  4. Node-Red
  5. [gelöst] Wert für alle Objekte in einem Order setzen
    6.4k
node-red
19 Beiträge 2 Kommentatoren 1.7k Aufrufe 2 Beobachtet
    schneidy76
    schrieb am zuletzt editiert von schneidy76
    Würde das funktionieren, das man mit einem flow alle Objekte in einen Ordner gleichzeitig auf "false" setzen kann?
    Habe da probiert, aber es funktioniert nicht:
            "id": "2d4606a3fadff7d5",
            "type": "ioBroker in",
            "z": "db97e840ec20025f",
            "name": "Vacuum state",
            "topic": "mihome-vacuum.0.info.state",
            "payloadType": "value",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "fireOnStart": "false",
            "outFormat": "MQTT",
            "x": 130,
            "y": 240,
            "wires": [
                    "adfe5c9e24e51537",
                    "07d90c82cc2e6a57"
            "id": "adfe5c9e24e51537",
            "type": "debug",
            "name": "State sauger",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 350,
            "y": 220,
            "wires": []
            "id": "07d90c82cc2e6a57",
            "type": "switch",
            "name": "bei Heimkehr",
            "property": "payload",
            "propertyType": "msg",
            "rules": [
                    "t": "eq",
                    "v": "6",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 350,
            "y": 260,
            "wires": [
                    "3d8cae059fee08af"
            "id": "3d8cae059fee08af",
            "type": "change",
            "name": "setze Auswahl zurück",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 560,
            "y": 260,
            "wires": [
                    "c8877bbda4460a57"
            "id": "c8877bbda4460a57",
            "type": "ioBroker out",
            "name": "Auswahl Räume",
            "topic": "0_userdata.0.Räume",
            "ack": "true",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 760,
            "y": 260,
            "wires": []
            "id": "34ca1497fa8fe595",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "6",
            "payloadType": "str",
            "x": 110,
            "y": 320,
            "wires": [
                    "07d90c82cc2e6a57"
    so wie ich das verstanden habe, sollte das doch gehen... Oder?
    VG Torsten
    Raspberry Matic (RP3), LIVE PV Monitoring mit Smartmeter, Poolsteuerung mit NodeRed, KNX Ausbau (ersetzt stückweise HM & klassische Installation), ioBroker Multihost (RP4 &RP2), Visu mit VIS
    • S schneidy76
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 130,
              "y": 240,
              "wires": [
                      "adfe5c9e24e51537",
                      "07d90c82cc2e6a57"
              "type": "debug",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 350,
              "y": 220,
              "wires": []
              "type": "switch",
              "rules": [
                      "t": "eq",
                      "v": "6",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 350,
              "y": 260,
              "wires": [
                      "3d8cae059fee08af"
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 560,
              "y": 260,
              "wires": [
                      "c8877bbda4460a57"
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 760,
              "y": 260,
              "wires": []
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "6",
              "x": 110,
              "y": 320,
              "wires": [
                      "07d90c82cc2e6a57"
      VG Torsten
      mickymM Offline
      mickymM Offline
      mickym
      Nein das funktioniert so nicht. Die iobroker-Out Node kann nur ein state setzen, aber du kannst die Objekte alle in einem Array sammeln und dann die payload gemeinsam setzen. Allerdings solltest Du aufpassen nicht alle Objekte in einem Adapter zu setzen - da viele ReadOnly sind.
      Zeig doch mal welche Objekte Du mit einem Flow auf false setzen möchtest, dann arbeitest Du einfach mit der List Node.
      Möchtest Du alle States unter Räume auf false setzen?
      0_userdata.0.Räume
      • mickymM mickym
        0_userdata.0.Räume
        schneidy76
        @mickym schade, hätte so einfach sein können... 😁
        Es geht um die Räume die ich ausgewählt habe und mein Saugroboter gereinigt hat.
        Auf der Rücktour zur Ladestation soll diese gelöscht werden...
        diese Objekte möchte ich auf "false" setzen:
        • S schneidy76
          mickymM Offline
          mickymM Offline
          mickym
          @schneidy76 Ja Du musst ggf den Control Ordner da rausmachen dann geht das super easy:
          [{"id":"6ff64a0eba16662a","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":250,"y":5560,"wires":[["0f1d8009da8aaaea"]]},{"id":"0f1d8009da8aaaea","type":"ioBroker list","z":"289f539dcc33814e","name":"","topic":"0_userdata.Räume.*","objType":"state","regex":"","asArray":"false","onlyIDs":"true","withValues":"false","x":440,"y":5560,"wires":[["8b50aaf612c48cad"]]},{"id":"8b50aaf612c48cad","type":"ioBroker out","z":"289f539dcc33814e","name":"Auswahl Räume","topic":"","ack":"true","autoCreate":"false","stateName":"","role":"","payloadType":"","readonly":"","stateUnit":"","stateMin":"","stateMax":"","x":680,"y":5560,"wires":[]}]
          Du kannst die auch drin lassen und dann über regex ausfiltern. Ich zeigs Dir.
          S mickymM 2 Antworten Letzte Antwort
          • mickymM mickym
            schneidy76
            @mickym said in Wert für alle Objekte in einem Order setzen:
            das habe ich mir auch schon fast gedacht -ich teste mal
            Danke!!!
            • mickymM mickym
              mickymM Offline
              mickymM Offline
              mickym
              @mickym Ja wie gesagt warte mal - ich probiere noch die Filterung.
              • mickymM mickym
                schneidy76
                @mickym ich warte... Du bist echt genial...
                • S schneidy76
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @schneidy76 Muss noch bissi an dem Filter mit regex tüfteln. ;)
                  • mickymM mickym
                    schneidy76
                    @mickym alles klar, kein Stress
                    • S schneidy76
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @schneidy76 Ja sorry - manchmal ist regEx verzwickt.
                      • mickymM mickym
                        schneidy76
                        @mickym ich kenn die Node nich mal 😂
                        • S schneidy76
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @schneidy76 Ok - ich habs mal so gemacht - dass es keine Sonderzeichen für Verzeichnisse gibt.
                          Also um nur die topics auf der ersten Ebene zu haben, habe ich die list Node wie folgt angepasst:
                          Also wenn Du den Filter
                          .*Räume\.\w*$
                          nutzt - dann werden aus der List Node nur die auf der 1. Ebene verwendet.
                          Also mit dem Flow sollten alles States direkt unter Räume auf false gesetzt werden:
                          [{"id":"6ff64a0eba16662a","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":250,"y":5560,"wires":[["0f1d8009da8aaaea"]]},{"id":"0f1d8009da8aaaea","type":"ioBroker list","z":"289f539dcc33814e","name":"","topic":"0_userdata.0.Räume.*","objType":"state","regex":".*Räume\\.\\w*$","asArray":"false","onlyIDs":"true","withValues":"false","x":440,"y":5560,"wires":[["8b50aaf612c48cad"]]},{"id":"8b50aaf612c48cad","type":"ioBroker out","z":"289f539dcc33814e","name":"Auswahl Räume","topic":"","ack":"true","autoCreate":"false","stateName":"","role":"","payloadType":"","readonly":"","stateUnit":"","stateMin":"","stateMax":"","x":680,"y":5560,"wires":[]}]
                          Du setzt halt statt false über die Inject Node über eine Change Node.
                          • mickymM mickym
                            .*Räume\.\w*$
                            schneidy76
                            @mickym funktioniert noch nicht ganz...
                                    "onlyack": "",
                                    "func": "all",
                                    "gap": "",
                                    "x": 130,
                                    "y": 300,
                                    "wires": [
                                            "938596741a116e5c"
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 510,
                                    "y": 280,
                                    "wires": []
                                    "type": "switch",
                                    "rules": [
                                            "t": "eq",
                                            "v": "6",
                                            "vt": "num"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 1,
                                    "x": 510,
                                    "y": 320,
                                    "wires": [
                                            "3d8cae059fee08af"
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "false",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 720,
                                    "y": 320,
                                    "wires": [
                                            "335221c44376c77e"
                                    "type": "inject",
                                    "name": "",
                                    "props": [
                                            "p": "payload"
                                    "repeat": "",
                                    "crontab": "",
                                    "once": false,
                                    "onceDelay": 0.1,
                                    "topic": "",
                                    "payload": "6",
                                    "x": 350,
                                    "y": 420,
                                    "wires": [
                                            "07d90c82cc2e6a57"
                                    "id": "938596741a116e5c",
                                    "type": "rbe",
                                    "name": "",
                                    "func": "rbe",
                                    "gap": "",
                                    "start": "",
                                    "inout": "out",
                                    "septopics": false,
                                    "topi": "topic",
                                    "x": 330,
                                    "y": 320,
                                    "wires": [
                                            "07d90c82cc2e6a57",
                                            "adfe5c9e24e51537"
                                    "id": "8b50aaf612c48cad",
                                    "ack": "true",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1200,
                                    "y": 320,
                                    "wires": []
                                    "id": "335221c44376c77e",
                                    "type": "ioBroker list",
                                    "name": "",
                                    "topic": "0_userdata.0.Räume.*",
                                    "objType": "state",
                                    "regex": ".*Räume\\.\\w*$",
                                    "asArray": "false",
                                    "onlyIDs": "true",
                                    "withValues": "false",
                                    "x": 960,
                                    "y": 320,
                                    "wires": [
                                            "8b50aaf612c48cad"
                            mach jetzt erst mal FA, habe morgen einen wichtigen Termin...
                            • S schneidy76
                                      "onlyack": "",
                                      "func": "all",
                                      "gap": "",
                                      "x": 130,
                                      "y": 300,
                                      "wires": [
                                              "938596741a116e5c"
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 510,
                                      "y": 280,
                                      "wires": []
                                      "type": "switch",
                                      "rules": [
                                              "t": "eq",
                                              "v": "6",
                                              "vt": "num"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 1,
                                      "x": 510,
                                      "y": 320,
                                      "wires": [
                                              "3d8cae059fee08af"
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "false",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 720,
                                      "y": 320,
                                      "wires": [
                                              "335221c44376c77e"
                                      "type": "inject",
                                      "name": "",
                                      "props": [
                                              "p": "payload"
                                      "repeat": "",
                                      "crontab": "",
                                      "once": false,
                                      "onceDelay": 0.1,
                                      "topic": "",
                                      "payload": "6",
                                      "x": 350,
                                      "y": 420,
                                      "wires": [
                                              "07d90c82cc2e6a57"
                                      "type": "rbe",
                                      "name": "",
                                      "func": "rbe",
                                      "gap": "",
                                      "start": "",
                                      "inout": "out",
                                      "septopics": false,
                                      "topi": "topic",
                                      "x": 330,
                                      "y": 320,
                                      "wires": [
                                              "07d90c82cc2e6a57",
                                              "adfe5c9e24e51537"
                                      "ack": "true",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 1200,
                                      "y": 320,
                                      "wires": []
                                      "name": "",
                                      "objType": "state",
                                      "asArray": "false",
                                      "onlyIDs": "true",
                                      "x": 960,
                                      "y": 320,
                                      "wires": [
                                              "8b50aaf612c48cad"
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @schneidy76 Was funktionier denn nicht?
                              • mickymM mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @mickym sagte in Wert für alle Objekte in einem Order setzen:
                                Ich seh shcon du hast meinen Flow nicht importiert:
                                In deiner iobroker Out NOde steht ja ein topic - bei mir nicht!!! Also topic aus der iobroker-OUT Node löschen!!!
                                • mickymM Offline
                                  mickymM Offline
                                  mickym
                                  .Räume.\w$
                                  Über folgenden Filter - kannst Du dann ein und ausschließen, wieviele Hierachieebenen die id enthalten soll:
                                  https://regex101.com/r/QVMv81/1
                                  .*Räume(?:\.\w*){1,2}$
                                  Für Ebene 1 und 2 unter Räume zum Beispiel
                                  oder {2,3} für die Ebenen 2 und 3 unter Räumen:
                                  • mickymM mickym
                                    .Räume.\w$
                                    schneidy76
                                    @mickym Moin, generell scheint das zu funktionieren, es scheint ein Problem mit den Raumnamen zu geben, wenn Sonderzeichen im Spiel sind...
                                    Debug schmeißt das raus.
                                    Dagegen steht in den Objekten
                                    VG Torsten
                                    • S schneidy76
                                      VG Torsten
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @schneidy76 Ja immer die Leute, die Sonderzeichen in Objekten verwenden. 🙄
                                      Dann ändere mal den Filter in der iobroker-List node wie folgt:
                                      .*Räume\.(?:\w|[ä,ü,ö,ß])*$
                                      Generell würde ich mir das Leben mit Sonderzeichen in Objekten nicht schwer machen, sondern den reinen ASCI Zeichensatz verwenden. In deiner UI oder Dashboard kannst Du ja soviele Sonderzeichen verwenden, wie Du willst.
                                      • mickymM mickym
                                        schneidy76
                                        jaja, schon verstanden, bisher war es kein Problem... ;-)
                                        Aber nun zum wesentlichen: es funktioniert tatsächlich!
                                        Dankeschön!!!
