  4. Zigbee Adapter mit Error "Class extends value"
    1.0k
    6.1k
3 Beiträge 2 Kommentatoren 374 Aufrufe 2 Beobachtet
  • K Offline
    kanonidom
    Hallo liebe Profis!
    ich habe eine frische Docker-Installation á la buanet heute gemacht.
    Schon ein paar Jahre her seit meiner letzten Begegnung mit iob.
    Der Zigbee-Adapter macht nun allerdings nicht mit.
    Er wirft direkt beim starten die Fehler im Log auf, siehe weiter unten:
    host.iobroker 2024-03-24 15:34:56.116	info	"system.adapter.zigbee.0" disabled
    host.iobroker 2024-03-24 15:34:41.445	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker 2024-03-24 15:34:41.445	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker 2024-03-24 15:34:41.444	error	Caught by controller[0]: Node.js v18.19.1
    host.iobroker 2024-03-24 15:34:41.444	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
    host.iobroker 2024-03-24 15:34:41.443	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    host.iobroker 2024-03-24 15:34:41.443	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    host.iobroker 2024-03-24 15:34:41.443	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    host.iobroker 2024-03-24 15:34:41.442	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    host.iobroker 2024-03-24 15:34:41.442	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    host.iobroker 2024-03-24 15:34:41.441	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:58:28)
    host.iobroker 2024-03-24 15:34:41.441	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
    host.iobroker 2024-03-24 15:34:41.440	error	Caught by controller[0]: ^
    host.iobroker 2024-03-24 15:34:41.440	error	Caught by controller[0]: class Zigbee extends utils.Adapter {
    host.iobroker 2024-03-24 15:34:41.439	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/main.js:58
    admin.0       2024-03-24 15:34:38.754	info	<== Disconnect system.user.admin from ::ffff:192.168.188.52
    host.iobroker 2024-03-24 15:34:33.112	info	instance system.adapter.zigbee.0 started with pid 563
    host.iobroker 2024-03-24 15:34:28.258	info	Restart adapter system.adapter.zigbee.0 because enabled
    NPM, node.js etc. ist eigentlich alles auf stand, siehe weiter unten.
    ich habe die devices sauber durchgereicht an docker, daran kann es nicht liegen meiner Meinung nach.
    Irgendwelche Ideen, was ich machen kann?
    System schon neu gestartet, nochmals neu das stack deployed, auch schon den Adapter de-installiert und wieder installiert. bislang ohne Erfolg.
    Danke vorab!
    • Adaptername: zigbee
    • Link zu Adapterrepository: http://download.iobroker.net/sources-dist.json
    • Adapterversion: 1.10.1
    • js-controller Version: 5:0:19
    • Admin Version: 6.13.16
    • Hardwaresystem: Pi4
    • Arbeitsspeicher: 8GB
    • Festplattenart: SD-Karte, SSD, HDD, ...
    • Betriebssystem: linux debian
    • Nodejs-Version: v18.19.1
    • NPM-Version: 10.2.4
    • Installationsart: docker compose
    • Image, Docker genutzt: ja
    • Ort, Name der Imagedatei: buanet/docker:v9.1.1
    • K kanonidom
      Hallo liebe Profis!
      Danke vorab!
      arteckA Offline
      arteckA Offline
      arteck
      @kanonidom deinstalliere den Adapter und installiere den nochmal mal neu.. da gabs eine kleine Unschärfe
      K 1 Antwort Letzte Antwort
      • arteckA arteck
        kanonidom
        @arteck Danke Dir! Das hat funktioniert!
