  3. Einsteigerfragen
  4. Probleme mit Repositories und RAM Auslastung
repositoryiobroker shelly
44 Beiträge 7 Kommentatoren 5.4k Aufrufe 6 Beobachtet
    paddy89
    #41
    @thomas-braun said in Probleme mit Repositories und RAM Auslastung:
    @paddy89 sagte in Probleme mit Repositories und RAM Auslastung:
    npm ERR! code ENOTEMPTY
    Jag da den
    iob stop
    iob fix
    drüber.
    Dann
    iob update
    iob upgrade all
    Alles klar. Danke.
    Nach einigen Durchläufen hat er es auch endlich gepackt.
    *** iob diag is starting up, please wait ***
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
      Static hostname: SmartHome01
            Icon name: computer
     Operating System: Raspbian GNU/Linux 11 (bullseye)
               Kernel: Linux 6.1.21-v7+
         Architecture: arm
    Model		: Raspberry Pi 3 Model B Plus Rev 1.3
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
    14:39:32 up 23:57,  2 users,  load average: 0.60, 0.55, 0.50
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                  Local time: Wed 2024-02-14 14:39:32 CET
              Universal time: Wed 2024-02-14 13:39:32 UTC
                    RTC time: n/a
                 NTP service: active
             RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            921M        600M         21M        0.0K        300M        257M
    Swap:            99M         81M         18M
    Total:          1.0G        682M         39M
             921 M total memory
             600 M used memory
             179 M active memory
             623 M inactive memory
              21 M free memory
              65 M buffer memory
             234 M swap cache
              99 M total swap
              81 M used swap
              18 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       14G  4.8G  8.6G  36% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
    tmpfs          tmpfs     185M  996K  184M   1% /run
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    [Tue Feb 13 14:42:30 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=92f8759a-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Feb 13 14:42:33 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Feb 13 14:42:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Feb 13 14:42:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.0G	/var/
    990M	/var/log
    985M	/var/log/journal/ec16586e65944846a75af4f859fe7f90
    648M	/var/cache
    Archived and active journals take up 984.1M in the file system.
    /opt/iobroker/backups:
    55M	/opt/iobroker/backups/
    24K	/opt/iobroker/backups/0
    /opt/iobroker/iobroker-data:
    241M	/opt/iobroker/iobroker-data/
    141M	/opt/iobroker/iobroker-data/history
    75M	/opt/iobroker/iobroker-data/files
    31M	/opt/iobroker/iobroker-data/files/web.admin/static
    22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    7.5M	/opt/iobroker/iobroker-data/objects.jsonl
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    4.4M	/opt/iobroker/iobroker-data/files/jarvis/js/vendor.3ed67ef3.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.0
    /usr/bin/node 		v18.19.0
    /usr/bin/npm 		10.2.3
    /usr/bin/npx 		10.2.3
    /usr/bin/corepack 	0.22.0
    nodejs:
     Installed: 18.19.0-1nodesource1
     Candidate: 18.19.0-1nodesource1
     Version table:
    *** 18.19.0-1nodesource1 1001
           500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           100 /var/lib/dpkg/status
        18.18.2-1nodesource1 1001
        18.18.1-1nodesource1 1001
        18.18.0-1nodesource1 1001
        18.17.1-1nodesource1 1001
        18.17.0-1nodesource1 1001
        18.16.1-1nodesource1 1001
        18.16.0-1nodesource1 1001
        18.15.0-1nodesource1 1001
        18.14.2-1nodesource1 1001
        18.14.1-1nodesource1 1001
        18.14.0-1nodesource1 1001
        18.13.0-1nodesource1 1001
        18.12.0-1nodesource1 1001
        18.11.0-1nodesource1 1001
        18.10.0-1nodesource1 1001
        18.9.1-1nodesource1 1001
        18.9.0-1nodesource1 1001
        18.8.0-1nodesource1 1001
        18.7.0-1nodesource1 1001
        18.6.0-1nodesource1 1001
        18.5.0-1nodesource1 1001
        18.4.0-1nodesource1 1001
        18.3.0-1nodesource1 1001
        18.2.0-1nodesource1 1001
        18.1.0-1nodesource1 1001
        18.0.0-1nodesource1 1001
        12.22.12~dfsg-1~deb11u4 500
           500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		6.13.16
    javascript: 	"javascript" not found
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : SmartHome01                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
     system.adapter.backitup.0               : backitup              : SmartHome01                              - disabled
     system.adapter.discovery.0              : discovery             : SmartHome01                              - disabled
     system.adapter.flot.0                   : flot                  : SmartHome01                              -  enabled
     system.adapter.fritzdect.0              : fritzdect             : SmartHome01                              - disabled
    + system.adapter.history.0                : history               : SmartHome01                              -  enabled
     system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: SmartHome01                              - disabled
     system.adapter.jarvis.0                 : jarvis                : SmartHome01                              - disabled
    + system.adapter.lovelace.0               : lovelace              : SmartHome01                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
     system.adapter.mihome.0                 : mihome                : SmartHome01                              - disabled, port: 9898, bind: 0.0.0.0
    + system.adapter.shelly.0                 : shelly                : SmartHome01                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : SmartHome01                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.2                 : shelly                : SmartHome01                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.3                 : shelly                : SmartHome01                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : SmartHome01                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : SmartHome01                              -  enabled
     system.adapter.sonoff.0                 : sonoff                : SmartHome01                              - disabled, port: 1883, bind: 0.0.0.0
     system.adapter.sonoff.1                 : sonoff                : SmartHome01                              - disabled, port: 1884, bind: 0.0.0.0
    + system.adapter.web.0                    : web                   : SmartHome01                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
     system.adapter.xterm.0                  : xterm                 : SmartHome01                              - disabled, port: 8099, bind: 0.0.0.0
     system.adapter.yeelight-2.1             : yeelight-2            : SmartHome01                              - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.0.15 [Updatable]
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "lovelace"     : 4.1.2    , installed 4.1.2
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "xterm"        : 2.0.1    , installed 2.0.1
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Objects and States
    Objects: 	2746
    States: 	2042
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1125932    14166/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1126527    14166/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12936      490/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        13554      542/mariadbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12938      490/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1128563    14343/io.simple-api
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1126158    14332/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1126028    14193/io.admin.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       1126157    14317/io.lovelace.0
    udp        0      0 0.0.0.0:40668           0.0.0.0:*                           108        12864      351/avahi-daemon: r
    udp        0      0 0.0.0.0:49894           0.0.0.0:*                           1001       1177506    14287/io.shelly.3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12862      351/avahi-daemon: r
    udp        0      0 0.0.0.0:42786           0.0.0.0:*                           1001       1181145    14272/io.shelly.2
    udp        0      0 0.0.0.0:35619           0.0.0.0:*                           1001       1181896    14257/io.shelly.1
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       1126640    14287/io.shelly.3
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       1126632    14272/io.shelly.2
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       1126592    14257/io.shelly.1
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       1127516    14242/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14470      759/dhcpcd
    udp        0      0 0.0.0.0:60025           0.0.0.0:*                           1001       1182764    14242/io.shelly.0
    udp6       0      0 :::5353                 :::*                                108        12863      351/avahi-daemon: r
    udp6       0      0 :::39975                :::*                                108        12865      351/avahi-daemon: r
    2024-02-14 14:39:47.620  - info: smartmeter.0 (14302) Received 14 values, 8 updated
    2024-02-14 14:39:51.602  - warn: shelly.2 (14272) [authEnabled] 192.168.2.24 (shelly1pm / shelly1pm-98CDAC1E255C / SHSW-PM#98CDAC1E255C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-14 14:39:51.806  - warn: shelly.3 (14287) [authEnabled] 192.168.2.24 (shelly1pm / shelly1pm-98CDAC1E255C / SHSW-PM#98CDAC1E255C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-14 14:39:53.604  - info: smartmeter.0 (14302) Received 14 values, 7 updated
    2024-02-14 14:39:59.626  - info: smartmeter.0 (14302) Received 14 values, 7 updated
    2024-02-14 14:40:05.630  - info: smartmeter.0 (14302) Received 14 values, 7 updated
    2024-02-14 14:40:11.594  - info: smartmeter.0 (14302) Received 14 values, 7 updated
    2024-02-14 14:40:17.629  - info: smartmeter.0 (14302) Received 14 values, 8 updated
    2024-02-14 14:40:23.626  - info: smartmeter.0 (14302) Received 14 values, 7 updated
    2024-02-14 14:40:29.621  - info: smartmeter.0 (14302) Received 14 values, 7 updated
    2024-02-14 14:40:35.636  - info: smartmeter.0 (14302) Received 14 values, 8 updated
    2024-02-14 14:40:41.611  - info: smartmeter.0 (14302) Received 14 values, 8 updated
    2024-02-14 14:40:47.598  - info: smartmeter.0 (14302) Received 14 values, 6 updated
    2024-02-14 14:40:53.619  - info: smartmeter.0 (14302) Received 14 values, 8 updated
    2024-02-14 14:40:59.600  - info: smartmeter.0 (14302) Received 14 values, 8 updated
    2024-02-14 14:41:05.599  - info: smartmeter.0 (14302) Received 14 values, 8 updated
    2024-02-14 14:41:05.635  - warn: shelly.1 (14257) [authEnabled] 192.168.2.24 (shelly1pm / shelly1pm-98CDAC1E255C / SHSW-PM#98CDAC1E255C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-14 14:41:11.609  - info: smartmeter.0 (14302) Received 14 values, 7 updated
    2024-02-14 14:41:13.134  - warn: shelly.1 (14257) [authEnabled] 192.168.2.24 (shelly1pm / shelly1pm-98CDAC1E255C / SHSW-PM#98CDAC1E255C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-14 14:41:14.292  - warn: shelly.3 (14287) [authEnabled] 192.168.2.24 (shelly1pm / shelly1pm-98CDAC1E255C / SHSW-PM#98CDAC1E255C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-14 14:41:15.402  - warn: shelly.2 (14272) [authEnabled] 192.168.2.24 (shelly1pm / shelly1pm-98CDAC1E255C / SHSW-PM#98CDAC1E255C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-14 14:41:17.608  - info: smartmeter.0 (14302) Received 14 values, 8 updated
    2024-02-14 14:41:23.600  - info: smartmeter.0 (14302) Received 14 values, 7 updated
    2024-02-14 14:41:27.119  - warn: shelly.3 (14287) [authEnabled] 192.168.2.24 (shelly1pm / shelly1pm-98CDAC1E255C / SHSW-PM#98CDAC1E255C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-02-14 14:41:29.633  - info: smartmeter.0 (14302) Received 14 values, 8 updated
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
       		v.2023-10-10
            Icon name: computer
         Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		armhf
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Pending OS-Updates: 	0
    Pending iob updates: 	1
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
       		/usr/bin/npm 		10.2.3
       		/usr/bin/npx 		10.2.3
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            921M        589M         78M        0.0K        254M        268M
    Swap:            99M         99M          0B
    Total:          1.0G        689M         78M
    Active iob-Instances: 	11
    ioBroker Core: 		js-controller 		5.0.17
       		admin 			6.13.16
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		2746
    States: 		2042
    Size of iob-Database:
    3.6M	/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    • Thomas BraunT Online
      #42
      @paddy89
      jarvis noch auf Stand bringen.
      Und dann würde ich mir diese Basis schnappen und damit auf ein frisch installiertes 64Bit-RaspberryOS 12 'Bookworm' umziehen.
      'Bullseye' läuft in wenigen Monaten aus. Zeit umzusatteln.
      P 1 Antwort Letzte Antwort
        @paddy89
        paddy89
        #43
        @paddy89
        Ah ok. Muss ich mich mal einlesen mit den Versionen.
        Hast du da einen guten Link für einen sauberen Umzug mit allem?
        Falls ich doch Upgraden wollen würde, welche Geräte wären da empfehlenswert?
        Hab hier einige mini PCs und auch NBs alles auf Core i Basis. Den kleinsten bekomm ich aber wie gesagt nur auf 15-20w, was mir auf Dauer aber zuviel ist. Ebenso passt es dann nicht, hohe Summen für ne neue Kiste auszugeben.
        • P paddy89
          @paddy89
          #44
          Betriebssystem NEU installieren.
          Backup des iobroker in eine frische Installation einspielen. Fertig.
