  3. Off Topic
  4. Unifi Controller HTTP Status 404 – Not Found
    6.0k
14 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
    @snopy_16 sagte in Unifi Controller HTTP Status 404 – Not Found:
    Illegal reflective access by org.apache.catalina.loader.WebappClassLoaderBase (file:/usr/lib/unifi/lib/tomcat-embed-core-9.0.65.jar) to field
    Wenn man danach sucht findet man einiges.
    Auf welchem Stand ist denn dein 'immer mal' upgedatetes System?
    iob diag
    sagt dir das.
    Snopy_16
    @thomas-braun sagte in Unifi Controller HTTP Status 404 – Not Found:
    Ja, aber leider ist mein englisch fast nicht zu verwenden
    iob diag
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     12:50:22 up  1:20,  3 users,  load average: 0.60, 0.86, 1.13
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2024-02-20 12:50:22 CET
               Universal time: Tue 2024-02-20 11:50:22 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        3.0G        3.5G         29M        1.3G        4.6G
    Swap:            99M          0B         99M
    Total:          7.9G        3.0G        3.6G
             7812 M total memory
             3023 M used memory
             3414 M active memory
              708 M inactive memory
             3495 M free memory
               87 M buffer memory
             1206 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   13G   14G  49% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  9.3M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Tue Feb 20 11:29:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:59:9B:B3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=96bb02d6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Tue Feb 20 11:29:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Feb 20 11:29:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Feb 20 11:29:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.9G    /var/
    1.5G    /var/lib
    1.1G    /var/cache/apt
    1.1G    /var/cache
    936M    /var/cache/apt/archives
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    124M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G    /opt/iobroker/iobroker-data/
    1.3G    /opt/iobroker/iobroker-data/history
    397M    /opt/iobroker/iobroker-data/files
    99M     /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   2
    Adapter State
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
    + system.adapter.eventlist.0              : eventlist             : raspberrypi                              -  enabled
    + system.adapter.eventlist.1              : eventlist             : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
    + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
    + system.adapter.pushsafer.0              : pushsafer             : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
      system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 9090, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
    + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.9.6   , installed 2.9.6
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
    Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.2  [Updatable]
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "snmp"         : 3.1.0    , installed 3.1.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        10959
    States:         9320
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 http://giteduberger.fr rpimonitor/ InRelease
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Hit:7 https://repos.influxdata.com/debian stable InRelease
    Hit:8 https://repos.influxdata.com/debian bullseye InRelease
    Hit:9 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:10 https://dl.ui.com/unifi/debian unifi-7.4 InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      117        16549      577/mongod
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12970      681/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          13102      802/perl
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       17401      1557/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       18360      1557/iobroker.js-co
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16414      567/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        2044       631/mosquitto
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21342      2899/io.sonoff.0
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15571      630/vncserver-x11-c
    tcp6       0      0 :::3000                 :::*                    LISTEN      120        17172      1553/grafana
    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       446767     3550/io.upnp.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      119        16973      597/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19281      2573/io.admin.0
    tcp6       0      0 :::8080                 :::*                    LISTEN      118        480432     26071/java
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31658      3636/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12973      681/sshd: /usr/sbin
    tcp6       0      0 :::8443                 :::*                    LISTEN      118        480443     26071/java
    tcp6       0      0 :::8843                 :::*                    LISTEN      118        478174     26071/java
    tcp6       0      0 :::8880                 :::*                    LISTEN      118        480433     26071/java
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16413      567/cupsd
    tcp6       0      0 :::1883                 :::*                    LISTEN      116        2045       631/mosquitto
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          15570      630/vncserver-x11-c
    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          13008      -
    udp        0      0 0.0.0.0:48878           0.0.0.0:*                           1001       31344      3425/io.snmp.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14904      526/dhcpcd
    udp        0      0 0.0.0.0:49453           0.0.0.0:*                           1001       32178      3550/io.upnp.0
    udp        0      0 0.0.0.0:41326           0.0.0.0:*                           1001       31343      3425/io.snmp.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14890      770/cups-browsed
    udp        0      0 0.0.0.0:54019           0.0.0.0:*                           1001       32179      3550/io.upnp.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1855       424/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21320      2823/io.shelly.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       32466      3550/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       32465      3550/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       32464      3550/io.upnp.0
    udp        0      0 0.0.0.0:47126           0.0.0.0:*                           108        1857       424/avahi-daemon: r
    udp        0      0 0.0.0.0:59784           0.0.0.0:*                           1001       32177      3550/io.upnp.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21404      2924/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21405      2924/io.tuya.0
    udp6       0      0 :::51820                :::*                                0          13009      -
    udp6       0      0 :::546                  :::*                                0          16538      526/dhcpcd
    udp6       0      0 :::46104                :::*                                108        1858       424/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        1856       424/avahi-daemon: r
    2024-02-20 11:33:07.070  - info: tuya.0 (2924) 67334207807d3a73076a: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.24:6668
    2024-02-20 11:33:15.889  - info: tuya.0 (2924) bfce629f8925be1b3avd8x: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.21:6668
    2024-02-20 11:33:21.815  - info: tuya.0 (2924) bf2a002143d1aaa3d6pxdo: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.80:6668
    2024-02-20 11:33:22.681  - info: tuya.0 (2924) bf6cb789979a05727fivhw: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.51:6668
    2024-02-20 11:33:24.375  - info: tuya.0 (2924) 703548358cce4ecf54fb: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.78:6668
    2024-02-20 11:33:28.695  - info: tuya.0 (2924) bfd24a3dcc000234f1fdsz: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.50:6668
    2024-02-20 11:33:30.423  - info: tuya.0 (2924) 10801581f4cfa202a51c: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.45:6668
    2024-02-20 11:33:32.119  - info: tuya.0 (2924) 10801581f4cfa202a6a2: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.78:6668
    2024-02-20 11:33:33.495  - info: tuya.0 (2924) 27051506b4e62d57b7e7: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.60:6668
    2024-02-20 11:33:36.471  - info: tuya.0 (2924) 70354835e09806164458: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.79:6668
    2024-02-20 11:33:38.040  - info: tuya.0 (2924) 703384143c6105ebb2c8: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.55:6668
    2024-02-20 11:49:34.513  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
    2024-02-20 11:49:50.081  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
    2024-02-20 11:49:53.101  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2024-02-20 12:02:00.240  - info: javascript.0 (2693) script.js.Mein_Ordner.Fronius0: Solarweb Token erstellt
    2024-02-20 12:03:00.162  - warn: zigbee.0 (2958) DeviceAvailability:Stopping to ping 0xa4c1387a9c41346d TS011F after 4 ping attempts
    2024-02-20 12:03:00.710  - warn: zigbee.0 (2958) DeviceAvailability:Stopping to ping 0xa4c1382e5d9115bd TS011F after 4 ping attempts
    2024-02-20 12:21:33.640  - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
    2024-02-20 12:21:33.653  - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
    2024-02-20 12:21:33.656  - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36
    2024-02-20 12:30:01.890  - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl_MW.Liter_MW, feature disabled processing normally)
    2024-02-20 12:34:21.995  - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl.Liter, feature disabled processing normally)
    2024-02-20 12:34:22.134  - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl_MW.Liter_MW, feature disabled processing normally)
    2024-02-20 12:49:09.157  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
    2024-02-20 12:49:09.173  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
    Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
    LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
    iobroker auf Proxmox VM
    Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
    FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
    • S Snopy_16
      iob diag
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7812 M total memory
               3023 M used memory
               3495 M free memory
                 87 M buffer memory
               1206 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      2.9G    /var/
      1.5G    /var/lib
      1.1G    /var/cache/apt
      1.1G    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        10959
      States:         9320
      Pending Updates: 0
      630/vncserver-x11-c
      Schalt den Desktop-Mumpitz und damit auch den vnc-Mist aus.
      Zum Problem: Könnte sein, dass die verwendete Datenbank zu alt ist.
      Ich hab aber keine Ahnung, ob eine Neuinstallation von Raspberry OS 'Bookworm' da aktuelleres mit bringt.
      Und die Quelle
      würde ich auch rauskicken, wenn du nicht weißt warum die drin ist.
      influxdb hast du doppelt drin.
        630/vncserver-x11-c
        Und die Quelle
        Snopy_16
        wie kann ich das rauskicken und kann ich auch die 2. influx kicken (Welche?)
        • S Snopy_16
          @snopy_16
          sudo systemctl set-default multi-user.target
          ls -lAh /etc/apt/sources.list.d/
          zeigen.
            @snopy_16
            zeigen.
            Snopy_16
            pi@raspberrypi:~ $ sudo systemctl set-default multi-user.target
            Removed /etc/systemd/system/default.target.
            Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
            pi@raspberrypi:~ $ ls -lAh /etc/apt/sources.list.d/
            insgesamt 28K
            -rw-r--r-- 1 root root 137 22. Sep 17:19 100-ubnt-unifi.list
            -rw-r--r-- 1 root root  53 29. Okt 17:30 grafana.list
            -rw-r--r-- 1 root root 117 24. Okt 17:24 influxdata.list
            -rw-r--r-- 1 root root  56 24. Okt 17:07 influxdb.list
            -rw-r--r-- 1 root root 100 24. Okt 15:37 nodesource.list
            -rw-r--r-- 1 root root 191  3. Mai 2023  raspi.list
            -rw-r--r-- 1 root root  73 24. Okt 10:47 rpimonitor.list
            • S Snopy_16
              insgesamt 28K
              sudo rm /etc/apt/sources.list.d/rpimonitor.list
              sudo rm /etc/apt/sources.list.d/influxdb.list
              sudo apt update
                sudo apt update
                Snopy_16
                schrieb am zuletzt editiert von Snopy_16
                so ok ?
                insgesamt 20K
                Unifi - Problem hab ich noch nicht gelöst😕
                Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                • S Snopy_16
                  so ok ?
                  insgesamt 20K
                  @snopy_16
                  sudo apt update
                  sagt?
                  Zum unifi-Problem kann ich dir nichts sagen.
                    @snopy_16
                    sudo apt update
                    sagt?
                    Snopy_16
                    sudo apt update
                    pi@raspberrypi:~ $ sudo apt update
                    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                    OK:2 http://deb.debian.org/debian bullseye InRelease
                    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                    OK:4 https://repos.influxdata.com/debian stable InRelease
                    OK:5 https://packages.grafana.com/oss/deb stable InRelease
                    OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                    OK:7 https://dl.ui.com/unifi/debian unifi-7.4 InRelease
                    OK:8 http://archive.raspberrypi.org/debian bullseye InRelease
                    Alle Pakete sind aktuell.
                    Ich glaub das ist so in Ordnung?
                    • S Snopy_16
                      sudo apt update
                      @snopy_16
                      Ja, passt.
                        @snopy_16
                        Ja, passt.
                        Snopy_16
                        @thomas-braun Danke
                        • S Snopy_16
                          so ok ?
                          insgesamt 20K
                          Meister MopperM Online
                          Meister Mopper
                          Hier wirst du doch bestimmt fündig für die Fälle des Installierens und Update.
                          Proxmox und HA ...
                          Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
