  5. Warmeldung und error im Javaskript und Admin.0
1 Beiträge 1 Kommentatoren 221 Aufrufe
  • F Offline
    Flopsi
    Hallo ich habe zwei neue Sensoren eingebunden jetzt bekomme ich jeden Tag folgenden error:
    2023-10-30 17:22:51.434	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":65,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334268930,"_id":"zwave2.0.Node_065.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-10-30 17:22:51.437	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334270043,"_id":"zwave2.0.Node_065.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-10-30 17:22:51.438	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269984,"_id":"zwave2.0.Node_065.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-10-30 17:22:51.438	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269209,"_id":"zwave2.0.Node_065.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-10-30 17:22:51.439	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":64,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812897069,"_id":"zwave2.0.Node_064.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-10-30 17:22:51.440	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698682109486}
    admin.0
    	2023-10-30 17:22:51.441	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698682110366}
    admin.0
    	2023-10-30 17:22:51.442	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812898332,"_id":"zwave2.0.Node_064.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    Ich habe folgendes Alias Skript:
    Github - https://github.com/xCruziX/ioBroker-Creating-Alias/blob/master/CreateAlias.js
    				Changelog
    Version 1.1.3
      - use callbacks in alias-path
    Version 1.1.2
      - fix log message 'Created Alias-Path '
    Version 1.1.1
      - Bugfixing, clean functions
    Version 1.1.0
      - added function for cleaning enums
    Version 1.0.6
      - use callback functions for safety call
    Version 1.0.5
      - decrease timeout assing enum
    Version 1.0.4
      - Bugfixing array id lenght
    Version 1.0.3
      - Githublink
    Version 1.0.2
      - existsObject for Alias in the timeout
      - remove lowerCase enum
      - improved logs
    Version 1.0.1
      - Rooms and functions casesensitive
    Version 1.0
    		Flags /
    		Variablen
    // typeAlias = 'boolean'; // oder 'number'
    // read = "val == 'Ein' ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
    // write = "val ? 'Ein' : 'Aus'";
    // nameAlias = 'Licht Haustür';
    // role = 'switch';
    // desc = 'per Script erstellt';
    // min = 0; // nur Zahlen
    // max = 100; // nur Zahlen
    // unit = '%'; // nur für Zahlen
    // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
    let bCreateAliasPath = false;  // If this flag is true, each folder is created seperately so rooms and functions can be assigned.
    Requirements: bCreateAliasPath == true
    If this flag is true, existing folders in the path will be converted so rooms and functions can be assigned.
    let bConvertExistingPath = false;
    	Don't change anything from here /
    	Ab hier nichts verändern
    let arEnum = [];
    let arId = [];
    let timeoutAssignEnum;
    function createAlias(idSrc, idDst,raum, gewerk,typeAlias, read, write, nameAlias, role, desc, min, max, unit, states) {
      if(!idDst.includes('alias.0.'))
          idDst = 'alias.0.' + idDst;
      if(!existsObject(idSrc))
          log('Source-Id ' + idSrc +' does not exists.','warn');
          return;
      // Create the object Path for alias id,
      // so you can assign rooms and function to the parents
      var createAliasPath = (id) => {
           if(bCreateAliasPath){
                let lisMergedIds = [];
                let mergedId = 'alias.0';
                id = id.replace(mergedId + '.', ''); // Remove prefix alias so it will not be changed
                let split = id.split('.');
                for(let i=0;i<split.length-1;i++){
                    mergedId += '.' + split[i];
                    lisMergedIds.push(mergedId);
                function path(){
                    if(lisMergedIds.length == 0) {// Zu Ende erstellt
                        alias();
                        return;
                    let tmpId = lisMergedIds[0];
                    lisMergedIds.splice(0,1); // entferne element
                    if(!existsObject(tmpId) || bConvertExistingPath){ // not exists
                        let obj;
                        if(existsObject(tmpId))
                            obj = getObject(tmpId);
                        else
                            obj = {};
                        if(obj.type == undefined || obj.type != 'meta')
                            obj.type = 'meta';
                        if(obj.common == undefined || obj.common != {})
                            obj.common = {};
                        if(obj.common.type == undefined || obj.common.type != 'meta.folder')
                            obj.common.type = 'meta.folder';
                        if(obj.common.desc == undefined || obj.common.desc != 'createAliasPath')
                            obj.common.desc = 'createAliasPath';
                        if(obj.common.def == undefined || obj.common.def != false)
                            obj.common.def = false;
                        if(obj.native == undefined || obj.native != {})
                            obj.native = {};
                        setObject(tmpId, obj, (err) =>{
                            if(!err){
                                log('Created Alias-Path ' + tmpId);
                                path();
                            else
                                log('Error creating alias-path','error');
                path();
           else
             alias();
        //   createAliasPath(idDst);
      function alias(){
          // Create alias object
            if(!existsObject(idDst)){
                let obj = {};
                obj.type = 'state';
                obj.common = getObject(idSrc).common;
                obj.common.alias = {};
                obj.common.alias.id = idSrc;
                if(typeAlias !== undefined)
                    obj.common.type = typeAlias;
                if(obj.common.read !== undefined)
                    obj.common.alias.read = read;
                if(obj.common.write !== undefined)
                    obj.common.alias.write = write;
                if(nameAlias !== undefined)
                    obj.common.name = nameAlias;
                if(role !== undefined)
                    obj.common.role = role;
                if(desc !== undefined)
                    obj.common.desc = desc;
                if(min !== undefined)
                    obj.common.min = min;
                if(max !== undefined)
                    obj.common.max = max;
                if(unit !== undefined)
                    obj.common.unit = unit;
                if(states !== undefined)
                    obj.common.states = states;
                obj.native = {};
                obj.common.custom = []; // Damit die Zuordnung zu iQontrol, Sql etc. nicht übernommen wird
                log('Created Alias-State ' + idDst);
                setObject(idDst, obj,(err) =>{
                    if(!err)
                        startAttach();
                    else
                        log('Error creating-alias','error');
            else
                startAttach();
      // Save ID and Enum (room or function)
      var attach = (id, enu,value) => {
          if(id.length == 0){
              log('ID has lenght 0, can not attach to enum','warn');
              return;
          if(value.length == 0){
              log('Value has lenght 0','warn');
              return;
          let sEnuId = 'enum.' + enu + '.' + value;
          if(enu.length > 0 && existsObject(sEnuId))
              let obj = getObject(sEnuId)
              let members = obj.common.members;
              if(!members.includes(id)){
                  arEnum.push(sEnuId);
                  arId.push(id);
          else
       	      log('Can not find enum ' + sEnuId,'warn');
     function startAttach(){
        let bRoom = raum !== undefined && raum.length > 0;
        let bGewerk = gewerk !== undefined && gewerk.length > 0;
        if(bRoom)
            attach(idDst,'rooms',raum);
        if(bGewerk)
            attach(idDst,'functions',gewerk);
        if(bRoom || bGewerk){
                if(timeoutAssignEnum){
                    clearTimeout(timeoutAssignEnum);
                    timeoutAssignEnum = null;
                timeoutAssignEnum = setTimeout(finishScript,100);
    function finishScript(){
    	assignEnums();
    // Add the saved IDs to the rooms/functions
    function assignEnums(){
     if(arEnum.length == 0 || arId.length == 0){
          return;
     if(arEnum.length != arId.length){
          log('Arrays have different size','error');
          return;
     let mapEnumId = new Map();
     for(let i=0;i < arEnum.length; i++){
         let enu = arEnum[i];
         let id = arId[i];
         if(existsObject(id)){
        	 let obj = getObject(enu)
        	 let members;
        	 if(!mapEnumId.has(enu)){
        		 mapEnumId.set(enu,members);
        	 else
        		 members = mapEnumId.get(enu);
        		  log("Adding " + id + " to " + enu);
        		  members.push(id);
         else
             log('Can not find Alias ' + id,'error');
      function setMembers(members,enu,map){
          let obj = getObject(enu);
          obj.common.members = members;
          setObject(enu,obj);
      mapEnumId.forEach(setMembers);
    Und dann bekomme ich noch folgende Fehlermeldung (Warung) im Javaskript:
    javascript.0
    	2023-10-30 17:16:14.634	warn	State "alias.0.Wohnzimmer.Alexa.speak" not found
    javascript.0
    	2023-10-30 17:16:14.644	warn	at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    javascript.0
    	2023-10-30 17:16:14.645	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1798:29)
    javascript.0
    	2023-10-30 17:16:14.646	warn	at listOnTimeout (node:internal/timers:571:11)
    javascript.0
    	2023-10-30 17:16:14.646	warn	at processTimers (node:internal/timers:512:7)
    javascript.0
    	2023-10-30 17:16:33.661	warn	State "alias.0.Wohnzimmer.Alexa.speak" not found
    javascript.0
    	2023-10-30 17:16:33.662	warn	at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    javascript.0
    	2023-10-30 17:16:33.663	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1798:29)
    javascript.0
    	2023-10-30 17:16:33.663	warn	at listOnTimeout (node:internal/timers:571:11)
    javascript.0
    	2023-10-30 17:16:33.663	warn	at processTimers (node:internal/timers:512:7)
    Ich bin mein Skripte mehrfach durchgegangen finden aber den Datenpunkt nicht:
    Hat wer einen Tip für mich ?
