  4. [GELÖST] ble Adapter macht Probleme auf Raspi 5
27 Beiträge 4 Kommentatoren 4.2k Aufrufe 4 Beobachtet
    @wauzzi
    Grundvoraussetzungen sind da?
    sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
    sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
    wauzziW Offline
    wauzziW Offline
    wauzzi
    @thomas-braun said in ble Adapter macht Probleme auf Raspi 5:
    sudo setcap cap_net_raw+eip $(eval readlink -f which node)
    offensichtlich, ja. Wenn ich dies beurteilen würde
    admin@iobroker:/opt/iobroker $ sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
    Reading package lists... Done
    Building dependency tree... Done
    bluetooth is already the newest version (5.66-1+rpt1+deb12u1).
    bluez is already the newest version (5.66-1+rpt1+deb12u1).
    libbluetooth-dev is already the newest version (5.66-1+rpt1+deb12u1).
    libudev-dev is already the newest version (252.22-1~deb12u1).
    libcap2-bin is already the newest version (1:2.66-4).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    admin@iobroker:/opt/iobroker $ sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
    • wauzziW wauzzi
      @wauzzi
      Dann schau dir einen Kaltstart des Adapters per
      iob logs --watch | uniq
      an.
      GlasfaserG wauzziW 2 Antworten Letzte Antwort
        @wauzzi
        an.
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        Kommt wohl öfters der Fehler vor :
        https://github.com/AlCalzone/ioBroker.ble/issues/837
          @wauzzi
          an.
          wauzziW Offline
          wauzziW Offline
          wauzzi
          2024-02-10 23:45:58.679  - info: ble.0 (1699) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v18.19.0, js-controller: 5.0.17
          2024-02-10 23:45:58.740  - info: ble.0 (1699) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
          2024-02-10 23:45:58.741  - info: ble.0 (1699) enabled plugins: _default
          2024-02-10 23:45:58.741  - info: ble.0 (1699) monitoring all services
          2024-02-10 23:45:58.790  - info: ble.0 (1699) starting scanner process...
          2024-02-10 23:45:58.901  - error: ble.0 (1699) Cannot find module '@abandonware/bluetooth-hci-socket'
          Require stack:
          - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js
          - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js
          - /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js
          - /opt/iobroker/node_modules/@abandonware/noble/with-custom-binding.js
          - /opt/iobroker/node_modules/@abandonware/noble/index.js
          - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
          Require stack:
          • wauzziW wauzzi
            Require stack:
            Require stack:
            @wauzzi
            Dann versuch
            cd /opt/iobroker/node_modules
            sudo -H -u iobroker npm i @abandonware/bluetooth-hci-socket --omit=dev
            wauzziW 1 Antwort Letzte Antwort
              @wauzzi
              Dann versuch
              wauzziW Offline
              wauzziW Offline
              wauzzi
              schrieb am zuletzt editiert von wauzzi
              @wauzzi
              Dann versuch
              Ja Geil !!!! Hat geklappt !!! Alles grün und die BT Geräte werden gefunden. MEGA !!!!👯
              Vielen lieben Dank Thomas
              Auch vielen lieben an alle anderen die mir versucht haben zu helfen 💞
              Jetzt kann Charlie wieder selbst nach Hause kommen ;-)
              https://youtu.be/6ebXPKz4bSc?si=bCU5lA-OjBXOasHM
              • W Offline
                W Offline
                wrod
                @wauzzi
                wegen solcher Probleme mit BLE habe ich schon länger ein Skript "fixble.sh" folgenden Inhalts:
                iobroker stop
                sudo apt update
                sudo apt upgrade
                cd /opt/iobroker/node_modules/iobroker.ble
                npm install --omit=dev
                iobroker fix
                sudo reboot
                Dieses startet u.a. npm install.
                Datin wird eine Abfrage gestellt, ob man etwas erneuern will.
                Ich würde das Skript gerne auch unattended (per cron) laufen lassen. (Wie) kann man dabei erreichen, dass diese Abfrage immer als mit "Y" beantwortet gilt, ohne dass ein Eingriff nötig ist?
                Dank im Voraus
