  3. Off Topic
  4. nut-monitor.service entfernen
    6.0k
linuxservicenut
5 Beiträge 2 Kommentatoren 594 Aufrufe 2 Beobachtet
    Rushmed
    in meine iob diag finde ich Folgendes:
    *** FAILED SERVICES ***
      UNIT                LOAD   ACTIVE SUB    DESCRIPTION
    * nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
    1 loaded units listed.
    Wenn ich versuche zu deinstallieren kommt:
    pi@Smartazamba:~ $ sudo apt-get remove nut-monitor
    Reading package lists... Done
    Building dependency tree... Done
    Package 'nut-monitor' is not installed, so not removed
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Wie kann ich den nut-monitor.service, bzw. die Meldung loswerden?
    • R Rushmed
      @rushmed sagte in nut-monitor.service entfernen:
      nut-monitor
      sudo systemctl hide nut-monitor.service
      R 1 Antwort Letzte Antwort
        nut-monitor
        Rushmed
        schrieb am zuletzt editiert von Rushmed
        @thomas-braun Das hat leider nicht geklappt:
        pi@Smartazamba:~ $ sudo systemctl hide nut-monitor.service
        Unknown command verb hide.
        und
        pi@Smartazamba:~ $ systemctl status nut-monitor.service
        × nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller
             Loaded: loaded (/lib/systemd/system/nut-monitor.service; enabled; preset: enabled)
             Active: failed (Result: exit-code) since Fri 2024-03-01 19:29:19 CET; 1h 15min ago
           Duration: 97ms
            Process: 660 ExecStart=/sbin/upsmon -F (code=exited, status=1/FAILURE)
           Main PID: 660 (code=exited, status=1/FAILURE)
                CPU: 36ms
        Mar 01 19:29:19 Smartazamba nut-monitor[660]: fopen /run/nut/upsmon.pid: No such file or directory
        Mar 01 19:29:19 Smartazamba nut-monitor[660]: Could not find PID file to see if previous upsmon instance is already run>
        Mar 01 19:29:19 Smartazamba nut-monitor[660]: Using power down flag file /etc/killpower
        Mar 01 19:29:19 Smartazamba nut-monitor[660]: Network UPS Tools upsmon 2.8.0
        Mar 01 19:29:19 Smartazamba nut-monitor[660]: Fatal error: insufficient power configured!
        Mar 01 19:29:19 Smartazamba nut-monitor[660]: Sum of power values........: 0
        Mar 01 19:29:19 Smartazamba nut-monitor[660]: Minimum value (MINSUPPLIES): 1
        Mar 01 19:29:19 Smartazamba nut-monitor[660]: Edit your upsmon.conf and change the values.
        Mar 01 19:29:19 Smartazamba systemd[1]: nut-monitor.service: Main process exited, code=exited, status=1/FAILURE
        Mar 01 19:29:19 Smartazamba systemd[1]: nut-monitor.service: Failed with result 'exit-code'.
        lines 1-18/18 (END)
        • R Rushmed
          und
             Duration: 97ms
                  CPU: 36ms
          lines 1-18/18 (END)
          @rushmed
          Sorry, mein Fehler.
          sudo systemctl mask nut-monitor.service
            @rushmed
            Sorry, mein Fehler.
            Rushmed
            @thomas-braun Danke, das hat geklappt.
