  3. Off Topic
  4. Fehler bei Docker Compose
    6.0k
7 Beiträge 2 Kommentatoren 684 Aufrufe 2 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    versuche mich heute zum ersten mal an Docker.
    Hab auch direkt etwas wo ich nicht weiter komme
    Hat da jemand eine Idee?
    admin@docker:~/planka$ docker-compose up -d
    Creating network "planka_default" with the default driver
    Pulling planka (ghcr.io/plankanban/planka:latest)...
    latest: Pulling from plankanban/planka
    7264a8db6415: Pulling fs layer                                7264a8db6415: Downloading [>                                  7264a8db6415: Downloading [========>                                          ]  589.8kB/3.402MB                            7264a8db6415: Downloading [================>                                  ]   1.11MB/3.402MB=>                          7264a8db6415: Pull complete                                   751194035c36: Pull complete                                   eff5dce73b38: Pull complete                                   c8ce5be43019: Pull complete                                   2b80ad872417: Pull complete                                   21247504e003: Extracting [==================================================>]  38.92kB/38.92kB                             ec429d873e05: Download complete                               0e408e6be231: Download complete                               a68a61c1b02d: Download complete                               b8f464d926f4: Download complete                               ==============> ]  15.66MB/15.78MB                            7ff87f19dac3: Download complete                               ERROR: failed to register layer: unlinkat /usr/include/python3.11: invalid argument
    Die Zeile 22 und 24 sind entsprechend angepasst.
    version: '3'
    services:
      planka:
        image: ghcr.io/plankanban/planka:latest
        command: >
          bash -c
            "for i in `seq 1 30`; do
              ./start.sh &&
              s=$$? && break || s=$$?;
              echo \"Tried $$i times. Waiting 5 seconds...\";
              sleep 5;
            done; (exit $$s)"
        restart: unless-stopped
        volumes:
          - user-avatars:/app/public/user-avatars
          - project-background-images:/app/public/project-background-images
          - attachments:/app/private/attachments
        ports:
          - 3000:1337
        environment:
          - BASE_URL=http://localhost:3000
          - DATABASE_URL=postgresql://postgres@postgres/planka
          - SECRET_KEY=notsecretkey
          # - TRUST_PROXY=0
          # - TOKEN_EXPIRES_IN=365 # In days
          # related: https://github.com/knex/knex/issues/2354
          # As knex does not pass query parameters from the connection string we
          # have to use environment variables in order to pass the desired values, e.g.
          # - PGSSLMODE=<value>
          # Configure knex to accept SSL certificates
          # - KNEX_REJECT_UNAUTHORIZED_SSL_CERTIFICATE=false
          # - DEFAULT_ADMIN_EMAIL=demo@demo.demo # Do not remove if you want to prevent this user from being edited/deleted
          # - DEFAULT_ADMIN_PASSWORD=demo
          # - DEFAULT_ADMIN_NAME=Demo Demo
          # - DEFAULT_ADMIN_USERNAME=demo
          # - OIDC_ISSUER=
          # - OIDC_CLIENT_ID=
          # - OIDC_CLIENT_SECRET=
          # - OIDC_SCOPES=openid email profile
          # - OIDC_ADMIN_ROLES=admin
          # - OIDC_ROLES_ATTRIBUTE=groups
          # - OIDC_IGNORE_ROLES=true
        depends_on:
          - postgres
      postgres:
        image: postgres:14-alpine
        volumes:
          - db-data:/var/lib/postgresql/data
        environment:
          - POSTGRES_DB=planka
          - POSTGRES_HOST_AUTH_METHOD=trust
    volumes:
      user-avatars:
      db-data:
    Hab ka wo hier der Github link her kommt...
    • David G.D David G.
      version: '3'
      services:
        planka:
          command: >
            bash -c
                ./start.sh &&
                sleep 5;
              done; (exit $$s)"
          volumes:
          ports:
            - 3000:1337
          environment:
            # - TRUST_PROXY=0
            # - OIDC_ISSUER=
            # - OIDC_CLIENT_ID=
          depends_on:
            - postgres
        postgres:
          volumes:
          environment:
      volumes:
        user-avatars:
        db-data:
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      @david-g sagte in Fehler bei Docker Compose:
      da her:
      Und zu deiner eigentlichen Frage: kannst du bitte näher erklären, was das Problem ist? Ich kann's aus der Beschreibung nicht rauslesen.
      Funktioniert bei mir mit deiner Compose Datei out-of-the box (nur der Port angepasst und die Base-URL).
      • Marc BergM Marc Berg
        da her:
        David G.D Online
        David G.D Online
        David G.
        @marc-berg
        Da steht der Link ^^.
        Bekomme am Ende die Fehlermeldung.
        Geht evtl in DEM Einzeiler oben was unter.
        Es wird kein Container angelegt.
        Über Portainer will es auch nicht klappen.
          @marc-berg
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          Ja, bis ans Ende hatte ich jetzt wirklich nicht gescrollt.
          Selbst habe ich keine Idee, Google sagt aber, dass ein privileged Container bei diesem Fehlerbild helfen soll. Was hast du für eine Umgebung?
            David G.D Online
            David G.D Online
            David G.
            @marc-berg
            Das hab ich auch grade im Moment gefunden.
            Hier im Thread:
            https://forum.proxmox.com/threads/docker-failed-to-register-layer-applylayer-exit-status-1-stdout-stderr-unlinkat-var-log-apt-invalid-argument.119954/
            Dort steht auch, dass von abgeraten wird Docker in einem lcx auszuführen.
            Aber für die 2-3 Kleinigkeiten die da laufen extra eine VM...
            • Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              Das würde ich so unterschreiben. Ein containerisierter Container kann nur in Problemen münden. :-)
                David G.D Online
                David G.D Online
                David G.
                Erledigt
