  3. Off Topic
  4. Unifi Controller HTTP Status 404 – Not Found
    6.0k
14 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
    Snopy_16
    Hallo ich betreibe den Unificontroller zusammen mit iobroker nativ auf einen Raspberry PI4.
    Habe immer wieder mal apt-update && apt full-upgrade gemacht.
    Nun fiel mir auf dass der Unifi Controller nicht mehr erreichbar ist
    "HTTP Status 404 – Not Found"
    Hier die Meldung beim Abfragen des Status
    pi@raspberrypi:~ $ systemctl status unifi.service
    ● unifi.service - unifi
         Loaded: loaded (/lib/systemd/system/unifi.service; enabled; vendor preset: enabled)
         Active: activating (start-post) since Tue 2024-02-20 11:45:00 CET; 4min 3s ago
        Process: 7044 ExecStartPre=/usr/sbin/unifi-network-service-helper init (code=exited, status=0/SUCCESS)
        Process: 7088 ExecStartPre=/usr/sbin/unifi-network-service-helper init-uos (code=exited, status=0/SUCCESS)
       Main PID: 7097 (java); Control PID: 7098 (unifi-network-s)
          Tasks: 39 (limit: 8755)
            CPU: 1min 24.887s
         CGroup: /system.slice/unifi.service
                 ├─7097 /usr/bin/java -Dfile.encoding=UTF-8 -Djava.awt.headless=true -Dapple.awt.UIElement=true -Dunifi.core.enabled=false -Dunifi.mongodb.service.enabled=false -Xmx1024M -XX:+UseParallelGC -XX:>
                 ├─7098 /bin/bash /usr/sbin/unifi-network-service-helper healthcheck
                 └─8920 sleep 3
    Feb 20 11:45:00 raspberrypi unifi-network-service-helper[7087]: <13>Feb 20 11:45:00 unifi: init complete...
    Feb 20 11:45:00 raspberrypi unifi[7096]: Skipping init-uos...
    Feb 20 11:45:00 raspberrypi unifi-network-service-helper[7096]: <13>Feb 20 11:45:00 unifi: Skipping init-uos...
    Feb 20 11:45:00 raspberrypi unifi[7108]: health-check max retry count: 100
    Feb 20 11:45:00 raspberrypi unifi-network-service-helper[7108]: <13>Feb 20 11:45:00 unifi: health-check max retry count: 100
    Feb 20 11:45:13 raspberrypi java[7097]: WARNING: An illegal reflective access operation has occurred
    Feb 20 11:45:13 raspberrypi java[7097]: WARNING: Illegal reflective access by org.apache.catalina.loader.WebappClassLoaderBase (file:/usr/lib/unifi/lib/tomcat-embed-core-9.0.65.jar) to field java.io.ObjectS>
    Feb 20 11:45:13 raspberrypi java[7097]: WARNING: Please consider reporting this to the maintainers of org.apache.catalina.loader.WebappClassLoaderBase
    Feb 20 11:45:13 raspberrypi java[7097]: WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
    Feb 20 11:45:13 raspberrypi java[7097]: WARNING: All illegal access operations will be denied in a future release
    Ich bin nicht sehr fit in Sachen Linux und die Ausgabe sagt mir eigentlich gar nichts und ich weiss nicht wo ich das reparieren kann.
    Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
    LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
    iobroker auf Proxmox VM
    Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
    FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
    • S Snopy_16
              CPU: 1min 24.887s
                   └─8920 sleep 3
      @snopy_16 sagte in Unifi Controller HTTP Status 404 – Not Found:
      Wenn man danach sucht findet man einiges.
      Auf welchem Stand ist denn dein 'immer mal' upgedatetes System?
      iob diag
      sagt dir das.
        iob diag
        sagt dir das.
        Snopy_16
        @thomas-braun sagte in Unifi Controller HTTP Status 404 – Not Found:
        Ja, aber leider ist mein englisch fast nicht zu verwenden
        iob diag
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         12:50:22 up  1:20,  3 users,  load average: 0.60, 0.86, 1.13
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Tue 2024-02-20 12:50:22 CET
                   Universal time: Tue 2024-02-20 11:50:22 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        3.0G        3.5G         29M        1.3G        4.6G
        Swap:            99M          0B         99M
        Total:          7.9G        3.0G        3.6G
                 7812 M total memory
                 3023 M used memory
                 3414 M active memory
                  708 M inactive memory
                 3495 M free memory
                   87 M buffer memory
                 1206 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   13G   14G  49% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  9.3M  1.6G   1% /run
        /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
        tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
        [Tue Feb 20 11:29:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:59:9B:B3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=96bb02d6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Tue Feb 20 11:29:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Tue Feb 20 11:29:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Tue Feb 20 11:29:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems \(real ones only\):
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.9G    /var/
        1.5G    /var/lib
        1.1G    /var/cache/apt
        1.1G    /var/cache
        936M    /var/cache/apt/archives
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        124M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.8G    /opt/iobroker/iobroker-data/
        1.3G    /opt/iobroker/iobroker-data/history
        397M    /opt/iobroker/iobroker-data/files
        99M     /opt/iobroker/iobroker-data/backup-objects
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        22M     /opt/iobroker/iobroker-data/objects.jsonl
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.1
        /usr/bin/node           v18.19.1
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
         *** 18.19.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
        + system.adapter.eventlist.0              : eventlist             : raspberrypi                              -  enabled
        + system.adapter.eventlist.1              : eventlist             : raspberrypi                              -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
        + system.adapter.pushsafer.0              : pushsafer             : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
          system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 9090, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
        + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.13.16  , installed 6.13.16
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.9.6   , installed 2.9.6
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "email"        : 1.2.2    , installed 1.2.2
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
        Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.2  [Updatable]
        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "snmp"         : 3.1.0    , installed 3.1.0
        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis"          : 1.5.4    , installed 1.5.4
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        10959
        States:         9320
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 http://giteduberger.fr rpimonitor/ InRelease
        Hit:6 https://packages.grafana.com/oss/deb stable InRelease
        Hit:7 https://repos.influxdata.com/debian stable InRelease
        Hit:8 https://repos.influxdata.com/debian bullseye InRelease
        Hit:9 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:10 https://dl.ui.com/unifi/debian unifi-7.4 InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      117        16549      577/mongod
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12970      681/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          13102      802/perl
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       17401      1557/iobroker.js-co
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       18360      1557/iobroker.js-co
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16414      567/cupsd
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        2044       631/mosquitto
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21342      2899/io.sonoff.0
        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15571      630/vncserver-x11-c
        tcp6       0      0 :::3000                 :::*                    LISTEN      120        17172      1553/grafana
        tcp6       0      0 :::8000                 :::*                    LISTEN      1001       446767     3550/io.upnp.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      119        16973      597/influxd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19281      2573/io.admin.0
        tcp6       0      0 :::8080                 :::*                    LISTEN      118        480432     26071/java
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31658      3636/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12973      681/sshd: /usr/sbin
        tcp6       0      0 :::8443                 :::*                    LISTEN      118        480443     26071/java
        tcp6       0      0 :::8843                 :::*                    LISTEN      118        478174     26071/java
        tcp6       0      0 :::8880                 :::*                    LISTEN      118        480433     26071/java
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16413      567/cupsd
        tcp6       0      0 :::1883                 :::*                    LISTEN      116        2045       631/mosquitto
        tcp6       0      0 :::5900                 :::*                    LISTEN      0          15570      630/vncserver-x11-c
        udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          13008      -
        udp        0      0 0.0.0.0:48878           0.0.0.0:*                           1001       31344      3425/io.snmp.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14904      526/dhcpcd
        udp        0      0 0.0.0.0:49453           0.0.0.0:*                           1001       32178      3550/io.upnp.0
        udp        0      0 0.0.0.0:41326           0.0.0.0:*                           1001       31343      3425/io.snmp.0
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14890      770/cups-browsed
        udp        0      0 0.0.0.0:54019           0.0.0.0:*                           1001       32179      3550/io.upnp.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1855       424/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21320      2823/io.shelly.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       32466      3550/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       32465      3550/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       32464      3550/io.upnp.0
        udp        0      0 0.0.0.0:47126           0.0.0.0:*                           108        1857       424/avahi-daemon: r
        udp        0      0 0.0.0.0:59784           0.0.0.0:*                           1001       32177      3550/io.upnp.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21404      2924/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21405      2924/io.tuya.0
        udp6       0      0 :::51820                :::*                                0          13009      -
        udp6       0      0 :::546                  :::*                                0          16538      526/dhcpcd
        udp6       0      0 :::46104                :::*                                108        1858       424/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        1856       424/avahi-daemon: r
        2024-02-20 11:33:07.070  - info: tuya.0 (2924) 67334207807d3a73076a: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.24:6668
        2024-02-20 11:33:15.889  - info: tuya.0 (2924) bfce629f8925be1b3avd8x: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.21:6668
        2024-02-20 11:33:21.815  - info: tuya.0 (2924) bf2a002143d1aaa3d6pxdo: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.80:6668
        2024-02-20 11:33:22.681  - info: tuya.0 (2924) bf6cb789979a05727fivhw: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.51:6668
        2024-02-20 11:33:24.375  - info: tuya.0 (2924) 703548358cce4ecf54fb: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.78:6668
        2024-02-20 11:33:28.695  - info: tuya.0 (2924) bfd24a3dcc000234f1fdsz: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.50:6668
        2024-02-20 11:33:30.423  - info: tuya.0 (2924) 10801581f4cfa202a51c: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.45:6668
        2024-02-20 11:33:32.119  - info: tuya.0 (2924) 10801581f4cfa202a6a2: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.78:6668
        2024-02-20 11:33:33.495  - info: tuya.0 (2924) 27051506b4e62d57b7e7: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.60:6668
        2024-02-20 11:33:36.471  - info: tuya.0 (2924) 70354835e09806164458: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.79:6668
        2024-02-20 11:33:38.040  - info: tuya.0 (2924) 703384143c6105ebb2c8: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.55:6668
        2024-02-20 11:49:34.513  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
        2024-02-20 11:49:50.081  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
        2024-02-20 11:49:53.101  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2024-02-20 12:02:00.240  - info: javascript.0 (2693) script.js.Mein_Ordner.Fronius0: Solarweb Token erstellt
        2024-02-20 12:03:00.162  - warn: zigbee.0 (2958) DeviceAvailability:Stopping to ping 0xa4c1387a9c41346d TS011F after 4 ping attempts
        2024-02-20 12:03:00.710  - warn: zigbee.0 (2958) DeviceAvailability:Stopping to ping 0xa4c1382e5d9115bd TS011F after 4 ping attempts
        2024-02-20 12:21:33.640  - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
        2024-02-20 12:21:33.653  - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
        2024-02-20 12:21:33.656  - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36
        2024-02-20 12:30:01.890  - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl_MW.Liter_MW, feature disabled processing normally)
        2024-02-20 12:34:21.995  - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl.Liter, feature disabled processing normally)
        2024-02-20 12:34:22.134  - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl_MW.Liter_MW, feature disabled processing normally)
        2024-02-20 12:49:09.157  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
        2024-02-20 12:49:09.173  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
        • S Snopy_16
          iob diag
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   7812 M total memory
                   3023 M used memory
                   3495 M free memory
                     87 M buffer memory
                   1206 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          2.9G    /var/
          1.5G    /var/lib
          1.1G    /var/cache/apt
          1.1G    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.2.4
          /usr/bin/npx            10.2.4
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.13.16
          javascript:     7.8.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        10959
          States:         9320
          Pending Updates: 0
          630/vncserver-x11-c
          Schalt den Desktop-Mumpitz und damit auch den vnc-Mist aus.
          Zum Problem: Könnte sein, dass die verwendete Datenbank zu alt ist.
          Ich hab aber keine Ahnung, ob eine Neuinstallation von Raspberry OS 'Bookworm' da aktuelleres mit bringt.
          Und die Quelle
          würde ich auch rauskicken, wenn du nicht weißt warum die drin ist.
          influxdb hast du doppelt drin.
            630/vncserver-x11-c
            Und die Quelle
            Snopy_16
            wie kann ich das rauskicken und kann ich auch die 2. influx kicken (Welche?)
            • S Snopy_16
              @snopy_16
              sudo systemctl set-default multi-user.target
              ls -lAh /etc/apt/sources.list.d/
              zeigen.
                @snopy_16
                zeigen.
                Snopy_16
                pi@raspberrypi:~ $ sudo systemctl set-default multi-user.target
                Removed /etc/systemd/system/default.target.
                Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
                pi@raspberrypi:~ $ ls -lAh /etc/apt/sources.list.d/
                insgesamt 28K
                -rw-r--r-- 1 root root 137 22. Sep 17:19 100-ubnt-unifi.list
                -rw-r--r-- 1 root root  53 29. Okt 17:30 grafana.list
                -rw-r--r-- 1 root root 117 24. Okt 17:24 influxdata.list
                -rw-r--r-- 1 root root  56 24. Okt 17:07 influxdb.list
                -rw-r--r-- 1 root root 100 24. Okt 15:37 nodesource.list
                -rw-r--r-- 1 root root 191  3. Mai 2023  raspi.list
                -rw-r--r-- 1 root root  73 24. Okt 10:47 rpimonitor.list
                • S Snopy_16
                  insgesamt 28K
                  sudo rm /etc/apt/sources.list.d/rpimonitor.list
                  sudo rm /etc/apt/sources.list.d/influxdb.list
                  sudo apt update
                    sudo apt update
                    Snopy_16
                    schrieb am zuletzt editiert von Snopy_16
                    so ok ?
                    insgesamt 20K
                    Unifi - Problem hab ich noch nicht gelöst😕
                    Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                    • S Snopy_16
                      so ok ?
                      insgesamt 20K
                      @snopy_16
                      sudo apt update
                      sagt?
                      Zum unifi-Problem kann ich dir nichts sagen.
                        @snopy_16
                        sudo apt update
                        sagt?
                        Snopy_16
                        sudo apt update
                        pi@raspberrypi:~ $ sudo apt update
                        OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                        OK:2 http://deb.debian.org/debian bullseye InRelease
                        OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                        OK:4 https://repos.influxdata.com/debian stable InRelease
                        OK:5 https://packages.grafana.com/oss/deb stable InRelease
                        OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                        OK:7 https://dl.ui.com/unifi/debian unifi-7.4 InRelease
                        OK:8 http://archive.raspberrypi.org/debian bullseye InRelease
                        Alle Pakete sind aktuell.
                        Ich glaub das ist so in Ordnung?
                        • S Snopy_16
                          sudo apt update
                          @snopy_16
                          Ja, passt.
                            @snopy_16
                            Ja, passt.
                            Snopy_16
                            @thomas-braun Danke
                            • S Snopy_16
                              so ok ?
                              insgesamt 20K
                              Meister MopperM Online
                              Meister Mopper
                              Hier wirst du doch bestimmt fündig für die Fälle des Installierens und Update.
                              Proxmox und HA ...
