  4. Node-Red
  5. Node red: Number in array wandel
7 Beiträge 3 Kommentatoren 808 Aufrufe 2 Beobachtet
  • Eckhard MeierE Offline
    Eckhard Meier
    Hallo stehe als Anfänger vor dem Problem wie ich msg. payload number in msg. payload Array[1] umwandeln kann.
    sprobstS mickymM 2 Antworten Letzte Antwort
    • Eckhard MeierE Eckhard Meier
      sprobstS Offline
      sprobstS Offline
      sprobst
      @eckhard-meier
      Ich würde das z.B. so machen (jsonata mit "[payload]"):
              "id": "74cca6de35f6da1e",
              "type": "inject",
              "z": "96298e588ffbd16d",
              "name": "number",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "test",
              "payload": "12",
              "payloadType": "num",
              "x": 290,
              "y": 480,
              "wires": [
                      "3739397f4e83c55f"
              "id": "3739397f4e83c55f",
              "type": "change",
              "name": "number -> array[0]",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "[ payload ]",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 490,
              "y": 480,
              "wires": [
                      "5a705a2010250aa6"
              "id": "5a705a2010250aa6",
              "type": "debug",
              "name": "output",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "statusType": "auto",
              "x": 670,
              "y": 480,
              "wires": []
      Sven
      Eckhard MeierE 1 Antwort Letzte Antwort
      • sprobstS sprobst
        @eckhard-meier
                "type": "inject",
                "name": "number",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "test",
                "payload": "12",
                "x": 290,
                "y": 480,
                "wires": [
                        "3739397f4e83c55f"
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 490,
                "y": 480,
                "wires": [
                        "5a705a2010250aa6"
                "type": "debug",
                "name": "output",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 670,
                "y": 480,
                "wires": []
        Sven
        Eckhard Meier
        @sprobst sorry ich bin wirklich blutiger Anfänger !!
        jetzt habe ich schon einmal die Meldung [object, object, objekt]
        wie greife ich auf das eine Feld zu ? Ich habe eine Nummer die ich umwandeln möchte
        sprobstS 1 Antwort Letzte Antwort
          mickymM Offline
          mickymM Offline
          mickym
          @eckhard-meier Du möchtest einfache ein normale Zahl in ein Array umwandeln? Wenn ja dann einfach wie unten vorgeschlagen machen. Auf ein Array greifst Du ganz normal zu. Also mit payload[<indexnummer>]
            sprobstS Offline
            sprobstS Offline
            sprobst
            @eckhard-meier Das mit [object,object,object] klingt komisch. Zeig mal deine Daten und beschreib mal was Du damit wirklich machen willst. Wozu brauchst Du ein Array aus einer Zahl?
            • sprobstS sprobst
              Eckhard Meier
              @sprobst es gibt das node calulator unter function und das Ergebnis möchte ich mit dem Node : modbus write
              in eine Wärmepumpe schreiben. Bis ist der out dvon dem calulator node= number
              und das modbus write note erwartet array ?
              Kann den output oder input umdefinieren ?
                sprobstS Offline
                sprobstS Offline
                sprobst
                @eckhard-meier Da bin ich raus, modbus hab ich nicht, aber nach der Doku brauchst Du das array nur wenn Du mehrere Register gleichzeitig schreiben willst. Klingt für mich so, als ob Du nur eins schreibst, das müsste dann nach meinem Doku-Verständnis mit FunctionCode 6 und dem Single-Wert gehen.
