  3. Einsteigerfragen
  4. [gelöst] Javascript Adapter stürzt ab
24 Beiträge 6 Kommentatoren 2.5k Aufrufe 5 Beobachtet
  • blue231181B Offline
    blue231181B Offline
    blue231181
    schrieb am zuletzt editiert von blue231181
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Mitac PC
    Arbeitsspeicher: 8GB
    Festplattenart: SSD
    Betriebssystem: Ubuntu
    Node-Version: 19.9.0
    Nodejs-Version: command not found
    NPM-Version: 9.6.3
    Installationsart: Skript
    ich habe seit 3 Tagen das Problem das mein Javascript Adapter in unregelmäßigen Abständen abstürzt.
    Hier der Log dazu:
    2024-01-15 21:07:00.119 - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 253355
    2024-01-15 21:07:05.103 - info: openweathermap.0 (253355) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v19.9.0, js-controller: 5.0.17
    2024-01-15 21:07:24.977 - info: openweathermap.0 (253355) Terminated (NO_ERROR): Without reason
    2024-01-15 21:07:25.513 - info: host.iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2024-01-15 21:09:17.519 - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
    2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: [241690:0x6791ae0] 8052324 ms: Scavenge 2042.5 (2081.4) -> 2042.0 (2081.9) MB, 15.4 / 0.0 ms (average mu = 0.182, current mu = 0.201) allocation failure;
    2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: [241690:0x6791ae0] 8052350 ms: Scavenge 2043.1 (2081.9) -> 2042.7 (2082.9) MB, 18.4 / 0.0 ms (average mu = 0.182, current mu = 0.201) allocation failure;
    2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: [241690:0x6791ae0] 8052376 ms: Scavenge 2043.9 (2082.9) -> 2043.4 (2087.4) MB, 16.4 / 0.0 ms (average mu = 0.182, current mu = 0.201) allocation failure;
    2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
    2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
    2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[1]: 1: 0xbf9890 node::Abort() [io.javascript.0]
    2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[2]: 2: 0xaf6859 [io.javascript.0]
    2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[3]: 3: 0xddaf80 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0]
    2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[4]: 4: 0xddb336 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0]
    2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[5]: 5: 0xfd9db5 [io.javascript.0]
    2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[6]: 6: 0xfda366 v8::internal::Heap::RecomputeLimits(v8::internal::GarbageCollector) [io.javascript.0]
    2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[7]: 7: 0xfec656 [io.javascript.0]
    2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[8]: 8: 0xfed295 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
    2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[9]: 9: 0xfef978 v8::internal::Heap::HandleGCRequest() [io.javascript.0]
    2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[10]: 10: 0xf69be7 v8::internal::StackGuard::HandleInterrupts() [io.javascript.0]
    2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[11]: 11: 0x13bd365 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
    2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[12]: 12: 0x18443f9 [io.javascript.0]
    2024-01-15 21:09:17.522 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT
    2024-01-15 21:09:17.522 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
    2024-01-15 21:09:17.523 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
    2024-01-15 21:09:47.865 - info: host.iobroker instance system.adapter.javascript.0 started with pid 253608
    2024-01-15 21:09:52.402 - info: javascript.0 (253608) starting. Version 7.1.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v19.9.0, js-controller: 5.0.17
    2024-01-15 21:09:55.489 - info: javascript.0 (253608) requesting all states
    2024-01-15 21:09:55.492 - info: javascript.0 (253608) requesting all objects
    2024-01-15 21:10:01.666 - info: javascript.0 (253608) received all objects
    2024-01-15 21:10:03.022 - info: javascript.0 (253608) received all states
    2024-01-15 21:10:03.796 - info: javascript.0 (253608) Start javascript script.js.2021-04-09-scripts.Abfragen.Garagentor_Auf_Fährt_Zu
    es wurden keine neuen Scripte erstellt oder geändert.
    System läuft auf einem Proxmox Container unter Ubuntu.
    @iobroker:~# npm -v
    9.6.3
    @iobroker:~# node -v
    v19.9.0
    @iobroker:~# nodejs -v
    -bash: nodejs: command not found
    @iobroker:~# iob status
    Objects type: jsonl
    States  type: jsonl
    Danke im voraus und viele Grüße
    CodierknechtC haus-automatisierungH HomoranH Thomas BraunT 4 Antworten Letzte Antwort
    • blue231181B blue231181
      Festplattenart: SSD
      NPM-Version: 9.6.3
      Hier der Log dazu:
      @iobroker:~# npm -v
      9.6.3
      v19.9.0
      Objects type: jsonl
      States  type: jsonl
      CodierknechtC Online
      Codierknecht
      @blue231181 sagte in Javascript Adapter stürzt ab:
      Was sagt
      iob diag
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
        Festplattenart: SSD
        NPM-Version: 9.6.3
        Hier der Log dazu:
        @iobroker:~# npm -v
        9.6.3
        v19.9.0
        Objects type: jsonl
        States  type: jsonl
        haus-automatisierungH Offline
        Für die nodejs und npm version wirst du gleich auf die Finger bekommen :) Zieh das erstmal gerade. Wie ist das nodejs auf das System gekommen? Wahrscheinlich nicht über apt?!
          Festplattenart: SSD
          NPM-Version: 9.6.3
          Hier der Log dazu:
          @iobroker:~# npm -v
          9.6.3
          v19.9.0
          Objects type: jsonl
          States  type: jsonl
          v19.9.0
          wie kommst du denn an das krumme Ding?
            Codierknecht
            @haus-automatisierung sagte in Javascript Adapter stürzt ab:
            3 ... 2 ... 1 😁
              Festplattenart: SSD
              NPM-Version: 9.6.3
              Hier der Log dazu:
              @iobroker:~# npm -v
              9.6.3
              v19.9.0
              Objects type: jsonl
              States  type: jsonl
              @blue231181
              NICHT als root herumhampeln. (Auch wenn du den verschämt löschst sieht man das noch...)
              Als USER!:
              iob nodejs-update 18
                blue231181B Offline
                blue231181
                @Codierknecht
                @haus-automatisierung (wow ich glaubs nicht mein persönlicher youtube Held 💓 😳 , danke für all die genialen Videos und super Erklärungen)
                @Homoran
                euch allen Danke erstmal das ihr hier im Forum so aktiv seid und es zu dem macht was ioBroker ausmacht
                @Codierknecht ich habe einen neuen Benutzer angelegt. @Thomas-Braun hat recht ich habe es zu meiner Schande schön verstecken wollen. Nun mit dem neuen Benutzer kommt folgende Meldung:
                Sorry, user blue2311 is not allowed to execute '/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh' as iobroker on iobroker.local.
                Also habe ich das folgende durchgelesen: ioBroker Forum diag-skript was ich feststellen musste, von @Thomas-Braun entwickelt wurde. Hier hat Thomas wohl auch die LXC Container (Proxmox) mit auslesen können.
                Nun habe ich mal meine Version überprüft und folgendes ist heraus gekommen:
                blue2311@iobroker:~$ cat /etc/*release
                PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                NAME="Debian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=debian
                HOME_URL="https://www.debian.org/"
                SUPPORT_URL="https://www.debian.org/support"
                BUG_REPORT_URL="https://bugs.debian.org/"
                Also muss ich zu meiner weiteren Schande gestehen das es kein Ubuntu System ist, sondern ein Bullseye 11 Debian.
                @haus-automatisierung "Für die nodejs und npm version wirst du gleich auf die Finger bekommen 🙂 Zieh das erstmal gerade. Wie ist das nodejs auf das System gekommen? Wahrscheinlich nicht über apt?!" mit "apt-get" konnte ich diverse updates fahren..
                "Für die nodejs und npm version wirst du gleich auf die Finger bekommen" bitte nicht. Ich bin kein entwickler, hab auch niemals Informatiker gelernt aber mir macht es als Hobby Spass und ich bin unendlich dankbar hier im Forum immer wieder auf so nette und hilfsbereite Menschen zu treffen. Also nicht hauen 😖
                und zu guter letzt @Thomas-Braun:
                blue2311@iobroker:~$ iob nodejs-update 18
                [sudo] password for blue2311:
                Sorry, user blue2311 is not allowed to execute '/usr/bin/curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh' as iobroker on iobroker.local.
                Thomas BraunT HomoranH haus-automatisierungH 4 Antworten Letzte Antwort
                  @Codierknecht
                  @Homoran
                  VERSION_ID="11"
                  ID=debian
                  blue2311
                  Dann ist der user nicht in den rudimentärsten Gruppen drin.
                  Als dieser User:
                  groups
                    @Codierknecht
                    @Homoran
                    VERSION_ID="11"
                    ID=debian
                    das gilt hier für >90% der User.
                    aber node v19 kommt dann üblicherweise nicht bei raus
                    das ist das Problem wenn nicht von Anfang an mit dem User gearbeitet wird, dann hat er nicht automatisch die notwendigen Rechte und/oder die Nutzung von Root hat gewisse Rechte verbogen, dass der Systemuser iobroker und dein neuer User da nicht dran dürfen.
                    Erschwerend kommt dein Konstrukt mit Container dazu, wo wiederum zusätzlich Dinge richtig eingestellt sein müssen
                      @Codierknecht
                      @Homoran
                      VERSION_ID="11"
                      ID=debian
                      @blue231181
                      In der Doku steht auch drin, wie man im Container einen user anlegt:
                      https://www.iobroker.net/#de/documentation/install/proxmox.md
                      blue231181B 1 Antwort Letzte Antwort
                        @blue231181
                        blue231181B Offline
                        blue231181B Offline
                        blue231181
                        @thomas-braun @Homoran also wäre eine Neuinstallation mit einspielen des Backups am sinnvollsten wenn so viel schief liegt?
                          Das musst du selber entscheiden.
                            blue231181B Offline
                            blue231181B Offline
                            blue231181
                            @thomas-braun ja ich versuchs mit Neuinstallation bevor ich das krumme System anpasse
                            Danke an alle
                              @Codierknecht
                              @Homoran
                              VERSION_ID="11"
                              ID=debian
                              @blue231181 sagte in [gelöst] Javascript Adapter stürzt ab:
                              Gern, dort habe ich übrigens auch gezeigt wie man einen neuen Benutzer im LXC anlegt usw.
                              https://youtu.be/p6XmgzhH0Ow?si=ybEmskSEjmE_c6vc&t=1113
                                blue231181B Offline
                                blue231181B Offline
                                blue231181
                                muss hier leider wieder öffnen.
                                Habe nach bestem Wissen und gewissen mein System gerade gezogen
                                Leider stürzt der Javascript Adapter weiterhin ab.
                                Hier der Auszug vom Iob Diag
                                ======== Start marking the full check here =========
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                   Static hostname: iobroker
                                         Icon name: computer-container
                                           Chassis: container
                                    Virtualization: lxc
                                  Operating System: Debian GNU/Linux 11 (bullseye)
                                            Kernel: Linux 5.15.131-2-pve
                                      Architecture: x86-64
                                model name      : Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz
                                Docker          : false
                                Virtualization  : lxc
                                Kernel          : x86_64
                                Userland        : amd64
                                Systemuptime and Load:
                                 05:45:53 up 21:39,  1 user,  load average: 1.82, 1.66, 1.35
                                CPU threads: 4
                                *** Time and Time Zones ***
                                               Local time: Thu 2024-01-18 05:45:53 CET
                                           Universal time: Thu 2024-01-18 04:45:53 UTC
                                                 RTC time: n/a
                                              NTP service: inactive
                                          RTC in local TZ: no
                                *** User and Groups ***
                                blue2311
                                /home/blue2311
                                blue2311 sudo
                                *** X-Server-Setup ***
                                X-Server:       false
                                Desktop:
                                Terminal:
                                *** MEMORY ***
                                Mem:            7.8G        3.7G        3.5G        0.0K        592M        4.1G
                                Swap:             0B          0B          0B
                                Total:          7.8G        3.7G        3.5G
                                         7822 M total memory
                                         3689 M used memory
                                          167 M active memory
                                         3918 M inactive memory
                                         3541 M free memory
                                            0 M buffer memory
                                          592 M swap cache
                                            0 M total swap
                                            0 M used swap
                                            0 M free swap
                                *** FAILED SERVICES ***
                                  UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                                * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
                                * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
                                * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
                                3 loaded units listed.
                                *** FILESYSTEM ***
                                Filesystem                       Type      Size  Used Avail Use% Mounted on
                                /dev/mapper/pve-vm--100--disk--0 ext4       42G   11G   29G  27% /
                                none                             tmpfs     492K  4.0K  488K   1% /dev
                                /dev/mapper/pve-root             ext4       29G   20G  7.7G  73% /dev/ttyACM0
                                udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
                                tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
                                tmpfs                            tmpfs     1.6G  104K  1.6G   1% /run
                                tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                                dmesg: read kernel buffer failed: Operation not permitted
                                Show mounted filesystems \(real ones only\):
                                TARGET         SOURCE                                                 FSTYPE OPTIONS
                                /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
                                `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/189/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
                                /var:
                                3.2G    /var/
                                2.6G    /var/log/journal/4b4c08ea54a04d2e89ddb21f3e8976ed
                                2.6G    /var/log
                                466M    /var/cache
                                Archived and active journals take up 8.0M in the file system.
                                /opt/iobroker/backups:
                                521M    /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                2.3G    /opt/iobroker/iobroker-data/
                                1.1G    /opt/iobroker/iobroker-data/history
                                706M    /opt/iobroker/iobroker-data/files
                                299M    /opt/iobroker/iobroker-data/backup-objects
                                142M    /opt/iobroker/iobroker-data/files/vis.0
                                70M     /opt/iobroker/iobroker-data/objects.jsonl
                                65M     /opt/iobroker/iobroker-data/states.jsonl
                                41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                40M     /opt/iobroker/iobroker-data/objects.json.migrated
                                40M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                USB-Devices by-id:
                                USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                                /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2410075-if00
                                *** NodeJS-Installation ***
                                /usr/bin/nodejs         v18.19.0
                                /usr/bin/node           v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                /usr/bin/corepack       0.22.0
                                nodejs:
                                  Installed: 18.19.0-1nodesource1
                                  Candidate: 18.19.0-1nodesource1
                                  Version table:
                                 *** 18.19.0-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                        100 /var/lib/dpkg/status
                                     18.18.2-1nodesource1 1001
                                     18.18.1-1nodesource1 1001
                                     18.18.0-1nodesource1 1001
                                     18.17.1-1nodesource1 1001
                                     18.17.0-1nodesource1 1001
                                     18.16.1-1nodesource1 1001
                                     18.16.0-1nodesource1 1001
                                     18.15.0-1nodesource1 1001
                                     18.14.2-1nodesource1 1001
                                     18.14.1-1nodesource1 1001
                                     18.14.0-1nodesource1 1001
                                     18.13.0-1nodesource1 1001
                                     18.12.0-1nodesource1 1001
                                     18.11.0-1nodesource1 1001
                                     18.10.0-1nodesource1 1001
                                     18.9.1-1nodesource1 1001
                                     18.9.0-1nodesource1 1001
                                     18.8.0-1nodesource1 1001
                                     18.7.0-1nodesource1 1001
                                     18.6.0-1nodesource1 1001
                                     18.5.0-1nodesource1 1001
                                     18.4.0-1nodesource1 1001
                                     18.3.0-1nodesource1 1001
                                     18.2.0-1nodesource1 1001
                                     18.1.0-1nodesource1 1001
                                     18.0.0-1nodesource1 1001
                                     12.22.12~dfsg-1~deb11u4 500
                                        500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                        500 http://security.debian.org bullseye-security/main amd64 Packages
                                No problems detected
                                Errors in npm tree:
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Core adapters versions
                                admin:          6.12.0
                                javascript:     7.1.6
                                Adapters from github:   4
                                Adapter State
                                  system.adapter.admin.1                  : admin                 : iobroker                                 - disabled, port: 8083, bind: 0.0.0.0, run as: admin
                                + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled
                                  system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                  system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
                                + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                                  system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                                  system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                  system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                  system.adapter.email.0                  : email                 : iobroker                                 - disabled
                                  system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
                                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                  system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                  system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
                                  system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                                  system.adapter.heizoel.0                : heizoel               : iobroker                                 - disabled
                                + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                                  system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                                  system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                                + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                                + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  system.adapter.kodi.0                   : kodi                  : iobroker                                 - disabled, port: 8080
                                  system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
                                  system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
                                + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                                + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
                                  system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                                + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                                + system.adapter.proxmox.1                : proxmox               : iobroker                                 -  enabled, port: 8006
                                + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                  system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
                                + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 7770, bind: 0.0.0.0, run as: admin
                                  system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
                                + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 7769, bind: 0.0.0.0, run as: admin
                                  system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 -  enabled
                                + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                  system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
                                + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                  system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 - disabled
                                + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                                  system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                  system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                  system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                                  system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
                                  system.adapter.windows-control.0        : windows-control       : iobroker                                 - disabled
                                + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                                  system.adapter.worx.0                   : worx                  : iobroker                                 - disabled
                                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                                + instance is alive
                                ioBroker-Repositories
                                New           : http://iobroker.live/repo/sources-dist.json
                                Active repo(s): stable
                                Installed ioBroker-Instances
                                Used repository: stable
                                Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                                Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                                Adapter    "coronavirus-statistics": 0.9.0, installed 0.8.8-0 [Updatable]
                                Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                                Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
                                Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                                Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                Adapter    "email"        : 1.2.1    , installed 1.2.1
                                Adapter    "eusec"        : 1.2.1    , installed 1.2.1
                                Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                                Adapter    "fullybrowser" : 3.0.9    , installed 2.0.4  [Updatable]
                                Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                                Adapter    "hmip"         : 1.21.0   , installed 1.21.0
                                Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                                Adapter    "icons-material-png": 0.1.0, installed 0.1.0
                                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
                                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                Adapter    "info"         : 2.0.0    , installed 2.0.0
                                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                Controller "js-controller": 5.0.17   , installed 5.0.17
                                Adapter    "kodi"         : 3.0.0    , installed 3.0.0
                                Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                Adapter    "logparser"    : 2.2.1    , installed 2.2.1
                                Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
                                Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                                Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                                Adapter    "scenes"       : 2.3.9    , installed 2.3.9
                                Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                Adapter    "snmp"         : 3.1.0    , installed 2.4.11 [Updatable]
                                Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
                                Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
                                Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
                                Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
                                Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                Adapter    "tuya"         : 3.15.0   , installed 3.6.5  [Updatable]
                                Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.4  [Updatable]
                                Adapter    "unifi"        : 0.6.7    , installed 0.6.6  [Updatable]
                                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                                Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
                                Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                                Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
                                Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                                Adapter    "web"          : 6.1.10   , installed 6.1.10
                                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                Adapter    "windows-control": 0.1.5  , installed 0.1.5
                                Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                Adapter    "worx"         : 2.3.4    , installed 2.1.3  [Updatable]
                                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                Adapter    "zigbee"       : 1.9.7    , installed 1.8.24 [Updatable]
                                Objects and States
                                Objects:        32363
                                States:         26941
                                Hit:1 http://security.debian.org bullseye-security InRelease
                                Hit:2 http://ftp.debian.org/debian bullseye InRelease
                                Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                Reading package lists...
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       46666067   120/iobroker.js-con
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       46666075   120/iobroker.js-con
                                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          46667947   289/master
                                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        46666916   108/systemd-resolve
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          46665812   1/init
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       47647964   30207/io.sonoff.0
                                tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        46666910   108/systemd-resolve
                                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          46667948   289/master
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       46677868   1462/io.web.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       46666242   307/io.admin.0
                                tcp6       0      0 :::8000                 :::*                    LISTEN      1000       46683978   1398/io.upnp.0
                                tcp6       0      0 :::7770                 :::*                    LISTEN      1000       46676821   1261/io.simple-api.
                                tcp6       0      0 :::7769                 :::*                    LISTEN      1000       46676885   1284/io.socketio.0
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          46665611   1/init
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          46665814   1/init
                                tcp6       0      0 :::5355                 :::*                    LISTEN      104        46666913   108/systemd-resolve
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       46678967   1473/io.wled.0
                                udp        0      0 192.168.178.100:5353    0.0.0.0:*                           1000       46671958   548/io.tr-064.0
                                udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        46666909   108/systemd-resolve
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       46972090   8939/io.shelly.0
                                udp        0      0 0.0.0.0:54955           0.0.0.0:*                           1000       46678822   1398/io.upnp.0
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       46677926   1398/io.upnp.0
                                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       46670144   565/io.tuya.0
                                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       46670145   565/io.tuya.0
                                udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        46666915   108/systemd-resolve
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          46665813   1/init
                                udp6       0      0 :::5355                 :::*                                104        46666912   108/systemd-resolve
                                udp6       0      0 :::111                  :::*                                0          46665815   1/init
                                2024-01-18 05:42:06.483  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634911.225508433.HWv1" has to be type "string" but received type "number"
                                2024-01-18 05:42:06.851  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634911.225508433.NOP" has to be type "number" but received type "string"
                                2024-01-18 05:42:08.285  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.DEV_TYP1" has to be type "number" but received type "string"
                                2024-01-18 05:42:08.365  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.COMM_PTC_v1" has to be type "string" but received type "number"
                                2024-01-18 05:42:08.419  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.HWv1" has to be type "string" but received type "number"
                                2024-01-18 05:42:08.856  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.NOP" has to be type "number" but received type "string"
                                2024-01-18 05:42:10.733  - error: zigbee.0 (583) Send command to 0xc4988600000060aa failed with no error code (no response received (161)
                                2024-01-18 05:42:10.808  - info: solarmanpv.0 (120094) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                2024-01-18 05:42:11.349  - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-01-18 05:45:00.070  - info: host.iobroker instance system.adapter.ical.1 started with pid 120404
                                2024-01-18 05:45:00.202  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Durchgang Zähler LUX : 10
                                2024-01-18 05:45:00.202  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aktuelle LUX = 0
                                2024-01-18 05:45:00.204  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aussenlichtstaerke Mittelwert = 0
                                2024-01-18 05:45:00.205  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Zahlen aufsteigend sortiert: 0,0,0,0,0,0,0,0,0,0
                                2024-01-18 05:45:00.206  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Auswahl der Liste 7-9 : 0,0,0,0,0,0
                                2024-01-18 05:45:00.206  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: errechneter Mittelwert: 0
                                2024-01-18 05:45:03.942  - info: ical.1 (120404) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                                2024-01-18 05:45:12.852  - info: ical.1 (120404) Terminated (NO_ERROR): Without reason
                                2024-01-18 05:45:13.399  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                iob diag has finished.
                                Press any key for a summary
                                                        v.2023-10-10
                                           Chassis: container
                                    Virtualization: lxc
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               amd64
                                Timezone:               Europe/Berlin (CET, +0100)
                                User-ID:                1001
                                X-Server:               false
                                Pending OS-Updates:     0
                                Pending iob updates:    10
                                Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                        /usr/bin/npm            10.2.3
                                                        /usr/bin/npx            10.2.3
                                Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                MEMORY:
                                Mem:            7.8G        3.8G        3.3G        0.0K        703M        4.0G
                                Swap:             0B          0B          0B
                                Total:          7.8G        3.8G        3.3G
                                Active iob-Instances:   40
                                ioBroker Core:          js-controller           5.0.17
                                                        admin                   6.12.0
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                32363
                                States:                 26941
                                Size of iob-Database:
                                81M     /opt/iobroker/iobroker-data/objects.jsonl
                                9.5M    /opt/iobroker/iobroker-data/states.json.migrated
                                9.5M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                9.4M    /opt/iobroker/iobroker-data/states.jsonl
                                Hier der Auszug aus den Logs:
                                2024-01-17 22:12:07.737 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.DEV_TYP1" has to be type "number" but received type "string"
                                2024-01-17 22:12:07.819 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.COMM_PTC_v1" has to be type "string" but received type "number"
                                2024-01-17 22:12:07.873 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.HWv1" has to be type "string" but received type "number"
                                2024-01-17 22:12:08.290 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.NOP" has to be type "number" but received type "string"
                                2024-01-17 22:12:09.634 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.DEV_TYP1" has to be type "number" but received type "string"
                                2024-01-17 22:12:09.721 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.COMM_PTC_v1" has to be type "string" but received type "number"
                                2024-01-17 22:12:09.774 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.HWv1" has to be type "string" but received type "number"
                                2024-01-17 22:12:10.226 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.NOP" has to be type "number" but received type "string"
                                2024-01-17 22:12:11.201 - info: solarmanpv.0 (79070) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                2024-01-17 22:12:11.740 - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-01-17 22:14:19.619 - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
                                2024-01-17 22:14:19.619 - error: host.iobroker Caught by controller[0]: [64004:0x6cde870] 9870984 ms: Scavenge 2044.5 (2084.6) -> 2044.0 (2085.4) MB, 14.7 / 0.0 ms (average mu = 0.183, current mu = 0.193) allocation failure;
                                2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
                                2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 1: 0xb95b60 node::Abort() [io.javascript.0]
                                2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 2: 0xa9a7f8 [io.javascript.0]
                                2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                                2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                                2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[0]: 5: 0xf4cba5 [io.javascript.0]
                                2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[0]: 6: 0xf4daa8 v8::internal::Heap::RecomputeLimits(v8::internal::GarbageCollector) [io.javascript.0]
                                2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[1]: 7: 0xf5dfb3 [io.javascript.0]
                                2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[1]: 8: 0xf5ee28 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                                2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[1]: 9: 0xf3978e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                                2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[2]: 10: 0xf3ab57 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                                2024-01-17 22:14:19.622 - error: host.iobroker Caught by controller[2]: 11: 0xf1bd2a v8::internal::Factory::NewFillerObject(int, v8::internal::AllocationAlignment, v8::internal::AllocationType, v8::internal::AllocationOrigin) [io.javascript.0]
                                2024-01-17 22:14:19.622 - error: host.iobroker Caught by controller[2]: 12: 0x12e114f v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                                2024-01-17 22:14:19.622 - error: host.iobroker Caught by controller[3]: 13: 0x170deb9 [io.javascript.0]
                                2024-01-17 22:14:19.622 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT
                                2024-01-17 22:14:19.623 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
                                2024-01-17 22:14:19.623 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
                                2024-01-17 19:24:00.046 - info: host.iobroker instance system.adapter.solarmanpv.0 started with pid 63515
                                2024-01-17 19:24:03.269 - info: solarmanpv.0 (63515) starting. Version 0.5.1 (non-npm: raschy/ioBroker.solarmanpv) in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v18.19.0, js-controller: 5.0.17
                                2024-01-17 19:24:08.390 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.DEV_TYP1" has to be type "number" but received type "string"
                                2024-01-17 19:24:08.475 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.COMM_PTC_v1" has to be type "string" but received type "number"
                                2024-01-17 19:24:08.531 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.HWv1" has to be type "string" but received type "number"
                                2024-01-17 19:24:08.934 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.NOP" has to be type "number" but received type "string"
                                2024-01-17 19:24:10.435 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.DEV_TYP1" has to be type "number" but received type "string"
                                2024-01-17 19:24:10.507 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.COMM_PTC_v1" has to be type "string" but received type "number"
                                2024-01-17 19:24:10.562 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.HWv1" has to be type "string" but received type "number"
                                2024-01-17 19:24:10.973 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.NOP" has to be type "number" but received type "string"
                                2024-01-17 19:24:12.062 - info: solarmanpv.0 (63515) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                2024-01-17 19:24:12.644 - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-01-17 19:25:00.192 - info: javascript.0 (51920) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Durchgang Zähler LUX : 7
                                2024-01-17 19:25:00.194 - info: javascript.0 (51920) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aktuelle LUX = 0
                                2024-01-17 19:25:00.194 - info: javascript.0 (51920) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aussenlichtstaerke Mittelwert = 0
                                2024-01-17 19:29:07.194 - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
                                2024-01-17 19:29:07.195 - error: host.iobroker Caught by controller[0]: [51920:0x717f870] 8062565 ms: Scavenge 2044.2 (2084.9) -> 2043.7 (2089.4) MB, 16.4 / 0.0 ms (average mu = 0.179, current mu = 0.167) allocation failure;
                                2024-01-17 19:29:07.195 - error: host.iobroker Caught by controller[0]: [51920:0x717f870] 8068108 ms: Mark-sweep (reduce) 2045.7 (2089.4) -> 2044.7 (2084.1) MB, 4609.8 / 0.0 ms (+ 97.8 ms in 31 steps since start of marking, biggest step 5.9 ms, walltime since start of marking 4746 ms) (average mu = 0.172, current mu = 0.164
                                2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[1]: <--- JS stacktrace --->
                                2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[2]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[3]: 1: 0xb95b60 node::Abort() [io.javascript.0]
                                2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[4]: 2: 0xa9a7f8 [io.javascript.0]
                                2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[5]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                                2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[6]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                                2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[7]: 5: 0xf4cba5 [io.javascript.0]
                                2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[8]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                                2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[9]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [io.javascript.0]
                                2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[10]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [io.javascript.0]
                                2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[11]: 9: 0x12e0bcf v8::internal::Runtime_StackGuardWithGap(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                                2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[12]: 10: 0x170deb9 [io.javascript.0]
                                2024-01-17 19:29:07.197 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT
                                2024-01-17 19:29:07.198 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
                                2024-01-17 19:29:07.198 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
                                2024-01-17 19:29:37.457 - info: host.iobroker instance system.adapter.javascript.0 started with pid 64004
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                             Chassis: container
                                      Virtualization: lxc
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  CPU threads: 4
                                                   RTC time: n/a
                                            RTC in local TZ: no
                                  blue2311
                                  /home/blue2311
                                  blue2311 sudo
                                  X-Server:       false
                                  Desktop:
                                  Terminal:
                                  *** MEMORY ***
                                  Swap:             0B          0B          0B
                                           7822 M total memory
                                           3689 M used memory
                                            167 M active memory
                                           3541 M free memory
                                              0 M buffer memory
                                            592 M swap cache
                                              0 M total swap
                                              0 M used swap
                                              0 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  3.2G    /var/
                                  2.6G    /var/log
                                  466M    /var/cache
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.12.0
                                  javascript:     7.1.6
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        32363
                                  States:         26941
                                  Pending Updates: 0
                                                          v.2023-10-10
                                             Chassis: container
                                      Virtualization: lxc
                                  Installation:           lxc
                                  Kernel:                 x86_64
                                  Userland:               amd64
                                  User-ID:                1001
                                  X-Server:               false
                                                          /usr/bin/npm            10.2.3
                                                          /usr/bin/npx            10.2.3
                                  MEMORY:
                                  Swap:             0B          0B          0B
                                                          admin                   6.12.0
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                32363
                                  States:                 26941
                                  Codierknecht
                                  @blue231181
                                  1.) Entferne die privaten Daten aus dem Log!
                                  2.) Was passiert, wenn Du alle Scripte mal stoppst? Bleibt der Adapter am Leben?
                                  • CodierknechtC Codierknecht
                                    @blue231181
                                    blue231181B Offline
                                    blue231181B Offline
                                    blue231181
                                    @codierknecht private daten...? meine IP Adresse?
                                    Stimmt das könnte ich versuchen. Alle Skripte beenden, und nach und nach wieder starten. Das wird ein längerer Akt weil der Fehler nur alle 3 Stunden auftritt, aber ich versuche es
                                      Codierknecht
                                      Nein - Die Kalender-ID's ;-)
                                      In der Langfassung von diag.
                                      Und was passiert alle 3 Stunden?
                                      Läuft der vielleicht in genau diesem Intervall?
                                      mcm1957M blue231181B 2 Antworten Letzte Antwort
                                        mcm1957M Offline
                                        mcm1957M Offline
                                        mcm1957
                                        Keine Ahnung ob das auch hier zutreffen könnte - einen Zusammenhang mit 3h Intervall sehe ich da nicht - aber hier ging es um einen Crash des Javascript Adapters bei eine zu größen Anzahl von States (70.000 Alarmstates des unifi Adapters)
                                        https://github.com/ioBroker/ioBroker.javascript/issues/1467
                                        Support Repositoryverwaltung.
                                        LESEN - gute Forenbeitrage
                                          blue231181B Offline
                                          blue231181B Offline
                                          blue231181
                                          @codierknecht Danke für den Hinweis
                                          Was euch alles auffällt :man-facepalming:
                                          Also der Solarmanpv läuft alle 8 Min.
                                          3 stunden Intervall ist mir nichts bekannt. Ich habe alle Scripte nun mal deaktiviert und teste mich durch.
                                          @mcm57 den Adapter habe ich schon deaktiviert und die zugehörigen States gelöscht, ja damit hatte ich auch Probleme und massiv viele States die er mir angelegt hat
                                          CodierknechtC mcm1957M 2 Antworten Letzte Antwort
