  4. Node-Red
  5. Forecast Ergebnisse addieren
    6.4k
15 Beiträge 2 Kommentatoren 1.4k Aufrufe 2 Beobachtet
  • NefetzN Offline
    NefetzN Offline
    Nefetz
    Hallo zusammen!
    Hat jemand eine Idee , wie ich die 3 forecast Ergebnisse in NodeRed addiert bekomme?
    • NefetzN Nefetz
      Hallo zusammen!
      mickymM Offline
      mickymM Offline
      mickym
      @nefetz ah du hast schon alles richtig gemacht. Lass mal diese blöde function Node weg und rechne das Ganze mit einer Change Node aus.
      Hier zum Import
      [{"id":"2d9097cfea125152","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"solar","tot":"flow"},{"t":"set","p":"payload","pt":"msg","to":"$sum(payload.*)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":790,"y":5480,"wires":[["1f803c8a56d7fd8a"]]},{"id":"56826b1da656a934","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Ost","payload":"3227","payloadType":"num","x":260,"y":5480,"wires":[["10f9a9866ebbf5cb"]]},{"id":"43fcc2624bea9df1","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"West","payload":"3851","payloadType":"num","x":260,"y":5560,"wires":[["8cba3160bd1d1888"]]},{"id":"e597068edcb68144","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Süd","payload":"3818","payloadType":"num","x":260,"y":5520,"wires":[["3c147ff6bf76f324"]]},{"id":"10f9a9866ebbf5cb","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"solar.Ost","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":5480,"wires":[["e32bb31d6a802a41"]]},{"id":"3c147ff6bf76f324","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"solar.Süd","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":5520,"wires":[["e32bb31d6a802a41"]]},{"id":"8cba3160bd1d1888","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"solar.West","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":5560,"wires":[["e32bb31d6a802a41"]]},{"id":"1f803c8a56d7fd8a","type":"debug","z":"289f539dcc33814e","name":"Summe","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":980,"y":5480,"wires":[]},{"id":"885d4a2cfe457563","type":"function","z":"289f539dcc33814e","name":"Wenn es unbedingt sein muss ...","func":"var solar= flow.get(\"solar\");\nmsg.payload = solar.Ost + solar.Süd + solar.West;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":5540,"wires":[["7db50b242637c8e3"]]},{"id":"7db50b242637c8e3","type":"debug","z":"289f539dcc33814e","name":"Summe Function Node","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1100,"y":5540,"wires":[]},{"id":"e32bb31d6a802a41","type":"junction","z":"289f539dcc33814e","x":620,"y":5520,"wires":[["2d9097cfea125152","885d4a2cfe457563"]]}]
      und wenn Du unbedingt JS Code schreiben willst - was ich persönlich ja überhaupt nicht verstehe, dann halt so:
      var solar= flow.get("solar");
      return msg;
      NefetzN 1 Antwort Letzte Antwort
      • mickymM mickym
        Hier zum Import
        return msg;
        NefetzN Offline
        NefetzN Offline
        Nefetz
        schrieb am zuletzt editiert von Nefetz
        @mickym
        Danke für deine Antwort!
        Ich habe jetzt einfach mal den change node von dir bei meinem flow eingefügt , aber dann kommt diese Fehlermeldung:
        Bildschirmfoto vom 2024-04-06 14-27-34.png Bildschirmfoto vom 2024-04-06 14-27-37.png
        • NefetzN Nefetz
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          @nefetz ich sehe keine - zeig mal deinen Kontext?
          • mickymM mickym
            NefetzN Offline
            NefetzN Offline
            Nefetz
            @mickym
            Sorry, den wichtigsten screen vergessen.
            • NefetzN Nefetz
              @mickym
              mickymM Offline
              mickymM Offline
              mickym
              @nefetz Ja dann sind entweder noch nicht alle Felder belegt oder es ist keine Zahl drin (hast Du alle Inject Nodes betätigt?) - zeig mal deinen Kontext
              • mickymM mickym
                NefetzN Offline
                NefetzN Offline
                Nefetz
                @mickym Was meinste mit Kontext?
                • NefetzN Nefetz
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @nefetz Na wo Deine Variablen drin stehen.
                  Falls Du den Kontext nicht findest - das Menü aufklappen:
                  Und immer auf aktualisieren klicken!
                  Prüfe, ob da auch Zahlen drin stehen und betätige alle Inject Nodes um Dir ALLE Solarwerte abzuholen - ggf. lösche Deine Solarvariable nochmal.
                  Ansonsten ist irgendwas anderes faul - dann importiere meinen gesamten Flow und hänge Deine Nodes vorne dran.
                  Wenn aus Deinen Forecast Nodes keine Zahl rauskommt, dann musst Du das ggf. abfangen.
                  • mickymM mickym
                    NefetzN Offline
                    NefetzN Offline
                    Nefetz
                    @mickym
                    Ich habe jetzt deinen Flow verwendet.
                    Habe alle inject nodes angestoßen.
                    Keine Werte.
                    Wenn ich einen funktion node da noch einbaue kann ich die Werte abfangen. allerdings sind die dann einzeln.
                    • mickymM Offline
                      mickymM Offline
                      mickym
                      na das sind ja objekte und keine Zahlen die du schreibst. zeig mal das objekt, das aus den nodes kommt. Alternativ schreibe die Ergebnisse der function node in solar.Ost etc.
                      Also setze die 3 function nodes 3 mal direkt hinter die solarforecast nodes.
                      • mickymM mickym
                        NefetzN Offline
                        NefetzN Offline
                        Nefetz
                        @mickym
                        Könntest du mit anydesk mal drüber schauen?
                        • NefetzN Nefetz
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @nefetz Nein VOR die Change NOdes - die function Nodes direkt hinter die solar forecast nodes!!!
                          • mickymM mickym
                            NefetzN Offline
                            NefetzN Offline
                            Nefetz
                            @mickym
                            Vielen Dank, es hat somit geklappt!
                            • NefetzN Nefetz
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @nefetz JA viel Spaß und ein schönes Wochenende.
                              • mickymM mickym
                                NefetzN Offline
                                NefetzN Offline
                                Nefetz
                                @mickym Das wünsch ich dir auch 👍
