  2. English
  3. Scripting / Logic
  5. [Question] restart causes empty values are written
  • Mitmachen: Sprich „ioBroker“ ein – für ein lokales Aktivierungswort
  • Neuer Blogbeitrag: KI in ioBroker, vom Helfer im Admin bis zum eigenen Smart Assistant
  • Neues Video: Der KI-Assistent im ioBroker Admin
javascript
14 Beiträge 4 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • E
    E
    europe
    Following script produces empty entries when either the controller or system is rebooted, or when the script is restarted. How do I have to modify it to avoid that?
    // min (0 - 59)
    // hour (0 - 23)
    // day of month (1 - 31)
    // month (1 - 12)
    // day of week (0 - 6) (0 to 6 are Sunday to Saturday, or use names; 7 is Sunday, the same as 0)
    var cronH           = "59 * * * *";
    var cronD           = "59 23 * * *";
    var cronW           = "59 23 * * 0";
    var cronM           = "59 23 L * *";
    var cronY			= "59 23 31 12 *";
    var idH       = "0_userdata.0.Haus.Bezug.tmp.Total-h";
    var idD       = "0_userdata.0.Haus.Bezug.tmp.Total-d";
    var idW       = "0_userdata.0.Haus.Bezug.tmp.Total-w";
    var idM       = "0_userdata.0.Haus.Bezug.tmp.Total-m";
    var idY       = "0_userdata.0.Haus.Bezug.tmp.Total-y";
    var idValue   = "smartmeter.0.1-0:1_8_0__255.value"; // Bezug kWh
    var id_H      = "0_userdata.0.Haus.Bezug.Hour";
    var id_D      = "0_userdata.0.Haus.Bezug.Day";
    var id_W      = "0_userdata.0.Haus.Bezug.Week";
    var id_M      = "0_userdata.0.Haus.Bezug.Month";
    var id_Y      = "0_userdata.0.Haus.Bezug.Year";
    //var debug           = false;
    var DPArray         = [idH, idD , idW, idM, idY, id_H, id_D, id_W, id_M, id_Y];
    var DPUnit          = "kWh";
    DPArray.forEach(function(wert, index, array) {
        var DPType = wert.split(".");
        var DPDescr = "Power consumption of " + (DPType[DPType.length - 1]);
        if(index > 3) DPUnit = "kWh";
        createState(wert, 0, {
            desc: DPDescr,
            type: 'number',
            unit: DPUnit,
            role: 'value'
    function haupt (pre, post) {
        var nPre = getState(pre).val;
        var nCur = getState(idValue).val;
        var nDiff = (Math.round((nCur * 100)) - Math.round((nPre * 100)))/100; // kWh
        setState(post, nDiff, true);
        //if(debug) log("Aus: " + nCur +" - "+ nPre + " = " + nDiff);
        var shandler = on ({id: post, change: 'any'}, function(data) {
            setState(pre, Math.round(nCur*100)/100, true);
            unsubscribe(shandler);
    // schedule
    schedule(cronH, function () {
        haupt(idH, id_H);
    schedule(cronD, function () {
        haupt(idD, id_D);
    schedule(cronW, function () {
        haupt(idW, id_W);
    schedule(cronM, function () {
        haupt(idM, id_M);
    schedule(cronY, function () {
        haupt(idY, id_Y);
    • E europe
      // min (0 - 59)
      // hour (0 - 23)
      // month (1 - 12)
      var DPUnit          = "kWh";
              desc: DPDescr,
              type: 'number',
              unit: DPUnit,
              role: 'value'
      // schedule
          haupt(idH, id_H);
          haupt(idD, id_D);
          haupt(idW, id_W);
          haupt(idM, id_M);
          haupt(idY, id_Y);
      BananaJoeB
      BananaJoeB
      BananaJoe
      @europe da du sonst auch auf deutsch geschrieben hast:
      Definiere mal "empty entries". Am Anfang legt dein Skript die Datenpunkte an, da sollte aber eigentlich nichts passieren wenn es diese schon gibt.
      Sonst kommentiere den Block mal aus, Zeile 25 bis 36 und teste ob das Problem dann weg ist
      Define “empty entries”. At the beginning your script creates the data points, but nothing should actually happen if they already exist.
      Otherwise comment out the block, lines 25 to 36 and test whether the problem goes away
      mcm1957M E 2 Antworten Letzte Antwort
      • BananaJoeB BananaJoe
        mcm1957M
        mcm1957M
        mcm1957
        @bananajoe said in [Question] restart causes empty values are written:
        This is the english forum section.
        So PLEASE use english languge here, especially if TE writes in english - so this topic is put intentionally into the english section. For german langugage postiungs theres the german area.
        Thanks
        P.S. Even if @europe can read/write in german, others might not be capable to do so, Thats why we have an english section
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • BananaJoeB
          BananaJoeB
          BananaJoe
          i edit my post
            E
            E
            europe
            schrieb am zuletzt editiert von europe
            @bananajoe Thanks... with empty entries I meant null values
            Once without Ack once with.
            I just want to understand it before commenting that part out...
            • BananaJoeB
              BananaJoeB
              BananaJoe
              You have a function haupt.
              Your function will started via scheduled timers and different parameter - ok.
              But in your function Haupt you also have an on Trigger-reaction in line 44
              So everytime (!) your function is called, a new(!) trigger instance is added. for cronH 24 on a day. If the value change, all 24 instances of the trigger will start. so the script will cause a slow death of the system ...
              so move the on part to a separete section an be sure it will be called only once.
              i did not now if this is the problem, but it is a problem
              • E
                E
                europe
                @bananajoe ok, I'm completely stuck here now. I have like 10 of these crons running and the system is up and running sine more than 100 days on a simple TV box. So it might be a problem, but it didn't kill me yet...
                I just start the script once. If I modify it, I stop it and then start it again. You say while its running is it basically forking all the time?!
                Do you have a link to some basics that I can educate myself on this matter?
                "move the on part to a separate section", I have not the faintest clue how to implement that. Is there maybe a general function which implements what I want? A cron.tab like behaviour?
                BananaJoeB AsgothianA 2 Antworten Letzte Antwort
                • E europe
                  BananaJoeB
                  BananaJoeB
                  BananaJoe
                  @europe sagte in [Question] restart causes empty values are written:
                  if you stop the script, all "childs / sub-instances" are also stopped.
                  separte section: remove the on expression from the function and create this for every datapoint separate.
                  i am sorry, but i know no learning sites for this in english.
                  • E
                    E
                    europe
                    @bananajoe okay, thanks, a link to a german one is fine as well :-)
                    Do you know a better script which implements this kind of cron tab like behaviour?
                    • E europe
                      BananaJoeB
                      BananaJoeB
                      BananaJoe
                      @europe you could just use the "SourceAnalytix" Adapter. This Adapter will create all data you want with your script i think
                      I learned JavaScript / JavaScript with ioBroker/nodeJS and Blocky by 1.001 Websites and Examples from this forum.
                      I am sorry, but do not have "this one" site for learning this.
                      There are many videos on youtube for different themes (trigger, crontabs)
                      You don`t do it the wrong way. you wrote a script, you have problems and ask here. same as i do at the beginning.
                      • E europe
                        AsgothianA
                        AsgothianA
                        Asgothian
                        Actually, in your case the ’on’ construct is ok - due to the fast that once triggar is activated you unsubscribe from the triggar (line 46 in your code)
                        This does not get us closer to the null values, but explains why all is running fine.
                        • BananaJoeB
                          BananaJoeB
                          BananaJoe
                          @Asgothian
                          unsubscribe
                          damned, i missed the unsubscribe, so after the on is created it will immediately destroyed?
                            @Asgothian
                            unsubscribe
                            AsgothianA
                            AsgothianA
                            Asgothian
                            @bananajoe sagte in [Question] restart causes empty values are written:
                            @Asgothian
                            unsubscribe
                            The first time the trigger fires, yes.
                            E 1 Antwort Letzte Antwort
                            • AsgothianA Asgothian
                              @Asgothian
                              unsubscribe
                              E
                              E
                              europe
                              @asgothian
                              Okay, I just found the history adapter writes null at start and stop. I deactivated that.
                              I still had all those null entries though, which messed up with certain plotting routines.
                              I also wrote a script which goes through all objects (incl. 3 level of nesting according to the doc) and removes items in a certain timeframe of 1 minute.
                              Here's the code:
                              // 21-10-2024. Works perfectly!!
                              // To see log entries, set log level of javascript instance to silly
                              var startTimestamp = new Date('2023-12-14T09:40:00.000');
                              var endTimestamp = new Date(startTimestamp.getTime() + 1*60000);
                              //log(startTimestamp.toISOString())
                              //log(endTimestamp.toISOString())
                              $('0_userdata.0.Haus.*').each(function(id) {
                                  //log(id.toString())
                              //var currentElement = $(this);
                                 //console.log(currentElement);
                                sendTo('history.0', 'deleteRange', [{ id: id.toString(), start: startTimestamp, end: endTimestamp }]);
                              84.1k
                              1.4m
