  4. Node-Red
  5. Node Red unter Verbrauchswert ausschalten; Zeit X überprüfen
    6.5k
30 Beiträge 2 Kommentatoren 3.9k Aufrufe 1 Beobachtet
  • S SpeedyBlade
    @mickym
    irgendwie schaltet der so nun aber nicht mehr :(
    "id": "f8080a011db92103",
    "type": "template",
    "z": "aa961794.080218",
    "g": "598174313e10476d",
    "name": "Waschvorgang beendet",
    "field": "payload",
    "fieldType": "msg",
    "format": "handlebars",
    "syntax": "mustache",
    "template": "<speak> \n<s>Der Waschvorgang ist beendet, bitte die Wäsche nun trocknen!</s>\n</speak>",
    "output": "str",
    "x": 870,
    "y": 3760,
    "wires": [
    "6a36a8f4a3373c26"
    "id": "1d9e971bfbac9b9c",
    "type": "switch",
    "name": "zw. 0,0 - 2,0",
    "property": "payload",
    "propertyType": "msg",
    "rules": [
    "t": "btwn",
    "v": "0.0",
    "vt": "num",
    "v2": "2.0",
    "v2t": "num"
    "t": "else"
    "checkall": "false",
    "repair": false,
    "outputs": 2,
    "x": 250,
    "y": 3760,
    "wires": [
    "2b8bd472c67f5ff5"
    "644c6d663ca6d02e"
    "id": "5c161379df3ad577",
    "type": "trigger",
    "name": "",
    "op1": "",
    "op2": "false",
    "op1type": "nul",
    "op2type": "bool",
    "duration": "15",
    "extend": false,
    "overrideDelay": false,
    "units": "s",
    "reset": "",
    "bytopic": "all",
    "topic": "topic",
    "outputs": 1,
    "x": 630,
    "y": 3840,
    "wires": [
    "4641a1744f9f817d",
    "f8080a011db92103"
    "id": "644c6d663ca6d02e",
    "type": "change",
    "name": "",
    "rules": [
    "t": "set",
    "p": "reset",
    "pt": "msg",
    "to": "true",
    "tot": "bool"
    "action": "",
    "property": "",
    "from": "",
    "to": "",
    "reg": false,
    "x": 280,
    "y": 3840,
    "wires": [
    "5c161379df3ad577"
    "id": "4641a1744f9f817d",
    "type": "delay",
    "name": "",
    "pauseType": "delay",
    "timeout": "15",
    "timeoutUnits": "seconds",
    "rate": "1",
    "nbRateUnits": "10",
    "rateUnits": "second",
    "randomFirst": "1",
    "randomLast": "5",
    "randomUnits": "seconds",
    "drop": true,
    "allowrate": false,
    "outputs": 1,
    "x": 890,
    "y": 3840,
    "wires": [
    "392397818a8cebec"
    "id": "9059ca436bcf8d07",
    "type": "switch",
    "name": "wenn Shelly ein",
    "rules": [
    "t": "true"
    "repair": false,
    "outputs": 1,
    "x": 600,
    "y": 3760,
    "wires": [
    "5c161379df3ad577"
    "id": "2b8bd472c67f5ff5",
    "type": "ioBroker get",
    "name": "Shelly Status",
    "topic": "",
    "attrname": "payload",
    "payloadType": "value",
    "errOnInvalidState": "nothing",
    "x": 430,
    "y": 3760,
    "wires": [
    "9059ca436bcf8d07"
    "id": "bb143b342373c4b3",
    "type": "inject",
    "name": "",
    "props": [
    "p": "payload"
    "p": "topic",
    "vt": "str"
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "",
    "payloadType": "date",
    "x": 100,
    "y": 3760,
    "wires": [
    "1d9e971bfbac9b9c"
    "id": "392397818a8cebec",
    "type": "debug",
    "name": "debug 5",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "false",
    "statusVal": "",
    "statusType": "auto",
    "x": 1070,
    "y": 3840,
    "wires": []
    "id": "6a36a8f4a3373c26",
    "type": "debug",
    "name": "debug 6",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 1090,
    "y": 3760,
    "wires": []
    mickymM Offline
    mickymM Offline
    mickym
    @speedyblade
    1. Zum einen ein Flow zu exportieren muss immer in CodeTags sein.
    2. Nutze halt INJECT und Debug Nodes.
    In meinem Flow habe ich Dir doch 2 Inject Nodes mit unterschiedlichen Werten gezeigt. Dann nutz die halt und schau wie weit Dein Nachrichtenobjekt kommt.
    Wenn es vorher gegangen ist und jetzt nicht mehr, dann liegt es wohl an diesen beiden Nodes:
    Also mach eine Inject Node vorne dran und hinter die Switch node eine debug Node und schau ob die Nachrichten durchkommen wenn der Shelly eingeschaltet ist.
    Wenn nur connected im Status steht wurde die get Node entweder nicht getriggert oder der DP ist falsch oder wurde nicht ausgelesen.
    • mickymM mickym
      @speedyblade
      SpeedyBlade
      @mickym sagte in Node Red unter Verbrauchswert ausschalten; Zeit X überprüfen:
      so funktioniert es...
      • S SpeedyBlade
        mickymM Offline
        mickymM Offline
        mickym
        @speedyblade Du hast hoffentlich nicht im Adapter eingestellt, dass alle iobroker Werte in Strings gewandelt werden.
        • mickymM mickym
          SpeedyBlade
          schrieb am zuletzt editiert von SpeedyBlade
          das war wohl so im Standard eigestellt
          was ist mit Zeichenfolge gemeint?
          mickymM 2 Antworten Letzte Antwort
          • S SpeedyBlade
            mickymM Offline
            mickymM Offline
            mickym
            @speedyblade Wenn Du noch nicht viele Flows hast würde ich Dir raten das umzustellen. In den letzten Adapterversionen ist per Default abgeschaltet. Dann musst Du das schon lange so haben. Ich würde Dir jedenfalls langfristig raten, keine Umwandlung vorzunehmen und mit den originalen Datentypen zu arbeiten.
            • S SpeedyBlade
              mickymM Offline
              mickymM Offline
              mickym
              @speedyblade sagte in Node Red unter Verbrauchswert ausschalten; Zeit X überprüfen:
              Das sind Strings - Du solltest mal grundsätzlich mit Datentypen beschäftigen. Ansonsten bist Du viel mit Konvertieren beschäftigt. Mit Strings kannst Du halt nicht rechnen.
              In Node-Red kannst Du für die Eingabefelder grundsätzlich folgende Datentypen festlegen:
              Der Typ JSON - kann sowohl Arrays also in eckigen Klammern, als auch Objekte in geschweifte Klammern halten.
              • mickymM mickym
                SpeedyBlade
                @mickym
                Hab es jetzt auch umgestellt.
                All zu viele Nodes sind es nicht, die ich im Einsatz habe.
                Was genau sollte ich jetzt prüfen bei den alten nodes?
                • S SpeedyBlade
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  Das Du den richtigen Datentyp weiter verarbeitest. Jetzt wird deine Switch Node nicht mehr mit Stringvergleich funktionieren.
                  sondern als Boolean:
                  S mickymM 2 Antworten Letzte Antwort
                  • mickymM mickym
                    SpeedyBlade
                    @mickym
                    bei der node hatte ich das bereits geändert ;)
                    • mickymM mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @mickym Den Datentyp siehst Du soowhl in den Debug Nodes (Strings sind rot, Zahlen blau ....)
                      Im iobroker kannst Du mit dem Bleistift Dir anzeigen, was für ein Datentyp das ist:
                      Du siehst auch die iobroker Datenpunkte können verschiedene Datentypen enthalten:
