  3. Einsteigerfragen
  4. Installation
  5. Raspberry PI3 Installation
Geplant Angeheftet Gesperrt Verschoben Installation
25 Beiträge 6 Kommentatoren 3.2k Aufrufe 5 Beobachtet
  • DJMarc75D DJMarc75
    @erik-graus sagte in Raspberry PI3 Installation:
    Werde morgen screenshots vom Log und Debug machen
    Bitte keine Screenshots von Text, sondern Text hier immer in Codetags einsetzen.
    erik.graus
    @djmarc75 Hier mal screenshots und log output :
    Plattform: Windows
    RAM: 3.9 GB
    Node.js: v21.1.0(21.2.0)
    NPM: 10.2.0
    Plattform: linux
    RAM: 971.5 MB
    Node.js: v16.19.1(16.20.2)
    NPM: v8.19.3(8.19.4)
    Log vom PI nach dem Skriptstart :
    2023-11-25 07:41:20.733 - info: host.iobroker-pi instance system.adapter.backitup.0 started with pid 1060
    2023-11-25 07:41:20.950 - info: admin.0 (1009) Repository received successfully.
    2023-11-25 07:41:22.028 - info: host.iobroker-pi instance system.adapter.web.0 started with pid 1071
    2023-11-25 07:41:22.138 - info: discovery.0 (1038) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
    2023-11-25 07:41:22.535 - info: javascript.0 (1032) starting. Version 7.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.1, js-controller: 4.0.24
    2023-11-25 07:41:23.249 - info: javascript.0 (1032) requesting all states
    2023-11-25 07:41:23.253 - info: javascript.0 (1032) requesting all objects
    2023-11-25 07:41:24.304 - info: javascript.0 (1032) received all objects
    2023-11-25 07:41:24.312 - info: javascript.0 (1032) received all states
    2023-11-25 07:41:26.287 - info: backitup.0 (1060) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
    2023-11-25 07:41:26.553 - info: backitup.0 (1060) [iobroker] backup was activated at 02:40 every 1 day(s)
    2023-11-25 07:41:27.206 - info: web.0 (1071) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.1, js-controller: 4.0.24
    2023-11-25 07:41:27.806 - info: web.0 (1071) socket.io server listening on port 8082
    2023-11-25 07:41:27.819 - info: web.0 (1071) http server listening on port 8082
    2023-11-25 07:44:23.878 - info: admin.0 (1009) ==> Connected system.user.admin from ::ffff:192.168.1.159
    2023-11-25 07:44:43.329 - info: admin.0 (1009) ==> Connected system.user.admin from ::ffff:192.168.1.159
    2023-11-25 07:44:50.536 - info: javascript.0 (1032) Start javascript script.js.Skript_1
    2023-11-25 07:44:50.822 - info: javascript.0 (1032) script.js.Skript_1: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    2023-11-25 07:44:51.095 - info: javascript.0 (1032) script.js.Skript_1: undefined
    2023-11-25 07:44:52.055 - info: javascript.0 (1032) script.js.Skript_1: undefined
    2023-11-25 07:44:53.066 - info: javascript.0 (1032) script.js.Skript_1: undefined
    2023-11-25 07:44:54.050 - info: javascript.0 (1032) script.js.Skript_1: undefined
    2023-11-25 07:44:54.585 - info: javascript.0 (1032) Stop script script.js.Skript_1
    2023-11-25 07:45:04.120 - info: admin.0 (1009) <== Disconnect system.user.admin from ::ffff:192.168.1.159 javascript
    Marc BergM HomoranH 2 Antworten Letzte Antwort
    • E erik.graus
      Plattform: Windows
      RAM: 3.9 GB
      NPM: 10.2.0
      Plattform: linux
      RAM: 971.5 MB
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      @erik-graus
      @djmarc75 sagte in Raspberry PI3 Installation:
      • E erik.graus
        Plattform: Windows
        RAM: 3.9 GB
        NPM: 10.2.0
        Plattform: linux
        RAM: 971.5 MB
        @erik-graus was genau möchtest du uns zeigen?
        Im zweiten (kleinen) Blockly ist das Ergebnis undefined weil du dir eine nicht definierte Variable test ausgeben willst.
        Dieser hast du keinen Wert zugeordnet.
        Das erste, längere Blockly ist im Screenshot unvollständig.
        Du startest alle 10 Sekunden.
        Was auch immer du dir da ausgeben lässt kommt aber in viel kürzeren Abständen.
        ohne das vollständige Blockly zu sehen kann man dazu nichts sagen.
        Das bisher gezeigte sollte aber nichts mit einer Installation auf einen Pi zu tun haben
        E 1 Antwort Letzte Antwort
          erik.graus
          @homoran Das erste Lange Blockly funktioniert.
          das kürzere ist nur den test. variabele Test ist angelegt und das gleiche kurze blockly funktioniert so auf Windows
          • E erik.graus
            Natürlich!
            aber kein Wert zugewiesen.
            kann es aber nicht.
