  3. Entwicklung
  4. Neuer Adapter - Android TV & Fire TV Benachrichtigungen
81 Beiträge 20 Kommentatoren 15.7k Aufrufe 26 Beobachtet
  • ? Offline
    #41
    @stolly82
    seit V2.3.0, Host Docker V9.0.1, alles latest.
    2024-01-09 11:03:38.210  - info: host.iobroker "system.adapter.notificationforandroidtv.0" enabled
    2024-01-09 11:03:38.304  - info: host.iobroker instance system.adapter.notificationforandroidtv.0 started with pid 3609
    2024-01-09 11:03:39.597  - info: notificationforandroidtv.0 (3609) starting. Version 2.3.0 (non-npm: DNAngelX/ioBroker.notificationforandroidtv) in /opt/iobroker/node_modules/iobroker.notificationforandroidtv, node: v18.19.0, js-controller: 5.0.17
    2024-01-09 11:03:39.607  - error: notificationforandroidtv.0 (3609) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-01-09 11:03:39.611  - error: notificationforandroidtv.0 (3609) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-01-09 11:03:39.612  - error: notificationforandroidtv.0 (3609) unhandled promise rejection: Cannot read properties of undefined (reading 'error')
    2024-01-09 11:03:39.612  - error: notificationforandroidtv.0 (3609) TypeError: Cannot read properties of undefined (reading 'error')
        at Notificationforandroidtv.onReady (/opt/iobroker/node_modules/iobroker.notificationforandroidtv/main.js:338:22)
        at Notificationforandroidtv.emit (node:events:517:28)
        at Notificationforandroidtv._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9118:18)
        at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9097:26
    2024-01-09 11:03:39.612  - error: notificationforandroidtv.0 (3609) Cannot read properties of undefined (reading 'error')
    2024-01-09 11:03:39.608  - error: notificationforandroidtv.0 (3609) unhandled promise rejection: Cannot read properties of undefined (reading 'error')
    2024-01-09 11:03:39.610  - error: notificationforandroidtv.0 (3609) TypeError: Cannot read properties of undefined (reading 'error')
    2024-01-09 11:03:39.610  - error: notificationforandroidtv.0 (3609) Cannot read properties of undefined (reading 'error')
    2024-01-09 11:03:39.611  - info: notificationforandroidtv.0 (3609) registerNotification not processed because States database not connected
    2024-01-09 11:03:39.620  - info: notificationforandroidtv.0 (3609) terminating
    2024-01-09 11:03:39.621  - warn: notificationforandroidtv.0 (3609) Terminated (UNCAUGHT_EXCEPTION): Without reason
    stolly82S 1 Antwort Letzte Antwort
      @stolly82
      stolly82S Offline
      stolly82S Offline
      stolly82
      #42
      @ilovegym
      Hmm, merkwürdig. Ich bekomme den im dev System und live nicht.
      Ich schaue noch mal
      ? 1 Antwort Letzte Antwort
      • stolly82S stolly82
        @ilovegym
        Ich schaue noch mal
        #43
        @stolly82
        hab den Fehler gefunden, ich musste die Konfig neu anlegen, deshalb auch der Fehler im Log mit unexpected json ...
        Ich habe in der Konfig den Namen mit Leerzeichen versehen, also Fire TV Keller, da tritt der Fehler auf, wenn ich als Name FireTVKeller eintrage, geht alles...
        Edit:
        Zu frueh gefreut, hab alle 9 auf einmal angelegt, gleicher Fehler... ((
        Edit2:
        Also, ein FireTV angelegt, gespeichert, Adapter laeuft.
        Naechster Firetv in der Konfig angelegt, gespeichert, Adapter laeuft... so gehts.. beim neunten isser dann wieder abgestuerzt, hab ihn geloescht und nochmal angelegt (also den neunten FireTV), seitdem gehts...
        Denke, wenn du in der Konfig-Json suchst, biste richtig.. vielleicht kam das ja auch erst mit Admin 6.13.15..
        • wendy2702W Online
          wendy2702W Online
          wendy2702
          #44
          Geht mit dem Adapter und Notification for Android auch ein Live Stream einer Kamera?
          L 1 Antwort Letzte Antwort
          • wendy2702W wendy2702
            L Online
            L Online
            Lucky_ESA
            #45
            @wendy2702 sagte in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
            Dazu müsste noch die APP PiPup implementiert werden.
            Gruß//Lucky
            • L Lucky_ESA
              Gruß//Lucky
              wendy2702W Online
              wendy2702W Online
              wendy2702
              #46
              @lucky_esa Ja,
              Mit Pipup und Blockly mache ich es aktuell.
              Dachte es würde hiermit auch schon gehen.
                @lucky_esa Ja,
                L Online
                L Online
                Lucky_ESA
                #47
                @lucky_esa Ja,
                Ein Adapter wäre immer die bessere Lösung. Vielleicht implementiert @stolly82 PiPup noch.
                Gruß//Lucky
                • L Lucky_ESA
                  @lucky_esa Ja,
                  Gruß//Lucky
                  stolly82S Offline
                  stolly82S Offline
                  stolly82
                  #48
                  @lucky_esa
                  HMMMM, gar nicht mal so doof die Idee!
                  Schon mal, da die Configs ja schon alle da sind, sollte das nicht so schwer sein ;-)
                  Ich schaue mal
                    @lucky_esa
                    Ich schaue mal
                    L Online
                    L Online
                    Lucky_ESA
                    #49
                    @stolly82 sagte in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
                    @lucky_esa
                    Ich schaue mal
                    Hier wäre die API
                    readme.md
                    Gruß//Lucky
                      @stolly82
                      Edit:
                      Edit2:
                      stolly82S Offline
                      stolly82S Offline
                      stolly82
                      #50
                      @ilovegym
                      Objekt payload hatte ich nicht geprüft, wenn "leer" dann war es kein JSON und somit ist der Adapter abgestürzt.
                      Ist behoben, bekomme den über das DEV Portal nur nicht in add to latest
                      • L Lucky_ESA
                        @lucky_esa
                        Ich schaue mal
                        Hier wäre die API
                        readme.md
                        Gruß//Lucky
                        stolly82S Offline
                        stolly82S Offline
                        stolly82
                        #51
                        @lucky_esa
                        Ich muss das App erstmal auf die FireTV's drauf bekommen.
                        Grusel 😖
                        So, the tutorial:
                        Installing PiPup
                        Download ADB drivers (Platform-Tools) for the device you’re using from here 138. On windows you just unzip the file, open terminal there and everything should work. People using linux - you know what to do.
                        Enable ADB and connect to the TV: follow this 166, it’s way better than what I can write.
                        Download Pipup from here 156 (app-debug.apk file). Put it in the directory with ADB drivers
                        In the terminal you have open run: adb sideload app-debug.apk (you must already be connected to TV, so don’t forget adb connect <IP> from the last step)
                        Grant needed permission with: adb shell appops set nl.rogro82.pipup SYSTEM_ALERT_WINDOW allow
                        Open the app on your TV, you can close it pretty much immediately, it just needs to run in the background
                        • BananaJoeB Offline
                          BananaJoeB Offline
                          BananaJoe
                          #52
                          Kann PiPup denn RSTP-Streams? Das wäre der Kamera Standard. Oder "nur" Video?
                          Das Issue dazu ist noch offen, https://github.com/rogro82/PiPup/issues/8
                          Ich habe nur einen gefunden der das Video vorher über WebRTC umwandelt/bereitstellt.
                          • BananaJoeB BananaJoe
                            BananaJoeB Offline
                            BananaJoeB Offline
                            BananaJoe
                            #53
                            @bananajoe Nachtrag: Direkt das Bild von der Kamera zu holen klappt mit dem Adapter nicht (was aber wohl an der App auf Android liegen wird), ich hole es erst auf den ioBroker und stelle es dort bereit. Die App hat wohl nicht die gedult auf das Bild zu warten (Reolink Kameras)
                              @ilovegym
                              mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              #54
                              @stolly82 said in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
                              @ilovegym
                              Du brauchst nur EINMAL ein "add to latest" auslösen. Dein PR existiert als https://github.com/ioBroker/ioBroker.repositories/pull/3189.
                              Das Review ist noch pending.
                              Neue Releases brauchen für das latest Repository KEINEN neuerlichen Aufruf via dev Protal. Sobald ein Adapter für Latest freigeschaltet ist wird er im latest Repositpory automatisch aktualisisert. Nur fürs stable Repo musst du später einen Reqeust per Release stellen (dazu gibts dann aber ggF Erinnerungen)
                              Support Repositoryverwaltung.
                              LESEN - gute Forenbeitrage
                              • wendy2702W Online
                                wendy2702W Online
                                wendy2702
                                #55
                                @BananaJoe Ich nutze den http Stream aus Motioneye. RTSP direkt geht wohl nicht weil die auch im Browser nicht mehr gehen.
                                  BananaJoeB Offline
                                  BananaJoeB Offline
                                  BananaJoe
                                  #56
                                  @wendy2702 könnte ich bei mir auch machen (aus BlueIris). Hab dann aber irgendwann entschieden das ein Bild pro Sekunde auch reicht um zusehen wer da steht.
                                  Der Stream war immer eine ganz schöne Last ... und es hat lange gedauert bis das System erkannt hat das auf der anderen Seite gar keiner mehr zu hört und wieder runter geschaltet hat.
                                    @matthsc said in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
                                    @matthsc Hey, du willst praktisch ein JSON payload übergeben?
                                    {message:"BLA",'image_url:'http://bla.gif''} ?
                                    Ja, genau :-)
                                    Erledigt!
                                    Changelog
                                    2.3.0 (2024-01-08)
                                    • (DNAngel) extended payload possibility as message object
                                    matthscM Offline
                                    matthscM Offline
                                    matthsc
                                    #57
                                    Erledigt!
                                    Changelog
                                    2.3.0 (2024-01-08)
                                    Danke dir, funktioniert einwandfrei!
                                    • stolly82S Offline
                                      stolly82S Offline
                                      stolly82
                                      #58
                                      Ich hatte mich gestern dran gesetzt und PiPup eingearbeitet.
                                      El Question:
                                      hat schon mal jemand PiPup auf dem FireTV zum laufen gebracht?
                                      Ich habe es auf zwei FireTV 4k max installiert, das war es dann aber auch schon ;-)
                                      App startet, ich kann via Postman Daten senden und bekomme 'ne 200 und die Response der Daten zurück, die ich gesendet habe.
                                      PopupProps(duration=30, position=TopLeft, backgroundColor=#ffffff, title=Your awesome title, titleSize=20.0, titleColor=#0066cc, message=What ever you want to say... do it here..., messageSize=14.0, messageColor=#000000, media=Image(uri=https://i.ebayimg.com/images/g/ZOkAAOSwgyZkfGxF/s-l1600.jpg, width=480))
                                      Auf dem FireTV passiert ziemlich genau,.... nichts.
                                      Dachte dann,..
                                      On Android TV (8.0+), when sideloading, you will need to set the permission for SYSTEM_ALERT_WINDOW manually (using adb) as there is no interface on Android TV to do this.
                                      To give the application the required permission to draw overlays you will need to run:
                                      Integrating
                                      würden helfen, aber nix.
                                      Wenn es schon mal jemand zum laufen gebacht hat, was fehlt bei mir?
                                      Muss adb shell appops set nl.rogro82.pipup SYSTEM_ALERT_WINDOW allow irgend eine response im Terminal ergeben?
                                      MyWay:
                                      Ich haben mir atvTools geladen, habe die PiPup apk geladen und auf den FireTV übertragen, installiert und geöffnet.
                                      In der Befehlskonsole von atvTools dann "adb shell appops set nl.rogro82.pipup SYSTEM_ALERT_WINDOW allow" eingegeben.
                                      Meines Verständnisses nach, hätte sich das popup öffnen müssen.
                                      Liebe Grüsse
                                      • stolly82S Offline
                                        stolly82S Offline
                                        stolly82
                                        schrieb am zuletzt editiert von stolly82
                                        #59
                                        Ich habe PiPup jetzt komplett implementiert, auch wieder mit dem "payload" request etc.
                                        Laut response klappt es, wie gesagt, bei mir kommt auf dem TV nichts an.
                                        Ich mache selten Fehler im Software Development, deshalb würde ich die 3.0.1 dann direkt hochladen zum review.
                                        wendy2702W L 2 Antworten Letzte Antwort
                                          wendy2702W Online
                                          wendy2702W Online
                                          wendy2702
                                          #60
                                          @stolly82 ich kann das morgen mal testen wenn ich zu Hause bin.
                                          Mein Pipup funktioniert ja auf nem Philips Android TV.
