  5. Lüftersteuerung funktioniert nicht
    6.6k
10 Beiträge 2 Kommentatoren 846 Aufrufe 1 Beobachtet
  • G Offline
    gluecksmann
    var Luftreiniger_oben;
    on({ id: 'zigbee.0.00158d0008ab28bc.opened' /* Is open */, change: 'ne' }, async (obj) => {
      let value = obj.state.val;
      let oldValue = obj.oldState.val;
      if (getState('zigbee.0.00158d0008ab28bc.opened').val == true) {
        Luftreiniger_oben = getState('philips-air.1.control.power').val;
        setState('philips-air.1.control.power' /* Power */, false);
      } else {
        setState('philips-air.1.control.power' /* Power */, Luftreiniger_oben);
    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
    Hallo, ich habe dieses Script schon einmal luaffähig da. Habe aber sowohl Luftriniger als auch Fensterkontakt doppelt. Also dachte ich ich ändere eben die Komponenten und es läuft. Aber nix. Jemand eine Idee?
    • G gluecksmann
        } else {
      @gluecksmann
      Weshalb zeigst du nicht das Blockly?
      G 1 Antwort Letzte Antwort
        @gluecksmann
        gluecksmann
        Weil ich bislang imme angemault wurde wenn ich das gemacht habe...
          <variables>
            <variable id="ipxhv:mW=fGe;}a1[zxs">Lufttreiniger Zustand</variable>
          </variables>
          <block type="on" id=";-Kgs.@y(q%C-?)+a}n~" x="-2012" y="-863">
            <field name="OID">zigbee.0.00158d0006d30e97.opened</field>
            <statement name="STATEMENT">
              <block type="controls_if" id="YS*_n/I@{iX*15G9NSv~">
                <value name="IF0">
                  <block type="logic_compare" id="}u[P^bFzMF8:{+[Lf:.E">
                    <field name="OP">EQ</field>
                    <value name="A">
                      <block type="get_value" id="MkA7;.taf|KI3%bJM}Wp">
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_boolean" id=",9U^aOXyxIPbssu@c^om">
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="variables_set" id="xw8#_#tu)i|n1KS;kV]3">
                    <field name="VAR" id="ipxhv:mW=fGe;}a1[zxs">Lufttreiniger Zustand</field>
                    <value name="VALUE">
                      <block type="get_value" id="4:pl[Xd1r8Q^r#`ArTdg">
                        <field name="OID">philips-air.0.control.power</field>
                      </block>
                    </value>
                    <next>
                      <block type="control" id="23hyS4nX40{u|mD@%e65">
                        <field name="OID">alexa2.0.Echo-Devices.d45170c55cb94b44aa6bbdfd2eb11f61.Commands.speak</field>
                          <block type="text" id="BBtY-gka`Qa.IUj-jmC;">
                            <field name="TEXT">Luftreiniger wurde ausgeschaltet</field>
                          </block>
                        </value>
                        <next>
                          <block type="control" id="PKE):[;F:93Z]wN7y=_l">
                              <block type="logic_boolean" id="]4h;6!H.D]iu(A|T=F2u">
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
                <statement name="ELSE">
                  <block type="control" id="(`y*IO6Cy$VzWeMOhGgm">
                      <block type="variables_get" id="N%2AIn]8y9fAj/5)}w1u">
                      </block>
                    </value>
                    <next>
                      <block type="control" id="RO?{G;7kg[{qS8qdO,5/">
                          <block type="text" id="_{,sBi^WY*0%$aoE$!EN">
                            <field name="TEXT">alter Zustand wurde wiederhergestellt</field>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </xml>
        • G gluecksmann
            <variables>
            </variables>
                  <value name="IF0">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
          </xml>
          @gluecksmann sagte: wenn ich das gemacht habe...
          Poste das Bild (Snipping tool).
            gluecksmann
            • G gluecksmann
              @gluecksmann
              "philips-air.1.control.power" ist vom Typ "boolean"? Dann sollte es funktionieren.
              Besser:
                @gluecksmann
                Besser:
                gluecksmann
                Sorry, falsches Script gewesen .. das läuft ja...hier das das nicht geht...
                • G gluecksmann
                  @gluecksmann sagte: hier das das nicht geht...
                  Das sollte es aber, wenn "philips-air.1.control.power" vom Typ "boolean" ist.
                  Setze die Variable auch bei Skriptstart, da sie sonst undefined ist, wenn das Skript bei offenem Fenster gestartet wird.
                    gluecksmann
                    In deinem Beispiel hast die Variable zweimal gesetzt. Ist das richtig?
                    • G gluecksmann
                      @gluecksmann sagte: hast die Variable zweimal gesetzt. Ist das richtig?
                      Ja, einmal bei Skriptstart und einmal beim Öffnen.
