
                </value>
                  <block type="lists_getIndex" id="b1VSH{*:I/=/edCEnPE4">
                      <block type="variables_get" id="FqFxqs:u`bNisVz_foS{">
                      </block>
                    </value>
                    <value name="AT">
                      <block type="math_number" id="t(vU`nN(71gr?]Uy]+!+">
                        <field name="NUM">3</field>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="variables_set" id="erUoMIb:gXtia2~):2i]">
                  <block type="get_attr" id=";{humSZ%cG$y@Gl}:Xf:">
                    <value name="PATH">
                      <shadow type="text" id="qWlF4#n.sIa(D(~y^LN0">
                      </shadow>
                    </value>
                      <block type="lists_getIndex" id=";VK-q!N8_PCm4DFV_NwN">
                          <block type="variables_get" id="-uTP;]v/=aM,hU}~+-`8">
                          </block>
                        </value>
                        <value name="AT">
                          <block type="math_number" id="$9D-$QJI$|`oJf#|XW?l">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="variables_set" id="Ccw:}J2[X2z`QT3l%uCY">
                      <block type="text_join" id="rS/iQ^P}Y~%J9u{-E8Q9">
                        <value name="ADD0">
                          <block type="text" id="Xn-##vDRPNvxF0)f4kC;">
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="variables_get" id="BDWw:j.Tut!_5WLdzj~Y">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="procedures_defnoreturn" id="#q4j3!`Nirls4.;c!{3|" x="1313" y="463">
        <field name="NAME">Zähler 4</field>
          <block type="variables_set" id="BB{d~*_[.#LvnJJ*+itw">
              <block type="get_attr" id="ESK9!8)NB`Z=0n-C/QQd">
                <value name="PATH">
                  <shadow type="text" id=";W^xL:o(V~^Ck#NCeqNK">
                  </shadow>
                </value>
                  <block type="lists_getIndex" id="]Fd:VqryYgtQq/.9FgsN">
                      <block type="variables_get" id="#VTndo)Dqr]#q2rD$QA6">
                      </block>
                    </value>
                    <value name="AT">
                      <block type="math_number" id="eZoM`+K;5(4TvS7?EFUR">
                        <field name="NUM">4</field>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="variables_set" id="I2swv%pK7Y}zz?IC0$3f">
                  <block type="get_attr" id="}8@ctSseXxh4yw^86~lx">
                    <value name="PATH">
                      <shadow type="text" id="=z[/@V3Xps43sRK;bSB[">
                      </shadow>
                    </value>
                      <block type="lists_getIndex" id="c?_Y/T;u3Fams*v8!$f*">
                          <block type="variables_get" id="pyTN`#csJ9LpYR6I85(m">
                          </block>
                        </value>
                        <value name="AT">
                          <block type="math_number" id="j/Zp/lWH}ZY79LiYR;8;">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="variables_set" id="y.oNeoyJzIUql2IVw[Li">
                      <block type="text_join" id="u[c2Z.PO+Emv2Q9$..=?">
                        <value name="ADD0">
                          <block type="text" id="VQs7chN;PeRriRaF_KGB">
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="variables_get" id="EL7@]r?=-uUwWp_#|y;-">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="procedures_defnoreturn" id=":+lv4f]pnlGyCWDaYCV?" x="1313" y="688">
        <field name="NAME">Zähler 5</field>
          <block type="variables_set" id="HF9zb=uDd@f7Q#bl?(s}">
              <block type="get_attr" id="v05_N1g#v(?DEe`}kV6h">
                <value name="PATH">
                  <shadow type="text" id="uT$ur)yg}@ke)=vmEO^-">
                  </shadow>
                </value>
                  <block type="lists_getIndex" id="w8:1D2NBr|GTP+7r!wnt">
                      <block type="variables_get" id="IdPkVO6T4Kv5cJe^e@q=">
                      </block>
                    </value>
                    <value name="AT">
                      <block type="math_number" id="21Nce}:py)Bl1RUfGybF">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="variables_set" id="EaagpP]UP;neL(6FL7DO">
                  <block type="get_attr" id="+$^5]$2M$L^3!]O7hHU{">
                    <value name="PATH">
                      <shadow type="text" id="MMOcG!GCd0wWM8C_5,Qj">
                      </shadow>
                    </value>
                      <block type="lists_getIndex" id="=V%P]o?`{kTxiI@D[bh9">
                          <block type="variables_get" id="4EUzmOW%J457y~C}9)g5">
                          </block>
                        </value>
                        <value name="AT">
                          <block type="math_number" id="i_!MZc*Xj^VGz$/%pDvY">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="variables_set" id="-e+Cwt65ZW|e7y?F#b]k">
                      <block type="text_join" id="TgPJiC{+A+vtwz*m~8ki">
                        <value name="ADD0">
                          <block type="text" id="/Jl_ZrL+_oGy]r3+@O?(">
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="variables_get" id="BHRi?H!!S~aiOv^+?Ns?">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="procedures_defnoreturn" id="jF$lDUq8mp-iFRvT$lD(" x="1313" y="913">
        <field name="NAME">Alles größer</field>
          <block type="debug" id="3t$}YmKLB`I([!a4zENG">
            <value name="TEXT">
              <shadow type="text" id="=jYFEm)}ZIDgK@VM=eg9">
                <field name="TEXT">alle größer</field>
              </shadow>
            </value>
            <next>
              <block type="procedures_callnoreturn" id="7Ezo,5vF0ip{z;|K?$$M">
                <mutation name="Zäler 1"></mutation>
                <next>
                  <block type="control_ex" id="Gd|WP]47t-IW6F%sq%Hg">
                    <field name="TYPE">false</field>
                    <value name="OID">
                      <shadow type="field_oid" id="*yA?v[`NTMbhC#I^nuOt">
                      </shadow>
                      <block type="variables_get" id="lhRvGSu$5AR#2MVkZ3V4">
                      </block>
                    </value>
                      <shadow type="logic_boolean" id="GNb23rXp%:TH#[+Ei%0R">
                      </shadow>
                      <block type="variables_get" id="XdWrR{2487^Hmp(d#fnp">
                      </block>
                    </value>
                      <shadow type="math_number" id="0T#7657D7!!=RzNUH$?Q">
                      </shadow>
                    </value>
                    <next>
                      <block type="procedures_callnoreturn" id="zN3/iL@Sk!,dVB]y-dxY">
                        <mutation name="Zäler 2"></mutation>
                        <next>
                          <block type="control_ex" id="*d#}$xJbq$*NQ}Z*z]Y=">
                            <value name="OID">
                              </shadow>
                              <block type="variables_get" id="/.XVCX]ts`NoE`zf]sqQ">
                              </block>
                            </value>
                              </shadow>
                              <block type="variables_get" id="YR~DL(T_PYi,0sjXqb2A">
                              </block>
                            </value>
                              <shadow type="math_number" id="DGu,_AjC*pk*?yL+!L%M">
                              </shadow>
                            </value>
                            <next>
                              <block type="procedures_callnoreturn" id=";A8s@MFG;#J+$;87q+CJ">
                                <mutation name="Zähler 3"></mutation>
                                <next>
                                  <block type="control_ex" id="i]_7rbMzL[Jr#Ob/+g*l">
                                    <value name="OID">
                                      </shadow>
                                      <block type="variables_get" id="+~=K{QOe?RSM$WW8@oa;">
                                      </block>
                                    </value>
                                      </shadow>
                                      <block type="variables_get" id="{ZLxI:afR~h[g3$m.^uo">
                                      </block>
                                    </value>
                                      <shadow type="math_number" id="d.R}./w33cfih,6J^X#N">
                                      </shadow>
                                    </value>
                                    <next>
                                      <block type="procedures_callnoreturn" id="I03+5+nkS|HqC}HpWeSd">
                                        <mutation name="Zähler 4"></mutation>
                                        <next>
                                          <block type="control_ex" id="QxVC@.lPCD,[@U(i_Ol5">
                                            <value name="OID">
                                              </shadow>
                                              <block type="variables_get" id="6@b%b0QPXuOViF[#2V|r">
                                              </block>
                                            </value>
                                              </shadow>
                                              <block type="variables_get" id="yyMO*6uJ)CIRX]pxs|tJ">
                                              </block>
                                            </value>
                                              <shadow type="math_number" id="xnZ^F/+FsiqB[9Y?jt(X">
                                              </shadow>
                                            </value>
                                            <next>
                                              <block type="procedures_callnoreturn" id="58dq[/;:HPgkwU`[!GUa">
                                                <mutation name="Zähler 5"></mutation>
                                                <next>
                                                  <block type="control_ex" id="x/ERJqZpB+WhlQ)eVG2*">
                                                    <value name="OID">
                                                      </shadow>
                                                      <block type="variables_get" id="{:S+r`2G8ADQGYabqVc$">
                                                      </block>
                                                    </value>
                                                      </shadow>
                                                      <block type="variables_get" id="D:|xE2OBc4u4Po9Ydk86">
                                                      </block>
                                                    </value>
                                                      <shadow type="math_number" id="[J1[:]9zv5de$`a*cu][">
                                                      </shadow>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="procedures_defnoreturn" id="~-JVqzzPa4TW+}sWh`C]" x="1663" y="913">
        <field name="NAME">ab zwei größer</field>
          <block type="debug" id="u}kGgz-D};)h46#}~.f@">
            <value name="TEXT">
              <shadow type="text" id="OOV.Ji7eM:]A`E7e]bN-">
                <field name="TEXT">ab zwei größer</field>
              </shadow>
            </value>
            <next>
              <block type="variables_set" id="9/-G0${(Yn/Q)g}o]pZf">
                <field name="VAR" id="jz(WYo2RH^XV%P$8`cAz">rest ab 2te</field>
                  <block type="math_arithmetic" id="WOzb$L1X4!YU?@NyJBMz" inline="false">
                    <value name="A">
                      <shadow type="math_number" id="_QD]%tR$[VL*Y5Ur_q:*">
                      </shadow>
                      <block type="get_value" id="bSc=@MN#*E5q4.l9M#WK">
                      </block>
                    </value>
                    <value name="B">
                      <shadow type="math_number" id="cB!wj5WEYUajeu4Z9#@T">
                      </shadow>
                      <block type="variables_get" id="~9T)JdF}/5/!s$@H3$KW">
                        <field name="VAR" id="9Xtnev|xAV30$qnZw.?W">Wert_1ste</field>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="procedures_callnoreturn" id="1zvu~nE,Zg#%Ey,eO/+x">
                    <next>
                      <block type="control_ex" id="m;+`{oR{plbdmMhJ{,qn">
                        <value name="OID">
                          </shadow>
                          <block type="variables_get" id="eUJoC`n{{7wph!KNq*W,">
                          </block>
                        </value>
    Marco WilliM 1 Antwort Letzte Antwort
    • Marco WilliM Marco Willi
        <variables>
        </variables>
          </mutation>
        </block>
                  <value name="PATH">
                    </shadow>
                  </value>
                        </block>
                      </value>
                      <value name="AT">
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
              <next>
                      <value name="PATH">
                        </shadow>
                      </value>
                            </block>
                          </value>
                          <value name="AT">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                          <value name="ADD0">
                            </block>
                          </value>
                          <value name="ADD1">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
          <next>
              <next>
                  <next>
                      <next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
                </block>
              </value>
              <next>
                    </block>
                  </value>
                  <next>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                              <next>
                                      <value name="A">
                                        </shadow>
                                          <value name="A">
                                            </shadow>
                                            </block>
                                          </value>
                                          <value name="B">
                                            </shadow>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                        </shadow>
                                          <value name="A">
                                            </shadow>
                                            </block>
                                          </value>
                                          <value name="B">
                                            </shadow>
                                              <value name="A">
                                                </shadow>
                                                </block>
                                              </value>
                                              <value name="B">
                                                </shadow>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <next>
                                          <value name="A">
                                            </shadow>
                                            </block>
                                          </value>
                                          <value name="B">
                                            </shadow>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                              <value name="ADD0">
                                                  </mutation>
                                                  <value name="ARG0">
                                                    </block>
                                                  </value>
                                                  <value name="ARG1">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                  </mutation>
                                                  <value name="ARG0">
                                                    </block>
                                                  </value>
                                                  <value name="ARG1">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                  </mutation>
                                                  <value name="ARG0">
                                                    </block>
                                                  </value>
                                                  <value name="ARG1">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD3">
                                                  </mutation>
                                                  <value name="ARG0">
                                                    </block>
                                                  </value>
                                                  <value name="ARG1">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="ADD4">
                                                  </mutation>
                                                  <value name="ARG0">
                                                    </block>
                                                  </value>
                                                  <value name="ARG1">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                                    </shadow>
                                                  </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                  <value name="TEXT">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                  <next>
                                                      <value name="TEXT">
                                                        </shadow>
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                            </block>
                                                          </value>
                                                          <value name="ADD3">
                                                            </block>
                                                          </value>
                                                          <value name="ADD4">
                                                            </block>
                                                          </value>
                                                          <value name="ADD5">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                          <value name="TEXT">
                                                            </shadow>
                                                            </block>
                                                          </value>
                                                          <next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
                  <value name="PATH">
                    </shadow>
                  </value>
                        </block>
                      </value>
                      <value name="AT">
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
              <next>
                      <value name="PATH">
                        </shadow>
                      </value>
                            </block>
                          </value>
                          <value name="AT">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                          <value name="ADD0">
                            </block>
                          </value>
                          <value name="ADD1">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
          <next>
              <next>
                  <next>
                      <next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
                  <value name="PATH">
                    </shadow>
                  </value>
                        </block>
                      </value>
                      <value name="AT">
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
              <next>
                      <value name="PATH">
                        </shadow>
                      </value>
                            </block>
                          </value>
                          <value name="AT">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                          <value name="ADD0">
                            </block>
                          </value>
                          <value name="ADD1">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
                  <value name="PATH">
                    </shadow>
                  </value>
                        </block>
                      </value>
                      <value name="AT">
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
              <next>
                      <value name="PATH">
                        </shadow>
                      </value>
                            </block>
                          </value>
                          <value name="AT">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                          <value name="ADD0">
                            </block>
                          </value>
                          <value name="ADD1">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
                  <value name="PATH">
                    </shadow>
                  </value>
                        </block>
                      </value>
                      <value name="AT">
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
              <next>
                      <value name="PATH">
                        </shadow>
                      </value>
                            </block>
                          </value>
                          <value name="AT">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                          <value name="ADD0">
                            </block>
                          </value>
                          <value name="ADD1">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
              <value name="TEXT">
                </shadow>
              </value>
              <next>
                  <next>
                      <value name="OID">
                        </shadow>
                        </block>
                      </value>
                        </shadow>
                        </block>
                      </value>
                        </shadow>
                      </value>
                      <next>
                          <next>
                              <value name="OID">
                                </shadow>
                                </block>
                              </value>
                                </shadow>
                                </block>
                              </value>
                                </shadow>
                              </value>
                              <next>
                                  <next>
                                      <value name="OID">
                                        </shadow>
                                        </block>
                                      </value>
                                        </shadow>
                                        </block>
                                      </value>
                                        </shadow>
                                      </value>
                                      <next>
                                          <next>
                                              <value name="OID">
                                                </shadow>
                                                </block>
                                              </value>
                                                </shadow>
                                                </block>
                                              </value>
                                                </shadow>
                                              </value>
                                              <next>
                                                  <next>
                                                      <value name="OID">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
              <value name="TEXT">
                </shadow>
              </value>
              <next>
                      <value name="A">
                        </shadow>
                        </block>
                      </value>
                      <value name="B">
                        </shadow>
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                      <next>
                          <value name="OID">
                            </shadow>
                            </block>
                          </value>
      Marco Willi
      @marco-willi
      und
       </shadow>
                            <block type="math_arithmetic" id="qS8-`m%kL-BS_{Q2$d%^">
                              <value name="A">
                                <shadow type="math_number" id="t;3gR;seZYShH)$?{I=(">
                                </shadow>
                                <block type="variables_get" id="tEBykc|yB%.JasIM1id(">
                                </block>
                              </value>
                              <value name="B">
                                <shadow type="math_number" id="(6YQIxRIxo;-:~k.]]}V">
                                </shadow>
                              </value>
                            </block>
                          </value>
                            <shadow type="math_number" id="Jr3H*+D`!A(g#N.4o`p9">
                            </shadow>
                          </value>
                          <next>
                            <block type="procedures_callnoreturn" id=".=D}24*e?jEo6]ntW*hB">
                              <next>
                                <block type="control_ex" id="N:#8psGnspPq@L~G|XNT">
                                  <value name="OID">
                                    </shadow>
                                    <block type="variables_get" id="`j[JJ|iWrIi8~phxMFXk">
                                    </block>
                                  </value>
                                    <shadow type="logic_boolean" id="QiQ@@z:u`NM(egOfeIh4">
                                    </shadow>
                                    <block type="math_arithmetic" id="kqio3Ce1PUD7`xKm19uF">
                                      <value name="A">
                                        </shadow>
                                        <block type="variables_get" id="vsZwm@s+UDaN;LKzDd!b">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <shadow type="math_number" id="!=zcja1xu{qX2j!kW,CD">
                                        </shadow>
                                      </value>
                                    </block>
                                  </value>
                                    <shadow type="math_number" id="BQPrBYQ$u$n?;Giox3la">
                                    </shadow>
                                  </value>
                                  <next>
                                    <block type="procedures_callnoreturn" id="K;+O{1HIR1a9LZNzD_f0">
                                      <next>
                                        <block type="control_ex" id="/@RP1:A:JBftuL}I^pfD">
                                          <value name="OID">
                                            </shadow>
                                            <block type="variables_get" id="VCjDZaDH3iR`AiLVA5.k">
                                            </block>
                                          </value>
                                            </shadow>
                                            <block type="math_arithmetic" id="w+42-(~6JE?L~+U-)dpF">
                                              <value name="A">
                                                </shadow>
                                                <block type="variables_get" id=",`*GlnZ[t83%JY.4SjLH">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <shadow type="math_number" id="zl+My.KSe9`#(3|WbESd">
                                                </shadow>
                                              </value>
                                            </block>
                                          </value>
                                            <shadow type="math_number" id="y_c`ED:NG3dA_I]1ujPN">
                                            </shadow>
                                          </value>
                                          <next>
                                            <block type="procedures_callnoreturn" id="HX-#6oA_Gb34]7NOYuS)">
                                              <next>
                                                <block type="control_ex" id="1FGN,uqM.P-j$`|7tp)1">
                                                  <value name="OID">
                                                    </shadow>
                                                    <block type="variables_get" id="f@6BhD?}[s~.7J$!?s-i">
                                                    </block>
                                                  </value>
                                                    </shadow>
                                                    <block type="math_arithmetic" id="(v*`[/ic_8+x~0Fqa,Rl">
                                                      <value name="A">
                                                        </shadow>
                                                        <block type="variables_get" id="F4fJGg!VkTE-$L|.(!$u">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <shadow type="math_number" id="?VDn_e0{wlEfB^c8@a3|">
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </value>
                                                    <shadow type="math_number" id="~ta2os!r@srSP2y*$lX:">
                                                    </shadow>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
        <block type="procedures_defnoreturn" id="slt*~3~O;KsF-HT_T4#Z" x="2238" y="913">
          <field name="NAME">ab drei größer</field>
            <block type="debug" id="cOYvs:s1`!5aoSF2DA,G">
              <value name="TEXT">
                <shadow type="text" id="y0V%-XaN70{KCIlq8PPA">
                  <field name="TEXT">ab drei größer</field>
                </shadow>
              </value>
              <next>
                <block type="variables_set" id="Hzqf1Y,|dB=o~=%yF3L5">
                    <block type="math_arithmetic" id="i#6z%!/.05`NfS]yV#%A" inline="false">
                      <value name="A">
                        </shadow>
                        <block type="get_value" id="0b[3R-;:BH[RYMoWTMvD">
                        </block>
                      </value>
                      <value name="B">
                        </shadow>
                        <block type="variables_get" id="b(^T33.zC?Ah+@^$|VUY">
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                    <block type="procedures_callnoreturn" id="@nj,{ht`M`pT48FA;_.o">
                      <next>
                        <block type="control_ex" id="YE#Lv(M9J8NeI?VhJhFS">
                          <value name="OID">
                            </shadow>
                            <block type="variables_get" id="UWeB3cG%Hau2*J[EqDLn">
                            </block>
                          </value>
                            </shadow>
                            <block type="math_arithmetic" id=":t]9{@:9sAph!1uy1oWO">
                              <value name="A">
                                </shadow>
                                <block type="variables_get" id="7;;MQk@[so1Cu4V}1=Xb">
                                </block>
                              </value>
                              <value name="B">
                                <shadow type="math_number" id="iR(0Uf-2M93!T3vbaCDz">
                                </shadow>
                              </value>
                            </block>
                          </value>
                            <shadow type="math_number" id="+E/I(NQX0)dxMk2ytV`L">
                            </shadow>
                          </value>
                          <next>
                            <block type="procedures_callnoreturn" id="3[z|XEb[vTuRC488g]9b">
                              <next>
                                <block type="control_ex" id="OA5KJWr;]OChy)-TQVy1">
                                  <value name="OID">
                                    </shadow>
                                    <block type="variables_get" id="zL8a[^|Q1X09r3r.j|Nu">
                                    </block>
                                  </value>
                                    </shadow>
                                    <block type="math_arithmetic" id="JxGJV@P~G/p0mhYmd*U,">
                                      <value name="A">
                                        </shadow>
                                        <block type="variables_get" id="46H4tYW9tIpa?n.w[enU">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <shadow type="math_number" id="VP6`B+oQ4/4;a0SjE@Kd">
                                        </shadow>
                                      </value>
                                    </block>
                                  </value>
                                    <shadow type="math_number" id="CH]6?F)tC7+ycsTHeqt$">
                                    </shadow>
                                  </value>
                                  <next>
                                    <block type="procedures_callnoreturn" id="WDHML%rd0Ur[)r=D_I%w">
                                      <next>
                                        <block type="control_ex" id="cP5jBjOo7s5I2f`4=0jB">
                                          <value name="OID">
                                            </shadow>
                                            <block type="variables_get" id="C=:xCgU`ZQ{D{Z=wRldB">
                                            </block>
                                          </value>
                                            </shadow>
                                            <block type="math_arithmetic" id="gx#m,5{Z@W2baSAym@vw">
                                              <value name="A">
                                                </shadow>
                                                <block type="variables_get" id="$t1el%+2r;eDLS4@6:fh">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <shadow type="math_number" id="gLxH@r?in`b}8FVCve=S">
                                                </shadow>
                                              </value>
                                            </block>
                                          </value>
                                            <shadow type="math_number" id="f8WQ^|wiqZ9)%h.mX^`z">
                                            </shadow>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
        <block type="procedures_defnoreturn" id="D/2|B_#},fyC(n0w#2Xl" x="2813" y="888">
          <field name="NAME">ab vier grösser</field>
            <block type="debug" id="B(F;gN6Jk~snn%K%MP;/">
              <value name="TEXT">
                <shadow type="text" id="28u$%3HRWml/27^1N0$s">
                </shadow>
              </value>
              <next>
                <block type="variables_set" id="L.OQ`?]Uzp]*kF^3oKF#">
                    <block type="math_arithmetic" id="+KDSmxg!euC}#LvM2.Sw" inline="false">
                      <value name="A">
                        </shadow>
                        <block type="get_value" id="W|KAgVFFg^iTNXi^HVAq">
                        </block>
                      </value>
                      <value name="B">
                        </shadow>
                        <block type="variables_get" id="Pv!ui_8#Z4#UuGllt{|0">
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                    <block type="procedures_callnoreturn" id="`U|K],V-9$W/=u?Hp]){">
                      <next>
                        <block type="control_ex" id="EL,D|Q%2xrk[,O}jl1Bi">
                          <value name="OID">
                            </shadow>
                            <block type="variables_get" id="rOF5;=)4J|.D5g@L8|F-">
                            </block>
                          </value>
                            </shadow>
                            <block type="math_arithmetic" id="a*cmy96u$Oo[dzBUytB}">
                              <value name="A">
                                </shadow>
                                <block type="variables_get" id=")(pypYk?K88$Sa5b*2~/">
                                </block>
                              </value>
                              <value name="B">
                                <shadow type="math_number" id="*[,*-e*V:ffuG+G.zY:/">
                                </shadow>
                              </value>
                            </block>
                          </value>
                            <shadow type="math_number" id="/TDajhA#Cp9VP/3NBj_h">
                            </shadow>
                          </value>
                          <next>
                            <block type="procedures_callnoreturn" id="{E6%-}RV6NKGXRWt/;B?">
                              <next>
                                <block type="control_ex" id="ElA7rM]e4R/CwrQhlPsC">
                                  <value name="OID">
                                    </shadow>
                                    <block type="variables_get" id="V36T;1`B5SZF]!S/2mv=">
                                    </block>
                                  </value>
                                    </shadow>
                                    <block type="math_arithmetic" id="](Ou;DCR{T=sf6cI*Y!=">
                                      <value name="A">
                                        </shadow>
                                        <block type="variables_get" id="Yd-bN,aMlG+uK@niZrK]">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <shadow type="math_number" id="yO_=r@+CRARI$2A;bM+R">
                                        </shadow>
                                      </value>
                                    </block>
                                  </value>
                                    <shadow type="math_number" id="/yQKPlP`}}Dc1yM%!ens">
                                    </shadow>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
        <block type="procedures_defnoreturn" id="d|Gva)g{7[re]h!LJ.6i" x="3413" y="888">
          <field name="NAME">5t grösster</field>
            <block type="debug" id="d+x4guefo1qTrA[l_+E+">
              <value name="TEXT">
                <shadow type="text" id="$`|v9;CJj%Gr-._mc!.v">
                  <field name="TEXT">ab vier größer</field>
                </shadow>
              </value>
              <next>
                <block type="variables_set" id="^bh^[0K9FuO1ymr#]TP-">
                  <field name="VAR" id="$0Z58`kKviMG[zyjoa$3">rest ab 3te</field>
                    <block type="math_arithmetic" id="@C=m5OrxI,Ng5N-A%a6Y" inline="false">
                      <value name="A">
                        <shadow type="math_number" id="k53?o}|~Xo*;h$Kzc-Aa">
                        </shadow>
                        <block type="math_arithmetic" id="=hc:h;Y3/ON6D$Y)VYQ9" inline="false">
                          <value name="A">
                            </shadow>
                            <block type="get_value" id="9kH$MC@W$k}NVEJuJ}:1">
                            </block>
                          </value>
                          <value name="B">
                            </shadow>
                            <block type="variables_get" id=".3gGgQvPMhm($TLuS9pI">
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        <shadow type="math_number" id="8${![]vD+}ZV$-sOq_yD">
                        </shadow>
                        <block type="variables_get" id="+#1Z_sQn1}M_XKY^k]W5">
                          <field name="VAR" id="s}`NhkS#bbbkKnhEvlh}">Wert_2te</field>
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                    <block type="procedures_callnoreturn" id="]idLN9fk5-2Te]Rvn5DI">
                      <next>
                        <block type="control_ex" id="A{;1vnc=ZB[%,:pwFo#;">
                          <value name="OID">
                            </shadow>
                            <block type="variables_get" id="DO]$F^%eZX;KudD*qS|H">
                            </block>
                          </value>
                            </shadow>
                            <block type="variables_get" id="y3*XTCJiu3WoIx8%RW9I">
                            </block>
                          </value>
                            <shadow type="math_number" id=",CX_deI=EbT#KpT{-v:Q">
                            </shadow>
                          </value>
                          <next>
                            <block type="debug" id="K5%YWyL%PE~z.?}-qk4L">
                              <value name="TEXT">
                                <shadow type="text" id=")S:;(%B7Apz;bm{FkRzd">
                                  <field name="TEXT">Verbrauch von dritt größtem ist größer 1/3 der Erzeugung, also bekommt er den Rest</field>
                                </shadow>
                                <block type="text_join" id="9YFNC#1Zq{=[|JU0vbNi">
                                  <value name="ADD0">
                                    <block type="text" id="xjHn5X}ds4lbahny(s5o">
                                      <field name="TEXT">Verbrauch von dritt größtem ist größer 1/5 der Erzeugung, also bekommt er den Rest: </field>
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                    <block type="variables_get" id="pLj)!.!)_1mOkaPICcrM">
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    <block type="text" id="D:$Lp]{})0UlgzeA*`hD">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
        <block type="procedures_defnoreturn" id=")k!Yb1JbF165;uCP,x`;" x="163" y="1263">
          <field name="NAME">1ste</field>
            <block type="procedures_callnoreturn" id="9c]$)pQ4#U2`J|$j;I6:">
              <next>
                <block type="controls_if" id="pSSk+SN3-J}tg`UT61cE">
                  <value name="IF0">
                    <block type="logic_compare" id="3djY6~,xmE%u}X|#|`!/">
                      <field name="OP">LT</field>
                      <value name="A">
                        <block type="get_attr" id="]0LWJ@8c61*Zw@(@7}u3">
                          <value name="PATH">
                            <shadow type="text" id="(doN?Z,@[F3Lkj~SHP0F">
                            </shadow>
                          </value>
                            <block type="lists_getIndex" id="WB=W907+2M.b`Cd@P;^d">
                                <block type="variables_get" id="Zb:LQ:Ai9Y}Ged[wE31V">
                                </block>
                              </value>
                              <value name="AT">
                                <block type="math_number" id="os+(^|`JWLS}?O2GO8-n">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        <block type="variables_get" id="qz6m*K3Ns.ZUMvA7XOX-">
                        </block>
                      </value>
                    </block>
                  </value>
                    <block type="debug" id="b6a(o@L_.=2z?hp.bK_9">
                      <value name="TEXT">
                        <shadow type="text" id="cr_1YE1irZ,/xW[`~=.c">
                          <field name="TEXT">kleinster verbraucher ist kleiner 1/3 der Erzeugung</field>
                        </shadow>
                        <block type="text_join" id="q%/|J:Xy)MFrgN2{U_;(">
                          <value name="ADD0">
                            <block type="text" id="r,%smyMyAx70%KtwU=9!">
                              <field name="TEXT">kleinster verbraucher ist kleiner 1/5 der Erzeugung: </field>
                            </block>
                          </value>
                          <value name="ADD1">
                            <block type="variables_get" id=";O~|pj#@UoY8jB0GQU[0">
                            </block>
                          </value>
                          <value name="ADD2">
                            <block type="text" id=")ItEm@`67fVhH[J))jCZ">
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                        <block type="control_ex" id="/aCTQ;VR,.J/6ToFUxNF">
                          <value name="OID">
                            </shadow>
                            <block type="variables_get" id="1dey5%:ixM/9ej+[(!.]">
                            </block>
                          </value>
                            </shadow>
                            <block type="variables_get" id="-9gL|pbx@y,GUyJR}fEd">
                            </block>
                          </value>
                            <shadow type="math_number" id="#G?h(Fg4Z[aeS9XjSg6/">
                            </shadow>
                          </value>
                          <next>
                            <block type="variables_set" id="a{ESioPh#Z*]wpdnZ5JM">
                                <block type="variables_get" id="UYd5+Z6%yoW4z;AYNkM7">
                                </block>
                              </value>
                              <next>
                                <block type="procedures_callnoreturn" id="wIj#}:?:4-U/VThhgS`h">
                                  <mutation name="2te"></mutation>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <statement name="ELSE">
                    <block type="debug" id="MGli|aXhwAi7;s?CZBLi">
                      <value name="TEXT">
                        <shadow type="text" id="ycpHX8wE6|7%aEwCwTZx">
                          <field name="TEXT">kleinste Verbrauch ist größer 1/5 der Erzeugung, also sind alle größer als erzeugung</field>
                        </shadow>
                      </value>
                      <next>
                        <block type="procedures_callnoreturn" id="Jx[=oj27K+U]mmral~Vf">
                          <mutation name="Alles größer"></mutation>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </statement>
        </block>
        <block type="procedures_defnoreturn" id="*?[M|k2McK]{f@,:mvs0" x="163" y="1838">
          <field name="NAME">2te</field>
            <block type="procedures_callnoreturn" id="rXJc?v~a0i1hWO9SSa$s">
              <next>
                <block type="controls_if" id="ZK[Mm#3C)8[kH7}fB3=,">
                  <value name="IF0">
                    <block type="logic_compare" id="Y|FEm6t5SE,wo1/=~*N)">
                      <value name="A">
                        <block type="get_attr" id="W$V})SfDIQlx?^9C]HHI">
                          <value name="PATH">
                            <shadow type="text" id="/fSp%8JldFG)S~++Y:bz">
                            </shadow>
                          </value>
                            <block type="lists_getIndex" id="{)=2e+[A4`rG(Gb%h!$*">
                                <block type="variables_get" id="g4~P}65ZKW7h#P-NZ,{I">
                                </block>
                              </value>
                              <value name="AT">
                                <block type="math_number" id="Xd!e_ASb[p^xThoTjN/%">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        <block type="variables_get" id="Zmp^lj[__yltUH]tFRFP">
                        </block>
                      </value>
                    </block>
                  </value>
                    <block type="debug" id="-?PxgJM]uIcamg8U(^0C">
                      <value name="TEXT">
                        <shadow type="text" id="vmF:GDm%7ufKil(UFYcT">
                          <field name="TEXT">Verbrauch von zweit größtem ist kleiner 1/3 der Erzeugung</field>
                        </shadow>
                        <block type="text_join" id="Sv:Df6KaS0hL)XFdcg0{">
                          <value name="ADD0">
                            <block type="text" id="5.NNIi=T:k2X0[3uNsD=">
                              <field name="TEXT">Verbrauch von zweit größtem ist kleiner 1/5 der Erzeugung: </field>
                            </block>
                          </value>
                          <value name="ADD1">
                            <block type="variables_get" id="O]FXSn33*9JlkfKq`Q2U">
                            </block>
                          </value>
                          <value name="ADD2">
                            <block type="text" id="tP~JK]Y}EpF[]I0G7J[W">
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                        <block type="control_ex" id="f=LP:~8fj#)[VTYt}c?S">
                          <value name="OID">
                            </shadow>
                            <block type="variables_get" id="Ie{Z^Yts0v^7rq4]a`/a">
                            </block>
                          </value>
                            </shadow>
                            <block type="variables_get" id="X^/4{?Ib97KV?gcf$%}4">
                            </block>
                          </value>
                            <shadow type="math_number" id="D[gD#[U6~S6dek:X7ZSc">
                            </shadow>
                          </value>
                          <next>
                            <block type="variables_set" id="7u2P$(Q=sU?FR6o_`c9K">
                                <block type="variables_get" id="J5sS;hP6WDy34W529dST">
                                </block>
                              </value>
                              <next>
                                <block type="procedures_callnoreturn" id="b!p[QTn|PO_1q!gKx`:Z">
                                  <mutation name="3te"></mutation>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                    <block type="debug" id="^I%]x%9OBKRt*M.I%$S{">
                      <value name="TEXT">
                        <shadow type="text" id="Sv9IVn$8U=*{K{~P91lR">
                          <field name="TEXT">Verbrauch von zweit größtem ist größer 1/5 der Erzeugung, also alle weiteren auch</field>
                        </shadow>
                      </value>
                      <next>
                        <block type="procedures_callnoreturn" id="djbAtLt]+qcjG_A|LG}L">
                          <mutation name="ab zwei größer"></mutation>
                          <next>
                            <block type="variables_set" id="5-demYd$NUunsdnMG`DR">
                                <block type="variables_get" id="[pUW+s+d:cy{W:2~,26%">
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </statement>
        </block>
        <block type="procedures_defnoreturn" id="O=vz(qcihs2+iVH`akUa" x="163" y="2438">
          <field name="NAME">3te</field>
            <block type="procedures_callnoreturn" id=":4%{5$1|32/cT[AO@WKq">
              <next>
                <block type="controls_if" id="D{s}JF~Ltg:-nmyDMcJ#">
                  <value name="IF0">
                    <block type="logic_compare" id="u)_Wm3yHx]4`/[VS[HIm">
                      <value name="A">
                        <block type="get_attr" id="D6AAZE$3`;xx{}xKXT_n">
                          <value name="PATH">
                            <shadow type="text" id="MKfmff9vg]a0gvhvl(m1">
                            </shadow>
                          </value>
                            <block type="lists_getIndex" id="{!yp]dtZcAHuw$A;~J8B">
                                <block type="variables_get" id="*f[WW_o7C0z=SL*bRMKI">
                                </block>
                              </value>
                              <value name="AT">
                                <block type="math_number" id="?}de8mBG,sLQqG#cj}$G">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        <block type="variables_get" id="Ib5O$!%zQJ#8D,u9CKe,">
                        </block>
                      </value>
                    </block>
                  </value>
                    <block type="debug" id="~8+_d|~bw2YlJmNQ.Eq3">
                      <value name="TEXT">
                        <shadow type="text" id="(q[8(@oPyCzimm/KM*t?">
                          <field name="TEXT">Verbrauch von dritt größtem ist kleiner 1/3 der Erzeugung, also bekommt jeder 1/3 der erzeugung</field>
                        </shadow>
                        <block type="text_join" id="a5{^v-RO~dzUceY#x[kC">
                          <value name="ADD0">
                            <block type="text" id="]?b,fGRC6-)5K,cphLPo">
                              <field name="TEXT">Verbrauch von dritt größtem ist kleiner 1/5 der Erzeugung, also bekommt jeder 1/3 der erzeugung: </field>
                            </block>
                          </value>
                          <value name="ADD1">
                            <block type="variables_get" id="b*hCl#Mq#RfVvE7zUE]v">
                            </block>
                          </value>
                          <value name="ADD2">
                            <block type="text" id="eHmQ-$~SM^6BL]p26ep$">
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                        <block type="control_ex" id="4mcok9njHDSZ+8yL=Xp2">
                          <value name="OID">
                            </shadow>
                            <block type="variables_get" id="]@na!y}BG~sYKNA3q2lZ">
                            </block>
                          </value>
                            </shadow>
                            <block type="variables_get" id="g!EnU=YPke@bm!QneQdE">
                            </block>
                          </value>
                            <shadow type="math_number" id="%j59`B.Jr$34c=U),rtX">
                            </shadow>
                          </value>
                          <next>
                            <block type="variables_set" id="`Qi6l.*?MO=!t*eGeo5@">
                              <field name="VAR" id=";UV.oZ3B2@*-Y0JW8g|U">Wert_3te</field>
                                <block type="variables_get" id="VaLW20b?t6|i8qAaGMd-">
                                </block>
                              </value>
                              <next>
                                <block type="procedures_callnoreturn" id="D771Fum89TO4XiFC:n$)">
                                  <mutation name="4te"></mutation>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                    <block type="debug" id="2*+i|`nj_a,(r_jtCyz_">
                      <value name="TEXT">
                        <shadow type="text" id="[o~-R`_@,dn~K*O::`-.">
                          <field name="TEXT">Verbrauch vom dritt größtem ist größer 1/5 der Erzeugung, also alle weiteren auch</field>
                        </shadow>
                      </value>
                      <next>
                        <block type="procedures_callnoreturn" id=")uLKJbJs6-jxIzaxTnTX">
                          <mutation name="ab drei größer"></mutation>
                          <next>
                            <block type="variables_set" id="KlHM457qfI9rs~G6_1`k">
                                <block type="variables_get" id="H@5~WSBF+y1)zk0R*fP1">
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </statement>
        </block>
        <block type="procedures_defnoreturn" id="l|y)O@@Ui!T!ha0};SYX" x="163" y="3063">
          <field name="NAME">4te</field>
            <block type="procedures_callnoreturn" id="67HI8.5F9CAB/}-sOH#T">
              <next>
                <block type="controls_if" id="]C|#9Ge$zO?U,G8yhJMx">
                  <value name="IF0">
                    <block type="logic_compare" id="qrQCPHhNBMf[E^$9gyz[">
                      <value name="A">
                        <block type="get_attr" id="-1~z@sg``RSEu-A..dOG">
                          <value name="PATH">
                            <shadow type="text" id="fU_N45UM-Bgh@ZU$c*]y">
                            </shadow>
                          </value>
                            <block type="lists_getIndex" id="/R,TVrCS@$6c=]:aQa][">
                                <block type="variables_get" id="af1nHfpN6(_wkiUr(%xF">
                                </block>
                              </value>
                              <value name="AT">
                                <block type="math_number" id="Bjpb96j*T4_se^ifIv6{">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        <block type="variables_get" id="PS9cR{MgA0DWSH2S01qs">
                        </block>
                      </value>
                    </block>
                  </value>
                    <block type="debug" id="{X-tB)GAoAp:axuBE0;g">
                      <value name="TEXT">
                        </shadow>
                        <block type="text_join" id="D4=RJ|3%:6[-~#6{fZVk">
                          <value name="ADD0">
                            <block type="text" id="E}4*saujr#E/ziv0n_%D">
                              <field name="TEXT">Verbrauch von viert größtem ist kleiner 1/5 der Erzeugung, also bekommt jeder 1/3 der erzeugung: </field>
                            </block>
                          </value>
                          <value name="ADD1">
                            <block type="variables_get" id="]5np8X~/[n#Kt*]1I.(l">
                            </block>
                          </value>
                          <value name="ADD2">
                            <block type="text" id="8$Q4b@.KNZqo/;n#J;;3">
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                        <block type="control_ex" id="eM?cpr:-izS~~U,yzi4p">
                          <value name="OID">
                            </shadow>
                            <block type="variables_get" id="W0BhKryj0ib.|m%NvII2">
                            </block>
                          </value>
                            </shadow>
                            <block type="variables_get" id="|d1X-d|I]f=9dos]ZPa[">
                            </block>
                          </value>
                            <shadow type="math_number" id="p9:E~goGpA:r-ALIBtC`">
                            </shadow>
                          </value>
                          <next>
                            <block type="variables_set" id=")[15ePYPJoZ%S_D{by!D">
                              <field name="VAR" id="1F^o@YN[2g~LM-V]o$b!">Wert_4te</field>
                                <block type="variables_get" id="a^$K$.GgHt~c|:%$=1%#">
                                </block>
                              </value>
                              <next>
                                <block type="procedures_callnoreturn" id=",8;cE3Hi{WS+f6)rCMP*">
                                  <mutation name="5te"></mutation>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                    <block type="debug" id="zOoWrQ,Wc17^q?9SQ~bg">
                      <value name="TEXT">
                        <shadow type="text" id=";]r$n^.JDeim$kQ[lVe-">
                          <field name="TEXT">Verbrauch von viert größtem ist größer 1/5 der Erzeugung, also alle weiteren auch</field>
                        </shadow>
                      </value>
                      <next>
                        <block type="variables_set" id="Q*`U^L$!MggZx%f8,1rd">
                            <block type="variables_get" id="^1S8hormOvff#(`~~k#(">
                            </block>
                          </value>
                          <next>
                            <block type="procedures_callnoreturn" id=";Y)B?4{sth`HynMnXr)E">
                              <mutation name="ab vier grösser"></mutation>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </statement>
        </block>
        <block type="procedures_defnoreturn" id="4NvFzS{_qs6}=cL~_46O" x="163" y="3663">
          <field name="NAME">5te</field>
            <block type="procedures_callnoreturn" id="(gn:f8LSnRnlh#$33t0q">
              <next>
                <block type="controls_if" id="h4)a]Q_/RqVU:7sN[*CD">
                  <value name="IF0">
                    <block type="logic_compare" id="o+k9}40Osd^jJC#%9}%V">
                      <value name="A">
                        <block type="get_attr" id="gh/hY^tQX`.j]8b@M!%W">
                          <value name="PATH">
                            <shadow type="text" id="9)9gi;}yeIsGyP%38AY+">
                            </shadow>
                          </value>
                            <block type="lists_getIndex" id="c]cI5(rnhJ*#Eel_!I%g">
                                <block type="variables_get" id="2+.D@.Em!q;@1|5n6ZZ-">
                                </block>
                              </value>
                              <value name="AT">
                                <block type="math_number" id="JUD_[Ob9S0SMH!OlYUU*">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                        <block type="variables_get" id="?_yv4xk$pWh(loE*/5uh">
                        </block>
                      </value>
                    </block>
                  </value>
                    <block type="debug" id="xv]9aFT;/e(QLcqtb%1M">
                      <value name="TEXT">
                        </shadow>
                        <block type="text_join" id="{qeuFy.@c;NqQ8[@R]=a">
                          <value name="ADD0">
                            <block type="text" id="ou;vOehDWy-:5EWK]nZ0">
                              <field name="TEXT">Verbrauch von fünft größtem ist kleiner 1/5 der Erzeugung, also bekommt jeder 1/3 der erzeugung: </field>
                            </block>
                          </value>
                          <value name="ADD1">
                            <block type="variables_get" id=".tmb085.DNN7IsJ,mn!Z">
                            </block>
                          </value>
                          <value name="ADD2">
                            <block type="text" id="6gSiZ)ZVgO8nJx-?aTv9">
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                        <block type="control_ex" id="FNmi*1!2LQ(h3iPJeLuC">
                          <value name="OID">
                            </shadow>
                            <block type="variables_get" id="TfW||2?yl=1`[,FrQaNt">
                            </block>
                          </value>
                            </shadow>
                            <block type="variables_get" id="$)91PWz*IiR4E`T[Umq,">
                            </block>
                          </value>
                            <shadow type="math_number" id="T8%P~H:z*Z+2+lAT.xGw">
                            </shadow>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                    <block type="debug" id="v7Z3*PJ!u^mmuR.`1bP]">
                      <value name="TEXT">
                        <shadow type="text" id="Za2t)!4lo:7ee,IY9!vl">
                          <field name="TEXT">Verbrauch von fünft größtem ist größer 1/5 der Erzeugung, also alle weiteren auch</field>
                        </shadow>
                      </value>
                      <next>
                        <block type="variables_set" id="aQvJbeK*P,,^%9+CCZ:s">
                          <field name="VAR" id="LvJdi,HZcN8CJ5(TUGN?">Wert_5te</field>
                            <block type="variables_get" id="tB7HpKWpU4|qz7BY6U3u">
                            </block>
                          </value>
                          <next>
                            <block type="procedures_callnoreturn" id="y_!FeCID2XM/ZztZLOVF">
                              <mutation name="5t grösster"></mutation>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </statement>
        </block>
      </xml>
        @marco-willi
        und
         </shadow>
                                <value name="A">
                                  </shadow>
                                  </block>
                                </value>
                                <value name="B">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                              </shadow>
                            </value>
                            <next>
                                <next>
                                    <value name="OID">
                                      </shadow>
                                      </block>
                                    </value>
                                      </shadow>
                                        <value name="A">
                                          </shadow>
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                      </shadow>
                                    </value>
                                    <next>
                                        <next>
                                            <value name="OID">
                                              </shadow>
                                              </block>
                                            </value>
                                              </shadow>
                                                <value name="A">
                                                  </shadow>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                              </shadow>
                                            </value>
                                            <next>
                                                <next>
                                                    <value name="OID">
                                                      </shadow>
                                                      </block>
                                                    </value>
                                                      </shadow>
                                                        <value name="A">
                                                          </shadow>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                      </shadow>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
                <value name="TEXT">
                  </shadow>
                </value>
                <next>
                        <value name="A">
                          </shadow>
                          </block>
                        </value>
                        <value name="B">
                          </shadow>
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                        <next>
                            <value name="OID">
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                                <value name="A">
                                  </shadow>
                                  </block>
                                </value>
                                <value name="B">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                              </shadow>
                            </value>
                            <next>
                                <next>
                                    <value name="OID">
                                      </shadow>
                                      </block>
                                    </value>
                                      </shadow>
                                        <value name="A">
                                          </shadow>
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                      </shadow>
                                    </value>
                                    <next>
                                        <next>
                                            <value name="OID">
                                              </shadow>
                                              </block>
                                            </value>
                                            <value name="VALUE">
                                              </shadow>
                                                <value name="A">
                                                  </shadow>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                              </shadow>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
                <value name="TEXT">
                  </shadow>
                </value>
                <next>
                        <value name="A">
                          </shadow>
                          </block>
                        </value>
                        <value name="B">
                          </shadow>
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                        <next>
                            <value name="OID">
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                                <value name="A">
                                  </shadow>
                                  </block>
                                </value>
                                <value name="B">
                                  </shadow>
                                </value>
                              </block>
                            </value>
                                <field name="NUM">0</field>
                              </shadow>
                            </value>
                            <next>
                                <next>
                                    <value name="OID">
                                      </shadow>
                                      </block>
                                    </value>
                                      </shadow>
                                        <value name="A">
                                          </shadow>
                                          </block>
                                        </value>
                                        <value name="B">
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                      </shadow>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
                <value name="TEXT">
                  </shadow>
                </value>
                <next>
                        <value name="A">
                          </shadow>
                            <value name="A">
                              </shadow>
                              </block>
                            </value>
                            <value name="B">
                              </shadow>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          </shadow>
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                        <next>
                            <value name="OID">
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                            </value>
                            <next>
                                <value name="TEXT">
                                  </shadow>
                                    <value name="ADD0">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
                <next>
                    <value name="IF0">
                        <value name="A">
                            <value name="PATH">
                              </shadow>
                            </value>
                                  </block>
                                </value>
                                <value name="AT">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                        <value name="TEXT">
                          </shadow>
                            <value name="ADD0">
                              </block>
                            </value>
                            <value name="ADD1">
                              </block>
                            </value>
                            <value name="ADD2">
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                            <value name="OID">
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                            </value>
                            <next>
                                  </block>
                                </value>
                                <next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                        <value name="TEXT">
                          </shadow>
                        </value>
                        <next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
                <next>
                    <value name="IF0">
                        <value name="A">
                            <value name="PATH">
                              </shadow>
                            </value>
                                  </block>
                                </value>
                                <value name="AT">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                        <value name="TEXT">
                          </shadow>
                            <value name="ADD0">
                              </block>
                            </value>
                            <value name="ADD1">
                              </block>
                            </value>
                            <value name="ADD2">
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                            <value name="OID">
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                            </value>
                            <next>
                                  </block>
                                </value>
                                <next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                        <value name="TEXT">
                          </shadow>
                        </value>
                        <next>
                            <next>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
                <next>
                    <value name="IF0">
                        <value name="A">
                            <value name="PATH">
                              </shadow>
                            </value>
                            <value name="OBJECT">
                                <mutation statement="false" at="true"></mutation>
                                <field name="MODE">GET</field>
                                <field name="WHERE">FROM_START</field>
                                  </block>
                                </value>
                                <value name="AT">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                        <value name="TEXT">
                          </shadow>
                            <value name="ADD0">
                              </block>
                            </value>
                            <value name="ADD1">
                              </block>
                            </value>
                            <value name="ADD2">
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                            <value name="OID">
                                <field name="oid">Object ID</field>
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                            </value>
                            <next>
                                  </block>
                                </value>
                                <next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                        <value name="TEXT">
                          </shadow>
                        </value>
                        <next>
                            <next>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
                <next>
                    <value name="IF0">
                        <value name="A">
                            <value name="PATH">
                              </shadow>
                            </value>
                                  </block>
                                </value>
                                <value name="AT">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                        <value name="TEXT">
                          </shadow>
                            <value name="ADD0">
                              </block>
                            </value>
                            <value name="ADD1">
                              </block>
                            </value>
                            <value name="ADD2">
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                            <value name="OID">
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                            </value>
                            <next>
                                  </block>
                                </value>
                                <next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                        <value name="TEXT">
                          </shadow>
                        </value>
                        <next>
                              </block>
                            </value>
                            <next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
                <next>
                    <value name="IF0">
                        <value name="A">
                            <value name="PATH">
                              </shadow>
                            </value>
                                  </block>
                                </value>
                                <value name="AT">
                                    <field name="NUM">5</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                        <value name="TEXT">
                          </shadow>
                            <value name="ADD0">
                              </block>
                            </value>
                            <value name="ADD1">
                              </block>
                            </value>
                            <value name="ADD2">
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                            <value name="OID">
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                              </block>
                            </value>
                              </shadow>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                        <value name="TEXT">
                          </shadow>
                        </value>
                        <next>
                              </block>
                            </value>
                            <next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </xml>
        @marco-willi du hast aus knapp 500 Zeilen jetzt 2500 Zeilen gemacht?
          Marco Willi
          @homoran wie gesagt, ich musste den Code unterteilen, ich bekam immer ne Fehlermeldung, mehr als 10‘000 Zeichen würden nicht gehen. Hier noch die Bilder welche ich noch zu Beginn mit nur 3 Zählern hatte. Ich habe dann auf 5 erweitert.
          6adfad44-23e0-48a3-a6a1-a9cb268f4229.jpeg 345fd80c-c639-4e24-8f50-b21e53bea31e.jpeg 9c75b165-ff0b-4498-bba2-f42da4def259.jpeg c2a7fc81-ee66-460a-a7bd-22affb09a297.jpeg 174a819f-3d8e-45d7-8d92-ffb5bc75ceca.jpeg
            @marco-willi
            So große Blocklys baut man nicht! Wer soll da durchsteigen?
            Das Blockly hat nichts mit der Aufteilung des Eigenverbrauchs auf die 5 Verbraucher zu tun! Das sollte ein separates Skript sein.
            Für jeden Verbraucher erstellt man ein eigenes Skript (Export / Import mit ID-Anpassung). Ebenso für die PV / Eigenverbrauch.
              @marco-willi
              Marco Willi
              Ich habe das skript nicht gebaut nur erweitert. Zumindest ist es für mich bis auf zwei drei punkte verständlich und nachvollziehbar.
                Marco Willi
                @marco-willi said in PV Strom Aufteilung:
                Falls du das noch kompakter hinbekommst. Tu dir kein Zwang an🙈
                  @marco-willi
                  Mit einer sinnvollen ID-Struktur unter "alias.0" (Messwerte) und "0_userdata.0" (Zuweisungen) macht man es sich leichter.
                    @marco-willi
                    Marco Willi
                    @paul53 habe bei mir auch unter data separate Datenpunkte angelegt. Läuft dein skript? Müsste ich diese Woche mal importieren und testen.
                      @marco-willi sagte: Läuft dein skript?
                      Ich habe es nicht getestet. Sollte aber funktionieren. Habe noch die Alias-Datenpunkte zugewiesen.
                       <variables>
                         <variable id="4!.QWl^o3C^:xOUsncDM">leistungen</variable>
                         <variable id="Z/yy2t[:@n/yCnE{;JD2">arr</variable>
                         <variable id="/cK}~OC31xnguYr]V1Ug">attr</variable>
                         <variable id="j(Ay`U4*K?f`uxBMT=~B">Restleistung</variable>
                         <variable id="MEu~m0ap=YGi@;I{l)R*">i</variable>
                         <variable id="8IG{1^[y#F?[OcT$kfU^">obj</variable>
                         <variable id="q6h7`B[$+ZsH#a^bNB*f">Restanzahl</variable>
                         <variable id="%KbqcvOJ4#JoV?4(u1!T">Restmittel</variable>
                         <variable id="|~:77.d*!:FG7?xwvy=+">leistung</variable>
                         <variable id="ZS.uZvVkXP{+B`D%[jGd">id</variable>
                       </variables>
                       <block type="variables_set" id="XHOw[jb!GnH%uw/EkkSR" x="-1637" y="-1137">
                         <field name="VAR" id="4!.QWl^o3C^:xOUsncDM">leistungen</field>
                           <block type="lists_create_with" id="w0g@e!P0GRHlcL_JocR3">
                             <mutation items="5"></mutation>
                             <value name="ADD0">
                               <block type="object_new" id="Pz+z.0=fN{G#s2[vn_k$" inline="true">
                                 <mutation xmlns="http://www.w3.org/1999/xhtml">
                                   <attribute id="ATTR_0" name="id"></attribute>
                                   <attribute id="ATTR_1" name="power"></attribute>
                                 </mutation>
                                 <value name="ATTR_0">
                                   <shadow type="text" id="/n#q.h{2u%%6]:5x%sdL">
                                     <field name="TEXT">idZähler1</field>
                                   </shadow>
                                   <block type="field_oid" id="8f)e;qM~D5ZszgF6nvGK">
                                     <field name="oid">alias.0.SolarWEG.Zaehler01.Leistung</field>
                                   </block>
                                 </value>
                                 <value name="ATTR_1">
                                   <shadow type="text" id="5!nWL7pP`UDJEF2Iytm+">
                                     <field name="TEXT"></field>
                                   </shadow>
                                   <block type="math_number" id="ZIhR[uYM@@_$9Dd*Kji#">
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="ADD1">
                               <block type="object_new" id="mI,~-6{f0omisH]1$!aH" inline="true">
                                 </mutation>
                                   <shadow type="text" id="iYqVUWwruFtgC1SX4E,]">
                                     <field name="TEXT">idZähler2</field>
                                   </shadow>
                                   <block type="field_oid" id="SpP3^U3pb}QIyl,0*,+e">
                                     <field name="oid">alias.0.SolarWEG.Zaehler02.Leistung</field>
                                   </block>
                                 </value>
                                   </shadow>
                                   <block type="math_number" id="?EX-s%XS3b=]taH?;~qS">
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="ADD2">
                               <block type="object_new" id="4sx|V!a=GAi:aHYor=#c" inline="true">
                                 </mutation>
                                   <shadow type="text" id=",C(EXVwXVsw~kn*:;Ew@">
                                     <field name="TEXT">idZähler3</field>
                                   </shadow>
                                   <block type="field_oid" id="P`F3K2c6RP:P2w/Lt8gR">
                                     <field name="oid">alias.0.SolarWEG.Zaehler03.Leistung</field>
                                   </block>
                                 </value>
                                   </shadow>
                                   <block type="math_number" id="5.Z8gqu6t|d6Nn*B2+W3">
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="ADD3">
                               <block type="object_new" id="fr=y-vg*3~;hHyMzL@Xd" inline="true">
                                 </mutation>
                                   <shadow type="text" id="Tez`^.U4nL3Qr#PFhlNX">
                                     <field name="TEXT">idZähler4</field>
                                   </shadow>
                                   <block type="field_oid" id="+#X!oSy[%]r}IJ|Q}.gb">
                                     <field name="oid">alias.0.SolarWEG.Zaehler04.Leistung</field>
                                   </block>
                                 </value>
                                   </shadow>
                                   <block type="math_number" id="lh7sliQ,!$R:T+=kd^I=">
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="ADD4">
                               <block type="object_new" id="6v=SH@?A8sCwSrzlg1Ur" inline="true">
                                 </mutation>
                                   <shadow type="text" id="u=0=rm1ozyMf}[9iM2;,">
                                     <field name="TEXT">idZähler5</field>
                                   </shadow>
                                   <block type="field_oid" id="Hs2kCxcsz;#x*Iy`yyaa">
                                     <field name="oid">alias.0.SolarWEG.Zaehler05.Leistung</field>
                                   </block>
                                 </value>
                                   </shadow>
                                   <block type="math_number" id="YFDPREY!DyIOXg{CS37?">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                         <next>
                           <block type="on" id="~GBxWGx#,niJ$@tGOk.C">
                             <field name="OID">0_userdata.0.SolarWEG.ZaehlerPV.Eigenbedarf</field>
                             <statement name="STATEMENT">
                               <block type="variables_set" id="nG;I777OKpG+qk3:*X_]">
                                 <field name="VAR" id="j(Ay`U4*K?f`uxBMT=~B">Restleistung</field>
                                   <block type="on_source" id="!J[Br_=d_0yA?arw+vL*">
                                   </block>
                                 </value>
                                 <next>
                                   <block type="controls_for" id="jz%?P9H/lHwD^J6bh-Lq">
                                     <field name="VAR" id="MEu~m0ap=YGi@;I{l)R*">i</field>
                                     <value name="FROM">
                                       <shadow type="math_number" id="p/r%~#^;:kGAh2@vkL+c">
                                         <field name="NUM">1</field>
                                       </shadow>
                                     </value>
                                     <value name="TO">
                                       <shadow type="math_number" id="e)%X6NXh[(3!v_6NP}S*">
                                       </shadow>
                                     </value>
                                     <value name="BY">
                                       <shadow type="math_number" id="q;,9T5So)m`!BLV9L*8?">
                                       </shadow>
                                     </value>
                                     <statement name="DO">
                                       <block type="variables_set" id="k?{`ELn=nM{JEdI!fiXb">
                                         <field name="VAR" id="8IG{1^[y#F?[OcT$kfU^">obj</field>
                                           <block type="lists_getIndex" id="L5QxUxlJihTlVVIHW;_4">
                                               <block type="variables_get" id="LoL.9{E)}57X]?Nq/~RW">
                                               </block>
                                             </value>
                                             <value name="AT">
                                               <block type="variables_get" id="cfPi2Y^N7wKK~K}1J2od">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                           <block type="object_set_attr" id="i=ahLy029.U05]UGy]l]">
                                             <field name="ATTR">power</field>
                                               <block type="variables_get" id="1-1cXoe+]f2s}ui#E]3k">
                                               </block>
                                             </value>
                                               <shadow type="text" id="$(l%#9%IrZe(j9J:nS$9">
                                                 <field name="TEXT">value</field>
                                               </shadow>
                                               <block type="get_value_var" id="i^*U/KS(R]IXQWs0WeFm">
                                                 <value name="OID">
                                                   <shadow type="field_oid" id="pA}7xDu_zarp3IH1O8^G">
                                                   </shadow>
                                                   <block type="get_attr" id="MakZviRK#!y5O$FSUQDj">
                                                     <value name="PATH">
                                                       <shadow type="text" id="GYLIns737hBM(rTgwbq+">
                                                         <field name="TEXT">id</field>
                                                       </shadow>
                                                     </value>
                                                       <shadow type="get_object" id="vqVwCRtdz;4;|09)cUoG">
                                                       </shadow>
                                                       <block type="variables_get" id="J8[FT1(B2qCK|jVC)jr/">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                               <block type="lists_setIndex" id="2FK;uc+f#R0I,%71V}Rm">
                                                 <mutation at="true"></mutation>
                                                 <field name="MODE">SET</field>
                                                 <value name="LIST">
                                                   <block type="variables_get" id="|d#dX!1f9W:a_jS+=9LT">
                                                   </block>
                                                 </value>
                                                 <value name="AT">
                                                   <block type="variables_get" id="%,{F(;olX~.mC-4buL_#">
                                                   </block>
                                                 </value>
                                                 <value name="TO">
                                                   <block type="variables_get" id="pgAS[{dD}[ukC}c{L_gb">
                                                   </block>
                                                 </value>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </statement>
                                     <next>
                                       <block type="procedures_callcustomnoreturn" id="=;B`Gy;(6,m{q-?G$=8Q" inline="true">
                                         <mutation name="sortObjectNum">
                                           <arg name="arr"></arg>
                                           <arg name="attr"></arg>
                                         </mutation>
                                         <value name="ARG0">
                                           <block type="variables_get" id="3}QIG$EVa~0;!{+JyzGn">
                                           </block>
                                         </value>
                                         <value name="ARG1">
                                           <block type="text" id="tarlJ1Fw+E{_Suhu7=aL">
                                             <field name="TEXT">power</field>
                                           </block>
                                         </value>
                                         <next>
                                           <block type="variables_set" id="XX~d^%fLF^+zp9f8%YZX">
                                             <field name="VAR" id="q6h7`B[$+ZsH#a^bNB*f">Restanzahl</field>
                                               <block type="math_number" id="dfF)Kl1Hz4U;POr.tyWR">
                                               </block>
                                             </value>
                                             <next>
                                               <block type="controls_for" id="Z,T{!KsbeCX[m#]m%*j6">
                                                 <value name="FROM">
                                                   <shadow type="math_number" id="3Cy.u$.p{1P.QoX5#;16">
                                                   </shadow>
                                                 </value>
                                                 <value name="TO">
                                                   <shadow type="math_number" id="Sf/oUpwKuB;=4PasT;@x">
                                                   </shadow>
                                                 </value>
                                                 <value name="BY">
                                                   <shadow type="math_number" id="ZcjkV2mkj+s-kn~QClH9">
                                                   </shadow>
                                                 </value>
                                                   <block type="variables_set" id="z^9^*h9Ncs1`kX{}PS4#">
                                                     <field name="VAR" id="%KbqcvOJ4#JoV?4(u1!T">Restmittel</field>
                                                       <block type="math_round" id="!MB7J]7%bNAf=X;h^QCK">
                                                         <field name="OP">ROUND</field>
                                                         <value name="NUM">
                                                           <shadow type="math_number" id="E_zGQC$Y64TM3ClizW[Y">
                                                             <field name="NUM">3.1</field>
                                                           </shadow>
                                                           <block type="math_arithmetic" id="M*HjmCiocLGHz=ilHr2o">
                                                             <field name="OP">DIVIDE</field>
                                                             <value name="A">
                                                               <shadow type="math_number" id="r{CTeOH+-fp_sqwC0EKC">
                                                               </shadow>
                                                               <block type="variables_get" id="/RyBmFXVq)A_70ySFg_}">
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               <shadow type="math_number" id="w=e.DF{)iVv`WxUkBq9s">
                                                               </shadow>
                                                               <block type="variables_get" id="1E`Xnfl7s3EgPCfTlwFE">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="variables_set" id="k,W.9746]lV?c~40,4Rl">
                                                           <block type="lists_getIndex" id="l.wv[;!F/J9WPq4THM?^">
                                                               <block type="variables_get" id="eiU/42-|vX4Q8#8_jdb5">
                                                               </block>
                                                             </value>
                                                             <value name="AT">
                                                               <block type="variables_get" id="b^_u@ZD/Psy}F5Z9GOpZ">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="variables_set" id="{!y5o:n9_:=2K+RTk2!`">
                                                             <field name="VAR" id="|~:77.d*!:FG7?xwvy=+">leistung</field>
                                                               <block type="get_attr" id="l_[5ihlEj=inX{5l*^o!">
        <value name="PATH">
        <shadow type="text" id="vg#iQ)P.`6$GP(m!ER$e">
        </shadow>
        </value>
        </shadow>
        <block type="variables_get" id="TPdV*Rueb@x70p_XBRTZ">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
                                                               <block type="controls_if" id="(nDus,^!Ey661rY)dyN0">
        <value name="IF0">
        <block type="logic_compare" id="~#GYM1T$E$jp+PhS)ZRL">
        <field name="OP">GT</field>
        <value name="A">
        <block type="variables_get" id="ZmdhoHu)*.[iabl*-W.S">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="I=Q0StB]NA/HB{7TsQkO">
        </block>
        </value>
        </block>
        </value>
        <statement name="DO0">
        <block type="variables_set" id="I1UtP{U8HI#?YfN%VcVz">
        <block type="variables_get" id="L`trdMC{7RZxCvt@(nVy">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="variables_set" id="bKDOcaltB*/iMvcHoEU$">
        <field name="VAR" id="ZS.uZvVkXP{+B`D%[jGd">id</field>
        <block type="text_replace" id="8_aTm%Ib#,GHT2,Fi[u{">
        <value name="FROM">
        <shadow type="text" id="`1FmYkQgRVTX0gSmw3L/">
        <field name="TEXT">alias.0</field>
        </shadow>
        </value>
        <value name="TO">
        <shadow type="text" id="kWL:nij.yb90O.,~4d`4">
        <field name="TEXT">0_userdata.0</field>
        </shadow>
        </value>
        <value name="TEXT">
        <shadow type="text" id="CFe,-9!u[l|#/TvI~B@y">
        </shadow>
        <block type="get_attr" id="wOaK48e6v,Is-%XL#0EE">
        <value name="PATH">
        <shadow type="text" id="_TN-H-upTjupq8hyx1hX">
        </shadow>
        </value>
        </shadow>
        <block type="variables_get" id="sjlB|$?V5P0!Z+`Aj0OT">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="control_ex" id="Hws.qi!hVm#%OwNI!W1w" inline="true">
        <field name="TYPE">true</field>
        <value name="OID">
        <shadow type="field_oid" id="B,Z~E~138Rbd68r/zZa8">
        </shadow>
        <block type="variables_get" id="5MbG/Anwd!JphfxyM|`9">
        </block>
        </value>
        <shadow type="logic_boolean" id="9w%jp}sct=[1gZW}^)i:">
        </shadow>
        <block type="variables_get" id=":E9@lFe_u{%PbMVch]]P">
        </block>
        </value>
        <value name="DELAY_MS">
        <shadow type="math_number" id="B@Xu~_M:+UP}XRyn8e-K">
        </shadow>
        </value>
        <value name="EXPIRE">
        <shadow type="math_number" id="-*7!Pt_j|1@%D2LLoC`!">
        </shadow>
        </value>
        <next>
        <block type="math_change" id="Kl;wUCg]EscMZMPkL6q_">
        <value name="DELTA">
        <shadow type="math_number" id="HVu2@iYtQCXE?$l_R0;u">
        <field name="NUM">-1</field>
        </shadow>
        </value>
        <next>
        <block type="math_change" id="yjGl@0%,T^b|p8)$R^k#">
        <shadow type="math_number" id="C)z-_5P;}E+2nSj?7lA%">
        </shadow>
        <block type="math_single" id="N=Ygb:T9LY-]]oySV~-w">
        <field name="OP">NEG</field>
        <value name="NUM">
        <shadow type="math_number" id="vRpBXlSDwGMb3h#Ho^?b">
        <field name="NUM">9</field>
        </shadow>
        <block type="variables_get" id="LVM=mCV=RkXAd#tELl,~">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="debug" id="/FsC=bv8q6#^]wlol./}">
        <value name="TEXT">
        <shadow type="text" id="XZ}]x`H__:zD5ZE5ZCy8">
        </shadow>
        <block type="variables_get" id="J^}K8Z(-rGT^P4l9%M0|">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </next>
                       </block>
                       <block type="procedures_defcustomnoreturn" id="CxdOO.WCDAjV:Z{(+ME[" x="-1413" y="-912">
                         <mutation statements="false">
                           <arg name="arr" varid="Z/yy2t[:@n/yCnE{;JD2"></arg>
                           <arg name="attr" varid="/cK}~OC31xnguYr]V1Ug"></arg>
                         </mutation>
                         <field name="NAME">sortObjectNum</field>
                         <field name="SCRIPT">ZnVuY3Rpb24gc29ydEF0dHIoYSwgYikgew0KICAgIHJldHVybiBwYXJzZUZsb2F0KGFbYXR0cl0pIC0gcGFyc2VGbG9hdChiW2F0dHJdKTsNCn0NCmFyci5zb3J0KHNvcnRBdHRyKTs=</field>
                       </block>
                      </xml>
                      EDIT: Habe das Setzen von Restleistung nach oben verschoben (wegen obj).
                      Marco WilliM 2 Antworten Letzte Antwort
                         <variables>
                         </variables>
                               <value name="ADD0">
                                   </mutation>
                                     </shadow>
                                     </block>
                                   </value>
                                     </shadow>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="ADD1">
                                   </mutation>
                                     </shadow>
                                     </block>
                                   </value>
                                     </shadow>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="ADD2">
                                   </mutation>
                                     </shadow>
                                     </block>
                                   </value>
                                     </shadow>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="ADD3">
                                   </mutation>
                                     </shadow>
                                     </block>
                                   </value>
                                     </shadow>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="ADD4">
                                   </mutation>
                                     </shadow>
                                     </block>
                                   </value>
                                     </shadow>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                                     </block>
                                   </value>
                                   <next>
                                       <value name="FROM">
                                         </shadow>
                                       </value>
                                       <value name="TO">
                                         </shadow>
                                       </value>
                                       <value name="BY">
                                         </shadow>
                                       </value>
                                                 </block>
                                               </value>
                                               <value name="AT">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                                 </block>
                                               </value>
                                                 </shadow>
                                                   <value name="OID">
                                                     </shadow>
                                                       <value name="PATH">
                                                         </shadow>
                                                       </value>
                                                         </shadow>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                   <value name="LIST">
                                                     </block>
                                                   </value>
                                                   <value name="AT">
                                                     </block>
                                                   </value>
                                                   <value name="TO">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                       <next>
                                           </mutation>
                                           <value name="ARG0">
                                             </block>
                                           </value>
                                           <value name="ARG1">
                                             </block>
                                           </value>
                                           <next>
                                                 </block>
                                               </value>
                                               <next>
                                                   <value name="FROM">
                                                     </shadow>
                                                   </value>
                                                   <value name="TO">
                                                     </shadow>
                                                   </value>
                                                   <value name="BY">
                                                     </shadow>
                                                   </value>
                                                           <value name="NUM">
                                                             </shadow>
                                                               <value name="A">
        </shadow>
        </block>
                                                               </value>
                                                               <value name="B">
        </shadow>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                               <value name="AT">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        <value name="PATH">
        </shadow>
        </value>
        </shadow>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="FROM">
        </shadow>
        </value>
        <value name="TO">
        </shadow>
        </value>
        <value name="TEXT">
        </shadow>
        <value name="PATH">
        </shadow>
        </value>
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="OID">
        </shadow>
        </block>
        </value>
        </shadow>
        </block>
        </value>
        </shadow>
        </value>
        </shadow>
        </value>
        <next>
        </shadow>
        </value>
        <next>
        </shadow>
        <value name="NUM">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <next>
        <field name="Severity">info</field>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                           </mutation>
                         </block>
                        </xml>
                        Marco WilliM Offline
                        Marco Willi
                        @paul53 falls du noch zeit hast, machste mir ein Export daraus oder soll ich die einzeln importieren? Und du hast jetzt auch den momentanen Wert genommen und nicht ein Zählerstand oder?
                          @marco-willi sagte: machste mir ein Export daraus oder soll ich die einzeln importieren?
                          Unter dem Spoiler ist der Export.
                          @marco-willi sagte in PV Strom Aufteilung:
                          Leistungen sind momentane Werte.
                          Alles andere solltest du in separaten Skripten machen (je ein Skript pro Zähler).
                            Marco Willi
                            @paul53 habe das richtig verstanden. Das skript importiere ich, kopiere es 5x und passe die Datenpunkte alias und userdata an. Müsste alles enthalten sein?
                              @marco-willi sagte: Das skript importiere ich
                              Nein. Das exportierte Skript (unter dem Spoiler) enthält nur die Zuweisung der PV-Leistung zu den 5 Zählern und wird genau einmal gebraucht.
                              Andere notwendige Berechnungen - wie PV-Verbrauch aus PV-Leistung ermitteln - macht man mit einem Skript pro Zähler, da die Berechnungen gleich sind, aber verschiedene Datenpunkte nutzen.
                              Marco WilliM paul53P 2 Antworten Letzte Antwort
                                Marco Willi
                                Sorry, werd noch immer nicht ganz schlau. Wenn die PV aufteilung in Watt pro Zähler statt findet, reicht mir das aber völlig.
                                Die anderen Daten also die Energie, werden geloggt und mit anderen skripts berechnet. Das liegt bereit.
                                Werde das aber erst im Verlauf der Woche oder Wochende testen können.
                                Ich denke aber ich kann mich jetzt schon herzlich bei dir bedanken.
                                  Es wird ein ZEV. Heisst, es wird eine offizielle über 4 Wohnungen und 1 Allgemein sowie über die PV Anlage geben. Mein Auftrag ist es, mit Hilfe weiterer Messungen heraus zu bekommen, wer wann wieviel PV bekommt.
                                  Heisst: nur die Gesamtmessung kann einen negativen Wert aufweisen und nur bei Überschuss.
                                  Wohnung und Allgemein werden nur beziehen können.
                                  Daher die Formel.
                                  Die Bezüger haben also einen gewissen Bedarf der sich zu jedem Zeitpunkt ändern kann. Genau gleich mit ist es bei der PV Produktion.
                                  hans_999
                                  Gesperrt
                                  Es wird ein ZEV
                                  Hierzu muss ich vielleicht noch sagen. Dass ich ein Shelly 3EM dafür benutzen werde und somit 2 Datenpunkte habe für Verbrauch und Rückspeisung.
                                  Ich gehe davon aus, dass wir hier über ein Objekt in der Schweiz reden. Wenn ich die bisherigen Infos zu einem ZEV richtig verstanden habe, sind auf jeden Fall die allgemeinen Anforderungen aus der Messgesetzgebung zu beachten.
                                  Sind dort ungeeichte/unkalibrierte Zählern wie ein Shelly-3M zulässig, um auf Basis der damit erfassten Daten eine Verbrauchs-Abrechnung zu erstellen?
                                  Bei uns in DE wäre das auf jeden Fall ein No-Go.
                                  • H hans_999
                                    Es wird ein ZEV
                                    Marco Willi
                                    @hans_999 hätte mich überrascht, wenn die Frage nicht kommen würde.
                                    1. Schweiz ist korrekt
                                    2. nein, Shelly sind hier in solch einem Anwendungsfall auch nicht erlaubt. Die können resetet werden. Daher arbeite ich auch mit den momentanen Werten. Falls einer abraucht kann ich ihn schnell ersetzen und es geht kein Zählerstand verloren und wenn dann nicht viel und nur die PV Aufteilung.
                                      Im ZEV wird intern abgerechnet und daher müsste ich gar keine Zähler verbauen, dann wäre aber ein Aufteilungsschlüssel nötig, der richtig gut ist, um die Gemeinschaft zu überzeugen. Und um mich zu schützen werde ich geeichte Zähler verbauen und die Shelly nur für die Aufteilung nutzen.
                                      Es gäbe auch Zähler die das direkt können. Offeriert wurden uns ein Mehraufwand von 10‘000.-. Das konnte ich nicht auf mir sitzen lassen. Wenn ich es selber gemacht hätte mit den offerierten Zähler komme ich auf über 3000.-. Das Problem, die Zähler müssen nach 10 Jahren geeicht werden und so ein Zähler kostet 3.50.-.Ein dummer geeichter Zähler der nur in eine Richtung mist ohne Hoch und Niedertarif kostet im Moment 42.-. Der kann auch für die Abrechnung genutzt werden und nach 10 Jahren werf ich die Dinger einfach weg, da das eichen auch 250.- kostet. Die Shellys können ja bleiben.
                                      Die PV Aufteilung wird vorerst nur für eine Visualisierung genutzt. EVU und PV Strom wird bis zur Amortisation gleich verrechnet.
                                      Trotzdem logge ich die Daten mal und das wird dann in der internen Verrechnung auch aufgezeigt.
                                       <variables>
                                       </variables>
                                             <value name="ADD0">
                                                 </mutation>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <value name="ADD1">
                                                 </mutation>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <value name="ADD2">
                                                 </mutation>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <value name="ADD3">
                                                 </mutation>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <value name="ADD4">
                                                 </mutation>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                                   </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                                 <next>
                                                     <value name="FROM">
                                                       </shadow>
                                                     </value>
                                                     <value name="TO">
                                                       </shadow>
                                                     </value>
                                                     <value name="BY">
                                                       </shadow>
                                                     </value>
                                                               </block>
                                                             </value>
                                                             <value name="AT">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
                                                               </block>
                                                             </value>
                                                               </shadow>
        <value name="OID">
        </shadow>
        <value name="PATH">
        </shadow>
        </value>
        </shadow>
        </block>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        <value name="LIST">
        </block>
        </value>
        <value name="AT">
        </block>
        </value>
        <value name="TO">
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                         </mutation>
                                                         <value name="ARG0">
                                                           </block>
                                                         </value>
                                                         <value name="ARG1">
                                                           </block>
                                                         </value>
                                                         <next>
                                                               </block>
                                                             </value>
                                                             <next>
        <value name="FROM">
        </shadow>
        </value>
        <value name="TO">
        </shadow>
        </value>
        <value name="BY">
        </shadow>
        </value>
        <value name="NUM">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        <value name="AT">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="PATH">
        </shadow>
        </value>
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <value name="FROM">
        </shadow>
        </value>
        <value name="TO">
        </shadow>
        </value>
        <value name="TEXT">
        </shadow>
        <value name="PATH">
        </shadow>
        </value>
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="OID">
        </shadow>
        </block>
        </value>
        </shadow>
        </block>
        </value>
        </shadow>
        </value>
        </shadow>
        </value>
        <next>
        </shadow>
        </value>
        <next>
        </shadow>
        <value name="NUM">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                           </block>
                                         </next>
                                       </block>
                                         </mutation>
                                       </block>
                                      </xml>
                                      Marco Willi
                                      @paul53 ok danke für die info, habe die neue version mal runter kopiert. Angedacht ist die alias werte zu nehmen und in die Datenpunkte zu schreiben oder umgekehrt?
                                        @marco-willi sagte: Angedacht ist die alias werte zu nehmen und in die Datenpunkte zu schreiben oder umgekehrt?
                                        Die Original-Zählerwerte (Leistungen) werden über Alias abgebildet.
                                        Die Ergebnisse des Skriptes werden in eigene Datenpunkte unter "0_userdata.0" geschrieben.
                                        Dass die Werte rot sind, liegt am fehlerhaften Block "schreiben" in der Javascript-Version 8.4.x.
                                          Marco Willi
                                          6.6.2024, 18:36:35.009	[warn ]: javascript.0 (3879)     at Object.<anonymous> (script.js.Testskripte.Berechnung_Eigenbedarf_test:39:5)
                                          6.6.2024, 18:36:35.009	[info ]: javascript.0 (3879) script.js.Testskripte.Berechnung_Eigenbedarf_test: 200
                                          6.6.2024, 18:36:35.028	[warn ]: javascript.0 (3879)     at Object.<anonymous> (script.js.Testskripte.Berechnung_Eigenbedarf_test:39:5)
                                          6.6.2024, 18:36:35.028	[info ]: javascript.0 (3879) script.js.Testskripte.Berechnung_Eigenbedarf_test: 200
                                          6.6.2024, 18:36:35.035	[warn ]: javascript.0 (3879)     at Object.<anonymous> (script.js.Testskripte.Berechnung_Eigenbedarf_test:39:5)
                                          6.6.2024, 18:36:35.035	[info ]: javascript.0 (3879) script.js.Testskripte.Berechnung_Eigenbedarf_test: 200
                                          6.6.2024, 18:36:35.048	[warn ]: javascript.0 (3879)     at Object.<anonymous> (script.js.Testskripte.Berechnung_Eigenbedarf_test:39:5)
                                          6.6.2024, 18:36:35.048	[info ]: javascript.0 (3879) script.js.Testskripte.Berechnung_Eigenbedarf_test: 200
                                          6.6.2024, 18:36:35.049	[warn ]: javascript.0 (3879)     at Object.<anonymous> (script.js.Testskripte.Berechnung_Eigenbedarf_test:39:5)
                                          6.6.2024, 18:36:35.049	[info ]: javascript.0 (3879) script.js.Testskripte.Berechnung_Eigenbedarf_test: 200
                                          6.6.2024, 18:36:40.004	[warn ]: javascript.0 (3879)     at Object.<anonymous> (script.js.Testskripte.Berechnung_Eigenbedarf_test:39:5)
                                          Es wird leider nichts in die dafür angelegten Datenpunkte geschrieben, musst ich da was anpassen?
