  4. [gelöst] Problem mit Javascript-Adapter
    1.0k
    6.1k
javascript
10 Beiträge 5 Kommentatoren 1.1k Aufrufe 4 Beobachtet
  • H Offline
    hans_999
    Gesperrt
    schrieb am zuletzt editiert von hans_999
    Heute ist wohl nicht mein Tag am PC.
    Der Javascript-Adater wurde mir bei den vorhandenen Aktualisierungen angezeigt (7.1.4 -> 7.8.0)
    Also habe ich "Aktualisieren gewählt.
    Das ging leider schief
    2024-02-18 21:50:01.923 - info: host.PIioBroker iobroker Update javascript from @7.1.4 to @7.8.0
    2024-02-18 21:50:02.937 - info: dwd.0 (17409) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.1, js-controller: 5.0.17
    2024-02-18 21:50:03.347 - info: host.PIioBroker iobroker NPM version: 8.19.3Installing iobroker.javascript@7.8.0... (System call)
    2024-02-18 21:50:05.632 - info: dwd.0 (17409) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-02-18 21:50:06.170 - info: host.PIioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-02-18 21:50:39.028 - info: host.PIioBroker iobroker npm ERR! code ETIMEDOUT
    2024-02-18 21:50:39.032 - info: host.PIioBroker iobroker npm ERR! syscall readnpm ERR! errno -110
    2024-02-18 21:50:39.039 - info: host.PIioBroker iobroker npm ERR! network read ETIMEDOUTnpm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly. See: 'npm help config'
    2024-02-18 21:50:39.048 - info: host.PIioBroker iobroker
    2024-02-18 21:50:39.052 - info: host.PIioBroker iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2024-02-18T20_50_04_520Z-debug-0.log
    2024-02-18 21:50:39.086 - error: host.PIioBroker iobroker npm ERR! code ETIMEDOUTnpm ERR! syscall readnpm ERR! errno -110npm ERR! network read ETIMEDOUTnpm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly. See: 'npm help config'npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2024-02-18T20_50_04_520Z-debug-0.log
    2024-02-18 21:50:39.088 - error: host.PIioBroker iobroker host.PIioBroker Cannot install iobroker.javascript@7.8.0: 146
    Etwas später habe ich festgestellt, dass keine Skripte mehr laufen :-(
    Da der Adapter noch in der Liste der Instanzen war, habe ich gestoppt und neu gestartet. Dann lief andauernd die (erfolglose) Installation los.
    Also Adapter wieder gestoppt.
    Auf die Kommandozeile gegangen und die installierten Adapter geprüft: Er war nicht in der Liste.
    Also 1. Versuch:
    iob install javascript
    Leider wieder erfolglos. Hier wohl die relevante Fehlermeldung, die mir aber nicht weiterhilft.
    Der Versuch, die alte Version
    iob install javascript@7.1.4
    wieder zu installieren, ging ebenfalls schief und bringt eine ähnliche Fehlermeldung
    2024-02-18 22:02:39.168 - error: host.PIioBroker iobroker npm-install: npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@types/caselessnpm ERR! dest /opt/iobroker/node_modules/@types/.caseless-biP5OApGnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@types/caseless' -> '/opt/iobroker/node_modules/@types/.caseless-biP5OApG'npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2024-02-18T21_02_32_356Z-debug-0.log
    2024-02-18 22:02:39.169 - error: host.PIioBroker iobroker npm-install: host.PIioBroker Cannot install iobroker.javascript@7.1.4: 217
    Was kann ich jetzt noch machen?
    Thomas BraunT arteckA ? H 4 Antworten Letzte Antwort
    • H hans_999
      Also 1. Versuch:
      @hans_999
      iob stop
      iob fix
      iob nodejs-update
      sudo reboot
      Dann weiterschauen.
      Die Ausgabe von 'iob diag' ist auch immer sinnvoll.
      • H hans_999
        Also 1. Versuch:
        arteckA Offline
        arteckA Offline
        arteck
        @hans_999 sagte in Problem mit Javascript-Adapter:
        da ist ein update abgebrochen...
        for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
        in der console.. wenn nach dem iob fix trotzdem nicht weiter geht
        • H hans_999
          Also 1. Versuch:
          Da ist beim Update dein Netzwerk zusammengebrochen oder kein Internetzugang oder DNS Fehler oder oder oder...
          Also schau am besten, noch bevor du die Commands von @Thomas-Braun eingibst, dass dein Netzwerk im iobroker funktioniert..
          • arteckA arteck
            mcm1957M Offline
            mcm1957M Offline
            mcm1957
            @arteck said in Problem mit Javascript-Adapter:
            Könnte dein gescheiterter Versuch einen nicht im Repo enthaltenen Adapter direkt von Github zu installieren da schuld sein?
            https://forum.iobroker.net/topic/59422/new-adapter-huawei-fusionsolar-api/92?_=1708337684217
            Da klemmt es genau beim selben Modul ....
            Und wie schon dort geschrieben: GITHUB Installatoinen immer auf eigenes Risiko und nicht auf produktiven Systemen (von Ausnahmen in Abstimmung mit dem Developer mal abgesehen)
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
            • mcm1957M mcm1957
              arteckA Offline
              arteckA Offline
              arteck
              @mcm57
              .caseless-biP5OApG
              diese Ordnerstruktur ist immer dann wenn ein update läuft.. und wird nach dem Update bereinigt..
              bricht das upadate ab.. dann bleiben diese Order bestehen und blokieren alle anderen Updates..
              nur mal zur Info
              • H hans_999
                Also 1. Versuch:
                hans_999
                Gesperrt
                @Thomas-Braun
                Danke, die Vorgehensweise hat geholfen.
                Es hat zwar ewig gedauert, bis das Update-Skript durch war. Aber danach konnte ich den aktuellen Javascript-Adapter problemlos (neu) installieren.
                Danke auch für die anderen Tipps und Hinweise.
                • H hans_999
                  @Thomas-Braun
                  @hans_999
                  Das spricht dafür, dass da diverse Updates in der Pipeline hingen.
                  In einem ansonsten gepflegten System dauert das nämlich nicht besonders lange.
                  Kiste danach auch mal sauber neugestartet?
                  H 1 Antwort Letzte Antwort
                    @hans_999
                    hans_999
                    Gesperrt
                    @thomas-braun said in [gelöst] Problem mit Javascript-Adapter:
                    Ja, das war ja der letzte Punkt in deiner Anleitung.
                    • H hans_999
                      @hans_999
                      Dann kannst du dir jetzt noch die Ausgabe von
                      iob diag
                      anschauen.
